[U-Boot] [PATCH] nand booting support (SPL) for phyCORE-i.MX31
This patch allows Phytec phyCORE-i.MX31 based system to boot from embed NAND-flash memory.It not add support for NAND cmd and/or driver for U-BOOT, it is only SPL for U-BOOT. For NAND support in U-BOOT I give refer to Magnus Lilja's aug/2008 patch series for PDK/Litekit boards. ("[U-Boot] [PATCH v3 4/6] i.MX31: Add i.MX31 NAND Flash Controller driver."; MID 1219998982-21289-5-git-send-email-lilja.magnus@gmail.com)
Some note: by default, Phytec phyCORE-i.MX31 board (pcm-037 on pcm-970) is not suitable for nand-bootloading, because of SW5 switchers block haven't appropriate modes(8-bit, 2k page or 16-bit, 512B page) for BOOTPINS[4:0] and nand-flash(8-bit mode, 512B page) contemporary. There is require to make RESOLDER for really nand-booting either BOOTPIN state or JN1/2 and RN41/42. This nand-spl work with 8-bit, 512B page size nand-flash.
Patch is applicable on v2008.10 release tag master branch.
Maxim Artamonov, scn1874 a t yandex d o t ru. Nov, 29, 2008 --- MAKEALL | 1 + Makefile | 9 ++- board/imx31_phycore/config.mk | 10 ++ board/imx31_phycore/lowlevel_init.S | 29 ++++++- board/imx31_phycore/u-boot-nand.lds | 62 ++++++++++++ cpu/arm1136/start.S | 36 +++++-- include/asm-arm/arch-mx31/mx31-regs.h | 98 +++++++++++++++++++- include/configs/imx31_phycore.h | 58 +++++++++-- nand_spl/board/imx31_phycore/Makefile | 95 ++++++++++++++++++ nand_spl/board/imx31_phycore/config.mk | 33 +++++++ nand_spl/board/imx31_phycore/u-boot.lds | 65 +++++++++++++ nand_spl/nand_boot_mx31.c | 160 +++++++++++++++++++++++++++++++ 12 files changed, 633 insertions(+), 23 deletions(-) create mode 100644 board/imx31_phycore/u-boot-nand.lds create mode 100644 nand_spl/board/imx31_phycore/Makefile create mode 100644 nand_spl/board/imx31_phycore/config.mk create mode 100644 nand_spl/board/imx31_phycore/u-boot.lds create mode 100644 nand_spl/nand_boot_mx31.c
diff --git a/MAKEALL b/MAKEALL index 9ccb9ac..1f639a8 100755 --- a/MAKEALL +++ b/MAKEALL @@ -522,6 +522,7 @@ LIST_ARM11=" \ apollon \ imx31_litekit \ imx31_phycore \ + imx31_phycore_nand \ mx31ads \ smdk6400 \ " diff --git a/Makefile b/Makefile index 58b8331..7519dfe 100644 --- a/Makefile +++ b/Makefile @@ -353,7 +353,7 @@ $(NAND_SPL): $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C nand_spl/board/$(BOARDDIR) all
$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin $(obj)include/autoconf.mk - cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin + cat $(obj)nand_spl/u-boot-spl-aligned.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
$(ONENAND_IPL): $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C onenand_ipl/board/$(BOARDDIR) all @@ -2805,6 +2805,13 @@ imx31_litekit_config : unconfig imx31_phycore_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 imx31_phycore NULL mx31
+imx31_phycore_nand_config : unconfig + @mkdir -p $(obj)include $(obj)board/imx31_phycore + @mkdir -p $(obj)nand_spl/board/imx31_phycore + @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h + @$(MKCONFIG) -n $@ -a imx31_phycore arm arm1136 imx31_phycore NULL mx31 + @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk + mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
