Please pull u-boot-dm/next into -next
Hi Tom,
https://gitlab.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/5567
Note this is for the 'next' tree.
It includes the rename series which would be good to get in early.
The following changes since commit ddaa94978583d07ec515e7226e397221d8cc44c8:
Merge tag 'efi-next' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi into next (2020-12-10 13:54:33 -0500)
git://git.denx.de/u-boot-dm.git tags/dm-pull-14dec20
for you to fetch changes up to b7bbd553de0d9752f919dfc616f560f6f2504c14:
checkpatch: Add warnings for unexpected struct names (2020-12-13 16:51:09 -0700)
---------------------------------------------------------------- Driver model tidy-up for livetree Driver model big rename for consistency Python 3 clean-ups for patman Update sandbox serial driver to use membuff
---------------------------------------------------------------- Heinrich Schuchardt (4): sandbox: add handler for exceptions cmd: sandbox: implement exception command efi_selftest: implement exception test for sandbox test: unit test for exception command
Simon Glass (28): fdt: Use an Enum for the data type patman: Drop unicode helper functions patman: Drop tools.ToByte() patman: Drop tools.ToChar() and ToChars() dtoc: Tidy up Python style in dtb_platdata serial: sandbox: Drop unnecessary #ifdefs sandbox: serial: Convert to livetree sandbox: serial: Update to use membuff dm: core: Rename device_bind() to device_bind_offset() dm: core: Rename device_bind_ofnode() to device_bind() dm: core: Add a livetree function to check node status dm: Remove uses of device_bind_offset() dm: Drop uses of dev_set_of_offset() dm: core: Drop dev_set_of_offset() dm: core: Drop device_bind_offset() dm: core: Add an ofnode function to get the devicetree root dm: core: Combine the flattree and livetree binding code dm: core: Drop unused parameter from dm_scan_fdt() dm: core: Drop unused parameter from dm_extended_scan_fdt() dtoc: Tidy up more Python style in dtb_platdata dm: treewide: Rename auto_alloc_size members to be shorter dm: treewide: Rename 'platdata' variables to just 'plat' dm: Rename 'platdata_size' to 'plat_size' dm: treewide: Rename dev_get_platdata() to dev_get_plat() dm: treewide: Rename ofdata_to_platdata() to of_to_plat() dm: treewide: Update 'auto' declarations to be on one line dm: treewide: Rename ..._platdata variables to just ..._plat checkpatch: Add warnings for unexpected struct names
arch/Kconfig | 1 + arch/arm/include/asm/arch-hi6220/gpio.h | 2 +- arch/arm/include/asm/arch-imx8/power-domain.h | 2 +- arch/arm/include/asm/arch-imx8m/power-domain.h | 2 +- arch/arm/include/asm/arch-vf610/gpio.h | 2 +- arch/arm/include/asm/omap_gpio.h | 2 +- arch/arm/include/asm/omap_i2c.h | 2 +- arch/arm/include/asm/omap_musb.h | 2 +- arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c | 2 +- arch/arm/mach-at91/arm926ejs/at91sam9m10g45_devices.c | 2 +- arch/arm/mach-at91/include/mach/atmel_serial.h | 2 +- arch/arm/mach-at91/include/mach/gpio.h | 2 +- arch/arm/mach-bcm283x/include/mach/gpio.h | 4 +- arch/arm/mach-imx/mx6/soc.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 2 +- arch/arm/mach-ipq40xx/clock-ipq4019.c | 2 +- arch/arm/mach-ipq40xx/pinctrl-snapdragon.c | 2 +- arch/arm/mach-lpc32xx/devices.c | 4 +- arch/arm/mach-nexell/include/mach/display.h | 4 +- arch/arm/mach-omap2/am33xx/board.c | 12 +-- arch/arm/mach-omap2/omap3/board.c | 2 +- arch/arm/mach-rockchip/px30/syscon_px30.c | 8 +- arch/arm/mach-rockchip/rk3188/syscon_rk3188.c | 8 +- arch/arm/mach-rockchip/rk3288/syscon_rk3288.c | 10 +-- arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 10 +-- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 12 +-- arch/arm/mach-rockchip/spl-boot-order.c | 4 +- arch/arm/mach-snapdragon/clock-snapdragon.c | 2 +- arch/arm/mach-snapdragon/pinctrl-snapdragon.c | 2 +- arch/arm/mach-stm32mp/bsec.c | 36 ++++---- arch/arm/mach-stm32mp/pwr_regulator.c | 18 ++-- arch/arm/mach-tegra/board.c | 2 +- arch/riscv/include/asm/arch-fu540/gpio.h | 2 +- arch/riscv/include/asm/arch-generic/gpio.h | 2 +- arch/sandbox/Kconfig | 9 ++ arch/sandbox/cpu/os.c | 40 +++++++++ arch/sandbox/cpu/start.c | 4 + arch/sandbox/lib/interrupts.c | 35 ++++++++ arch/x86/cpu/acpi_gpe.c | 6 +- arch/x86/cpu/apollolake/hostbridge.c | 16 ++-- arch/x86/cpu/apollolake/pmc.c | 14 +-- arch/x86/cpu/apollolake/spl.c | 8 +- arch/x86/cpu/apollolake/uart.c | 24 ++--- arch/x86/cpu/broadwell/adsp.c | 4 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/cpu/broadwell/sata.c | 14 +-- arch/x86/cpu/cpu_x86.c | 2 +- arch/x86/cpu/intel_common/itss.c | 12 +-- arch/x86/cpu/intel_common/p2sb.c | 17 ++-- arch/x86/cpu/irq.c | 2 +- arch/x86/cpu/mp_init.c | 4 +- arch/x86/cpu/qfw_cpu.c | 4 +- arch/x86/cpu/slimbootloader/serial.c | 10 +-- arch/x86/cpu/tangier/pinmux.c | 2 +- arch/x86/include/asm/arch-broadwell/gpio.h | 2 +- arch/x86/include/asm/gpio.h | 2 +- arch/x86/include/asm/intel_pinctrl.h | 7 +- arch/x86/lib/acpi_table.c | 2 +- arch/x86/lib/fsp/fsp_graphics.c | 4 +- arch/x86/lib/mpspec.c | 2 +- arch/x86/lib/pmu.c | 2 +- arch/x86/lib/scu.c | 2 +- arch/x86/lib/sfi.c | 2 +- board/armltd/integrator/integrator.c | 4 +- board/armltd/total_compute/total_compute.c | 4 +- board/armltd/vexpress64/vexpress64.c | 4 +- board/bluewater/gurnard/gurnard.c | 6 +- board/bluewater/snapper9260/snapper9260.c | 4 +- board/cadence/xtfpga/xtfpga.c | 2 +- board/cavium/thunderx/thunderx.c | 8 +- board/compulab/cm_fx6/cm_fx6.c | 4 +- board/davinci/da8xxevm/omapl138_lcdk.c | 8 +- board/freescale/ls1012afrdm/eth.c | 4 +- board/freescale/ls1012aqds/eth.c | 4 +- board/freescale/ls1012ardb/eth.c | 4 +- board/freescale/lx2160a/lx2160a.c | 8 +- board/gateworks/gw_ventana/gw_ventana.c | 4 +- board/hisilicon/hikey/hikey.c | 6 +- board/hisilicon/hikey960/hikey960.c | 4 +- board/hisilicon/poplar/poplar.c | 4 +- board/intel/galileo/galileo.c | 2 +- board/isee/igep00x0/igep00x0.c | 2 +- board/lg/sniper/sniper.c | 4 +- board/nokia/rx51/rx51.c | 2 +- board/renesas/ulcb/cpld.c | 2 +- board/siemens/corvus/board.c | 4 +- board/st/stv0991/stv0991.c | 4 +- board/sysam/amcore/amcore.c | 4 +- board/ti/am335x/board.c | 12 +-- board/timll/devkit8000/devkit8000.c | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 4 +- board/toradex/colibri-imx6ull/colibri-imx6ull.c | 4 +- board/toradex/colibri_imx6/colibri_imx6.c | 4 +- board/toradex/colibri_pxa270/colibri_pxa270.c | 8 +- cmd/Kconfig | 4 +- cmd/Makefile | 1 + cmd/button.c | 2 +- cmd/cpu.c | 2 +- cmd/demo.c | 4 +- cmd/host.c | 2 +- cmd/i2c.c | 4 +- cmd/led.c | 2 +- cmd/lsblk.c | 2 +- cmd/pci.c | 4 +- cmd/regulator.c | 50 +++++------ cmd/remoteproc.c | 2 +- cmd/sandbox/Makefile | 3 + cmd/sandbox/exception.c | 41 +++++++++ common/lcd_simplefb.c | 4 +- common/usb_hub.c | 6 +- common/usb_storage.c | 14 +-- doc/driver-model/debugging.rst | 2 +- doc/driver-model/design.rst | 104 ++++++++++----------- doc/driver-model/ethernet.rst | 12 +-- doc/driver-model/of-plat.rst | 40 ++++----- doc/driver-model/remoteproc-framework.rst | 2 +- doc/driver-model/spi-howto.rst | 32 +++---- doc/driver-model/usb-info.rst | 18 ++-- doc/imx/clk/ccf.txt | 2 +- drivers/adc/adc-uclass.c | 52 +++++------ drivers/adc/exynos-adc.c | 8 +- drivers/adc/meson-saradc.c | 8 +- drivers/adc/rockchip-saradc.c | 10 +-- drivers/adc/sandbox.c | 8 +- drivers/adc/stm32-adc-core.c | 2 +- drivers/adc/stm32-adc.c | 8 +- drivers/ata/ahci-uclass.c | 2 +- drivers/ata/ahci.c | 8 +- drivers/ata/dwc_ahci.c | 6 +- drivers/ata/dwc_ahsata.c | 6 +- drivers/ata/fsl_sata.c | 18 ++-- drivers/ata/mtk_ahci.c | 6 +- drivers/ata/sata_ceva.c | 6 +- drivers/ata/sata_mv.c | 46 +++++----- drivers/ata/sata_sil.c | 14 +-- drivers/axi/ihs_axi.c | 2 +- drivers/axi/sandbox_store.c | 2 +- drivers/block/blk-uclass.c | 28 +++--- drivers/block/ide.c | 6 +- drivers/block/sandbox.c | 14 +-- drivers/bootcount/bootcount.c | 2 +- drivers/bootcount/i2c-eeprom.c | 2 +- drivers/bootcount/rtc.c | 2 +- drivers/bootcount/spi-flash.c | 2 +- drivers/button/button-gpio.c | 6 +- drivers/button/button-uclass.c | 4 +- drivers/cache/cache-v5l2.c | 14 +-- drivers/clk/altera/clk-agilex.c | 54 +++++------ drivers/clk/altera/clk-arria10.c | 24 ++--- drivers/clk/aspeed/clk_ast2500.c | 6 +- drivers/clk/at91/compat.c | 86 +++++++++--------- drivers/clk/at91/sckc.c | 2 +- drivers/clk/clk-cdce9xx.c | 2 +- drivers/clk/clk-hsdk-cgu.c | 2 +- drivers/clk/clk-ti-sci.c | 2 +- drivers/clk/clk.c | 2 +- drivers/clk/clk_bcm6345.c | 2 +- drivers/clk/clk_boston.c | 10 +-- drivers/clk/clk_fixed_factor.c | 8 +- drivers/clk/clk_fixed_rate.c | 6 +- drivers/clk/clk_octeon.c | 2 +- drivers/clk/clk_pic32.c | 2 +- drivers/clk/clk_sandbox.c | 2 +- drivers/clk/clk_sandbox_test.c | 2 +- drivers/clk/clk_stm32f.c | 2 +- drivers/clk/clk_stm32h7.c | 2 +- drivers/clk/clk_stm32mp1.c | 2 +- drivers/clk/clk_versal.c | 2 +- drivers/clk/clk_vexpress_osc.c | 2 +- drivers/clk/clk_zynq.c | 2 +- drivers/clk/clk_zynqmp.c | 2 +- drivers/clk/exynos/clk-exynos7420.c | 4 +- drivers/clk/ics8n3qv01.c | 2 +- drivers/clk/mediatek/clk-mt7622.c | 16 ++-- drivers/clk/mediatek/clk-mt7623.c | 12 +-- drivers/clk/mediatek/clk-mt7629.c | 14 +-- drivers/clk/mediatek/clk-mt8512.c | 8 +- drivers/clk/mediatek/clk-mt8516.c | 6 +- drivers/clk/mediatek/clk-mt8518.c | 6 +- drivers/clk/meson/axg.c | 2 +- drivers/clk/meson/g12a.c | 2 +- drivers/clk/meson/gxbb.c | 2 +- drivers/clk/mpc83xx_clk.c | 2 +- drivers/clk/mtmips/clk-mt7628.c | 2 +- drivers/clk/mvebu/armada-37xx-periph.c | 2 +- drivers/clk/mvebu/armada-37xx-tbg.c | 2 +- drivers/clk/owl/clk_owl.c | 2 +- drivers/clk/renesas/r8a774a1-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a774b1-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a774c0-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a774e1-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7790-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7791-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7792-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7794-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7795-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a7796-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a77965-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a77970-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a77980-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a77990-cpg-mssr.c | 2 +- drivers/clk/renesas/r8a77995-cpg-mssr.c | 2 +- drivers/clk/rockchip/clk_px30.c | 12 +-- drivers/clk/rockchip/clk_rk3036.c | 6 +- drivers/clk/rockchip/clk_rk3128.c | 6 +- drivers/clk/rockchip/clk_rk3188.c | 10 +-- drivers/clk/rockchip/clk_rk322x.c | 6 +- drivers/clk/rockchip/clk_rk3288.c | 10 +-- drivers/clk/rockchip/clk_rk3308.c | 6 +- drivers/clk/rockchip/clk_rk3328.c | 6 +- drivers/clk/rockchip/clk_rk3368.c | 10 +-- drivers/clk/rockchip/clk_rk3399.c | 20 ++--- drivers/clk/rockchip/clk_rv1108.c | 6 +- drivers/clk/sifive/fu540-prci.c | 2 +- drivers/clk/sunxi/clk_a10.c | 2 +- drivers/clk/sunxi/clk_a10s.c | 2 +- drivers/clk/sunxi/clk_a23.c | 2 +- drivers/clk/sunxi/clk_a31.c | 2 +- drivers/clk/sunxi/clk_a64.c | 2 +- drivers/clk/sunxi/clk_a80.c | 2 +- drivers/clk/sunxi/clk_a83t.c | 2 +- drivers/clk/sunxi/clk_h3.c | 2 +- drivers/clk/sunxi/clk_h6.c | 2 +- drivers/clk/sunxi/clk_r40.c | 2 +- drivers/clk/sunxi/clk_v3s.c | 2 +- drivers/clk/uniphier/clk-uniphier-core.c | 2 +- drivers/core/acpi.c | 2 +- drivers/core/device-remove.c | 20 ++--- drivers/core/device.c | 110 ++++++++++------------- drivers/core/devres.c | 2 +- drivers/core/dump.c | 2 +- drivers/core/ofnode.c | 10 +++ drivers/core/regmap.c | 4 +- drivers/core/root.c | 111 +++++++---------------- drivers/core/simple-bus.c | 6 +- drivers/core/simple-pm-bus.c | 2 +- drivers/core/syscon-uclass.c | 6 +- drivers/core/uclass.c | 8 +- drivers/cpu/at91_cpu.c | 10 +-- drivers/cpu/bmips_cpu.c | 4 +- drivers/cpu/cpu-uclass.c | 2 +- drivers/cpu/cpu_sandbox.c | 2 +- drivers/cpu/imx8_cpu.c | 20 ++--- drivers/cpu/mpc83xx_cpu.c | 2 +- drivers/cpu/riscv_cpu.c | 2 +- drivers/crypto/fsl/rng.c | 2 +- drivers/ddr/altera/sdram_agilex.c | 2 +- drivers/ddr/altera/sdram_gen5.c | 14 +-- drivers/ddr/altera/sdram_s10.c | 2 +- drivers/ddr/altera/sdram_soc64.c | 24 ++--- drivers/ddr/altera/sdram_soc64.h | 16 ++-- drivers/demo/demo-pdata.c | 10 +-- drivers/demo/demo-shape.c | 12 +-- drivers/demo/demo-simple.c | 8 +- drivers/demo/demo-uclass.c | 2 +- drivers/dma/bcm6348-iudma.c | 2 +- drivers/dma/dma-uclass.c | 2 +- drivers/dma/sandbox-dma-test.c | 2 +- drivers/dma/ti-edma3.c | 6 +- drivers/dma/ti/k3-udma.c | 2 +- drivers/firmware/scmi/mailbox_agent.c | 2 +- drivers/firmware/scmi/sandbox-scmi_agent.c | 2 +- drivers/firmware/scmi/sandbox-scmi_devices.c | 2 +- drivers/firmware/scmi/scmi_agent-uclass.c | 4 +- drivers/firmware/scmi/smccc_agent.c | 2 +- drivers/firmware/ti_sci.c | 2 +- drivers/gpio/74x164_gpio.c | 2 +- drivers/gpio/altera_pio.c | 20 ++--- drivers/gpio/at91_gpio.c | 6 +- drivers/gpio/atmel_pio4.c | 8 +- drivers/gpio/bcm2835_gpio.c | 12 +-- drivers/gpio/bcm6345_gpio.c | 2 +- drivers/gpio/cortina_gpio.c | 2 +- drivers/gpio/da8xx_gpio.c | 12 +-- drivers/gpio/da8xx_gpio.h | 2 +- drivers/gpio/dwapb_gpio.c | 24 ++--- drivers/gpio/gpio-rcar.c | 2 +- drivers/gpio/gpio-rza1.c | 2 +- drivers/gpio/gpio-uclass.c | 14 +-- drivers/gpio/gpio-uniphier.c | 2 +- drivers/gpio/hi6220_gpio.c | 4 +- drivers/gpio/hsdk-creg-gpio.c | 2 +- drivers/gpio/imx_rgpio2p.c | 14 +-- drivers/gpio/intel_broadwell_gpio.c | 12 +-- drivers/gpio/intel_gpio.c | 4 +- drivers/gpio/intel_ich6_gpio.c | 12 +-- drivers/gpio/iproc_gpio.c | 30 +++---- drivers/gpio/lpc32xx_gpio.c | 2 +- drivers/gpio/mpc83xx_spisel_boot.c | 16 ++-- drivers/gpio/mpc8xxx_gpio.c | 16 ++-- drivers/gpio/mscc_sgpio.c | 2 +- drivers/gpio/msm_gpio.c | 6 +- drivers/gpio/mt7621_gpio.c | 25 +++--- drivers/gpio/mvebu_gpio.c | 2 +- drivers/gpio/mxc_gpio.c | 12 +-- drivers/gpio/mxs_gpio.c | 14 +-- drivers/gpio/nx_gpio.c | 34 +++---- drivers/gpio/octeon_gpio.c | 2 +- drivers/gpio/omap_gpio.c | 18 ++-- drivers/gpio/pca953x_gpio.c | 18 ++-- drivers/gpio/pcf8575_gpio.c | 16 ++-- drivers/gpio/pic32_gpio.c | 2 +- drivers/gpio/pm8916_gpio.c | 12 +-- drivers/gpio/rk_gpio.c | 2 +- drivers/gpio/s5p_gpio.c | 16 ++-- drivers/gpio/sandbox.c | 6 +- drivers/gpio/sifive-gpio.c | 20 ++--- drivers/gpio/stm32_gpio.c | 2 +- drivers/gpio/sunxi_gpio.c | 23 +++-- drivers/gpio/tegra186_gpio.c | 13 ++- drivers/gpio/tegra_gpio.c | 14 +-- drivers/gpio/vybrid_gpio.c | 12 +-- drivers/gpio/xilinx_gpio.c | 100 ++++++++++----------- drivers/gpio/zynq_gpio.c | 64 ++++++------- drivers/hwspinlock/stm32_hwspinlock.c | 2 +- drivers/i2c/Kconfig | 2 +- drivers/i2c/acpi_i2c.c | 4 +- drivers/i2c/acpi_i2c.h | 2 +- drivers/i2c/ast_i2c.c | 6 +- drivers/i2c/at91_i2c.c | 8 +- drivers/i2c/cros_ec_tunnel.c | 6 +- drivers/i2c/davinci_i2c.c | 2 +- drivers/i2c/designware_i2c.c | 6 +- drivers/i2c/designware_i2c.h | 2 +- drivers/i2c/designware_i2c_pci.c | 8 +- drivers/i2c/exynos_hs_i2c.c | 6 +- drivers/i2c/fsl_i2c.c | 6 +- drivers/i2c/i2c-cdns.c | 6 +- drivers/i2c/i2c-cortina.c | 6 +- drivers/i2c/i2c-emul-uclass.c | 21 +++-- drivers/i2c/i2c-gpio.c | 6 +- drivers/i2c/i2c-uclass.c | 40 ++++----- drivers/i2c/i2c-uniphier-f.c | 2 +- drivers/i2c/i2c-uniphier.c | 2 +- drivers/i2c/i2c-versatile.c | 2 +- drivers/i2c/ihs_i2c.c | 2 +- drivers/i2c/imx_lpi2c.c | 2 +- drivers/i2c/intel_i2c.c | 2 +- drivers/i2c/iproc_i2c.c | 6 +- drivers/i2c/lpc32xx_i2c.c | 10 +-- drivers/i2c/meson_i2c.c | 2 +- drivers/i2c/muxes/i2c-arb-gpio-challenge.c | 2 +- drivers/i2c/muxes/i2c-mux-gpio.c | 2 +- drivers/i2c/muxes/i2c-mux-uclass.c | 10 +-- drivers/i2c/muxes/pca954x.c | 6 +- drivers/i2c/mv_i2c.c | 2 +- drivers/i2c/mvtwsi.c | 6 +- drivers/i2c/mxc_i2c.c | 2 +- drivers/i2c/nx_i2c.c | 2 +- drivers/i2c/ocores_i2c.c | 2 +- drivers/i2c/octeon_i2c.c | 2 +- drivers/i2c/omap24xx_i2c.c | 12 +-- drivers/i2c/rcar_i2c.c | 2 +- drivers/i2c/rcar_iic.c | 2 +- drivers/i2c/rk_i2c.c | 6 +- drivers/i2c/s3c24x0_i2c.c | 6 +- drivers/i2c/sandbox_i2c.c | 4 +- drivers/i2c/stm32f7_i2c.c | 6 +- drivers/i2c/tegra186_bpmp_i2c.c | 2 +- drivers/i2c/tegra_i2c.c | 2 +- drivers/i2c/xilinx_xiic.c | 2 +- drivers/input/cros_ec_keyb.c | 2 +- drivers/input/i8042.c | 2 +- drivers/input/keyboard-uclass.c | 2 +- drivers/input/tegra-kbc.c | 2 +- drivers/led/led-uclass.c | 4 +- drivers/led/led_bcm6328.c | 6 +- drivers/led/led_bcm6358.c | 6 +- drivers/led/led_bcm6858.c | 6 +- drivers/led/led_cortina.c | 28 +++--- drivers/led/led_gpio.c | 6 +- drivers/mailbox/k3-sec-proxy.c | 2 +- drivers/mailbox/sandbox-mbox-test.c | 2 +- drivers/mailbox/sandbox-mbox.c | 2 +- drivers/mailbox/stm32-ipcc.c | 2 +- drivers/mailbox/tegra-hsp.c | 2 +- drivers/mailbox/zynqmp-ipi.c | 2 +- drivers/memory/stm32-fmc2-ebi.c | 2 +- drivers/misc/altera_sysid.c | 12 +-- drivers/misc/atsha204a-i2c.c | 6 +- drivers/misc/cros_ec.c | 2 +- drivers/misc/cros_ec_i2c.c | 4 +- drivers/misc/cros_ec_sandbox.c | 2 +- drivers/misc/fs_loader.c | 18 ++-- drivers/misc/gdsys_ioep.c | 2 +- drivers/misc/gdsys_rxaui_ctrl.c | 2 +- drivers/misc/gdsys_soc.c | 2 +- drivers/misc/i2c_eeprom.c | 16 ++-- drivers/misc/i2c_eeprom_emul.c | 20 ++--- drivers/misc/ihs_fpga.c | 2 +- drivers/misc/imx8/scu.c | 6 +- drivers/misc/irq_sandbox.c | 2 +- drivers/misc/k3_avs.c | 2 +- drivers/misc/microchip_flexcom.c | 10 +-- drivers/misc/misc_sandbox.c | 2 +- drivers/misc/mpc83xx_serdes.c | 2 +- drivers/misc/p2sb-uclass.c | 19 ++-- drivers/misc/p2sb_emul.c | 18 ++-- drivers/misc/p2sb_sandbox.c | 2 +- drivers/misc/rockchip-efuse.c | 12 +-- drivers/misc/rockchip-otp.c | 16 ++-- drivers/misc/sandbox_adder.c | 4 +- drivers/misc/sifive-otp.c | 14 +-- drivers/misc/swap_case.c | 14 +-- drivers/misc/tegra186_bpmp.c | 2 +- drivers/mmc/am654_sdhci.c | 22 ++--- drivers/mmc/arm_pl180_mmci.c | 12 +-- drivers/mmc/aspeed_sdhci.c | 8 +- drivers/mmc/atmel_sdhci.c | 8 +- drivers/mmc/bcm2835_sdhci.c | 8 +- drivers/mmc/bcm2835_sdhost.c | 8 +- drivers/mmc/bcmstb_sdhci.c | 8 +- drivers/mmc/ca_dw_mmc.c | 12 +-- drivers/mmc/davinci_mmc.c | 14 +-- drivers/mmc/exynos_dw_mmc.c | 8 +- drivers/mmc/fsl_esdhc.c | 18 ++-- drivers/mmc/fsl_esdhc_imx.c | 18 ++-- drivers/mmc/ftsdc010_mci.c | 12 +-- drivers/mmc/gen_atmel_mci.c | 18 ++-- drivers/mmc/hi6220_dw_mmc.c | 12 +-- drivers/mmc/iproc_sdhci.c | 8 +- drivers/mmc/jz_mmc.c | 14 +-- drivers/mmc/meson_gx_mmc.c | 18 ++-- drivers/mmc/meson_gx_mmc.h | 2 +- drivers/mmc/mmc-uclass.c | 8 +- drivers/mmc/mmc.c | 2 +- drivers/mmc/mmc_spi.c | 8 +- drivers/mmc/mmc_write.c | 4 +- drivers/mmc/msm_sdhci.c | 12 +-- drivers/mmc/mtk-sd.c | 26 +++--- drivers/mmc/mv_sdhci.c | 8 +- drivers/mmc/mxsmmc.c | 22 ++--- drivers/mmc/nexell_dw_mmc.c | 12 +-- drivers/mmc/octeontx_hsmmc.c | 2 +- drivers/mmc/omap_hsmmc.c | 16 ++-- drivers/mmc/pci_mmc.c | 12 +-- drivers/mmc/pic32_sdhci.c | 8 +- drivers/mmc/pxa_mmc_gen.c | 10 +-- drivers/mmc/renesas-sdhi.c | 6 +- drivers/mmc/rockchip_dw_mmc.c | 12 +-- drivers/mmc/rockchip_sdhci.c | 12 +-- drivers/mmc/s5p_sdhci.c | 8 +- drivers/mmc/sandbox_mmc.c | 6 +- drivers/mmc/sdhci-cadence.c | 12 +-- drivers/mmc/sh_mmcif.c | 8 +- drivers/mmc/sh_sdhi.c | 8 +- drivers/mmc/snps_dw_mmc.c | 12 +-- drivers/mmc/socfpga_dw_mmc.c | 12 +-- drivers/mmc/sti_sdhci.c | 14 +-- drivers/mmc/stm32_sdmmc2.c | 8 +- drivers/mmc/sunxi_mmc.c | 12 +-- drivers/mmc/tangier_sdhci.c | 8 +- drivers/mmc/tegra_mmc.c | 8 +- drivers/mmc/tmio-common.c | 4 +- drivers/mmc/uniphier-sd.c | 4 +- drivers/mmc/xenon_sdhci.c | 12 +-- drivers/mmc/zynq_sdhci.c | 12 +-- drivers/mtd/altera_qspi.c | 26 +++--- drivers/mtd/hbmc-am654.c | 2 +- drivers/mtd/mtd-uclass.c | 2 +- drivers/mtd/nand/raw/arasan_nfc.c | 2 +- drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 2 +- drivers/mtd/nand/raw/brcmnand/bcm6368_nand.c | 2 +- drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 2 +- drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c | 2 +- drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 2 +- drivers/mtd/nand/raw/davinci_nand.c | 2 +- drivers/mtd/nand/raw/denali_dt.c | 2 +- drivers/mtd/nand/raw/mxs_nand_dt.c | 2 +- drivers/mtd/nand/raw/octeontx_bch.c | 4 +- drivers/mtd/nand/raw/octeontx_nand.c | 6 +- drivers/mtd/nand/raw/pxa3xx_nand.c | 2 +- drivers/mtd/nand/raw/stm32_fmc2_nand.c | 2 +- drivers/mtd/nand/raw/tegra_nand.c | 2 +- drivers/mtd/nand/raw/vf610_nfc.c | 2 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- drivers/mtd/nand/spi/core.c | 2 +- drivers/mtd/spi/Kconfig | 4 +- drivers/mtd/spi/sandbox.c | 18 ++-- drivers/mtd/spi/sf-uclass.c | 2 +- drivers/mtd/spi/sf_dataflash.c | 2 +- drivers/mtd/spi/sf_probe.c | 2 +- drivers/mux/mux-uclass.c | 2 +- drivers/net/ag7xxx.c | 14 +-- drivers/net/altera_tse.c | 14 +-- drivers/net/bcm6348-eth.c | 10 +-- drivers/net/bcm6368-eth.c | 6 +- drivers/net/bcmgenet.c | 14 +-- drivers/net/dc2114x.c | 8 +- drivers/net/designware.c | 20 ++--- drivers/net/designware.h | 2 +- drivers/net/dwc_eth_qos.c | 8 +- drivers/net/dwmac_s700.c | 10 +-- drivers/net/dwmac_socfpga.c | 16 ++-- drivers/net/e1000.c | 10 +-- drivers/net/eepro100.c | 8 +- drivers/net/eth-phy-uclass.c | 2 +- drivers/net/ethoc.c | 14 +-- drivers/net/fec_mxc.c | 16 ++-- drivers/net/fm/eth.c | 6 +- drivers/net/fm/fm.c | 2 +- drivers/net/fm/memac_phy.c | 4 +- drivers/net/fsl-mc/mc.c | 2 +- drivers/net/fsl_enetc.c | 16 ++-- drivers/net/fsl_enetc_mdio.c | 2 +- drivers/net/fsl_ls_mdio.c | 2 +- drivers/net/fsl_mcdmafec.c | 14 +-- drivers/net/fsl_mdio.c | 4 +- drivers/net/ftgmac100.c | 16 ++-- drivers/net/ftmac100.c | 14 +-- drivers/net/gmac_rockchip.c | 40 ++++----- drivers/net/higmacv300.c | 10 +-- drivers/net/ks8851_mll.c | 14 +-- drivers/net/ldpaa_eth/ldpaa_eth.c | 10 +-- drivers/net/macb.c | 20 ++--- drivers/net/mcffec.c | 14 +-- drivers/net/mdio-ipq4019.c | 2 +- drivers/net/mdio_mux_i2creg.c | 2 +- drivers/net/mdio_mux_sandbox.c | 2 +- drivers/net/mdio_sandbox.c | 2 +- drivers/net/mscc_eswitch/jr2_switch.c | 8 +- drivers/net/mscc_eswitch/luton_switch.c | 8 +- drivers/net/mscc_eswitch/ocelot_switch.c | 8 +- drivers/net/mscc_eswitch/serval_switch.c | 8 +- drivers/net/mscc_eswitch/servalt_switch.c | 8 +- drivers/net/mt7628-eth.c | 6 +- drivers/net/mtk_eth.c | 14 +-- drivers/net/mvgbe.c | 16 ++-- drivers/net/mvmdio.c | 2 +- drivers/net/mvneta.c | 18 ++-- drivers/net/mvpp2.c | 12 +-- drivers/net/octeontx/bgx.c | 2 +- drivers/net/octeontx/nic_main.c | 2 +- drivers/net/octeontx/nicvf_main.c | 12 +-- drivers/net/octeontx2/cgx.c | 2 +- drivers/net/octeontx2/nix.c | 2 +- drivers/net/octeontx2/rvu_af.c | 2 +- drivers/net/octeontx2/rvu_pf.c | 6 +- drivers/net/pch_gbe.c | 10 +-- drivers/net/pcnet.c | 8 +- drivers/net/pfe_eth/pfe_eth.c | 10 +-- drivers/net/pic32_eth.c | 8 +- drivers/net/qe/dm_qe_uec.c | 16 ++-- drivers/net/qe/dm_qe_uec_phy.c | 2 +- drivers/net/ravb.c | 18 ++-- drivers/net/rtl8139.c | 10 +-- drivers/net/rtl8169.c | 12 +-- drivers/net/sandbox-raw.c | 16 ++-- drivers/net/sandbox.c | 12 +-- drivers/net/sh_eth.c | 18 ++-- drivers/net/smc911x.c | 14 +-- drivers/net/sni_ave.c | 16 ++-- drivers/net/sun8i_emac.c | 16 ++-- drivers/net/sunxi_emac.c | 14 +-- drivers/net/ti/am65-cpsw-nuss.c | 14 +-- drivers/net/ti/cpsw.c | 16 ++-- drivers/net/ti/davinci_emac.c | 4 +- drivers/net/ti/keystone_net.c | 24 ++--- drivers/net/tsec.c | 8 +- drivers/net/xilinx_axi_emac.c | 12 +-- drivers/net/xilinx_emaclite.c | 12 +-- drivers/net/zynq_gem.c | 14 +-- drivers/nvme/nvme.c | 12 +-- drivers/pch/sandbox_pch.c | 2 +- drivers/pci/pci-aardvark.c | 8 +- drivers/pci/pci-emul-uclass.c | 10 +-- drivers/pci/pci-rcar-gen2.c | 6 +- drivers/pci/pci-rcar-gen3.c | 22 ++--- drivers/pci/pci-uclass.c | 51 ++++++----- drivers/pci/pci_mpc85xx.c | 6 +- drivers/pci/pci_mvebu.c | 18 ++-- drivers/pci/pci_octeontx.c | 6 +- drivers/pci/pci_rom.c | 8 +- drivers/pci/pci_sandbox.c | 5 +- drivers/pci/pci_tegra.c | 6 +- drivers/pci/pcie_brcmstb.c | 6 +- drivers/pci/pcie_dw_mvebu.c | 8 +- drivers/pci/pcie_dw_ti.c | 8 +- drivers/pci/pcie_ecam_generic.c | 8 +- drivers/pci/pcie_fsl.c | 6 +- drivers/pci/pcie_imx.c | 6 +- drivers/pci/pcie_intel_fpga.c | 6 +- drivers/pci/pcie_iproc.c | 2 +- drivers/pci/pcie_layerscape_ep.c | 2 +- drivers/pci/pcie_layerscape_gen4.c | 2 +- drivers/pci/pcie_layerscape_rc.c | 2 +- drivers/pci/pcie_mediatek.c | 8 +- drivers/pci/pcie_phytium.c | 8 +- drivers/pci/pcie_rockchip.c | 2 +- drivers/pci/pcie_xilinx.c | 8 +- drivers/pci_endpoint/pcie-cadence-ep.c | 2 +- drivers/pci_endpoint/sandbox-pci_ep.c | 2 +- drivers/phy/allwinner/phy-sun4i-usb.c | 6 +- drivers/phy/bcm6318-usbh-phy.c | 2 +- drivers/phy/bcm6348-usbh-phy.c | 2 +- drivers/phy/bcm6358-usbh-phy.c | 2 +- drivers/phy/bcm6368-usbh-phy.c | 2 +- drivers/phy/keystone-usb-phy.c | 2 +- drivers/phy/marvell/comphy_core.c | 2 +- drivers/phy/meson-g12a-usb2.c | 2 +- drivers/phy/meson-g12a-usb3-pcie.c | 2 +- drivers/phy/meson-gxbb-usb2.c | 2 +- drivers/phy/meson-gxl-usb2.c | 2 +- drivers/phy/msm8916-usbh-phy.c | 2 +- drivers/phy/mt76x8-usb-phy.c | 2 +- drivers/phy/nop-phy.c | 2 +- drivers/phy/omap-usb2-phy.c | 2 +- drivers/phy/phy-bcm-sr-pcie.c | 4 +- drivers/phy/phy-mtk-tphy.c | 2 +- drivers/phy/phy-qcom-ipq4019-usb.c | 4 +- drivers/phy/phy-rcar-gen2.c | 2 +- drivers/phy/phy-rcar-gen3.c | 2 +- drivers/phy/phy-stm32-usbphyc.c | 2 +- drivers/phy/phy-ti-am654.c | 4 +- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 2 +- drivers/phy/rockchip/phy-rockchip-pcie.c | 2 +- drivers/phy/rockchip/phy-rockchip-typec.c | 2 +- drivers/phy/sandbox-phy.c | 2 +- drivers/phy/sti_usb_phy.c | 2 +- drivers/phy/ti-pipe3-phy.c | 2 +- drivers/pinctrl/aspeed/pinctrl_ast2500.c | 2 +- drivers/pinctrl/ath79/pinctrl_ar933x.c | 2 +- drivers/pinctrl/ath79/pinctrl_qca953x.c | 2 +- drivers/pinctrl/broadcom/pinctrl-bcm283x.c | 8 +- drivers/pinctrl/broadcom/pinctrl-bcm6838.c | 2 +- drivers/pinctrl/exynos/pinctrl-exynos7420.c | 2 +- drivers/pinctrl/intel/pinctrl.c | 9 +- drivers/pinctrl/intel/pinctrl_apl.c | 20 ++--- drivers/pinctrl/mediatek/pinctrl-mt7622.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mt7623.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mt7629.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mt8512.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mt8516.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mt8518.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-axg.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-g12a.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-gxbb.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-gxl.c | 2 +- drivers/pinctrl/meson/pinctrl-meson.c | 5 +- drivers/pinctrl/mscc/pinctrl-jr2.c | 4 +- drivers/pinctrl/mscc/pinctrl-luton.c | 4 +- drivers/pinctrl/mscc/pinctrl-ocelot.c | 4 +- drivers/pinctrl/mscc/pinctrl-serval.c | 4 +- drivers/pinctrl/mscc/pinctrl-servalt.c | 4 +- drivers/pinctrl/mtmips/pinctrl-mt7628.c | 6 +- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 10 +-- drivers/pinctrl/mvebu/pinctrl-mvebu.c | 2 +- drivers/pinctrl/nexell/pinctrl-s5pxx18.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx5.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx6.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx7.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx7ulp.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx8.c | 2 +- drivers/pinctrl/nxp/pinctrl-imx8m.c | 2 +- drivers/pinctrl/nxp/pinctrl-imxrt.c | 2 +- drivers/pinctrl/nxp/pinctrl-mxs.c | 2 +- drivers/pinctrl/nxp/pinctrl-vf610.c | 2 +- drivers/pinctrl/pinctrl-at91-pio4.c | 8 +- drivers/pinctrl/pinctrl-at91.c | 2 +- drivers/pinctrl/pinctrl-kendryte.c | 2 +- drivers/pinctrl/pinctrl-qe-io.c | 14 +-- drivers/pinctrl/pinctrl-sandbox.c | 2 +- drivers/pinctrl/pinctrl-single.c | 12 +-- drivers/pinctrl/pinctrl-sti.c | 10 +-- drivers/pinctrl/pinctrl-stmfx.c | 14 +-- drivers/pinctrl/pinctrl_pic32.c | 2 +- drivers/pinctrl/pinctrl_stm32.c | 2 +- drivers/pinctrl/renesas/pfc-r7s72100.c | 8 +- drivers/pinctrl/renesas/pfc.c | 2 +- drivers/pinctrl/rockchip/pinctrl-px30.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3036.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3188.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3368.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rv1108.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 2 +- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 4 +- drivers/power/acpi_pmc/pmc_emul.c | 14 +-- drivers/power/acpi_pmc/sandbox.c | 4 +- drivers/power/domain/bcm6328-power-domain.c | 2 +- drivers/power/domain/imx8-power-domain-legacy.c | 22 ++--- drivers/power/domain/imx8m-power-domain.c | 16 ++-- drivers/power/domain/meson-ee-pwrc.c | 2 +- drivers/power/domain/meson-gx-pwrc-vpu.c | 2 +- drivers/power/domain/mtk-power-domain.c | 2 +- drivers/power/domain/sandbox-power-domain-test.c | 2 +- drivers/power/domain/sandbox-power-domain.c | 2 +- drivers/power/domain/ti-sci-power-domain.c | 2 +- drivers/power/pmic/i2c_pmic_emul.c | 14 +-- drivers/power/pmic/pm8916.c | 2 +- drivers/power/pmic/pmic-uclass.c | 2 +- drivers/power/pmic/rk8xx.c | 2 +- drivers/power/regulator/act8846.c | 4 +- drivers/power/regulator/as3722_regulator.c | 8 +- drivers/power/regulator/bd71837.c | 26 +++--- drivers/power/regulator/da9063.c | 12 +-- drivers/power/regulator/fan53555.c | 20 ++--- drivers/power/regulator/fixed.c | 28 +++--- drivers/power/regulator/gpio-regulator.c | 32 +++---- drivers/power/regulator/lp873x_regulator.c | 24 ++--- drivers/power/regulator/lp87565_regulator.c | 12 +-- drivers/power/regulator/max77686.c | 8 +- drivers/power/regulator/palmas_regulator.c | 28 +++--- drivers/power/regulator/pbias_regulator.c | 10 +-- drivers/power/regulator/pfuze100.c | 24 ++--- drivers/power/regulator/pwm_regulator.c | 10 +-- drivers/power/regulator/regulator-uclass.c | 47 +++++----- drivers/power/regulator/regulator_common.c | 9 +- drivers/power/regulator/regulator_common.h | 11 +-- drivers/power/regulator/rk8xx.c | 12 +-- drivers/power/regulator/s2mps11_regulator.c | 8 +- drivers/power/regulator/s5m8767.c | 8 +- drivers/power/regulator/sandbox.c | 16 ++-- drivers/power/regulator/stm32-vrefbuf.c | 2 +- drivers/power/regulator/stpmic1.c | 28 +++--- drivers/power/regulator/tps62360_regulator.c | 8 +- drivers/power/regulator/tps65090_regulator.c | 4 +- drivers/power/regulator/tps65910_regulator.c | 40 ++++----- drivers/power/regulator/tps65941_regulator.c | 24 ++--- drivers/pwm/exynos_pwm.c | 6 +- drivers/pwm/pwm-imx.c | 6 +- drivers/pwm/pwm-meson.c | 6 +- drivers/pwm/pwm-mtk.c | 2 +- drivers/pwm/pwm-sifive.c | 6 +- drivers/pwm/rk_pwm.c | 6 +- drivers/pwm/sandbox_pwm.c | 2 +- drivers/pwm/sunxi_pwm.c | 6 +- drivers/pwm/tegra_pwm.c | 6 +- drivers/ram/aspeed/sdram_ast2500.c | 6 +- drivers/ram/bmips_ram.c | 2 +- drivers/ram/imxrt_sdram.c | 12 +-- drivers/ram/k3-am654-ddrss.c | 2 +- drivers/ram/k3-j721e/k3-j721e-ddrss.c | 2 +- drivers/ram/mediatek/ddr3-mt7629.c | 2 +- drivers/ram/mpc83xx_sdram.c | 6 +- drivers/ram/octeon/octeon_ddr.c | 2 +- drivers/ram/rockchip/dmc-rk3368.c | 26 +++--- drivers/ram/rockchip/sdram_px30.c | 2 +- drivers/ram/rockchip/sdram_rk3128.