[U-Boot] [PATCH 0/4] Implant kernel-doc from Linux kernel
This patch series implants slightly modified kernel-doc documentation generator from Linux kernel into U-Boot. First patch pulls in all the necessary components with minor modifications made to them to work with the layout of U-Boot source tree and without kbuild.
Further patch implement CSS to make the HTML documentation look a bit nicer. This patch will eventually (hopefully) be further refined by someone more artistically capable than me ;-)
Next patch implements separate handling for "Example:" section, which in the original kernel-doc was in my opinion mistreated. The example section generated a block of code, but the indentation was removed. Thus this patch does avoid removing the indent.
Finally, the last patch implements example of how to use this kernel-doc to generate U-Boot documentation by documenting the Linker-Generated arrays.
NOTE: This patchset has a cross-dependency on: [PATCH 0/5 V2] Linker-generated arrays
Marek Vasut (4): doc: kerneldoc: Implant DocBook from Linux kernel doc: kerneldoc: Add nicer CSS stylesheet for HTML docs doc: kerneldoc: Implement "Example" section handling doc: kerneldoc: tmpl: Implement template for LG-arrays
Makefile | 7 + doc/DocBook/Makefile | 227 ++++ doc/DocBook/docbook.css | 16 + doc/DocBook/linker_lists.tmpl | 46 + doc/DocBook/stylesheet.xsl | 11 + tools/kernel-doc/Makefile | 44 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2557 +++++++++++++++++++++++++++++++++++++++++ 8 files changed, 3484 insertions(+) create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/docbook.css create mode 100644 doc/DocBook/linker_lists.tmpl create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Mike Frysinger vapier@gentoo.org
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build.
Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400
Signed-off-by: Marek Vasut marex@denx.de --- Makefile | 7 + doc/DocBook/Makefile | 227 ++++ doc/DocBook/stylesheet.xsl | 10 + tools/kernel-doc/Makefile | 44 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2554 +++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 3418 insertions(+) create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
diff --git a/Makefile b/Makefile index a40d4cc..eb9c388 100644 --- a/Makefile +++ b/Makefile @@ -695,6 +695,12 @@ easylogo env gdb: $(MAKE) -C tools/$@ all MTD_VERSION=${MTD_VERSION} gdbtools: gdb
+kernel-doc: + $(MAKE) -C tools/$@ all + +xmldocs pdfdocs psdocs htmldocs mandocs: + $(MAKE) U_BOOT_VERSION=$(U_BOOT_VERSION) -C doc/DocBook/ $@ + tools-all: easylogo env gdb $(VERSION_FILE) $(TIMESTAMP_FILE) $(MAKE) -C tools HOST_TOOLS_ALL=y
@@ -792,6 +798,7 @@ clean: @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s @rm -f $(TIMESTAMP_FILE) $(VERSION_FILE) + @$(MAKE) -C doc/DocBook/ cleandoc @find $(OBJTREE) -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' -o -name '*.su' \ -o -name '*.o' -o -name '*.a' -o -name '*.exe' ) -print \ diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile new file mode 100644 index 0000000..38f244a --- /dev/null +++ b/doc/DocBook/Makefile @@ -0,0 +1,227 @@ +### +# This makefile is used to generate the kernel documentation, +# primarily based on in-line comments in various source files. +# See doc/kernel-doc-nano-HOWTO.txt for instruction in how +# to document the SRC - and how to read it. +# To add a new book the only step required is to add the book to the +# list of DOCBOOKS. + +include $(TOPDIR)/config.mk + +DOCBOOKS := + +### +# The build process is as follows (targets): +# (xmldocs) [by docproc] +# file.tmpl --> file.xml +--> file.ps (psdocs) [by db2ps or xmlto] +# +--> file.pdf (pdfdocs) [by db2pdf or xmlto] +# +--> DIR=file (htmldocs) [by xmlto] +# +--> man/ (mandocs) [by xmlto] + + +# for PDF and PS output you can choose between xmlto and docbook-utils tools +PDF_METHOD = $(prefer-db2x) +PS_METHOD = $(prefer-db2x) + + +### +# The targets that may be used. +PHONY += $(obj).depend xmldocs sgmldocs psdocs pdfdocs htmldocs mandocs installmandocs cleandocs + +BOOKS := $(addprefix $(OBJTREE)/doc/DocBook/,$(DOCBOOKS)) +xmldocs: $(BOOKS) +sgmldocs: xmldocs + +PS := $(patsubst %.xml, %.ps, $(BOOKS)) +psdocs: $(PS) + +PDF := $(patsubst %.xml, %.pdf, $(BOOKS)) +pdfdocs: $(PDF) + +HTML := $(sort $(patsubst %.xml, %.html, $(BOOKS))) +htmldocs: $(HTML) + $(call build_main_index) + $(call build_images) + $(call install_media_images) + +MAN := $(patsubst %.xml, %.9, $(BOOKS)) +mandocs: $(MAN) + +installmandocs: mandocs + mkdir -p /usr/local/man/man9/ + install doc/DocBook/man/*.9.gz /usr/local/man/man9/ + +### +#External programs used +KERNELDOC = $(SRCTREE)/tools/kernel-doc/kernel-doc +DOCPROC = $(OBJTREE)/tools/kernel-doc/docproc + +XMLTOFLAGS = -m $(SRCTREE)/doc/DocBook/stylesheet.xsl +XMLTOFLAGS += --skip-validation + +### +# DOCPROC is used for two purposes: +# 1) To generate a dependency list for a .tmpl file +# 2) To preprocess a .tmpl file and call kernel-doc with +# appropriate parameters. +# The following rules are used to generate the .xml documentation +# required to generate the final targets. (ps, pdf, html). +%.xml: %.tmpl + $(DOCPROC) doc $< >$@ + +sinclude $(obj).depend +$(obj).depend: $(patsubst %.xml, %.tmpl, $(DOCBOOKS)) + rm -f $(obj).depend ; \ + touch $(obj).depend ; \ + for file in $^ ; do \ + xmlfile=`echo "$${file}" | \ + sed "s/tmpl$$/xml/"` ; \ + echo -n "$${xmlfile}: ">> $(obj).depend ; \ + $(DOCPROC) depend $$file >> $(obj).depend ; \ + echo -e "\n\t$(DOCPROC) doc $< >$${xmlfile} " >> \ + $(obj).depend ; \ + done + +### +# Changes in kernel-doc force a rebuild of all documentation +$(BOOKS): $(KERNELDOC) + +notfoundtemplate = echo "*** You have to install docbook-utils or xmlto ***"; \ + exit 1 +db2xtemplate = db2TYPE -o $(dir $@) $< +xmltotemplate = xmlto TYPE $(XMLTOFLAGS) -o $(dir $@) $< + +# determine which methods are available +ifeq ($(shell which db2ps >/dev/null 2>&1 && echo found),found) + use-db2x = db2x + prefer-db2x = db2x +else + use-db2x = notfound + prefer-db2x = $(use-xmlto) +endif +ifeq ($(shell which xmlto >/dev/null 2>&1 && echo found),found) + use-xmlto = xmlto + prefer-xmlto = xmlto +else + use-xmlto = notfound + prefer-xmlto = $(use-db2x) +endif + +# the commands, generated from the chosen template +quiet_cmd_db2ps = PS $@ + cmd_db2ps = $(subst TYPE,ps, $($(PS_METHOD)template)) +%.ps : %.xml + $(call cmd_db2ps) + +quiet_cmd_db2pdf = PDF $@ + cmd_db2pdf = $(subst TYPE,pdf, $($(PDF_METHOD)template)) +%.pdf : %.xml + $(call cmd_db2pdf) + + +index = index.html +main_idx = $(index) +build_main_index = rm -rf $(main_idx); \ + echo '<h1>U-Boot Bootloader HTML Documentation</h1>' >> $(main_idx) && \ + echo '<h2>U-Boot Version: $(U_BOOT_VERSION)</h2>' >> $(main_idx) && \ + cat $(HTML) >> $(main_idx) + +# To work around bug [1] in docbook-xsl-stylesheets 1.76.1 , generate only html +# docs instead of xhtml with xmlto. +# [1] http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=654338 +quiet_cmd_db2html = HTML $@ + cmd_db2html = xmlto html $(XMLTOFLAGS) -o $(patsubst %.html,%,$@) $< && \ + echo '<a HREF="$(patsubst %.html,%,$(notdir $@))/index.html"> \ + $(patsubst %.html,%,$(notdir $@))</a><p>' > $@ + +%.html: %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + @rm -rf $@ $(patsubst %.html,%,$@) + $(call cmd_db2html) + @if [ ! -z "$(PNG-$(basename $(notdir $@)))" ]; then \ + cp $(PNG-$(basename $(notdir $@))) $(patsubst %.html,%,$@); fi + +quiet_cmd_db2man = MAN $@ + cmd_db2man = if grep -q refentry $<; then xmlto man $(XMLTOFLAGS) -o $(obj)/man $< ; gzip -f $(obj)/man/*.9; fi +%.9 : %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + $(Q)mkdir -p $(obj)man + $(call cmd_db2man) + @touch $@ + +### +# Rules to generate postscripts and PNG images from .fig format files +quiet_cmd_fig2eps = FIG2EPS $@ + cmd_fig2eps = fig2dev -Leps $< $@ + +%.eps: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2eps) + +quiet_cmd_fig2png = FIG2PNG $@ + cmd_fig2png = fig2dev -Lpng $< $@ + +%.png: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2png) + +### +# Rule to convert a .c file to inline XML documentation + gen_xml = : + quiet_gen_xml = echo ' GEN $@' +silent_gen_xml = : +%.xml: %.c + @$($(quiet)gen_xml) + @( \ + echo "<programlisting>"; \ + expand --tabs=8 < $< | \ + sed -e "s/&/\&/g" \ + -e "s/</\</g" \ + -e "s/>/\>/g"; \ + echo "</programlisting>") > $@ + +### +# Help targets as used by the top-level makefile +dochelp: + @echo ' U-Boot bootloader internal documentation in different formats:' + @echo ' htmldocs - HTML' + @echo ' pdfdocs - PDF' + @echo ' psdocs - Postscript' + @echo ' xmldocs - XML DocBook' + @echo ' mandocs - man pages' + @echo ' installmandocs - install man pages generated by mandocs' + @echo ' cleandocs - clean all generated DocBook files' + +### +# Temporary files left by various tools +clean-files := $(DOCBOOKS) \ + $(patsubst %.xml, %.dvi, $(DOCBOOKS)) \ + $(patsubst %.xml, %.aux, $(DOCBOOKS)) \ + $(patsubst %.xml, %.tex, $(DOCBOOKS)) \ + $(patsubst %.xml, %.log, $(DOCBOOKS)) \ + $(patsubst %.xml, %.out, $(DOCBOOKS)) \ + $(patsubst %.xml, %.ps, $(DOCBOOKS)) \ + $(patsubst %.xml, %.pdf, $(DOCBOOKS)) \ + $(patsubst %.xml, %.html, $(DOCBOOKS)) \ + $(patsubst %.xml, %.9, $(DOCBOOKS)) \ + $(index) + +clean-dirs := $(patsubst %.xml,%,$(DOCBOOKS)) man + +cleandocs: + rm -f $(obj).depend + $(Q)rm -f $(call objectify, $(clean-files)) + $(Q)rm -rf $(call objectify, $(clean-dirs)) + +# Declare the contents of the .PHONY variable as phony. We keep that +# information in a variable se we can use it in if_changed and friends. + +.PHONY: $(PHONY) diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl new file mode 100644 index 0000000..85b2527 --- /dev/null +++ b/doc/DocBook/stylesheet.xsl @@ -0,0 +1,10 @@ +<?xml version="1.0" encoding="UTF-8"?> +<stylesheet xmlns="http://www.w3.org/1999/XSL/Transform" version="1.0"> +<param name="chunk.quietly">1</param> +<param name="funcsynopsis.style">ansi</param> +<param name="funcsynopsis.tabular.threshold">80</param> +<param name="callout.graphics">0</param> +<!-- <param name="paper.type">A4</param> --> +<param name="generate.section.toc.level">2</param> +<param name="use.id.as.filename">1</param> +</stylesheet> diff --git a/tools/kernel-doc/Makefile b/tools/kernel-doc/Makefile new file mode 100644 index 0000000..9d0e159 --- /dev/null +++ b/tools/kernel-doc/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (C) 2012 Marek Vasut marex@denx.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +BIN_FILES-y += docproc +SRC_FILES-y += docproc.c + +HOSTSRC += $(addprefix $(SRCTREE)/tools/kernel-doc/,$(SRC_FILES-y)) +HOSTBIN := $(addprefix $(obj),$(sort $(BIN_FILES-y))) + +all: $(HOSTBIN) + +$(obj)docproc: $(HOSTSRC) $(HEADERS) + $(HOSTCC) $(HOSTCFLAGS_NOPED) $(HOSTLDFLAGS) -o $@ $(HOSTSRC) + $(HOSTSTRIP) $@ + +clean: + rm -rf docproc + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/kernel-doc/docproc.c b/tools/kernel-doc/docproc.c new file mode 100644 index 0000000..8bc47b0 --- /dev/null +++ b/tools/kernel-doc/docproc.c @@ -0,0 +1,576 @@ +/* + * docproc is a simple preprocessor for the template files + * used as placeholders for the kernel internal documentation. + * docproc is used for documentation-frontend and + * dependency-generator. + * The two usages have in common that they require + * some knowledge of the .tmpl syntax, therefore they + * are kept together. + * + * documentation-frontend + * Scans the template file and call kernel-doc for + * all occurrences of ![EIF]file + * Beforehand each referenced file is scanned for + * any symbols that are exported via these macros: + * EXPORT_SYMBOL(), EXPORT_SYMBOL_GPL(), & + * EXPORT_SYMBOL_GPL_FUTURE() + * This is used to create proper -function and + * -nofunction arguments in calls to kernel-doc. + * Usage: docproc doc file.tmpl + * + * dependency-generator: + * Scans the template file and list all files + * referenced in a format recognized by make. + * Usage: docproc depend file.tmpl + * Writes dependency information to stdout + * in the following format: + * file.tmpl src.c src2.c + * The filenames are obtained from the following constructs: + * !Efilename + * !Ifilename + * !Dfilename + * !Ffilename + * !Pfilename + * + */ + +#define _GNU_SOURCE +#include <stdio.h> +#include <stdlib.h> +#include <string.h> +#include <ctype.h> +#include <unistd.h> +#include <limits.h> +#include <errno.h> +#include <sys/types.h> +#include <sys/wait.h> + +/* exitstatus is used to keep track of any failing calls to kernel-doc, + * but execution continues. */ +int exitstatus = 0; + +typedef void DFL(char *); +DFL *defaultline; + +typedef void FILEONLY(char * file); +FILEONLY *internalfunctions; +FILEONLY *externalfunctions; +FILEONLY *symbolsonly; +FILEONLY *findall; + +typedef void FILELINE(char * file, char * line); +FILELINE * singlefunctions; +FILELINE * entity_system; +FILELINE * docsection; + +#define MAXLINESZ 2048 +#define MAXFILES 250 +#define KERNELDOCPATH "tools/kernel-doc/" +#define KERNELDOC "kernel-doc" +#define DOCBOOK "-docbook" +#define LIST "-list" +#define FUNCTION "-function" +#define NOFUNCTION "-nofunction" +#define NODOCSECTIONS "-no-doc-sections" + +static char *srctree, *kernsrctree; + +static char **all_list = NULL; +static int all_list_len = 0; + +static void consume_symbol(const char *sym) +{ + int i; + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + if (strcmp(sym, all_list[i])) + continue; + all_list[i] = NULL; + break; + } +} + +static void usage (void) +{ + fprintf(stderr, "Usage: docproc {doc|depend} file\n"); + fprintf(stderr, "Input is read from file.tmpl. Output is sent to stdout\n"); + fprintf(stderr, "doc: frontend when generating kernel documentation\n"); + fprintf(stderr, "depend: generate list of files referenced within file\n"); + fprintf(stderr, "Environment variable SRCTREE: absolute path to sources.\n"); + fprintf(stderr, " KBUILD_SRC: absolute path to kernel source tree.\n"); +} + +/* + * Execute kernel-doc with parameters given in svec + */ +static void exec_kernel_doc(char **svec) +{ + pid_t pid; + int ret; + char real_filename[PATH_MAX + 1]; + /* Make sure output generated so far are flushed */ + fflush(stdout); + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, svec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; +} + +/* Types used to create list of all exported symbols in a number of files */ +struct symbols +{ + char *name; +}; + +struct symfile +{ + char *filename; + struct symbols *symbollist; + int symbolcnt; +}; + +struct symfile symfilelist[MAXFILES]; +int symfilecnt = 0; + +static void add_new_symbol(struct symfile *sym, char * symname) +{ + sym->symbollist = + realloc(sym->symbollist, (sym->symbolcnt + 1) * sizeof(char *)); + sym->symbollist[sym->symbolcnt++].name = strdup(symname); +} + +/* Add a filename to the list */ +static struct symfile * add_new_file(char * filename) +{ + symfilelist[symfilecnt++].filename = strdup(filename); + return &symfilelist[symfilecnt - 1]; +} + +/* Check if file already are present in the list */ +static struct symfile * filename_exist(char * filename) +{ + int i; + for (i=0; i < symfilecnt; i++) + if (strcmp(symfilelist[i].filename, filename) == 0) + return &symfilelist[i]; + return NULL; +} + +/* + * List all files referenced within the template file. + * Files are separated by tabs. + */ +static void adddep(char * file) { printf("\t%s", file); } +static void adddep2(char * file, char * line) { line = line; adddep(file); } +static void noaction(char * line) { line = line; } +static void noaction2(char * file, char * line) { file = file; line = line; } + +/* Echo the line without further action */ +static void printline(char * line) { printf("%s", line); } + +/* + * Find all symbols in filename that are exported with EXPORT_SYMBOL & + * EXPORT_SYMBOL_GPL (& EXPORT_SYMBOL_GPL_FUTURE implicitly). + * All symbols located are stored in symfilelist. + */ +static void find_export_symbols(char * filename) +{ + FILE * fp; + struct symfile *sym; + char line[MAXLINESZ]; + if (filename_exist(filename) == NULL) { + char real_filename[PATH_MAX + 1]; + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, srctree, PATH_MAX); + strncat(real_filename, "/", PATH_MAX - strlen(real_filename)); + strncat(real_filename, filename, + PATH_MAX - strlen(real_filename)); + sym = add_new_file(filename); + fp = fopen(real_filename, "r"); + if (fp == NULL) { + fprintf(stderr, "docproc: "); + perror(real_filename); + exit(1); + } + while (fgets(line, MAXLINESZ, fp)) { + char *p; + char *e; + if (((p = strstr(line, "EXPORT_SYMBOL_GPL")) != NULL) || + ((p = strstr(line, "EXPORT_SYMBOL")) != NULL)) { + /* Skip EXPORT_SYMBOL{_GPL} */ + while (isalnum(*p) || *p == '_') + p++; + /* Remove parentheses & additional whitespace */ + while (isspace(*p)) + p++; + if (*p != '(') + continue; /* Syntax error? */ + else + p++; + while (isspace(*p)) + p++; + e = p; + while (isalnum(*e) || *e == '_') + e++; + *e = '\0'; + add_new_symbol(sym, p); + } + } + fclose(fp); + } +} + +/* + * Document all external or internal functions in a file. + * Call kernel-doc with following parameters: + * kernel-doc -docbook -nofunction function_name1 filename + * Function names are obtained from all the src files + * by find_export_symbols. + * intfunc uses -nofunction + * extfunc uses -function + */ +static void docfunctions(char * filename, char * type) +{ + int i,j; + int symcnt = 0; + int idx = 0; + char **vec; + + for (i=0; i <= symfilecnt; i++) + symcnt += symfilelist[i].symbolcnt; + vec = malloc((2 + 2 * symcnt + 3) * sizeof(char *)); + if (vec == NULL) { + perror("docproc: "); + exit(1); + } + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + vec[idx++] = NODOCSECTIONS; + for (i=0; i < symfilecnt; i++) { + struct symfile * sym = &symfilelist[i]; + for (j=0; j < sym->symbolcnt; j++) { + vec[idx++] = type; + consume_symbol(sym->symbollist[j].name); + vec[idx++] = sym->symbollist[j].name; + } + } + vec[idx++] = filename; + vec[idx] = NULL; + printf("<!-- %s -->\n", filename); + exec_kernel_doc(vec); + fflush(stdout); + free(vec); +} +static void intfunc(char * filename) { docfunctions(filename, NOFUNCTION); } +static void extfunc(char * filename) { docfunctions(filename, FUNCTION); } + +/* + * Document specific function(s) in a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function function1 [-function function2] + */ +static void singfunc(char * filename, char * line) +{ + char *vec[200]; /* Enough for specific functions */ + int i, idx = 0; + int startofsym = 1; + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + + /* Split line up in individual parameters preceded by FUNCTION */ + for (i=0; line[i]; i++) { + if (isspace(line[i])) { + line[i] = '\0'; + startofsym = 1; + continue; + } + if (startofsym) { + startofsym = 0; + vec[idx++] = FUNCTION; + vec[idx++] = &line[i]; + } + } + for (i = 0; i < idx; i++) { + if (strcmp(vec[i], FUNCTION)) + continue; + consume_symbol(vec[i + 1]); + } + vec[idx++] = filename; + vec[idx] = NULL; + exec_kernel_doc(vec); +} + +/* + * Insert specific documentation section from a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function "doc section" filename + */ +static void docsect(char *filename, char *line) +{ + char *vec[6]; /* kerneldoc -docbook -function "section" file NULL */ + char *s; + + for (s = line; *s; s++) + if (*s == '\n') + *s = '\0'; + + if (asprintf(&s, "DOC: %s", line) < 0) { + perror("asprintf"); + exit(1); + } + consume_symbol(s); + free(s); + + vec[0] = KERNELDOC; + vec[1] = DOCBOOK; + vec[2] = FUNCTION; + vec[3] = line; + vec[4] = filename; + vec[5] = NULL; + exec_kernel_doc(vec); +} + +static void find_all_symbols(char *filename) +{ + char *vec[4]; /* kerneldoc -list file NULL */ + pid_t pid; + int ret, i, count, start; + char real_filename[PATH_MAX + 1]; + int pipefd[2]; + char *data, *str; + size_t data_len = 0; + + vec[0] = KERNELDOC; + vec[1] = LIST; + vec[2] = filename; + vec[3] = NULL; + + if (pipe(pipefd)) { + perror("pipe"); + exit(1); + } + + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + close(pipefd[0]); + dup2(pipefd[1], 1); + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, vec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + close(pipefd[1]); + data = malloc(4096); + do { + while ((ret = read(pipefd[0], + data + data_len, + 4096)) > 0) { + data_len += ret; + data = realloc(data, data_len + 4096); + } + } while (ret == -EAGAIN); + if (ret != 0) { + perror("read"); + exit(1); + } + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; + + count = 0; + /* poor man's strtok, but with counting */ + for (i = 0; i < data_len; i++) { + if (data[i] == '\n') { + count++; + data[i] = '\0'; + } + } + start = all_list_len; + all_list_len += count; + all_list = realloc(all_list, sizeof(char *) * all_list_len); + str = data; + for (i = 0; i < data_len && start != all_list_len; i++) { + if (data[i] == '\0') { + all_list[start] = str; + str = data + i + 1; + start++; + } + } +} + +/* + * Parse file, calling action specific functions for: + * 1) Lines containing !E + * 2) Lines containing !I + * 3) Lines containing !D + * 4) Lines containing !F + * 5) Lines containing !P + * 6) Lines containing !C + * 7) Default lines - lines not matching the above + */ +static void parse_file(FILE *infile) +{ + char line[MAXLINESZ]; + char * s; + while (fgets(line, MAXLINESZ, infile)) { + if (line[0] == '!') { + s = line + 2; + switch (line[1]) { + case 'E': + while (*s && !isspace(*s)) s++; + *s = '\0'; + externalfunctions(line+2); + break; + case 'I': + while (*s && !isspace(*s)) s++; + *s = '\0'; + internalfunctions(line+2); + break; + case 'D': + while (*s && !isspace(*s)) s++; + *s = '\0'; + symbolsonly(line+2); + break; + case 'F': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* function names */ + while (isspace(*s)) + s++; + singlefunctions(line +2, s); + break; + case 'P': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* DOC: section name */ + while (isspace(*s)) + s++; + docsection(line + 2, s); + break; + case 'C': + while (*s && !isspace(*s)) s++; + *s = '\0'; + if (findall) + findall(line+2); + break; + default: + defaultline(line); + } + } else { + defaultline(line); + } + } + fflush(stdout); +} + + +int main(int argc, char *argv[]) +{ + FILE * infile; + int i; + + srctree = getenv("SRCTREE"); + if (!srctree) + srctree = getcwd(NULL, 0); + kernsrctree = getenv("KBUILD_SRC"); + if (!kernsrctree || !*kernsrctree) + kernsrctree = srctree; + if (argc != 3) { + usage(); + exit(1); + } + /* Open file, exit on error */ + infile = fopen(argv[2], "r"); + if (infile == NULL) { + fprintf(stderr, "docproc: "); + perror(argv[2]); + exit(2); + } + + if (strcmp("doc", argv[1]) == 0) { + /* Need to do this in two passes. + * First pass is used to collect all symbols exported + * in the various files; + * Second pass generate the documentation. + * This is required because some functions are declared + * and exported in different files :-(( + */ + /* Collect symbols */ + defaultline = noaction; + internalfunctions = find_export_symbols; + externalfunctions = find_export_symbols; + symbolsonly = find_export_symbols; + singlefunctions = noaction2; + docsection = noaction2; + findall = find_all_symbols; + parse_file(infile); + + /* Rewind to start from beginning of file again */ + fseek(infile, 0, SEEK_SET); + defaultline = printline; + internalfunctions = intfunc; + externalfunctions = extfunc; + symbolsonly = printline; + singlefunctions = singfunc; + docsection = docsect; + findall = NULL; + + parse_file(infile); + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + fprintf(stderr, "Warning: didn't use docs for %s\n", + all_list[i]); + } + } else if (strcmp("depend", argv[1]) == 0) { + /* Create first part of dependency chain + * file.tmpl */ + printf("%s\t", argv[2]); + defaultline = noaction; + internalfunctions = adddep; + externalfunctions = adddep; + symbolsonly = adddep; + singlefunctions = adddep2; + docsection = adddep2; + findall = adddep; + parse_file(infile); + printf("\n"); + } else { + fprintf(stderr, "Unknown option: %s\n", argv[1]); + exit(1); + } + fclose(infile); + fflush(stdout); + return exitstatus; +} diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc new file mode 100755 index 0000000..8848efd --- /dev/null +++ b/tools/kernel-doc/kernel-doc @@ -0,0 +1,2554 @@ +#!/usr/bin/perl -w + +use strict; + +## Copyright (c) 1998 Michael Zucchi, All Rights Reserved ## +## Copyright (C) 2000, 1 Tim Waugh twaugh@redhat.com ## +## Copyright (C) 2001 Simon Huggins ## +## Copyright (C) 2005-2012 Randy Dunlap ## +## Copyright (C) 2012 Dan Luedtke ## +## ## +## #define enhancements by Armin Kuster akuster@mvista.com ## +## Copyright (c) 2000 MontaVista Software, Inc. ## +## ## +## This software falls under the GNU General Public License. ## +## Please read the COPYING file for more information ## + +# 18/01/2001 - Cleanups +# Functions prototyped as foo(void) same as foo() +# Stop eval'ing where we don't need to. +# -- huggie@earth.li + +# 27/06/2001 - Allowed whitespace after initial "/**" and +# allowed comments before function declarations. +# -- Christian Kreibich ck@whoop.org + +# Still to do: +# - add perldoc documentation +# - Look more closely at some of the scarier bits :) + +# 26/05/2001 - Support for separate source and object trees. +# Return error code. +# Keith Owens kaos@ocs.com.au + +# 23/09/2001 - Added support for typedefs, structs, enums and unions +# Support for Context section; can be terminated using empty line +# Small fixes (like spaces vs. \s in regex) +# -- Tim Jansen tim@tjansen.de + +# 25/07/2012 - Added support for HTML5 +# -- Dan Luedtke mail@danrl.de + +# +# This will read a 'c' file and scan for embedded comments in the +# style of gnome comments (+minor extensions - see below). +# + +# Note: This only supports 'c'. + +# usage: +# kernel-doc [ -docbook | -html | -html5 | -text | -man | -list ] +# [ -no-doc-sections ] +# [ -function funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# or +# [ -nofunction funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# +# Set output format using one of -docbook -html -html5 -text or -man. +# Default is man. +# The -list format is for internal use by docproc. +# +# -no-doc-sections +# Do not output DOC: sections +# +# -function funcname +# If set, then only generate documentation for the given function(s) or +# DOC: section titles. All other functions and DOC: sections are ignored. +# +# -nofunction funcname +# If set, then only generate documentation for the other function(s)/DOC: +# sections. Cannot be used together with -function (yes, that's a bug -- +# perl hackers can fix it 8)) +# +# c files - list of 'c' files to process +# +# All output goes to stdout, with errors to stderr. + +# +# format of comments. +# In the following table, (...)? signifies optional structure. +# (...)* signifies 0 or more structure elements +# /** +# * function_name(:)? (- short description)? +# (* @parameterx: (description of parameter x)?)* +# (* a blank line)? +# * (Description:)? (Description of function)? +# * (section header: (section description)? )* +# (*)?*/ +# +# So .. the trivial example would be: +# +# /** +# * my_function +# */ +# +# If the Description: header tag is omitted, then there must be a blank line +# after the last parameter specification. +# e.g. +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * +# * Does my stuff explained. +# */ +# +# or, could also use: +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * Description: Does my stuff explained. +# */ +# etc. +# +# Besides functions you can also write documentation for structs, unions, +# enums and typedefs. Instead of the function name you must write the name +# of the declaration; the struct/union/enum/typedef must always precede +# the name. Nesting of declarations is not supported. +# Use the argument mechanism to document members or constants. +# e.g. +# /** +# * struct my_struct - short description +# * @a: first member +# * @b: second member +# * +# * Longer description +# */ +# struct my_struct { +# int a; +# int b; +# /* private: */ +# int c; +# }; +# +# All descriptions can be multiline, except the short function description. +# +# You can also add additional sections. When documenting kernel functions you +# should document the "Context:" of the function, e.g. whether the functions +# can be called form interrupts. Unlike other sections you can end it with an +# empty line. +# Example-sections should contain the string EXAMPLE so that they are marked +# appropriately in DocBook. +# +# Example: +# /** +# * user_function - function that can only be called in user context +# * @a: some argument +# * Context: !in_interrupt() +# * +# * Some description +# * Example: +# * user_function(22); +# */ +# ... +# +# +# All descriptive text is further processed, scanning for the following special +# patterns, which are highlighted appropriately. +# +# 'funcname()' - function +# '$ENVVAR' - environmental variable +# '&struct_name' - name of a structure (up to two words including 'struct') +# '@parameter' - name of a parameter +# '%CONST' - name of a constant. + +## init lots of data + +my $errors = 0; +my $warnings = 0; +my $anon_struct_union = 0; + +# match expressions used to find embedded type information +my $type_constant = '%([-_\w]+)'; +my $type_func = '(\w+)()'; +my $type_param = '@(\w+)'; +my $type_struct = '&((struct\s*)*[_\w]+)'; +my $type_struct_xml = '\&((struct\s*)*[_\w]+)'; +my $type_env = '($\w+)'; + +# Output conversion substitutions. +# One for each output format + +# these work fairly well +my %highlights_html = ( $type_constant, "<i>$1</i>", + $type_func, "<b>$1</b>", + $type_struct_xml, "<i>$1</i>", + $type_env, "<b><i>$1</i></b>", + $type_param, "<tt><b>$1</b></tt>" ); +my $local_lt = "\\\\lt:"; +my $local_gt = "\\\\gt:"; +my $blankline_html = $local_lt . "p" . $local_gt; # was "<p>" + +# html version 5 +my %highlights_html5 = ( $type_constant, "<span class="const">$1</span>", + $type_func, "<span class="func">$1</span>", + $type_struct_xml, "<span class="struct">$1</span>", + $type_env, "<span class="env">$1</span>", + $type_param, "<span class="param">$1</span>" ); +my $blankline_html5 = $local_lt . "br /" . $local_gt; + +# XML, docbook format +my %highlights_xml = ( "([^=])\"([^\"<]+)\"", "$1<quote>$2</quote>", + $type_constant, "<constant>$1</constant>", + $type_func, "<function>$1</function>", + $type_struct_xml, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_xml = $local_lt . "/para" . $local_gt . $local_lt . "para" . $local_gt . "\n"; + +# gnome, docbook format +my %highlights_gnome = ( $type_constant, "<replaceable class="option">$1</replaceable>", + $type_func, "<function>$1</function>", + $type_struct, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_gnome = "</para><para>\n"; + +# these are pretty rough +my %highlights_man = ( $type_constant, "$1", + $type_func, "\\fB$1\\fP", + $type_struct, "\\fI$1\\fP", + $type_param, "\\fI$1\\fP" ); +my $blankline_man = ""; + +# text-mode +my %highlights_text = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_text = ""; + +# list mode +my %highlights_list = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_list = ""; + +# read arguments +if ($#ARGV == -1) { + usage(); +} + +my $kernelversion; +my $dohighlight = ""; + +my $verbose = 0; +my $output_mode = "man"; +my $no_doc_sections = 0; +my %highlights = %highlights_man; +my $blankline = $blankline_man; +my $modulename = "Bootloader API"; +my $function_only = 0; +my $man_date = ('January', 'February', 'March', 'April', 'May', 'June', + 'July', 'August', 'September', 'October', + 'November', 'December')[(localtime)[4]] . + " " . ((localtime)[5]+1900); + +# Essentially these are globals. +# They probably want to be tidied up, made more localised or something. +# CAVEAT EMPTOR! Some of the others I localised may not want to be, which +# could cause "use of undefined value" or other bugs. +my ($function, %function_table, %parametertypes, $declaration_purpose); +my ($type, $declaration_name, $return_type); +my ($newsection, $newcontents, $prototype, $brcount, %source_map); + +if (defined($ENV{'KBUILD_VERBOSE'})) { + $verbose = "$ENV{'KBUILD_VERBOSE'}"; +} + +# Generated docbook code is inserted in a template at a point where +# docbook v3.1 requires a non-zero sequence of RefEntry's; see: +# http://www.oasis-open.org/docbook/documentation/reference/html/refentry.html +# We keep track of number of generated entries and generate a dummy +# if needs be to ensure the expanded template can be postprocessed +# into html. +my $section_counter = 0; + +my $lineprefix=""; + +# states +# 0 - normal code +# 1 - looking for function name +# 2 - scanning field start. +# 3 - scanning prototype. +# 4 - documentation block +my $state; +my $in_doc_sect; + +#declaration types: can be +# 'function', 'struct', 'union', 'enum', 'typedef' +my $decl_type; + +my $doc_special = "@%$&"; + +my $doc_start = '^/**\s*$'; # Allow whitespace at end of comment start. +my $doc_end = '*/'; +my $doc_com = '\s**\s*'; +my $doc_decl = $doc_com . '(\w+)'; +my $doc_sect = $doc_com . '([' . $doc_special . ']?[\w\s]+):(.*)'; +my $doc_content = $doc_com . '(.*)'; +my $doc_block = $doc_com . 'DOC:\s*(.*)?'; + +my %constants; +my %parameterdescs; +my @parameterlist; +my %sections; +my @sectionlist; +my $sectcheck; +my $struct_actual; + +my $contents = ""; +my $section_default = "Description"; # default section +my $section_intro = "Introduction"; +my $section = $section_default; +my $section_context = "Context"; + +my $undescribed = "-- undescribed --"; + +reset_state(); + +while ($ARGV[0] =~ m/^-(.*)/) { + my $cmd = shift @ARGV; + if ($cmd eq "-html") { + $output_mode = "html"; + %highlights = %highlights_html; + $blankline = $blankline_html; + } elsif ($cmd eq "-html5") { + $output_mode = "html5"; + %highlights = %highlights_html5; + $blankline = $blankline_html5; + } elsif ($cmd eq "-man") { + $output_mode = "man"; + %highlights = %highlights_man; + $blankline = $blankline_man; + } elsif ($cmd eq "-text") { + $output_mode = "text"; + %highlights = %highlights_text; + $blankline = $blankline_text; + } elsif ($cmd eq "-docbook") { + $output_mode = "xml"; + %highlights = %highlights_xml; + $blankline = $blankline_xml; + } elsif ($cmd eq "-list") { + $output_mode = "list"; + %highlights = %highlights_list; + $blankline = $blankline_list; + } elsif ($cmd eq "-gnome") { + $output_mode = "gnome"; + %highlights = %highlights_gnome; + $blankline = $blankline_gnome; + } elsif ($cmd eq "-module") { # not needed for XML, inherits from calling document + $modulename = shift @ARGV; + } elsif ($cmd eq "-function") { # to only output specific functions + $function_only = 1; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-nofunction") { # to only output specific functions + $function_only = 2; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-v") { + $verbose = 1; + } elsif (($cmd eq "-h") || ($cmd eq "--help")) { + usage(); + } elsif ($cmd eq '-no-doc-sections') { + $no_doc_sections = 1; + } +} + +# continue execution near EOF; + +sub usage { + print "Usage: $0 [ -docbook | -html | -html5 | -text | -man | -list ]\n"; + print " [ -no-doc-sections ]\n"; + print " [ -function funcname [ -function funcname ...] ]\n"; + print " [ -nofunction funcname [ -nofunction funcname ...] ]\n"; + print " [ -v ]\n"; + print " c source file(s) > outputfile\n"; + print " -v : verbose output, more warnings & other info listed\n"; + exit 1; +} + +# get kernel version from env +sub get_kernel_version() { + my $version = 'unknown kernel version'; + + if (defined($ENV{'U_BOOT_VERSION'})) { + $version = $ENV{'U_BOOT_VERSION'}; + } + return $version; +} + +## +# dumps section contents to arrays/hashes intended for that purpose. +# +sub dump_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($name =~ m/$type_constant/) { + $name = $1; +# print STDERR "constant section '$1' = '$contents'\n"; + $constants{$name} = $contents; + } elsif ($name =~ m/$type_param/) { +# print STDERR "parameter def '$1' = '$contents'\n"; + $name = $1; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } elsif ($name eq "@...") { +# print STDERR "parameter def '...' = '$contents'\n"; + $name = "..."; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } else { +# print STDERR "other section '$name' = '$contents'\n"; + if (defined($sections{$name}) && ($sections{$name} ne "")) { + print STDERR "Error(${file}:$.): duplicate section name '$name'\n"; + ++$errors; + } + $sections{$name} = $contents; + push @sectionlist, $name; + } +} + +## +# dump DOC: section after checking that it should go out +# +sub dump_doc_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($no_doc_sections) { + return; + } + + if (($function_only == 0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + dump_section($file, $name, $contents); + output_blockhead({'sectionlist' => @sectionlist, + 'sections' => %sections, + 'module' => $modulename, + 'content-only' => ($function_only != 0), }); + } +} + +## +# output function +# +# parameterdescs, a hash. +# function => "function name" +# parameterlist => @list of parameters +# parameterdescs => %parameter descriptions +# sectionlist => @list of sections +# sections => %section descriptions +# + +sub output_highlight { + my $contents = join "\n",@_; + my $line; + +# DEBUG +# if (!defined $contents) { +# use Carp; +# confess "output_highlight got called with no args?