[U-Boot] [PATCH] imx: ventana: Avoid undefined behaviour
The leds array within struct ventana has space for 3 elements, but the setup_board_gpio() function tries to set up 4 GPIOs for LEDs. Recent versions of GCC complain about that:
board/gateworks/gw_ventana/gw_ventana.c: In function 'setup_board_gpio': board/gateworks/gw_ventana/gw_ventana.c:987:27: warning: iteration 3u invokes undefined behavior [-Waggressive-loop-optimizations] if (gpio_cfg[board].leds[i]) ^ board/gateworks/gw_ventana/gw_ventana.c:986:2: note: containing loop for (i = 0; i < 4; i++) { ^
Fix this by making the upper bound of the loop match the array size.
Signed-off-by: Thierry Reding treding@nvidia.com --- board/gateworks/gw_ventana/gw_ventana.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 9d2651f0cbf1..01212367c396 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -983,7 +983,7 @@ static void setup_board_gpio(int board) gpio_direction_output(gpio_cfg[board].pcie_rst, 0);
/* turn off (active-high) user LED's */ - for (i = 0; i < 4; i++) { + for (i = 0; i < ARRAY_SIZE(gpio_cfg[board].leds); i++) { if (gpio_cfg[board].leds[i]) gpio_direction_output(gpio_cfg[board].leds[i], 1); }
On Fri, Aug 22, 2014 at 12:46 AM, Thierry Reding thierry.reding@gmail.com wrote:
-- 2.0.4
Thanks for catching and fixing this Thierry!
Acked-by: Tim Harvey tharvey@gateworks.com
Tim
Best regards, Stefano Babic
Stefano Babic
Thierry Reding
Tim Harvey
