[PATCH 0/4] clk: exynos: Prepare clocks for eMMC enablement
This short series features a couple of Exynos850 clock driver fixes and adds new clocks needed for further eMMC and SD card enablement.
Sam Protsenko (4): clk: exynos: Re-arrange clocks in Exynos850 CMU_TOP clk: exynos: Don't expose prototypes for not used functions clk: exynos: Fix incorrect clock lookup for non-top CMUs clk: exynos: Add CMU_CORE and CMU_HSI for Exynos850
drivers/clk/exynos/clk-exynos850.c | 326 ++++++++++++++++++++++++++--- drivers/clk/exynos/clk-pll.c | 6 +- drivers/clk/exynos/clk-pll.h | 6 + drivers/clk/exynos/clk.c | 47 +++-- drivers/clk/exynos/clk.h | 70 +++++-- 5 files changed, 384 insertions(+), 71 deletions(-)
Group CMU_TOP clocks to make it easier to add the support for more CMUs. No functional change.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/clk/exynos/clk-exynos850.c | 56 ++++++++++++++++-------------- 1 file changed, 30 insertions(+), 26 deletions(-)
diff --git a/drivers/clk/exynos/clk-exynos850.c b/drivers/clk/exynos/clk-exynos850.c index cf94a3e1b646..de4170cdc2f3 100644 --- a/drivers/clk/exynos/clk-exynos850.c +++ b/drivers/clk/exynos/clk-exynos850.c @@ -35,16 +35,7 @@ #define CLK_CON_GAT_GATE_CLKCMU_PERI_IP 0x2084 #define CLK_CON_GAT_GATE_CLKCMU_PERI_UART 0x2088
-static const struct samsung_pll_clock top_pure_pll_clks[] = { - PLL(pll_0822x, CLK_FOUT_SHARED0_PLL, "fout_shared0_pll", "clock-oscclk", - PLL_CON3_PLL_SHARED0), - PLL(pll_0822x, CLK_FOUT_SHARED1_PLL, "fout_shared1_pll", "clock-oscclk", - PLL_CON3_PLL_SHARED1), - PLL(pll_0831x, CLK_FOUT_MMC_PLL, "fout_mmc_pll", "clock-oscclk", - PLL_CON3_PLL_MMC), -}; - -/* List of parent clocks for Muxes in CMU_TOP */ +/* List of parent clocks for Muxes in CMU_TOP: for PURECLKCOMP */ PNAME(mout_shared0_pll_p) = { "clock-oscclk", "fout_shared0_pll" }; PNAME(mout_shared1_pll_p) = { "clock-oscclk", "fout_shared1_pll" }; PNAME(mout_mmc_pll_p) = { "clock-oscclk", "fout_mmc_pll" }; @@ -55,6 +46,17 @@ PNAME(mout_peri_uart_p) = { "clock-oscclk", "dout_shared0_div4", PNAME(mout_peri_ip_p) = { "clock-oscclk", "dout_shared0_div4", "dout_shared1_div4", "clock-oscclk" };
+/* PURECLKCOMP */ + +static const struct samsung_pll_clock top_pure_pll_clks[] = { + PLL(pll_0822x, CLK_FOUT_SHARED0_PLL, "fout_shared0_pll", "clock-oscclk", + PLL_CON3_PLL_SHARED0), + PLL(pll_0822x, CLK_FOUT_SHARED1_PLL, "fout_shared1_pll", "clock-oscclk", + PLL_CON3_PLL_SHARED1), + PLL(pll_0831x, CLK_FOUT_MMC_PLL, "fout_mmc_pll", "clock-oscclk", + PLL_CON3_PLL_MMC), +}; + static const struct samsung_mux_clock top_pure_mux_clks[] = { MUX(CLK_MOUT_SHARED0_PLL, "mout_shared0_pll", mout_shared0_pll_p, PLL_CON0_PLL_SHARED0, 4, 1), @@ -64,15 +66,6 @@ static const struct samsung_mux_clock top_pure_mux_clks[] = { PLL_CON0_PLL_MMC, 4, 1), };
-static const struct samsung_mux_clock top_peri_mux_clks[] = { - MUX(CLK_MOUT_PERI_BUS, "mout_peri_bus", mout_peri_bus_p, - CLK_CON_MUX_MUX_CLKCMU_PERI_BUS, 0, 1), - MUX(CLK_MOUT_PERI_UART, "mout_peri_uart", mout_peri_uart_p, - CLK_CON_MUX_MUX_CLKCMU_PERI_UART, 0, 2), - MUX(CLK_MOUT_PERI_IP, "mout_peri_ip", mout_peri_ip_p, - CLK_CON_MUX_MUX_CLKCMU_PERI_IP, 0, 2), -}; - static const struct samsung_div_clock top_pure_div_clks[] = { DIV(CLK_DOUT_SHARED0_DIV3, "dout_shared0_div3", "mout_shared0_pll", CLK_CON_DIV_PLL_SHARED0_DIV3, 0, 2), @@ -88,13 +81,15 @@ static const struct samsung_div_clock top_pure_div_clks[] = { CLK_CON_DIV_PLL_SHARED1_DIV4, 0, 1), };
-static const struct samsung_div_clock top_peri_div_clks[] = { - DIV(CLK_DOUT_PERI_BUS, "dout_peri_bus", "gout_peri_bus", - CLK_CON_DIV_CLKCMU_PERI_BUS, 0, 4), - DIV(CLK_DOUT_PERI_UART, "dout_peri_uart", "gout_peri_uart", - CLK_CON_DIV_CLKCMU_PERI_UART, 0, 4), - DIV(CLK_DOUT_PERI_IP, "dout_peri_ip", "gout_peri_ip", - CLK_CON_DIV_CLKCMU_PERI_IP, 0, 4), +/* PERI */ + +static const struct samsung_mux_clock top_peri_mux_clks[] = { + MUX(CLK_MOUT_PERI_BUS, "mout_peri_bus", mout_peri_bus_p, + CLK_CON_MUX_MUX_CLKCMU_PERI_BUS, 0, 1), + MUX(CLK_MOUT_PERI_UART, "mout_peri_uart", mout_peri_uart_p, + CLK_CON_MUX_MUX_CLKCMU_PERI_UART, 0, 2), + MUX(CLK_MOUT_PERI_IP, "mout_peri_ip", mout_peri_ip_p, + CLK_CON_MUX_MUX_CLKCMU_PERI_IP, 0, 2), };
static const struct samsung_gate_clock top_peri_gate_clks[] = { @@ -106,6 +101,15 @@ static const struct samsung_gate_clock top_peri_gate_clks[] = { CLK_CON_GAT_GATE_CLKCMU_PERI_IP, 21, 0, 0), };
