[PATCH 1/2] dt-bindings: mtd: partitions: add binding for U-Boot bootloader
Right now there is no (known) real reason for a custom binding for standard U-Boot partitions. Broadcom's U-Boot however requires extra handling - looking for environment variables subblocks. This commit adds Broadcom specific binding.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- .../bindings/mtd/partitions/u-boot.yaml | 49 +++++++++++++++++++ 1 file changed, 49 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/u-boot.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/u-boot.yaml b/Documentation/devicetree/bindings/mtd/partitions/u-boot.yaml new file mode 100644 index 000000000000..8a88e7d16524 --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/u-boot.yaml @@ -0,0 +1,49 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/u-boot.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: U-Boot bootloader partition + +description: | + U-Boot is a bootlodaer commonly used in embedded devices. It's almost always + located on some kind of flash device. + + Device configuration is stored as a set of environment variables that are + located in a (usually standalone) block of data. + +maintainers: + - Rafał Miłecki rafal@milecki.pl + +allOf: + - $ref: partition.yaml# + +properties: + compatible: + oneOf: + - const: brcm,u-boot + description: | + Broadcom stores environment variables inside a U-Boot partition. They + can be identified by a custom header with magic value. + +unevaluatedProperties: false + +examples: + - | + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + compatible = "brcm,u-boot"; + reg = <0x0 0x100000>; + label = "u-boot"; + }; + + partition@100000 { + reg = <0x100000 0x1ff00000>; + label = "firmware"; + }; + };
Broadcom stores environment variables blocks inside U-Boot partition itself. This driver finds & registers them.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/mtd/parsers/Kconfig | 10 ++++ drivers/mtd/parsers/Makefile | 1 + drivers/mtd/parsers/brcm_u-boot.c | 84 +++++++++++++++++++++++++++++++ 3 files changed, 95 insertions(+) create mode 100644 drivers/mtd/parsers/brcm_u-boot.c
diff --git a/drivers/mtd/parsers/Kconfig b/drivers/mtd/parsers/Kconfig index b43df73927a0..81f2d0a795a6 100644 --- a/drivers/mtd/parsers/Kconfig +++ b/drivers/mtd/parsers/Kconfig @@ -20,6 +20,16 @@ config MTD_BCM63XX_PARTS This provides partition parsing for BCM63xx devices with CFE bootloaders.
+config MTD_BRCM_U_BOOT + tristate "Broadcom's U-Boot partition parser" + depends on ARCH_BCM4908 || COMPILE_TEST + help + Broadcom uses a custom way of storing U-Boot environment variables. + They are placed inside U-Boot partition itself at unspecified offset. + It's possible to locate them by looking for a custom header with a + magic value. This driver does that and creates subpartitions for + each found environment variables block. + config MTD_CMDLINE_PARTS tristate "Command line partition table parsing" depends on MTD diff --git a/drivers/mtd/parsers/Makefile b/drivers/mtd/parsers/Makefile index 2fcf0ab9e7da..23fa4de4016f 100644 --- a/drivers/mtd/parsers/Makefile +++ b/drivers/mtd/parsers/Makefile @@ -2,6 +2,7 @@ obj-$(CONFIG_MTD_AR7_PARTS) += ar7part.o obj-$(CONFIG_MTD_BCM47XX_PARTS) += bcm47xxpart.o obj-$(CONFIG_MTD_BCM63XX_PARTS) += bcm63xxpart.o +obj-$(CONFIG_MTD_BRCM_U_BOOT) += brcm_u-boot.o obj-$(CONFIG_MTD_CMDLINE_PARTS) += cmdlinepart.o obj-$(CONFIG_MTD_OF_PARTS) += ofpart.o ofpart-y += ofpart_core.o diff --git a/drivers/mtd/parsers/brcm_u-boot.c b/drivers/mtd/parsers/brcm_u-boot.c new file mode 100644 index 000000000000..7c338dc7b8f3 --- /dev/null +++ b/drivers/mtd/parsers/brcm_u-boot.c @@ -0,0 +1,84 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright © 2022 Rafał Miłecki rafal@milecki.pl + */ + +#include <linux/module.h> +#include <linux/kernel.h> +#include <linux/slab.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/partitions.h> + +#define BRCM_U_BOOT_MAX_OFFSET 0x200000 +#define BRCM_U_BOOT_STEP 0x1000 + +#define BRCM_U_BOOT_MAX_PARTS 2 + +#define BRCM_U_BOOT_MAGIC 0x75456e76 /* uEnv */ + +struct brcm_u_boot_header { + __le32 magic; + __le32 length; +} __packed; + +static const char *names[BRCM_U_BOOT_MAX_PARTS] = { + "u-boot-env", + "u-boot-env-backup", +}; + +static int brcm_u_boot_parse(struct mtd_info *mtd, + const struct mtd_partition **pparts, + struct mtd_part_parser_data *data) +{ + struct brcm_u_boot_header header; + struct mtd_partition *parts; + size_t bytes_read; + size_t offset; + int err; + int i = 0; + + parts = kcalloc(BRCM_U_BOOT_MAX_PARTS, sizeof(*parts), GFP_KERNEL); + if (!parts) + return -ENOMEM; + + for (offset = 0; + offset < min_t(size_t, mtd->size, BRCM_U_BOOT_MAX_OFFSET); + offset += BRCM_U_BOOT_STEP) { + err = mtd_read(mtd, offset, sizeof(header), &bytes_read, (uint8_t *)&header); + if (err && !mtd_is_bitflip(err)) { + pr_err("Failed to read from %s at 0x%zx: %d\n", mtd->name, offset, err); + continue; + } + + if (le32_to_cpu(header.magic) != BRCM_U_BOOT_MAGIC) + continue; + + parts[i].name = names[i]; + parts[i].offset = offset; + parts[i].size = sizeof(header) + le32_to_cpu(header.length); + i++; + pr_info("offset:0x%zx magic:0x%08x BINGO\n", offset, header.magic); + + if (i == BRCM_U_BOOT_MAX_PARTS) + break; + } + + *pparts = parts; + + return i; +}; + +static const struct of_device_id brcm_u_boot_of_match_table[] = { + { .compatible = "brcm,u-boot" }, + {}, +}; +MODULE_DEVICE_TABLE(of, brcm_u_boot_of_match_table); + +static struct mtd_part_parser brcm_u_boot_mtd_parser = { + .parse_fn = brcm_u_boot_parse, + .name = "brcm_u-boot", + .of_match_table = brcm_u_boot_of_match_table, +}; +module_mtd_part_parser(brcm_u_boot_mtd_parser); + +MODULE_LICENSE("GPL");
Applied to https://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux.git mtd/next, thanks.
Miquel
Reviewed-by: Rob Herring robh@kernel.org
Signed-off-by: Rafał Miłecki rafal@milecki.pl Reviewed-by: Rob Herring robh@kernel.org
Miquel
Miquel Raynal
Rafał Miłecki
Rob Herring