diff --git a/board/imx31_phycore/config.mk b/board/imx31_phycore/config.mk index d34dc02..412defc 100644 --- a/board/imx31_phycore/config.mk +++ b/board/imx31_phycore/config.mk @@ -1 +1,11 @@ +# +# (C) Copyright 2008 +# was changed by Maxim Artamonov, <scn1874 at yandex.ru> +# + +ifndef CONFIG_NAND_SPL TEXT_BASE = 0x87f00000 +else +TEXT_BASE = 0x87ec0000 +endif + diff --git a/board/imx31_phycore/lowlevel_init.S b/board/imx31_phycore/lowlevel_init.S index c5d6eb0..bd838c7 100644 --- a/board/imx31_phycore/lowlevel_init.S +++ b/board/imx31_phycore/lowlevel_init.S @@ -1,5 +1,7 @@ /* - * + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de * * See file CREDITS for list of people who contributed to this @@ -43,6 +45,20 @@ bcs 1b .endm
+#ifdef CONFIG_NAND_SPL +/* somewhat macro to reduce bin size for CONFIG_NAND_SPL*/ +.macro FILLREGS begreg, val, count, step + ldr r2, =\begreg + ldr r3, =\val + ldr r4, =\count +2: + str r3, [r2] + add r2, r2, #\step + subs r4, r4, #1 + bcs 2b +.endm +#endif + .globl lowlevel_init lowlevel_init:
@@ -60,10 +76,20 @@ lowlevel_init:
REG CCM_SPCTL, PLL_PD(1) | PLL_MFD(0x43) | PLL_MFI(12) | PLL_MFN(1)
+ REG CCM_UPCTL, 0x40c2403 /* USB Clock 60 MHZ *//*add 201108 for USB clocking init*/ + +#ifdef CONFIG_NAND_SPL + FILLREGS 0x43FAC26C, 0, 0x3, 0x4 +#else REG 0x43FAC26C, 0 /* SDCLK */ REG 0x43FAC270, 0 /* CAS */ REG 0x43FAC274, 0 /* RAS */ +#endif /* CONFIG_NAND_SPL */ REG 0x43FAC27C, 0x1000 /* CS2 (CSD0) */ + +#ifdef CONFIG_NAND_SPL + FILLREGS 0x43FAC284, 0, 0x17, 0x4 +#else REG 0x43FAC284, 0 /* DQM3 */ REG 0x43FAC288, 0 /* DQM2, DQM1, DQM0, SD31-SD0, A25-A0, MA10 (0x288..0x2DC) */ REG 0x43FAC28C, 0 @@ -87,6 +113,7 @@ lowlevel_init: REG 0x43FAC2D4, 0 REG 0x43FAC2D8, 0 REG 0x43FAC2DC, 0 +#endif /* CONFIG_NAND_SPL */ REG 0xB8001010, 0x00000004 REG 0xB8001004, 0x006ac73a REG 0xB8001000, 0x92100000 diff --git a/board/imx31_phycore/u-boot-nand.lds b/board/imx31_phycore/u-boot-nand.lds new file mode 100644 index 0000000..bd09a8d --- /dev/null +++ b/board/imx31_phycore/u-boot-nand.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm1136/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/cpu/arm1136/start.S b/cpu/arm1136/start.S index 51b664d..596efe9 100644 --- a/cpu/arm1136/start.S +++ b/cpu/arm1136/start.S @@ -1,6 +1,9 @@ /* * armboot - Startup Code for OMP2420/ARM1136 CPU-core * + * + * Copyright (c) 2008 Maxim Artamonov, <scn1874 at yandex.ru> + * * Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com * * Copyright (c) 2001 Marius Grüger mag@sysgo.de @@ -32,6 +35,15 @@ #include <version.h> .globl _start _start: b reset +#ifdef CONFIG_NAND_SPL + nop + nop + nop + nop + nop + nop + nop +#else #ifdef CONFIG_ONENAND_IPL ldr pc, _hang ldr pc, _hang @@ -68,6 +80,7 @@ _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ #endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_NAND_SPL */ .global _end_vect _end_vect:
@@ -156,9 +169,9 @@ relocate: /* relocate U-Boot to RAM */ adr r0, _start /* r0 <- current position of code */ ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ cmp r0, r1 /* don't reloc during debug */ -#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) beq stack_setup -#endif /* CONFIG_ONENAND_IPL */ +#endif /* !CONFIG_ONENAND_IPL && !CONFIG_NAND_SPL*/
ldr r2, _armboot_start ldr r3, _bss_start @@ -175,7 +188,7 @@ copy_loop: /* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ -#ifdef CONFIG_ONENAND_IPL +#if defined(CONFIG_ONENAND_IPL) || defined (CONFIG_NAND_SPL) sub sp, r0, #128 /* leave 32 words for abort-stack */ #else sub r0, r0, #CFG_MALLOC_LEN /* malloc area */ @@ -184,14 +197,14 @@ stack_setup: sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif sub sp, r0, #12 /* leave 3 words for abort-stack */ -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_ONENAND_IPL || CONFIG_NAND_SPL*/