+static const struct samsung_div_clock top_peri_div_clks[] = { + DIV(CLK_DOUT_PERI_BUS, "dout_peri_bus", "gout_peri_bus", + CLK_CON_DIV_CLKCMU_PERI_BUS, 0, 4), + DIV(CLK_DOUT_PERI_UART, "dout_peri_uart", "gout_peri_uart", + CLK_CON_DIV_CLKCMU_PERI_UART, 0, 4), + DIV(CLK_DOUT_PERI_IP, "dout_peri_ip", "gout_peri_ip", + CLK_CON_DIV_CLKCMU_PERI_IP, 0, 4), +}; + static const struct samsung_clk_group top_cmu_clks[] = { /* CMU_TOP_PURECLKCOMP */ { S_CLK_PLL, top_pure_pll_clks, ARRAY_SIZE(top_pure_pll_clks) },
Samsung CCF is meant to be used from the clock drivers by calling the CMU registration API, i.e.: - samsung_cmu_register_one() -- for top-level CMU - samsung_register_cmu() -- for the rest of CMUs
Functions for registering separate clocks is probably not going to be very useful, and isn't used at the moment. Remove prototypes of those functions to make the Samsung CCF interface more compact and clear.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/clk/exynos/clk-pll.h | 6 ++++++ drivers/clk/exynos/clk.c | 12 ++++++------ drivers/clk/exynos/clk.h | 16 ---------------- 3 files changed, 12 insertions(+), 22 deletions(-)
diff --git a/drivers/clk/exynos/clk-pll.h b/drivers/clk/exynos/clk-pll.h index bd79309fa1cf..00c750687072 100644 --- a/drivers/clk/exynos/clk-pll.h +++ b/drivers/clk/exynos/clk-pll.h @@ -15,9 +15,15 @@
#include <linux/clk-provider.h>
+struct samsung_pll_clock; + enum samsung_pll_type { pll_0822x, pll_0831x, };
+void samsung_clk_register_pll(void __iomem *base, + const struct samsung_pll_clock *clk_list, + unsigned int nr_clk); + #endif /* __EXYNOS_CLK_PLL_H */ diff --git a/drivers/clk/exynos/clk.c b/drivers/clk/exynos/clk.c index 430767f072d8..14ccd2cba374 100644 --- a/drivers/clk/exynos/clk.c +++ b/drivers/clk/exynos/clk.c @@ -10,7 +10,7 @@ #include <dm.h> #include "clk.h"
-void samsung_clk_register_mux(void __iomem *base, +static void samsung_clk_register_mux(void __iomem *base, const struct samsung_mux_clock *clk_list, unsigned int nr_clk) { @@ -28,7 +28,7 @@ void samsung_clk_register_mux(void __iomem *base, } }
-void samsung_clk_register_div(void __iomem *base, +static void samsung_clk_register_div(void __iomem *base, const struct samsung_div_clock *clk_list, unsigned int nr_clk) { @@ -46,7 +46,7 @@ void samsung_clk_register_div(void __iomem *base, } }
-void samsung_clk_register_gate(void __iomem *base, +static void samsung_clk_register_gate(void __iomem *base, const struct samsung_gate_clock *clk_list, unsigned int nr_clk) { @@ -84,9 +84,9 @@ static const samsung_clk_register_fn samsung_clk_register_fns[] = { * Having the array of clock groups @clk_groups makes it possible to keep a * correct clocks registration order. */ -void samsung_cmu_register_clocks(void __iomem *base, - const struct samsung_clk_group *clk_groups, - unsigned int nr_groups) +static void samsung_cmu_register_clocks(void __iomem *base, + const struct samsung_clk_group *clk_groups, + unsigned int nr_groups) { unsigned int i;
diff --git a/drivers/clk/exynos/clk.h b/drivers/clk/exynos/clk.h index 91a51b877a63..14e06b2030fb 100644 --- a/drivers/clk/exynos/clk.h +++ b/drivers/clk/exynos/clk.h @@ -179,22 +179,6 @@ struct samsung_clk_group { unsigned int nr_clk; };
-void samsung_clk_register_mux(void __iomem *base, - const struct samsung_mux_clock *clk_list, - unsigned int nr_clk); -void samsung_clk_register_div(void __iomem *base, - const struct samsung_div_clock *clk_list, - unsigned int nr_clk); -void samsung_clk_register_gate(void __iomem *base, - const struct samsung_gate_clock *clk_list, - unsigned int nr_clk); -void samsung_clk_register_pll(void __iomem *base, - const struct samsung_pll_clock *clk_list, - unsigned int nr_clk); - -void samsung_cmu_register_clocks(void __iomem *base, - const struct samsung_clk_group *clk_groups, - unsigned int nr_groups); int samsung_cmu_register_one(struct udevice *dev, const struct samsung_clk_group *clk_groups, unsigned int nr_groups);
Samsung clock drivers usually define the clock indices that are unique per one CMU, but are not unique across all CMUs. That is, clock indices start from 1 for each CMU, as provided in CMU bindings header. The way the clock lookup via clk_get_by_index() works at the moment is by using clk_of_xlate_default(), which returns globally non-unique clock ids for for clocks registered with Samsung CCF API, which leads to incorrect clocks being obtained. One way to fix that would be to make all clock ids defined in the bindings header unique, but it'd make it incompatible with Linux kernel bindings header. A better way to solve this issue is to calculate the global clock id and use it when registering a clock with clk_dm() and when obtaining it, in a custom .of_xlate function.
