[U-Boot] [PATCH 1/7] sunxi-common.h: Remove CONFIG_SYS_BOOT_GET_CMDLINE
sunxi does not need this and it should never have been enabled for it in the first place.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 6a3044f..e3dc9c4 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -126,8 +126,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "bootm_size=0x10000000\0"
-#define CONFIG_SYS_BOOT_GET_CMDLINE - #include <config_cmd_default.h>
#define CONFIG_FAT_WRITE /* enable write access */
We undef CONFIG_CMD_NET at line 167, and there is nothing re-defining it between line 167 and the #ifdef CONFIG_CMD_NET, so remove this effectively dead block.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index e3dc9c4..9d4801a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -205,14 +205,6 @@ #define CONFIG_PHYLIB #endif
-#ifdef CONFIG_CMD_NET -#define CONFIG_CMD_NFS -#define CONFIG_CMD_DNS -#define CONFIG_NETCONSOLE -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME -#endif - #ifdef CONFIG_USB_EHCI #define CONFIG_CMD_USB #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
Acked-by: Ian Campbell ijc@hellion.org.uk
I see no reason to override the choice to include this from config_cmd_defauls.h .
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9d4801a..cbe8b40 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -168,7 +168,6 @@
#undef CONFIG_CMD_FPGA #undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS
/* I2C */ #define CONFIG_SPL_I2C_SUPPORT
config_distro_defaults.h which is include later will redefine CONFIG_CMD_NET, drop the useless / meaningless undef of it.
While at also move the undef of CONFIG_CMD_FPGA up to directly under the include of config_cmd_defaults.h, to make it clear that it overwrites the setting done from config_cmd_defaults.h .
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index cbe8b40..4c712f3 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -127,6 +127,7 @@ "bootm_size=0x10000000\0"
#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA
@@ -166,9 +167,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x4ff00000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000 /* 512 KiB */
-#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_NET - /* I2C */ #define CONFIG_SPL_I2C_SUPPORT #define CONFIG_SYS_I2C
Use the new standard bootcmd from <config_distro_bootcmd.h>.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 27 ++++++++++++++++++++++++--- 1 file changed, 24 insertions(+), 3 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 4c712f3..f5a702a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -123,9 +123,6 @@ #define CONFIG_ENV_OFFSET (544 << 10) /* (8 + 24 + 512) KiB */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */
-#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootm_size=0x10000000\0" - #include <config_cmd_default.h> #undef CONFIG_CMD_FPGA
@@ -219,6 +216,30 @@
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> + +#ifdef CONFIG_AHCI +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) \ + func(USB, usb, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) +#else +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) +#endif + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + BOOTENV + +#else /* ifndef CONFIG_SPL_BUILD */ +#define CONFIG_EXTRA_ENV_SETTINGS #endif
#endif /* _SUNXI_COMMON_CONFIG_H */
Note this applies on top of Stephen Warren's "[PATCH 1/3] config: introduce a generic $bootcmd"
Regards,
Hans
- func(MMC, mmc, 0) \
- func(SCSI, scsi, 0) \
- func(USB, usb, 0) \
- func(PXE, pxe, na) \
- func(DHCP, dhcp, na)
- "bootm_size=0x10000000\0" \
- BOOTENV
Acked-by: Stephen Warren swarren@nvidia.com
In the spirit of using crazy macros (!) :-) I might code that as:
#ifdef CONFIG_AHCI #define BOOT_TARGET_DEVICES_SCSI(func) func(SCSI, scsi, 0) #else #define BOOT_TARGET_DEVICES_SCSI(func) #endif
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ BOOT_TARGET_DEVICES_SCSI(func) \ func(USB, usb, 0) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
... since it doesn't duplicate the rest of the main macro, but either way is fine by me.
Thanks for the review.
Ah, I like, esp. since in the future we may get boards without an USB host (tablets), and then things would get complicated but not with your trick.
I've modified this patch my personal tree to use your approach.
Regards,
Hans
Agreed, Stephen's way is much better and more flexible. We could use it even for the non-optional stuff right away I suppose but I'm not sure there is much point.