clear_bss: ldr r0, _bss_start /* find start of bss segment */ ldr r1, _bss_end /* stop here */ mov r2, #0x00000000 /* clear */
-#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 @@ -200,12 +213,15 @@ clbss_l:str r2, [r0] /* clear loop... */
ldr pc, _start_armboot
+#ifdef CONFIG_NAND_SPL +_start_armboot: .word nand_boot +#else #ifdef CONFIG_ONENAND_IPL _start_armboot: .word start_oneboot #else _start_armboot: .word start_armboot -#endif - +#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_NAND_SPL */
/* ************************************************************************* @@ -244,7 +260,7 @@ cpu_init_crit: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */
-#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) /* ************************************************************************* * @@ -357,11 +373,12 @@ cpu_init_crit: .macro get_fiq_stack @ setup FIQ stack ldr sp, FIQ_STACK_START .endm -#endif /* CONFIG_ONENAND_IPL */ +#endif /* !CONFIG_ONENAND_IPL && !CONFIG_NAND_SPL*/
/* * exception handlers */ +#ifndef CONFIG_NAND_SPL #ifdef CONFIG_ONENAND_IPL .align 5 do_hang: @@ -436,3 +453,4 @@ arm1136_cache_flush: mcr p15, 0, r1, c7, c5, 0 @ invalidate I cache mov pc, lr @ back to caller #endif /* CONFIG_ONENAND_IPL */ +#endif /* !CONFIG_NAND_SPL*/ diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index b04a718..7d6bd45 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -34,7 +34,7 @@ #define CCM_PDR1 (CCM_BASE + 0x08) #define CCM_RCSR (CCM_BASE + 0x0c) #define CCM_MPCTL (CCM_BASE + 0x10) -#define CCM_UPCTL (CCM_BASE + 0x10) +#define CCM_UPCTL (CCM_BASE + 0x14) #define CCM_SPCTL (CCM_BASE + 0x18) #define CCM_COSR (CCM_BASE + 0x1C) #define CCM_CGR0 (CCM_BASE + 0x20) @@ -168,4 +168,100 @@ #define CS5_BASE 0xB6000000 #define PCMCIA_MEM_BASE 0xC0000000
+/* + * NAND controller + */ +#define NFC_BASE_ADDR 0xB8000000 + +/* + * Addresses for NFC registers + */ +#define NFC_BUF_SIZE (*((volatile u16 *)(NFC_BASE_ADDR + 0xE00))) +#define NFC_BUF_ADDR (*((volatile u16 *)(NFC_BASE_ADDR + 0xE04))) +#define NFC_FLASH_ADDR (*((volatile u16 *)(NFC_BASE_ADDR + 0xE06))) +#define NFC_FLASH_CMD (*((volatile u16 *)(NFC_BASE_ADDR + 0xE08))) +#define NFC_CONFIG (*((volatile u16 *)(NFC_BASE_ADDR + 0xE0A))) +#define NFC_ECC_STATUS_RESULT (*((volatile u16 *)(NFC_BASE_ADDR + 0xE0C))) +#define NFC_RSLTMAIN_AREA (*((volatile u16 *)(NFC_BASE_ADDR + 0xE0E))) +#define NFC_RSLTSPARE_AREA (*((volatile u16 *)(NFC_BASE_ADDR + 0xE10))) +#define NFC_WRPROT (*((volatile u16 *)(NFC_BASE_ADDR + 0xE12))) +#define NFC_UNLOCKSTART_BLKADDR (*((volatile u16 *)(NFC_BASE_ADDR + 0xE14))) +#define NFC_UNLOCKEND_BLKADDR (*((volatile u16 *)(NFC_BASE_ADDR + 0xE16))) +#define NFC_NF_WRPRST (*((volatile u16 *)(NFC_BASE_ADDR + 0xE18))) +#define NFC_CONFIG1 (*((volatile u16 *)(NFC_BASE_ADDR + 0xE1A))) +#define NFC_CONFIG2 (*((volatile u16 *)(NFC_BASE_ADDR + 0xE1C))) + +/* + * Addresses for NFC RAM BUFFER Main area 0 + */ +#define MAIN_AREA0 (volatile u16 *)(NFC_BASE_ADDR + 0x000) +#define MAIN_AREA1 (volatile u16 *)(NFC_BASE_ADDR + 0x200) +#define MAIN_AREA2 (volatile u16 *)(NFC_BASE_ADDR + 0x400) +#define MAIN_AREA3 (volatile u16 *)(NFC_BASE_ADDR + 