This patch adds an API for such mapping calculation, introducing the necessary modifications to CMU registering functions in Samsung CCF. Exynos850 clock driver (the only driver that uses Samsung CCF at the moment) is modified accordingly, as it uses the changed API. So the clock lookup with clk-exynos850.c driver is also fixed here.
The global clock id is calculated from CMU id and local clock id in SAMSUNG_TO_CLK_ID() macro like this:
clk_id_global = cmu_id * 256 + clk_id_local
leaving a range of up to 256 clocks for each CMU. Then this mapping macro is used in clk_dm() to register clocks using their global ids, and in .of_xlate() to lookup the clock by its local id correctly. Because .of_xlate() operation has a separate function for each CMU, it "knows" the correct way of finding the correct clk_id_global by provided clk_id_local.
Fixes: ff3e8b8c6c22 ("clk: exynos: Add Samsung clock framework") Fixes: a36cc5e3ef4d ("clk: exynos: Add Exynos850 clock driver") Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/clk/exynos/clk-exynos850.c | 18 +++++++--- drivers/clk/exynos/clk-pll.c | 6 ++-- drivers/clk/exynos/clk-pll.h | 2 +- drivers/clk/exynos/clk.c | 43 ++++++++++++++---------- drivers/clk/exynos/clk.h | 54 +++++++++++++++++++++++++++--- 5 files changed, 95 insertions(+), 28 deletions(-)
diff --git a/drivers/clk/exynos/clk-exynos850.c b/drivers/clk/exynos/clk-exynos850.c index de4170cdc2f3..f11c1ff29bdd 100644 --- a/drivers/clk/exynos/clk-exynos850.c +++ b/drivers/clk/exynos/clk-exynos850.c @@ -10,6 +10,11 @@ #include <dt-bindings/clock/exynos850.h> #include "clk.h"
+enum exynos850_cmu_id { + CMU_TOP, + CMU_PERI, +}; + /* ---- CMU_TOP ------------------------------------------------------------- */
/* Register Offset definitions for CMU_TOP (0x120e0000) */ @@ -124,7 +129,7 @@ static const struct samsung_clk_group top_cmu_clks[] = {
static int exynos850_cmu_top_probe(struct udevice *dev) { - return samsung_cmu_register_one(dev, top_cmu_clks, + return samsung_cmu_register_one(dev, CMU_TOP, top_cmu_clks, ARRAY_SIZE(top_cmu_clks)); }
@@ -133,11 +138,13 @@ static const struct udevice_id exynos850_cmu_top_ids[] = { { } };
+SAMSUNG_CLK_OPS(exynos850_cmu_top, CMU_TOP); + U_BOOT_DRIVER(exynos850_cmu_top) = { .name = "exynos850-cmu-top", .id = UCLASS_CLK, .of_match = exynos850_cmu_top_ids, - .ops = &ccf_clk_ops, + .ops = &exynos850_cmu_top_clk_ops, .probe = exynos850_cmu_top_probe, .flags = DM_FLAG_PRE_RELOC, }; @@ -175,7 +182,8 @@ static const struct samsung_clk_group peri_cmu_clks[] = {
static int exynos850_cmu_peri_probe(struct udevice *dev) { - return samsung_register_cmu(dev, peri_cmu_clks, exynos850_cmu_top); + return samsung_register_cmu(dev, CMU_PERI, peri_cmu_clks, + exynos850_cmu_top); }
static const struct udevice_id exynos850_cmu_peri_ids[] = { @@ -183,11 +191,13 @@ static const struct udevice_id exynos850_cmu_peri_ids[] = { { } };
+SAMSUNG_CLK_OPS(exynos850_cmu_peri, CMU_PERI); + U_BOOT_DRIVER(exynos850_cmu_peri) = { .name = "exynos850-cmu-peri", .id = UCLASS_CLK, .of_match = exynos850_cmu_peri_ids, - .ops = &ccf_clk_ops, + .ops = &exynos850_cmu_peri_clk_ops, .probe = exynos850_cmu_peri_probe, .flags = DM_FLAG_PRE_RELOC, }; diff --git a/drivers/clk/exynos/clk-pll.c b/drivers/clk/exynos/clk-pll.c index 4aacbc26b25d..542d577eaa6f 100644 --- a/drivers/clk/exynos/clk-pll.c +++ b/drivers/clk/exynos/clk-pll.c @@ -136,7 +136,7 @@ static struct clk *_samsung_clk_register_pll(void __iomem *base, return clk; }
-void samsung_clk_register_pll(void __iomem *base, +void samsung_clk_register_pll(void __iomem *base, unsigned int cmu_id, const struct samsung_pll_clock *clk_list, unsigned int nr_clk) { @@ -145,10 +145,12 @@ void samsung_clk_register_pll(void __iomem *base, for (cnt = 0; cnt < nr_clk; cnt++) { struct clk *clk; const struct samsung_pll_clock *pll_clk; + unsigned long clk_id;
pll_clk = &clk_list[cnt]; clk = _samsung_clk_register_pll(base, pll_clk); - clk_dm(pll_clk->id, clk); + clk_id = SAMSUNG_TO_CLK_ID(cmu_id, pll_clk->id); + clk_dm(clk_id, clk); } }