Ack to that in principal.
Ian.
SYS_CPU, SYS_BOARD and SYS_SOC are identical for all sunxi boards, move them to a shared code block.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/Kconfig | 32 ++++++-------------------------- 1 file changed, 6 insertions(+), 26 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index b06b5e0..24cca47 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -1,17 +1,5 @@ if TARGET_SUN4I
-config SYS_CPU - string - default "armv7" - -config SYS_BOARD - string - default "sunxi" - -config SYS_SOC - string - default "sunxi" - config SYS_CONFIG_NAME string default "sun4i" @@ -20,25 +8,21 @@ endif
if TARGET_SUN5I
-config SYS_CPU +config SYS_CONFIG_NAME string - default "armv7" + default "sun5i"
-config SYS_BOARD - string - default "sunxi" +endif
-config SYS_SOC - string - default "sunxi" +if TARGET_SUN7I
config SYS_CONFIG_NAME string - default "sun5i" + default "sun7i"
endif
-if TARGET_SUN7I +if TARGET_SUN4I || TARGET_SUN5I || TARGET_SUN7I
config SYS_CPU string @@ -52,8 +36,4 @@ config SYS_SOC string default "sunxi"
-config SYS_CONFIG_NAME - string - default "sun7i" - endif
This is an improvement so: Acked-by: Ian Campbell ijc@hellion.org.uk
But eventually we could clean up even more, e.g.
config SYS_CONFIG_NAME string default "sun4i" if TARGET_SUN4I default "sun5i" if TARGET_SUN5I etc
Possibly even some things should be select'd rather than default'd.
Ian.
Selected sounds better. :)
The main thing I know about select is that one needs to be very careful about when it is used, since it can have odd side effects....
Ian.
Automatic booting using an extlinux.conf file requires various environment variables to be set.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/Kconfig | 3 +++ configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Cubieboard2_FEL_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_FEL_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Mele_A1000G_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mini-X-1Gb_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/qt840a_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + include/configs/sunxi-common.h | 18 +++++++++++++++--- 23 files changed, 39 insertions(+), 3 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 24cca47..c61c650 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -36,4 +36,7 @@ config SYS_SOC string default "sunxi"
+config FTDFILE + string "Default ftdfile env setting for this board" + endif diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index a414953..b93ae7d 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A10_OLINUXINO_L,SPL,AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3),USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-olinuxino-lime.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 1560ab1..f206970 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A10S_OLINUXINO_M,SPL,AXP152_POWER,SUNXI_EMAC,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPB(10)" +CONFIG_FTDFILE="sun5i-a10s-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index fb510d5..8529dbe 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A13_OLINUXINOM,SPL,CONS_INDEX=2,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(11)" +CONFIG_FTDFILE="sun5i-a13-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index ba21136..c3a12cc 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A13_OLINUXINO,SPL,CONS_INDEX=2,AXP209_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(11)" +CONFIG_FTDFILE="sun5i-a13-olinuxino.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 52a857a..c91319d 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A20_OLINUXINO_M,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 643e628..193019c 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AUXTEK_T004,SPL,AXP152_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(13)" +CONFIG_FTDFILE="sun5i-a10s-auxtek-t004.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index be3d815..dc68469 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="BANANAPI,SPL,AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-bananapi.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard2_FEL_defconfig b/configs/Cubieboard2_FEL_defconfig index 63636b0..ae5e25a 100644 --- a/configs/Cubieboard2_FEL_defconfig +++ b/configs/Cubieboard2_FEL_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD2,SPL_FEL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-cubieboard2.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index fa34c51..df87edc 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD2,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-cubieboard2.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 774029c..57bf045 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD,SPL,AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-cubieboard.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Cubietruck_FEL_defconfig b/configs/Cubietruck_FEL_defconfig index 7ebf635..790125a 100644 --- a/configs/Cubietruck_FEL_defconfig +++ b/configs/Cubietruck_FEL_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIETRUCK,SPL_FEL,AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-cubietruck.