[U-Boot] [PATCH] igep00x0: Do not include config_distro_defaults.h directly
File is already included: omap3_igep00x0.h -> ti_omap3_common.h -> ti_armv7_omap.h -> ti_armv7_common.h -> config_distro_defaults.h
Signed-off-by: Ladislav Michl ladis@linux-mips.org --- include/configs/omap3_igep00x0.h | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index cf2bc3e..a64b38f 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -43,7 +43,7 @@ #else #error "status LED not defined for this machine." #endif -#define RED_LED_DEV 0 +#define RED_LED_DEV 0 #define STATUS_LED_BIT RED_LED_GPIO #define STATUS_LED_STATE STATUS_LED_ON #define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) @@ -56,7 +56,7 @@ #define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO bank 6 */
/* USB */ -#define CONFIG_USB_MUSB_UDC 1 +#define CONFIG_USB_MUSB_UDC 1 #define CONFIG_USB_OMAP3 1 #define CONFIG_TWL4030_USB 1
@@ -81,12 +81,8 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
-/*#undef CONFIG_ENV_IS_NOWHERE*/ - #ifndef CONFIG_SPL_BUILD
-#include <config_distro_defaults.h> - /* Environment */ #define ENV_DEVICE_SETTINGS \ "stdin=serial\0" \ @@ -138,7 +134,7 @@ #if defined(CONFIG_CMD_NET) #define CONFIG_SMC911X #define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 +#define CONFIG_SMC911X_BASE 0x2C000000 #endif /* (CONFIG_CMD_NET) */
/* OneNAND boot config */
Hi Ladislav,
Thanks for the patch, some comments below
2015-12-30 2:50 GMT+01:00 Ladislav Michl ladis@linux-mips.org:
any reason for this change ?
and this ?
and this ?
again, any reason for this change?
2.1.4
Also, can you send this patch and the other patch (igep00x0: cleanup ethernet support) as numbered patch series?
Thanks,
Enric
Hi Enric Balletbo,
On Wed, Dec 30, 2015 at 10:34:28PM +0100, Enric Balletbo Serra wrote: [indentation changes snipped]
I'm sure you know there is no other reason, but to indent constants to the same column with others. I did that in one patch as it is also no-op change and I was lazy to split it to separate patch. All that igep00x0 patches are just side-products of an effort to use UBI volumes for everything: U-Boot, its environment, kernel and filesystem.
Sure, but could you take a look or even give a try to that second half of patches? These makes things much more interesting..
Thanks,
Enric
ladis
Ladislav Michl
