[PATCH] patman: use new --u-boot option with checkpath.pl
checkpatch.pl now supports a --u-boot option for U-Boot specific checks. Use that in patman to check the patch series.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
tools/patman/checkpatch.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/patman/checkpatch.py b/tools/patman/checkpatch.py index 795b519314..7f507154b8 100644 --- a/tools/patman/checkpatch.py +++ b/tools/patman/checkpatch.py @@ -64,7 +64,7 @@ def CheckPatch(fname, verbose=False): result.problems = [] chk = FindCheckPatch() item = {} - result.stdout = command.Output(chk, '--no-tree', fname, + result.stdout = command.Output(chk, '--no-tree', '--u-boot', fname, raise_on_error=False) #pipe = subprocess.Popen(cmd, stdout=subprocess.PIPE) #stdout, stderr = pipe.communicate()
Hi Daniel,
On Sat, 6 Jun 2020 at 15:31, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
- result.stdout = command.Output(chk, '--no-tree', '--u-boot', fname, raise_on_error=False)
Can we make this conditional on something? Maybe detecting a U-Boot tree? Patman is used for linux and Zephyr, for example.
-- 2.27.0
Hi Daniel,
On Sat, 6 Jun 2020 at 20:02, Simon Glass sjg@chromium.org wrote:
Hi Daniel,
Actually I just remembered that I was hoping we could just adjust the .checkpatch.conf file in the U-Boot directory to add the option. Would that work?
-- 2.27.0
Am 07.06.20 um 05:44 schrieb Simon Glass:
Hi Daniel,
Hi Daniel,
hm, missed that earlier but you already added that with commit b77df5980c3e24e34e0db3a52c5bce396a81c430. Then you can ignore this patch ;)
Hi Daniel,
On Sun, 7 Jun 2020 at 08:15, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Hi Daniel,
Hi Daniel,
Ah OK. Does it work correctly for you?
Daniel Schwierzeck
