[U-Boot] [PATCH] driver/ddr/fsl: Add workaround for A009663
Erratum A-009663 workaround requires to set DDR_INTERVAL[BSTOPRE] to 0 before setting DDR_SDRAM_CFG[MEM_EN] and set DDR_INTERVAL[BSTOPRE] to the desired value after DDR initialization has completed.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 3 +++ arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 2 ++ drivers/ddr/fsl/fsl_ddr_gen4.c | 10 ++++++++++ include/fsl_ddr_sdram.h | 1 + 6 files changed, 20 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 6e5224e..fac82ff 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -118,6 +118,8 @@ #define CONFIG_SYS_FSL_ERRATUM_A008585 #define CONFIG_SYS_FSL_ERRATUM_A008751 #define CONFIG_SYS_FSL_ERRATUM_A009635 +#define CONFIG_SYS_FSL_ERRATUM_A009663 + #elif defined(CONFIG_LS1043A) #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_CACHELINE_SIZE 64 @@ -165,6 +167,7 @@ /* Generic Interrupt Controller Definitions */ #define GICD_BASE 0x01401000 #define GICC_BASE 0x01402000 +#define CONFIG_SYS_FSL_ERRATUM_A009663
#else #error SoC not defined diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index f066480..424fe87 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -131,6 +131,7 @@ #define CONFIG_SYS_FSL_SEC_COMPAT 5 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_ERRATUM_A008378 +#define CONFIG_SYS_FSL_ERRATUM_A009663 #else #error SoC not defined #endif diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index a493556..3b06ae4 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -326,6 +326,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_SYS_FSL_B4860QDS_XFI_ERR) && defined(CONFIG_B4860QDS) puts("Work-around for Erratum XFI on B4860QDS enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A009663 + puts("Work-around for Erratum A009663 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 674fac8..eccc146 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -808,6 +808,7 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define QE_NUM_OF_SNUM 28 #define CONFIG_SYS_FSL_SFP_VER_3_0 #define CONFIG_SYS_FSL_ERRATUM_A008378 +#define CONFIG_SYS_FSL_ERRATUM_A009663
#elif defined(CONFIG_PPC_T1024) || defined(CONFIG_PPC_T1023) ||\ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) @@ -856,6 +857,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define QE_NUM_OF_SNUM 28 #define CONFIG_SYS_FSL_SFP_VER_3_0 #define CONFIG_SYS_FSL_ERRATUM_A008378 +#define CONFIG_SYS_FSL_ERRATUM_A009663
#elif defined(CONFIG_PPC_T2080) || defined(CONFIG_PPC_T2081) #define CONFIG_E6500 diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index 3fca5c2..6bd447d 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -151,7 +151,12 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->sdram_mode_15, regs->ddr_sdram_mode_15); ddr_out32(&ddr->sdram_mode_16, regs->ddr_sdram_mode_16); ddr_out32(&ddr->sdram_md_cntl, regs->ddr_sdram_md_cntl); +#ifdef CONFIG_SYS_FSL_ERRATUM_A009663 + ddr_out32(&ddr->sdram_interval, + regs->ddr_sdram_interval & ~SDRAM_INTERVAL_BSTOPRE); +#else ddr_out32(&ddr->sdram_interval, regs->ddr_sdram_interval); +#endif ddr_out32(&ddr->sdram_data_init, regs->ddr_data_init); ddr_out32(&ddr->ddr_wrlvl_cntl, regs->ddr_wrlvl_cntl); #ifndef CONFIG_SYS_FSL_DDR_EMU @@ -379,6 +384,11 @@ step2:
if (timeout <= 0) printf("Waiting for D_INIT timeout. Memory may not work.\n"); + +#ifdef CONFIG_SYS_FSL_ERRATUM_A009663 + ddr_out32(&ddr->sdram_interval, regs->ddr_sdram_interval); +#endif + #ifdef CONFIG_DEEP_SLEEP if (is_warm_boot()) { /* exit self-refresh */ diff --git a/include/fsl_ddr_sdram.h b/include/fsl_ddr_sdram.h index 4b022d4..504903d 100644 --- a/include/fsl_ddr_sdram.h +++ b/include/fsl_ddr_sdram.h @@ -131,6 +131,7 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; #define SDRAM_CFG2_ODT_ONLY_READ 2 #define SDRAM_CFG2_ODT_ALWAYS 3
+#define SDRAM_INTERVAL_BSTOPRE 0x3FFF #define TIMING_CFG_2_CPO_MASK 0x0F800000
#if defined(CONFIG_SYS_FSL_DDR_VER) && \
- puts("Work-around for Erratum A009663 enabled\n");
- ddr_out32(&ddr->sdram_interval,
Please add some comment to explain when BSTOPRE is zero (auto), this workaround is not needed. So users understand why it has been working so far.
York
Shengzhou Liu
York Sun
