[PATCH v2 1/1] doc: move README.NetConsole to HTML documentation
Convert README.NetConsole to reStructured text and move it to doc/usage/netconsole.rst.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org --- v2: add changes to doc/usage/index.rst --- doc/README.NetConsole | 97 ---------------------------------- doc/usage/index.rst | 2 + doc/usage/netconsole.rst | 109 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 111 insertions(+), 97 deletions(-) delete mode 100644 doc/README.NetConsole create mode 100644 doc/usage/netconsole.rst
diff --git a/doc/README.NetConsole b/doc/README.NetConsole deleted file mode 100644 index af7fc6043a..0000000000 --- a/doc/README.NetConsole +++ /dev/null @@ -1,97 +0,0 @@ - -In U-Boot, we implemented the networked console via the standard -"devices" mechanism, which means that you can switch between the -serial and network input/output devices by adjusting the 'stdin' and -'stdout' environment variables. To switch to the networked console, -set either of these variables to "nc". Input and output can be -switched independently. - -CONFIG_NETCONSOLE_BUFFER_SIZE - Override the default buffer size - -We use an environment variable 'ncip' to set the IP address and the -port of the destination. The format is <ip_addr>:<port>. If <port> is -omitted, the value of 6666 is used. If the env var doesn't exist, the -broadcast address and port 6666 are used. If it is set to an IP -address of 0 (or 0.0.0.0) then no messages are sent to the network. -The source / listening port can be configured separately by setting -the 'ncinport' environment variable and the destination port can be -configured by setting the 'ncoutport' environment variable. - -For example, if your server IP is 192.168.1.1, you could use: - - => setenv nc 'setenv stdout nc;setenv stdin nc' - => setenv ncip 192.168.1.1 - => saveenv - => run nc - - -On the host side, please use this script to access the console: - - tools/netconsole <ip> [port] - -The script uses netcat to talk to the board over UDP. It requires you to -specify the target IP address (or host name, assuming DNS is working). The -script can be interrupted by pressing ^T (CTRL-T). - -Be aware that in some distributives (Fedora Core 5 at least) -usage of nc has been changed and -l and -p options are considered -as mutually exclusive. If nc complains about options provided, -you can just remove the -p option from the script. - -It turns out that 'netcat' cannot be used to listen to broadcast -packets. We developed our own tool 'ncb' (see tools directory) that -listens to broadcast packets on a given port and dumps them to the -standard output. It will be built when compiling for a board which -has CONFIG_NETCONSOLE defined. If the netconsole script can find it -in PATH or in the same directory, it will be used instead. - -For Linux, the network-based console needs special configuration. -Minimally, the host IP address needs to be specified. This can be -done either via the kernel command line, or by passing parameters -while loading the netconsole.o module (when used in a loadable module -configuration). Please refer to Documentation/networking/logging.txt -file for the original Ingo Molnar's documentation on how to pass -parameters to the loadable module. - -The format of the kernel command line parameter (for the static -configuration) is as follows: - - netconsole=[src-port]@[src-ip]/[<dev>],[tgt-port]@<tgt-ip>/[tgt-macaddr] - -where - - src-port source for UDP packets - (defaults to 6665) - src-ip source IP to use - (defaults to the interface's address) - dev network interface - (defaults to eth0) - tgt-port port for logging agent - (defaults to 6666) - tgt-ip IP address for logging agent - (this is the required parameter) - tgt-macaddr ethernet MAC address for logging agent - (defaults to broadcast) - -Examples: - - netconsole=4444@10.0.0.1/eth1,9353@10.0.0.2/12:34:56:78:9a:bc - -or - - netconsole=@/,@192.168.3.1/ - -Please note that for the Linux networked console to work, the -ethernet interface has to be up by the time the netconsole driver is -initialized. This means that in case of static kernel configuration, -the respective Ethernet interface has to be brought up using the "IP -Autoconfiguration" kernel feature, which is usually done by defaults -in the ELDK-NFS-based environment. - -To browse the Linux network console output, use the 'netcat' tool invoked -as follows: - - nc -u -l -p 6666 - -Note that unlike the U-Boot implementation the Linux netconsole is -unidirectional, i. e. you have console output only in Linux. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index af7d50650d..063e970981 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -3,6 +3,8 @@ Use U-Boot