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index fbc9127..4ad82e3 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIETRUCK,SPL,AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-cubietruck.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 10ebcef..22d0446 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="PCDUINO3,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-pcduino3.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Mele_A1000G_defconfig b/configs/Mele_A1000G_defconfig index 2079279..fa47fae 100644 --- a/configs/Mele_A1000G_defconfig +++ b/configs/Mele_A1000G_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MELE_A1000G,SPL,AXP209_POWER,SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI,USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-a1000.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 13528ab..d7c156d 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MELE_A1000,SPL,AXP209_POWER,SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI,USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-a1000.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mini-X-1Gb_defconfig b/configs/Mini-X-1Gb_defconfig index 61fa1de..af0b800 100644 --- a/configs/Mini-X-1Gb_defconfig +++ b/configs/Mini-X-1Gb_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MINI_X_1GB,SPL,AXP209_POWER,USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-mini-xplus.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index ceb02c5..ea0c786 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MINI_X,SPL,AXP209_POWER,USB_EHCI" +CONFIG_FTDFILE="sun4i-a10-mini-xplus.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 02a2538..c9961bd 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="BA10_TV_BOX,SPL,AXP209_POWER,SUNXI_EMAC,USB_EHCI,SUNXI_USB_VBUS1_GPIO=SUNXI_GPH(12)" +CONFIG_FTDFILE="sun4i-a10-ba10-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index ff86841..b267312 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="I12_TVBOX,SPL,AXP209_POWER,SUNXI_GMAC,MACPWR=SUNXI_GPH(21),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-i12-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/qt840a_defconfig b/configs/qt840a_defconfig index acb100c..7360212 100644 --- a/configs/qt840a_defconfig +++ b/configs/qt840a_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="QT840A,SPL,AXP209_POWER,SUNXI_GMAC,MACPWR=SUNXI_GPH(21),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-i12-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index f0f97b0..35b66f0 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -1,4 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="R7DONGLE,SPL,AXP152_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(13)" +CONFIG_FTDFILE="sun5i-a10s-r7-tv-dongle.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index f5a702a..b7708c6 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -100,10 +100,10 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_SYS_LOAD_ADDR 0x48000000 /* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */
/* standalone support */ -#define CONFIG_STANDALONE_LOAD_ADDR 0x48000000 +#define CONFIG_STANDALONE_LOAD_ADDR 0x42000000
#define CONFIG_SYS_HZ 1000
@@ -217,6 +217,16 @@ #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
+/* 256M RAM (minimum), 32M uncompressed kernel, 16M compressed kernel, 1M fdt, + * 1M script, 1M pxe and the ramdisk at the end */ +#define MEM_LAYOUT_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "scriptaddr=0x43100000\0" \ + "pxefile_addr_r=0x43200000\0" \ + "ramdisk_addr_r=0x43300000\0" + #ifdef CONFIG_AHCI #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ @@ -235,7 +245,9 @@ #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootm_size=0x10000000\0" \ + MEM_LAYOUT_ENV_SETTINGS \ + "fdtfile=" CONFIG_FTDFILE "\0" \ + "console=ttyS0,115200\0" \ BOOTENV
I'd personally be tempted to set fdt_high=0xffffffff, initrd_high=0xffffffff to stop U-Boot copying the DT/initrd from the load location to some other location under 256M, but that's just an optimization and entirely optional.
On Fri, 01 Aug 2014 12:57:31 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
There has been quite a few times where using 0xffffff has caused issues. I really think you should set bootm_size to something reasonable. beaglebones for instance has to be 0x10000000 as the beaglebone white only has 256M of ram. and let u-boot move things around, ensuring we do not get into a place where the decompressed kernel overwrites memory. This behaviour is what I had in the docs I had written earlier in the year.
Dennis
What kind of issues?
At least for Tegra, I've carefully chosen the values for the various load addresses so that there won't be issues. (Without that I can easily see the potential for issues.) I've seen far more repeated problems when U-Boot moves the DT/initrd around than than when it didn't (none in that case). Besides, it's completely redundant and unnecessary work if the blobs are already loaded at sane addresses, which they are on Tegra at least.
