[U-Boot] [PATCH v2 1/6] sunxi: makes an invisible option for H3-like DRAM controllers
Allwinner SoCs after H3 (e.g. A64, H5, R40, V3s) uses a H3-like DesignWare DRAM controller, which do not have official free DRAM initialization code, but can use modified dram_sun8i_h3.c.
Add a invisible option for easier DRAM initialization code reuse.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes since v1: - rename the option to SUNXI_DW_DRAM. arch/arm/include/asm/arch-sunxi/dram.h | 2 +- arch/arm/mach-sunxi/Makefile | 2 +- board/sunxi/Kconfig | 8 ++++++++ 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index e0be744dba..1475a80196 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -24,7 +24,7 @@ #include <asm/arch/dram_sun8i_a33.h> #elif defined(CONFIG_MACH_SUN8I_A83T) #include <asm/arch/dram_sun8i_a83t.h> -#elif defined(CONFIG_MACH_SUN8I_H3) +#elif defined(CONFIG_SUNXI_DW_DRAM) #include <asm/arch/dram_sun8i_h3.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/dram_sun9i.h> diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index e73114ee64..c9f3a12b62 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -48,6 +48,6 @@ obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o -obj-$(CONFIG_MACH_SUN8I_H3) += dram_sun8i_h3.o +obj-$(CONFIG_SUNXI_DW_DRAM) += dram_sun8i_h3.o obj-$(CONFIG_MACH_SUN9I) += dram_sun9i.o endif diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index e1d4ab148f..ab318a76ca 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -42,6 +42,13 @@ config SUNXI_GEN_SUN6I separate ahb reset control registers, custom pmic bus, new style watchdog, etc.
+config SUNXI_DW_DRAM + bool + ---help--- + Select this for sunxi SoCs which uses a DRAM controller like the + DesignWare controller used in H3, mainly SoCs after H3, which do + not have official open-source DRAM initialization code, but can + use modified H3 DRAM initialization code.
choice prompt "Sunxi SoC Variant" @@ -113,6 +120,7 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select SUNXI_GEN_SUN6I select SUPPORT_SPL + select SUNXI_DW_DRAM select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN9I
H3-like DRAM controller needs some special code to operate a DDR2 DRAM chip. Add the logic to probe such a chip.
As there's no commercial boards available now with H3 and DDR2 DRAM, the patch is developed and tested on a V3s chip, which has in-package DDR2 DRAM.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes since v1: - Enable banks detection on also non-DDR2 situations. - Change 32BIT and 16BIT to FULL/HALF width (see also dram_sun8i_a33.h) - some small cleanup.
arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h | 6 +- arch/arm/mach-sunxi/dram_sun8i_h3.c | 111 +++++++++++++++++++++--- board/sunxi/Kconfig | 11 +++ 3 files changed, 114 insertions(+), 14 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h b/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h index d0f2b8afdb..92d15fe2d8 100644 --- a/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h +++ b/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h @@ -49,9 +49,9 @@ struct sunxi_mctl_com_reg { #define MCTL_CR_SEQUENTIAL (0x1 << 15) #define MCTL_CR_INTERLEAVED (0x0 << 15)
-#define MCTL_CR_32BIT (0x1 << 12) -#define MCTL_CR_16BIT (0x0 << 12) -#define MCTL_CR_BUS_WIDTH(x) ((x) == 32 ? MCTL_CR_32BIT : MCTL_CR_16BIT) +#define MCTL_CR_FULL_WIDTH (0x1 << 12) +#define MCTL_CR_HALF_WIDTH (0x0 << 12) +#define MCTL_CR_BUS_FULL_WIDTH(x) ((x) ? MCTL_CR_FULL_WIDTH : MCTL_CR_HALF_WIDTH)
#define MCTL_CR_PAGE_SIZE(x) ((fls(x) - 4) << 8) #define MCTL_CR_ROW_BITS(x) (((x) - 1) << 4) diff --git a/arch/arm/mach-sunxi/dram_sun8i_h3.c b/arch/arm/mach-sunxi/dram_sun8i_h3.c index 8e2527dee1..81e7af1299 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_h3.c +++ b/arch/arm/mach-sunxi/dram_sun8i_h3.c @@ -19,9 +19,10 @@ struct dram_para { u32 read_delays; u32 write_delays; u16 page_size; - u8 bus_width; + u8 bus_full_width; u8 dual_rank; u8 row_bits; + u8 bank_bits; };
static inline int ns_to_t(int nanoseconds) @@ -136,36 +137,77 @@ static void mctl_set_timing_params(struct dram_para *para) struct sunxi_mctl_ctl_reg * const mctl_ctl = (struct sunxi_mctl_ctl_reg *)SUNXI_DRAM_CTL0_BASE;
+#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 tccd = 2; +#else + u8 tccd = 1; +#endif u8 tfaw = ns_to_t(50); +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 trrd = max(ns_to_t(10), 4); u8 trcd = ns_to_t(15); u8 trc = ns_to_t(53); u8 txp = max(ns_to_t(8), 3); u8 twtr = max(ns_to_t(8), 4); u8 trtp = max(ns_to_t(8), 4); +#else + u8 trrd = max(ns_to_t(10), 2); + u8 trcd = ns_to_t(20); + u8 trc = ns_to_t(65); + u8 txp = 2; + u8 twtr = max(ns_to_t(8), 2); + u8 trtp = max(ns_to_t(8), 2); +#endif u8 twr = max(ns_to_t(15), 3); u8 trp = ns_to_t(15); +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 tras = ns_to_t(38); +#else + u8 tras = ns_to_t(45); +#endif u16 trefi = ns_to_t(7800) / 32; +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u16 trfc = ns_to_t(350); +#else + u16 trfc = ns_to_t(328); +#endif
u8 tmrw = 0; +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 tmrd = 4; +#else + u8 tmrd = 2; +#endif u8 tmod = 12; u8 tcke = 3; u8 tcksrx = 5; u8 tcksre = 5; u8 tckesr = 4; +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 trasmax = 24; +#else + u8 trasmax = 27; +#endif
+#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u8 tcl = 6; /* CL 12 */ u8 tcwl = 4; /* CWL 8 */ u8 t_rdata_en = 4; u8 wr_latency = 2; - +#else + u8 tcl = 3; /* CL 6 */ + u8 tcwl = 3; /* CWL 6 */ + u8 t_rdata_en = 1; + u8 wr_latency = 1; +#endif + +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 u32 tdinit0 = (500 * CONFIG_DRAM_CLK) + 1; /* 500us */ u32 tdinit1 = (360 * CONFIG_DRAM_CLK) / 1000 + 1; /* 360ns */ +#else + u32 tdinit0 = (400 * CONFIG_DRAM_CLK) + 1; /* 400us */ + u32 tdinit1 = (500 * CONFIG_DRAM_CLK) / 1000 + 1; /* 500ns */ +#endif u32 tdinit2 = (200 * CONFIG_DRAM_CLK) + 1; /* 200us */ u32 tdinit3 = (1 * CONFIG_DRAM_CLK) + 1; /* 1us */
@@ -174,9 +216,15 @@ static void mctl_set_timing_params(struct dram_para *para) u8 trd2wr = tcl + 2 + 1 - tcwl; /* RL + BL / 2 + 2 - WL */
/* set mode register */ +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 writel(0x1c70, &mctl_ctl->mr[0]); /* CL=11, WR=12 */ writel(0x40, &mctl_ctl->mr[1]); writel(0x18, &mctl_ctl->mr[2]); /* CWL=8 */ +#else + writel(0x263, &mctl_ctl->mr[0]); + writel(0x4, &mctl_ctl->mr[1]); + writel(0x0, &mctl_ctl->mr[2]); +#endif writel(0x0, &mctl_ctl->mr[3]);
/* set DRAM timing */ @@ -212,6 +260,12 @@ static void mctl_set_timing_params(struct dram_para *para) writel(RFSHTMG_TREFI(trefi) | RFSHTMG_TRFC(trfc), &mctl_ctl->rfshtmg); }
+#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 +#define ZQ_COUNT 6 +#else +#define ZQ_COUNT 4 +#endif + static void mctl_zq_calibration(struct dram_para *para) { struct sunxi_mctl_ctl_reg * const mctl_ctl = @@ -244,7 +298,8 @@ static void mctl_zq_calibration(struct dram_para *para)
writel(0x0a0a0a0a, &mctl_ctl->zqdr[2]);
- for (i = 0; i < 6; i++) { + for (i = 0; i < ZQ_COUNT; i++) + { u8 zq = (CONFIG_DRAM_ZQ >> (i * 4)) & 0xf;
writel((zq << 20) | (zq << 16) | (zq << 12) | @@ -266,7 +321,9 @@ static void mctl_zq_calibration(struct dram_para *para)