\n"; +# } + + if ($output_mode eq "html" || $output_mode eq "html5" || + $output_mode eq "xml") { + $contents = local_unescape($contents); + # convert data read & converted thru xml_escape() into &xyz; format: + $contents =~ s/\\\/&/g; + } +# print STDERR "contents b4:$contents\n"; + eval $dohighlight; + die $@ if $@; +# print STDERR "contents af:$contents\n"; + +# strip whitespaces when generating html5 + if ($output_mode eq "html5") { + $contents =~ s/^\s+//; + $contents =~ s/\s+$//; + } + foreach $line (split "\n", $contents) { + if ($line eq ""){ + print $lineprefix, local_unescape($blankline); + } else { + $line =~ s/\\\/&/g; + if ($output_mode eq "man" && substr($line, 0, 1) eq ".") { + print "\&$line"; + } else { + print $lineprefix, $line; + } + } + print "\n"; + } +} + +# output sections in html +sub output_section_html(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<blockquote>\n"; + output_highlight($args{'sections'}{$section}); + print "</blockquote>\n"; + } +} + +# output enum in html +sub output_enum_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>enum " . $args{'enum'} . "</h2>\n"; + + print "<b>enum " . $args{'enum'} . "</b> {<br>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " <b>" . $parameter . "</b>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + print "<br>"; + } + print "};<br>\n"; + + print "<h3>Constants</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output typedef in html +sub output_typedef_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>typedef " . $args{'typedef'} . "</h2>\n"; + + print "<b>typedef " . $args{'typedef'} . "</b>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output struct in html +sub output_struct_html(%) { + my %args = %{$_[0]}; + my ($parameter); + + print "<h2>" . $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<b>" . $args{'type'} . " " . $args{'struct'} . "</b> {<br>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter<br>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <i>$1</i><b>$parameter</b>) <i>($2)</i>;<br>\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " <i>$1</i> <b>$parameter</b>$2;<br>\n"; + } else { + print " <i>$type</i> <b>$parameter</b>;<br>\n"; + } + } + print "};<br>\n"; + + print "<h3>Members</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output function in html +sub output_function_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print "<h2>" . $args{'function'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<i>" . $args{'functiontype'} . "</i>\n"; + print "<b>" . $args{'function'} . "</b>\n"; + print "("; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<i>$1</i><b>$parameter</b>) <i>($2)</i>"; + } else { + print "<i>" . $type . "</i> <b>" . $parameter . "</b>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + } + print ")\n"; + + print "<h3>Arguments</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output DOC: block header in html +sub output_blockhead_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<ul>\n"; + output_highlight($args{'sections'}{$section}); + print "</ul>\n"; + } + print "<hr>\n"; +} + +# output sections in html5 +sub output_section_html5(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<section>\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + print "</section>\n"; + } +} + +# output enum in html5 +sub output_enum_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'enum'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="enum" id="enum:". $html5id . "">"; + print "<h1>enum " . $args{'enum'} . "</h1>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">enum</span> "; + print "<span class="identifier">" . $args{'enum'} . "</span> {"; + print "</li>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + print "<span class="param">" . $parameter . "</span>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Constants</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output typedef in html5 +sub output_typedef_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'typedef'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="typedef" id="typedef:" . $html5id . "">\n"; + print "<h1>typedef " . $args{'typedef'} . "</h1>\n"; + + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">typedef</span> "; + print "<span class="identifier">" . $args{'typedef'} . "</span>"; + print "</li>\n"; + print "</ol>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output struct in html5 +sub output_struct_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $html5id; + + $html5id = $args{'struct'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="struct" id="struct:" . $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'type'} . " " . $args{'struct'} . "</h1>"; + print "<h2>". $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'type'} . "</span> "; + print "<span class="identifier">" . $args{'struct'} . "</span> {"; + print "</li>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + if ($parameter =~ /^#/) { + print "<span class="param">" . $parameter ."</span>\n"; + print "</li>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>);"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="bits">$2</span>;"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>;"; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Members</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output function in html5 +sub output_function_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + $html5id = $args{'function'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="function" id="func:". $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'function'} . "</h1>"; + print "<h2>" . $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'functiontype'} . "</span> "; + print "<span class="identifier">" . $args{'function'} . "</span> ("; + print "</li>"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>)"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>)</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Arguments</h1>\n"; + print "<p>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output DOC: block header in html5 +sub output_blockhead_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + foreach $section (@{$args{'sectionlist'}}) { + $html5id = $section; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="doc" id="doc:". $html5id . "">\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + } + print "</article>\n"; +} + +sub output_section_xml(%) { + my %args = %{$_[0]}; + my $section; + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<refsect1>\n"; + print "<title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<informalexample><programlisting>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></informalexample>\n"; + } else { + print "</para>\n"; + } + print "</refsect1>\n"; + } +} + +# output function in XML DocBook +sub output_function_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'function'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'function'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <funcsynopsis><funcprototype>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " </function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1<parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void/>\n"; + } + print " </funcprototype></funcsynopsis>\n"; + print "</refsynopsisdiv>\n"; + + # print parameters + print "<refsect1>\n <title>Arguments</title>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>\n <term><parameter>$parameter</parameter></term>\n"; + print " <listitem>\n <para>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para>\n </listitem>\n </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print "</refsect1>\n"; + + output_section_xml(@_); + print "</refentry>\n\n"; +} + +# output struct in XML DocBook +sub output_struct_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-struct-" . $args{'struct'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'type'} . " " . $args{'struct'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'type'} . " " . $args{'struct'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + my $prm = $parameter; + # convert data read & converted thru xml_escape() into &xyz; format: + # This allows us to have #define macros interspersed in a struct. + $prm =~ s/\\\/&/g; + print "$prm\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " $1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " $1 $parameter$2;\n"; + } else { + print " " . $type . " " . $parameter . ";\n"; + } + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print " <refsect1>\n"; + print " <title>Members</title>\n"; + + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print " </refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output enum in XML DocBook +sub output_enum_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-enum-" . $args{'enum'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>enum " . $args{'enum'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>enum " . $args{'enum'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " $parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print "<refsect1>\n"; + print " <title>Constants</title>\n"; + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + print "</refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output typedef in XML DocBook +sub output_typedef_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-typedef-" . $args{'typedef'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>typedef " . $args{'typedef'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>typedef " . $args{'typedef'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <synopsis>typedef " . $args{'typedef'} . ";</synopsis>\n"; + print "</refsynopsisdiv>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output in XML DocBook +sub output_blockhead_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + my $id = $args{'module'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + if (!$args{'content-only'}) { + print "<refsect1>\n <title>$section</title>\n"; + } + if ($section =~ m/EXAMPLE/i) { + print "<example><para>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</para></example>\n"; + } else { + print "</para>"; + } + if (!$args{'content-only'}) { + print "\n</refsect1>\n"; + } + } + + print "\n\n"; +} + +# output in XML DocBook +sub output_function_gnome { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = $args{'module'} . "-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<sect2>\n"; + print " <title id="$id">" . $args{'function'} . "</title>\n"; + + print " <funcsynopsis>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " "; + print "</function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1 <parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void>\n"; + } + print " </funcsynopsis>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <informaltable pgwide="1" frame="none" role="params">\n"; + print "<tgroup cols="2">\n"; + print "<colspec colwidth="2*">\n"; + print "<colspec colwidth="8*">\n"; + print "<tbody>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <row><entry align="right"><parameter>$parameter</parameter></entry>\n"; + print " <entry>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </entry></row>\n"; + } + print " </tbody></tgroup></informaltable>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<simplesect>\n <title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<example><programlisting>\n"; + } else { + } + print "<para>\n"; + output_highlight($args{'sections'}{$section}); + print "</para>\n"; + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></example>\n"; + } else { + } + print " </simplesect>\n"; + } + + print "</sect2>\n\n"; +} + +## +# output function in man +sub output_function_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'function'}" 9 "$args{'function'}" "$man_date" "Bootloader Hacker's Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'function'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + if ($args{'functiontype'} ne "") { + print ".B "" . $args{'functiontype'} . "" " . $args{'function'} . "\n"; + } else { + print ".B "" . $args{'function'} . "\n"; + } + $count = 0; + my $parenth = "("; + my $post = ","; + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($count == $#{$args{'parameterlist'}}) { + $post = ");"; + } + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI "" . $parenth . $1 . "" " . $parameter . " ") (" . $2 . ")" . $post . ""\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI "" . $parenth . $type . "" " . $parameter . " "" . $post . ""\n"; + } + $count++; + $parenth = ""; + } + + print ".SH ARGUMENTS\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "", uc $section, ""\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output enum in man +sub output_enum_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "enum $args{'enum'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "enum " . $args{'enum'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + print ".br\n.BI " $parameter"\n"; + if ($count == $#{$args{'parameterlist'}}) { + print "\n};\n"; + last; + } + else { + print ", \n.br\n"; + } + $count++; + } + + print ".SH Constants\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output struct in man +sub output_struct_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "" . $args{'type'} . " " . $args{'struct'} . "" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'type'} . " " . $args{'struct'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n.br\n"; + + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print ".BI "$parameter"\n.br\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI " " . $1 . "" " . $parameter . " ") (" . $2 . ")" . ""\n;\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print ".BI " " . $1 . "\ " " . $parameter . $2 . " "" . ""\n;\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI " " . $type . "" " . $parameter . " "" . ""\n;\n"; + } + print "\n.br\n"; + } + print "};\n.br\n"; + + print ".SH Members\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output typedef in man +sub output_typedef_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "$args{'typedef'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "typedef " . $args{'typedef'} . " \- " . $args{'purpose'} . "\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +sub output_blockhead_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "$args{'module'}" "$man_date" "API Manual" U-BOOT\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output in text +sub output_function_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $start; + + print "Name:\n\n"; + print $args{'function'} . " - " . $args{'purpose'} . "\n"; + + print "\nSynopsis:\n\n"; + if ($args{'functiontype'} ne "") { + $start = $args{'functiontype'} . " " . $args{'function'} . " ("; + } else { + $start = $args{'function'} . " ("; + } + print $start; + + my $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print $1 . $parameter . ") (" . $2; + } else { + print $type . " " . $parameter; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + print " " x length($start); + } else { + print ");\n\n"; + } + } + + print "Arguments:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print $parameter . "\n\t" . $args{'parameterdescs'}{$parameter_name} . "\n"; + } + output_section_text(@_); +} + +#output sections in text +sub output_section_text(%) { + my %args = %{$_[0]}; + my $section; + + print "\n"; + foreach $section (@{$args{'sectionlist'}}) { + print "$section:\n\n"; + output_highlight($args{'sections'}{$section}); + } + print "\n\n"; +} + +# output enum in text +sub output_enum_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Enum:\n\n"; + + print "enum " . $args{'enum'} . " - " . $args{'purpose'} . "\n\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "\t$parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};\n\n"; + + print "Constants:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter} . "\n"; + } + + output_section_text(@_); +} + +# output typedef in text +sub output_typedef_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Typedef:\n\n"; + + print "typedef " . $args{'typedef'} . " - " . $args{'purpose'} . "\n"; + output_section_text(@_); +} + +# output struct as text +sub output_struct_text(%) { + my %args = %{$_[0]}; + my ($parameter); + + print $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "\n\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "\t$1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "\t$1 $parameter$2;\n"; + } else { + print "\t" . $type . " " . $parameter . ";\n"; + } + } + print "};\n\n"; + + print "Members:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter_name} . "\n"; + } + print "\n"; + output_section_text(@_); +} + +sub output_blockhead_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print " $section:\n"; + print " -> "; + output_highlight($args{'sections'}{$section}); + } +} + +## list mode output functions + +sub output_function_list(%) { + my %args = %{$_[0]}; + + print $args{'function'} . "\n"; +} + +# output enum in list +sub output_enum_list(%) { + my %args = %{$_[0]}; + print $args{'enum'} . "\n"; +} + +# output typedef in list +sub output_typedef_list(%) { + my %args = %{$_[0]}; + print $args{'typedef'} . "\n"; +} + +# output struct as list +sub output_struct_list(%) { + my %args = %{$_[0]}; + + print $args{'struct'} . "\n"; +} + +sub output_blockhead_list(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print "DOC: $section\n"; + } +} + +## +# generic output function for all types (function, struct/union, typedef, enum); +# calls the generated, variable output_ function name based on +# functype and output_mode +sub output_declaration { + no strict 'refs'; + my $name = shift; + my $functype = shift; + my $func = "output_${functype}_$output_mode"; + if (($function_only==0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + &$func(@_); + $section_counter++; + } +} + +## +# generic output function - calls the right one based on current output mode. +sub output_blockhead { + no strict 'refs'; + my $func = "output_blockhead_" . $output_mode; + &$func(@_); + $section_counter++; +} + +## +# takes a declaration (struct, union, enum, typedef) and +# invokes the right handler. NOT called for functions. +sub dump_declaration($$) { + no strict 'refs'; + my ($prototype, $file) = @_; + my $func = "dump_" . $decl_type; + &$func(@_); +} + +sub dump_union($$) { + dump_struct(@_); +} + +sub dump_struct($$) { + my $x = shift; + my $file = shift; + my $nested; + + if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}/) { + #my $decl_type = $1; + $declaration_name = $2; + my $members = $3; + + # ignore embedded structs or unions + $members =~ s/({.*})//g; + $nested = $1; + + # ignore members marked private: + $members =~ s//*\s*private:.*?/*\s*public:.*?*///gos; + $members =~ s//*\s*private:.*//gos; + # strip comments: + $members =~ s//*.*?*///gos; + $nested =~ s//*.*?*///gos; + # strip kmemcheck_bitfield_{begin,end}.*; + $members =~ s/kmemcheck_bitfield_.*?;//gos; + # strip attributes + $members =~ s/__aligned\s*(\d+)//gos; + + create_parameterlist($members, ';', $file); + check_sections($file, $declaration_name, "struct", $sectcheck, $struct_actual, $nested); + + output_declaration($declaration_name, + 'struct', + {'struct' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose, + 'type' => $decl_type + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse struct or union!\n"; + ++$errors; + } +} + +sub dump_enum($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + $x =~ s/^#\s*define\s+.*$//; # strip #define macros inside enums + + if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { + $declaration_name = $1; + my $members = $2; + + foreach my $arg (split ',', $members) { + $arg =~ s/^\s*(\w+).*/$1/; + push @parameterlist, $arg; + if (!$parameterdescs{$arg}) { + $parameterdescs{$arg} = $undescribed; + print STDERR "Warning(${file}:$.): Enum value '$arg' ". + "not described in enum '$declaration_name'\n"; + } + + } + + output_declaration($declaration_name, + 'enum', + {'enum' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse enum!\n"; + ++$errors; + } +} + +sub dump_typedef($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + while (($x =~ /(*.)\s*;$/) || ($x =~ /[*.]\s*;$/)) { + $x =~ s/(*.)\s*;$/;/; + $x =~ s/[*.]\s*;$/;/; + } + + if ($x =~ /typedef.*\s+(\w+)\s*;/) { + $declaration_name = $1; + + output_declaration($declaration_name, + 'typedef', + {'typedef' => $declaration_name, + 'module' => $modulename, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse typedef!\n"; + ++$errors; + } +} + +sub save_struct_actual($) { + my $actual = shift; + + # strip all spaces from the actual param so that it looks like one string item + $actual =~ s/\s*//g; + $struct_actual = $struct_actual . $actual . " "; +} + +sub create_parameterlist($$$) { + my $args = shift; + my $splitter = shift; + my $file = shift; + my $type; + my $param; + + # temporarily replace commas inside function pointer definition + while ($args =~ /(([^),]+),/) { + $args =~ s/(([^),]+),/$1#/g; + } + + foreach my $arg (split($splitter, $args)) { + # strip comments + $arg =~ s//*.**///; + # strip leading/trailing spaces + $arg =~ s/^\s*//; + $arg =~ s/\s*$//; + $arg =~ s/\s+/ /; + + if ($arg =~ /^#/) { + # Treat preprocessor directive as a typeless variable just to fill + # corresponding data structures "correctly". Catch it later in + # output_* subs. + push_parameter($arg, "", $file); + } elsif ($arg =~ m/(.+)\s*(/) { + # pointer-to-function + $arg =~ tr/#/,/; + $arg =~ m/[^(]+(*?\s*(\w*)\s*)/; + $param = $1; + $type = $arg; + $type =~ s/([^(]+(*?)\s*$param/$1/; + save_struct_actual($param); + push_parameter($param, $type, $file); + } elsif ($arg) { + $arg =~ s/\s*:\s*/:/g; + $arg =~ s/\s*[/[/g; + + my @args = split('\s*,\s*', $arg); + if ($args[0] =~ m/*/) { + $args[0] =~ s/(*+)\s*/ $1/; + } + + my @first_arg; + if ($args[0] =~ /^(.*\s+)(.*?[.*].*)$/) { + shift @args; + push(@first_arg, split('\s+', $1)); + push(@first_arg, $2); + } else { + @first_arg = split('\s+', shift @args); + } + + unshift(@args, pop @first_arg); + $type = join " ", @first_arg; + + foreach $param (@args) { + if ($param =~ m/^(*+)\s*(.*)/) { + save_struct_actual($2); + push_parameter($2, "$type $1", $file); + } + elsif ($param =~ m/(.*?):(\d+)/) { + if ($type ne "") { # skip unnamed bit-fields + save_struct_actual($1); + push_parameter($1, "$type:$2", $file) + } + } + else { + save_struct_actual($param); + push_parameter($param, $type, $file); + } + } + } + } +} + +sub push_parameter($$$) { + my $param = shift; + my $type = shift; + my $file = shift; + + if (($anon_struct_union == 1) && ($type eq "") && + ($param eq "}")) { + return; # ignore the ending }; from anon. struct/union + } + + $anon_struct_union = 0; + my $param_name = $param; + $param_name =~ s/[.*//; + + if ($type eq "" && $param =~ /...$/) + { + if (!defined $parameterdescs{$param} || $parameterdescs{$param} eq "") { + $parameterdescs{$param} = "variable arguments"; + } + } + elsif ($type eq "" && ($param eq "" or $param eq "void")) + { + $param="void"; + $parameterdescs{void} = "no arguments"; + } + elsif ($type eq "" && ($param eq "struct" or $param eq "union")) + # handle unnamed (anonymous) union or struct: + { + $type = $param; + $param = "{unnamed_" . $param . "}"; + $parameterdescs{$param} = "anonymous\n"; + $anon_struct_union = 1; + } + + # warn if parameter has no description + # (but ignore ones starting with # as these are not parameters + # but inline preprocessor statements); + # also ignore unnamed structs/unions; + if (!$anon_struct_union) { + if (!defined $parameterdescs{$param_name} && $param_name !~ /^#/) { + + $parameterdescs{$param_name} = $undescribed; + + if (($type eq 'function') || ($type eq 'enum')) { + print STDERR "Warning(${file}:$.): Function parameter ". + "or member '$param' not " . + "described in '$declaration_name'\n"; + } + print STDERR "Warning(${file}:$.):" . + " No description found for parameter '$param'\n"; + ++$warnings; + } + } + + $param = xml_escape($param); + + # strip spaces from $param so that it is one continuous string + # on @parameterlist; + # this fixes a problem where check_sections() cannot find + # a parameter like "addr[6 + 2]" because it actually appears + # as "addr[6", "+", "2]" on the parameter list; + # but it's better to maintain the param string unchanged for output, + # so just weaken the string compare in check_sections() to ignore + # "[blah" in a parameter string; + ###$param =~ s/\s*//g; + push @parameterlist, $param; + $parametertypes{$param} = $type; +} + +sub check_sections($$$$$$) { + my ($file, $decl_name, $decl_type, $sectcheck, $prmscheck, $nested) = @_; + my @sects = split ' ', $sectcheck; + my @prms = split ' ', $prmscheck; + my $err; + my ($px, $sx); + my $prm_clean; # strip trailing "[array size]" and/or beginning "*" + + foreach $sx (0 .. $#sects) { + $err = 1; + foreach $px (0 .. $#prms) { + $prm_clean = $prms[$px]; + $prm_clean =~ s/[.*]//; + $prm_clean =~ s/__attribute__\s*(([a-z,_*\s()]*))//i; + # ignore array size in a parameter string; + # however, the original param string may contain + # spaces, e.g.: addr[6 + 2] + # and this appears in @prms as "addr[6" since the + # parameter list is split at spaces; + # hence just ignore "[..." for the sections check; + $prm_clean =~ s/[.*//; + + ##$prm_clean =~ s/^**//; + if ($prm_clean eq $sects[$sx]) { + $err = 0; + last; + } + } + if ($err) { + if ($decl_type eq "function") { + print STDERR "Warning(${file}:$.): " . + "Excess function parameter " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } else { + if ($nested !~ m/\Q$sects[$sx]\E/) { + print STDERR "Warning(${file}:$.): " . + "Excess struct/union/enum/typedef member " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } + } + } + } +} + +## +# takes a function prototype and the name of the current file being +# processed and spits out all the details stored in the global +# arrays/hashes. +sub dump_function($$) { + my $prototype = shift; + my $file = shift; + + $prototype =~ s/^static +//; + $prototype =~ s/^extern +//; + $prototype =~ s/^asmlinkage +//; + $prototype =~ s/^inline +//; + $prototype =~ s/^__inline__ +//; + $prototype =~ s/^__inline +//; + $prototype =~ s/^__always_inline +//; + $prototype =~ s/^noinline +//; + $prototype =~ s/__devinit +//; + $prototype =~ s/__init +//; + $prototype =~ s/__init_or_module +//; + $prototype =~ s/__must_check +//; + $prototype =~ s/__weak +//; + $prototype =~ s/^#\s*define\s+//; #ak added + $prototype =~ s/__attribute__\s*(([a-z,]*))//; + + # Yes, this truly is vile. We are looking for: + # 1. Return type (may be nothing if we're looking at a macro) + # 2. Function name + # 3. Function parameters. + # + # All the while we have to watch out for function pointer parameters + # (which IIRC is what the two sections are for), C types (these + # regexps don't even start to express all the possibilities), and + # so on. + # + # If you mess with these regexps, it's a good idea to check that + # the following functions' documentation still comes out right: + # - parport_register_device (function pointer parameters) + # - atomic_set (macro) + # - pci_match_device, __copy_to_user (long return type) + + if ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**+)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**\s*\w+\s**\s*)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/) { + $return_type = $1; + $declaration_name = $2; + my $args = $3; + + create_parameterlist($args, ',', $file); + } else { + print STDERR "Error(${file}:$.): cannot understand prototype: '$prototype'\n"; + ++$errors; + return; + } + + my $prms = join " ", @parameterlist; + check_sections($file, $declaration_name, "function", $sectcheck, $prms, ""); + + output_declaration($declaration_name, + 'function', + {'function' => $declaration_name, + 'module' => $modulename, + 'functiontype' => $return_type, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); +} + +sub reset_state { + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $sectcheck = ""; + $struct_actual = ""; + $prototype = ""; + + $state = 0; +} + +sub tracepoint_munge($) { + my $file = shift; + my $tracepointname = 0; + my $tracepointargs = 0; + + if ($prototype =~ m/TRACE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_SINGLE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_EVENT((.*?),(.*?),/) { + $tracepointname = $2; + } + $tracepointname =~ s/^\s+//; #strip leading whitespace + if ($prototype =~ m/TP_PROTO((.*?))/) { + $tracepointargs = $1; + } + if (($tracepointname eq 0) || ($tracepointargs eq 0)) { + print STDERR "Warning(${file}:$.): Unrecognized tracepoint format: \n". + "$prototype\n"; + } else { + $prototype = "static inline void trace_$tracepointname($tracepointargs)"; + } +} + +sub syscall_munge() { + my $void = 0; + + $prototype =~ s@[\r\n\t]+@ @gos; # strip newlines/CR's/tabs +## if ($prototype =~ m/SYSCALL_DEFINE0\s*(\s*(a-zA-Z0-9_)*\s*)/) { + if ($prototype =~ m/SYSCALL_DEFINE0/) { + $void = 1; +## $prototype = "long sys_$1(void)"; + } + + $prototype =~ s/SYSCALL_DEFINE.*(/long sys_/; # fix return type & func name + if ($prototype =~ m/long (sys_.*?),/) { + $prototype =~ s/,/(/; + } elsif ($void) { + $prototype =~ s/)/(void)/; + } + + # now delete all of the odd-number commas in $prototype + # so that arg types & arg names don't have a comma between them + my $count = 0; + my $len = length($prototype); + if ($void) { + $len = 0; # skip the for-loop + } + for (my $ix = 0; $ix < $len; $ix++) { + if (substr($prototype, $ix, 1) eq ',') { + $count++; + if ($count % 2 == 1) { + substr($prototype, $ix, 1) = ' '; + } + } + } +} + +sub process_state3_function($$) { + my $x = shift; + my $file = shift; + + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ m#\s*/*\s+MACDOC\s*#io || ($x =~ /^#/ && $x !~ /^#\s*define/)) { + # do nothing + } + elsif ($x =~ /([^{]*)/) { + $prototype .= $1; + } + + if (($x =~ /{/) || ($x =~ /#\s*define/) || ($x =~ /;/)) { + $prototype =~ s@/*.*?*/@@gos; # strip comments. + $prototype =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $prototype =~ s@^\s+@@gos; # strip leading spaces + if ($prototype =~ /SYSCALL_DEFINE/) { + syscall_munge(); + } + if ($prototype =~ /TRACE_EVENT/ || $prototype =~ /DEFINE_EVENT/ || + $prototype =~ /DEFINE_SINGLE_EVENT/) + { + tracepoint_munge($file); + } + dump_function($prototype, $file); + reset_state(); + } +} + +sub process_state3_type($$) { + my $x = shift; + my $file = shift; + + $x =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $x =~ s@^\s+@@gos; # strip leading spaces + $x =~ s@\s+$@@gos; # strip trailing spaces + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ /^#/) { + # To distinguish preprocessor directive from regular declaration later. + $x .= ";"; + } + + while (1) { + if ( $x =~ /([^{};]*)([{};])(.*)/ ) { + $prototype .= $1 . $2; + ($2 eq '{') && $brcount++; + ($2 eq '}') && $brcount--; + if (($2 eq ';') && ($brcount == 0)) { + dump_declaration($prototype, $file); + reset_state(); + last; + } + $x = $3; + } else { + $prototype .= $x; + last; + } + } +} + +# xml_escape: replace <, >, and & in the text stream; +# +# however, formatting controls that are generated internally/locally in the +# kernel-doc script are not escaped here; instead, they begin life like +# $blankline_html (4 of '' followed by a mnemonic + ':'), then these strings +# are converted to their mnemonic-expected output, without the 4 * '' & ':', +# just before actual output; (this is done by local_unescape()) +sub xml_escape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/&/\\\amp;/g; + $text =~ s/</\\\lt;/g; + $text =~ s/>/\\\gt;/g; + return $text; +} + +# convert local escape strings to html +# local escape strings look like: '\\menmonic:' (that's 4 backslashes) +sub local_unescape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/\\\\lt:/</g; + $text =~ s/\\\\gt:/>/g; + return $text; +} + +sub process_file($) { + my $file; + my $identifier; + my $func; + my $descr; + my $in_purpose = 0; + my $initial_section_counter = $section_counter; + + if (defined($ENV{'SRCTREE'})) { + $file = "$ENV{'SRCTREE'}" . "/" . "@_"; + } + else { + $file = "@_"; + } + if (defined($source_map{$file})) { + $file = $source_map{$file}; + } + + if (!open(IN,"<$file")) { + print STDERR "Error: Cannot open file $file\n"; + ++$errors; + return; + } + + $. = 1; + + $section_counter = 0; + while (<IN>) { + if ($state == 0) { + if (/$doc_start/o) { + $state = 1; # next line is always the function name + $in_doc_sect = 0; + } + } elsif ($state == 1) { # this line is the function name (always) + if (/$doc_block/o) { + $state = 4; + $contents = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_decl/o) { + $identifier = $1; + if (/\s*([\w\s]+?)\s*-/) { + $identifier = $1; + } + + $state = 2; + if (/-(.*)/) { + # strip leading/trailing/multiple spaces + $descr= $1; + $descr =~ s/^\s*//; + $descr =~ s/\s*$//; + $descr =~ s/\s+/ /; + $declaration_purpose = xml_escape($descr); + $in_purpose = 1; + } else { + $declaration_purpose = ""; + } + + if (($declaration_purpose eq "") && $verbose) { + print STDERR "Warning(${file}:$.): missing initial short description on line:\n"; + print STDERR $_; + ++$warnings; + } + + if ($identifier =~ m/^struct/) { + $decl_type = 'struct'; + } elsif ($identifier =~ m/^union/) { + $decl_type = 'union'; + } elsif ($identifier =~ m/^enum/) { + $decl_type = 'enum'; + } elsif ($identifier =~ m/^typedef/) { + $decl_type = 'typedef'; + } else { + $decl_type = 'function'; + } + + if ($verbose) { + print STDERR "Info(${file}:$.): Scanning doc for $identifier\n"; + } + } else { + print STDERR "Warning(${file}:$.): Cannot understand $_ on line $.", + " - I thought it was a doc line\n"; + ++$warnings; + $state = 0; + } + } elsif ($state == 2) { # look for head: lines, and include content + if (/$doc_sect/o) { + $newsection = $1; + $newcontents = $2; + + if (($contents ne "") && ($contents ne "\n")) { + if (!$in_doc_sect && $verbose) { + print STDERR "Warning(${file}:$.): contents before sections\n"; + ++$warnings; + } + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + } + + $in_doc_sect = 1; + $in_purpose = 0; + $contents = $newcontents; + if ($contents ne "") { + while ((substr($contents, 0, 1) eq " ") || + substr($contents, 0, 1) eq "\t") { + $contents = substr($contents, 1); + } + $contents .= "\n"; + } + $section = $newsection; + } elsif (/$doc_end/) { + + if (($contents ne "") && ($contents ne "\n")) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } + # look for doc_com + <text> + doc_end: + if ($_ =~ m'\s**\s*[a-zA-Z_0-9:.]+*/') { + print STDERR "Warning(${file}:$.): suspicious ending line: $_"; + ++$warnings; + } + + $prototype = ""; + $state = 3; + $brcount = 0; +# print STDERR "end of doc comment, looking for prototype\n"; + } elsif (/$doc_content/) { + # miguel-style comment kludge, look for blank lines after + # @parameter line to signify start of description + if ($1 eq "") { + if ($section =~ m/^@/ || $section eq $section_context) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } else { + $contents .= "\n"; + } + $in_purpose = 0; + } elsif ($in_purpose == 1) { + # Continued declaration purpose + chomp($declaration_purpose); + $declaration_purpose .= " " . xml_escape($1); + } else { + $contents .= $1 . "\n"; + } + } else { + # i dont know - bad line? ignore. + print STDERR "Warning(${file}:$.): bad line: $_"; + ++$warnings; + } + } elsif ($state == 3) { # scanning for function '{' (end of prototype) + if ($decl_type eq 'function') { + process_state3_function($_, $file); + } else { + process_state3_type($_, $file); + } + } elsif ($state == 4) { + # Documentation block + if (/$doc_block/) { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_end/) + { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + $state = 0; + } + elsif (/$doc_content/) + { + if ( $1 eq "" ) + { + $contents .= $blankline; + } + else + { + $contents .= $1 . "\n"; + } + } + } + } + if ($initial_section_counter == $section_counter) { + print STDERR "Warning(${file}): no structured comments found\n"; + if ($output_mode eq "xml") { + # The template wants at least one RefEntry here; make one. + print "<refentry>\n"; + print " <refnamediv>\n"; + print " <refname>\n"; + print " ${file}\n"; + print " </refname>\n"; + print " <refpurpose>\n"; + print " Document generation inconsistency\n"; + print " </refpurpose>\n"; + print " </refnamediv>\n"; + print " <refsect1>\n"; + print " <title>\n"; + print " Oops\n"; + print " </title>\n"; + print " <warning>\n"; + print " <para>\n"; + print " The template for this document tried to insert\n"; + print " the structured comment from the file\n"; + print " <filename>${file}</filename> at this point,\n"; + print " but none was found.\n"; + print " This dummy section is inserted to allow\n"; + print " generation to continue.\n"; + print " </para>\n"; + print " </warning>\n"; + print " </refsect1>\n"; + print "</refentry>\n"; + } + } +} + + +$kernelversion = get_kernel_version(); + +# generate a sequence of code that will splice in highlighting information +# using the s// operator. +foreach my $pattern (keys %highlights) { +# print STDERR "scanning pattern:$pattern, highlight:($highlights{$pattern})\n"; + $dohighlight .= "$contents =~ s:$pattern:$highlights{$pattern}:gs;\n"; +} + +# Read the file that maps relative names to absolute names for +# separate source and object directories and for shadow trees. +if (open(SOURCE_MAP, "<.tmp_filelist.txt")) { + my ($relname, $absname); + while(<SOURCE_MAP>) { + chop(); + ($relname, $absname) = (split())[0..1]; + $relname =~ s:^/+::; + $source_map{$relname} = $absname; + } + close(SOURCE_MAP); +} + +foreach (@ARGV) { + chomp; + process_file($_); +} +if ($verbose && $errors) { + print STDERR "$errors errors\n"; +} +if ($verbose && $warnings) { + print STDERR "$warnings warnings\n"; +} + +exit($errors);
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build.
Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400
Signed-off-by: Marek Vasut marex@denx.de --- Makefile | 7 +- doc/DocBook/.gitignore | 15 + doc/DocBook/Makefile | 229 ++++ doc/DocBook/stylesheet.xsl | 10 + tools/.gitignore | 1 + tools/Makefile | 2 +- tools/kernel-doc/Makefile | 38 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2554 +++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 3430 insertions(+), 2 deletions(-) create mode 100644 doc/DocBook/.gitignore create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
V2: Add .gitignore, drop kernel-doc target which was bogus
diff --git a/Makefile b/Makefile index a40d4cc..4c515ac 100644 --- a/Makefile +++ b/Makefile @@ -695,6 +695,9 @@ easylogo env gdb: $(MAKE) -C tools/$@ all MTD_VERSION=${MTD_VERSION} gdbtools: gdb
+xmldocs pdfdocs psdocs htmldocs mandocs: tools/kernel-doc/docproc + $(MAKE) U_BOOT_VERSION=$(U_BOOT_VERSION) -C doc/DocBook/ $@ + tools-all: easylogo env gdb $(VERSION_FILE) $(TIMESTAMP_FILE) $(MAKE) -C tools HOST_TOOLS_ALL=y
@@ -779,7 +782,8 @@ clean: $(obj)tools/mk{env,}image $(obj)tools/mpc86x_clk \ $(obj)tools/mk{smdk5250,}spl \ $(obj)tools/mxsboot \ - $(obj)tools/ncb $(obj)tools/ubsha1 + $(obj)tools/ncb $(obj)tools/ubsha1 \ + $(obj)tools/kernel-doc/docproc @rm -f $(obj)board/cray/L1/{bootscript.c,bootscript.image} \ $(obj)board/matrix_vision/*/bootscript.img \ $(obj)board/voiceblue/eeprom \ @@ -792,6 +796,7 @@ clean: @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s @rm -f $(TIMESTAMP_FILE) $(VERSION_FILE) + @$(MAKE) -C doc/DocBook/ cleandocs @find $(OBJTREE) -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' -o -name '*.su' \ -o -name '*.o' -o -name '*.a' -o -name '*.exe' ) -print \ diff --git a/doc/DocBook/.gitignore b/doc/DocBook/.gitignore new file mode 100644 index 0000000..90c1b11 --- /dev/null +++ b/doc/DocBook/.gitignore @@ -0,0 +1,15 @@ +*/ +*.xml +*.ps +*.pdf +*.html +*.9.gz +*.9 +*.aux +*.dvi +*.log +*.out +*.png +*.gif +media-indices.tmpl +media-entities.tmpl diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile new file mode 100644 index 0000000..2f2ddfc --- /dev/null +++ b/doc/DocBook/Makefile @@ -0,0 +1,229 @@ +### +# This makefile is used to generate the kernel documentation, +# primarily based on in-line comments in various source files. +# See doc/kernel-doc-nano-HOWTO.txt for instruction in how +# to document the SRC - and how to read it. +# To add a new book the only step required is to add the book to the +# list of DOCBOOKS. + +include $(TOPDIR)/config.mk + +DOCBOOKS := + +### +# The build process is as follows (targets): +# (xmldocs) [by docproc] +# file.tmpl --> file.xml +--> file.ps (psdocs) [by db2ps or xmlto] +# +--> file.pdf (pdfdocs) [by db2pdf or xmlto] +# +--> DIR=file (htmldocs) [by xmlto] +# +--> man/ (mandocs) [by xmlto] + + +# for PDF and PS output you can choose between xmlto and docbook-utils tools +PDF_METHOD = $(prefer-db2x) +PS_METHOD = $(prefer-db2x) + + +### +# The targets that may be used. +PHONY += $(obj).depend xmldocs sgmldocs psdocs pdfdocs htmldocs mandocs installmandocs cleandocs + +BOOKS := $(addprefix $(OBJTREE)/doc/DocBook/,$(DOCBOOKS)) +xmldocs: $(BOOKS) +sgmldocs: xmldocs + +PS := $(patsubst %.xml, %.ps, $(BOOKS)) +psdocs: $(PS) + +PDF := $(patsubst %.xml, %.pdf, $(BOOKS)) +pdfdocs: $(PDF) + +HTML := $(sort $(patsubst %.xml, %.html, $(BOOKS))) +htmldocs: $(HTML) + $(call build_main_index) + $(call build_images) + $(call install_media_images) + +MAN := $(patsubst %.xml, %.9, $(BOOKS)) +mandocs: $(MAN) + +installmandocs: mandocs + mkdir -p /usr/local/man/man9/ + install doc/DocBook/man/*.9.gz /usr/local/man/man9/ + +### +#External programs used +KERNELDOC = $(SRCTREE)/tools/kernel-doc/kernel-doc +DOCPROC = $(OBJTREE)/tools/kernel-doc/docproc + +XMLTOFLAGS = -m $(SRCTREE)/doc/DocBook/stylesheet.xsl +XMLTOFLAGS += --skip-validation + +### +# DOCPROC is used for two purposes: +# 1) To generate a dependency list for a .tmpl file +# 2) To preprocess a .tmpl file and call kernel-doc with +# appropriate parameters. +# The following rules are used to generate the .xml documentation +# required to generate the final targets. (ps, pdf, html). +%.xml: %.tmpl + $(DOCPROC) doc $< >$@ + +ifeq ($@, "cleandocs") +sinclude $(obj).depend +$(obj).depend: $(patsubst %.xml, %.tmpl, $(DOCBOOKS)) + rm -f $(obj).depend ; \ + touch $(obj).depend ; \ + for file in $^ ; do \ + xmlfile=`echo "$${file}" | \ + sed "s/tmpl$$/xml/"` ; \ + echo -n "$${xmlfile}: ">> $(obj).depend ; \ + $(DOCPROC) depend $$file >> $(obj).depend ; \ + echo -e "\n\t$(DOCPROC) doc $< >$${xmlfile} " >> \ + $(obj).depend ; \ + done +endif + +### +# Changes in kernel-doc force a rebuild of all documentation +$(BOOKS): $(KERNELDOC) + +notfoundtemplate = echo "*** You have to install docbook-utils or xmlto ***"; \ + exit 1 +db2xtemplate = db2TYPE -o $(dir $@) $< +xmltotemplate = xmlto TYPE $(XMLTOFLAGS) -o $(dir $@) $< + +# determine which methods are available +ifeq ($(shell which db2ps >/dev/null 2>&1 && echo found),found) + use-db2x = db2x + prefer-db2x = db2x +else + use-db2x = notfound + prefer-db2x = $(use-xmlto) +endif +ifeq ($(shell which xmlto >/dev/null 2>&1 && echo found),found) + use-xmlto = xmlto + prefer-xmlto = xmlto +else + use-xmlto = notfound + prefer-xmlto = $(use-db2x) +endif + +# the commands, generated from the chosen template +quiet_cmd_db2ps = PS $@ + cmd_db2ps = $(subst TYPE,ps, $($(PS_METHOD)template)) +%.ps : %.xml + $(call cmd_db2ps) + +quiet_cmd_db2pdf = PDF $@ + cmd_db2pdf = $(subst TYPE,pdf, $($(PDF_METHOD)template)) +%.pdf : %.xml + $(call cmd_db2pdf) + + +index = index.html +main_idx = $(index) +build_main_index = rm -rf $(main_idx); \ + echo '<h1>U-Boot Bootloader HTML Documentation</h1>' >> $(main_idx) && \ + echo '<h2>U-Boot Version: $(U_BOOT_VERSION)</h2>' >> $(main_idx) && \ + cat $(HTML) >> $(main_idx) + +# To work around bug [1] in docbook-xsl-stylesheets 1.76.1 , generate only html +# docs instead of xhtml with xmlto. +# [1] http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=654338 +quiet_cmd_db2html = HTML $@ + cmd_db2html = xmlto html $(XMLTOFLAGS) -o $(patsubst %.html,%,$@) $< && \ + echo '<a HREF="$(patsubst %.html,%,$(notdir $@))/index.html"> \ + $(patsubst %.html,%,$(notdir $@))</a><p>' > $@ + +%.html: %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + @rm -rf $@ $(patsubst %.html,%,$@) + $(call cmd_db2html) + @if [ ! -z "$(PNG-$(basename $(notdir $@)))" ]; then \ + cp $(PNG-$(basename $(notdir $@))) $(patsubst %.html,%,$@); fi + +quiet_cmd_db2man = MAN $@ + cmd_db2man = if grep -q refentry $<; then xmlto man $(XMLTOFLAGS) -o $(obj)/man $< ; gzip -f $(obj)/man/*.9; fi +%.9 : %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + $(Q)mkdir -p $(obj)man + $(call cmd_db2man) + @touch $@ + +### +# Rules to generate postscripts and PNG images from .fig format files +quiet_cmd_fig2eps = FIG2EPS $@ + cmd_fig2eps = fig2dev -Leps $< $@ + +%.eps: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2eps) + +quiet_cmd_fig2png = FIG2PNG $@ + cmd_fig2png = fig2dev -Lpng $< $@ + +%.png: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2png) + +### +# Rule to convert a .c file to inline XML documentation + gen_xml = : + quiet_gen_xml = echo ' GEN $@' +silent_gen_xml = : +%.xml: %.c + @$($(quiet)gen_xml) + @( \ + echo "<programlisting>"; \ + expand --tabs=8 < $< | \ + sed -e "s/&/\&/g" \ + -e "s/</\</g" \ + -e "s/>/\>/g"; \ + echo "</programlisting>") > $@ + +### +# Help targets as used by the top-level makefile +dochelp: + @echo ' U-Boot bootloader internal documentation in different formats:' + @echo ' htmldocs - HTML' + @echo ' pdfdocs - PDF' + @echo ' psdocs - Postscript' + @echo ' xmldocs - XML DocBook' + @echo ' mandocs - man pages' + @echo ' installmandocs - install man pages generated by mandocs' + @echo ' cleandocs - clean all generated DocBook files' + +### +# Temporary files left by various tools +clean-files := $(DOCBOOKS) \ + $(patsubst %.xml, %.dvi, $(DOCBOOKS)) \ + $(patsubst %.xml, %.aux, $(DOCBOOKS)) \ + $(patsubst %.xml, %.tex, $(DOCBOOKS)) \ + $(patsubst %.xml, %.log, $(DOCBOOKS)) \ + $(patsubst %.xml, %.out, $(DOCBOOKS)) \ + $(patsubst %.xml, %.ps, $(DOCBOOKS)) \ + $(patsubst %.xml, %.pdf, $(DOCBOOKS)) \ + $(patsubst %.xml, %.html, $(DOCBOOKS)) \ + $(patsubst %.xml, %.9, $(DOCBOOKS)) \ + $(index) + +clean-dirs := $(patsubst %.xml,%,$(DOCBOOKS)) man + +cleandocs: + @rm -f $(obj).depend + @$(Q)rm -f $(call objectify, $(clean-files)) + @$(Q)rm -rf $(call objectify, $(clean-dirs)) + +# Declare the contents of the .PHONY variable as phony. We keep that +# information in a variable se we can use it in if_changed and friends. + +.PHONY: $(PHONY) diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl new file mode 100644 index 0000000..85b2527 --- /dev/null +++ b/doc/DocBook/stylesheet.xsl @@ -0,0 +1,10 @@ +<?xml version="1.0" encoding="UTF-8"?> +<stylesheet xmlns="http://www.w3.org/1999/XSL/Transform" version="1.0"> +<param name="chunk.quietly">1</param> +<param name="funcsynopsis.style">ansi</param> +<param name="funcsynopsis.tabular.threshold">80</param> +<param name="callout.graphics">0</param> +<!-- <param name="paper.type">A4</param> --> +<param name="generate.section.toc.level">2</param> +<param name="use.id.as.filename">1</param> +</stylesheet> diff --git a/tools/.gitignore b/tools/.gitignore index 3088f4d..9bce719 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -17,3 +17,4 @@ /env/fw_printenv /gdb/gdbcont /gdb/gdbsend +/kernel-doc/docproc diff --git a/tools/Makefile b/tools/Makefile index c31437e..686840a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
-TOOLSUBDIRS = +TOOLSUBDIRS = kernel-doc
# # Include this after HOSTOS HOSTARCH check diff --git a/tools/kernel-doc/Makefile b/tools/kernel-doc/Makefile new file mode 100644 index 0000000..28a3f61 --- /dev/null +++ b/tools/kernel-doc/Makefile @@ -0,0 +1,38 @@ +# +# Copyright (C) 2012 Marek Vasut marex@denx.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +all: $(obj)docproc + +$(obj)docproc: docproc.c + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(HOSTSTRIP) $@ + +clean: + rm -rf docproc + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/kernel-doc/docproc.c b/tools/kernel-doc/docproc.c new file mode 100644 index 0000000..8bc47b0 --- /dev/null +++ b/tools/kernel-doc/docproc.c @@ -0,0 +1,576 @@ +/* + * docproc is a simple preprocessor for the template files + * used as placeholders for the kernel internal documentation. + * docproc is used for documentation-frontend and + * dependency-generator. + * The two usages have in common that they require + * some knowledge of the .tmpl syntax, therefore they + * are kept together. + * + * documentation-frontend + * Scans the template file and call kernel-doc for + * all occurrences of ![EIF]file + * Beforehand each referenced file is scanned for + * any symbols that are exported via these macros: + * EXPORT_SYMBOL(), EXPORT_SYMBOL_GPL(), & + * EXPORT_SYMBOL_GPL_FUTURE() + * This is used to create proper -function and + * -nofunction arguments in calls to kernel-doc. + * Usage: docproc doc file.tmpl + * + * dependency-generator: + * Scans the template file and list all files + * referenced in a format recognized by make. + * Usage: docproc depend file.tmpl + * Writes dependency information to stdout + * in the following format: + * file.tmpl src.c src2.c + * The filenames are obtained from the following constructs: + * !Efilename + * !Ifilename + * !Dfilename + * !Ffilename + * !Pfilename + * + */ + +#define _GNU_SOURCE +#include <stdio.h> +#include <stdlib.h> +#include <string.h> +#include <ctype.h> +#include <unistd.h> +#include <limits.h> +#include <errno.h> +#include <sys/types.h> +#include <sys/wait.h> + +/* exitstatus is used to keep track of any failing calls to kernel-doc, + * but execution continues. */ +int exitstatus = 0; + +typedef void DFL(char *); +DFL *defaultline; + +typedef void FILEONLY(char * file); +FILEONLY *internalfunctions; +FILEONLY *externalfunctions; +FILEONLY *symbolsonly; +FILEONLY *findall; + +typedef void FILELINE(char * file, char * line); +FILELINE * singlefunctions; +FILELINE * entity_system; +FILELINE * docsection; + +#define MAXLINESZ 2048 +#define MAXFILES 250 +#define KERNELDOCPATH "tools/kernel-doc/" +#define KERNELDOC "kernel-doc" +#define DOCBOOK "-docbook" +#define LIST "-list" +#define FUNCTION "-function" +#define NOFUNCTION "-nofunction" +#define NODOCSECTIONS "-no-doc-sections" + +static char *srctree, *kernsrctree; + +static char **all_list = NULL; +static int all_list_len = 0; + +static void consume_symbol(const char *sym) +{ + int i; + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + if (strcmp(sym, all_list[i])) + continue; + all_list[i] = NULL; + break; + } +} + +static void usage (void) +{ + fprintf(stderr, "Usage: docproc {doc|depend} file\n"); + fprintf(stderr, "Input is read from file.tmpl. Output is sent to stdout\n"); + fprintf(stderr, "doc: frontend when generating kernel documentation\n"); + fprintf(stderr, "depend: generate list of files referenced within file\n"); + fprintf(stderr, "Environment variable SRCTREE: absolute path to sources.\n"); + fprintf(stderr, " KBUILD_SRC: absolute path to kernel source tree.\n"); +} + +/* + * Execute kernel-doc with parameters given in svec + */ +static void exec_kernel_doc(char **svec) +{ + pid_t pid; + int ret; + char real_filename[PATH_MAX + 1]; + /* Make sure output generated so far are flushed */ + fflush(stdout); + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, svec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; +} + +/* Types used to create list of all exported symbols in a number of files */ +struct symbols +{ + char *name; +}; + +struct symfile +{ + char *filename; + struct symbols *symbollist; + int symbolcnt; +}; + +struct symfile symfilelist[MAXFILES]; +int symfilecnt = 0; + +static void add_new_symbol(struct symfile *sym, char * symname) +{ + sym->symbollist = + realloc(sym->symbollist, (sym->symbolcnt + 1) * sizeof(char *)); + sym->symbollist[sym->symbolcnt++].name = strdup(symname); +} + +/* Add a filename to the list */ +static struct symfile * add_new_file(char * filename) +{ + symfilelist[symfilecnt++].filename = strdup(filename); + return &symfilelist[symfilecnt - 1]; +} + +/* Check if file already are present in the list */ +static struct symfile * filename_exist(char * filename) +{ + int i; + for (i=0; i < symfilecnt; i++) + if (strcmp(symfilelist[i].filename, filename) == 0) + return &symfilelist[i]; + return NULL; +} + +/* + * List all files referenced within the template file. + * Files are separated by tabs. + */ +static void adddep(char * file) { printf("\t%s", file); } +static void adddep2(char * file, char * line) { line = line; adddep(file); } +static void noaction(char * line) { line = line; } +static void noaction2(char * file, char * line) { file = file; line = line; } + +/* Echo the line without further action */ +static void printline(char * line) { printf("%s", line); } + +/* + * Find all symbols in filename that are exported with EXPORT_SYMBOL & + * EXPORT_SYMBOL_GPL (& EXPORT_SYMBOL_GPL_FUTURE implicitly). + * All symbols located are stored in symfilelist. + */ +static void find_export_symbols(char * filename) +{ + FILE * fp; + struct symfile *sym; + char line[MAXLINESZ]; + if (filename_exist(filename) == NULL) { + char real_filename[PATH_MAX + 1]; + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, srctree, PATH_MAX); + strncat(real_filename, "/", PATH_MAX - strlen(real_filename)); + strncat(real_filename, filename, + PATH_MAX - strlen(real_filename)); + sym = add_new_file(filename); + fp = fopen(real_filename, "r"); + if (fp == NULL) { + fprintf(stderr, "docproc: "); + perror(real_filename); + exit(1); + } + while (fgets(line, MAXLINESZ, fp)) { + char *p; + char *e; + if (((p = strstr(line, "EXPORT_SYMBOL_GPL")) != NULL) || + ((p = strstr(line, "EXPORT_SYMBOL")) != NULL)) { + /* Skip EXPORT_SYMBOL{_GPL} */ + while (isalnum(*p) || *p == '_') + p++; + /* Remove parentheses & additional whitespace */ + while (isspace(*p)) + p++; + if (*p != '(') + continue; /* Syntax error? */ + else + p++; + while (isspace(*p)) + p++; + e = p; + while (isalnum(*e) || *e == '_') + e++; + *e = '\0'; + add_new_symbol(sym, p); + } + } + fclose(fp); + } +} + +/* + * Document all external or internal functions in a file. + * Call kernel-doc with following parameters: + * kernel-doc -docbook -nofunction function_name1 filename + * Function names are obtained from all the src files + * by find_export_symbols. + * intfunc uses -nofunction + * extfunc uses -function + */ +static void docfunctions(char * filename, char * type) +{ + int i,j; + int symcnt = 0; + int idx = 0; + char **vec; + + for (i=0; i <= symfilecnt; i++) + symcnt += symfilelist[i].symbolcnt; + vec = malloc((2 + 2 * symcnt + 3) * sizeof(char *)); + if (vec == NULL) { + perror("docproc: "); + exit(1); + } + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + vec[idx++] = NODOCSECTIONS; + for (i=0; i < symfilecnt; i++) { + struct symfile * sym = &symfilelist[i]; + for (j=0; j < sym->symbolcnt; j++) { + vec[idx++] = type; + consume_symbol(sym->symbollist[j].name); + vec[idx++] = sym->symbollist[j].name; + } + } + vec[idx++] = filename; + vec[idx] = NULL; + printf("<!-- %s -->\n", filename); + exec_kernel_doc(vec); + fflush(stdout); + free(vec); +} +static void intfunc(char * filename) { docfunctions(filename, NOFUNCTION); } +static void extfunc(char * filename) { docfunctions(filename, FUNCTION); } + +/* + * Document specific function(s) in a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function function1 [-function function2] + */ +static void singfunc(char * filename, char * line) +{ + char *vec[200]; /* Enough for specific functions */ + int i, idx = 0; + int startofsym = 1; + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + + /* Split line up in individual parameters preceded by FUNCTION */ + for (i=0; line[i]; i++) { + if (isspace(line[i])) { + line[i] = '\0'; + startofsym = 1; + continue; + } + if (startofsym) { + startofsym = 0; + vec[idx++] = FUNCTION; + vec[idx++] = &line[i]; + } + } + for (i = 0; i < idx; i++) { + if (strcmp(vec[i], FUNCTION)) + continue; + consume_symbol(vec[i + 1]); + } + vec[idx++] = filename; + vec[idx] = NULL; + exec_kernel_doc(vec); +} + +/* + * Insert specific documentation section from a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function "doc section" filename + */ +static void docsect(char *filename, char *line) +{ + char *vec[6]; /* kerneldoc -docbook -function "section" file NULL */ + char *s; + + for (s = line; *s; s++) + if (*s == '\n') + *s = '\0'; + + if (asprintf(&s, "DOC: %s", line) < 0) { + perror("asprintf"); + exit(1); + } + consume_symbol(s); + free(s); + + vec[0] = KERNELDOC; + vec[1] = DOCBOOK; + vec[2] = FUNCTION; + vec[3] = line; + vec[4] = filename; + vec[5] = NULL; + exec_kernel_doc(vec); +} + +static void find_all_symbols(char *filename) +{ + char *vec[4]; /* kerneldoc -list file NULL */ + pid_t pid; + int ret, i, count, start; + char real_filename[PATH_MAX + 1]; + int pipefd[2]; + char *data, *str; + size_t data_len = 0; + + vec[0] = KERNELDOC; + vec[1] = LIST; + vec[2] = filename; + vec[3] = NULL; + + if (pipe(pipefd)) { + perror("pipe"); + exit(1); + } + + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + close(pipefd[0]); + dup2(pipefd[1], 1); + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, vec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + close(pipefd[1]); + data = malloc(4096); + do { + while ((ret = read(pipefd[0], + data + data_len, + 4096)) > 0) { + data_len += ret; + data = realloc(data, data_len + 4096); + } + } while (ret == -EAGAIN); + if (ret != 0) { + perror("read"); + exit(1); + } + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; + + count = 0; + /* poor man's strtok, but with counting */ + for (i = 0; i < data_len; i++) { + if (data[i] == '\n') { + count++; + data[i] = '\0'; + } + } + start = all_list_len; + all_list_len += count; + all_list = realloc(all_list, sizeof(char *) * all_list_len); + str = data; + for (i = 0; i < data_len && start != all_list_len; i++) { + if (data[i] == '\0') { + all_list[start] = str; + str = data + i + 1; + start++; + } + } +} + +/* + * Parse file, calling action specific functions for: + * 1) Lines containing !E + * 2) Lines containing !I + * 3) Lines containing !D + * 4) Lines containing !F + * 5) Lines containing !P + * 6) Lines containing !C + * 7) Default lines - lines not matching the above + */ +static void parse_file(FILE *infile) +{ + char line[MAXLINESZ]; + char * s; + while (fgets(line, MAXLINESZ, infile)) { + if (line[0] == '!') { + s = line + 2; + switch (line[1]) { + case 'E': + while (*s && !isspace(*s)) s++; + *s = '\0'; + externalfunctions(line+2); + break; + case 'I': + while (*s && !isspace(*s)) s++; + *s = '\0'; + internalfunctions(line+2); + break; + case 'D': + while (*s && !isspace(*s)) s++; + *s = '\0'; + symbolsonly(line+2); + break; + case 'F': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* function names */ + while (isspace(*s)) + s++; + singlefunctions(line +2, s); + break; + case 'P': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* DOC: section name */ + while (isspace(*s)) + s++; + docsection(line + 2, s); + break; + case 'C': + while (*s && !isspace(*s)) s++; + *s = '\0'; + if (findall) + findall(line+2); + break; + default: + defaultline(line); + } + } else { + defaultline(line); + } + } + fflush(stdout); +} + + +int main(int argc, char *argv[]) +{ + FILE * infile; + int i; + + srctree = getenv("SRCTREE"); + if (!srctree) + srctree = getcwd(NULL, 0); + kernsrctree = getenv("KBUILD_SRC"); + if (!kernsrctree || !*kernsrctree) + kernsrctree = srctree; + if (argc != 3) { + usage(); + exit(1); + } + /* Open file, exit on error */ + infile = fopen(argv[2], "r"); + if (infile == NULL) { + fprintf(stderr, "docproc: "); + perror(argv[2]); + exit(2); + } + + if (strcmp("doc", argv[1]) == 0) { + /* Need to do this in two passes. + * First pass is used to collect all symbols exported + * in the various files; + * Second pass generate the documentation. + * This is required because some functions are declared + * and exported in different files :-(( + */ + /* Collect symbols */ + defaultline = noaction; + internalfunctions = find_export_symbols; + externalfunctions = find_export_symbols; + symbolsonly = find_export_symbols; + singlefunctions = noaction2; + docsection = noaction2; + findall = find_all_symbols; + parse_file(infile); + + /* Rewind to start from beginning of file again */ + fseek(infile, 0, SEEK_SET); + defaultline = printline; + internalfunctions = intfunc; + externalfunctions = extfunc; + symbolsonly = printline; + singlefunctions = singfunc; + docsection = docsect; + findall = NULL; + + parse_file(infile); + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + fprintf(stderr, "Warning: didn't use docs for %s\n", + all_list[i]); + } + } else if (strcmp("depend", argv[1]) == 0) { + /* Create first part of dependency chain + * file.tmpl */ + printf("%s\t", argv[2]); + defaultline = noaction; + internalfunctions = adddep; + externalfunctions = adddep; + symbolsonly = adddep; + singlefunctions = adddep2; + docsection = adddep2; + findall = adddep; + parse_file(infile); + printf("\n"); + } else { + fprintf(stderr, "Unknown option: %s\n", argv[1]); + exit(1); + } + fclose(infile); + fflush(stdout); + return exitstatus; +} diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc new file mode 100755 index 0000000..8848efd --- /dev/null +++ b/tools/kernel-doc/kernel-doc @@ -0,0 +1,2554 @@ +#!/usr/bin/perl -w + +use strict; + +## Copyright (c) 1998 Michael Zucchi, All Rights Reserved ## +## Copyright (C) 2000, 1 Tim Waugh twaugh@redhat.com ## +## Copyright (C) 2001 Simon Huggins ## +## Copyright (C) 2005-2012 Randy Dunlap ## +## Copyright (C) 2012 Dan Luedtke ## +## ## +## #define enhancements by Armin Kuster akuster@mvista.com ## +## Copyright (c) 2000 MontaVista Software, Inc. ## +## ## +## This software falls under the GNU General Public License. ## +## Please read the COPYING file for more information ## + +# 18/01/2001 - Cleanups +# Functions prototyped as foo(void) same as foo() +# Stop eval'ing where we don't need to. +# -- huggie@earth.li + +# 27/06/2001 - Allowed whitespace after initial "/**" and +# allowed comments before function declarations. +# -- Christian Kreibich ck@whoop.org + +# Still to do: +# - add perldoc documentation +# - Look more closely at some of the scarier bits :) + +# 26/05/2001 - Support for separate source and object trees. +# Return error code. +# Keith Owens kaos@ocs.com.au + +# 23/09/2001 - Added support for typedefs, structs, enums and unions +# Support for Context section; can be terminated using empty line +# Small fixes (like spaces vs. \s in regex) +# -- Tim Jansen tim@tjansen.de + +# 25/07/2012 - Added support for HTML5 +# -- Dan Luedtke mail@danrl.de + +# +# This will read a 'c' file and scan for embedded comments in the +# style of gnome comments (+minor extensions - see below). +# + +# Note: This only supports 'c'. + +# usage: +# kernel-doc [ -docbook | -html | -html5 | -text | -man | -list ] +# [ -no-doc-sections ] +# [ -function funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# or +# [ -nofunction funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# +# Set output format using one of -docbook -html -html5 -text or -man. +# Default is man. +# The -list format is for internal use by docproc. +# +# -no-doc-sections +# Do not output DOC: sections +# +# -function funcname +# If set, then only generate documentation for the given function(s) or +# DOC: section titles. All other functions and DOC: sections are ignored. +# +# -nofunction funcname +# If set, then only generate documentation for the other function(s)/DOC: +# sections. Cannot be used together with -function (yes, that's a bug -- +# perl hackers can fix it 8)) +# +# c files - list of 'c' files to process +# +# All output goes to stdout, with errors to stderr. + +# +# format of comments. +# In the following table, (...)? signifies optional structure. +# (...)* signifies 0 or more structure elements +# /** +# * function_name(:)? (- short description)? +# (* @parameterx: (description of parameter x)?)* +# (* a blank line)? +# * (Description:)? (Description of function)? +# * (section header: (section description)? )* +# (*)?*/ +# +# So .. the trivial example would be: +# +# /** +# * my_function +# */ +# +# If the Description: header tag is omitted, then there must be a blank line +# after the last parameter specification. +# e.g. +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * +# * Does my stuff explained. +# */ +# +# or, could also use: +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * Description: Does my stuff explained. +# */ +# etc. +# +# Besides functions you can also write documentation for structs, unions, +# enums and typedefs. Instead of the function name you must write the name +# of the declaration; the struct/union/enum/typedef must always precede +# the name. Nesting of declarations is not supported. +# Use the argument mechanism to document members or constants. +# e.g. +# /** +# * struct my_struct - short description +# * @a: first member +# * @b: second member +# * +# * Longer description +# */ +# struct my_struct { +# int a; +# int b; +# /* private: */ +# int c; +# }; +# +# All descriptions can be multiline, except the short function description. +# +# You can also add additional sections. When documenting kernel functions you +# should document the "Context:" of the function, e.g. whether the functions +# can be called form interrupts. Unlike other sections you can end it with an +# empty line. +# Example-sections should contain the string EXAMPLE so that they are marked +# appropriately in DocBook. +# +# Example: +# /** +# * user_function - function that can only be called in user context +# * @a: some argument +# * Context: !in_interrupt() +# * +# * Some description +# * Example: +# * user_function(22); +# */ +# ... +# +# +# All descriptive text is further processed, scanning for the following special +# patterns, which are highlighted appropriately. +# +# 'funcname()' - function +# '$ENVVAR' - environmental variable +# '&struct_name' - name of a structure (up to two words including 'struct') +# '@parameter' - name of a parameter +# '%CONST' - name of a constant. + +## init lots of data + +my $errors = 0; +my $warnings = 0; +my $anon_struct_union = 0; + +# match expressions used to find embedded type information +my $type_constant = '%([-_\w]+)'; +my $type_func = '(\w+)()'; +my $type_param = '@(\w+)'; +my $type_struct = '&((struct\s*)*[_\w]+)'; +my $type_struct_xml = '\&((struct\s*)*[_\w]+)'; +my $type_env = '($\w+)'; + +# Output conversion substitutions. +# One for each output format + +# these work fairly well +my %highlights_html = ( $type_constant, "<i>$1</i>", + $type_func, "<b>$1</b>", + $type_struct_xml, "<i>$1</i>", + $type_env, "<b><i>$1</i></b>", + $type_param, "<tt><b>$1</b></tt>" ); +my $local_lt = "\\\\lt:"; +my $local_gt = "\\\\gt:"; +my $blankline_html = $local_lt . "p" . $local_gt; # was "<p>" + +# html version 5 +my %highlights_html5 = ( $type_constant, "<span class="const">$1</span>", + $type_func, "<span class="func">$1</span>", + $type_struct_xml, "<span class="struct">$1</span>", + $type_env, "<span class="env">$1</span>", + $type_param, "<span class="param">$1</span>" ); +my $blankline_html5 = $local_lt . "br /" . $local_gt; + +# XML, docbook format +my %highlights_xml = ( "([^=])\"([^\"<]+)\"", "$1<quote>$2</quote>", + $type_constant, "<constant>$1</constant>", + $type_func, "<function>$1</function>", + $type_struct_xml, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_xml = $local_lt . "/para" . $local_gt . $local_lt . "para" . $local_gt . "\n"; + +# gnome, docbook format +my %highlights_gnome = ( $type_constant, "<replaceable class="option">$1</replaceable>", + $type_func, "<function>$1</function>", + $type_struct, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_gnome = "</para><para>\n"; + +# these are pretty rough +my %highlights_man = ( $type_constant, "$1", + $type_func, "\\fB$1\\fP", + $type_struct, "\\fI$1\\fP", + $type_param, "\\fI$1\\fP" ); +my $blankline_man = ""; + +# text-mode +my %highlights_text = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_text = ""; + +# list mode +my %highlights_list = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_list = ""; + +# read arguments +if ($#ARGV == -1) { + usage(); +} + +my $kernelversion; +my $dohighlight = ""; + +my $verbose = 0; +my $output_mode = "man"; +my $no_doc_sections = 0; +my %highlights = %highlights_man; +my $blankline = $blankline_man; +my $modulename = "Bootloader API"; +my $function_only = 0; +my $man_date = ('January', 'February', 'March', 'April', 'May', 'June', + 'July', 'August', 'September', 'October', + 'November', 'December')[(localtime)[4]] . + " " . ((localtime)[5]+1900); + +# Essentially these are globals. +# They probably want to be tidied up, made more localised or something. +# CAVEAT EMPTOR! Some of the others I localised may not want to be, which +# could cause "use of undefined value" or other bugs. +my ($function, %function_table, %parametertypes, $declaration_purpose); +my ($type, $declaration_name, $return_type); +my ($newsection, $newcontents, $prototype, $brcount, %source_map); + +if (defined($ENV{'KBUILD_VERBOSE'})) { + $verbose = "$ENV{'KBUILD_VERBOSE'}"; +} + +# Generated docbook code is inserted in a template at a point where +# docbook v3.1 requires a non-zero sequence of RefEntry's; see: +# http://www.oasis-open.org/docbook/documentation/reference/html/refentry.html +# We keep track of number of generated entries and generate a dummy +# if needs be to ensure the expanded template can be postprocessed +# into html. +my $section_counter = 0; + +my $lineprefix=""; + +# states +# 0 - normal code +# 1 - looking for function name +# 2 - scanning field start. +# 3 - scanning prototype. +# 4 - documentation block +my $state; +my $in_doc_sect; + +#declaration types: can be +# 'function', 'struct', 'union', 'enum', 'typedef' +my $decl_type; + +my $doc_special = "@%$&"; + +my $doc_start = '^/**\s*$'; # Allow whitespace at end of comment start. +my $doc_end = '*/'; +my $doc_com = '\s**\s*'; +my $doc_decl = $doc_com . '(\w+)'; +my $doc_sect = $doc_com . '([' . $doc_special . ']?[\w\s]+):(.*)'; +my $doc_content = $doc_com . '(.*)'; +my $doc_block = $doc_com . 'DOC:\s*(.*)?'; + +my %constants; +my %parameterdescs; +my @parameterlist; +my %sections; +my @sectionlist; +my $sectcheck; +my $struct_actual; + +my $contents = ""; +my $section_default = "Description"; # default section +my $section_intro = "Introduction"; +my $section = $section_default; +my $section_context = "Context"; + +my $undescribed = "-- undescribed --"; + +reset_state(); + +while ($ARGV[0] =~ m/^-(.*)/) { + my $cmd = shift @ARGV; + if ($cmd eq "-html") { + $output_mode = "html"; + %highlights = %highlights_html; + $blankline = $blankline_html; + } elsif ($cmd eq "-html5") { + $output_mode = "html5"; + %highlights = %highlights_html5; + $blankline = $blankline_html5; + } elsif ($cmd eq "-man") { + $output_mode = "man"; + %highlights = %highlights_man; + $blankline = $blankline_man; + } elsif ($cmd eq "-text") { + $output_mode = "text"; + %highlights = %highlights_text; + $blankline = $blankline_text; + } elsif ($cmd eq "-docbook") { + $output_mode = "xml"; + %highlights = %highlights_xml; + $blankline = $blankline_xml; + } elsif ($cmd eq "-list") { + $output_mode = "list"; + %highlights = %highlights_list; + $blankline = $blankline_list; + } elsif ($cmd eq "-gnome") { + $output_mode = "gnome"; + %highlights = %highlights_gnome; + $blankline = $blankline_gnome; + } elsif ($cmd eq "-module") { # not needed for XML, inherits from calling document + $modulename = shift @ARGV; + } elsif ($cmd eq "-function") { # to only output specific functions + $function_only = 1; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-nofunction") { # to only output specific functions + $function_only = 2; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-v") { + $verbose = 1; + } elsif (($cmd eq "-h") || ($cmd eq "--help")) { + usage(); + } elsif ($cmd eq '-no-doc-sections') { + $no_doc_sections = 1; + } +} + +# continue execution near EOF; + +sub usage { + print "Usage: $0 [ -docbook | -html | -html5 | -text | -man | -list ]\n"; + print " [ -no-doc-sections ]\n"; + print " [ -function funcname [ -function funcname ...] ]\n"; + print " [ -nofunction funcname [ -nofunction funcname ...] ]\n"; + print " [ -v ]\n"; + print " c source file(s) > outputfile\n"; + print " -v : verbose output, more warnings & other info listed\n"; + exit 1; +} + +# get kernel version from env +sub get_kernel_version() { + my $version = 'unknown kernel version'; + + if (defined($ENV{'U_BOOT_VERSION'})) { + $version = $ENV{'U_BOOT_VERSION'}; + } + return $version; +} + +## +# dumps section contents to arrays/hashes intended for that purpose. +# +sub dump_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($name =~ m/$type_constant/) { + $name = $1; +# print STDERR "constant section '$1' = '$contents'\n"; + $constants{$name} = $contents; + } elsif ($name =~ m/$type_param/) { +# print STDERR "parameter def '$1' = '$contents'\n"; + $name = $1; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } elsif ($name eq "@...") { +# print STDERR "parameter def '...' = '$contents'\n"; + $name = "..."; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } else { +# print STDERR "other section '$name' = '$contents'\n"; + if (defined($sections{$name}) && ($sections{$name} ne "")) { + print STDERR "Error(${file}:$.): duplicate section name '$name'\n"; + ++$errors; + } + $sections{$name} = $contents; + push @sectionlist, $name; + } +} + +## +# dump DOC: section after checking that it should go out +# +sub dump_doc_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($no_doc_sections) { + return; + } + + if (($function_only == 0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + dump_section($file, $name, $contents); + output_blockhead({'sectionlist' => @sectionlist, + 'sections' => %sections, + 'module' => $modulename, + 'content-only' => ($function_only != 0), }); + } +} + +## +# output function +# +# parameterdescs, a hash. +# function => "function name" +# parameterlist => @list of parameters +# parameterdescs => %parameter descriptions +# sectionlist => @list of sections +# sections => %section descriptions +# + +sub output_highlight { + my $contents = join "\n",@_; + my $line; + +# DEBUG +# if (!defined $contents) { +# use Carp; +# confess "output_highlight got called with no args?