diff --git a/drivers/clk/exynos/clk-pll.h b/drivers/clk/exynos/clk-pll.h index 00c750687072..bdc94e7624d2 100644 --- a/drivers/clk/exynos/clk-pll.h +++ b/drivers/clk/exynos/clk-pll.h @@ -22,7 +22,7 @@ enum samsung_pll_type { pll_0831x, };
-void samsung_clk_register_pll(void __iomem *base, +void samsung_clk_register_pll(void __iomem *base, unsigned int cmu_id, const struct samsung_pll_clock *clk_list, unsigned int nr_clk);
diff --git a/drivers/clk/exynos/clk.c b/drivers/clk/exynos/clk.c index 14ccd2cba374..943e8bd01892 100644 --- a/drivers/clk/exynos/clk.c +++ b/drivers/clk/exynos/clk.c @@ -10,61 +10,67 @@ #include <dm.h> #include "clk.h"
-static void samsung_clk_register_mux(void __iomem *base, - const struct samsung_mux_clock *clk_list, - unsigned int nr_clk) +static void samsung_clk_register_mux(void __iomem *base, unsigned int cmu_id, + const struct samsung_mux_clock *clk_list, + unsigned int nr_clk) { unsigned int cnt;
for (cnt = 0; cnt < nr_clk; cnt++) { struct clk *clk; const struct samsung_mux_clock *m; + unsigned long clk_id;
m = &clk_list[cnt]; clk = clk_register_mux(NULL, m->name, m->parent_names, m->num_parents, m->flags, base + m->offset, m->shift, m->width, m->mux_flags); - clk_dm(m->id, clk); + clk_id = SAMSUNG_TO_CLK_ID(cmu_id, m->id); + clk_dm(clk_id, clk); } }
-static void samsung_clk_register_div(void __iomem *base, - const struct samsung_div_clock *clk_list, - unsigned int nr_clk) +static void samsung_clk_register_div(void __iomem *base, unsigned int cmu_id, + const struct samsung_div_clock *clk_list, + unsigned int nr_clk) { unsigned int cnt;
for (cnt = 0; cnt < nr_clk; cnt++) { struct clk *clk; const struct samsung_div_clock *d; + unsigned long clk_id;
d = &clk_list[cnt]; clk = clk_register_divider(NULL, d->name, d->parent_name, d->flags, base + d->offset, d->shift, d->width, d->div_flags); - clk_dm(d->id, clk); + clk_id = SAMSUNG_TO_CLK_ID(cmu_id, d->id); + clk_dm(clk_id, clk); } }
-static void samsung_clk_register_gate(void __iomem *base, - const struct samsung_gate_clock *clk_list, - unsigned int nr_clk) +static void samsung_clk_register_gate(void __iomem *base, unsigned int cmu_id, + const struct samsung_gate_clock *clk_list, + unsigned int nr_clk) { unsigned int cnt;
for (cnt = 0; cnt < nr_clk; cnt++) { struct clk *clk; const struct samsung_gate_clock *g; + unsigned long clk_id;
g = &clk_list[cnt]; clk = clk_register_gate(NULL, g->name, g->parent_name, g->flags, base + g->offset, g->bit_idx, g->gate_flags, NULL); - clk_dm(g->id, clk); + clk_id = SAMSUNG_TO_CLK_ID(cmu_id, g->id); + clk_dm(clk_id, clk); } }
-typedef void (*samsung_clk_register_fn)(void __iomem *base, +typedef void (*samsung_clk_register_fn)(void __iomem *base, unsigned int cmu_id, const void *clk_list, unsigned int nr_clk);
@@ -78,13 +84,14 @@ static const samsung_clk_register_fn samsung_clk_register_fns[] = { /** * samsung_cmu_register_clocks() - Register provided clock groups * @base: Base address of CMU registers + * @cmu_id: CMU index number * @clk_groups: list of clock groups * @nr_groups: count of clock groups in @clk_groups * * Having the array of clock groups @clk_groups makes it possible to keep a * correct clocks registration order. */ -static void samsung_cmu_register_clocks(void __iomem *base, +static void samsung_cmu_register_clocks(void __iomem *base, unsigned int cmu_id, const struct samsung_clk_group *clk_groups, unsigned int nr_groups) { @@ -93,19 +100,21 @@ static void samsung_cmu_register_clocks(void __iomem *base, for (i = 0; i < nr_groups; i++) { const struct samsung_clk_group *g = &clk_groups[i];
- samsung_clk_register_fns[g->type](base, g->clk_list, g->nr_clk); + samsung_clk_register_fns[g->type](base, cmu_id, + g->clk_list, g->nr_clk); } }
/** * samsung_cmu_register_one - Register all CMU clocks * @dev: CMU device + * @cmu_id: CMU index number * @clk_groups: list of CMU clock groups * @nr_groups: count of CMU clock groups in @clk_groups * * Return: 0 on success or negative value on error. */ -int samsung_cmu_register_one(struct udevice *dev, +int samsung_cmu_register_one(struct udevice *dev, unsigned int cmu_id, const struct samsung_clk_group *clk_groups, unsigned int nr_groups) { @@ -115,7 +124,7 @@ int samsung_cmu_register_one(struct udevice *dev, if (!base) return -EINVAL;