writel((zq_val[1] << 16) | zq_val[0], &mctl_ctl->zqdr[0]); writel((zq_val[3] << 16) | zq_val[2], &mctl_ctl->zqdr[1]); +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 writel((zq_val[5] << 16) | zq_val[4], &mctl_ctl->zqdr[2]); +#endif } }
@@ -275,8 +332,15 @@ static void mctl_set_cr(struct dram_para *para) struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE;
- writel(MCTL_CR_BL8 | MCTL_CR_2T | MCTL_CR_DDR3 | MCTL_CR_INTERLEAVED | - MCTL_CR_EIGHT_BANKS | MCTL_CR_BUS_WIDTH(para->bus_width) | + writel(MCTL_CR_BL8 | MCTL_CR_2T | +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 + MCTL_CR_DDR3 | +#else + MCTL_CR_DDR2 | +#endif + (para->bank_bits == 3 ? MCTL_CR_EIGHT_BANKS : MCTL_CR_FOUR_BANKS) | + MCTL_CR_BUS_FULL_WIDTH(para->bus_full_width) | + MCTL_CR_INTERLEAVED | (para->dual_rank ? MCTL_CR_DUAL_RANK : MCTL_CR_SINGLE_RANK) | MCTL_CR_PAGE_SIZE(para->page_size) | MCTL_CR_ROW_BITS(para->row_bits), &mctl_com->cr); @@ -363,7 +427,7 @@ static int mctl_channel_init(struct dram_para *para) (0x1 << 10) | (0x2 << 8));
/* set half DQ */ - if (para->bus_width != 32) { + if (!para->bus_full_width) { writel(0x0, &mctl_ctl->datx[2].gcr); writel(0x0, &mctl_ctl->datx[3].gcr); } @@ -380,7 +444,10 @@ static int mctl_channel_init(struct dram_para *para)
mctl_zq_calibration(para);
- mctl_phy_init(PIR_PLLINIT | PIR_DCAL | PIR_PHYRST | PIR_DRAMRST | + mctl_phy_init(PIR_PLLINIT | PIR_DCAL | PIR_PHYRST | +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 + PIR_DRAMRST | +#endif PIR_DRAMINIT | PIR_QSGATE);
/* detect ranks and bus width */ @@ -397,7 +464,7 @@ static int mctl_channel_init(struct dram_para *para) ((readl(&mctl_ctl->datx[3].gsr[0]) >> 24) & 0x1)) { writel(0x0, &mctl_ctl->datx[2].gcr); writel(0x0, &mctl_ctl->datx[3].gcr); - para->bus_width = 16; + para->bus_full_width = 0; }
mctl_set_cr(para); @@ -435,10 +502,20 @@ static void mctl_auto_detect_dram_size(struct dram_para *para) /* detect row address bits */ para->page_size = 512; para->row_bits = 16; + para->bank_bits = 2; + mctl_set_cr(para);
for (para->row_bits = 11; para->row_bits < 16; para->row_bits++) - if (mctl_mem_matches((1 << (para->row_bits + 3)) * para->page_size)) + if (mctl_mem_matches((1 << (para->row_bits + para->bank_bits)) * para->page_size)) + break; + + /* detect bank address bits */ + para->bank_bits = 3; + mctl_set_cr(para); + + for (para->bank_bits = 2; para->bank_bits < 3; para->bank_bits++) + if (mctl_mem_matches((1 << para->bank_bits) * para->page_size)) break;
/* detect page size */ @@ -458,11 +535,17 @@ unsigned long sunxi_dram_init(void) (struct sunxi_mctl_ctl_reg *)SUNXI_DRAM_CTL0_BASE;
struct dram_para para = { +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 .read_delays = 0x00007979, /* dram_tpr12 */ .write_delays = 0x6aaa0000, /* dram_tpr11 */ +#else + .read_delays = 0x00007878, /* dram_tpr12 */ + .write_delays = 0x6a440000, /* dram_tpr11 */ +#endif .dual_rank = 0, - .bus_width = 32, + .bus_full_width = 1, .row_bits = 15, + .bank_bits = 3, .page_size = 4096, };
@@ -477,7 +560,13 @@ unsigned long sunxi_dram_init(void) udelay(1);
/* odt delay */ +#ifndef CONFIG_SUNXI_DW_DRAM_DDR2 writel(0x0c000400, &mctl_ctl->odtcfg); +#else + writel(0x04000400, &mctl_ctl->odtcfg); + + clrbits_le32(&mctl_ctl->pgcr[2], (1 << 13)); +#endif
/* clear credit value */ setbits_le32(&mctl_com->cccr, 1 << 31); @@ -486,6 +575,6 @@ unsigned long sunxi_dram_init(void) mctl_auto_detect_dram_size(¶); mctl_set_cr(¶);
