[U-Boot] [Patch V2 0/3] LS1043AQDS related patches
Hi all,
The version 2 patchset has:
- Fixed some format issues according to the comments. - Changed the core frequency to 1600M for SD boot with QSPI support.
Also note that to apply the patchset and work well on LS1043AQDS board, it depends on the QSPI&I2C driver bug fixing and QIXIS patchsets that I have already sent out and are still under review.
[Patch V2 1/3] armv8/ls1043aqds: add DSPI support [Patch V2 2/3] armv8/ls1043aqds: add QSPI support in SD boot [Patch V2 3/3] armv8/ls1043aqds: add QSPI boot support
Regards, Qianyu
Enable three DSPI flash memories on board.
Commands: => sf probe 1:0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB => sf probe 1:1 SF: Detected SST25WF040B with page size 256 Bytes, erase size 4 KiB, total 512 KiB => sf probe 1:2 SF: Detected EN25S64 with page size 256 Bytes, erase size 64 KiB, total 8 MiB
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V2: - Remove blank line and add necessary blank lines.
arch/arm/dts/fsl-ls1043a-qds.dts | 32 ++++++++++++++++++++++++++++++++ configs/ls1043aqds_defconfig | 3 +++ configs/ls1043aqds_nand_defconfig | 5 +++++ configs/ls1043aqds_sdcard_ifc_defconfig | 5 +++++ include/configs/ls1043a_common.h | 12 ++++++++++++ include/configs/ls1043ardb.h | 10 ---------- 6 files changed, 57 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1043a-qds.dts b/arch/arm/dts/fsl-ls1043a-qds.dts index 7435222..93d73a6 100644 --- a/arch/arm/dts/fsl-ls1043a-qds.dts +++ b/arch/arm/dts/fsl-ls1043a-qds.dts @@ -15,6 +15,38 @@
/ { model = "LS1043A QDS Board"; + aliases { + spi1 = &dspi0; + }; +}; + +&dspi0 { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <2>; + }; };
&i2c0 { diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 60fb0ad..5b12632 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -4,3 +4,6 @@ CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_NS16550=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index e9d5afd..d4f758c 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -3,3 +3,8 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_NS16550=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 6765d3d..25ae9cc 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -3,3 +3,8 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_NS16550=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 677d281..38e5b9b 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -197,6 +197,18 @@ #define CONFIG_DOS_PARTITION #endif
+/* DSPI */ +#define CONFIG_FSL_DSPI +#ifdef CONFIG_FSL_DSPI +#define CONFIG_CMD_SF +#define CONFIG_DM_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO /* cs0 */ +#define CONFIG_SPI_FLASH_SST /* cs1 */ +#define CONFIG_SPI_FLASH_EON /* cs2 */ +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#endif + /* FMan ucode */ #define CONFIG_SYS_DPAA_FMAN #ifdef CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 585114f..f768348 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -222,16 +222,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-/* DSPI */ -#define CONFIG_FSL_DSPI -#ifdef CONFIG_FSL_DSPI -#define CONFIG_CMD_SF -#define CONFIG_DM_SPI_FLASH -#define CONFIG_SPI_FLASH_STMICRO -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 -#endif - /* * Environment */
QSPI and IFC are pin-multiplexed on LS1043A. So we use ls1043aqds_sdcard_ifc_defconfig to support IFC in SD boot and ls1043aqds_sdcard_qspi_defconfig to support QSPI in SD boot. If QSPI is enabled, IFC should be disabled in kernel as well.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V2: - Modified rcw file to change core frequency to 1600MHz for SD_BOOT_QSPI.
arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 5 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 3 +++ arch/arm/dts/fsl-ls1043a-qds.dts | 14 +++++++++++++ arch/arm/dts/fsl-ls1043a.dtsi | 11 +++++++++++ board/freescale/ls1043aqds/MAINTAINERS | 1 + .../ls1043aqds/ls1043aqds_rcw_sd_qspi.cfg | 8 ++++++++ configs/ls1043aqds_sdcard_qspi_defconfig | 10 ++++++++++ include/configs/ls1043a_common.h | 13 ++++++++++++ include/configs/ls1043aqds.h | 23 ++++++++++++++++++++++ 9 files changed, 88 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index eafdd71..a247510 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -201,4 +201,9 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_FSL_LSCH3 fdt_fixup_smmu(blob); #endif + +#ifdef CONFIG_FSL_QSPI + do_fixup_by_compat(blob, "fsl,ifc", + "status", "disabled", 8 + 1, 1); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 23d6b73..4b1f792 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -219,6 +219,9 @@ void fsl_lsch2_early_init_f(void) init_early_memctl_regs(); /* tighten IFC timing */ #endif
+#ifdef CONFIG_FSL_QSPI + out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); +#endif /* Make SEC reads and writes snoopable */ setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP | SCFG_SNPCNFGCR_SECWRSNP); diff --git a/arch/arm/dts/fsl-ls1043a-qds.dts b/arch/arm/dts/fsl-ls1043a-qds.dts index 93d73a6..9916f1b 100644 --- a/arch/arm/dts/fsl-ls1043a-qds.dts +++ b/arch/arm/dts/fsl-ls1043a-qds.dts @@ -16,6 +16,7 @@ / { model = "LS1043A QDS Board"; aliases { + spi0 = &qspi; spi1 = &dspi0; }; }; @@ -49,6 +50,19 @@ }; };
+&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fl128s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + &i2c0 { status = "okay"; pca9547@77 { diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index 85ea81e..f83cc3e 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -182,5 +182,16 @@ interrupts = <0 55 0x4>; clocks = <&clockgen 4 0>; }; + + qspi: quadspi@1550000 { + compatible = "fsl,vf610-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x1550000 0x10000>, + <0x40000000 0x4000000>; + num-cs = <2>; + big-endian; + status = "disabled"; + }; }; }; diff --git a/board/freescale/ls1043aqds/MAINTAINERS b/board/freescale/ls1043aqds/MAINTAINERS index 0c7f648..868bb72 100644 --- a/board/freescale/ls1043aqds/MAINTAINERS +++ b/board/freescale/ls1043aqds/MAINTAINERS @@ -7,3 +7,4 @@ F: configs/ls1043aqds_defconfig F: configs/ls1043aqds_nor_ddr3_defconfig F: configs/ls1043aqds_nand_defconfig F: configs/ls1043aqds_sdcard_ifc_defconfig +F: configs/ls1043aqds_sdcard_qspi_defconfig diff --git a/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_qspi.cfg b/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_qspi.cfg new file mode 100644 index 0000000..7783521 --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_qspi.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +# Enable QSPI; disable IFC +08100010 0a000000 00000000 00000000 +14550002 80004012 60040000 c1002000 +00000000 00000000 00000000 00038800 +20124000 00001100 00000096 00000001 diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig new file mode 100644 index 0000000..37e8b3c --- /dev/null +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -0,0 +1,10 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" +CONFIG_SYS_NS16550=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 38e5b9b..707405c 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -121,6 +121,7 @@ #endif
/* IFC */ +#ifndef CONFIG_SD_BOOT_QSPI #define CONFIG_FSL_IFC /* * CONFIG_SYS_FLASH_BASE has the final address (core view) @@ -139,6 +140,7 @@ #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ #endif +#endif
/* I2C */ #define CONFIG_CMD_I2C @@ -205,18 +207,29 @@ #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ #define CONFIG_SPI_FLASH_SST /* cs1 */ #define CONFIG_SPI_FLASH_EON /* cs2 */ +#ifndef CONFIG_SD_BOOT_QSPI #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_CS 0 #endif +#endif
/* FMan ucode */ #define CONFIG_SYS_DPAA_FMAN #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_FM_MURAM_SIZE 0x60000
+#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 1000000 +#define CONFIG_ENV_SPI_MODE 0x03 +#else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR /* FMan fireware Pre-load address */ #define CONFIG_SYS_FMAN_FW_ADDR 0x60300000 +#endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) #endif diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 43107b0..cb519e1 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -85,8 +85,12 @@ unsigned long get_board_ddr_clk(void); #endif
#ifdef CONFIG_SD_BOOT +#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043aqds/ls1043aqds_rcw_sd_qspi.cfg +#else #define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg #endif +#endif
/* SATA */ #define CONFIG_LIBATA @@ -108,6 +112,7 @@ unsigned long get_board_ddr_clk(void); /* * IFC Definitions */ +#ifndef CONFIG_SD_BOOT_QSPI #define CONFIG_SYS_NOR0_CSPR_EXT (0x0) #define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ CSPR_PORT_SIZE_16 | \ @@ -191,6 +196,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_NAND
#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#endif
#ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ @@ -198,6 +204,12 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) #endif
+#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_QIXIS_I2C_ACCESS +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS +#endif + /* * QIXIS Definitions */ @@ -214,6 +226,7 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_ALTBANK 0x04 #define QIXIS_LBMAP_NAND 0x09 #define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0xff #define QIXIS_RCW_SRC_NAND 0x106 #define QIXIS_RCW_SRC_SD 0x040 #define QIXIS_RST_CTL_RESET 0x41 @@ -342,6 +355,16 @@ unsigned long get_board_ddr_clk(void); #define VDD_MV_MIN 819 #define VDD_MV_MAX 1212
+/* QSPI device */ +#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_FSL_QSPI +#ifdef CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_NUM 2 +#endif +#endif + /* * Miscellaneous configurable options */
Enable the U-Boot Driver Model(DM) to use the Freescale QSPI driver.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V2: - No change.
arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 ++ board/freescale/ls1043aqds/MAINTAINERS | 1 + board/freescale/ls1043aqds/README | 1 + board/freescale/ls1043aqds/ls1043aqds.c | 7 +++++++ configs/ls1043aqds_qspi_defconfig | 9 +++++++++ include/configs/ls1043a_common.h | 6 +++--- include/configs/ls1043aqds.h | 15 ++++++++++++--- 7 files changed, 35 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index e030430..f2f1206 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -150,6 +150,8 @@ static const struct sys_mmu_table early_mmu_table[] = { { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE | PMD_SECT_PXN | PMD_SECT_UXN }, + { CONFIG_SYS_FSL_QSPI_BASE, CONFIG_SYS_FSL_QSPI_BASE, + CONFIG_SYS_FSL_QSPI_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, diff --git a/board/freescale/ls1043aqds/MAINTAINERS b/board/freescale/ls1043aqds/MAINTAINERS index 868bb72..65a0af1 100644 --- a/board/freescale/ls1043aqds/MAINTAINERS +++ b/board/freescale/ls1043aqds/MAINTAINERS @@ -8,3 +8,4 @@ F: configs/ls1043aqds_nor_ddr3_defconfig F: configs/ls1043aqds_nand_defconfig F: configs/ls1043aqds_sdcard_ifc_defconfig F: configs/ls1043aqds_sdcard_qspi_defconfig +F: configs/ls1043aqds_qspi_defconfig diff --git a/board/freescale/ls1043aqds/README b/board/freescale/ls1043aqds/README index 6261a77..a6fd7a3 100644 --- a/board/freescale/ls1043aqds/README +++ b/board/freescale/ls1043aqds/README @@ -94,3 +94,4 @@ a) Promjet Boot b) NOR boot c) NAND boot d) SD boot +e) QSPI boot diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index d6696ca..770b79f 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -43,15 +43,19 @@ enum {
int checkboard(void) { +#ifndef CONFIG_QSPI_BOOT char buf[64]; #ifndef CONFIG_SD_BOOT u8 sw; #endif +#endif
puts("Board: LS1043AQDS, boot from ");
#ifdef CONFIG_SD_BOOT puts("SD\n"); +#elif defined(CONFIG_QSPI_BOOT) + puts("QSPI\n"); #else sw = QIXIS_READ(brdcfg[0]); sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; @@ -68,12 +72,15 @@ int checkboard(void) printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); #endif
+#ifndef CONFIG_QSPI_BOOT + /* For QSPI boot, here I2C is not ready yet. */ printf("Sys ID: 0x%02x, Sys Ver: 0x%02x\n", QIXIS_READ(id), QIXIS_READ(arch));
printf("FPGA: v%d (%s), build %d\n", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); +#endif
return 0; } diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig new file mode 100644 index 0000000..fcbaf31 --- /dev/null +++ b/configs/ls1043aqds_qspi_defconfig @@ -0,0 +1,9 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,QSPI_BOOT" +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" +CONFIG_SYS_NS16550=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 707405c..afddedc 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -121,7 +121,7 @@ #endif
/* IFC */ -#ifndef CONFIG_SD_BOOT_QSPI +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_FSL_IFC /* * CONFIG_SYS_FLASH_BASE has the final address (core view) @@ -207,7 +207,7 @@ #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ #define CONFIG_SPI_FLASH_SST /* cs1 */ #define CONFIG_SPI_FLASH_EON /* cs2 */ -#ifndef CONFIG_SD_BOOT_QSPI +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_CS 0 #endif @@ -218,7 +218,7 @@ #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_FM_MURAM_SIZE 0x60000
-#ifdef CONFIG_SD_BOOT_QSPI +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_QE_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 #define CONFIG_ENV_SPI_BUS 0 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index cb519e1..e01f06d 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -14,6 +14,8 @@
#if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) #define CONFIG_SYS_TEXT_BASE 0x82000000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_TEXT_BASE 0x40010000 #else #define CONFIG_SYS_TEXT_BASE 0x60100000 #endif @@ -112,7 +114,7 @@ unsigned long get_board_ddr_clk(void); /* * IFC Definitions */ -#ifndef CONFIG_SD_BOOT_QSPI +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_NOR0_CSPR_EXT (0x0) #define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ CSPR_PORT_SIZE_16 | \ @@ -204,7 +206,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) #endif
-#ifdef CONFIG_SD_BOOT_QSPI +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_QIXIS_I2C_ACCESS #define CONFIG_SYS_NO_FLASH #undef CONFIG_CMD_IMLS @@ -227,8 +229,10 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_NAND 0x09 #define QIXIS_LBMAP_SD 0x00 #define QIXIS_LBMAP_SD_QSPI 0xff +#define QIXIS_LBMAP_QSPI 0xff #define QIXIS_RCW_SRC_NAND 0x106 #define QIXIS_RCW_SRC_SD 0x040 +#define QIXIS_RCW_SRC_QSPI 0x045 #define QIXIS_RST_CTL_RESET 0x41 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 @@ -356,7 +360,7 @@ unsigned long get_board_ddr_clk(void); #define VDD_MV_MAX 1212
/* QSPI device */ -#ifdef CONFIG_SD_BOOT_QSPI +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION @@ -415,6 +419,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000)
Gong Qianyu