0x600) + +/* + * Addresses for NFC SPARE BUFFER Spare area 0 + */ +#define SPARE_AREA0 (volatile u16 *)(NFC_BASE_ADDR + 0x800) +#define SPARE_AREA1 (volatile u16 *)(NFC_BASE_ADDR + 0x810) +#define SPARE_AREA2 (volatile u16 *)(NFC_BASE_ADDR + 0x820) +#define SPARE_AREA3 (volatile u16 *)(NFC_BASE_ADDR + 0x830) + +/* + * Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command + * operation + */ +#define NFC_CMD 0x1 + +/* + * Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address + * operation + */ +#define NFC_ADDR 0x2 + +/* + * Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input + * operation + */ +#define NFC_INPUT 0x4 + +/* + * Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data + * Output operation + */ +#define NFC_OUTPUT 0x8 + +/* + * Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID + * operation + */ +#define NFC_ID 0x10 + +/* + * Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read + * Status operation + */ +#define NFC_STATUS 0x20 + +/* + * Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status + * operation + */ +#define NFC_INT 0x8000 + +#define NFC_SP_EN (1 << 2) +#define NFC_ECC_EN (1 << 3) +#define NFC_INT_MSK (1 << 4) +#define NFC_BIG (1 << 5) +#define NFC_RST (1 << 6) +#define NFC_CE (1 << 7) +#define NFC_ONE_CYCLE (1 << 8) + +/* + * NFMS bit in RCSR register for pagesize of nandflash + */ +#define NFMS (*((volatile u32 *)CCM_RCSR)) +#define NFMS_BIT 30 + #endif /* __ASM_ARCH_MX31_REGS_H */ + diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 1540203..dd6c39b 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -1,4 +1,7 @@ /* + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * * (C) Copyright 2004 * Texas Instruments. * Richard Woodruff r-woodruff2@ti.com @@ -34,6 +37,11 @@ #define CONFIG_MX31_HCLK_FREQ 26000000 #define CONFIG_MX31_CLK32 32000
+#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT +#endif + #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
@@ -85,26 +93,30 @@
#define CONFIG_BOOTDELAY 3
-#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:128k(uboot)ro,1536k(kernel),-(root)" +#define MTDPARTS_DEFAULT "mtdparts=phys_mapped_flash.0:128k(uboot)ro,128k(env),1792k(kernel),-(root)"
#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 192.168.23.168 -#define CONFIG_SERVERIP 192.168.23.2 +#define CONFIG_IPADDR 192.168.3.11 +#define CONFIG_SERVERIP 192.168.3.10
#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootargs_base=setenv bootargs console=ttySMX0,115200\0" \ - "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp\0" \ - "bootargs_flash=setenv bootargs $(bootargs) root=/dev/mtdblock2 rootfstype=jffs2" \ - "bootargs_mtd=setenv bootargs $(bootargs) $(mtdparts)" \ + "jffs2=root-pcm037.jffs2\0" \ + "uimage=uImage-pcm037\0" \ + "nfsrootfs=/nfsroot\0" \ "bootcmd=run bootcmd_net\0" \ + "mtdids=nor0=phys_mapped_flash\0" \ + "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp\0" \ + "bootargs_mtd=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "bootargs_flash=setenv bootargs $(bootargs) root=/dev/mtdblock3 rootfstype=jffs2\0" \ "bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; tftpboot 0x80000000 $(uimage); bootm\0" \ - "bootcmd_flash=run bootargs_base bootargs_mtd bootargs_flash; bootm 0x80000000\0" \ + "bootcmd_flash=run bootargs_base bootargs_mtd bootargs_flash; bootm 0xa0040000\0" \ + "bootcmd_netflash=run bootargs_base bootargs_mtd bootargs_flash; tftpboot 