[PATCH v1 0/3] Risc-V cache operations
This patchset adds support for using the CBO instructions to perform the dcache flush/inval operations for the qemu-riscv board when those are enabled. The CBO instructions are defined in the Risc-V CMO specification which can be found at the link below: https://github.com/riscv/riscv-CMOs/blob/master/specifications/cmobase-v1.0....
Mayuresh Chitale (3): riscv: Add support for defining instructions riscv: cache: Add CBO instructions board: qemu-riscv: Override enable_caches
arch/riscv/Kconfig | 4 ++ arch/riscv/include/asm/cache.h | 3 + arch/riscv/include/asm/insn-def.h | 42 ++++++++++++ arch/riscv/lib/cache.c | 90 +++++++++++++++++++++++++ board/emulation/qemu-riscv/qemu-riscv.c | 16 +++++ 5 files changed, 155 insertions(+) create mode 100644 arch/riscv/include/asm/insn-def.h
Add insn-def.h which is similar to that in linux and contains the macros to generate any instruction of type 'I' using the assembler's .insn directive.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- arch/riscv/include/asm/insn-def.h | 42 +++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+) create mode 100644 arch/riscv/include/asm/insn-def.h
diff --git a/arch/riscv/include/asm/insn-def.h b/arch/riscv/include/asm/insn-def.h new file mode 100644 index 0000000000..99ad5b8f6a --- /dev/null +++ b/arch/riscv/include/asm/insn-def.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Ventana Micro Systems Ltd. + * + * Ported from linux insn-def.h. + */ + +#ifndef _ASM_RISCV_BARRIER_H +#define _ASM_RISCV_BARRIER_H + +#define INSN_I_SIMM12_SHIFT 20 +#define INSN_I_RS1_SHIFT 15 +#define INSN_I_FUNC3_SHIFT 12 +#define INSN_I_RD_SHIFT 7 +#define INSN_I_OPCODE_SHIFT 0 + +#define RV_OPCODE(v) __ASM_STR(v) +#define RV_FUNC3(v) __ASM_STR(v) +#define RV_FUNC7(v) __ASM_STR(v) +#define RV_SIMM12(v) __ASM_STR(v) +#define RV_RD(v) __ASM_STR(v) +#define RV_RS1(v) __ASM_STR(v) +#define RV_RS2(v) __ASM_STR(v) +#define __RV_REG(v) __ASM_STR(x ## v) +#define RV___RD(v) __RV_REG(v) +#define RV___RS1(v) __RV_REG(v) +#define RV___RS2(v) __RV_REG(v) + +#define RV_OPCODE_MISC_MEM RV_OPCODE(15) +#define RV_OPCODE_SYSTEM RV_OPCODE(115) + +#define RV_OPCODE_MISC_MEM RV_OPCODE(15) +#define RV_OPCODE_SYSTEM RV_OPCODE(115) + +#define __INSN_I(opcode, func3, rd, rs1, simm12) \ + ".insn i " opcode ", " func3 ", " rd ", " rs1 ", " simm12 "\n" + +#define INSN_I(opcode, func3, rd, rs1, simm12) \ + __INSN_I(RV_##opcode, RV_##func3, RV_##rd, \ + RV_##rs1, RV_##simm12) + +#endif /* _ASM_RISCV_BARRIER_H */
Define CBO inval and flush instructions and use those for the dcache inval and flush operations respectively.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- arch/riscv/Kconfig | 4 ++ arch/riscv/include/asm/cache.h | 3 ++ arch/riscv/lib/cache.c | 90 ++++++++++++++++++++++++++++++++++ 3 files changed, 97 insertions(+)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fa3b016c52..0f89d07be7 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -310,6 +310,10 @@ endmenu config RISCV_ISA_A def_bool y
+config RISCV_ISA_ZICBOM + bool "Zicbom support" + depends on !SYS_DISABLE_DCACHE_OPS + config DMA_ADDR_T_64BIT bool default y if 64BIT diff --git a/arch/riscv/include/asm/cache.h b/arch/riscv/include/asm/cache.h index 874963d731..42dbce5b4f 100644 --- a/arch/riscv/include/asm/cache.h +++ b/arch/riscv/include/asm/cache.h @@ -9,6 +9,9 @@
/* cache */ void cache_flush(void); +void riscv_zicbom_init(void); +void cbo_flush(unsigned long start, unsigned long end); +void cbo_inval(unsigned long start, unsigned long end);