\n"; +# } + + if ($output_mode eq "html" || $output_mode eq "html5" || + $output_mode eq "xml") { + $contents = local_unescape($contents); + # convert data read & converted thru xml_escape() into &xyz; format: + $contents =~ s/\\\/&/g; + } +# print STDERR "contents b4:$contents\n"; + eval $dohighlight; + die $@ if $@; +# print STDERR "contents af:$contents\n"; + +# strip whitespaces when generating html5 + if ($output_mode eq "html5") { + $contents =~ s/^\s+//; + $contents =~ s/\s+$//; + } + foreach $line (split "\n", $contents) { + if ($line eq ""){ + print $lineprefix, local_unescape($blankline); + } else { + $line =~ s/\\\/&/g; + if ($output_mode eq "man" && substr($line, 0, 1) eq ".") { + print "\&$line"; + } else { + print $lineprefix, $line; + } + } + print "\n"; + } +} + +# output sections in html +sub output_section_html(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<blockquote>\n"; + output_highlight($args{'sections'}{$section}); + print "</blockquote>\n"; + } +} + +# output enum in html +sub output_enum_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>enum " . $args{'enum'} . "</h2>\n"; + + print "<b>enum " . $args{'enum'} . "</b> {<br>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " <b>" . $parameter . "</b>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + print "<br>"; + } + print "};<br>\n"; + + print "<h3>Constants</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output typedef in html +sub output_typedef_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>typedef " . $args{'typedef'} . "</h2>\n"; + + print "<b>typedef " . $args{'typedef'} . "</b>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output struct in html +sub output_struct_html(%) { + my %args = %{$_[0]}; + my ($parameter); + + print "<h2>" . $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<b>" . $args{'type'} . " " . $args{'struct'} . "</b> {<br>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter<br>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <i>$1</i><b>$parameter</b>) <i>($2)</i>;<br>\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " <i>$1</i> <b>$parameter</b>$2;<br>\n"; + } else { + print " <i>$type</i> <b>$parameter</b>;<br>\n"; + } + } + print "};<br>\n"; + + print "<h3>Members</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output function in html +sub output_function_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print "<h2>" . $args{'function'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<i>" . $args{'functiontype'} . "</i>\n"; + print "<b>" . $args{'function'} . "</b>\n"; + print "("; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<i>$1</i><b>$parameter</b>) <i>($2)</i>"; + } else { + print "<i>" . $type . "</i> <b>" . $parameter . "</b>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + } + print ")\n"; + + print "<h3>Arguments</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output DOC: block header in html +sub output_blockhead_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<ul>\n"; + output_highlight($args{'sections'}{$section}); + print "</ul>\n"; + } + print "<hr>\n"; +} + +# output sections in html5 +sub output_section_html5(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<section>\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + print "</section>\n"; + } +} + +# output enum in html5 +sub output_enum_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'enum'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="enum" id="enum:". $html5id . "">"; + print "<h1>enum " . $args{'enum'} . "</h1>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">enum</span> "; + print "<span class="identifier">" . $args{'enum'} . "</span> {"; + print "</li>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + print "<span class="param">" . $parameter . "</span>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Constants</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output typedef in html5 +sub output_typedef_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'typedef'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="typedef" id="typedef:" . $html5id . "">\n"; + print "<h1>typedef " . $args{'typedef'} . "</h1>\n"; + + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">typedef</span> "; + print "<span class="identifier">" . $args{'typedef'} . "</span>"; + print "</li>\n"; + print "</ol>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output struct in html5 +sub output_struct_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $html5id; + + $html5id = $args{'struct'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="struct" id="struct:" . $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'type'} . " " . $args{'struct'} . "</h1>"; + print "<h2>". $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'type'} . "</span> "; + print "<span class="identifier">" . $args{'struct'} . "</span> {"; + print "</li>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + if ($parameter =~ /^#/) { + print "<span class="param">" . $parameter ."</span>\n"; + print "</li>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>);"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="bits">$2</span>;"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>;"; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Members</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output function in html5 +sub output_function_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + $html5id = $args{'function'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="function" id="func:". $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'function'} . "</h1>"; + print "<h2>" . $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'functiontype'} . "</span> "; + print "<span class="identifier">" . $args{'function'} . "</span> ("; + print "</li>"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>)"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>)</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Arguments</h1>\n"; + print "<p>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output DOC: block header in html5 +sub output_blockhead_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + foreach $section (@{$args{'sectionlist'}}) { + $html5id = $section; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="doc" id="doc:". $html5id . "">\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + } + print "</article>\n"; +} + +sub output_section_xml(%) { + my %args = %{$_[0]}; + my $section; + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<refsect1>\n"; + print "<title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<informalexample><programlisting>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></informalexample>\n"; + } else { + print "</para>\n"; + } + print "</refsect1>\n"; + } +} + +# output function in XML DocBook +sub output_function_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'function'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'function'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <funcsynopsis><funcprototype>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " </function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1<parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void/>\n"; + } + print " </funcprototype></funcsynopsis>\n"; + print "</refsynopsisdiv>\n"; + + # print parameters + print "<refsect1>\n <title>Arguments</title>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>\n <term><parameter>$parameter</parameter></term>\n"; + print " <listitem>\n <para>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para>\n </listitem>\n </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print "</refsect1>\n"; + + output_section_xml(@_); + print "</refentry>\n\n"; +} + +# output struct in XML DocBook +sub output_struct_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-struct-" . $args{'struct'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'type'} . " " . $args{'struct'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'type'} . " " . $args{'struct'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + my $prm = $parameter; + # convert data read & converted thru xml_escape() into &xyz; format: + # This allows us to have #define macros interspersed in a struct. + $prm =~ s/\\\/&/g; + print "$prm\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " $1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " $1 $parameter$2;\n"; + } else { + print " " . $type . " " . $parameter . ";\n"; + } + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print " <refsect1>\n"; + print " <title>Members</title>\n"; + + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print " </refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output enum in XML DocBook +sub output_enum_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-enum-" . $args{'enum'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>enum " . $args{'enum'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>enum " . $args{'enum'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " $parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print "<refsect1>\n"; + print " <title>Constants</title>\n"; + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + print "</refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output typedef in XML DocBook +sub output_typedef_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-typedef-" . $args{'typedef'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>typedef " . $args{'typedef'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>typedef " . $args{'typedef'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <synopsis>typedef " . $args{'typedef'} . ";</synopsis>\n"; + print "</refsynopsisdiv>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output in XML DocBook +sub output_blockhead_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + my $id = $args{'module'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + if (!$args{'content-only'}) { + print "<refsect1>\n <title>$section</title>\n"; + } + if ($section =~ m/EXAMPLE/i) { + print "<example><para>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</para></example>\n"; + } else { + print "</para>"; + } + if (!$args{'content-only'}) { + print "\n</refsect1>\n"; + } + } + + print "\n\n"; +} + +# output in XML DocBook +sub output_function_gnome { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = $args{'module'} . "-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<sect2>\n"; + print " <title id="$id">" . $args{'function'} . "</title>\n"; + + print " <funcsynopsis>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " "; + print "</function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1 <parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void>\n"; + } + print " </funcsynopsis>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <informaltable pgwide="1" frame="none" role="params">\n"; + print "<tgroup cols="2">\n"; + print "<colspec colwidth="2*">\n"; + print "<colspec colwidth="8*">\n"; + print "<tbody>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <row><entry align="right"><parameter>$parameter</parameter></entry>\n"; + print " <entry>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </entry></row>\n"; + } + print " </tbody></tgroup></informaltable>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<simplesect>\n <title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<example><programlisting>\n"; + } else { + } + print "<para>\n"; + output_highlight($args{'sections'}{$section}); + print "</para>\n"; + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></example>\n"; + } else { + } + print " </simplesect>\n"; + } + + print "</sect2>\n\n"; +} + +## +# output function in man +sub output_function_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'function'}" 9 "$args{'function'}" "$man_date" "Bootloader Hacker's Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'function'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + if ($args{'functiontype'} ne "") { + print ".B "" . $args{'functiontype'} . "" " . $args{'function'} . "\n"; + } else { + print ".B "" . $args{'function'} . "\n"; + } + $count = 0; + my $parenth = "("; + my $post = ","; + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($count == $#{$args{'parameterlist'}}) { + $post = ");"; + } + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI "" . $parenth . $1 . "" " . $parameter . " ") (" . $2 . ")" . $post . ""\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI "" . $parenth . $type . "" " . $parameter . " "" . $post . ""\n"; + } + $count++; + $parenth = ""; + } + + print ".SH ARGUMENTS\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "", uc $section, ""\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output enum in man +sub output_enum_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "enum $args{'enum'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "enum " . $args{'enum'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + print ".br\n.BI " $parameter"\n"; + if ($count == $#{$args{'parameterlist'}}) { + print "\n};\n"; + last; + } + else { + print ", \n.br\n"; + } + $count++; + } + + print ".SH Constants\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output struct in man +sub output_struct_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "" . $args{'type'} . " " . $args{'struct'} . "" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'type'} . " " . $args{'struct'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n.br\n"; + + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print ".BI "$parameter"\n.br\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI " " . $1 . "" " . $parameter . " ") (" . $2 . ")" . ""\n;\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print ".BI " " . $1 . "\ " " . $parameter . $2 . " "" . ""\n;\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI " " . $type . "" " . $parameter . " "" . ""\n;\n"; + } + print "\n.br\n"; + } + print "};\n.br\n"; + + print ".SH Members\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output typedef in man +sub output_typedef_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "$args{'typedef'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "typedef " . $args{'typedef'} . " \- " . $args{'purpose'} . "\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +sub output_blockhead_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "$args{'module'}" "$man_date" "API Manual" U-BOOT\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output in text +sub output_function_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $start; + + print "Name:\n\n"; + print $args{'function'} . " - " . $args{'purpose'} . "\n"; + + print "\nSynopsis:\n\n"; + if ($args{'functiontype'} ne "") { + $start = $args{'functiontype'} . " " . $args{'function'} . " ("; + } else { + $start = $args{'function'} . " ("; + } + print $start; + + my $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print $1 . $parameter . ") (" . $2; + } else { + print $type . " " . $parameter; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + print " " x length($start); + } else { + print ");\n\n"; + } + } + + print "Arguments:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print $parameter . "\n\t" . $args{'parameterdescs'}{$parameter_name} . "\n"; + } + output_section_text(@_); +} + +#output sections in text +sub output_section_text(%) { + my %args = %{$_[0]}; + my $section; + + print "\n"; + foreach $section (@{$args{'sectionlist'}}) { + print "$section:\n\n"; + output_highlight($args{'sections'}{$section}); + } + print "\n\n"; +} + +# output enum in text +sub output_enum_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Enum:\n\n"; + + print "enum " . $args{'enum'} . " - " . $args{'purpose'} . "\n\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "\t$parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};\n\n"; + + print "Constants:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter} . "\n"; + } + + output_section_text(@_); +} + +# output typedef in text +sub output_typedef_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Typedef:\n\n"; + + print "typedef " . $args{'typedef'} . " - " . $args{'purpose'} . "\n"; + output_section_text(@_); +} + +# output struct as text +sub output_struct_text(%) { + my %args = %{$_[0]}; + my ($parameter); + + print $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "\n\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "\t$1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "\t$1 $parameter$2;\n"; + } else { + print "\t" . $type . " " . $parameter . ";\n"; + } + } + print "};\n\n"; + + print "Members:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter_name} . "\n"; + } + print "\n"; + output_section_text(@_); +} + +sub output_blockhead_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print " $section:\n"; + print " -> "; + output_highlight($args{'sections'}{$section}); + } +} + +## list mode output functions + +sub output_function_list(%) { + my %args = %{$_[0]}; + + print $args{'function'} . "\n"; +} + +# output enum in list +sub output_enum_list(%) { + my %args = %{$_[0]}; + print $args{'enum'} . "\n"; +} + +# output typedef in list +sub output_typedef_list(%) { + my %args = %{$_[0]}; + print $args{'typedef'} . "\n"; +} + +# output struct as list +sub output_struct_list(%) { + my %args = %{$_[0]}; + + print $args{'struct'} . "\n"; +} + +sub output_blockhead_list(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print "DOC: $section\n"; + } +} + +## +# generic output function for all types (function, struct/union, typedef, enum); +# calls the generated, variable output_ function name based on +# functype and output_mode +sub output_declaration { + no strict 'refs'; + my $name = shift; + my $functype = shift; + my $func = "output_${functype}_$output_mode"; + if (($function_only==0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + &$func(@_); + $section_counter++; + } +} + +## +# generic output function - calls the right one based on current output mode. +sub output_blockhead { + no strict 'refs'; + my $func = "output_blockhead_" . $output_mode; + &$func(@_); + $section_counter++; +} + +## +# takes a declaration (struct, union, enum, typedef) and +# invokes the right handler. NOT called for functions. +sub dump_declaration($$) { + no strict 'refs'; + my ($prototype, $file) = @_; + my $func = "dump_" . $decl_type; + &$func(@_); +} + +sub dump_union($$) { + dump_struct(@_); +} + +sub dump_struct($$) { + my $x = shift; + my $file = shift; + my $nested; + + if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}/) { + #my $decl_type = $1; + $declaration_name = $2; + my $members = $3; + + # ignore embedded structs or unions + $members =~ s/({.*})//g; + $nested = $1; + + # ignore members marked private: + $members =~ s//*\s*private:.*?/*\s*public:.*?*///gos; + $members =~ s//*\s*private:.*//gos; + # strip comments: + $members =~ s//*.*?*///gos; + $nested =~ s//*.*?*///gos; + # strip kmemcheck_bitfield_{begin,end}.*; + $members =~ s/kmemcheck_bitfield_.*?;//gos; + # strip attributes + $members =~ s/__aligned\s*(\d+)//gos; + + create_parameterlist($members, ';', $file); + check_sections($file, $declaration_name, "struct", $sectcheck, $struct_actual, $nested); + + output_declaration($declaration_name, + 'struct', + {'struct' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose, + 'type' => $decl_type + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse struct or union!\n"; + ++$errors; + } +} + +sub dump_enum($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + $x =~ s/^#\s*define\s+.*$//; # strip #define macros inside enums + + if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { + $declaration_name = $1; + my $members = $2; + + foreach my $arg (split ',', $members) { + $arg =~ s/^\s*(\w+).*/$1/; + push @parameterlist, $arg; + if (!$parameterdescs{$arg}) { + $parameterdescs{$arg} = $undescribed; + print STDERR "Warning(${file}:$.): Enum value '$arg' ". + "not described in enum '$declaration_name'\n"; + } + + } + + output_declaration($declaration_name, + 'enum', + {'enum' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse enum!\n"; + ++$errors; + } +} + +sub dump_typedef($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + while (($x =~ /(*.)\s*;$/) || ($x =~ /[*.]\s*;$/)) { + $x =~ s/(*.)\s*;$/;/; + $x =~ s/[*.]\s*;$/;/; + } + + if ($x =~ /typedef.*\s+(\w+)\s*;/) { + $declaration_name = $1; + + output_declaration($declaration_name, + 'typedef', + {'typedef' => $declaration_name, + 'module' => $modulename, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse typedef!\n"; + ++$errors; + } +} + +sub save_struct_actual($) { + my $actual = shift; + + # strip all spaces from the actual param so that it looks like one string item + $actual =~ s/\s*//g; + $struct_actual = $struct_actual . $actual . " "; +} + +sub create_parameterlist($$$) { + my $args = shift; + my $splitter = shift; + my $file = shift; + my $type; + my $param; + + # temporarily replace commas inside function pointer definition + while ($args =~ /(([^),]+),/) { + $args =~ s/(([^),]+),/$1#/g; + } + + foreach my $arg (split($splitter, $args)) { + # strip comments + $arg =~ s//*.**///; + # strip leading/trailing spaces + $arg =~ s/^\s*//; + $arg =~ s/\s*$//; + $arg =~ s/\s+/ /; + + if ($arg =~ /^#/) { + # Treat preprocessor directive as a typeless variable just to fill + # corresponding data structures "correctly". Catch it later in + # output_* subs. + push_parameter($arg, "", $file); + } elsif ($arg =~ m/(.+)\s*(/) { + # pointer-to-function + $arg =~ tr/#/,/; + $arg =~ m/[^(]+(*?\s*(\w*)\s*)/; + $param = $1; + $type = $arg; + $type =~ s/([^(]+(*?)\s*$param/$1/; + save_struct_actual($param); + push_parameter($param, $type, $file); + } elsif ($arg) { + $arg =~ s/\s*:\s*/:/g; + $arg =~ s/\s*[/[/g; + + my @args = split('\s*,\s*', $arg); + if ($args[0] =~ m/*/) { + $args[0] =~ s/(*+)\s*/ $1/; + } + + my @first_arg; + if ($args[0] =~ /^(.*\s+)(.*?[.*].*)$/) { + shift @args; + push(@first_arg, split('\s+', $1)); + push(@first_arg, $2); + } else { + @first_arg = split('\s+', shift @args); + } + + unshift(@args, pop @first_arg); + $type = join " ", @first_arg; + + foreach $param (@args) { + if ($param =~ m/^(*+)\s*(.*)/) { + save_struct_actual($2); + push_parameter($2, "$type $1", $file); + } + elsif ($param =~ m/(.*?):(\d+)/) { + if ($type ne "") { # skip unnamed bit-fields + save_struct_actual($1); + push_parameter($1, "$type:$2", $file) + } + } + else { + save_struct_actual($param); + push_parameter($param, $type, $file); + } + } + } + } +} + +sub push_parameter($$$) { + my $param = shift; + my $type = shift; + my $file = shift; + + if (($anon_struct_union == 1) && ($type eq "") && + ($param eq "}")) { + return; # ignore the ending }; from anon. struct/union + } + + $anon_struct_union = 0; + my $param_name = $param; + $param_name =~ s/[.*//; + + if ($type eq "" && $param =~ /...$/) + { + if (!defined $parameterdescs{$param} || $parameterdescs{$param} eq "") { + $parameterdescs{$param} = "variable arguments"; + } + } + elsif ($type eq "" && ($param eq "" or $param eq "void")) + { + $param="void"; + $parameterdescs{void} = "no arguments"; + } + elsif ($type eq "" && ($param eq "struct" or $param eq "union")) + # handle unnamed (anonymous) union or struct: + { + $type = $param; + $param = "{unnamed_" . $param . "}"; + $parameterdescs{$param} = "anonymous\n"; + $anon_struct_union = 1; + } + + # warn if parameter has no description + # (but ignore ones starting with # as these are not parameters + # but inline preprocessor statements); + # also ignore unnamed structs/unions; + if (!$anon_struct_union) { + if (!defined $parameterdescs{$param_name} && $param_name !~ /^#/) { + + $parameterdescs{$param_name} = $undescribed; + + if (($type eq 'function') || ($type eq 'enum')) { + print STDERR "Warning(${file}:$.): Function parameter ". + "or member '$param' not " . + "described in '$declaration_name'\n"; + } + print STDERR "Warning(${file}:$.):" . + " No description found for parameter '$param'\n"; + ++$warnings; + } + } + + $param = xml_escape($param); + + # strip spaces from $param so that it is one continuous string + # on @parameterlist; + # this fixes a problem where check_sections() cannot find + # a parameter like "addr[6 + 2]" because it actually appears + # as "addr[6", "+", "2]" on the parameter list; + # but it's better to maintain the param string unchanged for output, + # so just weaken the string compare in check_sections() to ignore + # "[blah" in a parameter string; + ###$param =~ s/\s*//g; + push @parameterlist, $param; + $parametertypes{$param} = $type; +} + +sub check_sections($$$$$$) { + my ($file, $decl_name, $decl_type, $sectcheck, $prmscheck, $nested) = @_; + my @sects = split ' ', $sectcheck; + my @prms = split ' ', $prmscheck; + my $err; + my ($px, $sx); + my $prm_clean; # strip trailing "[array size]" and/or beginning "*" + + foreach $sx (0 .. $#sects) { + $err = 1; + foreach $px (0 .. $#prms) { + $prm_clean = $prms[$px]; + $prm_clean =~ s/[.*]//; + $prm_clean =~ s/__attribute__\s*(([a-z,_*\s()]*))//i; + # ignore array size in a parameter string; + # however, the original param string may contain + # spaces, e.g.: addr[6 + 2] + # and this appears in @prms as "addr[6" since the + # parameter list is split at spaces; + # hence just ignore "[..." for the sections check; + $prm_clean =~ s/[.*//; + + ##$prm_clean =~ s/^**//; + if ($prm_clean eq $sects[$sx]) { + $err = 0; + last; + } + } + if ($err) { + if ($decl_type eq "function") { + print STDERR "Warning(${file}:$.): " . + "Excess function parameter " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } else { + if ($nested !~ m/\Q$sects[$sx]\E/) { + print STDERR "Warning(${file}:$.): " . + "Excess struct/union/enum/typedef member " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } + } + } + } +} + +## +# takes a function prototype and the name of the current file being +# processed and spits out all the details stored in the global +# arrays/hashes. +sub dump_function($$) { + my $prototype = shift; + my $file = shift; + + $prototype =~ s/^static +//; + $prototype =~ s/^extern +//; + $prototype =~ s/^asmlinkage +//; + $prototype =~ s/^inline +//; + $prototype =~ s/^__inline__ +//; + $prototype =~ s/^__inline +//; + $prototype =~ s/^__always_inline +//; + $prototype =~ s/^noinline +//; + $prototype =~ s/__devinit +//; + $prototype =~ s/__init +//; + $prototype =~ s/__init_or_module +//; + $prototype =~ s/__must_check +//; + $prototype =~ s/__weak +//; + $prototype =~ s/^#\s*define\s+//; #ak added + $prototype =~ s/__attribute__\s*(([a-z,]*))//; + + # Yes, this truly is vile. We are looking for: + # 1. Return type (may be nothing if we're looking at a macro) + # 2. Function name + # 3. Function parameters. + # + # All the while we have to watch out for function pointer parameters + # (which IIRC is what the two sections are for), C types (these + # regexps don't even start to express all the possibilities), and + # so on. + # + # If you mess with these regexps, it's a good idea to check that + # the following functions' documentation still comes out right: + # - parport_register_device (function pointer parameters) + # - atomic_set (macro) + # - pci_match_device, __copy_to_user (long return type) + + if ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**+)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**\s*\w+\s**\s*)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/) { + $return_type = $1; + $declaration_name = $2; + my $args = $3; + + create_parameterlist($args, ',', $file); + } else { + print STDERR "Error(${file}:$.): cannot understand prototype: '$prototype'\n"; + ++$errors; + return; + } + + my $prms = join " ", @parameterlist; + check_sections($file, $declaration_name, "function", $sectcheck, $prms, ""); + + output_declaration($declaration_name, + 'function', + {'function' => $declaration_name, + 'module' => $modulename, + 'functiontype' => $return_type, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); +} + +sub reset_state { + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $sectcheck = ""; + $struct_actual = ""; + $prototype = ""; + + $state = 0; +} + +sub tracepoint_munge($) { + my $file = shift; + my $tracepointname = 0; + my $tracepointargs = 0; + + if ($prototype =~ m/TRACE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_SINGLE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_EVENT((.*?),(.*?),/) { + $tracepointname = $2; + } + $tracepointname =~ s/^\s+//; #strip leading whitespace + if ($prototype =~ m/TP_PROTO((.*?))/) { + $tracepointargs = $1; + } + if (($tracepointname eq 0) || ($tracepointargs eq 0)) { + print STDERR "Warning(${file}:$.): Unrecognized tracepoint format: \n". + "$prototype\n"; + } else { + $prototype = "static inline void trace_$tracepointname($tracepointargs)"; + } +} + +sub syscall_munge() { + my $void = 0; + + $prototype =~ s@[\r\n\t]+@ @gos; # strip newlines/CR's/tabs +## if ($prototype =~ m/SYSCALL_DEFINE0\s*(\s*(a-zA-Z0-9_)*\s*)/) { + if ($prototype =~ m/SYSCALL_DEFINE0/) { + $void = 1; +## $prototype = "long sys_$1(void)"; + } + + $prototype =~ s/SYSCALL_DEFINE.*(/long sys_/; # fix return type & func name + if ($prototype =~ m/long (sys_.*?),/) { + $prototype =~ s/,/(/; + } elsif ($void) { + $prototype =~ s/)/(void)/; + } + + # now delete all of the odd-number commas in $prototype + # so that arg types & arg names don't have a comma between them + my $count = 0; + my $len = length($prototype); + if ($void) { + $len = 0; # skip the for-loop + } + for (my $ix = 0; $ix < $len; $ix++) { + if (substr($prototype, $ix, 1) eq ',') { + $count++; + if ($count % 2 == 1) { + substr($prototype, $ix, 1) = ' '; + } + } + } +} + +sub process_state3_function($$) { + my $x = shift; + my $file = shift; + + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ m#\s*/*\s+MACDOC\s*#io || ($x =~ /^#/ && $x !~ /^#\s*define/)) { + # do nothing + } + elsif ($x =~ /([^{]*)/) { + $prototype .= $1; + } + + if (($x =~ /{/) || ($x =~ /#\s*define/) || ($x =~ /;/)) { + $prototype =~ s@/*.*?*/@@gos; # strip comments. + $prototype =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $prototype =~ s@^\s+@@gos; # strip leading spaces + if ($prototype =~ /SYSCALL_DEFINE/) { + syscall_munge(); + } + if ($prototype =~ /TRACE_EVENT/ || $prototype =~ /DEFINE_EVENT/ || + $prototype =~ /DEFINE_SINGLE_EVENT/) + { + tracepoint_munge($file); + } + dump_function($prototype, $file); + reset_state(); + } +} + +sub process_state3_type($$) { + my $x = shift; + my $file = shift; + + $x =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $x =~ s@^\s+@@gos; # strip leading spaces + $x =~ s@\s+$@@gos; # strip trailing spaces + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ /^#/) { + # To distinguish preprocessor directive from regular declaration later. + $x .= ";"; + } + + while (1) { + if ( $x =~ /([^{};]*)([{};])(.*)/ ) { + $prototype .= $1 . $2; + ($2 eq '{') && $brcount++; + ($2 eq '}') && $brcount--; + if (($2 eq ';') && ($brcount == 0)) { + dump_declaration($prototype, $file); + reset_state(); + last; + } + $x = $3; + } else { + $prototype .= $x; + last; + } + } +} + +# xml_escape: replace <, >, and & in the text stream; +# +# however, formatting controls that are generated internally/locally in the +# kernel-doc script are not escaped here; instead, they begin life like +# $blankline_html (4 of '' followed by a mnemonic + ':'), then these strings +# are converted to their mnemonic-expected output, without the 4 * '' & ':', +# just before actual output; (this is done by local_unescape()) +sub xml_escape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/&/\\\amp;/g; + $text =~ s/</\\\lt;/g; + $text =~ s/>/\\\gt;/g; + return $text; +} + +# convert local escape strings to html +# local escape strings look like: '\\menmonic:' (that's 4 backslashes) +sub local_unescape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/\\\\lt:/</g; + $text =~ s/\\\\gt:/>/g; + return $text; +} + +sub process_file($) { + my $file; + my $identifier; + my $func; + my $descr; + my $in_purpose = 0; + my $initial_section_counter = $section_counter; + + if (defined($ENV{'SRCTREE'})) { + $file = "$ENV{'SRCTREE'}" . "/" . "@_"; + } + else { + $file = "@_"; + } + if (defined($source_map{$file})) { + $file = $source_map{$file}; + } + + if (!open(IN,"<$file")) { + print STDERR "Error: Cannot open file $file\n"; + ++$errors; + return; + } + + $. = 1; + + $section_counter = 0; + while (<IN>) { + if ($state == 0) { + if (/$doc_start/o) { + $state = 1; # next line is always the function name + $in_doc_sect = 0; + } + } elsif ($state == 1) { # this line is the function name (always) + if (/$doc_block/o) { + $state = 4; + $contents = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_decl/o) { + $identifier = $1; + if (/\s*([\w\s]+?)\s*-/) { + $identifier = $1; + } + + $state = 2; + if (/-(.*)/) { + # strip leading/trailing/multiple spaces + $descr= $1; + $descr =~ s/^\s*//; + $descr =~ s/\s*$//; + $descr =~ s/\s+/ /; + $declaration_purpose = xml_escape($descr); + $in_purpose = 1; + } else { + $declaration_purpose = ""; + } + + if (($declaration_purpose eq "") && $verbose) { + print STDERR "Warning(${file}:$.): missing initial short description on line:\n"; + print STDERR $_; + ++$warnings; + } + + if ($identifier =~ m/^struct/) { + $decl_type = 'struct'; + } elsif ($identifier =~ m/^union/) { + $decl_type = 'union'; + } elsif ($identifier =~ m/^enum/) { + $decl_type = 'enum'; + } elsif ($identifier =~ m/^typedef/) { + $decl_type = 'typedef'; + } else { + $decl_type = 'function'; + } + + if ($verbose) { + print STDERR "Info(${file}:$.): Scanning doc for $identifier\n"; + } + } else { + print STDERR "Warning(${file}:$.): Cannot understand $_ on line $.", + " - I thought it was a doc line\n"; + ++$warnings; + $state = 0; + } + } elsif ($state == 2) { # look for head: lines, and include content + if (/$doc_sect/o) { + $newsection = $1; + $newcontents = $2; + + if (($contents ne "") && ($contents ne "\n")) { + if (!$in_doc_sect && $verbose) { + print STDERR "Warning(${file}:$.): contents before sections\n"; + ++$warnings; + } + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + } + + $in_doc_sect = 1; + $in_purpose = 0; + $contents = $newcontents; + if ($contents ne "") { + while ((substr($contents, 0, 1) eq " ") || + substr($contents, 0, 1) eq "\t") { + $contents = substr($contents, 1); + } + $contents .= "\n"; + } + $section = $newsection; + } elsif (/$doc_end/) { + + if (($contents ne "") && ($contents ne "\n")) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } + # look for doc_com + <text> + doc_end: + if ($_ =~ m'\s**\s*[a-zA-Z_0-9:.]+*/') { + print STDERR "Warning(${file}:$.): suspicious ending line: $_"; + ++$warnings; + } + + $prototype = ""; + $state = 3; + $brcount = 0; +# print STDERR "end of doc comment, looking for prototype\n"; + } elsif (/$doc_content/) { + # miguel-style comment kludge, look for blank lines after + # @parameter line to signify start of description + if ($1 eq "") { + if ($section =~ m/^@/ || $section eq $section_context) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } else { + $contents .= "\n"; + } + $in_purpose = 0; + } elsif ($in_purpose == 1) { + # Continued declaration purpose + chomp($declaration_purpose); + $declaration_purpose .= " " . xml_escape($1); + } else { + $contents .= $1 . "\n"; + } + } else { + # i dont know - bad line? ignore. + print STDERR "Warning(${file}:$.): bad line: $_"; + ++$warnings; + } + } elsif ($state == 3) { # scanning for function '{' (end of prototype) + if ($decl_type eq 'function') { + process_state3_function($_, $file); + } else { + process_state3_type($_, $file); + } + } elsif ($state == 4) { + # Documentation block + if (/$doc_block/) { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_end/) + { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + $state = 0; + } + elsif (/$doc_content/) + { + if ( $1 eq "" ) + { + $contents .= $blankline; + } + else + { + $contents .= $1 . "\n"; + } + } + } + } + if ($initial_section_counter == $section_counter) { + print STDERR "Warning(${file}): no structured comments found\n"; + if ($output_mode eq "xml") { + # The template wants at least one RefEntry here; make one. + print "<refentry>\n"; + print " <refnamediv>\n"; + print " <refname>\n"; + print " ${file}\n"; + print " </refname>\n"; + print " <refpurpose>\n"; + print " Document generation inconsistency\n"; + print " </refpurpose>\n"; + print " </refnamediv>\n"; + print " <refsect1>\n"; + print " <title>\n"; + print " Oops\n"; + print " </title>\n"; + print " <warning>\n"; + print " <para>\n"; + print " The template for this document tried to insert\n"; + print " the structured comment from the file\n"; + print " <filename>${file}</filename> at this point,\n"; + print " but none was found.\n"; + print " This dummy section is inserted to allow\n"; + print " generation to continue.\n"; + print " </para>\n"; + print " </warning>\n"; + print " </refsect1>\n"; + print "</refentry>\n"; + } + } +} + + +$kernelversion = get_kernel_version(); + +# generate a sequence of code that will splice in highlighting information +# using the s// operator. +foreach my $pattern (keys %highlights) { +# print STDERR "scanning pattern:$pattern, highlight:($highlights{$pattern})\n"; + $dohighlight .= "$contents =~ s:$pattern:$highlights{$pattern}:gs;\n"; +} + +# Read the file that maps relative names to absolute names for +# separate source and object directories and for shadow trees. +if (open(SOURCE_MAP, "<.tmp_filelist.txt")) { + my ($relname, $absname); + while(<SOURCE_MAP>) { + chop(); + ($relname, $absname) = (split())[0..1]; + $relname =~ s:^/+::; + $source_map{$relname} = $absname; + } + close(SOURCE_MAP); +} + +foreach (@ARGV) { + chomp; + process_file($_); +} +if ($verbose && $errors) { + print STDERR "$errors errors\n"; +} +if ($verbose && $warnings) { + print STDERR "$warnings warnings\n"; +} + +exit($errors);
Hi Marek,
Comments based on the assumption that we want to sync with the Linux tools.