.. toctree::
+ netconsole + Shell commands --------------
diff --git a/doc/usage/netconsole.rst b/doc/usage/netconsole.rst new file mode 100644 index 0000000000..0156f0212d --- /dev/null +++ b/doc/usage/netconsole.rst @@ -0,0 +1,109 @@ +Network console +=============== + +In U-Boot, we implemented the networked console via the standard +"devices" mechanism, which means that you can switch between the +serial and network input/output devices by adjusting the 'stdin' and +'stdout' environment variables. To switch to the networked console, +set either of these variables to "nc". Input and output can be +switched independently. + +The default buffer size can be overridden by setting +CONFIG_NETCONSOLE_BUFFER_SIZE. + +We use an environment variable 'ncip' to set the IP address and the +port of the destination. The format is <ip_addr>:<port>. If <port> is +omitted, the value of 6666 is used. If the env var doesn't exist, the +broadcast address and port 6666 are used. If it is set to an IP +address of 0 (or 0.0.0.0) then no messages are sent to the network. +The source / listening port can be configured separately by setting +the 'ncinport' environment variable and the destination port can be +configured by setting the 'ncoutport' environment variable. + +For example, if your server IP is 192.168.1.1, you could use:: + + => setenv nc 'setenv stdout nc;setenv stdin nc' + => setenv ncip 192.168.1.1 + => saveenv + => run nc + +On the host side, please use this script to access the console + +.. code-block:: bash + + tools/netconsole <ip> [port] + +The script uses netcat to talk to the board over UDP. It requires you to +specify the target IP address (or host name, assuming DNS is working). The +script can be interrupted by pressing ^T (CTRL-T). + +Be aware that in some distributives (Fedora Core 5 at least) +usage of nc has been changed and -l and -p options are considered +as mutually exclusive. If nc complains about options provided, +you can just remove the -p option from the script. + +It turns out that 'netcat' cannot be used to listen to broadcast +packets. We developed our own tool 'ncb' (see tools directory) that +listens to broadcast packets on a given port and dumps them to the +standard output. It will be built when compiling for a board which +has CONFIG_NETCONSOLE defined. If the netconsole script can find it +in PATH or in the same directory, it will be used instead. + +For Linux, the network-based console needs special configuration. +Minimally, the host IP address needs to be specified. This can be +done either via the kernel command line, or by passing parameters +while loading the netconsole.o module (when used in a loadable module +configuration). Please refer to Documentation/networking/logging.txt +file for the original Ingo Molnar's documentation on how to pass +parameters to the loadable module. + +The format of the kernel command line parameter (for the static +configuration) is as follows + +.. code-block:: bash + + netconsole=[src-port]@[src-ip]/[<dev>],[tgt-port]@<tgt-ip>/[tgt-macaddr] + +where + +src-port + source for UDP packets (defaults to 6665) + +src-ip + source IP to use (defaults to the interface's address) + +dev + network interface (defaults to eth0) + +tgt-port + port for logging agent (defaults to 6666) + +tgt-ip + IP address for logging agent (this is the required parameter) + +tgt-macaddr + ethernet MAC address for logging agent (defaults to broadcast) + +Examples + +.. code-block:: bash + + netconsole=4444@10.0.0.1/eth1,9353@10.0.0.2/12:34:56:78:9a:bc + netconsole=@/,@192.168.3.1/ + +Please note that for the Linux networked console to work, the +ethernet interface has to be up by the time the netconsole driver is +initialized. This means that in case of static kernel configuration, +the respective Ethernet interface has to be brought up using the "IP +Autoconfiguration" kernel feature, which is usually done by defaults +in the ELDK-NFS-based environment. + +To browse the Linux network console output, use the 'netcat' tool invoked +as follows: + +.. code-block:: bash + + nc -u -l -p 6666 + +Note that unlike the U-Boot implementation the Linux netconsole is +unidirectional, i. e. you have console output only in Linux. -- 2.29.2