- samsung_cmu_register_clocks(base, clk_groups, nr_groups); + samsung_cmu_register_clocks(base, cmu_id, clk_groups, nr_groups);
return 0; } diff --git a/drivers/clk/exynos/clk.h b/drivers/clk/exynos/clk.h index 14e06b2030fb..ed0a395f0f63 100644 --- a/drivers/clk/exynos/clk.h +++ b/drivers/clk/exynos/clk.h @@ -13,6 +13,51 @@ #include <linux/clk-provider.h> #include "clk-pll.h"
+#define _SAMSUNG_CLK_OPS(_name, _cmu) \ +static int _name##_of_xlate(struct clk *clk, \ + struct ofnode_phandle_args *args) \ +{ \ + if (args->args_count > 1) { \ + debug("Invalid args_count: %d\n", args->args_count); \ + return -EINVAL; \ + } \ + \ + if (args->args_count) \ + clk->id = SAMSUNG_TO_CLK_ID(_cmu, args->args[0]); \ + else \ + clk->id = 0; \ + \ + return 0; \ +} \ + \ +static const struct clk_ops _name##_clk_ops = { \ + .set_rate = ccf_clk_set_rate, \ + .get_rate = ccf_clk_get_rate, \ + .set_parent = ccf_clk_set_parent, \ + .enable = ccf_clk_enable, \ + .disable = ccf_clk_disable, \ + .of_xlate = _name##_of_xlate, \ +} + +/** + * SAMSUNG_CLK_OPS - Define clock operations structure for specified CMU. + * @name: name of generated structure + * @cmu: CMU index + * + * Like ccf_clk_ops, but with custom .of_xlate callback. + */ +#define SAMSUNG_CLK_OPS(name, cmu) _SAMSUNG_CLK_OPS(name, cmu) + +/** + * SAMSUNG_TO_CLK_ID - Calculate a global clock index. + * @_cmu: CMU index + * @_id: local clock index (unique across @_cmu) + * + * Return: A global clock index unique across all CMUs. + * Keeps a range of 256 available clocks for every CMU. + */ +#define SAMSUNG_TO_CLK_ID(_cmu, _id) (((_cmu) << 8) | ((_id) & 0xff)) + /** * struct samsung_mux_clock - information about mux clock * @id: platform specific id of the clock @@ -179,13 +224,14 @@ struct samsung_clk_group { unsigned int nr_clk; };
-int samsung_cmu_register_one(struct udevice *dev, +int samsung_cmu_register_one(struct udevice *dev, unsigned int cmu_id, const struct samsung_clk_group *clk_groups, unsigned int nr_groups);
/** * samsung_register_cmu - Register CMU clocks ensuring parent CMU is present * @dev: CMU device + * @cmu_id: CMU index number * @clk_groups: list of CMU clock groups * @parent_drv: name of parent CMU driver * @@ -194,7 +240,7 @@ int samsung_cmu_register_one(struct udevice *dev, * * Return: 0 on success or negative value on error. */ -#define samsung_register_cmu(dev, clk_groups, parent_drv) \ +#define samsung_register_cmu(dev, cmu_id, clk_groups, parent_drv) \ ({ \ struct udevice *__parent; \ int __ret; \ @@ -204,8 +250,8 @@ int samsung_cmu_register_one(struct udevice *dev, if (__ret || !__parent) \ __ret = -ENOENT; \ else \ - __ret = samsung_cmu_register_one(dev, clk_groups, \ - ARRAY_SIZE(clk_groups)); \ + __ret = samsung_cmu_register_one(dev, cmu_id, \ + clk_groups, ARRAY_SIZE(clk_groups)); \ __ret; \ })
CMU_CORE generates clocks needed for eMMC enablement, and CMU_HSI provides clocks for SD card and USB. Most of the code is copied from the Linux kernel counterpart driver.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/clk/exynos/clk-exynos850.c | 252 +++++++++++++++++++++++++++++ 1 file changed, 252 insertions(+)
diff --git a/drivers/clk/exynos/clk-exynos850.c b/drivers/clk/exynos/clk-exynos850.c index f11c1ff29bdd..0c09ba02de4a 100644 --- a/drivers/clk/exynos/clk-exynos850.c +++ b/drivers/clk/exynos/clk-exynos850.c @@ -13,6 +13,8 @@ enum exynos850_cmu_id { CMU_TOP, CMU_PERI, + CMU_CORE, + CMU_HSI, };
