[PATCH v3 0/2] add support for Compulab iot-gate-imx8
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Add initial support for Compulab iot-gate-imx8 board (imx8mm-cl-iot-gate). The initial support includes: - MMC - eMMC - I2C - FEC - Serial console
Ying-Chun Liu (PaulLiu) (2): arm: dts: add imx8mm-cl-iot-gate dts file arm: imx8m: add support for Compulab iot-gate-imx8 (imx8mm-cl-iot-gate)
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 131 ++ arch/arm/dts/imx8mm-cl-iot-gate.dts | 550 +++++ arch/arm/mach-imx/imx8m/Kconfig | 8 + board/compulab/imx8mm-cl-iot-gate/Kconfig | 12 + board/compulab/imx8mm-cl-iot-gate/MAINTAINERS | 6 + board/compulab/imx8mm-cl-iot-gate/Makefile | 13 + .../compulab/imx8mm-cl-iot-gate/ddr/Makefile | 8 + board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c | 211 ++ board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h | 26 + .../ddr/lpddr4_timing_01061010.1_2.c | 1848 +++++++++++++++++ .../ddr/lpddr4_timing_01061010.c | 1847 ++++++++++++++++ .../ddr/lpddr4_timing_ff000110.c | 1847 ++++++++++++++++ .../ddr/lpddr4_timing_ff020008.c | 1847 ++++++++++++++++ .../imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 69 + board/compulab/imx8mm-cl-iot-gate/spl.c | 187 ++ configs/imx8mm-cl-iot-gate_defconfig | 130 ++ include/configs/imx8mm-cl-iot-gate.h | 190 ++ 18 files changed, 8932 insertions(+) create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate.dts create mode 100644 board/compulab/imx8mm-cl-iot-gate/Kconfig create mode 100644 board/compulab/imx8mm-cl-iot-gate/MAINTAINERS create mode 100644 board/compulab/imx8mm-cl-iot-gate/Makefile create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/Makefile create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff000110.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff020008.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/spl.c create mode 100644 configs/imx8mm-cl-iot-gate_defconfig create mode 100644 include/configs/imx8mm-cl-iot-gate.h
Add board dts for imx8mm-cl-iot-gate
Signed-off-by: Kirill Kapranov kirill.kapranov@compulab.co.il Signed-off-by: Uri Mashiach uri.mashiach@compulab.co.il Signed-off-by: Valentin Raevsky valentin@compulab.co.il Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 131 +++++ arch/arm/dts/imx8mm-cl-iot-gate.dts | 550 ++++++++++++++++++++ 3 files changed, 683 insertions(+) create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e2e8a5fb7a..d00ecb88e0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1003,6 +1003,8 @@ dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb
dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
+dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE) += imx8mm-cl-iot-gate.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi new file mode 100644 index 0000000000..a36147eb11 --- /dev/null +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pinctrl_reg_usdhc2_vmmc { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { + u-boot,dm-spl; +}; + +&pinctrl_i2c2 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; +}; + +&wdog1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-cl-iot-gate.dts b/arch/arm/dts/imx8mm-cl-iot-gate.dts new file mode 100644 index 0000000000..82e9c0f40b --- /dev/null +++ b/arch/arm/dts/imx8mm-cl-iot-gate.dts @@ -0,0 +1,550 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +/dts-v1/; + +#include <dt-bindings/usb/pd.h> +#include "imx8mm.dtsi" + +/ { + model = "CompuLab IOT-GATE-iMX8"; + compatible = "sb-iotgimx8", "cpl,ucm-imx8m-mini", "fsl,imx8mm-evk", "fsl,imx8mm"; + + chosen { + bootargs = "console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200"; + stdout-path = &uart3; + }; + + reg_vusb_5v: regulator-usdhc2 { + compatible = "regulator-fixed"; + regulator-name = "VUSB_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 28 GPIO_ACTIVE_HIGH>; + regulator-boot-on; + enable-active-high; + }; + + reg_usdhc2_vqmmc: regulator-usdhc2_1v8 { + compatible = "regulator-fixed"; + regulator-name = "usdhc2_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + reg_usdhc2_vmmc: regulator-usdhc2-vmmc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100>; + off-on-delay-us = <12000>; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + at803x,led-act-blind-workaround; + at803x,eee-okay; + at803x,vddio-1p8v; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pmic@4b { + compatible = "rohm,bd71837"; + reg = <0x4b>; + pinctrl-0 = <&pinctrl_pmic>; + gpio_intr = <&gpio1 3 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio1>; + interrupts = <3 GPIO_ACTIVE_LOW>; + + gpo { + rohm,drv = <0x0C>; /* 0b0000_1100 all gpos with cmos output mode */ + }; + + regulators { + bd71837,pmic-buck2-uses-i2c-dvs; + bd71837,pmic-buck2-dvs-voltage = <1000000>, + <900000>, + <0>; /* VDD_ARM: Run-Idle */ + buck1_reg: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck2_reg: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck3_reg: BUCK3 { + regulator-name = "BUCK3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + }; + + buck4_reg: BUCK4 { + regulator-name = "BUCK4"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: BUCK5 { + regulator-name = "BUCK5"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck7_reg: BUCK7 { + regulator-name = "BUCK7"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck8_reg: BUCK8 { + regulator-name = "BUCK8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: LDO2 { + regulator-name = "LDO2"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: LDO3 { + regulator-name = "LDO3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5_reg: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + regulator-name = "LDO6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo7_reg: LDO7 { + regulator-name = "LDO7"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + }; + }; + + ptn5110: tcpc@50 { + compatible = "nxp,ptn5110"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_typec1>; + reg = <0x50>; + interrupt-parent = <&gpio2>; + interrupts = <11 8>; + status = "okay"; + + port { + typec1_dr_sw: endpoint { + remote-endpoint = <&usb1_drd_sw>; + }; + }; + + typec1_con: connector { + compatible = "usb-c-connector"; + label = "USB-C"; + power-role = "dual"; + data-role = "dual"; + try-power-role = "sink"; + source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; + sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM) + PDO_VAR(5000, 20000, 3000)>; + op-sink-microwatt = <15000000>; + self-powered; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "disabled"; +}; + +&i2c4 {/* Expansion connector I2C */ + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + pca9555: gpio@22 { + compatible = "nxp,pca9555"; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart3 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "host"; + hnp-disable; + srp-disable; + adp-disable; + usb-role-switch; + vbus-supply = <®_vusb_5v>; + status = "okay"; + + port { + usb1_drd_sw: endpoint { + remote-endpoint = <&typec1_dr_sw>; + }; + }; +}; + +&usbotg2 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + bus-width = <4>; + fsl,wp-controller; + vmmc-supply = <®_usdhc2_vmmc>; + no-1-8-v; + mmc-ddr-1_8v; + non-removable; + vqmmc-supply = <®_usdhc2_vqmmc>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_hog: hoggrp { + fsl,pins = < + /* USB VBUS enable GPIO */ + MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x00 + >; + }; + + pinctrl_hog_1: hoggrp-1 { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x19 + MX8MM_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x140 + MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x140 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MM_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 + >; + }; + + pinctrl_flexspi0: flexspi0grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x1c4 + MX8MM_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x84 + MX8MM_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x84 + MX8MM_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x84 + MX8MM_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x84 + MX8MM_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x84 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_pmic: pmicirq { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x41 + >; + }; + + pinctrl_typec1: typec1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_STROBE_GPIO2_IO11 0x159 + >; + }; + + pinctrl_uart3: uart1grp { + fsl,pins = < + MX8MM_IOMUXC_UART3_RXD_UART3_DCE_RX 0x49 + MX8MM_IOMUXC_UART3_TXD_UART3_DCE_TX 0x49 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX8MM_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x49 + MX8MM_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x49 + MX8MM_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x49 + MX8MM_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x49 + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc { + fsl,pins = < + MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; +
What's changed since the last version. You should put a change log at this point.
targets += $(dtb-y)
- Copyright 2019 NXP
wdt-reboot {
wdt = <&wdog1>;
u-boot,dm-spl;
+&{/soc@0} {
u-boot,dm-spl;
+&clk {
u-boot,dm-spl;
+&osc_24m {
u-boot,dm-spl;
+&aips1 {
u-boot,dm-spl;
+&aips2 {
u-boot,dm-spl;
+&aips3 {
u-boot,dm-spl;
+&iomuxc {
u-boot,dm-spl;
u-boot,dm-spl;
+&pinctrl_uart3 {
u-boot,dm-spl;
u-boot,dm-spl;
+&pinctrl_usdhc2 {
u-boot,dm-spl;
+&pinctrl_usdhc3 {
u-boot,dm-spl;
+&gpio1 {
u-boot,dm-spl;
+&gpio2 {
u-boot,dm-spl;
+&gpio3 {
u-boot,dm-spl;
+&gpio4 {
u-boot,dm-spl;
+&gpio5 {
u-boot,dm-spl;
+&uart3 {
u-boot,dm-spl;
+&usdhc1 {
u-boot,dm-spl;
+&usdhc2 {
u-boot,dm-spl;
+&usdhc3 {
u-boot,dm-spl;
+&i2c2 {
u-boot,dm-spl;
u-boot,dm-spl;
u-boot,dm-spl;
+&pinctrl_i2c2 {
u-boot,dm-spl;
+&pinctrl_pmic {
u-boot,dm-spl;
+&fec1 {
+&wdog1 {
u-boot,dm-spl;
+/dts-v1/;
chosen {
regulator-boot-on;
enable-active-high;
enable-active-high;
+&A53_0 {
+&fec1 {
fsl,magic-packet;
status = "okay";
mdio {
#size-cells = <0>;
reg = <0>;
at803x,eee-okay;
at803x,vddio-1p8v;
+&i2c1 {
status = "okay";
+&i2c2 {
status = "okay";
pmic@4b {
reg = <0x4b>;
gpo {
regulators {
<900000>,
buck1_reg: BUCK1 {
regulator-boot-on;
buck2_reg: BUCK2 {
regulator-boot-on;
buck3_reg: BUCK3 {
buck4_reg: BUCK4 {
regulator-boot-on;
buck5_reg: BUCK5 {
regulator-boot-on;
buck6_reg: BUCK6 {
regulator-boot-on;
buck7_reg: BUCK7 {
regulator-boot-on;
buck8_reg: BUCK8 {
regulator-boot-on;
ldo1_reg: LDO1 {
regulator-boot-on;
ldo2_reg: LDO2 {
regulator-boot-on;
ldo3_reg: LDO3 {
regulator-boot-on;
ldo4_reg: LDO4 {
regulator-boot-on;
ldo5_reg: LDO5 {
regulator-boot-on;
ldo6_reg: LDO6 {
regulator-boot-on;
ldo7_reg: LDO7 {
ptn5110: tcpc@50 {
reg = <0x50>;
status = "okay";
port {
label = "USB-C";
data-role = "dual";
self-powered;
+&i2c3 {
status = "okay";
pca9555: gpio@22 {
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
+&snvs_pwrkey {
status = "okay";
status = "okay";
+&usbotg1 {
dr_mode = "host";
hnp-disable;
srp-disable;
adp-disable;
usb-role-switch;
status = "okay";
port {
+&usbotg2 {
dr_mode = "host";
status = "okay";
+&usdhc2 {
bus-width = <4>;
fsl,wp-controller;
no-1-8-v;
mmc-ddr-1_8v;
non-removable;
status = "okay";
+&usdhc3 {
bus-width = <8>;
non-removable;
status = "okay";
+&wdog1 {
status = "okay";
+&iomuxc {
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
-- 2.29.2
Signed-off-by: Kirill Kapranov kirill.kapranov@compulab.co.il Signed-off-by: Uri Mashiach uri.mashiach@compulab.co.il Signed-off-by: Valentin Raevsky valentin@compulab.co.il Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Peter Robinson pbrobinson@gmail.com --- arch/arm/mach-imx/imx8m/Kconfig | 8 + board/compulab/imx8mm-cl-iot-gate/Kconfig | 12 + board/compulab/imx8mm-cl-iot-gate/MAINTAINERS | 6 + board/compulab/imx8mm-cl-iot-gate/Makefile | 13 + .../compulab/imx8mm-cl-iot-gate/ddr/Makefile | 8 + board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c | 211 ++ board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h | 26 + .../ddr/lpddr4_timing_01061010.1_2.c | 1848 +++++++++++++++++ .../ddr/lpddr4_timing_01061010.c | 1847 ++++++++++++++++ .../ddr/lpddr4_timing_ff000110.c | 1847 ++++++++++++++++ .../ddr/lpddr4_timing_ff020008.c | 1847 ++++++++++++++++ .../imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 69 + board/compulab/imx8mm-cl-iot-gate/spl.c | 187 ++ configs/imx8mm-cl-iot-gate_defconfig | 130 ++ include/configs/imx8mm-cl-iot-gate.h | 190 ++ 15 files changed, 8249 insertions(+) create mode 100644 board/compulab/imx8mm-cl-iot-gate/Kconfig create mode 100644 board/compulab/imx8mm-cl-iot-gate/MAINTAINERS create mode 100644 board/compulab/imx8mm-cl-iot-gate/Makefile create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/Makefile create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff000110.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff020008.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c create mode 100644 board/compulab/imx8mm-cl-iot-gate/spl.c create mode 100644 configs/imx8mm-cl-iot-gate_defconfig create mode 100644 include/configs/imx8mm-cl-iot-gate.h
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 8615dc3bec..287a6f4616 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -77,6 +77,13 @@ config TARGET_PHYCORE_IMX8MM select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + +config TARGET_IMX8MM_CL_IOT_GATE + bool "CompuLab iot-gate-imx8" + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + endchoice
source "board/freescale/imx8mq_evk/Kconfig" @@ -88,5 +95,6 @@ source "board/technexion/pico-imx8mq/Kconfig" source "board/toradex/verdin-imx8mm/Kconfig" source "board/beacon/imx8mm/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" +source "board/compulab/imx8mm-cl-iot-gate/Kconfig"
endif diff --git a/board/compulab/imx8mm-cl-iot-gate/Kconfig b/board/compulab/imx8mm-cl-iot-gate/Kconfig new file mode 100644 index 0000000000..7f5c794bf5 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/Kconfig @@ -0,0 +1,12 @@ +if TARGET_IMX8MM_CL_IOT_GATE + +config SYS_BOARD + default "imx8mm-cl-iot-gate" + +config SYS_VENDOR + default "compulab" + +config SYS_CONFIG_NAME + default "imx8mm-cl-iot-gate" + +endif diff --git a/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS b/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS new file mode 100644 index 0000000000..9c6b17095c --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS @@ -0,0 +1,6 @@ +Compulab IOT-GATE-iMX8 BOARD +M: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org +S: Maintained +F: board/compulab/imx8mm-cl-iot-gate/ +F: include/configs/imx8mm-cl-iot-gate.h +F: configs/imx8mm-cl-iot-gate_defconfig diff --git a/board/compulab/imx8mm-cl-iot-gate/Makefile b/board/compulab/imx8mm-cl-iot-gate/Makefile new file mode 100644 index 0000000000..3a2bfc4dc4 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/Makefile @@ -0,0 +1,13 @@ +# +# Copyright 2018 NXP +# Copyright 2020 Linaro +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8mm-cl-iot-gate.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += ddr/ +endif diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/Makefile b/board/compulab/imx8mm-cl-iot-gate/ddr/Makefile new file mode 100644 index 0000000000..5914796628 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/Makefile @@ -0,0 +1,8 @@ +obj-y += ddr.o +obj-y += lpddr4_timing_ff020008.o +obj-y += lpddr4_timing_ff000110.o +ifdef CONFIG_TARGET_MCM_IMX8M_MINI +obj-y += lpddr4_timing_01061010.o +else +obj-y += lpddr4_timing_01061010.1_2.o +endif diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c b/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c new file mode 100644 index 0000000000..42dd0dbf18 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.c @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017 NXP + * Copyright 2020 Linaro + * + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <errno.h> +#include <command.h> +#include <asm/io.h> +#include <asm/arch/lpddr4_define.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm-generic/gpio.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/gpio.h> +#include "ddr.h" + +static unsigned int lpddr4_mr_read(unsigned int mr_rank, unsigned int mr_addr) +{ + unsigned int tmp; + + reg32_write(DRC_PERF_MON_MRR0_DAT(0), 0x1); + do { + tmp = reg32_read(DDRC_MRSTAT(0)); + } while (tmp & 0x1); + + reg32_write(DDRC_MRCTRL0(0), (mr_rank << 4) | 0x1); + reg32_write(DDRC_MRCTRL1(0), (mr_addr << 8)); + reg32setbit(DDRC_MRCTRL0(0), 31); + do { + tmp = reg32_read(DRC_PERF_MON_MRR0_DAT(0)); + } while ((tmp & 0x8) == 0); + tmp = reg32_read(DRC_PERF_MON_MRR1_DAT(0)); + reg32_write(DRC_PERF_MON_MRR0_DAT(0), 0x4); + while (tmp) { //try to find a significant byte in the word + if (tmp & 0xff) { + tmp &= 0xff; + break; + } + tmp >>= 8; + } + return tmp; +} + +struct lpddr4_desc { + char name[16]; + unsigned int id; + unsigned int size; + unsigned int count; + /* an optional field + * use it if default is not the + * 1-st array entry + */ + unsigned int _default; + /* An optional field to distiguish DRAM chips that + * have different geometry, though return the same MRR. + * Default value 0xff + */ + u8 subind; + struct dram_timing_info *timing; + char *desc[4]; +}; + +#define DEFAULT (('D' << 24) + ('E' << 16) + ('F' << 8) + 'A') +static const struct lpddr4_desc lpddr4_array[] = { + { .name = "Nanya", .id = 0x05000010, .subind = 0xff, + .size = 2048, .count = 1, .timing = &ucm_dram_timing_01061010}, + { .name = "Samsung", .id = 0x01061010, .subind = 0xff, + .size = 2048, .count = 1, .timing = &ucm_dram_timing_01061010}, + { .name = "Kingston", .id = 0xff000010, .subind = 0x04, + .size = 4096, .count = 1, .timing = &ucm_dram_timing_ff000110}, + { .name = "Kingston", .id = 0xff000010, .subind = 0x02, + .size = 2048, .count = 1, .timing = &ucm_dram_timing_01061010}, + { .name = "Micron", .id = 0xff020008, .subind = 0xff, + .size = 2048, .count = 1, .timing = &ucm_dram_timing_ff020008}, + { .name = "Micron", .id = 0xff000110, .subind = 0xff, + .size = 4096, .count = 1, .timing = &ucm_dram_timing_ff000110}, +}; + +static unsigned int lpddr4_get_mr(void) +{ + int i = 0, attempts = 5; + unsigned int ddr_info = 0; + unsigned int regs[] = { 5, 6, 7, 8 }; + + do { + for (i = 0 ; i < ARRAY_SIZE(regs) ; i++) { + unsigned int data = 0; + + data = lpddr4_mr_read(0xF, regs[i]); + ddr_info <<= 8; + ddr_info += (data & 0xFF); + } + if (ddr_info != 0xFFFFFFFF && ddr_info != 0) + break; // The attempt was successful + } while (--attempts); + return ddr_info; +} + +static void spl_tcm_init(struct lpddr4_tcm_desc *lpddr4_tcm_desc) +{ + if (lpddr4_tcm_desc->sign == DEFAULT) + return; + + lpddr4_tcm_desc->sign = DEFAULT; + lpddr4_tcm_desc->index = 0; +} + +static void spl_tcm_fini(struct lpddr4_tcm_desc *lpddr4_tcm_desc) +{ + if (lpddr4_tcm_desc->sign != DEFAULT) + return; + + lpddr4_tcm_desc->sign = ~DEFAULT; + lpddr4_tcm_desc->index = 0; +} + +#define SPL_TCM_DATA 0x7e0000 +#define SPL_TCM_INIT spl_tcm_init(lpddr4_tcm_desc) +#define SPL_TCM_FINI spl_tcm_fini(lpddr4_tcm_desc) + +void spl_dram_init_compulab(void) +{ + unsigned int ddr_info = 0xdeadbeef; + unsigned int ddr_info_mrr = 0xdeadbeef; + unsigned int ddr_found = 0; + int i = 0; + + struct lpddr4_tcm_desc *lpddr4_tcm_desc = + (struct lpddr4_tcm_desc *)SPL_TCM_DATA; + + if (lpddr4_tcm_desc->sign != DEFAULT) { + /* if not in tcm scan mode */ + for (i = 0; i < ARRAY_SIZE(lpddr4_array); i++) { + if (lpddr4_array[i].id == ddr_info && + lpddr4_array[i].subind == 0xff) { + ddr_found = 1; + break; + } + } + } + + /* Walk trought all available ddr ids and apply + * one by one. Save the index at the tcm memory that + * persists after the reset. + */ + if (ddr_found == 0) { + SPL_TCM_INIT; + + if (lpddr4_tcm_desc->index < ARRAY_SIZE(lpddr4_array)) { + printf("DDRINFO: Cfg attempt: [ %d/%lu ]\n", + lpddr4_tcm_desc->index + 1, + ARRAY_SIZE(lpddr4_array)); + i = lpddr4_tcm_desc->index; + lpddr4_tcm_desc->index += 1; + } else { + /* Ran out all available ddr setings */ + printf("DDRINFO: Ran out all [ %lu ] cfg attempts. A non supported configuration.\n", + ARRAY_SIZE(lpddr4_array)); + while (1) + ; + } + ddr_info = lpddr4_array[i].id; + } else { + printf("DDRINFO(%s): %s %dG\n", (ddr_found ? "D" : "?"), + lpddr4_array[i].name, + lpddr4_array[i].size); + } + + if (ddr_init(lpddr4_array[i].timing)) { + SPL_TCM_INIT; + do_reset(NULL, 0, 0, NULL); + } + + ddr_info_mrr = lpddr4_get_mr(); + if (ddr_info_mrr == 0xFFFFFFFF) { + printf("DDRINFO(M): mr5-8 [ 0x%x ] is invalid; reset\n", + ddr_info_mrr); + SPL_TCM_INIT; + do_reset(NULL, 0, 0, NULL); + } + + printf("DDRINFO(M): mr5-8 [ 0x%x ]\n", ddr_info_mrr); + printf("DDRINFO(%s): mr5-8 [ 0x%x ]\n", (ddr_found ? "E" : "T"), + ddr_info); + + if (ddr_info_mrr != ddr_info) { + SPL_TCM_INIT; + do_reset(NULL, 0, 0, NULL); + } + + SPL_TCM_FINI; + + /* Pass the dram size to th U-Boot through the tcm memory */ + { /* To figure out what to store into the TCM buffer */ + /* For debug purpouse only. To override the real memsize */ + unsigned int ddr_tcm_size = 0; + + if (ddr_tcm_size == 0 || ddr_tcm_size == -1) + ddr_tcm_size = lpddr4_array[i].size; + + lpddr4_tcm_desc->size = ddr_tcm_size; + } +} diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h b/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h new file mode 100644 index 0000000000..59c1891159 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/ddr.