- return (1 << (para.row_bits + 3)) * para.page_size * + return (1 << (para.row_bits + para.bank_bits)) * para.page_size * (para.dual_rank ? 2 : 1); } diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index ab318a76ca..26fe82c5bc 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -261,6 +261,17 @@ config DRAM_ODT_CORRECTION then the correction is negative. Usually the value for this is 0. endif
+if SUNXI_DW_DRAM +config SUNXI_DW_DRAM_DDR2 + bool "Board uses DDR2 DRAM" + default no + ---help--- + Only select this option when your board uses DDR2 DRAM chips instead + of DDR3 ones. + DDR2 chips needs some special probing logic, which will be included by + selecting this option. +endif + config SYS_CLK_FREQ default 816000000 if MACH_SUN50I default 912000000 if MACH_SUN7I
Basic U-Boot support is now present for V3s.
Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes since v1: - squashed memory footprint patch into it. - disabled VIDEO for V3s.
arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 9 ++++++-- arch/arm/mach-sunxi/cpu_info.c | 2 ++ board/sunxi/Kconfig | 15 ++++++++++++-- include/configs/sun8i.h | 2 ++ include/configs/sunxi-common.h | 38 ++++++++++++++++++++++++++++++++-- 6 files changed, 61 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 85a4ec3b0e..24f85206c8 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -161,6 +161,7 @@ enum sunxi_gpio_number { #define SUN8I_GPB_UART2 2 #define SUN8I_A33_GPB_UART0 3 #define SUN8I_A83T_GPB_UART0 2 +#define SUN8I_V3S_GPB_UART0 3 #define SUN50I_GPB_UART0 4
#define SUNXI_GPC_NAND 2 diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index aa11493748..3b28478e2d 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -110,6 +110,10 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S) + sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0); + sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN9I) sunxi_gpio_set_cfgpin(SUNXI_GPH(12), SUN9I_GPH_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPH(13), SUN9I_GPH_UART0); @@ -180,10 +184,11 @@ void s_init(void) /* No H3 BSP, boot0 seems to not modify SUNXI_SRAMC_BASE + 0x44 */ #endif
-#if defined CONFIG_MACH_SUN6I || \ +#if (defined CONFIG_MACH_SUN6I || \ defined CONFIG_MACH_SUN7I || \ defined CONFIG_MACH_SUN8I || \ - defined CONFIG_MACH_SUN9I + defined CONFIG_MACH_SUN9I) && \ + !defined CONFIG_MACH_SUN8I_V3S /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ asm volatile( "mrc p15, 0, r0, c1, c0, 1\n" diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index f1f6fd5ba4..15f1e0e45a 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -87,6 +87,8 @@ int print_cpuinfo(void) printf("CPU: Allwinner A83T (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_H3 printf("CPU: Allwinner H3 (SUN8I %04x)\n", sunxi_get_sram_id()); +#elif defined CONFIG_MACH_SUN8I_V3S + printf("CPU: Allwinner V3s (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN9I puts("CPU: Allwinner A80 (SUN9I)\n"); #elif defined CONFIG_MACH_SUN50I diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 26fe82c5bc..d29735d16b 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -123,6 +123,17 @@ config MACH_SUN8I_H3 select SUNXI_DW_DRAM select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
+config MACH_SUN8I_V3S + bool "sun8i (Allwinner V3s)" + select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select SUNXI_GEN_SUN6I + select SUPPORT_SPL + select SUNXI_DW_DRAM + select SUNXI_DW_DRAM_DDR2 + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 @@ -139,7 +150,7 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool - default y if MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_H3 || MACH_SUN8I_A83T + default y if MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_H3 || MACH_SUN8I_A83T || MACH_SUN8I_V3S