/* ---- CMU_TOP ------------------------------------------------------------- */ @@ -24,9 +26,23 @@ enum exynos850_cmu_id { #define PLL_CON3_PLL_SHARED0 0x014c #define PLL_CON0_PLL_SHARED1 0x0180 #define PLL_CON3_PLL_SHARED1 0x018c +#define CLK_CON_MUX_MUX_CLKCMU_CORE_BUS 0x1014 +#define CLK_CON_MUX_MUX_CLKCMU_CORE_CCI 0x1018 +#define CLK_CON_MUX_MUX_CLKCMU_CORE_MMC_EMBD 0x101c +#define CLK_CON_MUX_MUX_CLKCMU_CORE_SSS 0x1020 +#define CLK_CON_MUX_MUX_CLKCMU_HSI_BUS 0x103c +#define CLK_CON_MUX_MUX_CLKCMU_HSI_MMC_CARD 0x1040 +#define CLK_CON_MUX_MUX_CLKCMU_HSI_USB20DRD 0x1044 #define CLK_CON_MUX_MUX_CLKCMU_PERI_BUS 0x1070 #define CLK_CON_MUX_MUX_CLKCMU_PERI_IP 0x1074 #define CLK_CON_MUX_MUX_CLKCMU_PERI_UART 0x1078 +#define CLK_CON_DIV_CLKCMU_CORE_BUS 0x1820 +#define CLK_CON_DIV_CLKCMU_CORE_CCI 0x1824 +#define CLK_CON_DIV_CLKCMU_CORE_MMC_EMBD 0x1828 +#define CLK_CON_DIV_CLKCMU_CORE_SSS 0x182c +#define CLK_CON_DIV_CLKCMU_HSI_BUS 0x1848 +#define CLK_CON_DIV_CLKCMU_HSI_MMC_CARD 0x184c +#define CLK_CON_DIV_CLKCMU_HSI_USB20DRD 0x1850 #define CLK_CON_DIV_CLKCMU_PERI_BUS 0x187c #define CLK_CON_DIV_CLKCMU_PERI_IP 0x1880 #define CLK_CON_DIV_CLKCMU_PERI_UART 0x1884 @@ -36,6 +52,13 @@ enum exynos850_cmu_id { #define CLK_CON_DIV_PLL_SHARED1_DIV2 0x1898 #define CLK_CON_DIV_PLL_SHARED1_DIV3 0x189c #define CLK_CON_DIV_PLL_SHARED1_DIV4 0x18a0 +#define CLK_CON_GAT_GATE_CLKCMU_CORE_BUS 0x201c +#define CLK_CON_GAT_GATE_CLKCMU_CORE_CCI 0x2020 +#define CLK_CON_GAT_GATE_CLKCMU_CORE_MMC_EMBD 0x2024 +#define CLK_CON_GAT_GATE_CLKCMU_CORE_SSS 0x2028 +#define CLK_CON_GAT_GATE_CLKCMU_HSI_BUS 0x2044 +#define CLK_CON_GAT_GATE_CLKCMU_HSI_MMC_CARD 0x2048 +#define CLK_CON_GAT_GATE_CLKCMU_HSI_USB20DRD 0x204c #define CLK_CON_GAT_GATE_CLKCMU_PERI_BUS 0x2080 #define CLK_CON_GAT_GATE_CLKCMU_PERI_IP 0x2084 #define CLK_CON_GAT_GATE_CLKCMU_PERI_UART 0x2088 @@ -44,6 +67,25 @@ enum exynos850_cmu_id { PNAME(mout_shared0_pll_p) = { "clock-oscclk", "fout_shared0_pll" }; PNAME(mout_shared1_pll_p) = { "clock-oscclk", "fout_shared1_pll" }; PNAME(mout_mmc_pll_p) = { "clock-oscclk", "fout_mmc_pll" }; +/* List of parent clocks for Muxes in CMU_TOP: for CMU_CORE */ +PNAME(mout_core_bus_p) = { "dout_shared1_div2", "dout_shared0_div3", + "dout_shared1_div3", "dout_shared0_div4" }; +PNAME(mout_core_cci_p) = { "dout_shared0_div2", "dout_shared1_div2", + "dout_shared0_div3", "dout_shared1_div3" }; +PNAME(mout_core_mmc_embd_p) = { "clock-oscclk", "dout_shared0_div2", + "dout_shared1_div2", "dout_shared0_div3", + "dout_shared1_div3", "mout_mmc_pll", + "clock-oscclk", "clock-oscclk" }; +PNAME(mout_core_sss_p) = { "dout_shared0_div3", "dout_shared1_div3", + "dout_shared0_div4", "dout_shared1_div4" }; +/* List of parent clocks for Muxes in CMU_TOP: for CMU_HSI */ +PNAME(mout_hsi_bus_p) = { "dout_shared0_div2", "dout_shared1_div2" }; +PNAME(mout_hsi_mmc_card_p) = { "clock-oscclk", "dout_shared0_div2", + "dout_shared1_div2", "dout_shared0_div3", + "dout_shared1_div3", "mout_mmc_pll", + "clock-oscclk", "clock-oscclk" }; +PNAME(mout_hsi_usb20drd_p) = { "clock-oscclk", "dout_shared0_div4", + "dout_shared1_div4", "clock-oscclk" }; /* List of parent clocks for Muxes in CMU_TOP: for CMU_PERI */ PNAME(mout_peri_bus_p) = { "dout_shared0_div4", "dout_shared1_div4" }; PNAME(mout_peri_uart_p) = { "clock-oscclk", "dout_shared0_div4", @@ -86,6 +128,70 @@ static const struct samsung_div_clock top_pure_div_clks[] = { CLK_CON_DIV_PLL_SHARED1_DIV4, 0, 1), };
+/* CORE */ + +static const struct samsung_mux_clock top_core_mux_clks[] = { + MUX(CLK_MOUT_CORE_BUS, "mout_core_bus", mout_core_bus_p, + CLK_CON_MUX_MUX_CLKCMU_CORE_BUS, 0, 2), + MUX(CLK_MOUT_CORE_CCI, "mout_core_cci", mout_core_cci_p, + CLK_CON_MUX_MUX_CLKCMU_CORE_CCI, 0, 2), + MUX(CLK_MOUT_CORE_MMC_EMBD, "mout_core_mmc_embd", mout_core_mmc_embd_p, + CLK_CON_MUX_MUX_CLKCMU_CORE_MMC_EMBD, 0, 3), + MUX(CLK_MOUT_CORE_SSS, "mout_core_sss", mout_core_sss_p, + CLK_CON_MUX_MUX_CLKCMU_CORE_SSS, 0, 2), +}; + +static const struct samsung_gate_clock top_core_gate_clks[] = { + GATE(CLK_GOUT_CORE_BUS, "gout_core_bus", "mout_core_bus", + CLK_CON_GAT_GATE_CLKCMU_CORE_BUS, 21, 0, 0), + GATE(CLK_GOUT_CORE_CCI, "gout_core_cci", "mout_core_cci", + CLK_CON_GAT_GATE_CLKCMU_CORE_CCI, 21, 0, 0), + GATE(CLK_GOUT_CORE_MMC_EMBD, "gout_core_mmc_embd", "mout_core_mmc_embd", + CLK_CON_GAT_GATE_CLKCMU_CORE_MMC_EMBD, 21, 0, 0), + GATE(CLK_GOUT_CORE_SSS, "gout_core_sss", "mout_core_sss", + CLK_CON_GAT_GATE_CLKCMU_CORE_SSS, 21, 0, 0), +}; + +static const struct samsung_div_clock top_core_div_clks[] = { + DIV(CLK_DOUT_CORE_BUS, "dout_core_bus", "gout_core_bus", + CLK_CON_DIV_CLKCMU_CORE_BUS, 0, 4), + DIV(CLK_DOUT_CORE_CCI, "dout_core_cci", "gout_core_cci", + CLK_CON_DIV_CLKCMU_CORE_CCI, 