On Fri, 01 Aug 2014 14:22:40 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
Mostly to do with the decompressed kernel overwriting the initrd or dtb resulting in machines that would hang on boot. it came up quite a few times earlier this year on both imx and omap.
Dennis
Just how large of a kernel have you thrown on a Tegra? 32MB might seem reasonable at first but it wouldn't be overly surprised if someone can shove a BSS into there. I know I shoved DT into 128MB by default because a 32bit ARM kernel isn't functional at that size.
There's enough space for the following:
16M decompressed kernel 16M compressed kernel 1M DTB
The kernel I typically boot is ~4.MB zImage, and ~9MB Image (which doesn't include BSS).
Note that if the decompressed/compressed kernel overlap, the kernel decompresser takes care of relocating the compressed kernel before doing the decompression, and IIRC is supposed to take care not to clobber the DTB (or initrd?) when doing so.
Fedora's rawhide zImage is a bit larger at ~6MB. That works fine too.
... which is potentially small :)
1M DTB
The decompressor is happy to clobber over other things I would swear which is how people end up in the "oops, my DT was eaten" case when things are placed too close and _not_ relocated prior to booting.
Right but what's the worst case you can come up with? There's folks out there attempting to feed the same kernel into their testboard farm of relatively wild differnet HW but all works on multi_v7_defconfig.
On 08/01/2014 01:46 AM, Hans de Goede wrote: > Automatic booting using an extlinux.conf file requires various > environment variables to be set.
Yes, I suppose we should bump the decompressed kernel size to 24M. The last time we had this conversation, IIRC there was an agreement that since that's the limit of the ARM ISA's branch/jump instruction, that's the largest a kernel image could be (and at that size, no modules could be loaded). That is, unless intermediate trampolines were generated by the linker, which IIRC isn't done.
FWIW, multi_v7_defconfig is only 11MB uncompressed and 5MB compressed, so we're not likely to hit the 16M limit for a while.
1M DTB
Hmm. Some experimentation shows that if the DTB is loaded where the kernel will be decompressed to, then the DTB does indeed get clobbered.
Still, the Tegra default environment already places the DTB 32MB after the decompressed kernel location, so that won't be an issue (unless there's a 24MB kernel with 8MB BSS, which is very unlikely). If we fix the size allocated to the decompressed kernel to be the full 24MB, the issue would then only occur with a 24MB uncompressed kernel with 16MB BSS. That's even more unlikely. For tegra_defconfig or multi_v7_defconfig, BSS is currently 3/8MB and 1/4MB respectively.
>On 08/01/2014 01:46 AM, Hans de Goede wrote: >>Automatic booting using an extlinux.conf file requires various >>environment variables to be set. > >Acked-by: Stephen Warren swarren@nvidia.com > >I'd personally be tempted to set fdt_high=0xffffffff, >initrd_high=0xffffffff to stop U-Boot copying the DT/initrd from the >load location to some other location under 256M, but that's just an >optimization and entirely optional.
Part of why I harp on this is that I've had vendor kernels run past this 16MB limit (some test file had be included in the kernel binary due to some _other_ problem). That's why I moved the am33xx stuff (and other TI bits I could test) to the worst-case must-be-safe limits because you never know what less-than-ideal thing might get thrown at us later on.
Which we do FWIW, "bootm_size=0x10000000\0" is retained by this patch. I think this was discussed/agreed during the initial upstreaming (but I've not checked the archives to confirm my recollection)
Ian.
Right, and that is 256M which is the smallest amount of memory found on any allwinner board (there is only one 256M board, all others are 512M or more).
Regards,
Hans
I think these two changes need to be explained in the commit log. Otherwise looks good.
Ian.
Good idea, I'll amend the commit log for this.
