[RESEND PATCH v2 0/2] mtd: spi-nor-ids: Add NO_CHIP_ERASE flag to Infineon 2Gb parts
S25HS02GT, S25HL02GT, and S28HS02GT are dual-die package parts and do not support chip erase.
In v2, split the patch and add fixes tag.
Takahiro Kuwano (2): mtd: spi-nor-ids: Add NO_CHIP_ERASE flag to Infineon s25hl02Gt and s25hs02gt mtd: spi-nor-ids: Add NO_CHIP_ERASE flag to Infineon s28hs02gt
drivers/mtd/spi/spi-nor-ids.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
S25HL02GT and S25HS02GT are dual-die package parts and do not support chip erase.
Fixes: c95a914aed7 ("mtd: spi-nor-ids: Add Cypress s25hl-t/s25hs-t") Reviewed-by: Tudor Ambarus tudor.ambarus@linaro.org Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- drivers/mtd/spi/spi-nor-ids.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 9693c179b7e..3270ebb533c 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -372,7 +372,7 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, { INFO6("s25hl02gt", 0x342a1c, 0x0f0090, 256 * 1024, 1024, - SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | NO_CHIP_ERASE) }, { INFO6("s25hs512t", 0x342b1a, 0x0f0390, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, @@ -380,7 +380,7 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, { INFO6("s25hs02gt", 0x342b1c, 0x0f0090, 256 * 1024, 1024, - SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | NO_CHIP_ERASE) }, { INFO6("s25fs256t", 0x342b19, 0x0f0890, 128 * 1024, 256, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, #ifdef CONFIG_SPI_FLASH_S28HX_T
S28HS02GT is dual-die package parts and do not support chip erase.
Fixes: 16dd1095101 ("mtd: spi-nor-ids: Add Infineon(Cypress) s28hs02gt ID") Reviewed-by: Tudor Ambarus tudor.ambarus@linaro.org Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- drivers/mtd/spi/spi-nor-ids.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 3270ebb533c..4e7e89eb65a 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -388,7 +388,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s28hl01gt", 0x345a1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, { INFO("s28hs512t", 0x345b1a, 0, 256 * 1024, 256, SPI_NOR_OCTAL_DTR_READ) }, { INFO("s28hs01gt", 0x345b1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, - { INFO("s28hs02gt", 0x345b1c, 0, 256 * 1024, 1024, SPI_NOR_OCTAL_DTR_READ) }, + { INFO("s28hs02gt", 0x345b1c, 0, 256 * 1024, 1024, SPI_NOR_OCTAL_DTR_READ | NO_CHIP_ERASE) }, #endif #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */