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2017 NXP + * Copyright 2020 Linaro + * + */ + +#ifndef __COMPULAB_DDR_H__ +#define __COMPULAB_DDR_H__ + +extern struct dram_timing_info ucm_dram_timing_ff020008; +extern struct dram_timing_info ucm_dram_timing_ff000110; +extern struct dram_timing_info ucm_dram_timing_01061010; + +void spl_dram_init_compulab(void); + +#define TCM_DATA_CFG 0x7e0000 + +struct lpddr4_tcm_desc { + unsigned int size; + unsigned int sign; + unsigned int index; + unsigned int count; +}; + +#endif diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c new file mode 100644 index 0000000000..870a94aecc --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.1_2.c @@ -0,0 +1,1848 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x2ee00}, + {0x3d400064, 0x4900a8}, + {0x3d4000d0, 0xc0030495}, + {0x3d4000d4, 0x770000}, + {0x3d4000dc, 0xc40024}, + {0x3d4000e0, 0x310000}, + {0x3d4000e8, 0x66004d}, + {0x3d4000ec, 0x16004d}, + {0x3d400100, 0x1618141a}, + {0x3d400104, 0x504a6}, + {0x3d40010c, 0x909000}, + {0x3d400110, 0xb04060b}, + {0x3d400114, 0x2030909}, + {0x3d400118, 0x1010006}, + {0x3d40011c, 0x301}, + {0x3d400130, 0x20500}, + {0x3d400134, 0xb100002}, + {0x3d400138, 0xad}, + {0x3d400144, 0x78003c}, + {0x3d400180, 0x2580012}, + {0x3d400184, 0x1e0493e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x4938208}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x1308}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x60c1514}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x7070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc001c}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa040305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x1d}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30007}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa010102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x8}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0xa}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x2}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x258}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0}, + { 0x1200b2, 0x0}, + { 0x2200b2, 0x0}, + { 0x200cb, 0x0}, + { 0x10043, 0x0}, + { 0x110043, 0x0}, + { 0x210043, 0x0}, + { 0x10143, 0x0}, + { 0x110143, 0x0}, + { 0x210143, 0x0}, + { 0x11043, 0x0}, + { 0x111043, 0x0}, + { 0x211043, 0x0}, + { 0x11143, 0x0}, + { 0x111143, 0x0}, + { 0x211143, 0x0}, + { 0x12043, 0x0}, + { 0x112043, 0x0}, + { 0x212043, 0x0}, + { 0x12143, 0x0}, + { 0x112143, 0x0}, + { 0x212143, 0x0}, + { 0x13043, 0x0}, + { 0x113043, 0x0}, + { 0x213043, 0x0}, + { 0x13143, 0x0}, + { 0x113143, 0x0}, + { 0x213143, 0x0}, + { 0x80, 0x0}, + { 0x100080, 0x0}, + { 0x200080, 0x0}, + { 0x1080, 0x0}, + { 0x101080, 0x0}, + { 0x201080, 0x0}, + { 0x2080, 0x0}, + { 0x102080, 0x0}, + { 0x202080, 0x0}, + { 0x3080, 0x0}, + { 0x103080, 0x0}, + { 0x203080, 0x0}, + { 0x4080, 0x0}, + { 0x104080, 0x0}, + { 0x204080, 0x0}, + { 0x5080, 0x0}, + { 0x105080, 0x0}, + { 0x205080, 0x0}, + { 0x6080, 0x0}, + { 0x106080, 0x0}, + { 0x206080, 0x0}, + { 0x7080, 0x0}, + { 0x107080, 0x0}, + { 0x207080, 0x0}, + { 0x8080, 0x0}, + { 0x108080, 0x0}, + { 0x208080, 0x0}, + { 0x9080, 0x0}, + { 0x109080, 0x0}, + { 0x209080, 0x0}, + { 0x10080, 0x0}, + { 0x110080, 0x0}, + { 0x210080, 0x0}, + { 0x10180, 0x0}, + { 0x110180, 0x0}, + { 0x210180, 0x0}, + { 0x11080, 0x0}, + { 0x111080, 0x0}, + { 0x211080, 0x0}, + { 0x11180, 0x0}, + { 0x111180, 0x0}, + { 0x211180, 0x0}, + { 0x12080, 0x0}, + { 0x112080, 0x0}, + { 0x212080, 0x0}, + { 0x12180, 0x0}, + { 0x112180, 0x0}, + { 0x212180, 0x0}, + { 0x13080, 0x0}, + { 0x113080, 0x0}, + { 0x213080, 0x0}, + { 0x13180, 0x0}, + { 0x113180, 0x0}, + { 0x213180, 0x0}, + { 0x10081, 0x0}, + { 0x110081, 0x0}, + { 0x210081, 0x0}, + { 0x10181, 0x0}, + { 0x110181, 0x0}, + { 0x210181, 0x0}, + { 0x11081, 0x0}, + { 0x111081, 0x0}, + { 0x211081, 0x0}, + { 0x11181, 0x0}, + { 0x111181, 0x0}, + { 0x211181, 0x0}, + { 0x12081, 0x0}, + { 0x112081, 0x0}, + { 0x212081, 0x0}, + { 0x12181, 0x0}, + { 0x112181, 0x0}, + { 0x212181, 0x0}, + { 0x13081, 0x0}, + { 0x113081, 0x0}, + { 0x213081, 0x0}, + { 0x13181, 0x0}, + { 0x113181, 0x0}, + { 0x213181, 0x0}, + { 0x100d0, 0x0}, + { 0x1100d0, 0x0}, + { 0x2100d0, 0x0}, + { 0x101d0, 0x0}, + { 0x1101d0, 0x0}, + { 0x2101d0, 0x0}, + { 0x110d0, 0x0}, + { 0x1110d0, 0x0}, + { 0x2110d0, 0x0}, + { 0x111d0, 0x0}, + { 0x1111d0, 0x0}, + { 0x2111d0, 0x0}, + { 0x120d0, 0x0}, + { 0x1120d0, 0x0}, + { 0x2120d0, 0x0}, + { 0x121d0, 0x0}, + { 0x1121d0, 0x0}, + { 0x2121d0, 0x0}, + { 0x130d0, 0x0}, + { 0x1130d0, 0x0}, + { 0x2130d0, 0x0}, + { 0x131d0, 0x0}, + { 0x1131d0, 0x0}, + { 0x2131d0, 0x0}, + { 0x100d1, 0x0}, + { 0x1100d1, 0x0}, + { 0x2100d1, 0x0}, + { 0x101d1, 0x0}, + { 0x1101d1, 0x0}, + { 0x2101d1, 0x0}, + { 0x110d1, 0x0}, + { 0x1110d1, 0x0}, + { 0x2110d1, 0x0}, + { 0x111d1, 0x0}, + { 0x1111d1, 0x0}, + { 0x2111d1, 0x0}, + { 0x120d1, 0x0}, + { 0x1120d1, 0x0}, + { 0x2120d1, 0x0}, + { 0x121d1, 0x0}, + { 0x1121d1, 0x0}, + { 0x2121d1, 0x0}, + { 0x130d1, 0x0}, + { 0x1130d1, 0x0}, + { 0x2130d1, 0x0}, + { 0x131d1, 0x0}, + { 0x1131d1, 0x0}, + { 0x2131d1, 0x0}, + { 0x10068, 0x0}, + { 0x10168, 0x0}, + { 0x10268, 0x0}, + { 0x10368, 0x0}, + { 0x10468, 0x0}, + { 0x10568, 0x0}, + { 0x10668, 0x0}, + { 0x10768, 0x0}, + { 0x10868, 0x0}, + { 0x11068, 0x0}, + { 0x11168, 0x0}, + { 0x11268, 0x0}, + { 0x11368, 0x0}, + { 0x11468, 0x0}, + { 0x11568, 0x0}, + { 0x11668, 0x0}, + { 0x11768, 0x0}, + { 0x11868, 0x0}, + { 0x12068, 0x0}, + { 0x12168, 0x0}, + { 0x12268, 0x0}, + { 0x12368, 0x0}, + { 0x12468, 0x0}, + { 0x12568, 0x0}, + { 0x12668, 0x0}, + { 0x12768, 0x0}, + { 0x12868, 0x0}, + { 0x13068, 0x0}, + { 0x13168, 0x0}, + { 0x13268, 0x0}, + { 0x13368, 0x0}, + { 0x13468, 0x0}, + { 0x13568, 0x0}, + { 0x13668, 0x0}, + { 0x13768, 0x0}, + { 0x13868, 0x0}, + { 0x10069, 0x0}, + { 0x10169, 0x0}, + { 0x10269, 0x0}, + { 0x10369, 0x0}, + { 0x10469, 0x0}, + { 0x10569, 0x0}, + { 0x10669, 0x0}, + { 0x10769, 0x0}, + { 0x10869, 0x0}, + { 0x11069, 0x0}, + { 0x11169, 0x0}, + { 0x11269, 0x0}, + { 0x11369, 0x0}, + { 0x11469, 0x0}, + { 0x11569, 0x0}, + { 0x11669, 0x0}, + { 0x11769, 0x0}, + { 0x11869, 0x0}, + { 0x12069, 0x0}, + { 0x12169, 0x0}, + { 0x12269, 0x0}, + { 0x12369, 0x0}, + { 0x12469, 0x0}, + { 0x12569, 0x0}, + { 0x12669, 0x0}, + { 0x12769, 0x0}, + { 0x12869, 0x0}, + { 0x13069, 0x0}, + { 0x13169, 0x0}, + { 0x13269, 0x0}, + { 0x13369, 0x0}, + { 0x13469, 0x0}, + { 0x13569, 0x0}, + { 0x13669, 0x0}, + { 0x13769, 0x0}, + { 0x13869, 0x0}, + { 0x1008c, 0x0}, + { 0x11008c, 0x0}, + { 0x21008c, 0x0}, + { 0x1018c, 0x0}, + { 0x11018c, 0x0}, + { 0x21018c, 0x0}, + { 0x1108c, 0x0}, + { 0x11108c, 0x0}, + { 0x21108c, 0x0}, + { 0x1118c, 0x0}, + { 0x11118c, 0x0}, + { 0x21118c, 0x0}, + { 0x1208c, 0x0}, + { 0x11208c, 0x0}, + { 0x21208c, 0x0}, + { 0x1218c, 0x0}, + { 0x11218c, 0x0}, + { 0x21218c, 0x0}, + { 0x1308c, 0x0}, + { 0x11308c, 0x0}, + { 0x21308c, 0x0}, + { 0x1318c, 0x0}, + { 0x11318c, 0x0}, + { 0x21318c, 0x0}, + { 0x1008d, 0x0}, + { 0x11008d, 0x0}, + { 0x21008d, 0x0}, + { 0x1018d, 0x0}, + { 0x11018d, 0x0}, + { 0x21018d, 0x0}, + { 0x1108d, 0x0}, + { 0x11108d, 0x0}, + { 0x21108d, 0x0}, + { 0x1118d, 0x0}, + { 0x11118d, 0x0}, + { 0x21118d, 0x0}, + { 0x1208d, 0x0}, + { 0x11208d, 0x0}, + { 0x21208d, 0x0}, + { 0x1218d, 0x0}, + { 0x11218d, 0x0}, + { 0x21218d, 0x0}, + { 0x1308d, 0x0}, + { 0x11308d, 0x0}, + { 0x21308d, 0x0}, + { 0x1318d, 0x0}, + { 0x11318d, 0x0}, + { 0x21318d, 0x0}, + { 0x100c0, 0x0}, + { 0x1100c0, 0x0}, + { 0x2100c0, 0x0}, + { 0x101c0, 0x0}, + { 0x1101c0, 0x0}, + { 0x2101c0, 0x0}, + { 0x102c0, 0x0}, + { 0x1102c0, 0x0}, + { 0x2102c0, 0x0}, + { 0x103c0, 0x0}, + { 0x1103c0, 0x0}, + { 0x2103c0, 0x0}, + { 0x104c0, 0x0}, + { 0x1104c0, 0x0}, + { 0x2104c0, 0x0}, + { 0x105c0, 0x0}, + { 0x1105c0, 0x0}, + { 0x2105c0, 0x0}, + { 0x106c0, 0x0}, + { 0x1106c0, 0x0}, + { 0x2106c0, 0x0}, + { 0x107c0, 0x0}, + { 0x1107c0, 0x0}, + { 0x2107c0, 0x0}, + { 0x108c0, 0x0}, + { 0x1108c0, 0x0}, + { 0x2108c0, 0x0}, + { 0x110c0, 0x0}, + { 0x1110c0, 0x0}, + { 0x2110c0, 0x0}, + { 0x111c0, 0x0}, + { 0x1111c0, 0x0}, + { 0x2111c0, 0x0}, + { 0x112c0, 0x0}, + { 0x1112c0, 0x0}, + { 0x2112c0, 0x0}, + { 0x113c0, 0x0}, + { 0x1113c0, 0x0}, + { 0x2113c0, 0x0}, + { 0x114c0, 0x0}, + { 0x1114c0, 0x0}, + { 0x2114c0, 0x0}, + { 0x115c0, 0x0}, + { 0x1115c0, 0x0}, + { 0x2115c0, 0x0}, + { 0x116c0, 0x0}, + { 0x1116c0, 0x0}, + { 0x2116c0, 0x0}, + { 0x117c0, 0x0}, + { 0x1117c0, 0x0}, + { 0x2117c0, 0x0}, + { 0x118c0, 0x0}, + { 0x1118c0, 0x0}, + { 0x2118c0, 0x0}, + { 0x120c0, 0x0}, + { 0x1120c0, 0x0}, + { 0x2120c0, 0x0}, + { 0x121c0, 0x0}, + { 0x1121c0, 0x0}, + { 0x2121c0, 0x0}, + { 0x122c0, 0x0}, + { 0x1122c0, 0x0}, + { 0x2122c0, 0x0}, + { 0x123c0, 0x0}, + { 0x1123c0, 0x0}, + { 0x2123c0, 0x0}, + { 0x124c0, 0x0}, + { 0x1124c0, 0x0}, + { 0x2124c0, 0x0}, + { 0x125c0, 0x0}, + { 0x1125c0, 0x0}, + { 0x2125c0, 0x0}, + { 0x126c0, 0x0}, + { 0x1126c0, 0x0}, + { 0x2126c0, 0x0}, + { 0x127c0, 0x0}, + { 0x1127c0, 0x0}, + { 0x2127c0, 0x0}, + { 0x128c0, 0x0}, + { 0x1128c0, 0x0}, + { 0x2128c0, 0x0}, + { 0x130c0, 0x0}, + { 0x1130c0, 0x0}, + { 0x2130c0, 0x0}, + { 0x131c0, 0x0}, + { 0x1131c0, 0x0}, + { 0x2131c0, 0x0}, + { 0x132c0, 0x0}, + { 0x1132c0, 0x0}, + { 0x2132c0, 0x0}, + { 0x133c0, 0x0}, + { 0x1133c0, 0x0}, + { 0x2133c0, 0x0}, + { 0x134c0, 0x0}, + { 0x1134c0, 0x0}, + { 0x2134c0, 0x0}, + { 0x135c0, 0x0}, + { 0x1135c0, 0x0}, + { 0x2135c0, 0x0}, + { 0x136c0, 0x0}, + { 0x1136c0, 0x0}, + { 0x2136c0, 0x0}, + { 0x137c0, 0x0}, + { 0x1137c0, 0x0}, + { 0x2137c0, 0x0}, + { 0x138c0, 0x0}, + { 0x1138c0, 0x0}, + { 0x2138c0, 0x0}, + { 0x100c1, 0x0}, + { 0x1100c1, 0x0}, + { 0x2100c1, 0x0}, + { 0x101c1, 0x0}, + { 0x1101c1, 0x0}, + { 0x2101c1, 0x0}, + { 0x102c1, 0x0}, + { 0x1102c1, 0x0}, + { 0x2102c1, 0x0}, + { 0x103c1, 0x0}, + { 0x1103c1, 0x0}, + { 0x2103c1, 0x0}, + { 0x104c1, 0x0}, + { 0x1104c1, 0x0}, + { 0x2104c1, 0x0}, + { 0x105c1, 0x0}, + { 0x1105c1, 0x0}, + { 0x2105c1, 0x0}, + { 0x106c1, 0x0}, + { 0x1106c1, 0x0}, + { 0x2106c1, 0x0}, + { 0x107c1, 0x0}, + { 0x1107c1, 0x0}, + { 0x2107c1, 0x0}, + { 0x108c1, 0x0}, + { 0x1108c1, 0x0}, + { 0x2108c1, 0x0}, + { 0x110c1, 0x0}, + { 0x1110c1, 0x0}, + { 0x2110c1, 0x0}, + { 0x111c1, 0x0}, + { 0x1111c1, 0x0}, + { 0x2111c1, 0x0}, + { 0x112c1, 0x0}, + { 0x1112c1, 0x0}, + { 0x2112c1, 0x0}, + { 0x113c1, 0x0}, + { 0x1113c1, 0x0}, + { 0x2113c1, 0x0}, + { 0x114c1, 0x0}, + { 0x1114c1, 0x0}, + { 0x2114c1, 0x0}, + { 0x115c1, 0x0}, + { 0x1115c1, 0x0}, + { 0x2115c1, 0x0}, + { 0x116c1, 0x0}, + { 0x1116c1, 0x0}, + { 0x2116c1, 0x0}, + { 0x117c1, 0x0}, + { 0x1117c1, 0x0}, + { 0x2117c1, 0x0}, + { 0x118c1, 0x0}, + { 0x1118c1, 0x0}, + { 0x2118c1, 0x0}, + { 0x120c1, 0x0}, + { 0x1120c1, 0x0}, + { 0x2120c1, 0x0}, + { 0x121c1, 0x0}, + { 0x1121c1, 0x0}, + { 0x2121c1, 0x0}, + { 0x122c1, 0x0}, + { 0x1122c1, 0x0}, + { 0x2122c1, 0x0}, + { 0x123c1, 0x0}, + { 0x1123c1, 0x0}, + { 0x2123c1, 0x0}, + { 0x124c1, 0x0}, + { 0x1124c1, 0x0}, + { 0x2124c1, 0x0}, + { 0x125c1, 0x0}, + { 0x1125c1, 0x0}, + { 0x2125c1, 0x0}, + { 0x126c1, 0x0}, + { 0x1126c1, 0x0}, + { 0x2126c1, 0x0}, + { 0x127c1, 0x0}, + { 0x1127c1, 0x0}, + { 0x2127c1, 0x0}, + { 0x128c1, 0x0}, + { 0x1128c1, 0x0}, + { 0x2128c1, 0x0}, + { 0x130c1, 0x0}, + { 0x1130c1, 0x0}, + { 0x2130c1, 0x0}, + { 0x131c1, 0x0}, + { 0x1131c1, 0x0}, + { 0x2131c1, 0x0}, + { 0x132c1, 0x0}, + { 0x1132c1, 0x0}, + { 0x2132c1, 0x0}, + { 0x133c1, 0x0}, + { 0x1133c1, 0x0}, + { 0x2133c1, 0x0}, + { 0x134c1, 0x0}, + { 0x1134c1, 0x0}, + { 0x2134c1, 0x0}, + { 0x135c1, 0x0}, + { 0x1135c1, 0x0}, + { 0x2135c1, 0x0}, + { 0x136c1, 0x0}, + { 0x1136c1, 0x0}, + { 0x2136c1, 0x0}, + { 0x137c1, 0x0}, + { 0x1137c1, 0x0}, + { 0x2137c1, 0x0}, + { 0x138c1, 0x0}, + { 0x1138c1, 0x0}, + { 0x2138c1, 0x0}, + { 0x10020, 0x0}, + { 0x110020, 0x0}, + { 0x210020, 0x0}, + { 0x11020, 0x0}, + { 0x111020, 0x0}, + { 0x211020, 0x0}, + { 0x12020, 0x0}, + { 0x112020, 0x0}, + { 0x212020, 0x0}, + { 0x13020, 0x0}, + { 0x113020, 0x0}, + { 0x213020, 0x0}, + { 0x20072, 0x0}, + { 0x20073, 0x0}, + { 0x20074, 0x0}, + { 0x100aa, 0x0}, + { 0x110aa, 0x0}, + { 0x120aa, 0x0}, + { 0x130aa, 0x0}, + { 0x20010, 0x0}, + { 0x120010, 0x0}, + { 0x220010, 0x0}, + { 0x20011, 0x0}, + { 0x120011, 0x0}, + { 0x220011, 0x0}, + { 0x100ae, 0x0}, + { 0x1100ae, 0x0}, + { 0x2100ae, 0x0}, + { 0x100af, 0x0}, + { 0x1100af, 0x0}, + { 0x2100af, 0x0}, + { 0x110ae, 0x0}, + { 0x1110ae, 0x0}, + { 0x2110ae, 0x0}, + { 0x110af, 0x0}, + { 0x1110af, 0x0}, + { 0x2110af, 0x0}, + { 0x120ae, 0x0}, + { 0x1120ae, 0x0}, + { 0x2120ae, 0x0}, + { 0x120af, 0x0}, + { 0x1120af, 0x0}, + { 0x2120af, 0x0}, + { 0x130ae, 0x0}, + { 0x1130ae, 0x0}, + { 0x2130ae, 0x0}, + { 0x130af, 0x0}, + { 0x1130af, 0x0}, + { 0x2130af, 0x0}, + { 0x20020, 0x0}, + { 0x120020, 0x0}, + { 0x220020, 0x0}, + { 0x100a0, 0x0}, + { 0x100a1, 0x0}, + { 0x100a2, 0x0}, + { 0x100a3, 0x0}, + { 0x100a4, 0x0}, + { 0x100a5, 0x0}, + { 0x100a6, 0x0}, + { 0x100a7, 0x0}, + { 0x110a0, 0x0}, + { 0x110a1, 0x0}, + { 0x110a2, 0x0}, + { 0x110a3, 