/* * The current upper bound for RISCV L1 data cache line sizes is 32 bytes. diff --git a/arch/riscv/lib/cache.c b/arch/riscv/lib/cache.c index afad7e117f..456353d9c1 100644 --- a/arch/riscv/lib/cache.c +++ b/arch/riscv/lib/cache.c @@ -5,6 +5,95 @@ */
#include <cpu_func.h> +#include <dm.h> +#include <asm/insn-def.h> +#include <linux/const.h> + +#define CBO_INVAL(base) \ + INSN_I(OPCODE_MISC_MEM, FUNC3(2), __RD(0), \ + RS1(base), SIMM12(0)) +#define CBO_CLEAN(base) \ + INSN_I(OPCODE_MISC_MEM, FUNC3(2), __RD(0), \ + RS1(base), SIMM12(1)) +#define CBO_FLUSH(base) \ + INSN_I(OPCODE_MISC_MEM, FUNC3(2), __RD(0), \ + RS1(base), SIMM12(2)) +enum { + CBO_CLEAN, + CBO_FLUSH, + CBO_INVAL +} riscv_cbo_ops; +static int zicbom_block_size; + +static inline void do_cbo_clean(unsigned long base) +{ + asm volatile ("add a0, %0, zero\n" CBO_CLEAN(%0) :: + "r"(base) : "memory"); +} + +static inline void do_cbo_flush(unsigned long base) +{ + asm volatile ("add a0, %0, zero\n" CBO_FLUSH(%0) :: + "r"(base) : "memory"); +} + +static inline void do_cbo_inval(unsigned long base) +{ + asm volatile ("add a0, %0, zero\n" CBO_INVAL(%0) :: + "r"(base) : "memory"); +} + +static void cbo_op(int op_type, unsigned long start, + unsigned long end) +{ + unsigned long op_size = end - start, size = 0; + void (*fn)(unsigned long base); + + switch (op_type) { + case CBO_CLEAN: + fn = do_cbo_clean; + break; + case CBO_FLUSH: + fn = do_cbo_flush; + break; + case CBO_INVAL: + fn = do_cbo_inval; + break; + } + start &= ~(UL(zicbom_block_size - 1)); + while (size < op_size) { + fn(start + size); + size += zicbom_block_size; + } +} + +void cbo_flush(unsigned long start, unsigned long end) +{ + if (zicbom_block_size) + cbo_op(CBO_FLUSH, start, end); +} + +void cbo_inval(unsigned long start, unsigned long end) +{ + if (zicbom_block_size) + cbo_op(CBO_INVAL, start, end); +} + +void riscv_zicbom_init(void) +{ + struct udevice *dev; + + if (!CONFIG_IS_ENABLED(RISCV_ISA_ZICBOM)) + return; + + uclass_first_device(UCLASS_CPU, &dev); + if (!dev) { + log_err("Failed to get cpu device!\n"); + return; + } + + (void)dev_read_u32(dev, "riscv,cbom-block-size", &zicbom_block_size); +}
void invalidate_icache_all(void) { @@ -72,4 +161,5 @@ __weak int dcache_status(void)
__weak void enable_caches(void) { + puts("WARNING: Caches not enabled\n"); }
- bool "Zicbom support"
- depends on !SYS_DISABLE_DCACHE_OPS
- config DMA_ADDR_T_64BIT bool default y if 64BIT
- The current upper bound for RISCV L1 data cache line sizes is 32 bytes.
- INSN_I(OPCODE_MISC_MEM, FUNC3(2), __RD(0), \
+enum {
- CBO_CLEAN,
- CBO_FLUSH,
- CBO_INVAL
- asm volatile ("add a0, %0, zero\n" CBO_CLEAN(%0) ::
- asm volatile ("add a0, %0, zero\n" CBO_FLUSH(%0) ::
- asm volatile ("add a0, %0, zero\n" CBO_INVAL(%0) ::
unsigned long end)
- unsigned long op_size = end - start, size = 0;
- void (*fn)(unsigned long base);
- switch (op_type) {
- case CBO_CLEAN:
fn = do_cbo_clean;
break;
- case CBO_FLUSH:
fn = do_cbo_flush;
break;
- case CBO_INVAL:
fn = do_cbo_inval;
break;
- start &= ~(UL(zicbom_block_size - 1));
- while (size < op_size) {
fn(start + size);
- if (zicbom_block_size)
- struct udevice *dev;
- if (!CONFIG_IS_ENABLED(RISCV_ISA_ZICBOM))
return;
- uclass_first_device(UCLASS_CPU, &dev);
- if (!dev) {
return;
Please, return an error code.
- (void)dev_read_u32(dev, "riscv,cbom-block-size", &zicbom_block_size);
Please, do not ignore errors.
Best regards
Heinrich
- puts("WARNING: Caches not enabled\n"); }
On Tue, Aug 20, 2024 at 5:49 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
+enum {
CBO_CLEAN,
CBO_FLUSH,
CBO_INVAL
unsigned long end)
switch (op_type) {
case CBO_CLEAN:
fn = do_cbo_clean;
break;
case CBO_FLUSH:
fn = do_cbo_flush;
break;
case CBO_INVAL:
fn = do_cbo_inval;
break;
fn(start + size);
return;
if (!dev) {
return;
Ok.