0x80000000 $(uimage); bootm\0" \ "unlock=yes\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "prg_uboot=tftpboot 0x80000000 $(uboot); protect off 0xa0000000 +0x20000; erase 0xa0000000 +0x20000; cp.b 0x80000000 0xa0000000 $(filesize)\0" \ - "prg_kernel=tftpboot 0x80000000 $(uimage); erase 0xa0040000 +0x180000; cp.b 0x80000000 0xa0040000 $(filesize)\0" \ - "prg_jffs2=tftpboot 0x80000000 $(jffs2); erase 0xa01c0000 0xa1ffffff; cp.b 0x80000000 0xa01c0000 $(filesize)\0" - + "prg_kernel=tftpboot 0x80000000 $(uimage); erase 0xa0040000 +0x1C0000; cp.b 0x80000000 0xa0040000 $(filesize)\0" \ + "prg_jffs2=tftpboot 0x80000000 $(jffs2); erase 0xa0200000 0xa1ffffff; cp.b 0x80000000 0xa0200000 $(filesize)\0"
#define CONFIG_DRIVER_SMC911X 1 #define CONFIG_DRIVER_SMC911X_BASE 0xa8000000 @@ -172,6 +184,30 @@ #define CFG_FLASH_ERASE_TOUT (100*CFG_HZ) /* Timeout for Flash Erase */ #define CFG_FLASH_WRITE_TOUT (100*CFG_HZ) /* Timeout for Flash Write */
+/*----------------------------------------------------------------------- + * NAND flash + */ + +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x40000000 + +/* + * Because of small buffer size of NFC in iMX31, SPL has to fit into 2kB. + */ + +#define CFG_NAND_U_BOOT_OFFS 0x800 +#define CFG_NAND_U_BOOT_SIZE 0x30000 +#define CFG_NAND_U_BOOT_DST 0x87f00000 /* Load big U-Boot to this addr */ +#define CFG_NAND_U_BOOT_START CFG_NAND_U_BOOT_DST /* Start big U-Boot from */ +#define CFG_NAND_SPL_DST CFG_NAND_U_BOOT_DST-0x40000 /* Relocate NAND_SPL to this adress*/ + +#define CFG_NAND_PAGE_SIZE 0x200 +#define CFG_NAND_BLOCK_SIZE 0x4000 +#define CFG_NAND_PAGE_COUNT 0x20 +/*for NAND_SPL*/ +#define CFG_NAND_CHIP_SIZE 0x4000000 + /* * JFFS2 partitions */ diff --git a/nand_spl/board/imx31_phycore/Makefile b/nand_spl/board/imx31_phycore/Makefile new file mode 100644 index 0000000..0aabea3 --- /dev/null +++ b/nand_spl/board/imx31_phycore/Makefile @@ -0,0 +1,95 @@ +# +# (C) Copyright 2008 +# Maxim Artamonov, <scn1874 at yandex.ru> +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o lowlevel_init.o +COBJS = nand_boot_mx31.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-aligned.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-aligned.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +# create symbolic links for common files + +# from cpu directory +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/cpu/arm1136/start.S $@ + +# from board directory +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/board/imx31_phycore/lowlevel_init.S $@ + +# from nand_spl directory +$(obj)nand_boot_mx31.c: + @rm -f $@ + @ln -s $(TOPDIR)/nand_spl/nand_boot_mx31.c $@ + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/imx31_phycore/config.mk b/nand_spl/board/imx31_phycore/config.mk new file mode 100644 index 0000000..4c271c5 --- /dev/null +++ b/nand_spl/board/imx31_phycore/config.mk @@ -0,0 +1,33 @@ +# +# (C) Copyright 2008 +# Maxim Artamonov, <scn1874 at yandex.ru> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# phyCORE-i.MX31 - PHYTECâs phyCORE Single Board Computer module + +# TEXT_BASE for SPL: = CFG_NAND_U_BOOT_DST-0x40000 is set in board/imx31_phycore/config.mk + +# PAD_TO used to generate a 2kByte binary needed for the combined image +# -> PAD_TO = TEXT_BASE + 2048 +PAD_TO := $(shell expr $$[$(TEXT_BASE) + 2048]) + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif diff --git a/nand_spl/board/imx31_phycore/u-boot.lds b/nand_spl/board/imx31_phycore/u-boot.lds new file mode 100644 index 0000000..d25abf8 --- /dev/null +++ b/nand_spl/board/imx31_phycore/u-boot.lds @@ -0,0 +1,65 @@ +/* + * + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + lowlevel_init.o (.text) + nand_boot_mx31.