[U-Boot] [PATCH 1/3] dm: spi: Add support for all targets which requires MANUAL_RELOC
It is follow up patch based on "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) to update function pointers for DM.
drivers/spi/spi-uclass.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d666272e39ce..27409fb088ea 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -118,6 +118,26 @@ static int spi_post_probe(struct udevice *bus) spi->max_hz = fdtdec_get_int(gd->fdt_blob, bus->of_offset, "spi-max-frequency", 0);
+#if defined(CONFIG_NEEDS_MANUAL_RELOC) + struct dm_spi_ops *ops = spi_get_ops(bus); + + + if (ops->claim_bus) + ops->claim_bus += gd->reloc_off; + if (ops->release_bus) + ops->release_bus += gd->reloc_off; + if (ops->set_wordlen) + ops->set_wordlen += gd->reloc_off; + if (ops->xfer) + ops->xfer += gd->reloc_off; + if (ops->set_speed) + ops->set_speed += gd->reloc_off; + if (ops->set_mode) + ops->set_mode += gd->reloc_off; + if (ops->cs_info) + ops->cs_info += gd->reloc_off; +#endif + return 0; }
Patches: "dm: core: Add a post_bind method for parents" (sha1: 0118ce79577f9b0881f99a6e4f8a79cd5014cb87) "dm: core: Add a uclass pre_probe() method for devices" (sha1: 02c07b3741f1b825934b1a6eb8f23530532dc426) "dm: core: Allow the uclass to set up a device's child after binding" (sha1: 081f2fcbd9a95ba10677065359791f8fea3f8c58) "dm: core: Allow uclass to set up a device's child before it is probed" (sha1: 83c7e434c9dd3ca81f8b763e23c1881b973bcf2f)
Adds new entries to struct driver and struct uclass_driver without extending code for manual relocation. This patch fixes it for all architectures which requires MANUAL_RELOC.
drivers/core/root.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/core/root.c b/drivers/core/root.c index bdb394a9ae21..e7b1f249682e 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -59,6 +59,8 @@ void fix_drivers(void) entry->unbind += gd->reloc_off; if (entry->ofdata_to_platdata) entry->ofdata_to_platdata += gd->reloc_off; + if (entry->child_post_bind) + entry->child_post_bind += gd->reloc_off; if (entry->child_pre_probe) entry->child_pre_probe += gd->reloc_off; if (entry->child_post_remove) @@ -81,10 +83,16 @@ void fix_uclass(void) entry->post_bind += gd->reloc_off; if (entry->pre_unbind) entry->pre_unbind += gd->reloc_off; + if (entry->pre_probe) + entry->pre_probe += gd->reloc_off; if (entry->post_probe) entry->post_probe += gd->reloc_off; if (entry->pre_remove) entry->pre_remove += gd->reloc_off; + if (entry->child_post_bind) + entry->child_post_bind += gd->reloc_off; + if (entry->child_pre_probe) + entry->child_pre_probe += gd->reloc_off; if (entry->init) entry->init += gd->reloc_off; if (entry->destroy)
Looking forward to getting rid of the manual relocation!
:-) What about that third one? Is any change in API needed or that style is fine?
Thanks, Michal
Using post_bind is not ideal but it is one on current option what can be used. Variable reloc_done has to be used do not call relocation after every bind. Maybe new core functions should be introduced for this case.
drivers/mtd/spi/sf-uclass.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 350e21aa7d65..07204094cfce 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -11,6 +11,8 @@ #include <dm/device-internal.h> #include "sf_internal.h"
+DECLARE_GLOBAL_DATA_PTR; + int spi_flash_read_dm(struct udevice *dev, u32 offset, size_t len, void *buf) { return sf_get_ops(dev)->read(dev, offset, len, buf); @@ -72,8 +74,28 @@ int spi_flash_remove(struct udevice *dev) return device_remove(dev); }
+static int reloc_done; + +static int spi_flash_post_bind(struct udevice *dev) +{ + struct dm_spi_flash_ops *ops = sf_get_ops(dev); + + if (!reloc_done) { + if (ops->read) + ops->read += gd->reloc_off; + if (ops->write) + ops->write += gd->reloc_off; + if (ops->erase) + ops->erase += gd->reloc_off; + + reloc_done++; + } + return 0; +} + UCLASS_DRIVER(spi_flash) = { .id = UCLASS_SPI_FLASH, .name = "spi_flash", + .post_bind = spi_flash_post_bind, .per_device_auto_alloc_size = sizeof(struct spi_flash), };
- struct dm_spi_flash_ops *ops = sf_get_ops(dev);
- if (!reloc_done) {
if (ops->read)
if (ops->write)
if (ops->erase)
reloc_done++;
This is missing some #if defined(CONFIG_NEEDS_MANUAL_RELOC) around. Will fix it in v2 but would like to know if this is the best way how to call this because I am not convinced about it. That solution with static variable is not the best one.
Thanks, Michal
Michal Simek
Michal Simek
