[U-Boot] [PATCH] nios2: change virt_to_phys to use physaddr_mask in global data
As virt_to_phys() is used a lot in DMA transfer, change it to use physaddr_mask in global data. This will save an "if" statement and get a little faster.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/cpu/cpu.c | 1 + arch/nios2/include/asm/global_data.h | 1 + arch/nios2/include/asm/io.h | 5 +---- 3 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 88c4e18..f6d5cd3 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -119,6 +119,7 @@ static int altera_nios2_probe(struct udevice *dev) "altr,has-mmu", 0); gd->arch.io_region_base = gd->arch.has_mmu ? 0xe0000000 : 0x80000000; gd->arch.mem_region_base = gd->arch.has_mmu ? 0xc0000000 : 0x00000000; + gd->arch.physaddr_mask = gd->arch.has_mmu ? 0x1fffffff : 0x7fffffff;
return 0; } diff --git a/arch/nios2/include/asm/global_data.h b/arch/nios2/include/asm/global_data.h index 9f3bd00..9863fd9 100644 --- a/arch/nios2/include/asm/global_data.h +++ b/arch/nios2/include/asm/global_data.h @@ -19,6 +19,7 @@ struct arch_global_data { int has_mmu; u32 io_region_base; u32 mem_region_base; + u32 physaddr_mask; };
#include <asm-generic/global_data.h> diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index 007df8d..3443408 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -44,10 +44,7 @@ static inline void unmap_physmem(void *vaddr, unsigned long flags) static inline phys_addr_t virt_to_phys(void * vaddr) { DECLARE_GLOBAL_DATA_PTR; - if (gd->arch.has_mmu) - return (phys_addr_t)vaddr & 0x1fffffff; - else - return (phys_addr_t)vaddr & 0x7fffffff; + return (phys_addr_t)vaddr & gd->arch.physaddr_mask; }
static inline void *ioremap(unsigned long physaddr, unsigned long size)
Makes sense.
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Applied to u-boot-nios.
Thomas Chou