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/nand_spl/nand_boot_mx31.c b/nand_spl/nand_boot_mx31.c new file mode 100644 index 0000000..0003d7d --- /dev/null +++ b/nand_spl/nand_boot_mx31.c @@ -0,0 +1,160 @@ +/* + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * + * (C) Copyright 2006-2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <nand.h> +#include <asm-arm/arch/mx31-regs.h> + +static void mx31_wait_ready(void) +{ + while(1) + if (NFC_CONFIG2 & NFC_INT) + { + NFC_CONFIG2 = NFC_CONFIG2 & (~NFC_INT);/*int flag reset*/ + break; + } +} + +static void mx31_nand_init(void) +{ + /*unlocking RAM Buff*/ + NFC_CONFIG = 0x2; + + /* Block of NAND flash to be unlocked */ + /*NFC_UNLOCKSTART_BLKADDR = 0x0;*/ + /*NFC_UNLOCKEND_BLKADDR = 0x4000;*/ + + /* Unlock NAND Flash Block Command for given address range */ + /*NFC_WRPROT = 0x4;*/ + + NFC_CONFIG1 = NFC_ECC_EN; +} + +static void mx31_nand_command(unsigned short command) +{ + NFC_FLASH_CMD = command; + NFC_CONFIG2 = NFC_CMD; + mx31_wait_ready(); +} + +static void mx31_nand_page_address(unsigned int page_address) +{ + unsigned int page_count; + + NFC_FLASH_ADDR = 0x00; + NFC_CONFIG2 = NFC_ADDR; + mx31_wait_ready(); + + if(CFG_NAND_PAGE_SIZE==0x800) + { + NFC_FLASH_ADDR = 0x00; + NFC_CONFIG2 = NFC_ADDR; + mx31_wait_ready(); + }; + + page_count = CFG_NAND_CHIP_SIZE/CFG_NAND_PAGE_SIZE; + + if (page_address <= (page_count)) + { + page_count--;// transform 0x01000000 to 0x00ffffff + do + { + NFC_FLASH_ADDR = (unsigned short)(page_address & 0xff); + NFC_CONFIG2 = NFC_ADDR; + mx31_wait_ready(); + page_address = page_address >> 8; + page_count = page_count >> 8; + } + while(page_count); + } +} + +static void mx31_nand_data_output(void) +{ + NFC_CONFIG1 = NFC_ECC_EN; + NFC_BUF_ADDR = 0; /* read in first 0 buffer*/ + NFC_CONFIG2 = NFC_OUTPUT; + mx31_wait_ready(); +} + +static int mx31_nand_check_ecc(void) +{ + unsigned short ecc_status_registr; + ecc_status_registr = NFC_ECC_STATUS_RESULT; + + if(ecc_status_registr!=0) + return 1;/*error*/ + return 0; +} + +static int mx31_read_page(unsigned int page_address, unsigned char *buf) +{ + int i; + u32 *p1,*p2; + mx31_nand_init(); + NFC_BUF_ADDR = 0; /* read in first 0 buffer*/ + mx31_nand_command(NAND_CMD_READ0); + mx31_nand_page_address(page_address); + if(CFG_NAND_CHIP_SIZE >= 0x08000000) + mx31_nand_command(NAND_CMD_READSTART); + mx31_nand_data_output();/*fill the main buffer 0*/ + if(mx31_nand_check_ecc())while(1){break;};/*!!!!!*/ + + p1=NFC_BASE_ADDR; p2=buf; + for(i=0;i<(CFG_NAND_PAGE_SIZE/4);i++) + { + *p2= *p1; + p1++;p2++; + } + return 0; +} + +static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) +{ + int i; + if((from+size) > CFG_NAND_CHIP_SIZE) + return 1; + mx31_nand_init(); + + from = from/CFG_NAND_PAGE_SIZE;/*from must be set in full pages*/ + for(i=0;i<(size/CFG_NAND_PAGE_SIZE);i++) + { + mx31_read_page(from, buf); + from ++; + buf = buf + CFG_NAND_PAGE_SIZE; + } + return 0; +} +/* + * The main entry for NAND booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from NAND into SDRAM and starts it from there. + */ +void nand_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + + nand_load(CFG_NAND_U_BOOT_OFFS, CFG_NAND_U_BOOT_SIZE, (uchar *)CFG_NAND_U_BOOT_DST); + + uboot = (void *)CFG_NAND_U_BOOT_START; + uboot(); +}