config DRAM_TYPE int "sunxi dram type" @@ -481,7 +492,7 @@ config AXP_GPIO
config VIDEO bool "Enable graphical uboot console on HDMI, LCD or VGA" - depends on !MACH_SUN8I_A83T && !MACH_SUN8I_H3 && !MACH_SUN9I && !MACH_SUN50I + depends on !MACH_SUN8I_A83T && !MACH_SUN8I_H3 && !MACH_SUN8I_V3S && !MACH_SUN9I && !MACH_SUN50I default y ---help--- Say Y here to add support for using a cfb console on the HDMI, LCD diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index a4c3fb69e4..6ac42acaea 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -21,6 +21,8 @@ #define CONFIG_SUNXI_USB_PHYS 4 #elif defined CONFIG_MACH_SUN8I_A83T #define CONFIG_SUNXI_USB_PHYS 3 +#elif defined CONFIG_MACH_SUN8I_V3S + #define CONFIG_SUNXI_USB_PHYS 1 #else #define CONFIG_SUNXI_USB_PHYS 2 #endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b0bfc0dfd7..6bcb9e692c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -75,8 +75,13 @@ #else #define SDRAM_OFFSET(x) 0x4##x #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0x41000000 /* default load address */ +/* V3s do not have enough memory to place code at 0x4a000000 */ +#ifndef CONFIG_MACH_SUN8I_V3S #define CONFIG_SYS_TEXT_BASE 0x4a000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x42e00000 +#endif /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -148,8 +153,13 @@ #define CONFIG_SYS_MMC_MAX_DEVICE 4 #endif
+#ifndef CONFIG_MACH_SUN8I_V3S /* 64MB of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (64 << 20)) +#else +/* 2MB of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (2 << 20)) +#endif
/* * Miscellaneous configurable options @@ -280,7 +290,11 @@ extern int soft_i2c_gpio_scl; * The amount of RAM to keep free at the top of RAM when relocating u-boot, * to use as framebuffer. This must be a multiple of 4096. */ +#ifndef CONFIG_MACH_SUN8I_V3S #define CONFIG_SUNXI_MAX_FB_SIZE (16 << 20) +#else +#define CONFIG_SUNXI_MAX_FB_SIZE (2 << 20) +#endif
/* Do we want to initialize a simple FB? */ #define CONFIG_VIDEO_DT_SIMPLEFB @@ -383,12 +397,24 @@ extern int soft_i2c_gpio_scl; * 32M uncompressed kernel, 16M compressed kernel, 1M fdt, * 1M script, 1M pxe and the ramdisk at the end. */ - +#ifndef CONFIG_MACH_SUN8I_V3S #define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(2000000)) #define FDT_ADDR_R __stringify(SDRAM_OFFSET(3000000)) #define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(3100000)) #define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000)) #define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3300000)) +#else +/* + * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc. + * 16M uncompressed kernel, 8M compressed kernel, 1M fdt, + * 1M script, 1M pxe and the ramdisk at the end. + */ +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) +#endif #endif
#define MEM_LAYOUT_ENV_SETTINGS \ @@ -399,11 +425,19 @@ extern int soft_i2c_gpio_scl; "pxefile_addr_r=" PXEFILE_ADDR_R "\0" \ "ramdisk_addr_r=" RAMDISK_ADDR_R "\0"
+#ifndef CONFIG_MACH_SUN8I_V3S #define DFU_ALT_INFO_RAM \ "dfu_alt_info_ram=" \ "kernel ram " KERNEL_ADDR_R " 0x1000000;" \ "fdt ram " FDT_ADDR_R " 0x100000;" \ "ramdisk ram " RAMDISK_ADDR_R " 0x4000000\0" +#else +#define DFU_ALT_INFO_RAM \ + "dfu_alt_info_ram=" \ + "kernel ram " KERNEL_ADDR_R " 0x800000;" \ + "fdt ram " FDT_ADDR_R " 0x100000;" \ + "ramdisk ram " RAMDISK_ADDR_R " 0x1000000\0" +#endif
#ifdef CONFIG_MMC #define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0)
As we have now V3s support in board code, the V3s DTSI file should also be added.
