[PATCH] dm: pci: fsl: Correct the workaround of erratum A-007815
The register to enable/disable the write-permission of DBI RO registers should be accessed via the CFG_ADDR/CFG_DATA registers instead of accessing directly.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_fsl.c | 20 ++++++++++++++++---- drivers/pci/pcie_fsl.h | 2 ++ 2 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index ab33459e28..fb50b8f518 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -396,6 +396,19 @@ static int fsl_pcie_init_atmu(struct fsl_pcie *pcie) return 0; }
+static void fsl_pcie_dbi_read_only_reg_write_enable(struct fsl_pcie *pcie, + bool enable) +{ + u32 val; + + fsl_pcie_hose_read_config_dword(pcie, DBI_RO_WR_EN, &val); + if (enable) + val |= 1; + else + val &= ~1; + fsl_pcie_hose_write_config_dword(pcie, DBI_RO_WR_EN, val); +} + static int fsl_pcie_init_port(struct fsl_pcie *pcie) { ccsr_fsl_pci_t *regs = pcie->regs; @@ -470,7 +483,7 @@ static int fsl_pcie_init_port(struct fsl_pcie *pcie) * Set to 0 to protect the read-only registers. */ #ifdef CONFIG_SYS_FSL_ERRATUM_A007815 - clrbits_be32(®s->dbi_ro_wr_en, 0x01); + fsl_pcie_dbi_read_only_reg_write_enable(pcie, false); #endif
/* @@ -504,13 +517,12 @@ static int fsl_pcie_init_port(struct fsl_pcie *pcie)
static int fsl_pcie_fixup_classcode(struct fsl_pcie *pcie) { - ccsr_fsl_pci_t *regs = pcie->regs; u32 classcode_reg; u32 val;
if (pcie->block_rev >= PEX_IP_BLK_REV_3_0) { classcode_reg = PCI_CLASS_REVISION; - setbits_be32(®s->dbi_ro_wr_en, 0x01); + fsl_pcie_dbi_read_only_reg_write_enable(pcie, true); } else { classcode_reg = CSR_CLASSCODE; } @@ -521,7 +533,7 @@ static int fsl_pcie_fixup_classcode(struct fsl_pcie *pcie) fsl_pcie_hose_write_config_dword(pcie, classcode_reg, val);
if (pcie->block_rev >= PEX_IP_BLK_REV_3_0) - clrbits_be32(®s->dbi_ro_wr_en, 0x01); + fsl_pcie_dbi_read_only_reg_write_enable(pcie, false);
return 0; } diff --git a/drivers/pci/pcie_fsl.h b/drivers/pci/pcie_fsl.h index dc8368d559..70c5f4e4cf 100644 --- a/drivers/pci/pcie_fsl.h +++ b/drivers/pci/pcie_fsl.h @@ -26,6 +26,8 @@ /* PCIe Link Status Register */ #define PCI_LSR (FSL_PCIE_CAP_ID + 0x12)
+#define DBI_RO_WR_EN 0x8bc + #ifndef CONFIG_SYS_PCI_MEMORY_BUS #define CONFIG_SYS_PCI_MEMORY_BUS 0 #endif
Zhiqiang Hou