Best regards
Heinrich
}puts("WARNING: Caches not enabled\n");
return;
- if (!dev) {
return;
I'm curious what the policy of U-Boot is w.r.t. extension probing. Is it okay to enable the option for Zicbom even if your hardware does not support it, in which case riscv_zicbom_init() would be expected to fail gracefully and no CMOs done? Say, for example, you had two very similar chips, one with DMA non-coherent peripherals and one that only differed by having DMA coherent ones, and you wanted to run the same U-Boot binary on both devices using a devicetree passed from firmware.
return;
- if (!dev) {
return;
To be clear, I did notice that if the dev_read_u32() does not populate zicbom_block_size no cache ops will be done. My question was about the behaviour relating to the config option and or emitting warnings etc.
Cheers, Conor.
return;
- if (!dev) {
return;
I am planning to add a info message if the config option is enabled but the dt property is not found.
Cheers, Conor.
On Wed, Aug 21, 2024 at 3:28 PM Conor Dooley conor.dooley@microchip.com wrote:
return;
- if (!dev) {
return;
I think in such a case the config option can always be enabled with the proper dt being passed by the firmware.
return;
- if (!dev) {
return;
I don't understand what you mean, sorry. Both cases I mention would have a "proper" devicetree that matches the hardware. I'm interested in whether or not U-Boot's maintainers think that enabling the config option should warn on, or preclude use of, systems that do not not support Zicbom.
Cheers, Conor.
Also, technically there's no guarantee that "riscv,cbom-block-size" being present means that zicbom also is. Realistically, it should never be the case that it is present without zicbom in the isa string representation, but correctness would require checking that it is. supports_extension() only supports single-letter extensions at present, making it support multi-letter extensions should not be too difficult.
Define enable_caches function for the qemu-riscv board which probes for the cbom-block-size dt property when RISCV_ISA_ZICBOM is enabled. Also add flush_dcache_range and invalidate_dcache_range functions which use the corresponding CBO ops.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- board/emulation/qemu-riscv/qemu-riscv.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/board/emulation/qemu-riscv/qemu-riscv.c b/board/emulation/qemu-riscv/qemu-riscv.c index e5193e31e3..1795d2f831 100644 --- a/board/emulation/qemu-riscv/qemu-riscv.c +++ b/board/emulation/qemu-riscv/qemu-riscv.c @@ -14,6 +14,7 @@ #include <usb.h> #include <virtio_types.h> #include <virtio.h> +#include <asm/cache.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -70,3 +71,18 @@ void *board_fdt_blob_setup(int *err) /* Stored the DTB address there during our init */ return (void *)(ulong)gd->arch.firmware_fdt_addr; } + +void enable_caches(void) +{ + riscv_zicbom_init(); +} + +void flush_dcache_range(unsigned long start, unsigned long end) +{ + cbo_flush(start, end); +} + +void invalidate_dcache_range(unsigned long start, unsigned long end) +{ + cbo_inval(start, end); +}
- riscv_zicbom_init();
Enable caches may be called multiple times. But riscv_zicbom_init() only needs to be called once.
- cbo_flush(start, end);
- cbo_inval(start, end);
The ZICBOM extension is not specific to a single board. We should not add this code to board files but into the central place for cache operations, i.e. arch/riscv/lib/cache.c.
E.g.
static int get_zicbom_block_size() { if (!CONFIG_IS_ENABLED(RISCV_ISA_ZICBOM)) return 0; if (zicbom_block_size) return zicbom_block_size;
uclass_first_device(UCLASS_CPU, &dev); if (!dev) { log_err("Failed to get CPU device!\n"); return 0; }
if (dev_read_u32(dev, "riscv,cbom-block-size", &zicbom_block_size)) return 0; return zicbom_block_size }
__weak void invalidate_icache_range(unsigned long start, unsigned long end) { if (CONFIG_IS_ENABLED(RISCV_ISA_ZICBOM) && get_zicbom_block_size()) cbo_inval(start, end); else invalidate_icache_all(); }
Cc: Rick as one of the RISC-V maintainers.
Best regards
Heinrich
Hi Heinrich,
On Tue, Aug 20, 2024 at 5:43 PM Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Ok.
Most of the code is already cache.c. I didn't know if it would suffice for all platforms so I decided to override the weak functions like in ARM.
E.g.
uclass_first_device(UCLASS_CPU, &dev); if (!dev) { log_err("Failed to get CPU device!\n"); return 0; } if (dev_read_u32(dev, "riscv,cbom-block-size", &zicbom_block_size)) return 0; return zicbom_block_size
Ok.
Best regards
Heinrich
On 21.08.24 11:11, Mayuresh Chitale wrote:
Hi Heinrich,
Ok.
With the suggestion below boards needing a board specific solution can still override the weak functions. But I would expect that in future new boards converge on zicbom.
Best regards
Heinrich
E.g.
Ok.
Best regards
Heinrich
participants (6)
Conor Dooley
Conor Dooley
Mayuresh Chitale