General comment/hypothetical question: would it not be simpler to patch the existing Linux tools in-place so that we can use them on the U-Boot tree?
Detailed comments below in this spirit; ignore if suggestion above is stupid/complicated/plain wrong/other(specify...or not).
On Sat, 29 Sep 2012 04:43:04 +0200, Marek Vasut marex@denx.de wrote:
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts.
Is it possible to make replace these changes with an if/then/else conditional based on an external option? That would make it possible to try and backmerge them into the Linux version of kerneldoc.
It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches.
Maybe make this change more general, i.e. replace KERNEL_VERSION with PROJECT_VERSION with a default value assuming Linux, make magic constant strings variables with a linux-friendly default, and make all those variables overridable from command line? We'd just have to have a small script to provide the U-Boot-sensible values.
Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel.
Does it not make sense to drop the change above and instead, symlink doc/ to Documentation/? We could keep the symlink for one release then switch to a true rename for the release after.
Amicalement,
Dear Albert ARIBAUD,
Hi Marek,
Yes, it is a good idea. I'll do that. The problem is, replies to my patches do documentation mailing lists are slow, that's for one thing.
The other, much more grave and unpleasant is that we're way too far behind the DM schedule. I don't know what to do, but since pushing stuff upstream goes much slower than I expected, I will soon be left with no option other than forking u- boot, finishing the university project and -- at the end, without the team -- merge the stuff slowly back upstream.
The patchsets are starting to depend one on another, so nothing gets in without something else etc ...
Yes, it would ... while I already see how Linux people would hate it.
Yes, this would be easy. But see above.
I'd hate to do so ... is there any reason? An environment variable would be much easier, docproc already uses them a bit.
Amicalement,
Best regards, Marek Vasut
Hi Marek,
Hi Marek,
If I were in your position, I would not hesitate for a minute to do a fork. The beauty of the FLOSS model of development is that forking is trivial and if the fork has worthy features, merging later will meet with general enthusiasm from the community. The merge will probably happen faster than you think (and may actually happen in parallel so that when your project finishes, more than half of your work has already been integrated)
And once you fork, all the bottlenecks of global community approval disappear.
Regards,
Graeme
Dear Graeme Russ,
Hi Marek,
Hi Marek,
I do, bloody damnit! Just remember how it ended last time -- the result was a stupid useless piece of crap which was never merged back. Lot of wasted time etc.
See above.
And the fork will be sheets of crap, one on another ... because there'll be no proper review.
My position is that I DO NOT WANT TO DO IT ... unless I'm pushed to do so by the circumstances. And I'm reaching that point :'-C
Regards,
Graeme
Hi Marek,
Hi Marek,
Good point. Actually, environment variables (or an overridable configuration file) may help alleviate all three points above, avoid if/then/else (yes, I understand Linux people may not like that)...
Amicalement,
Hi Marek,
Albert, can we just merge this version and resync when I get the patches into upstream Linux? This is blocking the LG-arrays and other patches dependent on them (like serial stuff).
The other option is to allow /** style comment. Wolfgang, can we do that?
Import basic CSS stylesheet for the HTML documentation. The base for the stylesheet is taken from:
http://ds9a.nl/docbook/minimal-page.html
I customized the CSS a bit further, for example to add curvy corners to example section and change the tint of gray. The HTML documentation does not look that crude anymore.
Signed-off-by: Marek Vasut marex@denx.de --- doc/DocBook/docbook.css | 16 ++++++++++++++++ doc/DocBook/stylesheet.xsl | 1 + 2 files changed, 17 insertions(+) create mode 100644 doc/DocBook/docbook.css
diff --git a/doc/DocBook/docbook.css b/doc/DocBook/docbook.css new file mode 100644 index 0000000..7a79ec5 --- /dev/null +++ b/doc/DocBook/docbook.css @@ -0,0 +1,16 @@ +body { + font-family: sans-serif; +} + +.programlisting { + font-family: monospace; + font-size: 1em; + display: block; + padding: 10px; + border: 1px solid #aaa; + color: #000; + background-color: #eee; + overflow: auto; + margin: 1em 0em; + border-radius: 6px; +} diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl index 85b2527..8adce56 100644 --- a/doc/DocBook/stylesheet.xsl +++ b/doc/DocBook/stylesheet.xsl @@ -7,4 +7,5 @@ <!-- <param name="paper.type">A4</param> --> <param name="generate.section.toc.level">2</param> <param name="use.id.as.filename">1</param> +<param name="html.stylesheet">../docbook.css</param> </stylesheet>
The default kernel-doc strips starting spaces from every single line in the Example section. This makes the code look bad. Thus, implement special handling for this section.
Signed-off-by: Marek Vasut marex@denx.de --- tools/kernel-doc/kernel-doc | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc index 8848efd..6347418 100755 --- a/tools/kernel-doc/kernel-doc +++ b/tools/kernel-doc/kernel-doc @@ -2424,6 +2424,9 @@ sub process_file($) { # Continued declaration purpose chomp($declaration_purpose); $declaration_purpose .= " " . xml_escape($1); + } elsif ($section =~ m/^Example/) { + $_ =~ s/^\s**//; + $contents .= $_; } else { $contents .= $1 . "\n"; }
Implement kerneldoc template for linker-generated arrays. This is the first template in U-Boot that is used to generate kerneldoc style documentation. This template is very basic.
Signed-off-by: Marek Vasut marex@denx.de --- doc/DocBook/Makefile | 2 +- doc/DocBook/linker_lists.tmpl | 46 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 47 insertions(+), 1 deletion(-) create mode 100644 doc/DocBook/linker_lists.tmpl
diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile index 38f244a..4f59f60 100644 --- a/doc/DocBook/Makefile +++ b/doc/DocBook/Makefile @@ -8,7 +8,7 @@
include $(TOPDIR)/config.mk
-DOCBOOKS := +DOCBOOKS := linker_lists.xml
### # The build process is as follows (targets): diff --git a/doc/DocBook/linker_lists.tmpl b/doc/DocBook/linker_lists.tmpl new file mode 100644 index 0000000..a47377f --- /dev/null +++ b/doc/DocBook/linker_lists.tmpl @@ -0,0 +1,46 @@ +<?xml version="1.0" encoding="UTF-8"?> +<!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML V4.1.2//EN" + "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd" []> + +<book id="UBootLGArrays"> + <bookinfo> + <title>The U-Boot Linker-Generated Arrays</title> + + <legalnotice> + <para> + This documentation is free software; you can redistribute + it and/or modify it under the terms of the GNU General Public + License as published by the Free Software Foundation; either + version 2 of the License, or (at your option) any later + version. + </para> + + <para> + This program is distributed in the hope that it will be + useful, but WITHOUT ANY WARRANTY; without even the implied + warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. + See the GNU General Public License for more details. + </para> + + <para> + You should have received a copy of the GNU General Public + License along with this program; if not, write to the Free + Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, + MA 02111-1307 USA + </para> + + <para> + For more details see the file COPYING in the source + distribution of U-Boot Bootloader. + </para> + </legalnotice> + </bookinfo> + +<toc></toc> + + <chapter id="adt"> + <title>Linker-Generated Arrays</title> +!Iinclude/linker_lists.h + </chapter> + +</book>
This patch series implants slightly modified kernel-doc documentation generator from Linux kernel into U-Boot. First patch pulls in all the necessary components with minor modifications made to them to work with the layout of U-Boot source tree and without kbuild.
Further patch implement CSS to make the HTML documentation look a bit nicer. This patch will eventually (hopefully) be further refined by someone more artistically capable than me ;-)
Next patch implements separate handling for "Example:" section, which in the original kernel-doc was in my opinion mistreated. The example section generated a block of code, but the indentation was removed. Thus this patch does avoid removing the indent.
Finally, the last patch implements example of how to use this kernel-doc to generate U-Boot documentation by documenting the Linker-Generated arrays.
NOTE: This patchset (last patch) has a cross-dependency on: [PATCH 0/5] Linker-generated arrays (take 2)
V2: Add proper .gitignore entries, fix build issues (fix Makefiles)
Marek Vasut (4): doc: kerneldoc: Implant DocBook from Linux kernel doc: kerneldoc: Add nicer CSS stylesheet for HTML docs doc: kerneldoc: Implement "Example" section handling doc: kerneldoc: tmpl: Implement template for LG-arrays
Makefile | 7 +- doc/DocBook/.gitignore | 15 + doc/DocBook/Makefile | 229 ++++ doc/DocBook/docbook.css | 16 + doc/DocBook/linker_lists.tmpl | 46 + doc/DocBook/stylesheet.xsl | 11 + tools/.gitignore | 1 + tools/Makefile | 2 +- tools/kernel-doc/Makefile | 38 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2557 +++++++++++++++++++++++++++++++++++++++++ 11 files changed, 3496 insertions(+), 2 deletions(-) create mode 100644 doc/DocBook/.gitignore create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/docbook.css create mode 100644 doc/DocBook/linker_lists.tmpl create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Mike Frysinger vapier@gentoo.org
Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build.
Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400
Signed-off-by: Marek Vasut marex@denx.de --- Makefile | 7 +- doc/DocBook/.gitignore | 15 + doc/DocBook/Makefile | 229 ++++ doc/DocBook/stylesheet.xsl | 10 + tools/.gitignore | 1 + tools/Makefile | 2 +- tools/kernel-doc/Makefile | 38 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2554 +++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 3430 insertions(+), 2 deletions(-) create mode 100644 doc/DocBook/.gitignore create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
diff --git a/Makefile b/Makefile index a40d4cc..4c515ac 100644 --- a/Makefile +++ b/Makefile @@ -695,6 +695,9 @@ easylogo env gdb: $(MAKE) -C tools/$@ all MTD_VERSION=${MTD_VERSION} gdbtools: gdb
+xmldocs pdfdocs psdocs htmldocs mandocs: tools/kernel-doc/docproc + $(MAKE) U_BOOT_VERSION=$(U_BOOT_VERSION) -C doc/DocBook/ $@ + tools-all: easylogo env gdb $(VERSION_FILE) $(TIMESTAMP_FILE) $(MAKE) -C tools HOST_TOOLS_ALL=y
@@ -779,7 +782,8 @@ clean: $(obj)tools/mk{env,}image $(obj)tools/mpc86x_clk \ $(obj)tools/mk{smdk5250,}spl \ $(obj)tools/mxsboot \ - $(obj)tools/ncb $(obj)tools/ubsha1 + $(obj)tools/ncb $(obj)tools/ubsha1 \ + $(obj)tools/kernel-doc/docproc @rm -f $(obj)board/cray/L1/{bootscript.c,bootscript.image} \ $(obj)board/matrix_vision/*/bootscript.img \ $(obj)board/voiceblue/eeprom \ @@ -792,6 +796,7 @@ clean: @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s @rm -f $(TIMESTAMP_FILE) $(VERSION_FILE) + @$(MAKE) -C doc/DocBook/ cleandocs @find $(OBJTREE) -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' -o -name '*.su' \ -o -name '*.o' -o -name '*.a' -o -name '*.exe' ) -print \ diff --git a/doc/DocBook/.gitignore b/doc/DocBook/.gitignore new file mode 100644 index 0000000..90c1b11 --- /dev/null +++ b/doc/DocBook/.gitignore @@ -0,0 +1,15 @@ +*/ +*.xml +*.ps +*.pdf +*.html +*.9.gz +*.9 +*.aux +*.dvi +*.log +*.out +*.png +*.gif +media-indices.tmpl +media-entities.tmpl diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile new file mode 100644 index 0000000..2f2ddfc --- /dev/null +++ b/doc/DocBook/Makefile @@ -0,0 +1,229 @@ +### +# This makefile is used to generate the kernel documentation, +# primarily based on in-line comments in various source files. +# See doc/kernel-doc-nano-HOWTO.txt for instruction in how +# to document the SRC - and how to read it. +# To add a new book the only step required is to add the book to the +# list of DOCBOOKS. + +include $(TOPDIR)/config.mk + +DOCBOOKS := + +### +# The build process is as follows (targets): +# (xmldocs) [by docproc] +# file.tmpl --> file.xml +--> file.ps (psdocs) [by db2ps or xmlto] +# +--> file.pdf (pdfdocs) [by db2pdf or xmlto] +# +--> DIR=file (htmldocs) [by xmlto] +# +--> man/ (mandocs) [by xmlto] + + +# for PDF and PS output you can choose between xmlto and docbook-utils tools +PDF_METHOD = $(prefer-db2x) +PS_METHOD = $(prefer-db2x) + + +### +# The targets that may be used. +PHONY += $(obj).depend xmldocs sgmldocs psdocs pdfdocs htmldocs mandocs installmandocs cleandocs + +BOOKS := $(addprefix $(OBJTREE)/doc/DocBook/,$(DOCBOOKS)) +xmldocs: $(BOOKS) +sgmldocs: xmldocs + +PS := $(patsubst %.xml, %.ps, $(BOOKS)) +psdocs: $(PS) + +PDF := $(patsubst %.xml, %.pdf, $(BOOKS)) +pdfdocs: $(PDF) + +HTML := $(sort $(patsubst %.xml, %.html, $(BOOKS))) +htmldocs: $(HTML) + $(call build_main_index) + $(call build_images) + $(call install_media_images) + +MAN := $(patsubst %.xml, %.9, $(BOOKS)) +mandocs: $(MAN) + +installmandocs: mandocs + mkdir -p /usr/local/man/man9/ + install doc/DocBook/man/*.9.gz /usr/local/man/man9/ + +### +#External programs used +KERNELDOC = $(SRCTREE)/tools/kernel-doc/kernel-doc +DOCPROC = $(OBJTREE)/tools/kernel-doc/docproc + +XMLTOFLAGS = -m $(SRCTREE)/doc/DocBook/stylesheet.xsl +XMLTOFLAGS += --skip-validation + +### +# DOCPROC is used for two purposes: +# 1) To generate a dependency list for a .tmpl file +# 2) To preprocess a .tmpl file and call kernel-doc with +# appropriate parameters. +# The following rules are used to generate the .xml documentation +# required to generate the final targets. (ps, pdf, html). +%.xml: %.tmpl + $(DOCPROC) doc $< >$@ + +ifeq ($@, "cleandocs") +sinclude $(obj).depend +$(obj).depend: $(patsubst %.xml, %.tmpl, $(DOCBOOKS)) + rm -f $(obj).depend ; \ + touch $(obj).depend ; \ + for file in $^ ; do \ + xmlfile=`echo "$${file}" | \ + sed "s/tmpl$$/xml/"` ; \ + echo -n "$${xmlfile}: ">> $(obj).depend ; \ + $(DOCPROC) depend $$file >> $(obj).depend ; \ + echo -e "\n\t$(DOCPROC) doc $< >$${xmlfile} " >> \ + $(obj).depend ; \ + done +endif + +### +# Changes in kernel-doc force a rebuild of all documentation +$(BOOKS): $(KERNELDOC) + +notfoundtemplate = echo "*** You have to install docbook-utils or xmlto ***"; \ + exit 1 +db2xtemplate = db2TYPE -o $(dir $@) $< +xmltotemplate = xmlto TYPE $(XMLTOFLAGS) -o $(dir $@) $< + +# determine which methods are available +ifeq ($(shell which db2ps >/dev/null 2>&1 && echo found),found) + use-db2x = db2x + prefer-db2x = db2x +else + use-db2x = notfound + prefer-db2x = $(use-xmlto) +endif +ifeq ($(shell which xmlto >/dev/null 2>&1 && echo found),found) + use-xmlto = xmlto + prefer-xmlto = xmlto +else + use-xmlto = notfound + prefer-xmlto = $(use-db2x) +endif + +# the commands, generated from the chosen template +quiet_cmd_db2ps = PS $@ + cmd_db2ps = $(subst TYPE,ps, $($(PS_METHOD)template)) +%.ps : %.xml + $(call cmd_db2ps) + +quiet_cmd_db2pdf = PDF $@ + cmd_db2pdf = $(subst TYPE,pdf, $($(PDF_METHOD)template)) +%.pdf : %.xml + $(call cmd_db2pdf) + + +index = index.html +main_idx = $(index) +build_main_index = rm -rf $(main_idx); \ + echo '<h1>U-Boot Bootloader HTML Documentation</h1>' >> $(main_idx) && \ + echo '<h2>U-Boot Version: $(U_BOOT_VERSION)</h2>' >> $(main_idx) && \ + cat $(HTML) >> $(main_idx) + +# To work around bug [1] in docbook-xsl-stylesheets 1.76.1 , generate only html +# docs instead of xhtml with xmlto. +# [1] http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=654338 +quiet_cmd_db2html = HTML $@ + cmd_db2html = xmlto html $(XMLTOFLAGS) -o $(patsubst %.html,%,$@) $< && \ + echo '<a HREF="$(patsubst %.html,%,$(notdir $@))/index.html"> \ + $(patsubst %.html,%,$(notdir $@))</a><p>' > $@ + +%.html: %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + @rm -rf $@ $(patsubst %.html,%,$@) + $(call cmd_db2html) + @if [ ! -z "$(PNG-$(basename $(notdir $@)))" ]; then \ + cp $(PNG-$(basename $(notdir $@))) $(patsubst %.html,%,$@); fi + +quiet_cmd_db2man = MAN $@ + cmd_db2man = if grep -q refentry $<; then xmlto man $(XMLTOFLAGS) -o $(obj)/man $< ; gzip -f $(obj)/man/*.9; fi +%.9 : %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + $(Q)mkdir -p $(obj)man + $(call cmd_db2man) + @touch $@ + +### +# Rules to generate postscripts and PNG images from .fig format files +quiet_cmd_fig2eps = FIG2EPS $@ + cmd_fig2eps = fig2dev -Leps $< $@ + +%.eps: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2eps) + +quiet_cmd_fig2png = FIG2PNG $@ + cmd_fig2png = fig2dev -Lpng $< $@ + +%.png: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2png) + +### +# Rule to convert a .c file to inline XML documentation + gen_xml = : + quiet_gen_xml = echo ' GEN $@' +silent_gen_xml = : +%.xml: %.c + @$($(quiet)gen_xml) + @( \ + echo "<programlisting>"; \ + expand --tabs=8 < $< | \ + sed -e "s/&/\&/g" \ + -e "s/</\</g" \ + -e "s/>/\>/g"; \ + echo "</programlisting>") > $@ + +### +# Help targets as used by the top-level makefile +dochelp: + @echo ' U-Boot bootloader internal documentation in different formats:' + @echo ' htmldocs - HTML' + @echo ' pdfdocs - PDF' + @echo ' psdocs - Postscript' + @echo ' xmldocs - XML DocBook' + @echo ' mandocs - man pages' + @echo ' installmandocs - install man pages generated by mandocs' + @echo ' cleandocs - clean all generated DocBook files' + +### +# Temporary files left by various tools +clean-files := $(DOCBOOKS) \ + $(patsubst %.xml, %.dvi, $(DOCBOOKS)) \ + $(patsubst %.xml, %.aux, $(DOCBOOKS)) \ + $(patsubst %.xml, %.tex, $(DOCBOOKS)) \ + $(patsubst %.xml, %.log, $(DOCBOOKS)) \ + $(patsubst %.xml, %.out, $(DOCBOOKS)) \ + $(patsubst %.xml, %.ps, $(DOCBOOKS)) \ + $(patsubst %.xml, %.pdf, $(DOCBOOKS)) \ + $(patsubst %.xml, %.html, $(DOCBOOKS)) \ + $(patsubst %.xml, %.9, $(DOCBOOKS)) \ + $(index) + +clean-dirs := $(patsubst %.xml,%,$(DOCBOOKS)) man + +cleandocs: + @rm -f $(obj).depend + @$(Q)rm -f $(call objectify, $(clean-files)) + @$(Q)rm -rf $(call objectify, $(clean-dirs)) + +# Declare the contents of the .PHONY variable as phony. We keep that +# information in a variable se we can use it in if_changed and friends. + +.PHONY: $(PHONY) diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl new file mode 100644 index 0000000..85b2527 --- /dev/null +++ b/doc/DocBook/stylesheet.xsl @@ -0,0 +1,10 @@ +<?xml version="1.0" encoding="UTF-8"?> +<stylesheet xmlns="http://www.w3.org/1999/XSL/Transform" version="1.0"> +<param name="chunk.quietly">1</param> +<param name="funcsynopsis.style">ansi</param> +<param name="funcsynopsis.tabular.threshold">80</param> +<param name="callout.graphics">0</param> +<!-- <param name="paper.type">A4</param> --> +<param name="generate.section.toc.level">2</param> +<param name="use.id.as.filename">1</param> +</stylesheet> diff --git a/tools/.gitignore b/tools/.gitignore index 3088f4d..9bce719 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -17,3 +17,4 @@ /env/fw_printenv /gdb/gdbcont /gdb/gdbsend +/kernel-doc/docproc diff --git a/tools/Makefile b/tools/Makefile index c31437e..686840a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
-TOOLSUBDIRS = +TOOLSUBDIRS = kernel-doc
# # Include this after HOSTOS HOSTARCH check diff --git a/tools/kernel-doc/Makefile b/tools/kernel-doc/Makefile new file mode 100644 index 0000000..28a3f61 --- /dev/null +++ b/tools/kernel-doc/Makefile @@ -0,0 +1,38 @@ +# +# Copyright (C) 2012 Marek Vasut marex@denx.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +all: $(obj)docproc + +$(obj)docproc: docproc.c + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(HOSTSTRIP) $@ + +clean: + rm -rf docproc + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/kernel-doc/docproc.c b/tools/kernel-doc/docproc.c new file mode 100644 index 0000000..8bc47b0 --- /dev/null +++ b/tools/kernel-doc/docproc.c @@ -0,0 +1,576 @@ +/* + * docproc is a simple preprocessor for the template files + * used as placeholders for the kernel internal documentation. + * docproc is used for documentation-frontend and + * dependency-generator. + * The two usages have in common that they require + * some knowledge of the .tmpl syntax, therefore they + * are kept together. + * + * documentation-frontend + * Scans the template file and call kernel-doc for + * all occurrences of ![EIF]file + * Beforehand each referenced file is scanned for + * any symbols that are exported via these macros: + * EXPORT_SYMBOL(), EXPORT_SYMBOL_GPL(), & + * EXPORT_SYMBOL_GPL_FUTURE() + * This is used to create proper -function and + * -nofunction arguments in calls to kernel-doc. + * Usage: docproc doc file.tmpl + * + * dependency-generator: + * Scans the template file and list all files + * referenced in a format recognized by make. + * Usage: docproc depend file.tmpl + * Writes dependency information to stdout + * in the following format: + * file.tmpl src.c src2.c + * The filenames are obtained from the following constructs: + * !Efilename + * !Ifilename + * !Dfilename + * !Ffilename + * !Pfilename + * + */ + +#define _GNU_SOURCE +#include <stdio.h> +#include <stdlib.h> +#include <string.h> +#include <ctype.h> +#include <unistd.h> +#include <limits.h> +#include <errno.h> +#include <sys/types.h> +#include <sys/wait.h> + +/* exitstatus is used to keep track of any failing calls to kernel-doc, + * but execution continues. */ +int exitstatus = 0; + +typedef void DFL(char *); +DFL *defaultline; + +typedef void FILEONLY(char * file); +FILEONLY *internalfunctions; +FILEONLY *externalfunctions; +FILEONLY *symbolsonly; +FILEONLY *findall; + +typedef void FILELINE(char * file, char * line); +FILELINE * singlefunctions; +FILELINE * entity_system; +FILELINE * docsection; + +#define MAXLINESZ 2048 +#define MAXFILES 250 +#define KERNELDOCPATH "tools/kernel-doc/" +#define KERNELDOC "kernel-doc" +#define DOCBOOK "-docbook" +#define LIST "-list" +#define FUNCTION "-function" +#define NOFUNCTION "-nofunction" +#define NODOCSECTIONS "-no-doc-sections" + +static char *srctree, *kernsrctree; + +static char **all_list = NULL; +static int all_list_len = 0; + +static void consume_symbol(const char *sym) +{ + int i; + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + if (strcmp(sym, all_list[i])) + continue; + all_list[i] = NULL; + break; + } +} + +static void usage (void) +{ + fprintf(stderr, "Usage: docproc {doc|depend} file\n"); + fprintf(stderr, "Input is read from file.tmpl. Output is sent to stdout\n"); + fprintf(stderr, "doc: frontend when generating kernel documentation\n"); + fprintf(stderr, "depend: generate list of files referenced within file\n"); + fprintf(stderr, "Environment variable SRCTREE: absolute path to sources.\n"); + fprintf(stderr, " KBUILD_SRC: absolute path to kernel source tree.\n"); +} + +/* + * Execute kernel-doc with parameters given in svec + */ +static void exec_kernel_doc(char **svec) +{ + pid_t pid; + int ret; + char real_filename[PATH_MAX + 1]; + /* Make sure output generated so far are flushed */ + fflush(stdout); + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, svec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; +} + +/* Types used to create list of all exported symbols in a number of files */ +struct symbols +{ + char *name; +}; + +struct symfile +{ + char *filename; + struct symbols *symbollist; + int symbolcnt; +}; + +struct symfile symfilelist[MAXFILES]; +int symfilecnt = 0; + +static void add_new_symbol(struct symfile *sym, char * symname) +{ + sym->symbollist = + realloc(sym->symbollist, (sym->symbolcnt + 1) * sizeof(char *)); + sym->symbollist[sym->symbolcnt++].name = strdup(symname); +} + +/* Add a filename to the list */ +static struct symfile * add_new_file(char * filename) +{ + symfilelist[symfilecnt++].filename = strdup(filename); + return &symfilelist[symfilecnt - 1]; +} + +/* Check if file already are present in the list */ +static struct symfile * filename_exist(char * filename) +{ + int i; + for (i=0; i < symfilecnt; i++) + if (strcmp(symfilelist[i].filename, filename) == 0) + return &symfilelist[i]; + return NULL; +} + +/* + * List all files referenced within the template file. + * Files are separated by tabs. + */ +static void adddep(char * file) { printf("\t%s", file); } +static void adddep2(char * file, char * line) { line = line; adddep(file); } +static void noaction(char * line) { line = line; } +static void noaction2(char * file, char * line) { file = file; line = line; } + +/* Echo the line without further action */ +static void printline(char * line) { printf("%s", line); } + +/* + * Find all symbols in filename that are exported with EXPORT_SYMBOL & + * EXPORT_SYMBOL_GPL (& EXPORT_SYMBOL_GPL_FUTURE implicitly). + * All symbols located are stored in symfilelist. + */ +static void find_export_symbols(char * filename) +{ + FILE * fp; + struct symfile *sym; + char line[MAXLINESZ]; + if (filename_exist(filename) == NULL) { + char real_filename[PATH_MAX + 1]; + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, srctree, PATH_MAX); + strncat(real_filename, "/", PATH_MAX - strlen(real_filename)); + strncat(real_filename, filename, + PATH_MAX - strlen(real_filename)); + sym = add_new_file(filename); + fp = fopen(real_filename, "r"); + if (fp == NULL) { + fprintf(stderr, "docproc: "); + perror(real_filename); + exit(1); + } + while (fgets(line, MAXLINESZ, fp)) { + char *p; + char *e; + if (((p = strstr(line, "EXPORT_SYMBOL_GPL")) != NULL) || + ((p = strstr(line, "EXPORT_SYMBOL")) != NULL)) { + /* Skip EXPORT_SYMBOL{_GPL} */ + while (isalnum(*p) || *p == '_') + p++; + /* Remove parentheses & additional whitespace */ + while (isspace(*p)) + p++; + if (*p != '(') + continue; /* Syntax error? */ + else + p++; + while (isspace(*p)) + p++; + e = p; + while (isalnum(*e) || *e == '_') + e++; + *e = '\0'; + add_new_symbol(sym, p); + } + } + fclose(fp); + } +} + +/* + * Document all external or internal functions in a file. + * Call kernel-doc with following parameters: + * kernel-doc -docbook -nofunction function_name1 filename + * Function names are obtained from all the src files + * by find_export_symbols. + * intfunc uses -nofunction + * extfunc uses -function + */ +static void docfunctions(char * filename, char * type) +{ + int i,j; + int symcnt = 0; + int idx = 0; + char **vec; + + for (i=0; i <= symfilecnt; i++) + symcnt += symfilelist[i].symbolcnt; + vec = malloc((2 + 2 * symcnt + 3) * sizeof(char *)); + if (vec == NULL) { + perror("docproc: "); + exit(1); + } + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + vec[idx++] = NODOCSECTIONS; + for (i=0; i < symfilecnt; i++) { + struct symfile * sym = &symfilelist[i]; + for (j=0; j < sym->symbolcnt; j++) { + vec[idx++] = type; + consume_symbol(sym->symbollist[j].name); + vec[idx++] = sym->symbollist[j].name; + } + } + vec[idx++] = filename; + vec[idx] = NULL; + printf("<!-- %s -->\n", filename); + exec_kernel_doc(vec); + fflush(stdout); + free(vec); +} +static void intfunc(char * filename) { docfunctions(filename, NOFUNCTION); } +static void extfunc(char * filename) { docfunctions(filename, FUNCTION); } + +/* + * Document specific function(s) in a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function function1 [-function function2] + */ +static void singfunc(char * filename, char * line) +{ + char *vec[200]; /* Enough for specific functions */ + int i, idx = 0; + int startofsym = 1; + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + + /* Split line up in individual parameters preceded by FUNCTION */ + for (i=0; line[i]; i++) { + if (isspace(line[i])) { + line[i] = '\0'; + startofsym = 1; + continue; + } + if (startofsym) { + startofsym = 0; + vec[idx++] = FUNCTION; + vec[idx++] = &line[i]; + } + } + for (i = 0; i < idx; i++) { + if (strcmp(vec[i], FUNCTION)) + continue; + consume_symbol(vec[i + 1]); + } + vec[idx++] = filename; + vec[idx] = NULL; + exec_kernel_doc(vec); +} + +/* + * Insert specific documentation section from a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function "doc section" filename + */ +static void docsect(char *filename, char *line) +{ + char *vec[6]; /* kerneldoc -docbook -function "section" file NULL */ + char *s; + + for (s = line; *s; s++) + if (*s == '\n') + *s = '\0'; + + if (asprintf(&s, "DOC: %s", line) < 0) { + perror("asprintf"); + exit(1); + } + consume_symbol(s); + free(s); + + vec[0] = KERNELDOC; + vec[1] = DOCBOOK; + vec[2] = FUNCTION; + vec[3] = line; + vec[4] = filename; + vec[5] = NULL; + exec_kernel_doc(vec); +} + +static void find_all_symbols(char *filename) +{ + char *vec[4]; /* kerneldoc -list file NULL */ + pid_t pid; + int ret, i, count, start; + char real_filename[PATH_MAX + 1]; + int pipefd[2]; + char *data, *str; + size_t data_len = 0; + + vec[0] = KERNELDOC; + vec[1] = LIST; + vec[2] = filename; + vec[3] = NULL; + + if (pipe(pipefd)) { + perror("pipe"); + exit(1); + } + + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + close(pipefd[0]); + dup2(pipefd[1], 1); + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, vec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + close(pipefd[1]); + data = malloc(4096); + do { + while ((ret = read(pipefd[0], + data + data_len, + 4096)) > 0) { + data_len += ret; + data = realloc(data, data_len + 4096); + } + } while (ret == -EAGAIN); + if (ret != 0) { + perror("read"); + exit(1); + } + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; + + count = 0; + /* poor man's strtok, but with counting */ + for (i = 0; i < data_len; i++) { + if (data[i] == '\n') { + count++; + data[i] = '\0'; + } + } + start = all_list_len; + all_list_len += count; + all_list = realloc(all_list, sizeof(char *) * all_list_len); + str = data; + for (i = 0; i < data_len && start != all_list_len; i++) { + if (data[i] == '\0') { + all_list[start] = str; + str = data + i + 1; + start++; + } + } +} + +/* + * Parse file, calling action specific functions for: + * 1) Lines containing !E + * 2) Lines containing !I + * 3) Lines containing !D + * 4) Lines containing !F + * 5) Lines containing !P + * 6) Lines containing !C + * 7) Default lines - lines not matching the above + */ +static void parse_file(FILE *infile) +{ + char line[MAXLINESZ]; + char * s; + while (fgets(line, MAXLINESZ, infile)) { + if (line[0] == '!') { + s = line + 2; + switch (line[1]) { + case 'E': + while (*s && !isspace(*s)) s++; + *s = '\0'; + externalfunctions(line+2); + break; + case 'I': + while (*s && !isspace(*s)) s++; + *s = '\0'; + internalfunctions(line+2); + break; + case 'D': + while (*s && !isspace(*s)) s++; + *s = '\0'; + symbolsonly(line+2); + break; + case 'F': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* function names */ + while (isspace(*s)) + s++; + singlefunctions(line +2, s); + break; + case 'P': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* DOC: section name */ + while (isspace(*s)) + s++; + docsection(line + 2, s); + break; + case 'C': + while (*s && !isspace(*s)) s++; + *s = '\0'; + if (findall) + findall(line+2); + break; + default: + defaultline(line); + } + } else { + defaultline(line); + } + } + fflush(stdout); +} + + +int main(int argc, char *argv[]) +{ + FILE * infile; + int i; + + srctree = getenv("SRCTREE"); + if (!srctree) + srctree = getcwd(NULL, 0); + kernsrctree = getenv("KBUILD_SRC"); + if (!kernsrctree || !*kernsrctree) + kernsrctree = srctree; + if (argc != 3) { + usage(); + exit(1); + } + /* Open file, exit on error */ + infile = fopen(argv[2], "r"); + if (infile == NULL) { + fprintf(stderr, "docproc: "); + perror(argv[2]); + exit(2); + } + + if (strcmp("doc", argv[1]) == 0) { + /* Need to do this in two passes. + * First pass is used to collect all symbols exported + * in the various files; + * Second pass generate the documentation. + * This is required because some functions are declared + * and exported in different files :-(( + */ + /* Collect symbols */ + defaultline = noaction; + internalfunctions = find_export_symbols; + externalfunctions = find_export_symbols; + symbolsonly = find_export_symbols; + singlefunctions = noaction2; + docsection = noaction2; + findall = find_all_symbols; + parse_file(infile); + + /* Rewind to start from beginning of file again */ + fseek(infile, 0, SEEK_SET); + defaultline = printline; + internalfunctions = intfunc; + externalfunctions = extfunc; + symbolsonly = printline; + singlefunctions = singfunc; + docsection = docsect; + findall = NULL; + + parse_file(infile); + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + fprintf(stderr, "Warning: didn't use docs for %s\n", + all_list[i]); + } + } else if (strcmp("depend", argv[1]) == 0) { + /* Create first part of dependency chain + * file.tmpl */ + printf("%s\t", argv[2]); + defaultline = noaction; + internalfunctions = adddep; + externalfunctions = adddep; + symbolsonly = adddep; + singlefunctions = adddep2; + docsection = adddep2; + findall = adddep; + parse_file(infile); + printf("\n"); + } else { + fprintf(stderr, "Unknown option: %s\n", argv[1]); + exit(1); + } + fclose(infile); + fflush(stdout); + return exitstatus; +} diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc new file mode 100755 index 0000000..8848efd --- /dev/null +++ b/tools/kernel-doc/kernel-doc @@ -0,0 +1,2554 @@ +#!/usr/bin/perl -w + +use strict; + +## Copyright (c) 1998 Michael Zucchi, All Rights Reserved ## +## Copyright (C) 2000, 1 Tim Waugh twaugh@redhat.com ## +## Copyright (C) 2001 Simon Huggins ## +## Copyright (C) 2005-2012 Randy Dunlap ## +## Copyright (C) 2012 Dan Luedtke ## +## ## +## #define enhancements by Armin Kuster akuster@mvista.com ## +## Copyright (c) 2000 MontaVista Software, Inc. ## +## ## +## This software falls under the GNU General Public License. ## +## Please read the COPYING file for more information ## + +# 18/01/2001 - Cleanups +# Functions prototyped as foo(void) same as foo() +# Stop eval'ing where we don't need to. +# -- huggie@earth.li + +# 27/06/2001 - Allowed whitespace after initial "/**" and +# allowed comments before function declarations. +# -- Christian Kreibich ck@whoop.org + +# Still to do: +# - add perldoc documentation +# - Look more closely at some of the scarier bits :) + +# 26/05/2001 - Support for separate source and object trees. +# Return error code. +# Keith Owens kaos@ocs.com.au + +# 23/09/2001 - Added support for typedefs, structs, enums and unions +# Support for Context section; can be terminated using empty line +# Small fixes (like spaces vs. \s in regex) +# -- Tim Jansen tim@tjansen.de + +# 25/07/2012 - Added support for HTML5 +# -- Dan Luedtke mail@danrl.de + +# +# This will read a 'c' file and scan for embedded comments in the +# style of gnome comments (+minor extensions - see below). +# + +# Note: This only supports 'c'. + +# usage: +# kernel-doc [ -docbook | -html | -html5 | -text | -man | -list ] +# [ -no-doc-sections ] +# [ -function funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# or +# [ -nofunction funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# +# Set output format using one of -docbook -html -html5 -text or -man. +# Default is man. +# The -list format is for internal use by docproc. +# +# -no-doc-sections +# Do not output DOC: sections +# +# -function funcname +# If set, then only generate documentation for the given function(s) or +# DOC: section titles. All other functions and DOC: sections are ignored. +# +# -nofunction funcname +# If set, then only generate documentation for the other function(s)/DOC: +# sections. Cannot be used together with -function (yes, that's a bug -- +# perl hackers can fix it 8)) +# +# c files - list of 'c' files to process +# +# All output goes to stdout, with errors to stderr. + +# +# format of comments. +# In the following table, (...)? signifies optional structure. +# (...)* signifies 0 or more structure elements +# /** +# * function_name(:)? (- short description)? +# (* @parameterx: (description of parameter x)?)* +# (* a blank line)? +# * (Description:)? (Description of function)? +# * (section header: (section description)? )* +# (*)?*/ +# +# So .. the trivial example would be: +# +# /** +# * my_function +# */ +# +# If the Description: header tag is omitted, then there must be a blank line +# after the last parameter specification. +# e.g. +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * +# * Does my stuff explained. +# */ +# +# or, could also use: +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * Description: Does my stuff explained. +# */ +# etc. +# +# Besides functions you can also write documentation for structs, unions, +# enums and typedefs. Instead of the function name you must write the name +# of the declaration; the struct/union/enum/typedef must always precede +# the name. Nesting of declarations is not supported. +# Use the argument mechanism to document members or constants. +# e.g. +# /** +# * struct my_struct - short description +# * @a: first member +# * @b: second member +# * +# * Longer description +# */ +# struct my_struct { +# int a; +# int b; +# /* private: */ +# int c; +# }; +# +# All descriptions can be multiline, except the short function description. +# +# You can also add additional sections. When documenting kernel functions you +# should document the "Context:" of the function, e.g. whether the functions +# can be called form interrupts. Unlike other sections you can end it with an +# empty line. +# Example-sections should contain the string EXAMPLE so that they are marked +# appropriately in DocBook. +# +# Example: +# /** +# * user_function - function that can only be called in user context +# * @a: some argument +# * Context: !in_interrupt() +# * +# * Some description +# * Example: +# * user_function(22); +# */ +# ... +# +# +# All descriptive text is further processed, scanning for the following special +# patterns, which are highlighted appropriately. +# +# 'funcname()' - function +# '$ENVVAR' - environmental variable +# '&struct_name' - name of a structure (up to two words including 'struct') +# '@parameter' - name of a parameter +# '%CONST' - name of a constant. + +## init lots of data + +my $errors = 0; +my $warnings = 0; +my $anon_struct_union = 0; + +# match expressions used to find embedded type information +my $type_constant = '%([-_\w]+)'; +my $type_func = '(\w+)()'; +my $type_param = '@(\w+)'; +my $type_struct = '&((struct\s*)*[_\w]+)'; +my $type_struct_xml = '\&((struct\s*)*[_\w]+)'; +my $type_env = '($\w+)'; + +# Output conversion substitutions. +# One for each output format + +# these work fairly well +my %highlights_html = ( $type_constant, "<i>$1</i>", + $type_func, "<b>$1</b>", + $type_struct_xml, "<i>$1</i>", + $type_env, "<b><i>$1</i></b>", + $type_param, "<tt><b>$1</b></tt>" ); +my $local_lt = "\\\\lt:"; +my $local_gt = "\\\\gt:"; +my $blankline_html = $local_lt . "p" . $local_gt; # was "<p>" + +# html version 5 +my %highlights_html5 = ( $type_constant, "<span class="const">$1</span>", + $type_func, "<span class="func">$1</span>", + $type_struct_xml, "<span class="struct">$1</span>", + $type_env, "<span class="env">$1</span>", + $type_param, "<span class="param">$1</span>" ); +my $blankline_html5 = $local_lt . "br /" . $local_gt; + +# XML, docbook format +my %highlights_xml = ( "([^=])\"([^\"<]+)\"", "$1<quote>$2</quote>", + $type_constant, "<constant>$1</constant>", + $type_func, "<function>$1</function>", + $type_struct_xml, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_xml = $local_lt . "/para" . $local_gt . $local_lt . "para" . $local_gt . "\n"; + +# gnome, docbook format +my %highlights_gnome = ( $type_constant, "<replaceable class="option">$1</replaceable>", + $type_func, "<function>$1</function>", + $type_struct, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_gnome = "</para><para>\n"; + +# these are pretty rough +my %highlights_man = ( $type_constant, "$1", + $type_func, "\\fB$1\\fP", + $type_struct, "\\fI$1\\fP", + $type_param, "\\fI$1\\fP" ); +my $blankline_man = ""; + +# text-mode +my %highlights_text = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_text = ""; + +# list mode +my %highlights_list = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_list = ""; + +# read arguments +if ($#ARGV == -1) { + usage(); +} + +my $kernelversion; +my $dohighlight = ""; + +my $verbose = 0; +my $output_mode = "man"; +my $no_doc_sections = 0; +my %highlights = %highlights_man; +my $blankline = $blankline_man; +my $modulename = "Bootloader API"; +my $function_only = 0; +my $man_date = ('January', 'February', 'March', 'April', 'May', 'June', + 'July', 'August', 'September', 'October', + 'November', 'December')[(localtime)[4]] . + " " . ((localtime)[5]+1900); + +# Essentially these are globals. +# They probably want to be tidied up, made more localised or something. +# CAVEAT EMPTOR! Some of the others I localised may not want to be, which +# could cause "use of undefined value" or other bugs. +my ($function, %function_table, %parametertypes, $declaration_purpose); +my ($type, $declaration_name, $return_type); +my ($newsection, $newcontents, $prototype, $brcount, %source_map); + +if (defined($ENV{'KBUILD_VERBOSE'})) { + $verbose = "$ENV{'KBUILD_VERBOSE'}"; +} + +# Generated docbook code is inserted in a template at a point where +# docbook v3.1 requires a non-zero sequence of RefEntry's; see: +# http://www.oasis-open.org/docbook/documentation/reference/html/refentry.html +# We keep track of number of generated entries and generate a dummy +# if needs be to ensure the expanded template can be postprocessed +# into html. +my $section_counter = 0; + +my $lineprefix=""; + +# states +# 0 - normal code +# 1 - looking for function name +# 2 - scanning field start. +# 3 - scanning prototype. +# 4 - documentation block +my $state; +my $in_doc_sect; + +#declaration types: can be +# 'function', 'struct', 'union', 'enum', 'typedef' +my $decl_type; + +my $doc_special = "@%$&"; + +my $doc_start = '^/**\s*$'; # Allow whitespace at end of comment start. +my $doc_end = '*/'; +my $doc_com = '\s**\s*'; +my $doc_decl = $doc_com . '(\w+)'; +my $doc_sect = $doc_com . '([' . $doc_special . ']?[\w\s]+):(.*)'; +my $doc_content = $doc_com . '(.*)'; +my $doc_block = $doc_com . 'DOC:\s*(.