[U-Boot] [PATCH v2 1/2] MX28: mx28evk: Align SSP clock speed
Align the SSP clock speed with oscilator to achieve higher transfer stability.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - reword commit log to match the change description done on m28evk.
board/freescale/mx28evk/mx28evk.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index 867d3c8..d782aea 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -49,8 +49,8 @@ int board_early_init_f(void)
/* SSP0 clock at 96MHz */ mx28_set_sspclk(MXC_SSPCLK0, 96000, 0); - /* SSP2 clock at 96MHz */ - mx28_set_sspclk(MXC_SSPCLK2, 96000, 0); + /* SSP2 clock at 160MHz */ + mx28_set_sspclk(MXC_SSPCLK2, 160000, 0);
#ifdef CONFIG_CMD_USB mxs_iomux_setup_pad(MX28_PAD_SSP2_SS1__USB1_OVERCURRENT);
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - new patch
include/configs/mx28evk.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 8d83495..a5a98fb 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -200,6 +200,7 @@ #ifdef CONFIG_CMD_SPI #define CONFIG_HARD_SPI #define CONFIG_MXS_SPI +#define CONFIG_MXS_SPI_DMA_ENABLE #define CONFIG_SPI_HALF_DUPLEX #define CONFIG_DEFAULT_SPI_BUS 2 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Dear Otavio Salvador,
This change is still pointless, unless you have user for this!
Changes in v2:
- /* SSP2 clock at 160MHz */
- mx28_set_sspclk(MXC_SSPCLK2, 160000, 0);
Best regards, Marek Vasut
As far as I know the SPI flash uses SSP2; so it is a user of it.
Changes in v2:
So, why dont you also align the default clockspeed of the spi flash attached to ssp2 in the config file within this patch?
Lemme answer myself after taking a look ... because that's already done.
Ok,
Acked-by: Marek Vasut marex@denx.de
Changes in v2:
Otavio Salvador
Stefano Babic