0x0}, + { 0x110a4, 0x0}, + { 0x110a5, 0x0}, + { 0x110a6, 0x0}, + { 0x110a7, 0x0}, + { 0x120a0, 0x0}, + { 0x120a1, 0x0}, + { 0x120a2, 0x0}, + { 0x120a3, 0x0}, + { 0x120a4, 0x0}, + { 0x120a5, 0x0}, + { 0x120a6, 0x0}, + { 0x120a7, 0x0}, + { 0x130a0, 0x0}, + { 0x130a1, 0x0}, + { 0x130a2, 0x0}, + { 0x130a3, 0x0}, + { 0x130a4, 0x0}, + { 0x130a5, 0x0}, + { 0x130a6, 0x0}, + { 0x130a7, 0x0}, + { 0x2007c, 0x0}, + { 0x12007c, 0x0}, + { 0x22007c, 0x0}, + { 0x2007d, 0x0}, + { 0x12007d, 0x0}, + { 0x22007d, 0x0}, + { 0x400fd, 0x0}, + { 0x400c0, 0x0}, + { 0x90201, 0x0}, + { 0x190201, 0x0}, + { 0x290201, 0x0}, + { 0x90202, 0x0}, + { 0x190202, 0x0}, + { 0x290202, 0x0}, + { 0x90203, 0x0}, + { 0x190203, 0x0}, + { 0x290203, 0x0}, + { 0x90204, 0x0}, + { 0x190204, 0x0}, + { 0x290204, 0x0}, + { 0x90205, 0x0}, + { 0x190205, 0x0}, + { 0x290205, 0x0}, + { 0x90206, 0x0}, + { 0x190206, 0x0}, + { 0x290206, 0x0}, + { 0x90207, 0x0}, + { 0x190207, 0x0}, + { 0x290207, 0x0}, + { 0x90208, 0x0}, + { 0x190208, 0x0}, + { 0x290208, 0x0}, + { 0x10062, 0x0}, + { 0x10162, 0x0}, + { 0x10262, 0x0}, + { 0x10362, 0x0}, + { 0x10462, 0x0}, + { 0x10562, 0x0}, + { 0x10662, 0x0}, + { 0x10762, 0x0}, + { 0x10862, 0x0}, + { 0x11062, 0x0}, + { 0x11162, 0x0}, + { 0x11262, 0x0}, + { 0x11362, 0x0}, + { 0x11462, 0x0}, + { 0x11562, 0x0}, + { 0x11662, 0x0}, + { 0x11762, 0x0}, + { 0x11862, 0x0}, + { 0x12062, 0x0}, + { 0x12162, 0x0}, + { 0x12262, 0x0}, + { 0x12362, 0x0}, + { 0x12462, 0x0}, + { 0x12562, 0x0}, + { 0x12662, 0x0}, + { 0x12762, 0x0}, + { 0x12862, 0x0}, + { 0x13062, 0x0}, + { 0x13162, 0x0}, + { 0x13262, 0x0}, + { 0x13362, 0x0}, + { 0x13462, 0x0}, + { 0x13562, 0x0}, + { 0x13662, 0x0}, + { 0x13762, 0x0}, + { 0x13862, 0x0}, + { 0x20077, 0x0}, + { 0x10001, 0x0}, + { 0x11001, 0x0}, + { 0x12001, 0x0}, + { 0x13001, 0x0}, + { 0x10040, 0x0}, + { 0x10140, 0x0}, + { 0x10240, 0x0}, + { 0x10340, 0x0}, + { 0x10440, 0x0}, + { 0x10540, 0x0}, + { 0x10640, 0x0}, + { 0x10740, 0x0}, + { 0x10840, 0x0}, + { 0x10030, 0x0}, + { 0x10130, 0x0}, + { 0x10230, 0x0}, + { 0x10330, 0x0}, + { 0x10430, 0x0}, + { 0x10530, 0x0}, + { 0x10630, 0x0}, + { 0x10730, 0x0}, + { 0x10830, 0x0}, + { 0x11040, 0x0}, + { 0x11140, 0x0}, + { 0x11240, 0x0}, + { 0x11340, 0x0}, + { 0x11440, 0x0}, + { 0x11540, 0x0}, + { 0x11640, 0x0}, + { 0x11740, 0x0}, + { 0x11840, 0x0}, + { 0x11030, 0x0}, + { 0x11130, 0x0}, + { 0x11230, 0x0}, + { 0x11330, 0x0}, + { 0x11430, 0x0}, + { 0x11530, 0x0}, + { 0x11630, 0x0}, + { 0x11730, 0x0}, + { 0x11830, 0x0}, + { 0x12040, 0x0}, + { 0x12140, 0x0}, + { 0x12240, 0x0}, + { 0x12340, 0x0}, + { 0x12440, 0x0}, + { 0x12540, 0x0}, + { 0x12640, 0x0}, + { 0x12740, 0x0}, + { 0x12840, 0x0}, + { 0x12030, 0x0}, + { 0x12130, 0x0}, + { 0x12230, 0x0}, + { 0x12330, 0x0}, + { 0x12430, 0x0}, + { 0x12530, 0x0}, + { 0x12630, 0x0}, + { 0x12730, 0x0}, + { 0x12830, 0x0}, + { 0x13040, 0x0}, + { 0x13140, 0x0}, + { 0x13240, 0x0}, + { 0x13340, 0x0}, + { 0x13440, 0x0}, + { 0x13540, 0x0}, + { 0x13640, 0x0}, + { 0x13740, 0x0}, + { 0x13840, 0x0}, + { 0x13030, 0x0}, + { 0x13130, 0x0}, + { 0x13230, 0x0}, + { 0x13330, 0x0}, + { 0x13430, 0x0}, + { 0x13530, 0x0}, + { 0x13630, 0x0}, + { 0x13730, 0x0}, + { 0x13830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0x960}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x24c4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x24c4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xc400}, + {0x54033, 0x3124}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xc400}, + {0x54039, 0x3124}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0x960}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x24c4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x24c4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xc400}, + {0x54033, 0x3124}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xc400}, + {0x54039, 0x3124}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x4b}, + {0x2000c, 0x96}, + {0x2000d, 0x5dc}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 2400mts 1D */ + .drate = 2400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 2400mts 2D */ + .drate = 2400, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info ucm_dram_timing_01061010 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 2400, 400, 100, }, +}; + diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.c b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.c new file mode 100644 index 0000000000..5141c04f12 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_01061010.c @@ -0,0 +1,1847 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x3a980}, + {0x3d400064, 0x5b00d2}, + {0x3d4000d0, 0xc00305ba}, + {0x3d4000d4, 0x940000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310000}, + {0x3d4000e8, 0x66004d}, + {0x3d4000ec, 0x16004d}, + {0x3d400100, 0x191e1920}, + {0x3d400104, 0x60630}, + {0x3d40010c, 0xb0b000}, + {0x3d400110, 0xe04080e}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xd8}, + {0x3d400144, 0x96004b}, + {0x3d400180, 0x2ee0017}, + {0x3d400184, 0x2605b8e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x170a}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x7070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc001c}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa040305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x1d}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30007}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa010102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x8}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x2ee}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0}, + { 0x1200b2, 0x0}, + { 0x2200b2, 0x0}, + { 0x200cb, 0x0}, + { 0x10043, 0x0}, + { 0x110043, 0x0}, + { 0x210043, 0x0}, + { 0x10143, 0x0}, + { 0x110143, 0x0}, + { 0x210143, 0x0}, + { 0x11043, 0x0}, + { 0x111043, 0x0}, + { 0x211043, 0x0}, + { 0x11143, 0x0}, + { 0x111143, 0x0}, + { 0x211143, 0x0}, + { 0x12043, 0x0}, + { 0x112043, 0x0}, + { 0x212043, 0x0}, + { 0x12143, 0x0}, + { 0x112143, 0x0}, + { 0x212143, 0x0}, + { 0x13043, 0x0}, + { 0x113043, 0x0}, + { 0x213043, 0x0}, + { 0x13143, 0x0}, + { 0x113143, 0x0}, + { 0x213143, 0x0}, + { 0x80, 0x0}, + { 0x100080, 0x0}, + { 0x200080, 0x0}, + { 0x1080, 0x0}, + { 0x101080, 0x0}, + { 0x201080, 0x0}, + { 0x2080, 0x0}, + { 0x102080, 0x0}, + { 0x202080, 0x0}, + { 0x3080, 0x0}, + { 0x103080, 0x0}, + { 0x203080, 0x0}, + { 0x4080, 0x0}, + { 0x104080, 0x0}, + { 0x204080, 0x0}, + { 0x5080, 0x0}, + { 0x105080, 0x0}, + { 0x205080, 0x0}, + { 0x6080, 0x0}, + { 0x106080, 0x0}, + { 0x206080, 0x0}, + { 0x7080, 0x0}, + { 0x107080, 0x0}, + { 0x207080, 0x0}, + { 0x8080, 0x0}, + { 0x108080, 0x0}, + { 0x208080, 0x0}, + { 0x9080, 0x0}, + { 0x109080, 0x0}, + { 0x209080, 0x0}, + { 0x10080, 0x0}, + { 0x110080, 0x0}, + { 0x210080, 0x0}, + { 0x10180, 0x0}, + { 0x110180, 0x0}, + { 0x210180, 0x0}, + { 0x11080, 0x0}, + { 0x111080, 0x0}, + { 0x211080, 0x0}, + { 0x11180, 0x0}, + { 0x111180, 0x0}, + { 0x211180, 0x0}, + { 0x12080, 0x0}, + { 0x112080, 0x0}, + { 0x212080, 0x0}, + { 0x12180, 0x0}, + { 0x112180, 0x0}, + { 0x212180, 0x0}, + { 0x13080, 0x0}, + { 0x113080, 0x0}, + { 0x213080, 0x0}, + { 0x13180, 0x0}, + { 0x113180, 0x0}, + { 0x213180, 0x0}, + { 0x10081, 0x0}, + { 0x110081, 0x0}, + { 0x210081, 0x0}, + { 0x10181, 0x0}, + { 0x110181, 0x0}, + { 0x210181, 0x0}, + { 0x11081, 0x0}, + { 0x111081, 0x0}, + { 0x211081, 0x0}, + { 0x11181, 0x0}, + { 0x111181, 0x0}, + { 0x211181, 0x0}, + { 0x12081, 0x0}, + { 0x112081, 0x0}, + { 0x212081, 0x0}, + { 0x12181, 0x0}, + { 0x112181, 0x0}, + { 0x212181, 0x0}, + { 0x13081, 0x0}, + { 0x113081, 0x0}, + { 0x213081, 0x0}, + { 0x13181, 0x0}, + { 0x113181, 0x0}, + { 0x213181, 0x0}, + { 0x100d0, 0x0}, + { 0x1100d0, 0x0}, + { 0x2100d0, 0x0}, + { 0x101d0, 0x0}, + { 0x1101d0, 0x0}, + { 0x2101d0, 0x0}, + { 0x110d0, 0x0}, + { 0x1110d0, 0x0}, + { 0x2110d0, 0x0}, + { 0x111d0, 0x0}, + { 0x1111d0, 0x0}, + { 0x2111d0, 0x0}, + { 0x120d0, 0x0}, + { 0x1120d0, 0x0}, + { 0x2120d0, 0x0}, + { 0x121d0, 0x0}, + { 0x1121d0, 0x0}, + { 0x2121d0, 0x0}, + { 0x130d0, 0x0}, + { 0x1130d0, 0x0}, + { 0x2130d0, 0x0}, + { 0x131d0, 0x0}, + { 0x1131d0, 0x0}, + { 0x2131d0, 0x0}, + { 0x100d1, 0x0}, + { 0x1100d1, 0x0}, + { 0x2100d1, 0x0}, + { 0x101d1, 0x0}, + { 0x1101d1, 0x0}, + { 0x2101d1, 0x0}, + { 0x110d1, 0x0}, + { 0x1110d1, 0x0}, + { 0x2110d1, 0x0}, + { 0x111d1, 0x0}, + { 0x1111d1, 0x0}, + { 0x2111d1, 0x0}, + { 0x120d1, 0x0}, + { 0x1120d1, 0x0}, + { 0x2120d1, 0x0}, + { 0x121d1, 0x0}, + { 0x1121d1, 0x0}, + { 0x2121d1, 0x0}, + { 0x130d1, 0x0}, + { 0x1130d1, 0x0}, + { 0x2130d1, 0x0}, + { 0x131d1, 0x0}, + { 0x1131d1, 0x0}, + { 0x2131d1, 0x0}, + { 0x10068, 0x0}, + { 0x10168, 0x0}, + { 0x10268, 0x0}, + { 0x10368, 0x0}, + { 0x10468, 0x0}, + { 0x10568, 0x0}, + { 0x10668, 0x0}, + { 0x10768, 0x0}, + { 0x10868, 0x0}, + { 0x11068, 0x0}, + { 0x11168, 0x0}, + { 0x11268, 0x0}, + { 0x11368, 0x0}, + { 0x11468, 0x0}, + { 0x11568, 0x0}, + { 0x11668, 0x0}, + { 0x11768, 0x0}, + { 0x11868, 0x0}, + { 0x12068, 0x0}, + { 0x12168, 0x0}, + { 0x12268, 0x0}, + { 0x12368, 0x0}, + { 0x12468, 0x0}, + { 0x12568, 0x0}, + { 0x12668, 0x0}, + { 0x12768, 0x0}, + { 0x12868, 0x0}, + { 0x13068, 0x0}, + { 0x13168, 0x0}, + { 0x13268, 0x0}, + { 0x13368, 0x0}, + { 0x13468, 0x0}, + { 0x13568, 0x0}, + { 0x13668, 0x0}, + { 0x13768, 0x0}, + { 0x13868, 0x0}, + { 0x10069, 0x0}, + { 0x10169, 0x0}, + { 0x10269, 0x0}, + { 0x10369, 0x0}, + { 0x10469, 0x0}, + { 0x10569, 0x0}, + { 0x10669, 0x0}, + { 0x10769, 0x0}, + { 0x10869, 0x0}, + { 0x11069, 0x0}, + { 0x11169, 0x0}, + { 0x11269, 0x0}, + { 0x11369, 0x0}, + { 0x11469, 0x0}, + { 0x11569, 0x0}, + { 0x11669, 0x0}, + { 0x11769, 0x0}, + { 0x11869, 0x0}, + { 0x12069, 0x0}, + { 0x12169, 0x0}, + { 0x12269, 0x0}, + { 0x12369, 0x0}, + { 0x12469, 0x0}, + { 0x12569, 0x0}, + { 0x12669, 0x0}, + { 0x12769, 0x0}, + { 0x12869, 0x0}, + { 0x13069, 0x0}, + { 0x13169, 0x0}, + { 0x13269, 0x0}, + { 0x13369, 0x0}, + { 0x13469, 0x0}, + { 0x13569, 0x0}, + { 0x13669, 0x0}, + { 0x13769, 0x0}, + { 0x13869, 0x0}, + { 0x1008c, 0x0}, + { 0x11008c, 0x0}, + { 0x21008c, 0x0}, + { 0x1018c, 0x0}, + { 0x11018c, 0x0}, + { 0x21018c, 0x0}, + { 0x1108c, 0x0}, + { 0x11108c, 0x0}, + { 0x21108c, 0x0}, + { 0x1118c, 0x0}, + { 0x11118c, 0x0}, + { 0x21118c, 0x0}, + { 0x1208c, 0x0}, + { 0x11208c, 0x0}, + { 0x21208c, 0x0}, + { 0x1218c, 0x0}, + { 0x11218c, 0x0}, + { 0x21218c, 0x0}, + { 0x1308c, 0x0}, + { 0x11308c, 0x0}, + { 0x21308c, 0x0}, + { 0x1318c, 0x0}, + { 0x11318c, 0x0}, + { 0x21318c, 0x0}, + { 0x1008d, 0x0}, + { 0x11008d, 0x0}, + { 0x21008d, 0x0}, + { 0x1018d, 0x0}, + { 0x11018d, 0x0}, + { 0x21018d, 0x0}, + { 0x1108d, 0x0}, + { 0x11108d, 0x0}, + { 0x21108d, 0x0}, + { 0x1118d, 0x0}, + { 0x11118d, 0x0}, + { 0x21118d, 0x0}, + { 0x1208d, 0x0}, + { 0x11208d, 0x0}, + { 0x21208d, 0x0}, + { 0x1218d, 0x0}, + { 0x11218d, 0x0}, + { 0x21218d, 0x0}, + { 0x1308d, 0x0}, + { 0x11308d, 0x0}, + { 0x21308d, 0x0}, + { 0x1318d, 0x0}, + { 0x11318d, 0x0}, + { 0x21318d, 0x0}, + { 0x100c0, 0x0}, + { 0x1100c0, 0x0}, + { 0x2100c0, 0x0}, + { 0x101c0, 0x0}, + { 0x1101c0, 0x0}, + { 0x2101c0, 0x0}, + { 0x102c0, 0x0}, + { 0x1102c0, 0x0}, + { 0x2102c0, 0x0}, + { 0x103c0, 0x0}, + { 0x1103c0, 0x0}, + { 0x2103c0, 0x0}, + { 0x104c0, 0x0}, + { 0x1104c0, 0x0}, + { 0x2104c0, 0x0}, + { 0x105c0, 0x0}, + { 0x1105c0, 0x0}, + { 0x2105c0, 0x0}, + { 0x106c0, 0x0}, + { 0x1106c0, 0x0}, + { 0x2106c0, 0x0}, + { 0x107c0, 0x0}, + { 0x1107c0, 0x0}, + { 0x2107c0, 0x0}, + { 0x108c0, 0x0}, + { 0x1108c0, 0x0}, + { 0x2108c0, 0x0}, + { 