0, 4), + DIV(CLK_DOUT_CORE_MMC_EMBD, "dout_core_mmc_embd", "gout_core_mmc_embd", + CLK_CON_DIV_CLKCMU_CORE_MMC_EMBD, 0, 9), + DIV(CLK_DOUT_CORE_SSS, "dout_core_sss", "gout_core_sss", + CLK_CON_DIV_CLKCMU_CORE_SSS, 0, 4), +}; + +/* HSI */ + +static const struct samsung_mux_clock top_hsi_mux_clks[] = { + MUX(CLK_MOUT_HSI_BUS, "mout_hsi_bus", mout_hsi_bus_p, + CLK_CON_MUX_MUX_CLKCMU_HSI_BUS, 0, 1), + MUX(CLK_MOUT_HSI_MMC_CARD, "mout_hsi_mmc_card", mout_hsi_mmc_card_p, + CLK_CON_MUX_MUX_CLKCMU_HSI_MMC_CARD, 0, 3), + MUX(CLK_MOUT_HSI_USB20DRD, "mout_hsi_usb20drd", mout_hsi_usb20drd_p, + CLK_CON_MUX_MUX_CLKCMU_HSI_USB20DRD, 0, 2), +}; + +static const struct samsung_gate_clock top_hsi_gate_clks[] = { + GATE(CLK_GOUT_HSI_BUS, "gout_hsi_bus", "mout_hsi_bus", + CLK_CON_GAT_GATE_CLKCMU_HSI_BUS, 21, 0, 0), + GATE(CLK_GOUT_HSI_MMC_CARD, "gout_hsi_mmc_card", "mout_hsi_mmc_card", + CLK_CON_GAT_GATE_CLKCMU_HSI_MMC_CARD, 21, 0, 0), + GATE(CLK_GOUT_HSI_USB20DRD, "gout_hsi_usb20drd", "mout_hsi_usb20drd", + CLK_CON_GAT_GATE_CLKCMU_HSI_USB20DRD, 21, 0, 0), +}; + +static const struct samsung_div_clock top_hsi_div_clks[] = { + DIV(CLK_DOUT_HSI_BUS, "dout_hsi_bus", "gout_hsi_bus", + CLK_CON_DIV_CLKCMU_HSI_BUS, 0, 4), + DIV(CLK_DOUT_HSI_MMC_CARD, "dout_hsi_mmc_card", "gout_hsi_mmc_card", + CLK_CON_DIV_CLKCMU_HSI_MMC_CARD, 0, 9), + DIV(CLK_DOUT_HSI_USB20DRD, "dout_hsi_usb20drd", "gout_hsi_usb20drd", + CLK_CON_DIV_CLKCMU_HSI_USB20DRD, 0, 4), +}; + /* PERI */
static const struct samsung_mux_clock top_peri_mux_clks[] = { @@ -121,6 +227,16 @@ static const struct samsung_clk_group top_cmu_clks[] = { { S_CLK_MUX, top_pure_mux_clks, ARRAY_SIZE(top_pure_mux_clks) }, { S_CLK_DIV, top_pure_div_clks, ARRAY_SIZE(top_pure_div_clks) },
+ /* CMU_TOP clocks for CMU_CORE */ + { S_CLK_MUX, top_core_mux_clks, ARRAY_SIZE(top_core_mux_clks) }, + { S_CLK_GATE, top_core_gate_clks, ARRAY_SIZE(top_core_gate_clks) }, + { S_CLK_DIV, top_core_div_clks, ARRAY_SIZE(top_core_div_clks) }, + + /* CMU_TOP clocks for CMU_HSI */ + { S_CLK_MUX, top_hsi_mux_clks, ARRAY_SIZE(top_hsi_mux_clks) }, + { S_CLK_GATE, top_hsi_gate_clks, ARRAY_SIZE(top_hsi_gate_clks) }, + { S_CLK_DIV, top_hsi_div_clks, ARRAY_SIZE(top_hsi_div_clks) }, + /* CMU_TOP clocks for CMU_PERI */ { S_CLK_MUX, top_peri_mux_clks, ARRAY_SIZE(top_peri_mux_clks) }, { S_CLK_GATE, top_peri_gate_clks, ARRAY_SIZE(top_peri_gate_clks) }, @@ -201,3 +317,139 @@ U_BOOT_DRIVER(exynos850_cmu_peri) = { .probe = exynos850_cmu_peri_probe, .flags = DM_FLAG_PRE_RELOC, }; + +/* ---- CMU_CORE ------------------------------------------------------------ */ + +/* Register Offset definitions for CMU_CORE (0x12000000) */ +#define PLL_CON0_MUX_CLKCMU_CORE_BUS_USER 0x0600 +#define PLL_CON0_MUX_CLKCMU_CORE_MMC_EMBD_USER 0x0620 +#define CLK_CON_DIV_DIV_CLK_CORE_BUSP 0x1800 +#define CLK_CON_GAT_GOUT_CORE_MMC_EMBD_I_ACLK 0x20e8 +#define CLK_CON_GAT_GOUT_CORE_MMC_EMBD_SDCLKIN 0x20ec + +/* List of parent clocks for Muxes in CMU_CORE */ +PNAME(mout_core_bus_user_p) = { "clock-oscclk", "dout_core_bus" }; +PNAME(mout_core_mmc_embd_user_p) = { "clock-oscclk", + "dout_core_mmc_embd" }; + +static const struct samsung_mux_clock core_mux_clks[] = { + MUX(CLK_MOUT_CORE_BUS_USER, "mout_core_bus_user", mout_core_bus_user_p, + PLL_CON0_MUX_CLKCMU_CORE_BUS_USER, 4, 1), + MUX_F(CLK_MOUT_CORE_MMC_EMBD_USER, "mout_core_mmc_embd_user", + mout_core_mmc_embd_user_p, PLL_CON0_MUX_CLKCMU_CORE_MMC_EMBD_USER, + 4, 1, CLK_SET_RATE_PARENT, 0), +}; + +static const struct samsung_div_clock core_div_clks[] = { + DIV(CLK_DOUT_CORE_BUSP, "dout_core_busp", "mout_core_bus_user", + CLK_CON_DIV_DIV_CLK_CORE_BUSP, 0, 2), +}; + +static const struct samsung_gate_clock core_gate_clks[] = { + GATE(CLK_GOUT_MMC_EMBD_ACLK, "gout_mmc_embd_aclk", "dout_core_busp", + CLK_CON_GAT_GOUT_CORE_MMC_EMBD_I_ACLK, 21, 0, 0), + GATE(CLK_GOUT_MMC_EMBD_SDCLKIN, "gout_mmc_embd_sdclkin", + "mout_core_mmc_embd_user", CLK_CON_GAT_GOUT_CORE_MMC_EMBD_SDCLKIN, + 21, CLK_SET_RATE_PARENT, 0), +}; + +static const struct samsung_clk_group