Add also some CCU include headers to satisfy the DTSI file.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes since v1: - Changed into the real DTSI.
arch/arm/dts/sun8i-v3s.dtsi | 284 ++++++++++++++++++++++++++++++ include/dt-bindings/clock/sun8i-v3s-ccu.h | 107 +++++++++++ include/dt-bindings/reset/sun8i-v3s-ccu.h | 78 ++++++++ 3 files changed, 469 insertions(+) create mode 100644 arch/arm/dts/sun8i-v3s.dtsi create mode 100644 include/dt-bindings/clock/sun8i-v3s-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-v3s-ccu.h
diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi new file mode 100644 index 0000000000..ebefc0fefe --- /dev/null +++ b/arch/arm/dts/sun8i-v3s.dtsi @@ -0,0 +1,284 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/clock/sun8i-v3s-ccu.h> +#include <dt-bindings/reset/sun8i-v3s-ccu.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&gic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + clocks = <&ccu CLK_CPU>; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; + }; + + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + mmc0: mmc@01c0f000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c0f000 0x1000>; + clocks = <&ccu CLK_BUS_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc1: mmc@01c10000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c10000 0x1000>; + clocks = <&ccu CLK_BUS_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@01c11000 { + compatible = "allwinner,sun7i-a20-mmc"; + reg = <0x01c11000 0x1000>; + clocks = <&ccu CLK_BUS_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usb_otg: usb@01c19000 { + compatible = "allwinner,sun8i-h3-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun8i-v3s-usb-phy"; + reg = <0x01c19400 0x2c>, + <0x01c1a800 0x4>; + reg-names = "phy_ctrl", + "pmu0"; + clocks = <&ccu CLK_USB_PHY0>; + clock-names = "usb0_phy"; + resets = <&ccu RST_USB_PHY0>; + reset-names = "usb0_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ccu: clock@01c20000 { + compatible = "allwinner,sun8i-v3s-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + rtc: rtc@01c20400 { + compatible = "allwinner,sun6i-a31-rtc"; + reg = <0x01c20400 0x54>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + }; + + pio: pinctrl@01c20800 { + compatible = "allwinner,sun8i-v3s-pinctrl"; + reg = <0x01c20800 0x400>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; + + uart0_pins_a: uart0@0 { + pins = "PB8", "PB9"; + function = "uart0"; + bias-pull-up; + }; + + mmc0_pins_a: mmc0@0 { + pins = "PF0", "PF1", "PF2", "PF3", + "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; + }; + }; + + timer@01c20c00 { + compatible = "allwinner,sun4i-a10-timer"; + reg = <0x01c20c00 0xa0>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + }; + + wdt0: watchdog@01c20ca0 { + compatible = "allwinner,sun6i-a31-wdt"; + reg = <0x01c20ca0 0x20>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + }; + + uart0: serial@01c28000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28000 0x400>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; + status = "disabled"; + }; + + uart1: serial@01c28400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28400 0x400>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + status = "disabled"; + }; + + uart2: serial@01c28800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28800 0x400>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; + status = "disabled"; + }; + + gic: interrupt-controller@01c81000 { + compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x1000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + }; +}; diff --git a/include/dt-bindings/clock/sun8i-v3s-ccu.h b/include/dt-bindings/clock/sun8i-v3s-ccu.h new file mode 100644 index 0000000000..c0d5d5599c --- /dev/null +++ b/include/dt-bindings/clock/sun8i-v3s-ccu.h @@ -0,0 +1,107 @@ +/* + * Copyright (c) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun8i-h3-ccu.h, which is: + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN8I_V3S_H_ +#define _DT_BINDINGS_CLK_SUN8I_V3S_H_ + +#define CLK_CPU 14 + +#define CLK_BUS_CE 20 +#define CLK_BUS_DMA 21 +#define CLK_BUS_MMC0 22 +#define CLK_BUS_MMC1 23 +#define CLK_BUS_MMC2 24 +#define CLK_BUS_DRAM 25 +#define CLK_BUS_EMAC 26 +#define CLK_BUS_HSTIMER 27 +#define CLK_BUS_SPI0 28 +#define CLK_BUS_OTG 29 +#define CLK_BUS_EHCI0 30 +#define CLK_BUS_OHCI0 31 +#define CLK_BUS_VE 32 +#define CLK_BUS_TCON0 33 +#define CLK_BUS_CSI 34 +#define CLK_BUS_DE 35 +#define CLK_BUS_CODEC 36 +#define CLK_BUS_PIO 37 +#define CLK_BUS_I2C0 38 +#define CLK_BUS_I2C1 39 +#define CLK_BUS_UART0 40 +#define CLK_BUS_UART1 41 +#define CLK_BUS_UART2 42 +#define CLK_BUS_EPHY 43 +#define CLK_BUS_DBG 44 + +#define CLK_MMC0 45 +#define CLK_MMC0_SAMPLE 46 +#define CLK_MMC0_OUTPUT 47 +#define CLK_MMC1 48 +#define CLK_MMC1_SAMPLE 49 +#define CLK_MMC1_OUTPUT 50 +#define CLK_MMC2 51 +#define CLK_MMC2_SAMPLE 52 +#define CLK_MMC2_OUTPUT 53 +#define CLK_CE 54 +#define CLK_SPI0 55 +#define CLK_USB_PHY0 56 +#define CLK_USB_OHCI0 57 + +#define CLK_DRAM_VE 59 +#define CLK_DRAM_CSI 60 +#define CLK_DRAM_EHCI 61 +#define CLK_DRAM_OHCI 62 +#define CLK_DE 63 +#define CLK_TCON0 64 +#define CLK_CSI_MISC 65 +#define CLK_CSI0_MCLK 66 +#define CLK_CSI1_SCLK 67 +#define CLK_CSI1_MCLK 68 +#define CLK_VE 69 +#define CLK_AC_DIG 70 +#define CLK_AVS 71 + +#define CLK_MIPI_CSI 73 + +#endif /* _DT_BINDINGS_CLK_SUN8I_V3S_H_ */ diff --git a/include/dt-bindings/reset/sun8i-v3s-ccu.h b/include/dt-bindings/reset/sun8i-v3s-ccu.h new file mode 100644 index 0000000000..b58ef21a2e --- /dev/null +++ b/include/dt-bindings/reset/sun8i-v3s-ccu.h @@ -0,0 +1,78 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun8i-v3s-ccu.h, which is + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN8I_V3S_H_ +#define _DT_BINDINGS_RST_SUN8I_V3S_H_ + +#define RST_USB_PHY0 0 + +#define RST_MBUS 1 + +#define RST_BUS_CE 5 +#define RST_BUS_DMA 6 +#define RST_BUS_MMC0 7 +#define RST_BUS_MMC1 8 +#define RST_BUS_MMC2 9 +#define RST_BUS_DRAM 11 +#define RST_BUS_EMAC 12 +#define RST_BUS_HSTIMER 14 +#define RST_BUS_SPI0 15 +#define RST_BUS_OTG 17 +#define RST_BUS_EHCI0 18 +#define RST_BUS_OHCI0 22 +#define RST_BUS_VE 26 +#define RST_BUS_TCON0 27 +#define RST_BUS_CSI 30 +#define RST_BUS_DE 34 +#define RST_BUS_DBG 38 +#define RST_BUS_EPHY 39 +#define RST_BUS_CODEC 40 +#define RST_BUS_I2C0 46 +#define RST_BUS_I2C1 47 +#define RST_BUS_UART0 49 +#define RST_BUS_UART1 50 +#define RST_BUS_UART2 51 + +#endif /* _DT_BINDINGS_RST_SUN8I_H3_H_ */
Lichee Pi Zero is a development board with a V3s SoC.