0x110c0, 0x0}, + { 0x1110c0, 0x0}, + { 0x2110c0, 0x0}, + { 0x111c0, 0x0}, + { 0x1111c0, 0x0}, + { 0x2111c0, 0x0}, + { 0x112c0, 0x0}, + { 0x1112c0, 0x0}, + { 0x2112c0, 0x0}, + { 0x113c0, 0x0}, + { 0x1113c0, 0x0}, + { 0x2113c0, 0x0}, + { 0x114c0, 0x0}, + { 0x1114c0, 0x0}, + { 0x2114c0, 0x0}, + { 0x115c0, 0x0}, + { 0x1115c0, 0x0}, + { 0x2115c0, 0x0}, + { 0x116c0, 0x0}, + { 0x1116c0, 0x0}, + { 0x2116c0, 0x0}, + { 0x117c0, 0x0}, + { 0x1117c0, 0x0}, + { 0x2117c0, 0x0}, + { 0x118c0, 0x0}, + { 0x1118c0, 0x0}, + { 0x2118c0, 0x0}, + { 0x120c0, 0x0}, + { 0x1120c0, 0x0}, + { 0x2120c0, 0x0}, + { 0x121c0, 0x0}, + { 0x1121c0, 0x0}, + { 0x2121c0, 0x0}, + { 0x122c0, 0x0}, + { 0x1122c0, 0x0}, + { 0x2122c0, 0x0}, + { 0x123c0, 0x0}, + { 0x1123c0, 0x0}, + { 0x2123c0, 0x0}, + { 0x124c0, 0x0}, + { 0x1124c0, 0x0}, + { 0x2124c0, 0x0}, + { 0x125c0, 0x0}, + { 0x1125c0, 0x0}, + { 0x2125c0, 0x0}, + { 0x126c0, 0x0}, + { 0x1126c0, 0x0}, + { 0x2126c0, 0x0}, + { 0x127c0, 0x0}, + { 0x1127c0, 0x0}, + { 0x2127c0, 0x0}, + { 0x128c0, 0x0}, + { 0x1128c0, 0x0}, + { 0x2128c0, 0x0}, + { 0x130c0, 0x0}, + { 0x1130c0, 0x0}, + { 0x2130c0, 0x0}, + { 0x131c0, 0x0}, + { 0x1131c0, 0x0}, + { 0x2131c0, 0x0}, + { 0x132c0, 0x0}, + { 0x1132c0, 0x0}, + { 0x2132c0, 0x0}, + { 0x133c0, 0x0}, + { 0x1133c0, 0x0}, + { 0x2133c0, 0x0}, + { 0x134c0, 0x0}, + { 0x1134c0, 0x0}, + { 0x2134c0, 0x0}, + { 0x135c0, 0x0}, + { 0x1135c0, 0x0}, + { 0x2135c0, 0x0}, + { 0x136c0, 0x0}, + { 0x1136c0, 0x0}, + { 0x2136c0, 0x0}, + { 0x137c0, 0x0}, + { 0x1137c0, 0x0}, + { 0x2137c0, 0x0}, + { 0x138c0, 0x0}, + { 0x1138c0, 0x0}, + { 0x2138c0, 0x0}, + { 0x100c1, 0x0}, + { 0x1100c1, 0x0}, + { 0x2100c1, 0x0}, + { 0x101c1, 0x0}, + { 0x1101c1, 0x0}, + { 0x2101c1, 0x0}, + { 0x102c1, 0x0}, + { 0x1102c1, 0x0}, + { 0x2102c1, 0x0}, + { 0x103c1, 0x0}, + { 0x1103c1, 0x0}, + { 0x2103c1, 0x0}, + { 0x104c1, 0x0}, + { 0x1104c1, 0x0}, + { 0x2104c1, 0x0}, + { 0x105c1, 0x0}, + { 0x1105c1, 0x0}, + { 0x2105c1, 0x0}, + { 0x106c1, 0x0}, + { 0x1106c1, 0x0}, + { 0x2106c1, 0x0}, + { 0x107c1, 0x0}, + { 0x1107c1, 0x0}, + { 0x2107c1, 0x0}, + { 0x108c1, 0x0}, + { 0x1108c1, 0x0}, + { 0x2108c1, 0x0}, + { 0x110c1, 0x0}, + { 0x1110c1, 0x0}, + { 0x2110c1, 0x0}, + { 0x111c1, 0x0}, + { 0x1111c1, 0x0}, + { 0x2111c1, 0x0}, + { 0x112c1, 0x0}, + { 0x1112c1, 0x0}, + { 0x2112c1, 0x0}, + { 0x113c1, 0x0}, + { 0x1113c1, 0x0}, + { 0x2113c1, 0x0}, + { 0x114c1, 0x0}, + { 0x1114c1, 0x0}, + { 0x2114c1, 0x0}, + { 0x115c1, 0x0}, + { 0x1115c1, 0x0}, + { 0x2115c1, 0x0}, + { 0x116c1, 0x0}, + { 0x1116c1, 0x0}, + { 0x2116c1, 0x0}, + { 0x117c1, 0x0}, + { 0x1117c1, 0x0}, + { 0x2117c1, 0x0}, + { 0x118c1, 0x0}, + { 0x1118c1, 0x0}, + { 0x2118c1, 0x0}, + { 0x120c1, 0x0}, + { 0x1120c1, 0x0}, + { 0x2120c1, 0x0}, + { 0x121c1, 0x0}, + { 0x1121c1, 0x0}, + { 0x2121c1, 0x0}, + { 0x122c1, 0x0}, + { 0x1122c1, 0x0}, + { 0x2122c1, 0x0}, + { 0x123c1, 0x0}, + { 0x1123c1, 0x0}, + { 0x2123c1, 0x0}, + { 0x124c1, 0x0}, + { 0x1124c1, 0x0}, + { 0x2124c1, 0x0}, + { 0x125c1, 0x0}, + { 0x1125c1, 0x0}, + { 0x2125c1, 0x0}, + { 0x126c1, 0x0}, + { 0x1126c1, 0x0}, + { 0x2126c1, 0x0}, + { 0x127c1, 0x0}, + { 0x1127c1, 0x0}, + { 0x2127c1, 0x0}, + { 0x128c1, 0x0}, + { 0x1128c1, 0x0}, + { 0x2128c1, 0x0}, + { 0x130c1, 0x0}, + { 0x1130c1, 0x0}, + { 0x2130c1, 0x0}, + { 0x131c1, 0x0}, + { 0x1131c1, 0x0}, + { 0x2131c1, 0x0}, + { 0x132c1, 0x0}, + { 0x1132c1, 0x0}, + { 0x2132c1, 0x0}, + { 0x133c1, 0x0}, + { 0x1133c1, 0x0}, + { 0x2133c1, 0x0}, + { 0x134c1, 0x0}, + { 0x1134c1, 0x0}, + { 0x2134c1, 0x0}, + { 0x135c1, 0x0}, + { 0x1135c1, 0x0}, + { 0x2135c1, 0x0}, + { 0x136c1, 0x0}, + { 0x1136c1, 0x0}, + { 0x2136c1, 0x0}, + { 0x137c1, 0x0}, + { 0x1137c1, 0x0}, + { 0x2137c1, 0x0}, + { 0x138c1, 0x0}, + { 0x1138c1, 0x0}, + { 0x2138c1, 0x0}, + { 0x10020, 0x0}, + { 0x110020, 0x0}, + { 0x210020, 0x0}, + { 0x11020, 0x0}, + { 0x111020, 0x0}, + { 0x211020, 0x0}, + { 0x12020, 0x0}, + { 0x112020, 0x0}, + { 0x212020, 0x0}, + { 0x13020, 0x0}, + { 0x113020, 0x0}, + { 0x213020, 0x0}, + { 0x20072, 0x0}, + { 0x20073, 0x0}, + { 0x20074, 0x0}, + { 0x100aa, 0x0}, + { 0x110aa, 0x0}, + { 0x120aa, 0x0}, + { 0x130aa, 0x0}, + { 0x20010, 0x0}, + { 0x120010, 0x0}, + { 0x220010, 0x0}, + { 0x20011, 0x0}, + { 0x120011, 0x0}, + { 0x220011, 0x0}, + { 0x100ae, 0x0}, + { 0x1100ae, 0x0}, + { 0x2100ae, 0x0}, + { 0x100af, 0x0}, + { 0x1100af, 0x0}, + { 0x2100af, 0x0}, + { 0x110ae, 0x0}, + { 0x1110ae, 0x0}, + { 0x2110ae, 0x0}, + { 0x110af, 0x0}, + { 0x1110af, 0x0}, + { 0x2110af, 0x0}, + { 0x120ae, 0x0}, + { 0x1120ae, 0x0}, + { 0x2120ae, 0x0}, + { 0x120af, 0x0}, + { 0x1120af, 0x0}, + { 0x2120af, 0x0}, + { 0x130ae, 0x0}, + { 0x1130ae, 0x0}, + { 0x2130ae, 0x0}, + { 0x130af, 0x0}, + { 0x1130af, 0x0}, + { 0x2130af, 0x0}, + { 0x20020, 0x0}, + { 0x120020, 0x0}, + { 0x220020, 0x0}, + { 0x100a0, 0x0}, + { 0x100a1, 0x0}, + { 0x100a2, 0x0}, + { 0x100a3, 0x0}, + { 0x100a4, 0x0}, + { 0x100a5, 0x0}, + { 0x100a6, 0x0}, + { 0x100a7, 0x0}, + { 0x110a0, 0x0}, + { 0x110a1, 0x0}, + { 0x110a2, 0x0}, + { 0x110a3, 0x0}, + { 0x110a4, 0x0}, + { 0x110a5, 0x0}, + { 0x110a6, 0x0}, + { 0x110a7, 0x0}, + { 0x120a0, 0x0}, + { 0x120a1, 0x0}, + { 0x120a2, 0x0}, + { 0x120a3, 0x0}, + { 0x120a4, 0x0}, + { 0x120a5, 0x0}, + { 0x120a6, 0x0}, + { 0x120a7, 0x0}, + { 0x130a0, 0x0}, + { 0x130a1, 0x0}, + { 0x130a2, 0x0}, + { 0x130a3, 0x0}, + { 0x130a4, 0x0}, + { 0x130a5, 0x0}, + { 0x130a6, 0x0}, + { 0x130a7, 0x0}, + { 0x2007c, 0x0}, + { 0x12007c, 0x0}, + { 0x22007c, 0x0}, + { 0x2007d, 0x0}, + { 0x12007d, 0x0}, + { 0x22007d, 0x0}, + { 0x400fd, 0x0}, + { 0x400c0, 0x0}, + { 0x90201, 0x0}, + { 0x190201, 0x0}, + { 0x290201, 0x0}, + { 0x90202, 0x0}, + { 0x190202, 0x0}, + { 0x290202, 0x0}, + { 0x90203, 0x0}, + { 0x190203, 0x0}, + { 0x290203, 0x0}, + { 0x90204, 0x0}, + { 0x190204, 0x0}, + { 0x290204, 0x0}, + { 0x90205, 0x0}, + { 0x190205, 0x0}, + { 0x290205, 0x0}, + { 0x90206, 0x0}, + { 0x190206, 0x0}, + { 0x290206, 0x0}, + { 0x90207, 0x0}, + { 0x190207, 0x0}, + { 0x290207, 0x0}, + { 0x90208, 0x0}, + { 0x190208, 0x0}, + { 0x290208, 0x0}, + { 0x10062, 0x0}, + { 0x10162, 0x0}, + { 0x10262, 0x0}, + { 0x10362, 0x0}, + { 0x10462, 0x0}, + { 0x10562, 0x0}, + { 0x10662, 0x0}, + { 0x10762, 0x0}, + { 0x10862, 0x0}, + { 0x11062, 0x0}, + { 0x11162, 0x0}, + { 0x11262, 0x0}, + { 0x11362, 0x0}, + { 0x11462, 0x0}, + { 0x11562, 0x0}, + { 0x11662, 0x0}, + { 0x11762, 0x0}, + { 0x11862, 0x0}, + { 0x12062, 0x0}, + { 0x12162, 0x0}, + { 0x12262, 0x0}, + { 0x12362, 0x0}, + { 0x12462, 0x0}, + { 0x12562, 0x0}, + { 0x12662, 0x0}, + { 0x12762, 0x0}, + { 0x12862, 0x0}, + { 0x13062, 0x0}, + { 0x13162, 0x0}, + { 0x13262, 0x0}, + { 0x13362, 0x0}, + { 0x13462, 0x0}, + { 0x13562, 0x0}, + { 0x13662, 0x0}, + { 0x13762, 0x0}, + { 0x13862, 0x0}, + { 0x20077, 0x0}, + { 0x10001, 0x0}, + { 0x11001, 0x0}, + { 0x12001, 0x0}, + { 0x13001, 0x0}, + { 0x10040, 0x0}, + { 0x10140, 0x0}, + { 0x10240, 0x0}, + { 0x10340, 0x0}, + { 0x10440, 0x0}, + { 0x10540, 0x0}, + { 0x10640, 0x0}, + { 0x10740, 0x0}, + { 0x10840, 0x0}, + { 0x10030, 0x0}, + { 0x10130, 0x0}, + { 0x10230, 0x0}, + { 0x10330, 0x0}, + { 0x10430, 0x0}, + { 0x10530, 0x0}, + { 0x10630, 0x0}, + { 0x10730, 0x0}, + { 0x10830, 0x0}, + { 0x11040, 0x0}, + { 0x11140, 0x0}, + { 0x11240, 0x0}, + { 0x11340, 0x0}, + { 0x11440, 0x0}, + { 0x11540, 0x0}, + { 0x11640, 0x0}, + { 0x11740, 0x0}, + { 0x11840, 0x0}, + { 0x11030, 0x0}, + { 0x11130, 0x0}, + { 0x11230, 0x0}, + { 0x11330, 0x0}, + { 0x11430, 0x0}, + { 0x11530, 0x0}, + { 0x11630, 0x0}, + { 0x11730, 0x0}, + { 0x11830, 0x0}, + { 0x12040, 0x0}, + { 0x12140, 0x0}, + { 0x12240, 0x0}, + { 0x12340, 0x0}, + { 0x12440, 0x0}, + { 0x12540, 0x0}, + { 0x12640, 0x0}, + { 0x12740, 0x0}, + { 0x12840, 0x0}, + { 0x12030, 0x0}, + { 0x12130, 0x0}, + { 0x12230, 0x0}, + { 0x12330, 0x0}, + { 0x12430, 0x0}, + { 0x12530, 0x0}, + { 0x12630, 0x0}, + { 0x12730, 0x0}, + { 0x12830, 0x0}, + { 0x13040, 0x0}, + { 0x13140, 0x0}, + { 0x13240, 0x0}, + { 0x13340, 0x0}, + { 0x13440, 0x0}, + { 0x13540, 0x0}, + { 0x13640, 0x0}, + { 0x13740, 0x0}, + { 0x13840, 0x0}, + { 0x13030, 0x0}, + { 0x13130, 0x0}, + { 0x13230, 0x0}, + { 0x13330, 0x0}, + { 0x13430, 0x0}, + { 0x13530, 0x0}, + { 0x13630, 0x0}, + { 0x13730, 0x0}, + { 0x13830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x5d}, + {0x2000c, 0xbb}, + {0x2000d, 0x753}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info ucm_dram_timing_01061010 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff000110.c b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff000110.c new file mode 100644 index 0000000000..2334722497 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff000110.c @@ -0,0 +1,1847 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa3080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x3a980}, + {0x3d400064, 0x5b00d2}, + {0x3d4000d0, 0xc00305ba}, + {0x3d4000d4, 0x940000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310000}, + {0x3d4000e8, 0x66004d}, + {0x3d4000ec, 0x16004d}, + {0x3d400100, 0x191e1920}, + {0x3d400104, 0x60630}, + {0x3d40010c, 0xb0b000}, + {0x3d400110, 0xe04080e}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xd8}, + {0x3d400144, 0x96004b}, + {0x3d400180, 0x2ee0017}, + {0x3d400184, 0x2605b8e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x170a}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x17}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x7070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc001c}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa040305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x1d}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30007}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa010102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x8}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x2ee}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0}, + { 0x1200b2, 0x0}, + { 0x2200b2, 0x0}, + { 0x200cb, 0x0}, + { 0x10043, 0x0}, + { 0x110043, 0x0}, + { 0x210043, 0x0}, + { 0x10143, 0x0}, + { 0x110143, 0x0}, + { 0x210143, 0x0}, + { 0x11043, 0x0}, + { 0x111043, 0x0}, + { 0x211043, 0x0}, + { 0x11143, 0x0}, + { 0x111143, 0x0}, + { 0x211143, 0x0}, + { 0x12043, 0x0}, + { 0x112043, 0x0}, + { 0x212043, 0x0}, + { 0x12143, 0x0}, + { 0x112143, 0x0}, + { 0x212143, 0x0}, + { 0x13043, 0x0}, + { 0x113043, 0x0}, + { 0x213043, 0x0}, + { 0x13143, 0x0}, + { 0x113143, 0x0}, + { 0x213143, 0x0}, + { 0x80, 0x0}, + { 0x100080, 0x0}, + { 0x200080, 0x0}, + { 0x1080, 0x0}, + { 0x101080, 0x0}, + { 0x201080, 0x0}, + { 0x2080, 0x0}, + { 0x102080, 0x0}, + { 0x202080, 0x0}, + { 0x3080, 0x0}, + { 0x103080, 0x0}, + { 0x203080, 0x0}, + { 0x4080, 0x0}, + { 0x104080, 0x0}, + { 0x204080, 0x0}, + { 0x5080, 0x0}, + { 0x105080, 0x0}, + { 0x205080, 0x0}, + { 0x6080, 0x0}, + { 0x106080, 0x0}, + { 0x206080, 0x0}, + { 0x7080, 0x0}, + { 0x107080, 0x0}, + { 0x207080, 0x0}, + { 0x8080, 0x0}, + { 0x108080, 0x0}, + { 0x208080, 0x0}, + { 0x9080, 0x0}, + { 0x109080, 0x0}, + { 0x209080, 0x0}, + { 0x10080, 0x0}, + { 0x110080, 0x0}, + { 0x210080, 0x0}, + { 0x10180, 0x0}, + { 0x110180, 0x0}, + { 0x210180, 0x0}, + { 0x11080, 0x0}, + { 0x111080, 0x0}, + { 0x211080, 0x0}, + { 0x11180, 0x0}, + { 0x111180, 0x0}, + { 0x211180, 0x0}, + { 0x12080, 0x0}, + { 0x112080, 0x0}, + { 0x212080, 0x0}, + { 0x12180, 0x0}, + { 0x112180, 0x0}, + { 0x212180, 0x0}, + { 0x13080, 0x0}, + { 0x113080, 0x0}, + { 0x213080, 0x0}, + { 0x13180, 0x0}, + { 0x113180, 0x0}, + { 0x213180, 0x0}, + { 0x10081, 0x0}, + { 0x110081, 0x0}, + { 0x210081, 0x0}, + { 0x10181, 0x0}, + { 0x110181, 0x0}, + { 