*)?'; + +my %constants; +my %parameterdescs; +my @parameterlist; +my %sections; +my @sectionlist; +my $sectcheck; +my $struct_actual; + +my $contents = ""; +my $section_default = "Description"; # default section +my $section_intro = "Introduction"; +my $section = $section_default; +my $section_context = "Context"; + +my $undescribed = "-- undescribed --"; + +reset_state(); + +while ($ARGV[0] =~ m/^-(.*)/) { + my $cmd = shift @ARGV; + if ($cmd eq "-html") { + $output_mode = "html"; + %highlights = %highlights_html; + $blankline = $blankline_html; + } elsif ($cmd eq "-html5") { + $output_mode = "html5"; + %highlights = %highlights_html5; + $blankline = $blankline_html5; + } elsif ($cmd eq "-man") { + $output_mode = "man"; + %highlights = %highlights_man; + $blankline = $blankline_man; + } elsif ($cmd eq "-text") { + $output_mode = "text"; + %highlights = %highlights_text; + $blankline = $blankline_text; + } elsif ($cmd eq "-docbook") { + $output_mode = "xml"; + %highlights = %highlights_xml; + $blankline = $blankline_xml; + } elsif ($cmd eq "-list") { + $output_mode = "list"; + %highlights = %highlights_list; + $blankline = $blankline_list; + } elsif ($cmd eq "-gnome") { + $output_mode = "gnome"; + %highlights = %highlights_gnome; + $blankline = $blankline_gnome; + } elsif ($cmd eq "-module") { # not needed for XML, inherits from calling document + $modulename = shift @ARGV; + } elsif ($cmd eq "-function") { # to only output specific functions + $function_only = 1; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-nofunction") { # to only output specific functions + $function_only = 2; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-v") { + $verbose = 1; + } elsif (($cmd eq "-h") || ($cmd eq "--help")) { + usage(); + } elsif ($cmd eq '-no-doc-sections') { + $no_doc_sections = 1; + } +} + +# continue execution near EOF; + +sub usage { + print "Usage: $0 [ -docbook | -html | -html5 | -text | -man | -list ]\n"; + print " [ -no-doc-sections ]\n"; + print " [ -function funcname [ -function funcname ...] ]\n"; + print " [ -nofunction funcname [ -nofunction funcname ...] ]\n"; + print " [ -v ]\n"; + print " c source file(s) > outputfile\n"; + print " -v : verbose output, more warnings & other info listed\n"; + exit 1; +} + +# get kernel version from env +sub get_kernel_version() { + my $version = 'unknown kernel version'; + + if (defined($ENV{'U_BOOT_VERSION'})) { + $version = $ENV{'U_BOOT_VERSION'}; + } + return $version; +} + +## +# dumps section contents to arrays/hashes intended for that purpose. +# +sub dump_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($name =~ m/$type_constant/) { + $name = $1; +# print STDERR "constant section '$1' = '$contents'\n"; + $constants{$name} = $contents; + } elsif ($name =~ m/$type_param/) { +# print STDERR "parameter def '$1' = '$contents'\n"; + $name = $1; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } elsif ($name eq "@...") { +# print STDERR "parameter def '...' = '$contents'\n"; + $name = "..."; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } else { +# print STDERR "other section '$name' = '$contents'\n"; + if (defined($sections{$name}) && ($sections{$name} ne "")) { + print STDERR "Error(${file}:$.): duplicate section name '$name'\n"; + ++$errors; + } + $sections{$name} = $contents; + push @sectionlist, $name; + } +} + +## +# dump DOC: section after checking that it should go out +# +sub dump_doc_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($no_doc_sections) { + return; + } + + if (($function_only == 0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + dump_section($file, $name, $contents); + output_blockhead({'sectionlist' => @sectionlist, + 'sections' => %sections, + 'module' => $modulename, + 'content-only' => ($function_only != 0), }); + } +} + +## +# output function +# +# parameterdescs, a hash. +# function => "function name" +# parameterlist => @list of parameters +# parameterdescs => %parameter descriptions +# sectionlist => @list of sections +# sections => %section descriptions +# + +sub output_highlight { + my $contents = join "\n",@_; + my $line; + +# DEBUG +# if (!defined $contents) { +# use Carp; +# confess "output_highlight got called with no args?\n"; +# } + + if ($output_mode eq "html" || $output_mode eq "html5" || + $output_mode eq "xml") { + $contents = local_unescape($contents); + # convert data read & converted thru xml_escape() into &xyz; format: + $contents =~ s/\\\/&/g; + } +# print STDERR "contents b4:$contents\n"; + eval $dohighlight; + die $@ if $@; +# print STDERR "contents af:$contents\n"; + +# strip whitespaces when generating html5 + if ($output_mode eq "html5") { + $contents =~ s/^\s+//; + $contents =~ s/\s+$//; + } + foreach $line (split "\n", $contents) { + if ($line eq ""){ + print $lineprefix, local_unescape($blankline); + } else { + $line =~ s/\\\/&/g; + if ($output_mode eq "man" && substr($line, 0, 1) eq ".") { + print "\&$line"; + } else { + print $lineprefix, $line; + } + } + print "\n"; + } +} + +# output sections in html +sub output_section_html(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<blockquote>\n"; + output_highlight($args{'sections'}{$section}); + print "</blockquote>\n"; + } +} + +# output enum in html +sub output_enum_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>enum " . $args{'enum'} . "</h2>\n"; + + print "<b>enum " . $args{'enum'} . "</b> {<br>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " <b>" . $parameter . "</b>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + print "<br>"; + } + print "};<br>\n"; + + print "<h3>Constants</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output typedef in html +sub output_typedef_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>typedef " . $args{'typedef'} . "</h2>\n"; + + print "<b>typedef " . $args{'typedef'} . "</b>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output struct in html +sub output_struct_html(%) { + my %args = %{$_[0]}; + my ($parameter); + + print "<h2>" . $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<b>" . $args{'type'} . " " . $args{'struct'} . "</b> {<br>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter<br>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <i>$1</i><b>$parameter</b>) <i>($2)</i>;<br>\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " <i>$1</i> <b>$parameter</b>$2;<br>\n"; + } else { + print " <i>$type</i> <b>$parameter</b>;<br>\n"; + } + } + print "};<br>\n"; + + print "<h3>Members</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output function in html +sub output_function_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print "<h2>" . $args{'function'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<i>" . $args{'functiontype'} . "</i>\n"; + print "<b>" . $args{'function'} . "</b>\n"; + print "("; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<i>$1</i><b>$parameter</b>) <i>($2)</i>"; + } else { + print "<i>" . $type . "</i> <b>" . $parameter . "</b>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + } + print ")\n"; + + print "<h3>Arguments</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output DOC: block header in html +sub output_blockhead_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<ul>\n"; + output_highlight($args{'sections'}{$section}); + print "</ul>\n"; + } + print "<hr>\n"; +} + +# output sections in html5 +sub output_section_html5(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<section>\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + print "</section>\n"; + } +} + +# output enum in html5 +sub output_enum_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'enum'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="enum" id="enum:". $html5id . "">"; + print "<h1>enum " . $args{'enum'} . "</h1>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">enum</span> "; + print "<span class="identifier">" . $args{'enum'} . "</span> {"; + print "</li>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + print "<span class="param">" . $parameter . "</span>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Constants</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output typedef in html5 +sub output_typedef_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'typedef'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="typedef" id="typedef:" . $html5id . "">\n"; + print "<h1>typedef " . $args{'typedef'} . "</h1>\n"; + + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">typedef</span> "; + print "<span class="identifier">" . $args{'typedef'} . "</span>"; + print "</li>\n"; + print "</ol>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output struct in html5 +sub output_struct_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $html5id; + + $html5id = $args{'struct'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="struct" id="struct:" . $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'type'} . " " . $args{'struct'} . "</h1>"; + print "<h2>". $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'type'} . "</span> "; + print "<span class="identifier">" . $args{'struct'} . "</span> {"; + print "</li>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + if ($parameter =~ /^#/) { + print "<span class="param">" . $parameter ."</span>\n"; + print "</li>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>);"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="bits">$2</span>;"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>;"; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Members</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output function in html5 +sub output_function_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + $html5id = $args{'function'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="function" id="func:". $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'function'} . "</h1>"; + print "<h2>" . $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'functiontype'} . "</span> "; + print "<span class="identifier">" . $args{'function'} . "</span> ("; + print "</li>"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>)"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>)</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Arguments</h1>\n"; + print "<p>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output DOC: block header in html5 +sub output_blockhead_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + foreach $section (@{$args{'sectionlist'}}) { + $html5id = $section; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="doc" id="doc:". $html5id . "">\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + } + print "</article>\n"; +} + +sub output_section_xml(%) { + my %args = %{$_[0]}; + my $section; + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<refsect1>\n"; + print "<title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<informalexample><programlisting>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></informalexample>\n"; + } else { + print "</para>\n"; + } + print "</refsect1>\n"; + } +} + +# output function in XML DocBook +sub output_function_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'function'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'function'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <funcsynopsis><funcprototype>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " </function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1<parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void/>\n"; + } + print " </funcprototype></funcsynopsis>\n"; + print "</refsynopsisdiv>\n"; + + # print parameters + print "<refsect1>\n <title>Arguments</title>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>\n <term><parameter>$parameter</parameter></term>\n"; + print " <listitem>\n <para>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para>\n </listitem>\n </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print "</refsect1>\n"; + + output_section_xml(@_); + print "</refentry>\n\n"; +} + +# output struct in XML DocBook +sub output_struct_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-struct-" . $args{'struct'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'type'} . " " . $args{'struct'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'type'} . " " . $args{'struct'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + my $prm = $parameter; + # convert data read & converted thru xml_escape() into &xyz; format: + # This allows us to have #define macros interspersed in a struct. + $prm =~ s/\\\/&/g; + print "$prm\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " $1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " $1 $parameter$2;\n"; + } else { + print " " . $type . " " . $parameter . ";\n"; + } + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print " <refsect1>\n"; + print " <title>Members</title>\n"; + + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print " </refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output enum in XML DocBook +sub output_enum_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-enum-" . $args{'enum'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>enum " . $args{'enum'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>enum " . $args{'enum'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " $parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print "<refsect1>\n"; + print " <title>Constants</title>\n"; + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + print "</refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output typedef in XML DocBook +sub output_typedef_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-typedef-" . $args{'typedef'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>typedef " . $args{'typedef'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>typedef " . $args{'typedef'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <synopsis>typedef " . $args{'typedef'} . ";</synopsis>\n"; + print "</refsynopsisdiv>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output in XML DocBook +sub output_blockhead_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + my $id = $args{'module'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + if (!$args{'content-only'}) { + print "<refsect1>\n <title>$section</title>\n"; + } + if ($section =~ m/EXAMPLE/i) { + print "<example><para>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</para></example>\n"; + } else { + print "</para>"; + } + if (!$args{'content-only'}) { + print "\n</refsect1>\n"; + } + } + + print "\n\n"; +} + +# output in XML DocBook +sub output_function_gnome { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = $args{'module'} . "-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<sect2>\n"; + print " <title id="$id">" . $args{'function'} . "</title>\n"; + + print " <funcsynopsis>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " "; + print "</function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1 <parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void>\n"; + } + print " </funcsynopsis>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <informaltable pgwide="1" frame="none" role="params">\n"; + print "<tgroup cols="2">\n"; + print "<colspec colwidth="2*">\n"; + print "<colspec colwidth="8*">\n"; + print "<tbody>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <row><entry align="right"><parameter>$parameter</parameter></entry>\n"; + print " <entry>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </entry></row>\n"; + } + print " </tbody></tgroup></informaltable>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<simplesect>\n <title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<example><programlisting>\n"; + } else { + } + print "<para>\n"; + output_highlight($args{'sections'}{$section}); + print "</para>\n"; + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></example>\n"; + } else { + } + print " </simplesect>\n"; + } + + print "</sect2>\n\n"; +} + +## +# output function in man +sub output_function_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'function'}" 9 "$args{'function'}" "$man_date" "Bootloader Hacker's Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'function'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + if ($args{'functiontype'} ne "") { + print ".B "" . $args{'functiontype'} . "" " . $args{'function'} . "\n"; + } else { + print ".B "" . $args{'function'} . "\n"; + } + $count = 0; + my $parenth = "("; + my $post = ","; + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($count == $#{$args{'parameterlist'}}) { + $post = ");"; + } + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI "" . $parenth . $1 . "" " . $parameter . " ") (" . $2 . ")" . $post . ""\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI "" . $parenth . $type . "" " . $parameter . " "" . $post . ""\n"; + } + $count++; + $parenth = ""; + } + + print ".SH ARGUMENTS\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "", uc $section, ""\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output enum in man +sub output_enum_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "enum $args{'enum'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "enum " . $args{'enum'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + print ".br\n.BI " $parameter"\n"; + if ($count == $#{$args{'parameterlist'}}) { + print "\n};\n"; + last; + } + else { + print ", \n.br\n"; + } + $count++; + } + + print ".SH Constants\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output struct in man +sub output_struct_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "" . $args{'type'} . " " . $args{'struct'} . "" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'type'} . " " . $args{'struct'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n.br\n"; + + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print ".BI "$parameter"\n.br\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI " " . $1 . "" " . $parameter . " ") (" . $2 . ")" . ""\n;\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print ".BI " " . $1 . "\ " " . $parameter . $2 . " "" . ""\n;\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI " " . $type . "" " . $parameter . " "" . ""\n;\n"; + } + print "\n.br\n"; + } + print "};\n.br\n"; + + print ".SH Members\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output typedef in man +sub output_typedef_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "$args{'typedef'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "typedef " . $args{'typedef'} . " \- " . $args{'purpose'} . "\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +sub output_blockhead_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "$args{'module'}" "$man_date" "API Manual" U-BOOT\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output in text +sub output_function_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $start; + + print "Name:\n\n"; + print $args{'function'} . " - " . $args{'purpose'} . "\n"; + + print "\nSynopsis:\n\n"; + if ($args{'functiontype'} ne "") { + $start = $args{'functiontype'} . " " . $args{'function'} . " ("; + } else { + $start = $args{'function'} . " ("; + } + print $start; + + my $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print $1 . $parameter . ") (" . $2; + } else { + print $type . " " . $parameter; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + print " " x length($start); + } else { + print ");\n\n"; + } + } + + print "Arguments:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print $parameter . "\n\t" . $args{'parameterdescs'}{$parameter_name} . "\n"; + } + output_section_text(@_); +} + +#output sections in text +sub output_section_text(%) { + my %args = %{$_[0]}; + my $section; + + print "\n"; + foreach $section (@{$args{'sectionlist'}}) { + print "$section:\n\n"; + output_highlight($args{'sections'}{$section}); + } + print "\n\n"; +} + +# output enum in text +sub output_enum_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Enum:\n\n"; + + print "enum " . $args{'enum'} . " - " . $args{'purpose'} . "\n\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "\t$parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};\n\n"; + + print "Constants:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter} . "\n"; + } + + output_section_text(@_); +} + +# output typedef in text +sub output_typedef_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Typedef:\n\n"; + + print "typedef " . $args{'typedef'} . " - " . $args{'purpose'} . "\n"; + output_section_text(@_); +} + +# output struct as text +sub output_struct_text(%) { + my %args = %{$_[0]}; + my ($parameter); + + print $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "\n\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "\t$1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "\t$1 $parameter$2;\n"; + } else { + print "\t" . $type . " " . $parameter . ";\n"; + } + } + print "};\n\n"; + + print "Members:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter_name} . "\n"; + } + print "\n"; + output_section_text(@_); +} + +sub output_blockhead_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print " $section:\n"; + print " -> "; + output_highlight($args{'sections'}{$section}); + } +} + +## list mode output functions + +sub output_function_list(%) { + my %args = %{$_[0]}; + + print $args{'function'} . "\n"; +} + +# output enum in list +sub output_enum_list(%) { + my %args = %{$_[0]}; + print $args{'enum'} . "\n"; +} + +# output typedef in list +sub output_typedef_list(%) { + my %args = %{$_[0]}; + print $args{'typedef'} . "\n"; +} + +# output struct as list +sub output_struct_list(%) { + my %args = %{$_[0]}; + + print $args{'struct'} . "\n"; +} + +sub output_blockhead_list(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print "DOC: $section\n"; + } +} + +## +# generic output function for all types (function, struct/union, typedef, enum); +# calls the generated, variable output_ function name based on +# functype and output_mode +sub output_declaration { + no strict 'refs'; + my $name = shift; + my $functype = shift; + my $func = "output_${functype}_$output_mode"; + if (($function_only==0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + &$func(@_); + $section_counter++; + } +} + +## +# generic output function - calls the right one based on current output mode. +sub output_blockhead { + no strict 'refs'; + my $func = "output_blockhead_" . $output_mode; + &$func(@_); + $section_counter++; +} + +## +# takes a declaration (struct, union, enum, typedef) and +# invokes the right handler. NOT called for functions. +sub dump_declaration($$) { + no strict 'refs'; + my ($prototype, $file) = @_; + my $func = "dump_" . $decl_type; + &$func(@_); +} + +sub dump_union($$) { + dump_struct(@_); +} + +sub dump_struct($$) { + my $x = shift; + my $file = shift; + my $nested; + + if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}/) { + #my $decl_type = $1; + $declaration_name = $2; + my $members = $3; + + # ignore embedded structs or unions + $members =~ s/({.*})//g; + $nested = $1; + + # ignore members marked private: + $members =~ s//*\s*private:.*?/*\s*public:.*?*///gos; + $members =~ s//*\s*private:.*//gos; + # strip comments: + $members =~ s//*.*?*///gos; + $nested =~ s//*.*?*///gos; + # strip kmemcheck_bitfield_{begin,end}.*; + $members =~ s/kmemcheck_bitfield_.*?;//gos; + # strip attributes + $members =~ s/__aligned\s*(\d+)//gos; + + create_parameterlist($members, ';', $file); + check_sections($file, $declaration_name, "struct", $sectcheck, $struct_actual, $nested); + + output_declaration($declaration_name, + 'struct', + {'struct' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose, + 'type' => $decl_type + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse struct or union!\n"; + ++$errors; + } +} + +sub dump_enum($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + $x =~ s/^#\s*define\s+.*$//; # strip #define macros inside enums + + if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { + $declaration_name = $1; + my $members = $2; + + foreach my $arg (split ',', $members) { + $arg =~ s/^\s*(\w+).*/$1/; + push @parameterlist, $arg; + if (!$parameterdescs{$arg}) { + $parameterdescs{$arg} = $undescribed; + print STDERR "Warning(${file}:$.): Enum value '$arg' ". + "not described in enum '$declaration_name'\n"; + } + + } + + output_declaration($declaration_name, + 'enum', + {'enum' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse enum!\n"; + ++$errors; + } +} + +sub dump_typedef($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + while (($x =~ /(*.)\s*;$/) || ($x =~ /[*.]\s*;$/)) { + $x =~ s/(*.)\s*;$/;/; + $x =~ s/[*.]\s*;$/;/; + } + + if ($x =~ /typedef.*\s+(\w+)\s*;/) { + $declaration_name = $1; + + output_declaration($declaration_name, + 'typedef', + {'typedef' => $declaration_name, + 'module' => $modulename, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse typedef!\n"; + ++$errors; + } +} + +sub save_struct_actual($) { + my $actual = shift; + + # strip all spaces from the actual param so that it looks like one string item + $actual =~ s/\s*//g; + $struct_actual = $struct_actual . $actual . " "; +} + +sub create_parameterlist($$$) { + my $args = shift; + my $splitter = shift; + my $file = shift; + my $type; + my $param; + + # temporarily replace commas inside function pointer definition + while ($args =~ /(([^),]+),/) { + $args =~ s/(([^),]+),/$1#/g; + } + + foreach my $arg (split($splitter, $args)) { + # strip comments + $arg =~ s//*.**///; + # strip leading/trailing spaces + $arg =~ s/^\s*//; + $arg =~ s/\s*$//; + $arg =~ s/\s+/ /; + + if ($arg =~ /^#/) { + # Treat preprocessor directive as a typeless variable just to fill + # corresponding data structures "correctly". Catch it later in + # output_* subs. + push_parameter($arg, "", $file); + } elsif ($arg =~ m/(.+)\s*(/) { + # pointer-to-function + $arg =~ tr/#/,/; + $arg =~ m/[^(]+(*?\s*(\w*)\s*)/; + $param = $1; + $type = $arg; + $type =~ s/([^(]+(*?)\s*$param/$1/; + save_struct_actual($param); + push_parameter($param, $type, $file); + } elsif ($arg) { + $arg =~ s/\s*:\s*/:/g; + $arg =~ s/\s*[/[/g; + + my @args = split('\s*,\s*', $arg); + if ($args[0] =~ m/*/) { + $args[0] =~ s/(*+)\s*/ $1/; + } + + my @first_arg; + if ($args[0] =~ /^(.*\s+)(.*?[.*].*)$/) { + shift @args; + push(@first_arg, split('\s+', $1)); + push(@first_arg, $2); + } else { + @first_arg = split('\s+', shift @args); + } + + unshift(@args, pop @first_arg); + $type = join " ", @first_arg; + + foreach $param (@args) { + if ($param =~ m/^(*+)\s*(.*)/) { + save_struct_actual($2); + push_parameter($2, "$type $1", $file); + } + elsif ($param =~ m/(.*?):(\d+)/) { + if ($type ne "") { # skip unnamed bit-fields + save_struct_actual($1); + push_parameter($1, "$type:$2", $file) + } + } + else { + save_struct_actual($param); + push_parameter($param, $type, $file); + } + } + } + } +} + +sub push_parameter($$$) { + my $param = shift; + my $type = shift; + my $file = shift; + + if (($anon_struct_union == 1) && ($type eq "") && + ($param eq "}")) { + return; # ignore the ending }; from anon. struct/union + } + + $anon_struct_union = 0; + my $param_name = $param; + $param_name =~ s/[.*//; + + if ($type eq "" && $param =~ /...$/) + { + if (!defined $parameterdescs{$param} || $parameterdescs{$param} eq "") { + $parameterdescs{$param} = "variable arguments"; + } + } + elsif ($type eq "" && ($param eq "" or $param eq "void")) + { + $param="void"; + $parameterdescs{void} = "no arguments"; + } + elsif ($type eq "" && ($param eq "struct" or $param eq "union")) + # handle unnamed (anonymous) union or struct: + { + $type = $param; + $param = "{unnamed_" . $param . "}"; + $parameterdescs{$param} = "anonymous\n"; + $anon_struct_union = 1; + } + + # warn if parameter has no description + # (but ignore ones starting with # as these are not parameters + # but inline preprocessor statements); + # also ignore unnamed structs/unions; + if (!$anon_struct_union) { + if (!defined $parameterdescs{$param_name} && $param_name !~ /^#/) { + + $parameterdescs{$param_name} = $undescribed; + + if (($type eq 'function') || ($type eq 'enum')) { + print STDERR "Warning(${file}:$.): Function parameter ". + "or member '$param' not " . + "described in '$declaration_name'\n"; + } + print STDERR "Warning(${file}:$.):" . + " No description found for parameter '$param'\n"; + ++$warnings; + } + } + + $param = xml_escape($param); + + # strip spaces from $param so that it is one continuous string + # on @parameterlist; + # this fixes a problem where check_sections() cannot find + # a parameter like "addr[6 + 2]" because it actually appears + # as "addr[6", "+", "2]" on the parameter list; + # but it's better to maintain the param string unchanged for output, + # so just weaken the string compare in check_sections() to ignore + # "[blah" in a parameter string; + ###$param =~ s/\s*//g; + push @parameterlist, $param; + $parametertypes{$param} = $type; +} + +sub check_sections($$$$$$) { + my ($file, $decl_name, $decl_type, $sectcheck, $prmscheck, $nested) = @_; + my @sects = split ' ', $sectcheck; + my @prms = split ' ', $prmscheck; + my $err; + my ($px, $sx); + my $prm_clean; # strip trailing "[array size]" and/or beginning "*" + + foreach $sx (0 .. $#sects) { + $err = 1; + foreach $px (0 .. $#prms) { + $prm_clean = $prms[$px]; + $prm_clean =~ s/[.*]//; + $prm_clean =~ s/__attribute__\s*(([a-z,_*\s()]*))//i; + # ignore array size in a parameter string; + # however, the original param string may contain + # spaces, e.g.: addr[6 + 2] + # and this appears in @prms as "addr[6" since the + # parameter list is split at spaces; + # hence just ignore "[..." for the sections check; + $prm_clean =~ s/[.*//; + + ##$prm_clean =~ s/^**//; + if ($prm_clean eq $sects[$sx]) { + $err = 0; + last; + } + } + if ($err) { + if ($decl_type eq "function") { + print STDERR "Warning(${file}:$.): " . + "Excess function parameter " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } else { + if ($nested !~ m/\Q$sects[$sx]\E/) { + print STDERR "Warning(${file}:$.): " . + "Excess struct/union/enum/typedef member " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } + } + } + } +} + +## +# takes a function prototype and the name of the current file being +# processed and spits out all the details stored in the global +# arrays/hashes. +sub dump_function($$) { + my $prototype = shift; + my $file = shift; + + $prototype =~ s/^static +//; + $prototype =~ s/^extern +//; + $prototype =~ s/^asmlinkage +//; + $prototype =~ s/^inline +//; + $prototype =~ s/^__inline__ +//; + $prototype =~ s/^__inline +//; + $prototype =~ s/^__always_inline +//; + $prototype =~ s/^noinline +//; + $prototype =~ s/__devinit +//; + $prototype =~ s/__init +//; + $prototype =~ s/__init_or_module +//; + $prototype =~ s/__must_check +//; + $prototype =~ s/__weak +//; + $prototype =~ s/^#\s*define\s+//; #ak added + $prototype =~ s/__attribute__\s*(([a-z,]*))//; + + # Yes, this truly is vile. We are looking for: + # 1. Return type (may be nothing if we're looking at a macro) + # 2. Function name + # 3. Function parameters. + # + # All the while we have to watch out for function pointer parameters + # (which IIRC is what the two sections are for), C types (these + # regexps don't even start to express all the possibilities), and + # so on. + # + # If you mess with these regexps, it's a good idea to check that + # the following functions' documentation still comes out right: + # - parport_register_device (function pointer parameters) + # - atomic_set (macro) + # - pci_match_device, __copy_to_user (long return type) + + if ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**+)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**\s*\w+\s**\s*)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/) { + $return_type = $1; + $declaration_name = $2; + my $args = $3; + + create_parameterlist($args, ',', $file); + } else { + print STDERR "Error(${file}:$.): cannot understand prototype: '$prototype'\n"; + ++$errors; + return; + } + + my $prms = join " ", @parameterlist; + check_sections($file, $declaration_name, "function", $sectcheck, $prms, ""); + + output_declaration($declaration_name, + 'function', + {'function' => $declaration_name, + 'module' => $modulename, + 'functiontype' => $return_type, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); +} + +sub reset_state { + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $sectcheck = ""; + $struct_actual = ""; + $prototype = ""; + + $state = 0; +} + +sub tracepoint_munge($) { + my $file = shift; + my $tracepointname = 0; + my $tracepointargs = 0; + + if ($prototype =~ m/TRACE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_SINGLE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_EVENT((.*?),(.*?),/) { + $tracepointname = $2; + } + $tracepointname =~ s/^\s+//; #strip leading whitespace + if ($prototype =~ m/TP_PROTO((.*?))/) { + $tracepointargs = $1; + } + if (($tracepointname eq 0) || ($tracepointargs eq 0)) { + print STDERR "Warning(${file}:$.): Unrecognized tracepoint format: \n". + "$prototype\n"; + } else { + $prototype = "static inline void trace_$tracepointname($tracepointargs)"; + } +} + +sub syscall_munge() { + my $void = 0; + + $prototype =~ s@[\r\n\t]+@ @gos; # strip newlines/CR's/tabs +## if ($prototype =~ m/SYSCALL_DEFINE0\s*(\s*(a-zA-Z0-9_)*\s*)/) { + if ($prototype =~ m/SYSCALL_DEFINE0/) { + $void = 1; +## $prototype = "long sys_$1(void)"; + } + + $prototype =~ s/SYSCALL_DEFINE.*(/long sys_/; # fix return type & func name + if ($prototype =~ m/long (sys_.*?),/) { + $prototype =~ s/,/(/; + } elsif ($void) { + $prototype =~ s/)/(void)/; + } + + # now delete all of the odd-number commas in $prototype + # so that arg types & arg names don't have a comma between them + my $count = 0; + my $len = length($prototype); + if ($void) { + $len = 0; # skip the for-loop + } + for (my $ix = 0; $ix < $len; $ix++) { + if (substr($prototype, $ix, 1) eq ',') { + $count++; + if ($count % 2 == 1) { + substr($prototype, $ix, 1) = ' '; + } + } + } +} + +sub process_state3_function($$) { + my $x = shift; + my $file = shift; + + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ m#\s*/*\s+MACDOC\s*#io || ($x =~ /^#/ && $x !~ /^#\s*define/)) { + # do nothing + } + elsif ($x =~ /([^{]*)/) { + $prototype .= $1; + } + + if (($x =~ /{/) || ($x =~ /#\s*define/) || ($x =~ /;/)) { + $prototype =~ s@/*.*?*/@@gos; # strip comments. + $prototype =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $prototype =~ s@^\s+@@gos; # strip leading spaces + if ($prototype =~ /SYSCALL_DEFINE/) { + syscall_munge(); + } + if ($prototype =~ /TRACE_EVENT/ || $prototype =~ /DEFINE_EVENT/ || + $prototype =~ /DEFINE_SINGLE_EVENT/) + { + tracepoint_munge($file); + } + dump_function($prototype, $file); + reset_state(); + } +} + +sub process_state3_type($$) { + my $x = shift; + my $file = shift; + + $x =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $x =~ s@^\s+@@gos; # strip leading spaces + $x =~ s@\s+$@@gos; # strip trailing spaces + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ /^#/) { + # To distinguish preprocessor directive from regular declaration later. + $x .= ";"; + } + + while (1) { + if ( $x =~ /([^{};]*)([{};])(.*)/ ) { + $prototype .= $1 . $2; + ($2 eq '{') && $brcount++; + ($2 eq '}') && $brcount--; + if (($2 eq ';') && ($brcount == 0)) { + dump_declaration($prototype, $file); + reset_state(); + last; + } + $x = $3; + } else { + $prototype .= $x; + last; + } + } +} + +# xml_escape: replace <, >, and & in the text stream; +# +# however, formatting controls that are generated internally/locally in the +# kernel-doc script are not escaped here; instead, they begin life like +# $blankline_html (4 of '' followed by a mnemonic + ':'), then these strings +# are converted to their mnemonic-expected output, without the 4 * '' & ':', +# just before actual output; (this is done by local_unescape()) +sub xml_escape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/&/\\\amp;/g; + $text =~ s/</\\\lt;/g; + $text =~ s/>/\\\gt;/g; + return $text; +} + +# convert local escape strings to html +# local escape strings look like: '\\menmonic:' (that's 4 backslashes) +sub local_unescape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/\\\\lt:/</g; + $text =~ s/\\\\gt:/>/g; + return $text; +} + +sub process_file($) { + my $file; + my $identifier; + my $func; + my $descr; + my $in_purpose = 0; + my $initial_section_counter = $section_counter; + + if (defined($ENV{'SRCTREE'})) { + $file = "$ENV{'SRCTREE'}" . "/" . "@_"; + } + else { + $file = "@_"; + } + if (defined($source_map{$file})) { + $file = $source_map{$file}; + } + + if (!open(IN,"<$file")) { + print STDERR "Error: Cannot open file $file\n"; + ++$errors; + return; + } + + $. = 1; + + $section_counter = 0; + while (<IN>) { + if ($state == 0) { + if (/$doc_start/o) { + $state = 1; # next line is always the function name + $in_doc_sect = 0; + } + } elsif ($state == 1) { # this line is the function name (always) + if (/$doc_block/o) { + $state = 4; + $contents = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_decl/o) { + $identifier = $1; + if (/\s*([\w\s]+?)\s*-/) { + $identifier = $1; + } + + $state = 2; + if (/-(.*)/) { + # strip leading/trailing/multiple spaces + $descr= $1; + $descr =~ s/^\s*//; + $descr =~ s/\s*$//; + $descr =~ s/\s+/ /; + $declaration_purpose = xml_escape($descr); + $in_purpose = 1; + } else { + $declaration_purpose = ""; + } + + if (($declaration_purpose eq "") && $verbose) { + print STDERR "Warning(${file}:$.): missing initial short description on line:\n"; + print STDERR $_; + ++$warnings; + } + + if ($identifier =~ m/^struct/) { + $decl_type = 'struct'; + } elsif ($identifier =~ m/^union/) { + $decl_type = 'union'; + } elsif ($identifier =~ m/^enum/) { + $decl_type = 'enum'; + } elsif ($identifier =~ m/^typedef/) { + $decl_type = 'typedef'; + } else { + $decl_type = 'function'; + } + + if ($verbose) { + print STDERR "Info(${file}:$.): Scanning doc for $identifier\n"; + } + } else { + print STDERR "Warning(${file}:$.): Cannot understand $_ on line $.", + " - I thought it was a doc line\n"; + ++$warnings; + $state = 0; + } + } elsif ($state == 2) { # look for head: lines, and include content + if (/$doc_sect/o) { + $newsection = $1; + $newcontents = $2; + + if (($contents ne "") && ($contents ne "\n")) { + if (!$in_doc_sect && $verbose) { + print STDERR "Warning(${file}:$.): contents before sections\n"; + ++$warnings; + } + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + } + + $in_doc_sect = 1; + $in_purpose = 0; + $contents = $newcontents; + if ($contents ne "") { + while ((substr($contents, 0, 1) eq " ") || + substr($contents, 0, 1) eq "\t") { + $contents = substr($contents, 1); + } + $contents .= "\n"; + } + $section = $newsection; + } elsif (/$doc_end/) { + + if (($contents ne "") && ($contents ne "\n")) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } + # look for doc_com + <text> + doc_end: + if ($_ =~ m'\s**\s*[a-zA-Z_0-9:.]+*/') { + print STDERR "Warning(${file}:$.): suspicious ending line: $_"; + ++$warnings; + } + + $prototype = ""; + $state = 3; + $brcount = 0; +# print STDERR "end of doc comment, looking for prototype\n"; + } elsif (/$doc_content/) { + # miguel-style comment kludge, look for blank lines after + # @parameter line to signify start of description + if ($1 eq "") { + if ($section =~ m/^@/ || $section eq $section_context) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } else { + $contents .= "\n"; + } + $in_purpose = 0; + } elsif ($in_purpose == 1) { + # Continued declaration purpose + chomp($declaration_purpose); + $declaration_purpose .= " " . xml_escape($1); + } else { + $contents .= $1 . "\n"; + } + } else { + # i dont know - bad line? ignore. + print STDERR "Warning(${file}:$.): bad line: $_"; + ++$warnings; + } + } elsif ($state == 3) { # scanning for function '{' (end of prototype) + if ($decl_type eq 'function') { + process_state3_function($_, $file); + } else { + process_state3_type($_, $file); + } + } elsif ($state == 4) { + # Documentation block + if (/$doc_block/) { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_end/) + { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + $state = 0; + } + elsif (/$doc_content/) + { + if ( $1 eq "" ) + { + $contents .= $blankline; + } + else + { + $contents .= $1 . "\n"; + } + } + } + } + if ($initial_section_counter == $section_counter) { + print STDERR "Warning(${file}): no structured comments found\n"; + if ($output_mode eq "xml") { + # The template wants at least one RefEntry here; make one. + print "<refentry>\n"; + print " <refnamediv>\n"; + print " <refname>\n"; + print " ${file}\n"; + print " </refname>\n"; + print " <refpurpose>\n"; + print " Document generation inconsistency\n"; + print " </refpurpose>\n"; + print " </refnamediv>\n"; + print " <refsect1>\n"; + print " <title>\n"; + print " Oops\n"; + print " </title>\n"; + print " <warning>\n"; + print " <para>\n"; + print " The template for this document tried to insert\n"; + print " the structured comment from the file\n"; + print " <filename>${file}</filename> at this point,\n"; + print " but none was found.\n"; + print " This dummy section is inserted to allow\n"; + print " generation to continue.\n"; + print " </para>\n"; + print " </warning>\n"; + print " </refsect1>\n"; + print "</refentry>\n"; + } + } +} + + +$kernelversion = get_kernel_version(); + +# generate a sequence of code that will splice in highlighting information +# using the s// operator. +foreach my $pattern (keys %highlights) { +# print STDERR "scanning pattern:$pattern, highlight:($highlights{$pattern})\n"; + $dohighlight .= "$contents =~ s:$pattern:$highlights{$pattern}:gs;\n"; +} + +# Read the file that maps relative names to absolute names for +# separate source and object directories and for shadow trees. +if (open(SOURCE_MAP, "<.tmp_filelist.txt")) { + my ($relname, $absname); + while(<SOURCE_MAP>) { + chop(); + ($relname, $absname) = (split())[0..1]; + $relname =~ s:^/+::; + $source_map{$relname} = $absname; + } + close(SOURCE_MAP); +} + +foreach (@ARGV) { + chomp; + process_file($_); +} +if ($verbose && $errors) { + print STDERR "$errors errors\n"; +} +if ($verbose && $warnings) { + print STDERR "$warnings warnings\n"; +} + +exit($errors);
Import basic CSS stylesheet for the HTML documentation. The base for the stylesheet is taken from:
http://ds9a.nl/docbook/minimal-page.html
I customized the CSS a bit further, for example to add curvy corners to example section and change the tint of gray. The HTML documentation does not look that crude anymore.