core_cmu_clks[] = { + { S_CLK_MUX, core_mux_clks, ARRAY_SIZE(core_mux_clks) }, + { S_CLK_DIV, core_div_clks, ARRAY_SIZE(core_div_clks) }, + { S_CLK_GATE, core_gate_clks, ARRAY_SIZE(core_gate_clks) }, +}; + +static int exynos850_cmu_core_probe(struct udevice *dev) +{ + return samsung_register_cmu(dev, CMU_CORE, core_cmu_clks, + exynos850_cmu_top); +} + +static const struct udevice_id exynos850_cmu_core_ids[] = { + { .compatible = "samsung,exynos850-cmu-core" }, + { } +}; + +SAMSUNG_CLK_OPS(exynos850_cmu_core, CMU_CORE); + +U_BOOT_DRIVER(exynos850_cmu_core) = { + .name = "exynos850-cmu-core", + .id = UCLASS_CLK, + .of_match = exynos850_cmu_core_ids, + .ops = &exynos850_cmu_core_clk_ops, + .probe = exynos850_cmu_core_probe, + .flags = DM_FLAG_PRE_RELOC, +}; + +/* ---- CMU_HSI ------------------------------------------------------------- */ + +/* Register Offset definitions for CMU_HSI (0x13400000) */ +#define PLL_CON0_MUX_CLKCMU_HSI_BUS_USER 0x0600 +#define PLL_CON0_MUX_CLKCMU_HSI_MMC_CARD_USER 0x0610 +#define PLL_CON0_MUX_CLKCMU_HSI_USB20DRD_USER 0x0620 +#define CLK_CON_GAT_HSI_USB20DRD_TOP_I_REF_CLK_50 0x200c +#define CLK_CON_GAT_HSI_USB20DRD_TOP_I_PHY_REFCLK_26 0x2010 +#define CLK_CON_GAT_GOUT_HSI_MMC_CARD_I_ACLK 0x2024 +#define CLK_CON_GAT_GOUT_HSI_MMC_CARD_SDCLKIN 0x2028 +#define CLK_CON_GAT_GOUT_HSI_USB20DRD_TOP_ACLK_PHYCTRL_20 0x203c +#define CLK_CON_GAT_GOUT_HSI_USB20DRD_TOP_BUS_CLK_EARLY 0x2040 + +/* List of parent clocks for Muxes in CMU_HSI */ +PNAME(mout_hsi_bus_user_p) = { "clock-oscclk", "dout_hsi_bus" }; +PNAME(mout_hsi_mmc_card_user_p) = { "clock-oscclk", "dout_hsi_mmc_card" }; +PNAME(mout_hsi_usb20drd_user_p) = { "clock-oscclk", "dout_hsi_usb20drd" }; + +static const struct samsung_mux_clock hsi_mux_clks[] __initconst = { + MUX(CLK_MOUT_HSI_BUS_USER, "mout_hsi_bus_user", mout_hsi_bus_user_p, + PLL_CON0_MUX_CLKCMU_HSI_BUS_USER, 4, 1), + MUX_F(CLK_MOUT_HSI_MMC_CARD_USER, "mout_hsi_mmc_card_user", + mout_hsi_mmc_card_user_p, PLL_CON0_MUX_CLKCMU_HSI_MMC_CARD_USER, + 4, 1, CLK_SET_RATE_PARENT, 0), + MUX(CLK_MOUT_HSI_USB20DRD_USER, "mout_hsi_usb20drd_user", + mout_hsi_usb20drd_user_p, PLL_CON0_MUX_CLKCMU_HSI_USB20DRD_USER, + 4, 1), +}; + +static const struct samsung_gate_clock hsi_gate_clks[] __initconst = { + GATE(CLK_GOUT_USB_REF_CLK, "gout_usb_ref", "mout_hsi_usb20drd_user", + CLK_CON_GAT_HSI_USB20DRD_TOP_I_REF_CLK_50, 21, 0, 0), + GATE(CLK_GOUT_USB_PHY_REF_CLK, "gout_usb_phy_ref", "clock-oscclk", + CLK_CON_GAT_HSI_USB20DRD_TOP_I_PHY_REFCLK_26, 21, 0, 0), + GATE(CLK_GOUT_MMC_CARD_ACLK, "gout_mmc_card_aclk", "mout_hsi_bus_user", + CLK_CON_GAT_GOUT_HSI_MMC_CARD_I_ACLK, 21, 0, 0), + GATE(CLK_GOUT_MMC_CARD_SDCLKIN, "gout_mmc_card_sdclkin", + "mout_hsi_mmc_card_user", + CLK_CON_GAT_GOUT_HSI_MMC_CARD_SDCLKIN, 21, CLK_SET_RATE_PARENT, 0), + GATE(CLK_GOUT_USB_PHY_ACLK, "gout_usb_phy_aclk", "mout_hsi_bus_user", + CLK_CON_GAT_GOUT_HSI_USB20DRD_TOP_ACLK_PHYCTRL_20, 21, 0, 0), + GATE(CLK_GOUT_USB_BUS_EARLY_CLK, "gout_usb_bus_early", + "mout_hsi_bus_user", + CLK_CON_GAT_GOUT_HSI_USB20DRD_TOP_BUS_CLK_EARLY, 21, 0, 0), +}; + +static const struct samsung_clk_group hsi_cmu_clks[] = { + { S_CLK_MUX, hsi_mux_clks, ARRAY_SIZE(hsi_mux_clks) }, + { S_CLK_GATE, hsi_gate_clks, ARRAY_SIZE(hsi_gate_clks) }, +}; + +static int exynos850_cmu_hsi_probe(struct udevice *dev) +{ + return samsung_register_cmu(dev, CMU_HSI, hsi_cmu_clks, + exynos850_cmu_hsi); +} + +static const struct udevice_id exynos850_cmu_hsi_ids[] = { + { .compatible = "samsung,exynos850-cmu-hsi" }, + { } +}; + +SAMSUNG_CLK_OPS(exynos850_cmu_hsi, CMU_HSI); + +U_BOOT_DRIVER(exynos850_cmu_hsi) = { + .name = "exynos850-cmu-hsi", + .id = UCLASS_CLK, + .of_match = exynos850_cmu_hsi_ids, + .ops = &exynos850_cmu_hsi_clk_ops, + .probe = exynos850_cmu_hsi_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Lukasz, Sean, Tom,
If there are no comments on this series, can you please apply it?
Thanks!
On Thu, Mar 7, 2024 at 8:18 PM Sam Protsenko semen.protsenko@linaro.org wrote:
-- 2.39.2
2024년 3월 20일 (수) 03:44, Sam Protsenko semen.protsenko@linaro.org님이 작성:
Thanks!
-- 2.39.2
applied to u-boot-samsung.
Thanks. Minkyu Kang.
Minkyu Kang
Sam Protsenko
