[PATCH v4 0/2] k3-am625-beagleplay: Add symlinks for tiboot3 and tispl
Add symlinks for both tiboot3.bin and tispl.bin because a user has to anyway rename these files to get the platform to boot up. Also update the documentation to reflect above change.
Changes in v4: * Add the docs patch.
Cc: Nishant Menon nm@ti.com Cc: Robert Nelson robertcnelson@gmail.com
Dhruva Gole (2): arm: dts: k3-am625-beagleplay: Add symlinks for tiboot3 and tispl doc: beagle: am62x_beagleplay: Rename the boot bins
arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 1 + arch/arm/dts/k3-am625-r5-beagleplay.dts | 1 + doc/board/beagle/am62x_beagleplay.rst | 7 +++---- 3 files changed, 5 insertions(+), 4 deletions(-)
base-commit: 16324b43db3f2b4fbbc3b701893fcfc4104f33fb
Add symlinks for both tiboot3.bin and tispl.bin because a user has to anyway rename these files to get the platform to boot up. This just makes it more intuitive and convenient.
Reviewed-by: Manorit Chawdhry m-chawdhry@ti.com Signed-off-by: Dhruva Gole d-gole@ti.com --- arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 1 + arch/arm/dts/k3-am625-r5-beagleplay.dts | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index fb2032068d1c..bd48af8d186a 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -71,6 +71,7 @@
ti-spl_unsigned { filename = "tispl.bin_unsigned"; + symlink = "tispl.bin"; pad-byte = <0xff>;
fit { diff --git a/arch/arm/dts/k3-am625-r5-beagleplay.dts b/arch/arm/dts/k3-am625-r5-beagleplay.dts index 9db58f093c8c..da6746e009d5 100644 --- a/arch/arm/dts/k3-am625-r5-beagleplay.dts +++ b/arch/arm/dts/k3-am625-r5-beagleplay.dts @@ -79,6 +79,7 @@ &binman { tiboot3-am62x-gp-evm.bin { filename = "tiboot3-am62x-gp-evm.bin"; + symlink = "tiboot3.bin"; ti-secure-rom { content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>;
Rename the boot bins as the _unsigned postfixes are not longer required. We have symlinks in place for having generic names for all the boot bins now.
Signed-off-by: Dhruva Gole d-gole@ti.com --- doc/board/beagle/am62x_beagleplay.rst | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/doc/board/beagle/am62x_beagleplay.rst b/doc/board/beagle/am62x_beagleplay.rst index 7784e62b0b71..f5a85dd1fb82 100644 --- a/doc/board/beagle/am62x_beagleplay.rst +++ b/doc/board/beagle/am62x_beagleplay.rst @@ -71,11 +71,10 @@ Set the variables corresponding to this platform:
Target Images ------------- -Copy the below images to an SD card and boot: +Copy these images to an SD card and boot:
-* tiboot3-am62x-gp-evm.bin from R5 build as tiboot3.bin -* tispl.bin_unsigned from Cortex-A build as tispl.bin -* u-boot.img_unsigned from Cortex-A build as u-boot.img +* tiboot3.bin from Cortex-R5 build. +* tispl.bin and u-boot.img from Cortex-A build
Image formats -------------
Changes in v4:
- Add the docs patch.
Robert/Jason:
Can you folks confirm that we will ONLY have GP version of BeaglePlay for even a new update of the board? If that is confirmed, then this series is good.
Any thoughts?
Changes in v4:
Robert/Jason:
Any thoughts?
Yeap pretty sure the BeaglePlay will ONLY ever use the GP version.
I know there is a list of wants for BeaglePlay2, cc33xx WiFi, the newer ITE HDMI encoder (oh wait, BeagleY-AI)...
Regards,
Changes in v4:
Robert/Jason:
Any thoughts?
Alright. thanks.
Changes in v4:
Dhruva Gole
Nishanth Menon
Robert Nelson