Signed-off-by: Marek Vasut marex@denx.de --- doc/DocBook/docbook.css | 16 ++++++++++++++++ doc/DocBook/stylesheet.xsl | 1 + 2 files changed, 17 insertions(+) create mode 100644 doc/DocBook/docbook.css
diff --git a/doc/DocBook/docbook.css b/doc/DocBook/docbook.css new file mode 100644 index 0000000..7a79ec5 --- /dev/null +++ b/doc/DocBook/docbook.css @@ -0,0 +1,16 @@ +body { + font-family: sans-serif; +} + +.programlisting { + font-family: monospace; + font-size: 1em; + display: block; + padding: 10px; + border: 1px solid #aaa; + color: #000; + background-color: #eee; + overflow: auto; + margin: 1em 0em; + border-radius: 6px; +} diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl index 85b2527..8adce56 100644 --- a/doc/DocBook/stylesheet.xsl +++ b/doc/DocBook/stylesheet.xsl @@ -7,4 +7,5 @@ <!-- <param name="paper.type">A4</param> --> <param name="generate.section.toc.level">2</param> <param name="use.id.as.filename">1</param> +<param name="html.stylesheet">../docbook.css</param> </stylesheet>
The default kernel-doc strips starting spaces from every single line in the Example section. This makes the code look bad. Thus, implement special handling for this section.
Signed-off-by: Marek Vasut marex@denx.de --- tools/kernel-doc/kernel-doc | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc index 8848efd..6347418 100755 --- a/tools/kernel-doc/kernel-doc +++ b/tools/kernel-doc/kernel-doc @@ -2424,6 +2424,9 @@ sub process_file($) { # Continued declaration purpose chomp($declaration_purpose); $declaration_purpose .= " " . xml_escape($1); + } elsif ($section =~ m/^Example/) { + $_ =~ s/^\s**//; + $contents .= $_; } else { $contents .= $1 . "\n"; }
Implement kerneldoc template for linker-generated arrays. This is the first template in U-Boot that is used to generate kerneldoc style documentation. This template is very basic.
Signed-off-by: Marek Vasut marex@denx.de --- doc/DocBook/Makefile | 2 +- doc/DocBook/linker_lists.tmpl | 46 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 47 insertions(+), 1 deletion(-) create mode 100644 doc/DocBook/linker_lists.tmpl
diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile index 2f2ddfc..5f13d3d 100644 --- a/doc/DocBook/Makefile +++ b/doc/DocBook/Makefile @@ -8,7 +8,7 @@
include $(TOPDIR)/config.mk
-DOCBOOKS := +DOCBOOKS := linker_lists.xml
### # The build process is as follows (targets): diff --git a/doc/DocBook/linker_lists.tmpl b/doc/DocBook/linker_lists.tmpl new file mode 100644 index 0000000..a47377f --- /dev/null +++ b/doc/DocBook/linker_lists.tmpl @@ -0,0 +1,46 @@ +<?xml version="1.0" encoding="UTF-8"?> +<!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML V4.1.2//EN" + "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd" []> + +<book id="UBootLGArrays"> + <bookinfo> + <title>The U-Boot Linker-Generated Arrays</title> + + <legalnotice> + <para> + This documentation is free software; you can redistribute + it and/or modify it under the terms of the GNU General Public + License as published by the Free Software Foundation; either + version 2 of the License, or (at your option) any later + version. + </para> + + <para> + This program is distributed in the hope that it will be + useful, but WITHOUT ANY WARRANTY; without even the implied + warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. + See the GNU General Public License for more details. + </para> + + <para> + You should have received a copy of the GNU General Public + License along with this program; if not, write to the Free + Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, + MA 02111-1307 USA + </para> + + <para> + For more details see the file COPYING in the source + distribution of U-Boot Bootloader. + </para> + </legalnotice> + </bookinfo> + +<toc></toc> + + <chapter id="adt"> + <title>Linker-Generated Arrays</title> +!Iinclude/linker_lists.h + </chapter> + +</book>
On Sun, Sep 30, 2012 at 02:21:31AM +0200, Marek Vasut wrote:
This patch series implants slightly modified kernel-doc documentation generator from Linux kernel into U-Boot. First patch pulls in all the necessary components with minor modifications made to them to work with the layout of U-Boot source tree and without kbuild.
Further patch implement CSS to make the HTML documentation look a bit nicer. This patch will eventually (hopefully) be further refined by someone more artistically capable than me ;-)
Next patch implements separate handling for "Example:" section, which in the original kernel-doc was in my opinion mistreated. The example section generated a block of code, but the indentation was removed. Thus this patch does avoid removing the indent.
Finally, the last patch implements example of how to use this kernel-doc to generate U-Boot documentation by documenting the Linker-Generated arrays.
NOTE: This patchset (last patch) has a cross-dependency on: [PATCH 0/5] Linker-generated arrays (take 2)
V2: Add proper .gitignore entries, fix build issues (fix Makefiles)
Thanks for doing all this. It looks fine and I'll grab this with the LG-arrays code once everyone is happy on that side.
Dear Tom Rini,
I'm spliting the LG-array dep from these ... but I have another problem. If I actually add the patman tags here (which I did now), can you pull that repo without pulling the tags too? How do we handle that ?
Best regards, Marek Vasut
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 10/06/12 16:26, Marek Vasut wrote:
Dear Tom Rini,
We talked about this on IRC, but to be clear and for the record: - - No pull requests from patman branches - - Just do a 'git checkout -b final/feature base_branch' or whatever and then just 'git am 0*' the patches that patman will have spit out for you already.
- -- Tom
Dear Tom Rini,
Dear Tom Rini,
Yes, good. I rolled out V3, are we ok to apply? I have some patches for upstream linux kernel ready, but ... documentation seems to be pretty dead/deaf area there :(
Dear Tom Rini,
Good, now it is imperative to discuss the rules. Can you check my proposal for wiki addendum?
On 10/09/12 15:37, Marek Vasut wrote:
Dear Tom Rini,
Done, and for clarity I did apply the v3 series, not v2. Just replied to the wrong summary.
- -- Tom
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build.
Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400
Signed-off-by: Marek Vasut marex@denx.de --- Makefile | 7 +- doc/DocBook/.gitignore | 15 + doc/DocBook/Makefile | 229 ++++ doc/DocBook/stylesheet.xsl | 10 + tools/.gitignore | 1 + tools/Makefile | 2 +- tools/kernel-doc/Makefile | 38 + tools/kernel-doc/docproc.c | 576 ++++++++++ tools/kernel-doc/kernel-doc | 2554 +++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 3430 insertions(+), 2 deletions(-) create mode 100644 doc/DocBook/.gitignore create mode 100644 doc/DocBook/Makefile create mode 100644 doc/DocBook/stylesheet.xsl create mode 100644 tools/kernel-doc/Makefile create mode 100644 tools/kernel-doc/docproc.c create mode 100755 tools/kernel-doc/kernel-doc
V3: - Discard the patch adding LG-array template - Add patch adding myself into git aliases for kerneldoc - Make use of patman tags in commit description - Push the patches to testing: http://git.denx.de/?p=u-boot/u-boot-testing.git;a=shortlog;h=refs/heads/dm-k...
V2: - Add .gitignore, drop kernel-doc target which was bogus
diff --git a/Makefile b/Makefile index 34d9075..012d325 100644 --- a/Makefile +++ b/Makefile @@ -695,6 +695,9 @@ easylogo env gdb: $(MAKE) -C tools/$@ all MTD_VERSION=${MTD_VERSION} gdbtools: gdb
+xmldocs pdfdocs psdocs htmldocs mandocs: tools/kernel-doc/docproc + $(MAKE) U_BOOT_VERSION=$(U_BOOT_VERSION) -C doc/DocBook/ $@ + tools-all: easylogo env gdb $(VERSION_FILE) $(TIMESTAMP_FILE) $(MAKE) -C tools HOST_TOOLS_ALL=y
@@ -779,7 +782,8 @@ clean: $(obj)tools/mk{env,}image $(obj)tools/mpc86x_clk \ $(obj)tools/mk{smdk5250,}spl \ $(obj)tools/mxsboot \ - $(obj)tools/ncb $(obj)tools/ubsha1 + $(obj)tools/ncb $(obj)tools/ubsha1 \ + $(obj)tools/kernel-doc/docproc @rm -f $(obj)board/cray/L1/{bootscript.c,bootscript.image} \ $(obj)board/matrix_vision/*/bootscript.img \ $(obj)board/voiceblue/eeprom \ @@ -792,6 +796,7 @@ clean: @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s @rm -f $(TIMESTAMP_FILE) $(VERSION_FILE) + @$(MAKE) -C doc/DocBook/ cleandocs @find $(OBJTREE) -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' -o -name '*.su' \ -o -name '*.o' -o -name '*.a' -o -name '*.exe' ) -print \ diff --git a/doc/DocBook/.gitignore b/doc/DocBook/.gitignore new file mode 100644 index 0000000..90c1b11 --- /dev/null +++ b/doc/DocBook/.gitignore @@ -0,0 +1,15 @@ +*/ +*.xml +*.ps +*.pdf +*.html +*.9.gz +*.9 +*.aux +*.dvi +*.log +*.out +*.png +*.gif +media-indices.tmpl +media-entities.tmpl diff --git a/doc/DocBook/Makefile b/doc/DocBook/Makefile new file mode 100644 index 0000000..2f2ddfc --- /dev/null +++ b/doc/DocBook/Makefile @@ -0,0 +1,229 @@ +### +# This makefile is used to generate the kernel documentation, +# primarily based on in-line comments in various source files. +# See doc/kernel-doc-nano-HOWTO.txt for instruction in how +# to document the SRC - and how to read it. +# To add a new book the only step required is to add the book to the +# list of DOCBOOKS. + +include $(TOPDIR)/config.mk + +DOCBOOKS := + +### +# The build process is as follows (targets): +# (xmldocs) [by docproc] +# file.tmpl --> file.xml +--> file.ps (psdocs) [by db2ps or xmlto] +# +--> file.pdf (pdfdocs) [by db2pdf or xmlto] +# +--> DIR=file (htmldocs) [by xmlto] +# +--> man/ (mandocs) [by xmlto] + + +# for PDF and PS output you can choose between xmlto and docbook-utils tools +PDF_METHOD = $(prefer-db2x) +PS_METHOD = $(prefer-db2x) + + +### +# The targets that may be used. +PHONY += $(obj).depend xmldocs sgmldocs psdocs pdfdocs htmldocs mandocs installmandocs cleandocs + +BOOKS := $(addprefix $(OBJTREE)/doc/DocBook/,$(DOCBOOKS)) +xmldocs: $(BOOKS) +sgmldocs: xmldocs + +PS := $(patsubst %.xml, %.ps, $(BOOKS)) +psdocs: $(PS) + +PDF := $(patsubst %.xml, %.pdf, $(BOOKS)) +pdfdocs: $(PDF) + +HTML := $(sort $(patsubst %.xml, %.html, $(BOOKS))) +htmldocs: $(HTML) + $(call build_main_index) + $(call build_images) + $(call install_media_images) + +MAN := $(patsubst %.xml, %.9, $(BOOKS)) +mandocs: $(MAN) + +installmandocs: mandocs + mkdir -p /usr/local/man/man9/ + install doc/DocBook/man/*.9.gz /usr/local/man/man9/ + +### +#External programs used +KERNELDOC = $(SRCTREE)/tools/kernel-doc/kernel-doc +DOCPROC = $(OBJTREE)/tools/kernel-doc/docproc + +XMLTOFLAGS = -m $(SRCTREE)/doc/DocBook/stylesheet.xsl +XMLTOFLAGS += --skip-validation + +### +# DOCPROC is used for two purposes: +# 1) To generate a dependency list for a .tmpl file +# 2) To preprocess a .tmpl file and call kernel-doc with +# appropriate parameters. +# The following rules are used to generate the .xml documentation +# required to generate the final targets. (ps, pdf, html). +%.xml: %.tmpl + $(DOCPROC) doc $< >$@ + +ifeq ($@, "cleandocs") +sinclude $(obj).depend +$(obj).depend: $(patsubst %.xml, %.tmpl, $(DOCBOOKS)) + rm -f $(obj).depend ; \ + touch $(obj).depend ; \ + for file in $^ ; do \ + xmlfile=`echo "$${file}" | \ + sed "s/tmpl$$/xml/"` ; \ + echo -n "$${xmlfile}: ">> $(obj).depend ; \ + $(DOCPROC) depend $$file >> $(obj).depend ; \ + echo -e "\n\t$(DOCPROC) doc $< >$${xmlfile} " >> \ + $(obj).depend ; \ + done +endif + +### +# Changes in kernel-doc force a rebuild of all documentation +$(BOOKS): $(KERNELDOC) + +notfoundtemplate = echo "*** You have to install docbook-utils or xmlto ***"; \ + exit 1 +db2xtemplate = db2TYPE -o $(dir $@) $< +xmltotemplate = xmlto TYPE $(XMLTOFLAGS) -o $(dir $@) $< + +# determine which methods are available +ifeq ($(shell which db2ps >/dev/null 2>&1 && echo found),found) + use-db2x = db2x + prefer-db2x = db2x +else + use-db2x = notfound + prefer-db2x = $(use-xmlto) +endif +ifeq ($(shell which xmlto >/dev/null 2>&1 && echo found),found) + use-xmlto = xmlto + prefer-xmlto = xmlto +else + use-xmlto = notfound + prefer-xmlto = $(use-db2x) +endif + +# the commands, generated from the chosen template +quiet_cmd_db2ps = PS $@ + cmd_db2ps = $(subst TYPE,ps, $($(PS_METHOD)template)) +%.ps : %.xml + $(call cmd_db2ps) + +quiet_cmd_db2pdf = PDF $@ + cmd_db2pdf = $(subst TYPE,pdf, $($(PDF_METHOD)template)) +%.pdf : %.xml + $(call cmd_db2pdf) + + +index = index.html +main_idx = $(index) +build_main_index = rm -rf $(main_idx); \ + echo '<h1>U-Boot Bootloader HTML Documentation</h1>' >> $(main_idx) && \ + echo '<h2>U-Boot Version: $(U_BOOT_VERSION)</h2>' >> $(main_idx) && \ + cat $(HTML) >> $(main_idx) + +# To work around bug [1] in docbook-xsl-stylesheets 1.76.1 , generate only html +# docs instead of xhtml with xmlto. +# [1] http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=654338 +quiet_cmd_db2html = HTML $@ + cmd_db2html = xmlto html $(XMLTOFLAGS) -o $(patsubst %.html,%,$@) $< && \ + echo '<a HREF="$(patsubst %.html,%,$(notdir $@))/index.html"> \ + $(patsubst %.html,%,$(notdir $@))</a><p>' > $@ + +%.html: %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + @rm -rf $@ $(patsubst %.html,%,$@) + $(call cmd_db2html) + @if [ ! -z "$(PNG-$(basename $(notdir $@)))" ]; then \ + cp $(PNG-$(basename $(notdir $@))) $(patsubst %.html,%,$@); fi + +quiet_cmd_db2man = MAN $@ + cmd_db2man = if grep -q refentry $<; then xmlto man $(XMLTOFLAGS) -o $(obj)/man $< ; gzip -f $(obj)/man/*.9; fi +%.9 : %.xml + @(which xmlto > /dev/null 2>&1) || \ + (echo "*** You need to install xmlto ***"; \ + exit 1) + $(Q)mkdir -p $(obj)man + $(call cmd_db2man) + @touch $@ + +### +# Rules to generate postscripts and PNG images from .fig format files +quiet_cmd_fig2eps = FIG2EPS $@ + cmd_fig2eps = fig2dev -Leps $< $@ + +%.eps: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2eps) + +quiet_cmd_fig2png = FIG2PNG $@ + cmd_fig2png = fig2dev -Lpng $< $@ + +%.png: %.fig + @(which fig2dev > /dev/null 2>&1) || \ + (echo "*** You need to install transfig ***"; \ + exit 1) + $(call cmd_fig2png) + +### +# Rule to convert a .c file to inline XML documentation + gen_xml = : + quiet_gen_xml = echo ' GEN $@' +silent_gen_xml = : +%.xml: %.c + @$($(quiet)gen_xml) + @( \ + echo "<programlisting>"; \ + expand --tabs=8 < $< | \ + sed -e "s/&/\&/g" \ + -e "s/</\</g" \ + -e "s/>/\>/g"; \ + echo "</programlisting>") > $@ + +### +# Help targets as used by the top-level makefile +dochelp: + @echo ' U-Boot bootloader internal documentation in different formats:' + @echo ' htmldocs - HTML' + @echo ' pdfdocs - PDF' + @echo ' psdocs - Postscript' + @echo ' xmldocs - XML DocBook' + @echo ' mandocs - man pages' + @echo ' installmandocs - install man pages generated by mandocs' + @echo ' cleandocs - clean all generated DocBook files' + +### +# Temporary files left by various tools +clean-files := $(DOCBOOKS) \ + $(patsubst %.xml, %.dvi, $(DOCBOOKS)) \ + $(patsubst %.xml, %.aux, $(DOCBOOKS)) \ + $(patsubst %.xml, %.tex, $(DOCBOOKS)) \ + $(patsubst %.xml, %.log, $(DOCBOOKS)) \ + $(patsubst %.xml, %.out, $(DOCBOOKS)) \ + $(patsubst %.xml, %.ps, $(DOCBOOKS)) \ + $(patsubst %.xml, %.pdf, $(DOCBOOKS)) \ + $(patsubst %.xml, %.html, $(DOCBOOKS)) \ + $(patsubst %.xml, %.9, $(DOCBOOKS)) \ + $(index) + +clean-dirs := $(patsubst %.xml,%,$(DOCBOOKS)) man + +cleandocs: + @rm -f $(obj).depend + @$(Q)rm -f $(call objectify, $(clean-files)) + @$(Q)rm -rf $(call objectify, $(clean-dirs)) + +# Declare the contents of the .PHONY variable as phony. We keep that +# information in a variable se we can use it in if_changed and friends. + +.PHONY: $(PHONY) diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl new file mode 100644 index 0000000..85b2527 --- /dev/null +++ b/doc/DocBook/stylesheet.xsl @@ -0,0 +1,10 @@ +<?xml version="1.0" encoding="UTF-8"?> +<stylesheet xmlns="http://www.w3.org/1999/XSL/Transform" version="1.0"> +<param name="chunk.quietly">1</param> +<param name="funcsynopsis.style">ansi</param> +<param name="funcsynopsis.tabular.threshold">80</param> +<param name="callout.graphics">0</param> +<!-- <param name="paper.type">A4</param> --> +<param name="generate.section.toc.level">2</param> +<param name="use.id.as.filename">1</param> +</stylesheet> diff --git a/tools/.gitignore b/tools/.gitignore index 3088f4d..9bce719 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -17,3 +17,4 @@ /env/fw_printenv /gdb/gdbcont /gdb/gdbsend +/kernel-doc/docproc diff --git a/tools/Makefile b/tools/Makefile index c31437e..686840a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
-TOOLSUBDIRS = +TOOLSUBDIRS = kernel-doc
# # Include this after HOSTOS HOSTARCH check diff --git a/tools/kernel-doc/Makefile b/tools/kernel-doc/Makefile new file mode 100644 index 0000000..28a3f61 --- /dev/null +++ b/tools/kernel-doc/Makefile @@ -0,0 +1,38 @@ +# +# Copyright (C) 2012 Marek Vasut marex@denx.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +all: $(obj)docproc + +$(obj)docproc: docproc.c + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(HOSTSTRIP) $@ + +clean: + rm -rf docproc + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/kernel-doc/docproc.c b/tools/kernel-doc/docproc.c new file mode 100644 index 0000000..8bc47b0 --- /dev/null +++ b/tools/kernel-doc/docproc.c @@ -0,0 +1,576 @@ +/* + * docproc is a simple preprocessor for the template files + * used as placeholders for the kernel internal documentation. + * docproc is used for documentation-frontend and + * dependency-generator. + * The two usages have in common that they require + * some knowledge of the .tmpl syntax, therefore they + * are kept together. + * + * documentation-frontend + * Scans the template file and call kernel-doc for + * all occurrences of ![EIF]file + * Beforehand each referenced file is scanned for + * any symbols that are exported via these macros: + * EXPORT_SYMBOL(), EXPORT_SYMBOL_GPL(), & + * EXPORT_SYMBOL_GPL_FUTURE() + * This is used to create proper -function and + * -nofunction arguments in calls to kernel-doc. + * Usage: docproc doc file.tmpl + * + * dependency-generator: + * Scans the template file and list all files + * referenced in a format recognized by make. + * Usage: docproc depend file.tmpl + * Writes dependency information to stdout + * in the following format: + * file.tmpl src.c src2.c + * The filenames are obtained from the following constructs: + * !Efilename + * !Ifilename + * !Dfilename + * !Ffilename + * !Pfilename + * + */ + +#define _GNU_SOURCE +#include <stdio.h> +#include <stdlib.h> +#include <string.h> +#include <ctype.h> +#include <unistd.h> +#include <limits.h> +#include <errno.h> +#include <sys/types.h> +#include <sys/wait.h> + +/* exitstatus is used to keep track of any failing calls to kernel-doc, + * but execution continues. */ +int exitstatus = 0; + +typedef void DFL(char *); +DFL *defaultline; + +typedef void FILEONLY(char * file); +FILEONLY *internalfunctions; +FILEONLY *externalfunctions; +FILEONLY *symbolsonly; +FILEONLY *findall; + +typedef void FILELINE(char * file, char * line); +FILELINE * singlefunctions; +FILELINE * entity_system; +FILELINE * docsection; + +#define MAXLINESZ 2048 +#define MAXFILES 250 +#define KERNELDOCPATH "tools/kernel-doc/" +#define KERNELDOC "kernel-doc" +#define DOCBOOK "-docbook" +#define LIST "-list" +#define FUNCTION "-function" +#define NOFUNCTION "-nofunction" +#define NODOCSECTIONS "-no-doc-sections" + +static char *srctree, *kernsrctree; + +static char **all_list = NULL; +static int all_list_len = 0; + +static void consume_symbol(const char *sym) +{ + int i; + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + if (strcmp(sym, all_list[i])) + continue; + all_list[i] = NULL; + break; + } +} + +static void usage (void) +{ + fprintf(stderr, "Usage: docproc {doc|depend} file\n"); + fprintf(stderr, "Input is read from file.tmpl. Output is sent to stdout\n"); + fprintf(stderr, "doc: frontend when generating kernel documentation\n"); + fprintf(stderr, "depend: generate list of files referenced within file\n"); + fprintf(stderr, "Environment variable SRCTREE: absolute path to sources.\n"); + fprintf(stderr, " KBUILD_SRC: absolute path to kernel source tree.\n"); +} + +/* + * Execute kernel-doc with parameters given in svec + */ +static void exec_kernel_doc(char **svec) +{ + pid_t pid; + int ret; + char real_filename[PATH_MAX + 1]; + /* Make sure output generated so far are flushed */ + fflush(stdout); + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, svec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; +} + +/* Types used to create list of all exported symbols in a number of files */ +struct symbols +{ + char *name; +}; + +struct symfile +{ + char *filename; + struct symbols *symbollist; + int symbolcnt; +}; + +struct symfile symfilelist[MAXFILES]; +int symfilecnt = 0; + +static void add_new_symbol(struct symfile *sym, char * symname) +{ + sym->symbollist = + realloc(sym->symbollist, (sym->symbolcnt + 1) * sizeof(char *)); + sym->symbollist[sym->symbolcnt++].name = strdup(symname); +} + +/* Add a filename to the list */ +static struct symfile * add_new_file(char * filename) +{ + symfilelist[symfilecnt++].filename = strdup(filename); + return &symfilelist[symfilecnt - 1]; +} + +/* Check if file already are present in the list */ +static struct symfile * filename_exist(char * filename) +{ + int i; + for (i=0; i < symfilecnt; i++) + if (strcmp(symfilelist[i].filename, filename) == 0) + return &symfilelist[i]; + return NULL; +} + +/* + * List all files referenced within the template file. + * Files are separated by tabs. + */ +static void adddep(char * file) { printf("\t%s", file); } +static void adddep2(char * file, char * line) { line = line; adddep(file); } +static void noaction(char * line) { line = line; } +static void noaction2(char * file, char * line) { file = file; line = line; } + +/* Echo the line without further action */ +static void printline(char * line) { printf("%s", line); } + +/* + * Find all symbols in filename that are exported with EXPORT_SYMBOL & + * EXPORT_SYMBOL_GPL (& EXPORT_SYMBOL_GPL_FUTURE implicitly). + * All symbols located are stored in symfilelist. + */ +static void find_export_symbols(char * filename) +{ + FILE * fp; + struct symfile *sym; + char line[MAXLINESZ]; + if (filename_exist(filename) == NULL) { + char real_filename[PATH_MAX + 1]; + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, srctree, PATH_MAX); + strncat(real_filename, "/", PATH_MAX - strlen(real_filename)); + strncat(real_filename, filename, + PATH_MAX - strlen(real_filename)); + sym = add_new_file(filename); + fp = fopen(real_filename, "r"); + if (fp == NULL) { + fprintf(stderr, "docproc: "); + perror(real_filename); + exit(1); + } + while (fgets(line, MAXLINESZ, fp)) { + char *p; + char *e; + if (((p = strstr(line, "EXPORT_SYMBOL_GPL")) != NULL) || + ((p = strstr(line, "EXPORT_SYMBOL")) != NULL)) { + /* Skip EXPORT_SYMBOL{_GPL} */ + while (isalnum(*p) || *p == '_') + p++; + /* Remove parentheses & additional whitespace */ + while (isspace(*p)) + p++; + if (*p != '(') + continue; /* Syntax error? */ + else + p++; + while (isspace(*p)) + p++; + e = p; + while (isalnum(*e) || *e == '_') + e++; + *e = '\0'; + add_new_symbol(sym, p); + } + } + fclose(fp); + } +} + +/* + * Document all external or internal functions in a file. + * Call kernel-doc with following parameters: + * kernel-doc -docbook -nofunction function_name1 filename + * Function names are obtained from all the src files + * by find_export_symbols. + * intfunc uses -nofunction + * extfunc uses -function + */ +static void docfunctions(char * filename, char * type) +{ + int i,j; + int symcnt = 0; + int idx = 0; + char **vec; + + for (i=0; i <= symfilecnt; i++) + symcnt += symfilelist[i].symbolcnt; + vec = malloc((2 + 2 * symcnt + 3) * sizeof(char *)); + if (vec == NULL) { + perror("docproc: "); + exit(1); + } + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + vec[idx++] = NODOCSECTIONS; + for (i=0; i < symfilecnt; i++) { + struct symfile * sym = &symfilelist[i]; + for (j=0; j < sym->symbolcnt; j++) { + vec[idx++] = type; + consume_symbol(sym->symbollist[j].name); + vec[idx++] = sym->symbollist[j].name; + } + } + vec[idx++] = filename; + vec[idx] = NULL; + printf("<!-- %s -->\n", filename); + exec_kernel_doc(vec); + fflush(stdout); + free(vec); +} +static void intfunc(char * filename) { docfunctions(filename, NOFUNCTION); } +static void extfunc(char * filename) { docfunctions(filename, FUNCTION); } + +/* + * Document specific function(s) in a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function function1 [-function function2] + */ +static void singfunc(char * filename, char * line) +{ + char *vec[200]; /* Enough for specific functions */ + int i, idx = 0; + int startofsym = 1; + vec[idx++] = KERNELDOC; + vec[idx++] = DOCBOOK; + + /* Split line up in individual parameters preceded by FUNCTION */ + for (i=0; line[i]; i++) { + if (isspace(line[i])) { + line[i] = '\0'; + startofsym = 1; + continue; + } + if (startofsym) { + startofsym = 0; + vec[idx++] = FUNCTION; + vec[idx++] = &line[i]; + } + } + for (i = 0; i < idx; i++) { + if (strcmp(vec[i], FUNCTION)) + continue; + consume_symbol(vec[i + 1]); + } + vec[idx++] = filename; + vec[idx] = NULL; + exec_kernel_doc(vec); +} + +/* + * Insert specific documentation section from a file. + * Call kernel-doc with the following parameters: + * kernel-doc -docbook -function "doc section" filename + */ +static void docsect(char *filename, char *line) +{ + char *vec[6]; /* kerneldoc -docbook -function "section" file NULL */ + char *s; + + for (s = line; *s; s++) + if (*s == '\n') + *s = '\0'; + + if (asprintf(&s, "DOC: %s", line) < 0) { + perror("asprintf"); + exit(1); + } + consume_symbol(s); + free(s); + + vec[0] = KERNELDOC; + vec[1] = DOCBOOK; + vec[2] = FUNCTION; + vec[3] = line; + vec[4] = filename; + vec[5] = NULL; + exec_kernel_doc(vec); +} + +static void find_all_symbols(char *filename) +{ + char *vec[4]; /* kerneldoc -list file NULL */ + pid_t pid; + int ret, i, count, start; + char real_filename[PATH_MAX + 1]; + int pipefd[2]; + char *data, *str; + size_t data_len = 0; + + vec[0] = KERNELDOC; + vec[1] = LIST; + vec[2] = filename; + vec[3] = NULL; + + if (pipe(pipefd)) { + perror("pipe"); + exit(1); + } + + switch (pid=fork()) { + case -1: + perror("fork"); + exit(1); + case 0: + close(pipefd[0]); + dup2(pipefd[1], 1); + memset(real_filename, 0, sizeof(real_filename)); + strncat(real_filename, kernsrctree, PATH_MAX); + strncat(real_filename, "/" KERNELDOCPATH KERNELDOC, + PATH_MAX - strlen(real_filename)); + execvp(real_filename, vec); + fprintf(stderr, "exec "); + perror(real_filename); + exit(1); + default: + close(pipefd[1]); + data = malloc(4096); + do { + while ((ret = read(pipefd[0], + data + data_len, + 4096)) > 0) { + data_len += ret; + data = realloc(data, data_len + 4096); + } + } while (ret == -EAGAIN); + if (ret != 0) { + perror("read"); + exit(1); + } + waitpid(pid, &ret ,0); + } + if (WIFEXITED(ret)) + exitstatus |= WEXITSTATUS(ret); + else + exitstatus = 0xff; + + count = 0; + /* poor man's strtok, but with counting */ + for (i = 0; i < data_len; i++) { + if (data[i] == '\n') { + count++; + data[i] = '\0'; + } + } + start = all_list_len; + all_list_len += count; + all_list = realloc(all_list, sizeof(char *) * all_list_len); + str = data; + for (i = 0; i < data_len && start != all_list_len; i++) { + if (data[i] == '\0') { + all_list[start] = str; + str = data + i + 1; + start++; + } + } +} + +/* + * Parse file, calling action specific functions for: + * 1) Lines containing !E + * 2) Lines containing !I + * 3) Lines containing !D + * 4) Lines containing !F + * 5) Lines containing !P + * 6) Lines containing !C + * 7) Default lines - lines not matching the above + */ +static void parse_file(FILE *infile) +{ + char line[MAXLINESZ]; + char * s; + while (fgets(line, MAXLINESZ, infile)) { + if (line[0] == '!') { + s = line + 2; + switch (line[1]) { + case 'E': + while (*s && !isspace(*s)) s++; + *s = '\0'; + externalfunctions(line+2); + break; + case 'I': + while (*s && !isspace(*s)) s++; + *s = '\0'; + internalfunctions(line+2); + break; + case 'D': + while (*s && !isspace(*s)) s++; + *s = '\0'; + symbolsonly(line+2); + break; + case 'F': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* function names */ + while (isspace(*s)) + s++; + singlefunctions(line +2, s); + break; + case 'P': + /* filename */ + while (*s && !isspace(*s)) s++; + *s++ = '\0'; + /* DOC: section name */ + while (isspace(*s)) + s++; + docsection(line + 2, s); + break; + case 'C': + while (*s && !isspace(*s)) s++; + *s = '\0'; + if (findall) + findall(line+2); + break; + default: + defaultline(line); + } + } else { + defaultline(line); + } + } + fflush(stdout); +} + + +int main(int argc, char *argv[]) +{ + FILE * infile; + int i; + + srctree = getenv("SRCTREE"); + if (!srctree) + srctree = getcwd(NULL, 0); + kernsrctree = getenv("KBUILD_SRC"); + if (!kernsrctree || !*kernsrctree) + kernsrctree = srctree; + if (argc != 3) { + usage(); + exit(1); + } + /* Open file, exit on error */ + infile = fopen(argv[2], "r"); + if (infile == NULL) { + fprintf(stderr, "docproc: "); + perror(argv[2]); + exit(2); + } + + if (strcmp("doc", argv[1]) == 0) { + /* Need to do this in two passes. + * First pass is used to collect all symbols exported + * in the various files; + * Second pass generate the documentation. + * This is required because some functions are declared + * and exported in different files :-(( + */ + /* Collect symbols */ + defaultline = noaction; + internalfunctions = find_export_symbols; + externalfunctions = find_export_symbols; + symbolsonly = find_export_symbols; + singlefunctions = noaction2; + docsection = noaction2; + findall = find_all_symbols; + parse_file(infile); + + /* Rewind to start from beginning of file again */ + fseek(infile, 0, SEEK_SET); + defaultline = printline; + internalfunctions = intfunc; + externalfunctions = extfunc; + symbolsonly = printline; + singlefunctions = singfunc; + docsection = docsect; + findall = NULL; + + parse_file(infile); + + for (i = 0; i < all_list_len; i++) { + if (!all_list[i]) + continue; + fprintf(stderr, "Warning: didn't use docs for %s\n", + all_list[i]); + } + } else if (strcmp("depend", argv[1]) == 0) { + /* Create first part of dependency chain + * file.tmpl */ + printf("%s\t", argv[2]); + defaultline = noaction; + internalfunctions = adddep; + externalfunctions = adddep; + symbolsonly = adddep; + singlefunctions = adddep2; + docsection = adddep2; + findall = adddep; + parse_file(infile); + printf("\n"); + } else { + fprintf(stderr, "Unknown option: %s\n", argv[1]); + exit(1); + } + fclose(infile); + fflush(stdout); + return exitstatus; +} diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc new file mode 100755 index 0000000..8848efd --- /dev/null +++ b/tools/kernel-doc/kernel-doc @@ -0,0 +1,2554 @@ +#!