Regards,
Hans
+config FTDFILE
- string "Default ftdfile env setting for this board"
Vagrant just pointed out the typo in all of this to me, whoops ;-)
At least the actual environment name is correct ;-)
8<------------------------------
From 64aeaa14fc0a7672ee4f89f03354558b09a3116a Mon Sep 17 00:00:00 2001
From: Ian Campbell ijc@hellion.org.uk Date: Sat, 30 Aug 2014 22:46:15 +0100 Subject: [PATCH] sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILE
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
Spotted-by: Vagrant Cascadian vagrant@debian.org Signed-off-by: Ian Campbell ijc@hellion.org.uk --- board/sunxi/Kconfig | 2 +- configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/A13-OLinuXinoM_defconfig | 2 +- configs/A13-OLinuXino_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/Auxtek-T004_defconfig | 2 +- configs/Bananapi_defconfig | 2 +- configs/Cubieboard2_FEL_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_FEL_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 2 +- configs/Mele_A1000G_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Mini-X-1Gb_defconfig | 2 +- configs/Mini-X_defconfig | 2 +- configs/ba10_tv_box_defconfig | 2 +- configs/i12-tvbox_defconfig | 2 +- configs/qt840a_defconfig | 2 +- configs/r7-tv-dongle_defconfig | 2 +- include/configs/sunxi-common.h | 2 +- 23 files changed, 23 insertions(+), 23 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index c61c650..877281b 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -36,7 +36,7 @@ config SYS_SOC string default "sunxi"
-config FTDFILE +config FDTFILE string "Default ftdfile env setting for this board"
endif diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index b93ae7d..37dbe9c 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A10_OLINUXINO_L,SPL,AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3),USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-olinuxino-lime.dtb" +CONFIG_FDTFILE="sun4i-a10-olinuxino-lime.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index f206970..8475b16 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A10S_OLINUXINO_M,SPL,AXP152_POWER,SUNXI_EMAC,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPB(10)" -CONFIG_FTDFILE="sun5i-a10s-olinuxino-micro.dtb" +CONFIG_FDTFILE="sun5i-a10s-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 8529dbe..bd135cd 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A13_OLINUXINOM,SPL,CONS_INDEX=2,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(11)" -CONFIG_FTDFILE="sun5i-a13-olinuxino-micro.dtb" +CONFIG_FDTFILE="sun5i-a13-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index c3a12cc..eb3a6c0 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A13_OLINUXINO,SPL,CONS_INDEX=2,AXP209_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(11)" -CONFIG_FTDFILE="sun5i-a13-olinuxino.dtb" +CONFIG_FDTFILE="sun5i-a13-olinuxino.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index c91319d..c9170fa 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="A20_OLINUXINO_M,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-olinuxino-micro.dtb" +CONFIG_FDTFILE="sun7i-a20-olinuxino-micro.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 193019c..0282c08 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AUXTEK_T004,SPL,AXP152_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(13)" -CONFIG_FTDFILE="sun5i-a10s-auxtek-t004.dtb" +CONFIG_FDTFILE="sun5i-a10s-auxtek-t004.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index dc68469..b75215c 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="BANANAPI,SPL,AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-bananapi.dtb" +CONFIG_FDTFILE="sun7i-a20-bananapi.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard2_FEL_defconfig b/configs/Cubieboard2_FEL_defconfig index ae5e25a..353b04a 100644 --- a/configs/Cubieboard2_FEL_defconfig +++ b/configs/Cubieboard2_FEL_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD2,SPL_FEL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-cubieboard2.dtb" +CONFIG_FDTFILE="sun7i-a20-cubieboard2.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index df87edc..19a2550 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD2,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-cubieboard2.dtb" +CONFIG_FDTFILE="sun7i-a20-cubieboard2.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 57bf045..e4d69ba 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIEBOARD,SPL,AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-cubieboard.dtb" +CONFIG_FDTFILE="sun4i-a10-cubieboard.