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 25 +++--- drivers/ram/rockchip/sdram_rk322x.c | 23 +++-- drivers/ram/rockchip/sdram_rk3288.c | 25 +++--- drivers/ram/rockchip/sdram_rk3308.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 23 +++-- drivers/ram/rockchip/sdram_rk3399.c | 23 +++-- drivers/ram/sifive/fu540_ddr.c | 6 +- drivers/ram/stm32_sdram.c | 12 +-- drivers/ram/stm32mp1/stm32mp1_ram.c | 2 +- drivers/remoteproc/k3_system_controller.c | 2 +- drivers/remoteproc/rproc-uclass.c | 15 ++-- drivers/remoteproc/sandbox_testproc.c | 20 ++--- drivers/remoteproc/stm32_copro.c | 2 +- drivers/remoteproc/ti_k3_arm64_rproc.c | 2 +- drivers/remoteproc/ti_k3_dsp_rproc.c | 2 +- drivers/remoteproc/ti_k3_r5f_rproc.c | 4 +- drivers/remoteproc/ti_power_proc.c | 8 +- drivers/reset/reset-ast2500.c | 2 +- drivers/reset/reset-bcm6345.c | 2 +- drivers/reset/reset-hisilicon.c | 2 +- drivers/reset/reset-hsdk.c | 2 +- drivers/reset/reset-imx7.c | 2 +- drivers/reset/reset-ipq4019.c | 2 +- drivers/reset/reset-mediatek.c | 2 +- drivers/reset/reset-meson.c | 2 +- drivers/reset/reset-mtmips.c | 6 +- drivers/reset/reset-rockchip.c | 2 +- drivers/reset/reset-sifive.c | 2 +- drivers/reset/reset-socfpga.c | 2 +- drivers/reset/reset-sunxi.c | 2 +- drivers/reset/reset-syscon.c | 2 +- drivers/reset/reset-ti-sci.c | 2 +- drivers/reset/reset-uniphier.c | 2 +- drivers/reset/sandbox-reset-test.c | 2 +- drivers/reset/sandbox-reset.c | 2 +- drivers/reset/sti-reset.c | 2 +- drivers/reset/stm32-reset.c | 2 +- drivers/rng/meson-rng.c | 18 ++-- drivers/rng/msm_rng.c | 2 +- drivers/rng/rockchip_rng.c | 18 ++-- drivers/rng/stm32mp1_rng.c | 20 ++--- drivers/rtc/ds3232.c | 2 +- drivers/rtc/emul_rtc.c | 2 +- drivers/rtc/i2c_rtc_emul.c | 20 ++--- drivers/rtc/mvrtc.c | 12 +-- drivers/rtc/pcf2127.c | 2 +- drivers/rtc/pl031.c | 14 +-- drivers/rtc/stm32_rtc.c | 2 +- drivers/scsi/scsi-uclass.c | 2 +- drivers/scsi/scsi.c | 16 ++-- drivers/serial/altera_jtag_uart.c | 18 ++-- drivers/serial/altera_uart.c | 18 ++-- drivers/serial/atmel_usart.c | 6 +- drivers/serial/lpc32xx_hsuart.c | 6 +- drivers/serial/ns16550.c | 36 ++++---- drivers/serial/sandbox.c | 83 +++++++---------- drivers/serial/serial-uclass.c | 2 +- drivers/serial/serial_ar933x.c | 2 +- drivers/serial/serial_arc.c | 18 ++-- drivers/serial/serial_bcm283x_mu.c | 10 +-- drivers/serial/serial_bcm283x_pl011.c | 10 +-- drivers/serial/serial_bcm6345.c | 2 +- drivers/serial/serial_coreboot.c | 10 +-- drivers/serial/serial_cortina.c | 6 +- drivers/serial/serial_efi.c | 2 +- drivers/serial/serial_intel_mid.c | 10 +-- drivers/serial/serial_linflexuart.c | 6 +- drivers/serial/serial_lpuart.c | 42 ++++----- drivers/serial/serial_mcf.c | 18 ++-- drivers/serial/serial_meson.c | 20 ++--- drivers/serial/serial_msm.c | 6 +- drivers/serial/serial_mtk.c | 6 +- drivers/serial/serial_mvebu_a3700.c | 20 ++--- drivers/serial/serial_mxc.c | 18 ++-- drivers/serial/serial_omap.c | 10 +-- drivers/serial/serial_owl.c | 6 +- drivers/serial/serial_pic32.c | 2 +- drivers/serial/serial_pl01x.c | 14 +-- drivers/serial/serial_pl01x_internal.h | 2 +- drivers/serial/serial_pxa.c | 10 +-- drivers/serial/serial_rockchip.c | 20 ++--- drivers/serial/serial_s5p.c | 20 ++--- drivers/serial/serial_sh.c | 14 +-- drivers/serial/serial_sifive.c | 38 ++++---- drivers/serial/serial_sti_asc.c | 2 +- drivers/serial/serial_stm32.c | 20 ++--- drivers/serial/serial_stm32.h | 2 +- drivers/serial/serial_uniphier.c | 2 +- drivers/serial/serial_xen.c | 2 +- drivers/serial/serial_xuartlite.c | 18 ++-- drivers/serial/serial_zynq.c | 38 ++++---- drivers/soc/soc_ti_k3.c | 10 +-- drivers/soc/ti/k3-navss-ringacc.c | 2 +- drivers/sound/broadwell_i2s.c | 2 +- drivers/sound/hda_codec.c | 2 +- drivers/sound/i2s-uclass.c | 2 +- drivers/sound/ivybridge_sound.c | 6 +- drivers/sound/max98088.c | 2 +- drivers/sound/max98090.c | 2 +- drivers/sound/max98095.c | 2 +- drivers/sound/max98357a.c | 4 +- drivers/sound/rt5677.c | 2 +- drivers/sound/samsung-i2s.c | 4 +- drivers/sound/sandbox.c | 6 +- drivers/sound/sound-uclass.c | 2 +- drivers/sound/tegra_ahub.c | 2 +- drivers/sound/wm8994.c | 2 +- drivers/spi/altera_spi.c | 16 ++-- drivers/spi/atcspi200_spi.c | 8 +- drivers/spi/ath79_spi.c | 4 +- drivers/spi/atmel-quadspi.c | 2 +- drivers/spi/atmel_spi.c | 20 ++--- drivers/spi/bcm63xx_hsspi.c | 8 +- drivers/spi/bcm63xx_spi.c | 8 +- drivers/spi/bcmstb_spi.c | 14 +-- drivers/spi/cadence_qspi.c | 20 ++--- drivers/spi/cadence_qspi.h | 12 +-- drivers/spi/cadence_qspi_apb.c | 18 ++-- drivers/spi/cf_spi.c | 22 ++--- drivers/spi/davinci_spi.c | 18 ++-- drivers/spi/designware_spi.c | 16 ++-- drivers/spi/exynos_spi.c | 20 ++--- drivers/spi/fsl_dspi.c | 30 +++---- drivers/spi/fsl_espi.c | 14 +-- drivers/spi/fsl_qspi.c | 6 +- drivers/spi/ich.c | 38 ++++---- drivers/spi/kirkwood_spi.c | 24 ++--- drivers/spi/meson_spifc.c | 2 +- drivers/spi/mpc8xxx_spi.c | 22 ++--- drivers/spi/mscc_bb_spi.c | 4 +- drivers/spi/mt7621_spi.c | 2 +- drivers/spi/mtk_snfi_spi.c | 2 +- drivers/spi/mvebu_a3700_spi.c | 24 ++--- drivers/spi/mxc_spi.c | 16 ++-- drivers/spi/mxs_spi.c | 14 +-- drivers/spi/nxp_fspi.c | 8 +- drivers/spi/octeon_spi.c | 4 +- drivers/spi/omap3_spi.c | 16 ++-- drivers/spi/pic32_spi.c | 6 +- drivers/spi/pl022_spi.c | 12 +-- drivers/spi/renesas_rpc_spi.c | 14 +-- drivers/spi/rk_spi.c | 26 +++--- drivers/spi/sh_qspi.c | 12 +-- drivers/spi/soft_spi.c | 24 ++--- drivers/spi/spi-qup.c | 4 +- drivers/spi/spi-sifive.c | 10 +-- drivers/spi/spi-sunxi.c | 18 ++-- drivers/spi/spi-uclass.c | 26 +++--- drivers/spi/stm32_qspi.c | 4 +- drivers/spi/stm32_spi.c | 6 +- drivers/spi/tegra114_spi.c | 18 ++-- drivers/spi/tegra20_sflash.c | 18 ++-- drivers/spi/tegra20_slink.c | 18 ++-- drivers/spi/tegra210_qspi.c | 20 ++--- drivers/spi/tegra_spi.h | 2 +- drivers/spi/ti_qspi.c | 16 ++-- drivers/spi/uniphier_spi.c | 20 ++--- drivers/spi/xilinx_spi.c | 6 +- drivers/spi/zynq_qspi.c | 18 ++-- drivers/spi/zynq_spi.c | 22 ++--- drivers/spi/zynqmp_gqspi.c | 18 ++-- drivers/spmi/spmi-msm.c | 2 +- drivers/spmi/spmi-sandbox.c | 2 +- drivers/sysinfo/gazerbeam.c | 2 +- drivers/sysinfo/sandbox.c | 2 +- drivers/sysreset/poweroff_gpio.c | 2 +- drivers/sysreset/sysreset-ti-sci.c | 2 +- drivers/sysreset/sysreset_gpio.c | 2 +- drivers/sysreset/sysreset_octeon.c | 2 +- drivers/sysreset/sysreset_resetctl.c | 2 +- drivers/sysreset/sysreset_socfpga.c | 2 +- drivers/sysreset/sysreset_sti.c | 2 +- drivers/sysreset/sysreset_syscon.c | 2 +- drivers/sysreset/sysreset_watchdog.c | 2 +- drivers/sysreset/sysreset_x86.c | 8 +- drivers/tee/optee/core.c | 14 +-- drivers/tee/sandbox.c | 2 +- drivers/tee/tee-uclass.c | 2 +- drivers/thermal/imx_scu_thermal.c | 14 +-- drivers/thermal/imx_thermal.c | 6 +- drivers/thermal/imx_tmu.c | 20 ++--- drivers/thermal/ti-bandgap.c | 2 +- drivers/timer/ag101p_timer.c | 14 +-- drivers/timer/altera_timer.c | 14 +-- drivers/timer/arc_timer.c | 2 +- drivers/timer/ast_timer.c | 6 +- drivers/timer/atcpit100_timer.c | 14 +-- drivers/timer/atmel_pit_timer.c | 14 +-- drivers/timer/cadence-ttc.c | 6 +- drivers/timer/dw-apb-timer.c | 6 +- drivers/timer/mchp-pit64b-timer.c | 2 +- drivers/timer/mpc83xx_timer.c | 2 +- drivers/timer/mtk_timer.c | 2 +- drivers/timer/nomadik-mtu-timer.c | 2 +- drivers/timer/omap-timer.c | 6 +- drivers/timer/ostm_timer.c | 6 +- drivers/timer/rockchip_timer.c | 10 +-- drivers/timer/sti-timer.c | 2 +- drivers/timer/stm32_timer.c | 2 +- drivers/timer/timer-uclass.c | 6 +- drivers/tpm/cr50_i2c.c | 8 +- drivers/tpm/tpm-uclass.c | 2 +- drivers/tpm/tpm2_ftpm_tee.c | 2 +- drivers/tpm/tpm2_tis_sandbox.c | 2 +- drivers/tpm/tpm2_tis_spi.c | 2 +- drivers/tpm/tpm_tis_infineon.c | 2 +- drivers/tpm/tpm_tis_lpc.c | 2 +- drivers/tpm/tpm_tis_sandbox.c | 2 +- drivers/tpm/tpm_tis_st33zp24_i2c.c | 2 +- drivers/tpm/tpm_tis_st33zp24_spi.c | 12 +-- drivers/ufs/ufs-uclass.c | 2 +- drivers/ufs/ufs.c | 4 +- drivers/usb/cdns3/cdns3-ti.c | 6 +- drivers/usb/cdns3/core.c | 4 +- drivers/usb/dwc3/dwc3-generic.c | 28 +++--- drivers/usb/dwc3/dwc3-meson-g12a.c | 8 +- drivers/usb/dwc3/dwc3-meson-gxl.c | 8 +- drivers/usb/emul/sandbox_flash.c | 16 ++-- drivers/usb/emul/sandbox_hub.c | 17 ++-- drivers/usb/emul/sandbox_keyb.c | 6 +- drivers/usb/emul/usb-emul-uclass.c | 22 ++--- drivers/usb/eth/asix.c | 10 +-- drivers/usb/eth/asix88179.c | 8 +- drivers/usb/eth/lan75xx.c | 10 +-- drivers/usb/eth/lan78xx.c | 10 +-- drivers/usb/eth/mcs7830.c | 8 +- drivers/usb/eth/r8152.c | 10 +-- drivers/usb/eth/smsc95xx.c | 10 +-- drivers/usb/gadget/dwc2_udc_otg.c | 59 ++++++------ drivers/usb/gadget/ether.c | 8 +- drivers/usb/gadget/max3420_udc.c | 6 +- drivers/usb/host/dwc2.c | 6 +- drivers/usb/host/dwc3-of-simple.c | 6 +- drivers/usb/host/dwc3-sti-glue.c | 22 ++--- drivers/usb/host/ehci-atmel.c | 4 +- drivers/usb/host/ehci-exynos.c | 16 ++-- drivers/usb/host/ehci-fsl.c | 8 +- drivers/usb/host/ehci-generic.c | 2 +- drivers/usb/host/ehci-marvell.c | 4 +- drivers/usb/host/ehci-msm.c | 10 +-- drivers/usb/host/ehci-mx5.c | 12 +-- drivers/usb/host/ehci-mx6.c | 14 +-- drivers/usb/host/ehci-omap.c | 12 +-- drivers/usb/host/ehci-pci.c | 4 +- drivers/usb/host/ehci-tegra.c | 10 +-- drivers/usb/host/ehci-vf.c | 10 +-- drivers/usb/host/ehci-zynq.c | 10 +-- drivers/usb/host/ohci-da8xx.c | 2 +- drivers/usb/host/ohci-generic.c | 2 +- drivers/usb/host/ohci-pci.c | 4 +- drivers/usb/host/r8a66597-hcd.c | 6 +- drivers/usb/host/usb-sandbox.c | 2 +- drivers/usb/host/usb-uclass.c | 32 +++---- drivers/usb/host/xhci-brcm.c | 10 +-- drivers/usb/host/xhci-dwc3.c | 10 +-- drivers/usb/host/xhci-exynos5.c | 16 ++-- drivers/usb/host/xhci-fsl.c | 4 +- drivers/usb/host/xhci-mtk.c | 2 +- drivers/usb/host/xhci-mvebu.c | 16 ++-- drivers/usb/host/xhci-pci.c | 4 +- drivers/usb/host/xhci-rcar.c | 18 ++-- drivers/usb/mtu3/mtu3_plat.c | 6 +- drivers/usb/musb-new/da8xx.c | 56 ++++++------ drivers/usb/musb-new/mt85xx.c | 4 +- drivers/usb/musb-new/omap2430.c | 75 ++++++++-------- drivers/usb/musb-new/pic32.c | 4 +- drivers/usb/musb-new/sunxi.c | 4 +- drivers/usb/musb-new/ti-musb.c | 72 +++++++-------- drivers/video/am335x-fb.c | 12 +-- drivers/video/atmel_hlcdfb.c | 10 +-- drivers/video/atmel_lcdfb.c | 14 +-- drivers/video/backlight_gpio.c | 6 +- drivers/video/bcm2835.c | 2 +- drivers/video/bridge/anx6345.c | 10 +-- drivers/video/bridge/ps862x.c | 2 +- drivers/video/bridge/video-bridge-uclass.c | 2 +- drivers/video/broadwell_igd.c | 22 ++--- drivers/video/console_truetype.c | 2 +- drivers/video/coreboot.c | 2 +- drivers/video/display-uclass.c | 6 +- drivers/video/dw_mipi_dsi.c | 2 +- drivers/video/efi.c | 2 +- drivers/video/exynos/exynos_dp.c | 6 +- drivers/video/exynos/exynos_fb.c | 10 +-- drivers/video/fsl_dcu_fb.c | 4 +- drivers/video/ihs_video_out.c | 2 +- drivers/video/imx/mxc_ipuv3_fb.c | 8 +- drivers/video/ivybridge_igd.c | 4 +- drivers/video/lg4573.c | 6 +- drivers/video/logicore_dp_tx.c | 2 +- drivers/video/mali_dp.c | 6 +- drivers/video/meson/meson_dw_hdmi.c | 2 +- drivers/video/meson/meson_plane.c | 2 +- drivers/video/meson/meson_vpu.c | 6 +- drivers/video/mvebu_lcd.c | 6 +- drivers/video/mxsfb.c | 6 +- drivers/video/nexell_display.c | 25 +++--- drivers/video/orisetech_otm8009a.c | 18 ++-- drivers/video/pwm_backlight.c | 10 +-- drivers/video/raydium-rm68200.c | 16 ++-- drivers/video/rockchip/rk3288_hdmi.c | 12 +-- drivers/video/rockchip/rk3288_mipi.c | 8 +- drivers/video/rockchip/rk3288_vop.c | 2 +- drivers/video/rockchip/rk3399_hdmi.c | 10 +-- drivers/video/rockchip/rk3399_mipi.c | 8 +- drivers/video/rockchip/rk3399_vop.c | 2 +- drivers/video/rockchip/rk_edp.c | 8 +- drivers/video/rockchip/rk_hdmi.c | 2 +- drivers/video/rockchip/rk_hdmi.h | 4 +- drivers/video/rockchip/rk_lvds.c | 8 +- drivers/video/rockchip/rk_vop.c | 6 +- drivers/video/sandbox_dsi_host.c | 2 +- drivers/video/sandbox_osd.c | 2 +- drivers/video/sandbox_sdl.c | 10 +-- drivers/video/simple_panel.c | 6 +- drivers/video/simplefb.c | 2 +- drivers/video/stm32/stm32_dsi.c | 4 +- drivers/video/stm32/stm32_ltdc.c | 6 +- drivers/video/sunxi/sunxi_de2.c | 10 +-- drivers/video/sunxi/sunxi_dw_hdmi.c | 4 +- drivers/video/sunxi/sunxi_lcd.c | 2 +- drivers/video/tda19988.c | 2 +- drivers/video/tegra.c | 10 +-- drivers/video/tegra124/display.c | 6 +- drivers/video/tegra124/dp.c | 14 +-- drivers/video/tegra124/sor.c | 6 +- drivers/video/vesa.c | 4 +- drivers/video/vidconsole-uclass.c | 2 +- drivers/video/video-uclass.c | 12 +-- drivers/virtio/virtio-uclass.c | 2 +- drivers/virtio/virtio_blk.c | 6 +- drivers/virtio/virtio_mmio.c | 6 +- drivers/virtio/virtio_net.c | 8 +- drivers/virtio/virtio_pci_legacy.c | 4 +- drivers/virtio/virtio_pci_modern.c | 4 +- drivers/virtio/virtio_rng.c | 2 +- drivers/virtio/virtio_sandbox.c | 4 +- drivers/w1-eeprom/ds24xxx.c | 2 +- drivers/w1-eeprom/ds2502.c | 2 +- drivers/w1-eeprom/w1-eeprom-uclass.c | 4 +- drivers/w1/mxc_w1.c | 18 ++-- drivers/w1/w1-gpio.c | 14 +-- drivers/w1/w1-uclass.c | 8 +- drivers/watchdog/armada-37xx-wdt.c | 2 +- drivers/watchdog/ast_wdt.c | 6 +- drivers/watchdog/at91sam9_wdt.c | 2 +- drivers/watchdog/bcm6345_wdt.c | 2 +- drivers/watchdog/cdns_wdt.c | 6 +- drivers/watchdog/designware_wdt.c | 2 +- drivers/watchdog/imx_watchdog.c | 2 +- drivers/watchdog/mt7621_wdt.c | 2 +- drivers/watchdog/mtk_wdt.c | 2 +- drivers/watchdog/octeontx_wdt.c | 2 +- drivers/watchdog/omap_wdt.c | 2 +- drivers/watchdog/orion_wdt.c | 6 +- drivers/watchdog/rti_wdt.c | 2 +- drivers/watchdog/sbsa_gwdt.c | 6 +- drivers/watchdog/sp805_wdt.c | 6 +- drivers/watchdog/stm32mp_wdt.c | 2 +- drivers/watchdog/xilinx_tb_wdt.c | 44 ++++----- drivers/watchdog/xilinx_wwdt.c | 22 ++--- drivers/xen/pvblock.c | 30 +++---- include/adc.h | 4 +- include/atmel_lcd.h | 4 +- include/blk.h | 2 +- include/cpu.h | 6 +- include/dm/device-internal.h | 22 ++--- include/dm/device.h | 87 +++++++++--------- include/dm/lists.h | 2 +- include/dm/ofnode.h | 23 +++++ include/dm/pci.h | 2 +- include/dm/platdata.h | 10 +-- include/dm/platform_data/fsl_espi.h | 2 +- include/dm/platform_data/lpc32xx_hsuart.h | 4 +- include/dm/platform_data/pxa_mmc_gen.h | 2 +- include/dm/platform_data/serial_bcm283x_mu.h | 2 +- include/dm/platform_data/serial_coldfire.h | 4 +- include/dm/platform_data/serial_mxc.h | 2 +- include/dm/platform_data/serial_pl01x.h | 2 +- include/dm/platform_data/serial_pxa.h | 4 +- include/dm/platform_data/serial_sh.h | 2 +- include/dm/platform_data/spi_coldfire.h | 4 +- include/dm/platform_data/spi_davinci.h | 2 +- include/dm/platform_data/spi_pl022.h | 2 +- include/dm/root.h | 14 ++- include/dm/uclass.h | 24 ++--- include/dwmmc.h | 4 +- include/fs_loader.h | 2 +- include/i2c.h | 12 +-- include/linux/clk-provider.h | 2 +- include/net.h | 2 +- include/ns16550.h | 10 +-- include/os.h | 17 ++++ include/p2sb.h | 4 +- include/pci.h | 6 +- include/power/acpi_pmc.h | 2 +- include/power/regulator.h | 26 +++--- include/regmap.h | 6 +- include/remoteproc.h | 2 +- include/scsi.h | 4 +- include/sdhci.h | 4 +- include/spi.h | 21 +++-- include/syscon.h | 2 +- include/usb.h | 18 ++-- include/vbe.h | 4 +- include/video.h | 10 +-- lib/acpi/acpi_device.c | 6 +- lib/efi_driver/efi_block_device.c | 22 ++--- lib/efi_loader/efi_device_path.c | 14 +-- lib/efi_loader/efi_disk.c | 2 +- lib/efi_selftest/efi_selftest_miniapp_exception.c | 2 + lib/smbios.c | 2 +- net/eth-uclass.c | 14 +-- net/mdio-mux-uclass.c | 8 +- net/mdio-uclass.c | 2 +- scripts/checkpatch.pl | 38 ++++++++ test/dm/acpi.c | 14 +-- test/dm/adc.c | 2 +- test/dm/blk.c | 2 +- test/dm/bus.c | 69 +++++++------- test/dm/core.c | 52 +++++------ test/dm/devres.c | 4 +- test/dm/gpio.c | 2 +- test/dm/mux-emul.c | 2 +- test/dm/of_platdata.c | 30 +++---- test/dm/ofnode.c | 12 +++ test/dm/ofread.c | 2 +- test/dm/regmap.c | 2 +- test/dm/regulator.c | 18 ++-- test/dm/test-driver.c | 6 +- test/dm/test-fdt.c | 56 ++++++------ test/dm/test-main.c | 8 +- test/dm/test-uclass.c | 11 ++- test/dm/video.c | 8 +- test/py/tests/test_sandbox_exit.py | 24 +++++ tools/binman/elf.py | 6 +- tools/binman/etype/fmap.py | 2 +- tools/binman/fdt_test.py | 14 +-- tools/binman/fmap_util.py | 3 +- tools/dtoc/dtb_platdata.py | 185 ++++++++++++++++++++------------------ tools/dtoc/fdt.py | 58 +++++++----- tools/dtoc/test_dtoc.py | 142 ++++++++++++++--------------- tools/dtoc/test_fdt.py | 34 +++---- tools/patman/func_test.py | 13 ++- tools/patman/gitutil.py | 3 +- tools/patman/series.py | 4 +- tools/patman/settings.py | 5 +- tools/patman/test_checkpatch.py | 28 ++++++ tools/patman/tools.py | 85 +----------------- 1201 files changed, 5482 insertions(+), 5374 deletions(-) create mode 100644 cmd/sandbox/Makefile create mode 100644 cmd/sandbox/exception.c
On Mon, Dec 14, 2020 at 08:50:53AM -0700, Simon Glass wrote:
Hi Tom,
In general, this is very good and we see small reductions almost everywhere. In a few cases however we see: 22: dm: core: Combine the flattree and livetree binding code aarch64: (for 1/1 boards) all -212.0 spl/u-boot-spl:all +40.0 spl/u-boot-spl:text +40.0 text -212.0 px30-core-ctouch2-px30: all -212 spl/u-boot-spl:all +40 spl/u-boot-spl:text +40 text -212 u-boot: add: 1/-1, grow: 1/-3 bytes: 124/-336 (-212) function old new delta ofnode_is_enabled - 92 +92 dm_scan_fdt_node 196 228 +32 dm_scan_fdt 52 32 -20 dm_scan_fdt_dev 104 20 -84 dm_extended_scan_fdt 236 132 -104 static.dm_scan_fdt_live 128 - -128 spl-u-boot-spl: add: 3/0, grow: 0/-4 bytes: 116/-76 (40) function old new delta ofnode_next_subnode - 40 +40 ofnode_first_subnode - 40 +40 ofnode_is_enabled - 36 +36 dm_scan_fdt 20 16 -4 dm_scan_fdt_dev 36 20 -16 dm_scan_fdt_node 168 148 -20 dm_extended_scan_fdt 168 132 -36
Is there anything we can do about that? That said:
Hi Tom,
Hi Tom,
I'll take a look. I may have missed a condition.
BTW I am hoping to get a series out around EOM with the next evolution of of-platdata. It reduces the SPL code size by a decent amount.
Hi Tom,
On Tue, 15 Dec 2020 at 09:28, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
The problem here is that we are now using ofnode versions of those three functions. The only thing I can do is inline them. It does make things a little more complicated, but I think it is worth it. I'll send a patch.
On Wed, Dec 16, 2020 at 07:10:58PM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
OK, thanks!