0x210181, 0x0}, + { 0x11081, 0x0}, + { 0x111081, 0x0}, + { 0x211081, 0x0}, + { 0x11181, 0x0}, + { 0x111181, 0x0}, + { 0x211181, 0x0}, + { 0x12081, 0x0}, + { 0x112081, 0x0}, + { 0x212081, 0x0}, + { 0x12181, 0x0}, + { 0x112181, 0x0}, + { 0x212181, 0x0}, + { 0x13081, 0x0}, + { 0x113081, 0x0}, + { 0x213081, 0x0}, + { 0x13181, 0x0}, + { 0x113181, 0x0}, + { 0x213181, 0x0}, + { 0x100d0, 0x0}, + { 0x1100d0, 0x0}, + { 0x2100d0, 0x0}, + { 0x101d0, 0x0}, + { 0x1101d0, 0x0}, + { 0x2101d0, 0x0}, + { 0x110d0, 0x0}, + { 0x1110d0, 0x0}, + { 0x2110d0, 0x0}, + { 0x111d0, 0x0}, + { 0x1111d0, 0x0}, + { 0x2111d0, 0x0}, + { 0x120d0, 0x0}, + { 0x1120d0, 0x0}, + { 0x2120d0, 0x0}, + { 0x121d0, 0x0}, + { 0x1121d0, 0x0}, + { 0x2121d0, 0x0}, + { 0x130d0, 0x0}, + { 0x1130d0, 0x0}, + { 0x2130d0, 0x0}, + { 0x131d0, 0x0}, + { 0x1131d0, 0x0}, + { 0x2131d0, 0x0}, + { 0x100d1, 0x0}, + { 0x1100d1, 0x0}, + { 0x2100d1, 0x0}, + { 0x101d1, 0x0}, + { 0x1101d1, 0x0}, + { 0x2101d1, 0x0}, + { 0x110d1, 0x0}, + { 0x1110d1, 0x0}, + { 0x2110d1, 0x0}, + { 0x111d1, 0x0}, + { 0x1111d1, 0x0}, + { 0x2111d1, 0x0}, + { 0x120d1, 0x0}, + { 0x1120d1, 0x0}, + { 0x2120d1, 0x0}, + { 0x121d1, 0x0}, + { 0x1121d1, 0x0}, + { 0x2121d1, 0x0}, + { 0x130d1, 0x0}, + { 0x1130d1, 0x0}, + { 0x2130d1, 0x0}, + { 0x131d1, 0x0}, + { 0x1131d1, 0x0}, + { 0x2131d1, 0x0}, + { 0x10068, 0x0}, + { 0x10168, 0x0}, + { 0x10268, 0x0}, + { 0x10368, 0x0}, + { 0x10468, 0x0}, + { 0x10568, 0x0}, + { 0x10668, 0x0}, + { 0x10768, 0x0}, + { 0x10868, 0x0}, + { 0x11068, 0x0}, + { 0x11168, 0x0}, + { 0x11268, 0x0}, + { 0x11368, 0x0}, + { 0x11468, 0x0}, + { 0x11568, 0x0}, + { 0x11668, 0x0}, + { 0x11768, 0x0}, + { 0x11868, 0x0}, + { 0x12068, 0x0}, + { 0x12168, 0x0}, + { 0x12268, 0x0}, + { 0x12368, 0x0}, + { 0x12468, 0x0}, + { 0x12568, 0x0}, + { 0x12668, 0x0}, + { 0x12768, 0x0}, + { 0x12868, 0x0}, + { 0x13068, 0x0}, + { 0x13168, 0x0}, + { 0x13268, 0x0}, + { 0x13368, 0x0}, + { 0x13468, 0x0}, + { 0x13568, 0x0}, + { 0x13668, 0x0}, + { 0x13768, 0x0}, + { 0x13868, 0x0}, + { 0x10069, 0x0}, + { 0x10169, 0x0}, + { 0x10269, 0x0}, + { 0x10369, 0x0}, + { 0x10469, 0x0}, + { 0x10569, 0x0}, + { 0x10669, 0x0}, + { 0x10769, 0x0}, + { 0x10869, 0x0}, + { 0x11069, 0x0}, + { 0x11169, 0x0}, + { 0x11269, 0x0}, + { 0x11369, 0x0}, + { 0x11469, 0x0}, + { 0x11569, 0x0}, + { 0x11669, 0x0}, + { 0x11769, 0x0}, + { 0x11869, 0x0}, + { 0x12069, 0x0}, + { 0x12169, 0x0}, + { 0x12269, 0x0}, + { 0x12369, 0x0}, + { 0x12469, 0x0}, + { 0x12569, 0x0}, + { 0x12669, 0x0}, + { 0x12769, 0x0}, + { 0x12869, 0x0}, + { 0x13069, 0x0}, + { 0x13169, 0x0}, + { 0x13269, 0x0}, + { 0x13369, 0x0}, + { 0x13469, 0x0}, + { 0x13569, 0x0}, + { 0x13669, 0x0}, + { 0x13769, 0x0}, + { 0x13869, 0x0}, + { 0x1008c, 0x0}, + { 0x11008c, 0x0}, + { 0x21008c, 0x0}, + { 0x1018c, 0x0}, + { 0x11018c, 0x0}, + { 0x21018c, 0x0}, + { 0x1108c, 0x0}, + { 0x11108c, 0x0}, + { 0x21108c, 0x0}, + { 0x1118c, 0x0}, + { 0x11118c, 0x0}, + { 0x21118c, 0x0}, + { 0x1208c, 0x0}, + { 0x11208c, 0x0}, + { 0x21208c, 0x0}, + { 0x1218c, 0x0}, + { 0x11218c, 0x0}, + { 0x21218c, 0x0}, + { 0x1308c, 0x0}, + { 0x11308c, 0x0}, + { 0x21308c, 0x0}, + { 0x1318c, 0x0}, + { 0x11318c, 0x0}, + { 0x21318c, 0x0}, + { 0x1008d, 0x0}, + { 0x11008d, 0x0}, + { 0x21008d, 0x0}, + { 0x1018d, 0x0}, + { 0x11018d, 0x0}, + { 0x21018d, 0x0}, + { 0x1108d, 0x0}, + { 0x11108d, 0x0}, + { 0x21108d, 0x0}, + { 0x1118d, 0x0}, + { 0x11118d, 0x0}, + { 0x21118d, 0x0}, + { 0x1208d, 0x0}, + { 0x11208d, 0x0}, + { 0x21208d, 0x0}, + { 0x1218d, 0x0}, + { 0x11218d, 0x0}, + { 0x21218d, 0x0}, + { 0x1308d, 0x0}, + { 0x11308d, 0x0}, + { 0x21308d, 0x0}, + { 0x1318d, 0x0}, + { 0x11318d, 0x0}, + { 0x21318d, 0x0}, + { 0x100c0, 0x0}, + { 0x1100c0, 0x0}, + { 0x2100c0, 0x0}, + { 0x101c0, 0x0}, + { 0x1101c0, 0x0}, + { 0x2101c0, 0x0}, + { 0x102c0, 0x0}, + { 0x1102c0, 0x0}, + { 0x2102c0, 0x0}, + { 0x103c0, 0x0}, + { 0x1103c0, 0x0}, + { 0x2103c0, 0x0}, + { 0x104c0, 0x0}, + { 0x1104c0, 0x0}, + { 0x2104c0, 0x0}, + { 0x105c0, 0x0}, + { 0x1105c0, 0x0}, + { 0x2105c0, 0x0}, + { 0x106c0, 0x0}, + { 0x1106c0, 0x0}, + { 0x2106c0, 0x0}, + { 0x107c0, 0x0}, + { 0x1107c0, 0x0}, + { 0x2107c0, 0x0}, + { 0x108c0, 0x0}, + { 0x1108c0, 0x0}, + { 0x2108c0, 0x0}, + { 0x110c0, 0x0}, + { 0x1110c0, 0x0}, + { 0x2110c0, 0x0}, + { 0x111c0, 0x0}, + { 0x1111c0, 0x0}, + { 0x2111c0, 0x0}, + { 0x112c0, 0x0}, + { 0x1112c0, 0x0}, + { 0x2112c0, 0x0}, + { 0x113c0, 0x0}, + { 0x1113c0, 0x0}, + { 0x2113c0, 0x0}, + { 0x114c0, 0x0}, + { 0x1114c0, 0x0}, + { 0x2114c0, 0x0}, + { 0x115c0, 0x0}, + { 0x1115c0, 0x0}, + { 0x2115c0, 0x0}, + { 0x116c0, 0x0}, + { 0x1116c0, 0x0}, + { 0x2116c0, 0x0}, + { 0x117c0, 0x0}, + { 0x1117c0, 0x0}, + { 0x2117c0, 0x0}, + { 0x118c0, 0x0}, + { 0x1118c0, 0x0}, + { 0x2118c0, 0x0}, + { 0x120c0, 0x0}, + { 0x1120c0, 0x0}, + { 0x2120c0, 0x0}, + { 0x121c0, 0x0}, + { 0x1121c0, 0x0}, + { 0x2121c0, 0x0}, + { 0x122c0, 0x0}, + { 0x1122c0, 0x0}, + { 0x2122c0, 0x0}, + { 0x123c0, 0x0}, + { 0x1123c0, 0x0}, + { 0x2123c0, 0x0}, + { 0x124c0, 0x0}, + { 0x1124c0, 0x0}, + { 0x2124c0, 0x0}, + { 0x125c0, 0x0}, + { 0x1125c0, 0x0}, + { 0x2125c0, 0x0}, + { 0x126c0, 0x0}, + { 0x1126c0, 0x0}, + { 0x2126c0, 0x0}, + { 0x127c0, 0x0}, + { 0x1127c0, 0x0}, + { 0x2127c0, 0x0}, + { 0x128c0, 0x0}, + { 0x1128c0, 0x0}, + { 0x2128c0, 0x0}, + { 0x130c0, 0x0}, + { 0x1130c0, 0x0}, + { 0x2130c0, 0x0}, + { 0x131c0, 0x0}, + { 0x1131c0, 0x0}, + { 0x2131c0, 0x0}, + { 0x132c0, 0x0}, + { 0x1132c0, 0x0}, + { 0x2132c0, 0x0}, + { 0x133c0, 0x0}, + { 0x1133c0, 0x0}, + { 0x2133c0, 0x0}, + { 0x134c0, 0x0}, + { 0x1134c0, 0x0}, + { 0x2134c0, 0x0}, + { 0x135c0, 0x0}, + { 0x1135c0, 0x0}, + { 0x2135c0, 0x0}, + { 0x136c0, 0x0}, + { 0x1136c0, 0x0}, + { 0x2136c0, 0x0}, + { 0x137c0, 0x0}, + { 0x1137c0, 0x0}, + { 0x2137c0, 0x0}, + { 0x138c0, 0x0}, + { 0x1138c0, 0x0}, + { 0x2138c0, 0x0}, + { 0x100c1, 0x0}, + { 0x1100c1, 0x0}, + { 0x2100c1, 0x0}, + { 0x101c1, 0x0}, + { 0x1101c1, 0x0}, + { 0x2101c1, 0x0}, + { 0x102c1, 0x0}, + { 0x1102c1, 0x0}, + { 0x2102c1, 0x0}, + { 0x103c1, 0x0}, + { 0x1103c1, 0x0}, + { 0x2103c1, 0x0}, + { 0x104c1, 0x0}, + { 0x1104c1, 0x0}, + { 0x2104c1, 0x0}, + { 0x105c1, 0x0}, + { 0x1105c1, 0x0}, + { 0x2105c1, 0x0}, + { 0x106c1, 0x0}, + { 0x1106c1, 0x0}, + { 0x2106c1, 0x0}, + { 0x107c1, 0x0}, + { 0x1107c1, 0x0}, + { 0x2107c1, 0x0}, + { 0x108c1, 0x0}, + { 0x1108c1, 0x0}, + { 0x2108c1, 0x0}, + { 0x110c1, 0x0}, + { 0x1110c1, 0x0}, + { 0x2110c1, 0x0}, + { 0x111c1, 0x0}, + { 0x1111c1, 0x0}, + { 0x2111c1, 0x0}, + { 0x112c1, 0x0}, + { 0x1112c1, 0x0}, + { 0x2112c1, 0x0}, + { 0x113c1, 0x0}, + { 0x1113c1, 0x0}, + { 0x2113c1, 0x0}, + { 0x114c1, 0x0}, + { 0x1114c1, 0x0}, + { 0x2114c1, 0x0}, + { 0x115c1, 0x0}, + { 0x1115c1, 0x0}, + { 0x2115c1, 0x0}, + { 0x116c1, 0x0}, + { 0x1116c1, 0x0}, + { 0x2116c1, 0x0}, + { 0x117c1, 0x0}, + { 0x1117c1, 0x0}, + { 0x2117c1, 0x0}, + { 0x118c1, 0x0}, + { 0x1118c1, 0x0}, + { 0x2118c1, 0x0}, + { 0x120c1, 0x0}, + { 0x1120c1, 0x0}, + { 0x2120c1, 0x0}, + { 0x121c1, 0x0}, + { 0x1121c1, 0x0}, + { 0x2121c1, 0x0}, + { 0x122c1, 0x0}, + { 0x1122c1, 0x0}, + { 0x2122c1, 0x0}, + { 0x123c1, 0x0}, + { 0x1123c1, 0x0}, + { 0x2123c1, 0x0}, + { 0x124c1, 0x0}, + { 0x1124c1, 0x0}, + { 0x2124c1, 0x0}, + { 0x125c1, 0x0}, + { 0x1125c1, 0x0}, + { 0x2125c1, 0x0}, + { 0x126c1, 0x0}, + { 0x1126c1, 0x0}, + { 0x2126c1, 0x0}, + { 0x127c1, 0x0}, + { 0x1127c1, 0x0}, + { 0x2127c1, 0x0}, + { 0x128c1, 0x0}, + { 0x1128c1, 0x0}, + { 0x2128c1, 0x0}, + { 0x130c1, 0x0}, + { 0x1130c1, 0x0}, + { 0x2130c1, 0x0}, + { 0x131c1, 0x0}, + { 0x1131c1, 0x0}, + { 0x2131c1, 0x0}, + { 0x132c1, 0x0}, + { 0x1132c1, 0x0}, + { 0x2132c1, 0x0}, + { 0x133c1, 0x0}, + { 0x1133c1, 0x0}, + { 0x2133c1, 0x0}, + { 0x134c1, 0x0}, + { 0x1134c1, 0x0}, + { 0x2134c1, 0x0}, + { 0x135c1, 0x0}, + { 0x1135c1, 0x0}, + { 0x2135c1, 0x0}, + { 0x136c1, 0x0}, + { 0x1136c1, 0x0}, + { 0x2136c1, 0x0}, + { 0x137c1, 0x0}, + { 0x1137c1, 0x0}, + { 0x2137c1, 0x0}, + { 0x138c1, 0x0}, + { 0x1138c1, 0x0}, + { 0x2138c1, 0x0}, + { 0x10020, 0x0}, + { 0x110020, 0x0}, + { 0x210020, 0x0}, + { 0x11020, 0x0}, + { 0x111020, 0x0}, + { 0x211020, 0x0}, + { 0x12020, 0x0}, + { 0x112020, 0x0}, + { 0x212020, 0x0}, + { 0x13020, 0x0}, + { 0x113020, 0x0}, + { 0x213020, 0x0}, + { 0x20072, 0x0}, + { 0x20073, 0x0}, + { 0x20074, 0x0}, + { 0x100aa, 0x0}, + { 0x110aa, 0x0}, + { 0x120aa, 0x0}, + { 0x130aa, 0x0}, + { 0x20010, 0x0}, + { 0x120010, 0x0}, + { 0x220010, 0x0}, + { 0x20011, 0x0}, + { 0x120011, 0x0}, + { 0x220011, 0x0}, + { 0x100ae, 0x0}, + { 0x1100ae, 0x0}, + { 0x2100ae, 0x0}, + { 0x100af, 0x0}, + { 0x1100af, 0x0}, + { 0x2100af, 0x0}, + { 0x110ae, 0x0}, + { 0x1110ae, 0x0}, + { 0x2110ae, 0x0}, + { 0x110af, 0x0}, + { 0x1110af, 0x0}, + { 0x2110af, 0x0}, + { 0x120ae, 0x0}, + { 0x1120ae, 0x0}, + { 0x2120ae, 0x0}, + { 0x120af, 0x0}, + { 0x1120af, 0x0}, + { 0x2120af, 0x0}, + { 0x130ae, 0x0}, + { 0x1130ae, 0x0}, + { 0x2130ae, 0x0}, + { 0x130af, 0x0}, + { 0x1130af, 0x0}, + { 0x2130af, 0x0}, + { 0x20020, 0x0}, + { 0x120020, 0x0}, + { 0x220020, 0x0}, + { 0x100a0, 0x0}, + { 0x100a1, 0x0}, + { 0x100a2, 0x0}, + { 0x100a3, 0x0}, + { 0x100a4, 0x0}, + { 0x100a5, 0x0}, + { 0x100a6, 0x0}, + { 0x100a7, 0x0}, + { 0x110a0, 0x0}, + { 0x110a1, 0x0}, + { 0x110a2, 0x0}, + { 0x110a3, 0x0}, + { 0x110a4, 0x0}, + { 0x110a5, 0x0}, + { 0x110a6, 0x0}, + { 0x110a7, 0x0}, + { 0x120a0, 0x0}, + { 0x120a1, 0x0}, + { 0x120a2, 0x0}, + { 0x120a3, 0x0}, + { 0x120a4, 0x0}, + { 0x120a5, 0x0}, + { 0x120a6, 0x0}, + { 0x120a7, 0x0}, + { 0x130a0, 0x0}, + { 0x130a1, 0x0}, + { 0x130a2, 0x0}, + { 0x130a3, 0x0}, + { 0x130a4, 0x0}, + { 0x130a5, 0x0}, + { 0x130a6, 0x0}, + { 0x130a7, 0x0}, + { 0x2007c, 0x0}, + { 0x12007c, 0x0}, + { 0x22007c, 0x0}, + { 0x2007d, 0x0}, + { 0x12007d, 0x0}, + { 0x22007d, 0x0}, + { 0x400fd, 0x0}, + { 0x400c0, 0x0}, + { 0x90201, 0x0}, + { 0x190201, 0x0}, + { 0x290201, 0x0}, + { 0x90202, 0x0}, + { 0x190202, 0x0}, + { 0x290202, 0x0}, + { 0x90203, 0x0}, + { 0x190203, 0x0}, + { 0x290203, 0x0}, + { 0x90204, 0x0}, + { 0x190204, 0x0}, + { 0x290204, 0x0}, + { 0x90205, 0x0}, + { 0x190205, 0x0}, + { 0x290205, 0x0}, + { 0x90206, 0x0}, + { 0x190206, 0x0}, + { 0x290206, 0x0}, + { 0x90207, 0x0}, + { 0x190207, 0x0}, + { 0x290207, 0x0}, + { 0x90208, 0x0}, + { 0x190208, 0x0}, + { 0x290208, 0x0}, + { 0x10062, 0x0}, + { 0x10162, 0x0}, + { 0x10262, 0x0}, + { 0x10362, 0x0}, + { 0x10462, 0x0}, + { 0x10562, 0x0}, + { 0x10662, 0x0}, + { 0x10762, 0x0}, + { 0x10862, 0x0}, + { 0x11062, 0x0}, + { 0x11162, 0x0}, + { 0x11262, 0x0}, + { 0x11362, 0x0}, + { 0x11462, 0x0}, + { 0x11562, 0x0}, + { 0x11662, 0x0}, + { 0x11762, 0x0}, + { 0x11862, 0x0}, + { 0x12062, 0x0}, + { 0x12162, 0x0}, + { 0x12262, 0x0}, + { 0x12362, 0x0}, + { 0x12462, 0x0}, + { 0x12562, 0x0}, + { 0x12662, 0x0}, + { 0x12762, 0x0}, + { 0x12862, 0x0}, + { 0x13062, 0x0}, + { 0x13162, 0x0}, + { 0x13262, 0x0}, + { 0x13362, 0x0}, + { 0x13462, 0x0}, + { 0x13562, 0x0}, + { 0x13662, 0x0}, + { 0x13762, 0x0}, + { 0x13862, 0x0}, + { 0x20077, 0x0}, + { 0x10001, 0x0}, + { 0x11001, 0x0}, + { 0x12001, 0x0}, + { 0x13001, 0x0}, + { 0x10040, 0x0}, + { 0x10140, 0x0}, + { 0x10240, 0x0}, + { 0x10340, 0x0}, + { 0x10440, 0x0}, + { 0x10540, 0x0}, + { 0x10640, 0x0}, + { 0x10740, 0x0}, + { 0x10840, 0x0}, + { 0x10030, 0x0}, + { 0x10130, 0x0}, + { 0x10230, 0x0}, + { 0x10330, 0x0}, + { 0x10430, 0x0}, + { 0x10530, 0x0}, + { 0x10630, 0x0}, + { 0x10730, 0x0}, + { 0x10830, 0x0}, + { 0x11040, 0x0}, + { 0x11140, 0x0}, + { 0x11240, 0x0}, + { 0x11340, 0x0}, + { 0x11440, 0x0}, + { 0x11540, 0x0}, + { 0x11640, 0x0}, + { 0x11740, 0x0}, + { 0x11840, 