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Cubietruck_FEL_defconfig b/configs/Cubietruck_FEL_defconfig index 790125a..23c5efb 100644 --- a/configs/Cubietruck_FEL_defconfig +++ b/configs/Cubietruck_FEL_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIETRUCK,SPL_FEL,AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-cubietruck.dtb" +CONFIG_FDTFILE="sun7i-a20-cubietruck.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 4ad82e3..710d99a 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CUBIETRUCK,SPL,AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-cubietruck.dtb" +CONFIG_FDTFILE="sun7i-a20-cubietruck.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 22d0446..ccae5d8 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="PCDUINO3,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-pcduino3.dtb" +CONFIG_FDTFILE="sun7i-a20-pcduino3.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/Mele_A1000G_defconfig b/configs/Mele_A1000G_defconfig index fa47fae..9f5c2f5 100644 --- a/configs/Mele_A1000G_defconfig +++ b/configs/Mele_A1000G_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MELE_A1000G,SPL,AXP209_POWER,SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI,USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-a1000.dtb" +CONFIG_FDTFILE="sun4i-a10-a1000.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index d7c156d..4212f73 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MELE_A1000,SPL,AXP209_POWER,SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI,USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-a1000.dtb" +CONFIG_FDTFILE="sun4i-a10-a1000.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mini-X-1Gb_defconfig b/configs/Mini-X-1Gb_defconfig index af0b800..9933efe 100644 --- a/configs/Mini-X-1Gb_defconfig +++ b/configs/Mini-X-1Gb_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MINI_X_1GB,SPL,AXP209_POWER,USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-mini-xplus.dtb" +CONFIG_FDTFILE="sun4i-a10-mini-xplus.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index ea0c786..8a99ba2 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MINI_X,SPL,AXP209_POWER,USB_EHCI" -CONFIG_FTDFILE="sun4i-a10-mini-xplus.dtb" +CONFIG_FDTFILE="sun4i-a10-mini-xplus.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c9961bd..f0e475b 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="BA10_TV_BOX,SPL,AXP209_POWER,SUNXI_EMAC,USB_EHCI,SUNXI_USB_VBUS1_GPIO=SUNXI_GPH(12)" -CONFIG_FTDFILE="sun4i-a10-ba10-tvbox.dtb" +CONFIG_FDTFILE="sun4i-a10-ba10-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN4I=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index b267312..31276e3 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="I12_TVBOX,SPL,AXP209_POWER,SUNXI_GMAC,MACPWR=SUNXI_GPH(21),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-i12-tvbox.dtb" +CONFIG_FDTFILE="sun7i-a20-i12-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/qt840a_defconfig b/configs/qt840a_defconfig index 7360212..35a6aee 100644 --- a/configs/qt840a_defconfig +++ b/configs/qt840a_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="QT840A,SPL,AXP209_POWER,SUNXI_GMAC,MACPWR=SUNXI_GPH(21),USB_EHCI" -CONFIG_FTDFILE="sun7i-a20-i12-tvbox.dtb" +CONFIG_FDTFILE="sun7i-a20-i12-tvbox.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN7I=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 35b66f0..9033297 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -1,5 +1,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="R7DONGLE,SPL,AXP152_POWER,USB_EHCI,SUNXI_USB_VBUS0_GPIO=SUNXI_GPG(13)" -CONFIG_FTDFILE="sun5i-a10s-r7-tv-dongle.dtb" +CONFIG_FDTFILE="sun5i-a10s-r7-tv-dongle.dtb" +S:CONFIG_ARM=y +S:CONFIG_TARGET_SUN5I=y diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index e768921..1d947d7 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -244,7 +244,7 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ MEM_LAYOUT_ENV_SETTINGS \ - "fdtfile=" CONFIG_FTDFILE "\0" \ + "fdtfile=" CONFIG_FDTFILE "\0" \ "console=ttyS0,115200\0" \ BOOTENV
+config FTDFILE
Oops.
Yeah, well if it wasn't I would have noticed as I tested extlinux.conf booting using the fdtfile env. variable to get the dt.
From 64aeaa14fc0a7672ee4f89f03354558b09a3116a Mon Sep 17 00:00:00 2001 From: Ian Campbell ijc@hellion.org.uk Date: Sat, 30 Aug 2014 22:46:15 +0100 Subject: [PATCH] sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILE
The typo is present in the help text too, the patch should probably fix it there too.
Regards,
Hans
- "fdtfile=" CONFIG_FDTFILE "\0" \ "console=ttyS0,115200\0" \ BOOTENV
participants (6)
Chen-Yu Tsai
Dennis Gilmore
Hans de Goede
Ian Campbell
Stephen Warren