Add support for it.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- Changes since v1: - Add a defconfig - Change to the real DTSI
arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-v3s-licheepi-zero.dts | 83 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/LicheePi_Zero_defconfig | 13 +++++ 4 files changed, 103 insertions(+) create mode 100644 arch/arm/dts/sun8i-v3s-licheepi-zero.dts create mode 100644 configs/LicheePi_Zero_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ee608b5b4..469dd710cf 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -280,6 +280,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ sun8i-h3-nanopi-neo.dtb +dtb-$(CONFIG_MACH_SUN8I_V3S) += \ + sun8i-v3s-licheepi-zero.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts new file mode 100644 index 0000000000..3d9168cbae --- /dev/null +++ b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts @@ -0,0 +1,83 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-v3s.dtsi" +#include "sunxi-common-regulators.dtsi" + +/ { + model = "Lichee Pi Zero"; + compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&mmc0 { + pinctrl-0 = <&mmc0_pins_a>; + pinctrl-names = "default"; + broken-cd; + bus-width = <4>; + vmmc-supply = <®_vcc3v3>; + status = "okay"; +}; + +&uart0 { + pinctrl-0 = <&uart0_pins_a>; + pinctrl-names = "default"; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index e23d45eed9..fe4e517256 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -182,6 +182,11 @@ M: Jelle de Jong jelledejong@powercraft.nl S: Maintained F: configs/Lamobo_R1_defconfig
+LICHEEPI-ZERO BOARD +M: Icenowy Zheng icenowy@aosc.xyz +S: Maintained +F: configs/LicheePi_Zero_defconfig + LINKSPRITE-PCDUINO BOARD M: Zoltan Herpai wigyori@uid0.hu S: Maintained diff --git a/configs/LicheePi_Zero_defconfig b/configs/LicheePi_Zero_defconfig new file mode 100644 index 0000000000..42414a81a7 --- /dev/null +++ b/configs/LicheePi_Zero_defconfig @@ -0,0 +1,13 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +# CONFIG_ARMV7_NONSEC is not set +CONFIG_MACH_SUN8I_V3S=y +CONFIG_DRAM_CLK=360 +CONFIG_DRAM_ZQ=14779 +CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero" +# CONFIG_CONSOLE_MUX is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_NETDEVICES is not set
USB OTG on V3s SoC seems to need the USB OTG clock gate to be passed and the reset to be deasserted before boot, otherwise it won't work in Linux.
It seems very difficult to workaround this from CCU driver in the kernel, so add this quirk.
Also add a generic quirk framework in sunxi's clock initialization code.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- New patch in v2.
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 1 + arch/arm/mach-sunxi/clock.c | 5 +++++ arch/arm/mach-sunxi/clock_sun6i.c | 11 +++++++++++ 3 files changed, 17 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index be9fcfda0e..9e22e15633 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -376,6 +376,7 @@ struct sunxi_ccm_reg { #define CCM_PLL11_PATTERN 0xf5860000
/* ahb_reset0 offsets */ +#define AHB_RESET_OFFSET_OTG 24 #define AHB_RESET_OFFSET_GMAC 17 #define AHB_RESET_OFFSET_MCTL 14 #define AHB_RESET_OFFSET_MMC3 11 diff --git a/arch/arm/mach-sunxi/clock.c b/arch/arm/mach-sunxi/clock.c index e6f53f91e6..505f9178dc 100644 --- a/arch/arm/mach-sunxi/clock.c +++ b/arch/arm/mach-sunxi/clock.c @@ -20,6 +20,10 @@ __weak void clock_init_sec(void) { }
+__weak void clock_init_quirk(void) +{ +} + __weak void gtbus_init(void) { } @@ -32,6 +36,7 @@ int clock_init(void) #endif clock_init_uart(); clock_init_sec(); + clock_init_quirk();
return 0; } diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index ed8cd9bbb3..474c5a325d 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -58,6 +58,17 @@ void clock_init_sec(void) #endif }
+void clock_init_quirk(void) +{ + /* without this quirk, the USB PHY cannot be used in Linux */ +#ifdef CONFIG_MACH_SUN8I_V3S + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + setbits_le32(&ccm->ahb_gate0, 1 << AHB_GATE_OFFSET_USB0); + setbits_le32(&ccm->ahb_reset0_cfg, 1 << AHB_RESET_OFFSET_OTG); +#endif +} + void clock_init_uart(void) { #if CONFIG_CONS_INDEX < 5
Icenowy Zheng