0x0}, + { 0x11030, 0x0}, + { 0x11130, 0x0}, + { 0x11230, 0x0}, + { 0x11330, 0x0}, + { 0x11430, 0x0}, + { 0x11530, 0x0}, + { 0x11630, 0x0}, + { 0x11730, 0x0}, + { 0x11830, 0x0}, + { 0x12040, 0x0}, + { 0x12140, 0x0}, + { 0x12240, 0x0}, + { 0x12340, 0x0}, + { 0x12440, 0x0}, + { 0x12540, 0x0}, + { 0x12640, 0x0}, + { 0x12740, 0x0}, + { 0x12840, 0x0}, + { 0x12030, 0x0}, + { 0x12130, 0x0}, + { 0x12230, 0x0}, + { 0x12330, 0x0}, + { 0x12430, 0x0}, + { 0x12530, 0x0}, + { 0x12630, 0x0}, + { 0x12730, 0x0}, + { 0x12830, 0x0}, + { 0x13040, 0x0}, + { 0x13140, 0x0}, + { 0x13240, 0x0}, + { 0x13340, 0x0}, + { 0x13440, 0x0}, + { 0x13540, 0x0}, + { 0x13640, 0x0}, + { 0x13740, 0x0}, + { 0x13840, 0x0}, + { 0x13030, 0x0}, + { 0x13130, 0x0}, + { 0x13230, 0x0}, + { 0x13330, 0x0}, + { 0x13430, 0x0}, + { 0x13530, 0x0}, + { 0x13630, 0x0}, + { 0x13730, 0x0}, + { 0x13830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x5d}, + {0x2000c, 0xbb}, + {0x2000d, 0x753}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info ucm_dram_timing_ff000110 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff020008.c b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff020008.c new file mode 100644 index 0000000000..e65445e015 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/ddr/lpddr4_timing_ff020008.c @@ -0,0 +1,1847 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa3080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x3a980}, + {0x3d400064, 0x5b00d2}, + {0x3d4000d0, 0xc00305ba}, + {0x3d4000d4, 0x940000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310000}, + {0x3d4000e8, 0x66004d}, + {0x3d4000ec, 0x16004d}, + {0x3d400100, 0x191e1920}, + {0x3d400104, 0x60630}, + {0x3d40010c, 0xb0b000}, + {0x3d400110, 0xe04080e}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xd8}, + {0x3d400144, 0x96004b}, + {0x3d400180, 0x2ee0017}, + {0x3d400184, 0x2605b8e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x170a}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x16}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0xf070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc001c}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa040305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x1d}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30007}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa010102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x8}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x2ee}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0}, + { 0x1200b2, 0x0}, + { 0x2200b2, 0x0}, + { 0x200cb, 0x0}, + { 0x10043, 0x0}, + { 0x110043, 0x0}, + { 0x210043, 0x0}, + { 0x10143, 0x0}, + { 0x110143, 0x0}, + { 0x210143, 0x0}, + { 0x11043, 0x0}, + { 0x111043, 0x0}, + { 0x211043, 0x0}, + { 0x11143, 0x0}, + { 0x111143, 0x0}, + { 0x211143, 0x0}, + { 0x12043, 0x0}, + { 0x112043, 0x0}, + { 0x212043, 0x0}, + { 0x12143, 0x0}, + { 0x112143, 0x0}, + { 0x212143, 0x0}, + { 0x13043, 0x0}, + { 0x113043, 0x0}, + { 0x213043, 0x0}, + { 0x13143, 0x0}, + { 0x113143, 0x0}, + { 0x213143, 0x0}, + { 0x80, 0x0}, + { 0x100080, 0x0}, + { 0x200080, 0x0}, + { 0x1080, 0x0}, + { 0x101080, 0x0}, + { 0x201080, 0x0}, + { 0x2080, 0x0}, + { 0x102080, 0x0}, + { 0x202080, 0x0}, + { 0x3080, 0x0}, + { 0x103080, 0x0}, + { 0x203080, 0x0}, + { 0x4080, 0x0}, + { 0x104080, 0x0}, + { 0x204080, 0x0}, + { 0x5080, 0x0}, + { 0x105080, 0x0}, + { 0x205080, 0x0}, + { 0x6080, 0x0}, + { 0x106080, 0x0}, + { 0x206080, 0x0}, + { 0x7080, 0x0}, + { 0x107080, 0x0}, + { 0x207080, 0x0}, + { 0x8080, 0x0}, + { 0x108080, 0x0}, + { 0x208080, 0x0}, + { 0x9080, 0x0}, + { 0x109080, 0x0}, + { 0x209080, 0x0}, + { 0x10080, 0x0}, + { 0x110080, 0x0}, + { 0x210080, 0x0}, + { 0x10180, 0x0}, + { 0x110180, 0x0}, + { 0x210180, 0x0}, + { 0x11080, 0x0}, + { 0x111080, 0x0}, + { 0x211080, 0x0}, + { 0x11180, 0x0}, + { 0x111180, 0x0}, + { 0x211180, 0x0}, + { 0x12080, 0x0}, + { 0x112080, 0x0}, + { 0x212080, 0x0}, + { 0x12180, 0x0}, + { 0x112180, 0x0}, + { 0x212180, 0x0}, + { 0x13080, 0x0}, + { 0x113080, 0x0}, + { 0x213080, 0x0}, + { 0x13180, 0x0}, + { 0x113180, 0x0}, + { 0x213180, 0x0}, + { 0x10081, 0x0}, + { 0x110081, 0x0}, + { 0x210081, 0x0}, + { 0x10181, 0x0}, + { 0x110181, 0x0}, + { 0x210181, 0x0}, + { 0x11081, 0x0}, + { 0x111081, 0x0}, + { 0x211081, 0x0}, + { 0x11181, 0x0}, + { 0x111181, 0x0}, + { 0x211181, 0x0}, + { 0x12081, 0x0}, + { 0x112081, 0x0}, + { 0x212081, 0x0}, + { 0x12181, 0x0}, + { 0x112181, 0x0}, + { 0x212181, 0x0}, + { 0x13081, 0x0}, + { 0x113081, 0x0}, + { 0x213081, 0x0}, + { 0x13181, 0x0}, + { 0x113181, 0x0}, + { 0x213181, 0x0}, + { 0x100d0, 0x0}, + { 0x1100d0, 0x0}, + { 0x2100d0, 0x0}, + { 0x101d0, 0x0}, + { 0x1101d0, 0x0}, + { 0x2101d0, 0x0}, + { 0x110d0, 0x0}, + { 0x1110d0, 0x0}, + { 0x2110d0, 0x0}, + { 0x111d0, 0x0}, + { 0x1111d0, 0x0}, + { 0x2111d0, 0x0}, + { 0x120d0, 0x0}, + { 0x1120d0, 0x0}, + { 0x2120d0, 0x0}, + { 0x121d0, 0x0}, + { 0x1121d0, 0x0}, + { 0x2121d0, 0x0}, + { 0x130d0, 0x0}, + { 0x1130d0, 0x0}, + { 0x2130d0, 0x0}, + { 0x131d0, 0x0}, + { 0x1131d0, 0x0}, + { 0x2131d0, 0x0}, + { 0x100d1, 0x0}, + { 0x1100d1, 0x0}, + { 0x2100d1, 0x0}, + { 0x101d1, 0x0}, + { 0x1101d1, 0x0}, + { 0x2101d1, 0x0}, + { 0x110d1, 0x0}, + { 0x1110d1, 0x0}, + { 0x2110d1, 0x0}, + { 0x111d1, 0x0}, + { 0x1111d1, 0x0}, + { 0x2111d1, 0x0}, + { 0x120d1, 0x0}, + { 0x1120d1, 0x0}, + { 0x2120d1, 0x0}, + { 0x121d1, 0x0}, + { 0x1121d1, 0x0}, + { 0x2121d1, 0x0}, + { 0x130d1, 0x0}, + { 0x1130d1, 0x0}, + { 0x2130d1, 0x0}, + { 0x131d1, 0x0}, + { 0x1131d1, 0x0}, + { 0x2131d1, 0x0}, + { 0x10068, 0x0}, + { 0x10168, 0x0}, + { 0x10268, 0x0}, + { 0x10368, 0x0}, + { 0x10468, 0x0}, + { 0x10568, 0x0}, + { 0x10668, 0x0}, + { 0x10768, 0x0}, + { 0x10868, 0x0}, + { 0x11068, 0x0}, + { 0x11168, 0x0}, + { 0x11268, 0x0}, + { 0x11368, 0x0}, + { 0x11468, 0x0}, + { 0x11568, 0x0}, + { 0x11668, 0x0}, + { 0x11768, 0x0}, + { 0x11868, 0x0}, + { 0x12068, 0x0}, + { 0x12168, 0x0}, + { 0x12268, 0x0}, + { 0x12368, 0x0}, + { 0x12468, 0x0}, + { 0x12568, 0x0}, + { 0x12668, 0x0}, + { 0x12768, 0x0}, + { 0x12868, 0x0}, + { 0x13068, 0x0}, + { 0x13168, 0x0}, + { 0x13268, 0x0}, + { 0x13368, 0x0}, + { 0x13468, 0x0}, + { 0x13568, 0x0}, + { 0x13668, 0x0}, + { 0x13768, 0x0}, + { 0x13868, 0x0}, + { 0x10069, 0x0}, + { 0x10169, 0x0}, + { 0x10269, 0x0}, + { 0x10369, 0x0}, + { 0x10469, 0x0}, + { 0x10569, 0x0}, + { 0x10669, 0x0}, + { 0x10769, 0x0}, + { 0x10869, 0x0}, + { 0x11069, 0x0}, + { 0x11169, 0x0}, + { 0x11269, 0x0}, + { 0x11369, 0x0}, + { 0x11469, 0x0}, + { 0x11569, 0x0}, + { 0x11669, 0x0}, + { 0x11769, 0x0}, + { 0x11869, 0x0}, + { 0x12069, 0x0}, + { 0x12169, 0x0}, + { 0x12269, 0x0}, + { 0x12369, 0x0}, + { 0x12469, 0x0}, + { 0x12569, 0x0}, + { 0x12669, 0x0}, + { 0x12769, 0x0}, + { 0x12869, 0x0}, + { 0x13069, 0x0}, + { 0x13169, 0x0}, + { 0x13269, 0x0}, + { 0x13369, 0x0}, + { 0x13469, 0x0}, + { 0x13569, 0x0}, + { 0x13669, 0x0}, + { 0x13769, 0x0}, + { 0x13869, 0x0}, + { 0x1008c, 0x0}, + { 0x11008c, 0x0}, + { 0x21008c, 0x0}, + { 0x1018c, 0x0}, + { 0x11018c, 0x0}, + { 0x21018c, 0x0}, + { 0x1108c, 0x0}, + { 0x11108c, 0x0}, + { 0x21108c, 0x0}, + { 0x1118c, 0x0}, + { 0x11118c, 0x0}, + { 0x21118c, 0x0}, + { 0x1208c, 0x0}, + { 0x11208c, 0x0}, + { 0x21208c, 0x0}, + { 0x1218c, 0x0}, + { 0x11218c, 0x0}, + { 0x21218c, 0x0}, + { 0x1308c, 0x0}, + { 0x11308c, 0x0}, + { 0x21308c, 0x0}, + { 0x1318c, 0x0}, + { 0x11318c, 0x0}, + { 0x21318c, 0x0}, + { 0x1008d, 0x0}, + { 0x11008d, 0x0}, + { 0x21008d, 0x0}, + { 0x1018d, 0x0}, + { 0x11018d, 0x0}, + { 0x21018d, 0x0}, + { 0x1108d, 0x0}, + { 0x11108d, 0x0}, + { 0x21108d, 0x0}, + { 0x1118d, 0x0}, + { 0x11118d, 0x0}, + { 0x21118d, 0x0}, + { 0x1208d, 0x0}, + { 0x11208d, 0x0}, + { 0x21208d, 0x0}, + { 0x1218d, 0x0}, + { 0x11218d, 0x0}, + { 0x21218d, 0x0}, + { 0x1308d, 0x0}, + { 0x11308d, 0x0}, + { 0x21308d, 0x0}, + { 0x1318d, 0x0}, + { 0x11318d, 0x0}, + { 0x21318d, 0x0}, + { 0x100c0, 0x0}, + { 0x1100c0, 0x0}, + { 0x2100c0, 0x0}, + { 0x101c0, 0x0}, + { 0x1101c0, 0x0}, + { 0x2101c0, 0x0}, + { 0x102c0, 0x0}, + { 0x1102c0, 0x0}, + { 0x2102c0, 0x0}, + { 0x103c0, 0x0}, + { 0x1103c0, 0x0}, + { 0x2103c0, 0x0}, + { 0x104c0, 0x0}, + { 0x1104c0, 0x0}, + { 0x2104c0, 0x0}, + { 0x105c0, 0x0}, + { 0x1105c0, 0x0}, + { 0x2105c0, 0x0}, + { 0x106c0, 0x0}, + { 0x1106c0, 0x0}, + { 0x2106c0, 0x0}, + { 0x107c0, 0x0}, + { 0x1107c0, 0x0}, + { 0x2107c0, 0x0}, + { 0x108c0, 0x0}, + { 0x1108c0, 0x0}, + { 0x2108c0, 0x0}, + { 0x110c0, 0x0}, + { 0x1110c0, 0x0}, + { 0x2110c0, 0x0}, + { 0x111c0, 0x0}, + { 0x1111c0, 0x0}, + { 0x2111c0, 0x0}, + { 0x112c0, 0x0}, + { 0x1112c0, 0x0}, + { 0x2112c0, 0x0}, + { 0x113c0, 0x0}, + { 0x1113c0, 0x0}, + { 0x2113c0, 0x0}, + { 0x114c0, 0x0}, + { 0x1114c0, 0x0}, + { 0x2114c0, 0x0}, + { 0x115c0, 0x0}, + { 0x1115c0, 0x0}, + { 0x2115c0, 0x0}, + { 0x116c0, 0x0}, + { 0x1116c0, 0x0}, + { 0x2116c0, 0x0}, + { 0x117c0, 0x0}, + { 0x1117c0, 0x0}, + { 0x2117c0, 0x0}, + { 0x118c0, 0x0}, + { 0x1118c0, 0x0}, + { 0x2118c0, 0x0}, + { 0x120c0, 0x0}, + { 0x1120c0, 0x0}, + { 0x2120c0, 0x0}, + { 0x121c0, 0x0}, + { 0x1121c0, 0x0}, + { 0x2121c0, 0x0}, + { 0x122c0, 0x0}, + { 0x1122c0, 0x0}, + { 0x2122c0, 0x0}, + { 0x123c0, 0x0}, + { 0x1123c0, 0x0}, + { 0x2123c0, 0x0}, + { 0x124c0, 0x0}, + { 0x1124c0, 0x0}, + { 0x2124c0, 0x0}, + { 0x125c0, 0x0}, + { 0x1125c0, 0x0}, + { 0x2125c0, 0x0}, + { 0x126c0, 0x0}, + { 0x1126c0, 0x0}, + { 0x2126c0, 0x0}, + { 0x127c0, 0x0}, + { 0x1127c0, 0x0}, + { 0x2127c0, 0x0}, + { 0x128c0, 0x0}, + { 0x1128c0, 0x0}, + { 0x2128c0, 0x0}, + { 0x130c0, 0x0}, + { 0x1130c0, 0x0}, + { 0x2130c0, 0x0}, + { 0x131c0, 0x0}, + { 0x1131c0, 0x0}, + { 0x2131c0, 0x0}, + { 0x132c0, 0x0}, + { 0x1132c0, 0x0}, + { 0x2132c0, 0x0}, + { 0x133c0, 0x0}, + { 0x1133c0, 0x0}, + { 0x2133c0, 0x0}, + { 0x134c0, 0x0}, + { 0x1134c0, 0x0}, + { 0x2134c0, 0x0}, + { 0x135c0, 0x0}, + { 0x1135c0, 0x0}, + { 0x2135c0, 0x0}, + { 0x136c0, 0x0}, + { 0x1136c0, 0x0}, + { 0x2136c0, 0x0}, + { 0x137c0, 0x0}, + { 0x1137c0, 0x0}, + { 0x2137c0, 0x0}, + { 0x138c0, 0x0}, + { 0x1138c0, 0x0}, + { 0x2138c0, 0x0}, + { 0x100c1, 0x0}, + { 0x1100c1, 0x0}, + { 0x2100c1, 0x0}, + { 0x101c1, 0x0}, + { 0x1101c1, 0x0}, + { 0x2101c1, 0x0}, + { 0x102c1, 0x0}, + { 0x1102c1, 0x0}, + { 0x2102c1, 0x0}, + { 0x103c1, 0x0}, + { 0x1103c1, 0x0}, + { 0x2103c1, 0x0}, + { 0x104c1, 0x0}, + { 0x1104c1, 0x0}, + { 0x2104c1, 0x0}, + { 0x105c1, 0x0}, + { 0x1105c1, 0x0}, + { 0x2105c1, 0x0}, + { 0x106c1, 0x0}, + { 0x1106c1, 0x0}, + { 0x2106c1, 0x0}, + { 0x107c1, 0x0}, + { 0x1107c1, 0x0}, + { 0x2107c1, 0x0}, + { 0x108c1, 0x0}, + { 0x1108c1, 0x0}, + { 0x2108c1, 0x0}, + { 0x110c1, 0x0}, + { 0x1110c1, 0x0}, + { 0x2110c1, 0x0}, + { 0x111c1, 0x0}, + { 0x1111c1, 0x0}, + { 0x2111c1, 0x0}, + { 0x112c1, 0x0}, + { 0x1112c1, 0x0}, + { 0x2112c1, 0x0}, + { 0x113c1, 0x0}, + { 0x1113c1, 0x0}, + { 0x2113c1, 0x0}, + { 0x114c1, 0x0}, + { 0x1114c1, 0x0}, + { 0x2114c1, 0x0}, + { 0x115c1, 0x0}, + { 0x1115c1, 0x0}, + { 0x2115c1, 0x0}, + { 0x116c1, 0x0}, + { 0x1116c1, 0x0}, + { 0x2116c1, 0x0}, + { 0x117c1, 0x0}, + { 0x1117c1, 0x0}, + { 0x2117c1, 0x0}, + { 0x118c1, 0x0}, + { 0x1118c1, 0x0}, + { 0x2118c1, 0x0}, + { 0x120c1, 0x0}, + { 0x1120c1, 0x0}, + { 0x2120c1, 0x0}, + { 0x121c1, 0x0}, + { 0x1121c1, 0x0}, + { 0x2121c1, 0x0}, + { 0x122c1, 0x0}, + { 0x1122c1, 0x0}, + { 0x2122c1, 0x0}, + { 0x123c1, 0x0}, + { 0x1123c1, 0x0}, + { 0x2123c1, 0x0}, + { 0x124c1, 0x0}, + { 0x1124c1, 0x0}, + { 0x2124c1, 0x0}, + { 0x125c1, 0x0}, + { 0x1125c1, 0x0}, + { 0x2125c1, 0x0}, + { 0x126c1, 0x0}, + { 0x1126c1, 0x0}, + { 0x2126c1, 0x0}, + { 0x127c1, 