[U-Boot] Pull request: u-boot-uniphier
The following changes since commit 125738e819a3b9d15210794b3dcef9f4d9bcf866:
Prepare v2015.01-rc4 (2014-12-29 21:22:38 -0500)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 7b77c9ab6fa90ada42185bcc64b7d33812fed35d:
ARM: UniPhier: display boot swap pin status by pinmon command (2014-12-30 17:45:40 +0900)
---------------------------------------------------------------- Masahiro Yamada (3): ARM: UniPhier: add DDR PHY training code ARM: UniPhier: add dump command of DDR PHY parameters ARM: UniPhier: display boot swap pin status by pinmon command
arch/arm/cpu/armv7/uniphier/Kconfig | 7 ++ arch/arm/cpu/armv7/uniphier/Makefile | 2 + arch/arm/cpu/armv7/uniphier/cmd_ddrphy.c | 229 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 3 + arch/arm/cpu/armv7/uniphier/ddrphy_training.c | 144 +++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 2 +- arch/arm/cpu/armv7/uniphier/ph1-ld4/ddrphy_init.c | 70 +++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 13 ++++ arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 2 +- arch/arm/cpu/armv7/uniphier/ph1-pro4/ddrphy_init.c | 70 +++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 25 +++++++ arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 2 +- arch/arm/cpu/armv7/uniphier/ph1-sld8/ddrphy_init.c | 75 +++++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 13 ++++ arch/arm/include/asm/arch-uniphier/ddrphy-regs.h | 172 ++++++++++++++++++++++++++++++++++++++++++ 15 files changed, 826 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_ddrphy.c create mode 100644 arch/arm/cpu/armv7/uniphier/ddrphy_training.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/ddrphy_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/ddrphy_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/ddrphy_init.c create mode 100644 arch/arm/include/asm/arch-uniphier/ddrphy-regs.h
Masahiro YAMADA