Hi
2008/11/29 user scn1874@yandex.ru:
stgit couldn't apply the patch, but the standard 'patch' command could (it said 'applied with fuzz' on start.S).
Your patch seems to have some trailing whitespaces here and there.
The above fix should really go into the arm-tree immediately since it's a separate bug fix (IMHO).
- NAND controller
- Addresses for NFC registers
- Addresses for NFC RAM BUFFER Main area 0
- Addresses for NFC SPARE BUFFER Spare area 0
- Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command
Change "rest" to "reset" (for all #define's below as well).
- operation
- Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address
- operation
- Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input
- operation
- Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data
- Output operation
- Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID
- operation
- Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read
- Status operation
- Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status
- operation
- NFMS bit in RCSR register for pagesize of nandflash
- (C) Copyright 2008
- Maxim Artamonov, <scn1874 at yandex.ru>
- (C) Copyright 2006-2008
- Stefan Roese, DENX Software Engineering, sr@denx.de.
- MA 02111-1307 USA
while(1)
Insert space before '('.
Move { to the same line as if.
break;
NFC_CONFIG = 0x2;
If the above is not needed, remove it.
mx31_wait_ready();
mx31_wait_ready();
Add space before '('. Add space around '=='.
Move { to the if-line.
mx31_wait_ready();
Add space around /.
No need to have parenthesis around page_count in the if statement.
Use C style comments /* .. */ instead of C++.
do
Move { to the do-line.
mx31_wait_ready();
while(page_count);
Add space before parenthesis. The while statement should probably be moved to the previous line (after }) but I'm not sure what the coding style says aout this.
mx31_wait_ready();
Add empty line after variable declarations.
Add space before parenthesis.Add space around '!='.
return 1;/*error*/
int i;
u32 *p1,*p2;
Insert empty line after variable declarations. Add space after comma.
mx31_nand_init();
Add space before parenthesis. And split this line into several lines.
Add spaces around =. Consider placing p2=buf; on a separate line.
Space before parenthesis, space after ;
Move { to the for-line.
*p2= *p1;
Add space before =.
p1++;p2++;
Split in two lines.
int i;
Add space before (.
return 1;
mx31_nand_init();
Add space before (. Add sape after ;. Add space around < and /.
from ++;
Remove space before ++;
Insert empty line.
Shouldn't the code check if the current block is marked as bad before copying all the pages from that block into SDRAM? The first block is typically guaranteed to be good (if I understand correctly) but any subsequent block may be marked bad already from the factory and should be skipped. The entire U-boot won't fit in the first block, atleast for small page NAND devices.
- The main entry for NAND booting. It's necessary that SDRAM is already
- configured and available since this code loads the main U-Boot image
- from NAND into SDRAM and starts it from there.
Split this line into two in order to keep it less than 80 chars long.
uboot();
1.5.2.4
Regards, Magnus
Magnus Lilja
user