0x0}, + { 0x1127c1, 0x0}, + { 0x2127c1, 0x0}, + { 0x128c1, 0x0}, + { 0x1128c1, 0x0}, + { 0x2128c1, 0x0}, + { 0x130c1, 0x0}, + { 0x1130c1, 0x0}, + { 0x2130c1, 0x0}, + { 0x131c1, 0x0}, + { 0x1131c1, 0x0}, + { 0x2131c1, 0x0}, + { 0x132c1, 0x0}, + { 0x1132c1, 0x0}, + { 0x2132c1, 0x0}, + { 0x133c1, 0x0}, + { 0x1133c1, 0x0}, + { 0x2133c1, 0x0}, + { 0x134c1, 0x0}, + { 0x1134c1, 0x0}, + { 0x2134c1, 0x0}, + { 0x135c1, 0x0}, + { 0x1135c1, 0x0}, + { 0x2135c1, 0x0}, + { 0x136c1, 0x0}, + { 0x1136c1, 0x0}, + { 0x2136c1, 0x0}, + { 0x137c1, 0x0}, + { 0x1137c1, 0x0}, + { 0x2137c1, 0x0}, + { 0x138c1, 0x0}, + { 0x1138c1, 0x0}, + { 0x2138c1, 0x0}, + { 0x10020, 0x0}, + { 0x110020, 0x0}, + { 0x210020, 0x0}, + { 0x11020, 0x0}, + { 0x111020, 0x0}, + { 0x211020, 0x0}, + { 0x12020, 0x0}, + { 0x112020, 0x0}, + { 0x212020, 0x0}, + { 0x13020, 0x0}, + { 0x113020, 0x0}, + { 0x213020, 0x0}, + { 0x20072, 0x0}, + { 0x20073, 0x0}, + { 0x20074, 0x0}, + { 0x100aa, 0x0}, + { 0x110aa, 0x0}, + { 0x120aa, 0x0}, + { 0x130aa, 0x0}, + { 0x20010, 0x0}, + { 0x120010, 0x0}, + { 0x220010, 0x0}, + { 0x20011, 0x0}, + { 0x120011, 0x0}, + { 0x220011, 0x0}, + { 0x100ae, 0x0}, + { 0x1100ae, 0x0}, + { 0x2100ae, 0x0}, + { 0x100af, 0x0}, + { 0x1100af, 0x0}, + { 0x2100af, 0x0}, + { 0x110ae, 0x0}, + { 0x1110ae, 0x0}, + { 0x2110ae, 0x0}, + { 0x110af, 0x0}, + { 0x1110af, 0x0}, + { 0x2110af, 0x0}, + { 0x120ae, 0x0}, + { 0x1120ae, 0x0}, + { 0x2120ae, 0x0}, + { 0x120af, 0x0}, + { 0x1120af, 0x0}, + { 0x2120af, 0x0}, + { 0x130ae, 0x0}, + { 0x1130ae, 0x0}, + { 0x2130ae, 0x0}, + { 0x130af, 0x0}, + { 0x1130af, 0x0}, + { 0x2130af, 0x0}, + { 0x20020, 0x0}, + { 0x120020, 0x0}, + { 0x220020, 0x0}, + { 0x100a0, 0x0}, + { 0x100a1, 0x0}, + { 0x100a2, 0x0}, + { 0x100a3, 0x0}, + { 0x100a4, 0x0}, + { 0x100a5, 0x0}, + { 0x100a6, 0x0}, + { 0x100a7, 0x0}, + { 0x110a0, 0x0}, + { 0x110a1, 0x0}, + { 0x110a2, 0x0}, + { 0x110a3, 0x0}, + { 0x110a4, 0x0}, + { 0x110a5, 0x0}, + { 0x110a6, 0x0}, + { 0x110a7, 0x0}, + { 0x120a0, 0x0}, + { 0x120a1, 0x0}, + { 0x120a2, 0x0}, + { 0x120a3, 0x0}, + { 0x120a4, 0x0}, + { 0x120a5, 0x0}, + { 0x120a6, 0x0}, + { 0x120a7, 0x0}, + { 0x130a0, 0x0}, + { 0x130a1, 0x0}, + { 0x130a2, 0x0}, + { 0x130a3, 0x0}, + { 0x130a4, 0x0}, + { 0x130a5, 0x0}, + { 0x130a6, 0x0}, + { 0x130a7, 0x0}, + { 0x2007c, 0x0}, + { 0x12007c, 0x0}, + { 0x22007c, 0x0}, + { 0x2007d, 0x0}, + { 0x12007d, 0x0}, + { 0x22007d, 0x0}, + { 0x400fd, 0x0}, + { 0x400c0, 0x0}, + { 0x90201, 0x0}, + { 0x190201, 0x0}, + { 0x290201, 0x0}, + { 0x90202, 0x0}, + { 0x190202, 0x0}, + { 0x290202, 0x0}, + { 0x90203, 0x0}, + { 0x190203, 0x0}, + { 0x290203, 0x0}, + { 0x90204, 0x0}, + { 0x190204, 0x0}, + { 0x290204, 0x0}, + { 0x90205, 0x0}, + { 0x190205, 0x0}, + { 0x290205, 0x0}, + { 0x90206, 0x0}, + { 0x190206, 0x0}, + { 0x290206, 0x0}, + { 0x90207, 0x0}, + { 0x190207, 0x0}, + { 0x290207, 0x0}, + { 0x90208, 0x0}, + { 0x190208, 0x0}, + { 0x290208, 0x0}, + { 0x10062, 0x0}, + { 0x10162, 0x0}, + { 0x10262, 0x0}, + { 0x10362, 0x0}, + { 0x10462, 0x0}, + { 0x10562, 0x0}, + { 0x10662, 0x0}, + { 0x10762, 0x0}, + { 0x10862, 0x0}, + { 0x11062, 0x0}, + { 0x11162, 0x0}, + { 0x11262, 0x0}, + { 0x11362, 0x0}, + { 0x11462, 0x0}, + { 0x11562, 0x0}, + { 0x11662, 0x0}, + { 0x11762, 0x0}, + { 0x11862, 0x0}, + { 0x12062, 0x0}, + { 0x12162, 0x0}, + { 0x12262, 0x0}, + { 0x12362, 0x0}, + { 0x12462, 0x0}, + { 0x12562, 0x0}, + { 0x12662, 0x0}, + { 0x12762, 0x0}, + { 0x12862, 0x0}, + { 0x13062, 0x0}, + { 0x13162, 0x0}, + { 0x13262, 0x0}, + { 0x13362, 0x0}, + { 0x13462, 0x0}, + { 0x13562, 0x0}, + { 0x13662, 0x0}, + { 0x13762, 0x0}, + { 0x13862, 0x0}, + { 0x20077, 0x0}, + { 0x10001, 0x0}, + { 0x11001, 0x0}, + { 0x12001, 0x0}, + { 0x13001, 0x0}, + { 0x10040, 0x0}, + { 0x10140, 0x0}, + { 0x10240, 0x0}, + { 0x10340, 0x0}, + { 0x10440, 0x0}, + { 0x10540, 0x0}, + { 0x10640, 0x0}, + { 0x10740, 0x0}, + { 0x10840, 0x0}, + { 0x10030, 0x0}, + { 0x10130, 0x0}, + { 0x10230, 0x0}, + { 0x10330, 0x0}, + { 0x10430, 0x0}, + { 0x10530, 0x0}, + { 0x10630, 0x0}, + { 0x10730, 0x0}, + { 0x10830, 0x0}, + { 0x11040, 0x0}, + { 0x11140, 0x0}, + { 0x11240, 0x0}, + { 0x11340, 0x0}, + { 0x11440, 0x0}, + { 0x11540, 0x0}, + { 0x11640, 0x0}, + { 0x11740, 0x0}, + { 0x11840, 0x0}, + { 0x11030, 0x0}, + { 0x11130, 0x0}, + { 0x11230, 0x0}, + { 0x11330, 0x0}, + { 0x11430, 0x0}, + { 0x11530, 0x0}, + { 0x11630, 0x0}, + { 0x11730, 0x0}, + { 0x11830, 0x0}, + { 0x12040, 0x0}, + { 0x12140, 0x0}, + { 0x12240, 0x0}, + { 0x12340, 0x0}, + { 0x12440, 0x0}, + { 0x12540, 0x0}, + { 0x12640, 0x0}, + { 0x12740, 0x0}, + { 0x12840, 0x0}, + { 0x12030, 0x0}, + { 0x12130, 0x0}, + { 0x12230, 0x0}, + { 0x12330, 0x0}, + { 0x12430, 0x0}, + { 0x12530, 0x0}, + { 0x12630, 0x0}, + { 0x12730, 0x0}, + { 0x12830, 0x0}, + { 0x13040, 0x0}, + { 0x13140, 0x0}, + { 0x13240, 0x0}, + { 0x13340, 0x0}, + { 0x13440, 0x0}, + { 0x13540, 0x0}, + { 0x13640, 0x0}, + { 0x13740, 0x0}, + { 0x13840, 0x0}, + { 0x13030, 0x0}, + { 0x13130, 0x0}, + { 0x13230, 0x0}, + { 0x13330, 0x0}, + { 0x13430, 0x0}, + { 0x13530, 0x0}, + { 0x13630, 0x0}, + { 0x13730, 0x0}, + { 0x13830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x5d}, + {0x2000c, 0xbb}, + {0x2000d, 0x753}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info ucm_dram_timing_ff020008 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c new file mode 100644 index 0000000000..1f18ccd959 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2020 Linaro + */ + +#include <common.h> +#include <env.h> +#include <init.h> +#include <miiphy.h> +#include <netdev.h> + +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if IS_ENABLED(CONFIG_FEC_MXC) +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], 0x2000, 0); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_FEC_MXC)) + setup_fec(); + + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { + env_set("board_name", "IOT-GATE-IMX8"); + env_set("board_rev", "SBC-IOTMX8"); + } + + return 0; +} diff --git a/board/compulab/imx8mm-cl-iot-gate/spl.c b/board/compulab/imx8mm-cl-iot-gate/spl.c new file mode 100644 index 0000000000..8f592457d4 --- /dev/null +++ b/board/compulab/imx8mm-cl-iot-gate/spl.c @@ -0,0 +1,187 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * Copyright 2020 Linaro + */ + +#include <common.h> +#include <command.h> +#include <cpu_func.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/mach-imx/gpio.h> +#include <asm/arch/ddr.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +#include <power/pmic.h> +#include <power/bd71837.h> + +#include "ddr/ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + switch (boot_dev_spl) { + case SD2_BOOT: + case MMC2_BOOT: + return BOOT_DEVICE_MMC1; + case SD3_BOOT: + case MMC3_BOOT: + return BOOT_DEVICE_MMC2; + default: + return BOOT_DEVICE_NONE; + } +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MM_PAD_I2C2_SCL_I2C2_SCL | PC, + .gpio_mode = IMX8MM_PAD_I2C2_SCL_GPIO5_IO16 | PC, + .gp = IMX_GPIO_NR(5, 16), + }, + .sda = { + .i2c_mode = IMX8MM_PAD_I2C2_SDA_I2C2_SDA | PC, + .gpio_mode = IMX8MM_PAD_I2C2_SDA_GPIO5_IO17 | PC, + .gp = IMX_GPIO_NR(5, 17), + }, +}; + +static void spl_dram_init(void) +{ + spl_dram_init_compulab(); +} + +void spl_board_init(void) +{ + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +static int power_init_board(void) +{ + struct udevice *dev; + int ret; + + ret = pmic_get("pmic@4b", &dev); + if (ret == -ENODEV) { + puts("No pmic\n"); + return 0; + } + if (ret != 0) + return ret; + + /* decrease RESET key long push time from the default 10s to 10ms */ + pmic_reg_write(dev, BD718XX_PWRONCONFIG1, 0x0); + + /* unlock the PMIC regs */ + pmic_reg_write(dev, BD718XX_REGLOCK, 0x1); + + /* increase VDD_SOC to typical value 0.85v before first DRAM access */ + pmic_reg_write(dev, BD718XX_BUCK1_VOLT_RUN, 0x0f); + + /* increase VDD_DRAM to 0.975v for 3Ghz DDR */ + pmic_reg_write(dev, BD718XX_1ST_NODVS_BUCK_VOLT, 0x83); + + /* increase NVCC_DRAM_1V2 to 1.2v for DDR4 */ + pmic_reg_write(dev, BD718XX_4TH_NODVS_BUCK_VOLT, 0x28); + + /* lock the PMIC regs */ + pmic_reg_write(dev, BD718XX_REGLOCK, 0x11); + + return 0; +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + arch_cpu_init(); + + board_early_init_f(); + + init_uart_clk(2); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) { + printf("Failed to find clock node. Check device tree\n"); + hang(); + } + + enable_tzc380(); + + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig new file mode 100644 index 0000000000..319d72497d --- /dev/null +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -0,0 +1,130 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x4400 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_CL_IOT_GATE=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-cl-iot-gate" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_BIND=y +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x44000000 +CONFIG_FASTBOOT_BUF_SIZE=0x5000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_DM_SPI_FLASH=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PCI_ENDPOINT=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_BD71837=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x40400000 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_IMX_WATCHDOG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_SECURE_BOOT=y diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h new file mode 100644 index 0000000000..3ebddff89b --- /dev/null +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -0,0 +1,190 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __IMX8MM_CL_IOT_GATE_H +#define __IMX8MM_CL_IOT_GATE_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> +#include <config_distro_bootcmd.h> + +#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x920000 +#define CONFIG_SPL_BSS_START_ADDR 0x910000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x912000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#endif + +#if CONFIG_IS_ENABLED(CMD_MMC) +# define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 2) \ + func(MMC, mmc, 0) +#else +# define BOOT_TARGET_MMC(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_USB) +# define BOOT_TARGET_USB(func) func(USB, usb, 0) +#else +# define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_PXE) +# define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else +# define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) +# define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else +# define BOOT_TARGET_DHCP(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "script=boot.scr\0" \ + "image=Image\0" \ + "console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "boot_fit=no\0" \ + "fdt_file=sb-iotgimx8.dtb\0" \ + "fdtfile=sb-iotgimx8.dtb\0" \ + "initrd_addr=0x43800000\0" \ + "bootm_size=0x10000000\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console} root=${mmcroot}\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "kernel_addr_r=0x40480000\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;\0" + +#ifndef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "fi;" +#endif + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN SZ_32M + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ + +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* USDHC */ +#define CONFIG_FSL_USDHC + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define FEC_QUIRK_ENET_MAC + +#define IMX_FEC_BASE 0x30BE0000 + +/* USB */ +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) + +#endif
Peter Robinson
Ying-Chun Liu