/usr/bin/perl -w + +use strict; + +## Copyright (c) 1998 Michael Zucchi, All Rights Reserved ## +## Copyright (C) 2000, 1 Tim Waugh twaugh@redhat.com ## +## Copyright (C) 2001 Simon Huggins ## +## Copyright (C) 2005-2012 Randy Dunlap ## +## Copyright (C) 2012 Dan Luedtke ## +## ## +## #define enhancements by Armin Kuster akuster@mvista.com ## +## Copyright (c) 2000 MontaVista Software, Inc. ## +## ## +## This software falls under the GNU General Public License. ## +## Please read the COPYING file for more information ## + +# 18/01/2001 - Cleanups +# Functions prototyped as foo(void) same as foo() +# Stop eval'ing where we don't need to. +# -- huggie@earth.li + +# 27/06/2001 - Allowed whitespace after initial "/**" and +# allowed comments before function declarations. +# -- Christian Kreibich ck@whoop.org + +# Still to do: +# - add perldoc documentation +# - Look more closely at some of the scarier bits :) + +# 26/05/2001 - Support for separate source and object trees. +# Return error code. +# Keith Owens kaos@ocs.com.au + +# 23/09/2001 - Added support for typedefs, structs, enums and unions +# Support for Context section; can be terminated using empty line +# Small fixes (like spaces vs. \s in regex) +# -- Tim Jansen tim@tjansen.de + +# 25/07/2012 - Added support for HTML5 +# -- Dan Luedtke mail@danrl.de + +# +# This will read a 'c' file and scan for embedded comments in the +# style of gnome comments (+minor extensions - see below). +# + +# Note: This only supports 'c'. + +# usage: +# kernel-doc [ -docbook | -html | -html5 | -text | -man | -list ] +# [ -no-doc-sections ] +# [ -function funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# or +# [ -nofunction funcname [ -function funcname ...] ] +# c file(s)s > outputfile +# +# Set output format using one of -docbook -html -html5 -text or -man. +# Default is man. +# The -list format is for internal use by docproc. +# +# -no-doc-sections +# Do not output DOC: sections +# +# -function funcname +# If set, then only generate documentation for the given function(s) or +# DOC: section titles. All other functions and DOC: sections are ignored. +# +# -nofunction funcname +# If set, then only generate documentation for the other function(s)/DOC: +# sections. Cannot be used together with -function (yes, that's a bug -- +# perl hackers can fix it 8)) +# +# c files - list of 'c' files to process +# +# All output goes to stdout, with errors to stderr. + +# +# format of comments. +# In the following table, (...)? signifies optional structure. +# (...)* signifies 0 or more structure elements +# /** +# * function_name(:)? (- short description)? +# (* @parameterx: (description of parameter x)?)* +# (* a blank line)? +# * (Description:)? (Description of function)? +# * (section header: (section description)? )* +# (*)?*/ +# +# So .. the trivial example would be: +# +# /** +# * my_function +# */ +# +# If the Description: header tag is omitted, then there must be a blank line +# after the last parameter specification. +# e.g. +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * +# * Does my stuff explained. +# */ +# +# or, could also use: +# /** +# * my_function - does my stuff +# * @my_arg: its mine damnit +# * Description: Does my stuff explained. +# */ +# etc. +# +# Besides functions you can also write documentation for structs, unions, +# enums and typedefs. Instead of the function name you must write the name +# of the declaration; the struct/union/enum/typedef must always precede +# the name. Nesting of declarations is not supported. +# Use the argument mechanism to document members or constants. +# e.g. +# /** +# * struct my_struct - short description +# * @a: first member +# * @b: second member +# * +# * Longer description +# */ +# struct my_struct { +# int a; +# int b; +# /* private: */ +# int c; +# }; +# +# All descriptions can be multiline, except the short function description. +# +# You can also add additional sections. When documenting kernel functions you +# should document the "Context:" of the function, e.g. whether the functions +# can be called form interrupts. Unlike other sections you can end it with an +# empty line. +# Example-sections should contain the string EXAMPLE so that they are marked +# appropriately in DocBook. +# +# Example: +# /** +# * user_function - function that can only be called in user context +# * @a: some argument +# * Context: !in_interrupt() +# * +# * Some description +# * Example: +# * user_function(22); +# */ +# ... +# +# +# All descriptive text is further processed, scanning for the following special +# patterns, which are highlighted appropriately. +# +# 'funcname()' - function +# '$ENVVAR' - environmental variable +# '&struct_name' - name of a structure (up to two words including 'struct') +# '@parameter' - name of a parameter +# '%CONST' - name of a constant. + +## init lots of data + +my $errors = 0; +my $warnings = 0; +my $anon_struct_union = 0; + +# match expressions used to find embedded type information +my $type_constant = '%([-_\w]+)'; +my $type_func = '(\w+)()'; +my $type_param = '@(\w+)'; +my $type_struct = '&((struct\s*)*[_\w]+)'; +my $type_struct_xml = '\&((struct\s*)*[_\w]+)'; +my $type_env = '($\w+)'; + +# Output conversion substitutions. +# One for each output format + +# these work fairly well +my %highlights_html = ( $type_constant, "<i>$1</i>", + $type_func, "<b>$1</b>", + $type_struct_xml, "<i>$1</i>", + $type_env, "<b><i>$1</i></b>", + $type_param, "<tt><b>$1</b></tt>" ); +my $local_lt = "\\\\lt:"; +my $local_gt = "\\\\gt:"; +my $blankline_html = $local_lt . "p" . $local_gt; # was "<p>" + +# html version 5 +my %highlights_html5 = ( $type_constant, "<span class="const">$1</span>", + $type_func, "<span class="func">$1</span>", + $type_struct_xml, "<span class="struct">$1</span>", + $type_env, "<span class="env">$1</span>", + $type_param, "<span class="param">$1</span>" ); +my $blankline_html5 = $local_lt . "br /" . $local_gt; + +# XML, docbook format +my %highlights_xml = ( "([^=])\"([^\"<]+)\"", "$1<quote>$2</quote>", + $type_constant, "<constant>$1</constant>", + $type_func, "<function>$1</function>", + $type_struct_xml, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_xml = $local_lt . "/para" . $local_gt . $local_lt . "para" . $local_gt . "\n"; + +# gnome, docbook format +my %highlights_gnome = ( $type_constant, "<replaceable class="option">$1</replaceable>", + $type_func, "<function>$1</function>", + $type_struct, "<structname>$1</structname>", + $type_env, "<envar>$1</envar>", + $type_param, "<parameter>$1</parameter>" ); +my $blankline_gnome = "</para><para>\n"; + +# these are pretty rough +my %highlights_man = ( $type_constant, "$1", + $type_func, "\\fB$1\\fP", + $type_struct, "\\fI$1\\fP", + $type_param, "\\fI$1\\fP" ); +my $blankline_man = ""; + +# text-mode +my %highlights_text = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_text = ""; + +# list mode +my %highlights_list = ( $type_constant, "$1", + $type_func, "$1", + $type_struct, "$1", + $type_param, "$1" ); +my $blankline_list = ""; + +# read arguments +if ($#ARGV == -1) { + usage(); +} + +my $kernelversion; +my $dohighlight = ""; + +my $verbose = 0; +my $output_mode = "man"; +my $no_doc_sections = 0; +my %highlights = %highlights_man; +my $blankline = $blankline_man; +my $modulename = "Bootloader API"; +my $function_only = 0; +my $man_date = ('January', 'February', 'March', 'April', 'May', 'June', + 'July', 'August', 'September', 'October', + 'November', 'December')[(localtime)[4]] . + " " . ((localtime)[5]+1900); + +# Essentially these are globals. +# They probably want to be tidied up, made more localised or something. +# CAVEAT EMPTOR! Some of the others I localised may not want to be, which +# could cause "use of undefined value" or other bugs. +my ($function, %function_table, %parametertypes, $declaration_purpose); +my ($type, $declaration_name, $return_type); +my ($newsection, $newcontents, $prototype, $brcount, %source_map); + +if (defined($ENV{'KBUILD_VERBOSE'})) { + $verbose = "$ENV{'KBUILD_VERBOSE'}"; +} + +# Generated docbook code is inserted in a template at a point where +# docbook v3.1 requires a non-zero sequence of RefEntry's; see: +# http://www.oasis-open.org/docbook/documentation/reference/html/refentry.html +# We keep track of number of generated entries and generate a dummy +# if needs be to ensure the expanded template can be postprocessed +# into html. +my $section_counter = 0; + +my $lineprefix=""; + +# states +# 0 - normal code +# 1 - looking for function name +# 2 - scanning field start. +# 3 - scanning prototype. +# 4 - documentation block +my $state; +my $in_doc_sect; + +#declaration types: can be +# 'function', 'struct', 'union', 'enum', 'typedef' +my $decl_type; + +my $doc_special = "@%$&"; + +my $doc_start = '^/**\s*$'; # Allow whitespace at end of comment start. +my $doc_end = '*/'; +my $doc_com = '\s**\s*'; +my $doc_decl = $doc_com . '(\w+)'; +my $doc_sect = $doc_com . '([' . $doc_special . ']?[\w\s]+):(.*)'; +my $doc_content = $doc_com . '(.*)'; +my $doc_block = $doc_com . 'DOC:\s*(.*)?'; + +my %constants; +my %parameterdescs; +my @parameterlist; +my %sections; +my @sectionlist; +my $sectcheck; +my $struct_actual; + +my $contents = ""; +my $section_default = "Description"; # default section +my $section_intro = "Introduction"; +my $section = $section_default; +my $section_context = "Context"; + +my $undescribed = "-- undescribed --"; + +reset_state(); + +while ($ARGV[0] =~ m/^-(.*)/) { + my $cmd = shift @ARGV; + if ($cmd eq "-html") { + $output_mode = "html"; + %highlights = %highlights_html; + $blankline = $blankline_html; + } elsif ($cmd eq "-html5") { + $output_mode = "html5"; + %highlights = %highlights_html5; + $blankline = $blankline_html5; + } elsif ($cmd eq "-man") { + $output_mode = "man"; + %highlights = %highlights_man; + $blankline = $blankline_man; + } elsif ($cmd eq "-text") { + $output_mode = "text"; + %highlights = %highlights_text; + $blankline = $blankline_text; + } elsif ($cmd eq "-docbook") { + $output_mode = "xml"; + %highlights = %highlights_xml; + $blankline = $blankline_xml; + } elsif ($cmd eq "-list") { + $output_mode = "list"; + %highlights = %highlights_list; + $blankline = $blankline_list; + } elsif ($cmd eq "-gnome") { + $output_mode = "gnome"; + %highlights = %highlights_gnome; + $blankline = $blankline_gnome; + } elsif ($cmd eq "-module") { # not needed for XML, inherits from calling document + $modulename = shift @ARGV; + } elsif ($cmd eq "-function") { # to only output specific functions + $function_only = 1; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-nofunction") { # to only output specific functions + $function_only = 2; + $function = shift @ARGV; + $function_table{$function} = 1; + } elsif ($cmd eq "-v") { + $verbose = 1; + } elsif (($cmd eq "-h") || ($cmd eq "--help")) { + usage(); + } elsif ($cmd eq '-no-doc-sections') { + $no_doc_sections = 1; + } +} + +# continue execution near EOF; + +sub usage { + print "Usage: $0 [ -docbook | -html | -html5 | -text | -man | -list ]\n"; + print " [ -no-doc-sections ]\n"; + print " [ -function funcname [ -function funcname ...] ]\n"; + print " [ -nofunction funcname [ -nofunction funcname ...] ]\n"; + print " [ -v ]\n"; + print " c source file(s) > outputfile\n"; + print " -v : verbose output, more warnings & other info listed\n"; + exit 1; +} + +# get kernel version from env +sub get_kernel_version() { + my $version = 'unknown kernel version'; + + if (defined($ENV{'U_BOOT_VERSION'})) { + $version = $ENV{'U_BOOT_VERSION'}; + } + return $version; +} + +## +# dumps section contents to arrays/hashes intended for that purpose. +# +sub dump_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($name =~ m/$type_constant/) { + $name = $1; +# print STDERR "constant section '$1' = '$contents'\n"; + $constants{$name} = $contents; + } elsif ($name =~ m/$type_param/) { +# print STDERR "parameter def '$1' = '$contents'\n"; + $name = $1; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } elsif ($name eq "@...") { +# print STDERR "parameter def '...' = '$contents'\n"; + $name = "..."; + $parameterdescs{$name} = $contents; + $sectcheck = $sectcheck . $name . " "; + } else { +# print STDERR "other section '$name' = '$contents'\n"; + if (defined($sections{$name}) && ($sections{$name} ne "")) { + print STDERR "Error(${file}:$.): duplicate section name '$name'\n"; + ++$errors; + } + $sections{$name} = $contents; + push @sectionlist, $name; + } +} + +## +# dump DOC: section after checking that it should go out +# +sub dump_doc_section { + my $file = shift; + my $name = shift; + my $contents = join "\n", @_; + + if ($no_doc_sections) { + return; + } + + if (($function_only == 0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + dump_section($file, $name, $contents); + output_blockhead({'sectionlist' => @sectionlist, + 'sections' => %sections, + 'module' => $modulename, + 'content-only' => ($function_only != 0), }); + } +} + +## +# output function +# +# parameterdescs, a hash. +# function => "function name" +# parameterlist => @list of parameters +# parameterdescs => %parameter descriptions +# sectionlist => @list of sections +# sections => %section descriptions +# + +sub output_highlight { + my $contents = join "\n",@_; + my $line; + +# DEBUG +# if (!defined $contents) { +# use Carp; +# confess "output_highlight got called with no args?\n"; +# } + + if ($output_mode eq "html" || $output_mode eq "html5" || + $output_mode eq "xml") { + $contents = local_unescape($contents); + # convert data read & converted thru xml_escape() into &xyz; format: + $contents =~ s/\\\/&/g; + } +# print STDERR "contents b4:$contents\n"; + eval $dohighlight; + die $@ if $@; +# print STDERR "contents af:$contents\n"; + +# strip whitespaces when generating html5 + if ($output_mode eq "html5") { + $contents =~ s/^\s+//; + $contents =~ s/\s+$//; + } + foreach $line (split "\n", $contents) { + if ($line eq ""){ + print $lineprefix, local_unescape($blankline); + } else { + $line =~ s/\\\/&/g; + if ($output_mode eq "man" && substr($line, 0, 1) eq ".") { + print "\&$line"; + } else { + print $lineprefix, $line; + } + } + print "\n"; + } +} + +# output sections in html +sub output_section_html(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<blockquote>\n"; + output_highlight($args{'sections'}{$section}); + print "</blockquote>\n"; + } +} + +# output enum in html +sub output_enum_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>enum " . $args{'enum'} . "</h2>\n"; + + print "<b>enum " . $args{'enum'} . "</b> {<br>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " <b>" . $parameter . "</b>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + print "<br>"; + } + print "};<br>\n"; + + print "<h3>Constants</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output typedef in html +sub output_typedef_html(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "<h2>typedef " . $args{'typedef'} . "</h2>\n"; + + print "<b>typedef " . $args{'typedef'} . "</b>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output struct in html +sub output_struct_html(%) { + my %args = %{$_[0]}; + my ($parameter); + + print "<h2>" . $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<b>" . $args{'type'} . " " . $args{'struct'} . "</b> {<br>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter<br>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <i>$1</i><b>$parameter</b>) <i>($2)</i>;<br>\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " <i>$1</i> <b>$parameter</b>$2;<br>\n"; + } else { + print " <i>$type</i> <b>$parameter</b>;<br>\n"; + } + } + print "};<br>\n"; + + print "<h3>Members</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output function in html +sub output_function_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print "<h2>" . $args{'function'} . " - " . $args{'purpose'} . "</h2>\n"; + print "<i>" . $args{'functiontype'} . "</i>\n"; + print "<b>" . $args{'function'} . "</b>\n"; + print "("; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<i>$1</i><b>$parameter</b>) <i>($2)</i>"; + } else { + print "<i>" . $type . "</i> <b>" . $parameter . "</b>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + } + } + print ")\n"; + + print "<h3>Arguments</h3>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt><b>" . $parameter . "</b>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + print "</dl>\n"; + output_section_html(@_); + print "<hr>\n"; +} + +# output DOC: block header in html +sub output_blockhead_html(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + foreach $section (@{$args{'sectionlist'}}) { + print "<h3>$section</h3>\n"; + print "<ul>\n"; + output_highlight($args{'sections'}{$section}); + print "</ul>\n"; + } + print "<hr>\n"; +} + +# output sections in html5 +sub output_section_html5(%) { + my %args = %{$_[0]}; + my $section; + + foreach $section (@{$args{'sectionlist'}}) { + print "<section>\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + print "</section>\n"; + } +} + +# output enum in html5 +sub output_enum_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'enum'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="enum" id="enum:". $html5id . "">"; + print "<h1>enum " . $args{'enum'} . "</h1>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">enum</span> "; + print "<span class="identifier">" . $args{'enum'} . "</span> {"; + print "</li>\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + print "<span class="param">" . $parameter . "</span>"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Constants</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output typedef in html5 +sub output_typedef_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + my $html5id; + + $html5id = $args{'typedef'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="typedef" id="typedef:" . $html5id . "">\n"; + print "<h1>typedef " . $args{'typedef'} . "</h1>\n"; + + print "<ol class="code">\n"; + print "<li>"; + print "<span class="keyword">typedef</span> "; + print "<span class="identifier">" . $args{'typedef'} . "</span>"; + print "</li>\n"; + print "</ol>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output struct in html5 +sub output_struct_html5(%) { + my %args = %{$_[0]}; + my ($parameter); + my $html5id; + + $html5id = $args{'struct'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="struct" id="struct:" . $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'type'} . " " . $args{'struct'} . "</h1>"; + print "<h2>". $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'type'} . "</span> "; + print "<span class="identifier">" . $args{'struct'} . "</span> {"; + print "</li>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + if ($parameter =~ /^#/) { + print "<span class="param">" . $parameter ."</span>\n"; + print "</li>\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>);"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="bits">$2</span>;"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>;"; + } + print "</li>\n"; + } + print "<li>};</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Members</h1>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output function in html5 +sub output_function_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + $html5id = $args{'function'}; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="function" id="func:". $html5id . "">\n"; + print "<hgroup>\n"; + print "<h1>" . $args{'function'} . "</h1>"; + print "<h2>" . $args{'purpose'} . "</h2>\n"; + print "</hgroup>\n"; + print "<ol class="code">\n"; + print "<li>"; + print "<span class="type">" . $args{'functiontype'} . "</span> "; + print "<span class="identifier">" . $args{'function'} . "</span> ("; + print "</li>"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "<li class="indent">"; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "<span class="type">$1</span> "; + print "<span class="param">$parameter</span>"; + print "<span class="type">)</span> "; + print "(<span class="args">$2</span>)"; + } else { + print "<span class="type">$type</span> "; + print "<span class="param">$parameter</span>"; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "</li>\n"; + } + print "<li>)</li>\n"; + print "</ol>\n"; + + print "<section>\n"; + print "<h1>Arguments</h1>\n"; + print "<p>\n"; + print "<dl>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "<dt>" . $parameter . "</dt>\n"; + print "<dd>"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print "</dd>\n"; + } + print "</dl>\n"; + print "</section>\n"; + output_section_html5(@_); + print "</article>\n"; +} + +# output DOC: block header in html5 +sub output_blockhead_html5(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $html5id; + + foreach $section (@{$args{'sectionlist'}}) { + $html5id = $section; + $html5id =~ s/[^a-zA-Z0-9-]+/_/g; + print "<article class="doc" id="doc:". $html5id . "">\n"; + print "<h1>$section</h1>\n"; + print "<p>\n"; + output_highlight($args{'sections'}{$section}); + print "</p>\n"; + } + print "</article>\n"; +} + +sub output_section_xml(%) { + my %args = %{$_[0]}; + my $section; + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<refsect1>\n"; + print "<title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<informalexample><programlisting>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></informalexample>\n"; + } else { + print "</para>\n"; + } + print "</refsect1>\n"; + } +} + +# output function in XML DocBook +sub output_function_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'function'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'function'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <funcsynopsis><funcprototype>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " </function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1<parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void/>\n"; + } + print " </funcprototype></funcsynopsis>\n"; + print "</refsynopsisdiv>\n"; + + # print parameters + print "<refsect1>\n <title>Arguments</title>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>\n <term><parameter>$parameter</parameter></term>\n"; + print " <listitem>\n <para>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para>\n </listitem>\n </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print "</refsect1>\n"; + + output_section_xml(@_); + print "</refentry>\n\n"; +} + +# output struct in XML DocBook +sub output_struct_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-struct-" . $args{'struct'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>" . $args{'type'} . " " . $args{'struct'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>" . $args{'type'} . " " . $args{'struct'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + my $prm = $parameter; + # convert data read & converted thru xml_escape() into &xyz; format: + # This allows us to have #define macros interspersed in a struct. + $prm =~ s/\\\/&/g; + print "$prm\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " $1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print " $1 $parameter$2;\n"; + } else { + print " " . $type . " " . $parameter . ";\n"; + } + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print " <refsect1>\n"; + print " <title>Members</title>\n"; + + if ($#{$args{'parameterlist'}} >= 0) { + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + defined($args{'parameterdescs'}{$parameter_name}) || next; + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + print " </refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output enum in XML DocBook +sub output_enum_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = "API-enum-" . $args{'enum'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>enum " . $args{'enum'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print " <refmiscinfo class="version">" . $kernelversion . "</refmiscinfo>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>enum " . $args{'enum'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <programlisting>\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print " $parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};"; + print " </programlisting>\n"; + print "</refsynopsisdiv>\n"; + + print "<refsect1>\n"; + print " <title>Constants</title>\n"; + print " <variablelist>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <varlistentry>"; + print " <term>$parameter</term>\n"; + print " <listitem><para>\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </para></listitem>\n"; + print " </varlistentry>\n"; + } + print " </variablelist>\n"; + print "</refsect1>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output typedef in XML DocBook +sub output_typedef_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $id; + + $id = "API-typedef-" . $args{'typedef'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<refentry id="$id">\n"; + print "<refentryinfo>\n"; + print " <title>U-BOOT</title>\n"; + print " <productname>Bootloader Hackers Manual</productname>\n"; + print " <date>$man_date</date>\n"; + print "</refentryinfo>\n"; + print "<refmeta>\n"; + print " <refentrytitle><phrase>typedef " . $args{'typedef'} . "</phrase></refentrytitle>\n"; + print " <manvolnum>9</manvolnum>\n"; + print "</refmeta>\n"; + print "<refnamediv>\n"; + print " <refname>typedef " . $args{'typedef'} . "</refname>\n"; + print " <refpurpose>\n"; + print " "; + output_highlight ($args{'purpose'}); + print " </refpurpose>\n"; + print "</refnamediv>\n"; + + print "<refsynopsisdiv>\n"; + print " <title>Synopsis</title>\n"; + print " <synopsis>typedef " . $args{'typedef'} . ";</synopsis>\n"; + print "</refsynopsisdiv>\n"; + + output_section_xml(@_); + + print "</refentry>\n\n"; +} + +# output in XML DocBook +sub output_blockhead_xml(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + my $id = $args{'module'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + if (!$args{'content-only'}) { + print "<refsect1>\n <title>$section</title>\n"; + } + if ($section =~ m/EXAMPLE/i) { + print "<example><para>\n"; + } else { + print "<para>\n"; + } + output_highlight($args{'sections'}{$section}); + if ($section =~ m/EXAMPLE/i) { + print "</para></example>\n"; + } else { + print "</para>"; + } + if (!$args{'content-only'}) { + print "\n</refsect1>\n"; + } + } + + print "\n\n"; +} + +# output in XML DocBook +sub output_function_gnome { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + my $id; + + $id = $args{'module'} . "-" . $args{'function'}; + $id =~ s/[^A-Za-z0-9]/-/g; + + print "<sect2>\n"; + print " <title id="$id">" . $args{'function'} . "</title>\n"; + + print " <funcsynopsis>\n"; + print " <funcdef>" . $args{'functiontype'} . " "; + print "<function>" . $args{'function'} . " "; + print "</function></funcdef>\n"; + + $count = 0; + if ($#{$args{'parameterlist'}} >= 0) { + foreach $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print " <paramdef>$1 <parameter>$parameter</parameter>)\n"; + print " <funcparams>$2</funcparams></paramdef>\n"; + } else { + print " <paramdef>" . $type; + print " <parameter>$parameter</parameter></paramdef>\n"; + } + } + } else { + print " <void>\n"; + } + print " </funcsynopsis>\n"; + if ($#{$args{'parameterlist'}} >= 0) { + print " <informaltable pgwide="1" frame="none" role="params">\n"; + print "<tgroup cols="2">\n"; + print "<colspec colwidth="2*">\n"; + print "<colspec colwidth="8*">\n"; + print "<tbody>\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print " <row><entry align="right"><parameter>$parameter</parameter></entry>\n"; + print " <entry>\n"; + $lineprefix=" "; + output_highlight($args{'parameterdescs'}{$parameter_name}); + print " </entry></row>\n"; + } + print " </tbody></tgroup></informaltable>\n"; + } else { + print " <para>\n None\n </para>\n"; + } + + # print out each section + $lineprefix=" "; + foreach $section (@{$args{'sectionlist'}}) { + print "<simplesect>\n <title>$section</title>\n"; + if ($section =~ m/EXAMPLE/i) { + print "<example><programlisting>\n"; + } else { + } + print "<para>\n"; + output_highlight($args{'sections'}{$section}); + print "</para>\n"; + if ($section =~ m/EXAMPLE/i) { + print "</programlisting></example>\n"; + } else { + } + print " </simplesect>\n"; + } + + print "</sect2>\n\n"; +} + +## +# output function in man +sub output_function_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'function'}" 9 "$args{'function'}" "$man_date" "Bootloader Hacker's Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'function'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + if ($args{'functiontype'} ne "") { + print ".B "" . $args{'functiontype'} . "" " . $args{'function'} . "\n"; + } else { + print ".B "" . $args{'function'} . "\n"; + } + $count = 0; + my $parenth = "("; + my $post = ","; + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($count == $#{$args{'parameterlist'}}) { + $post = ");"; + } + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI "" . $parenth . $1 . "" " . $parameter . " ") (" . $2 . ")" . $post . ""\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI "" . $parenth . $type . "" " . $parameter . " "" . $post . ""\n"; + } + $count++; + $parenth = ""; + } + + print ".SH ARGUMENTS\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "", uc $section, ""\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output enum in man +sub output_enum_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "enum $args{'enum'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "enum " . $args{'enum'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + print ".br\n.BI " $parameter"\n"; + if ($count == $#{$args{'parameterlist'}}) { + print "\n};\n"; + last; + } + else { + print ", \n.br\n"; + } + $count++; + } + + print ".SH Constants\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output struct in man +sub output_struct_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "" . $args{'type'} . " " . $args{'struct'} . "" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print $args{'type'} . " " . $args{'struct'} . " \- " . $args{'purpose'} . "\n"; + + print ".SH SYNOPSIS\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n.br\n"; + + foreach my $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print ".BI "$parameter"\n.br\n"; + next; + } + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print ".BI " " . $1 . "" " . $parameter . " ") (" . $2 . ")" . ""\n;\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print ".BI " " . $1 . "\ " " . $parameter . $2 . " "" . ""\n;\n"; + } else { + $type =~ s/([^*])$/$1 /; + print ".BI " " . $type . "" " . $parameter . " "" . ""\n;\n"; + } + print "\n.br\n"; + } + print "};\n.br\n"; + + print ".SH Members\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print ".IP "" . $parameter . "" 12\n"; + output_highlight($args{'parameterdescs'}{$parameter_name}); + } + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output typedef in man +sub output_typedef_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + print ".TH "$args{'module'}" 9 "$args{'typedef'}" "$man_date" "API Manual" U-BOOT\n"; + + print ".SH NAME\n"; + print "typedef " . $args{'typedef'} . " \- " . $args{'purpose'} . "\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +sub output_blockhead_man(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $count; + + print ".TH "$args{'module'}" 9 "$args{'module'}" "$man_date" "API Manual" U-BOOT\n"; + + foreach $section (@{$args{'sectionlist'}}) { + print ".SH "$section"\n"; + output_highlight($args{'sections'}{$section}); + } +} + +## +# output in text +sub output_function_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + my $start; + + print "Name:\n\n"; + print $args{'function'} . " - " . $args{'purpose'} . "\n"; + + print "\nSynopsis:\n\n"; + if ($args{'functiontype'} ne "") { + $start = $args{'functiontype'} . " " . $args{'function'} . " ("; + } else { + $start = $args{'function'} . " ("; + } + print $start; + + my $count = 0; + foreach my $parameter (@{$args{'parameterlist'}}) { + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print $1 . $parameter . ") (" . $2; + } else { + print $type . " " . $parameter; + } + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ",\n"; + print " " x length($start); + } else { + print ");\n\n"; + } + } + + print "Arguments:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + print $parameter . "\n\t" . $args{'parameterdescs'}{$parameter_name} . "\n"; + } + output_section_text(@_); +} + +#output sections in text +sub output_section_text(%) { + my %args = %{$_[0]}; + my $section; + + print "\n"; + foreach $section (@{$args{'sectionlist'}}) { + print "$section:\n\n"; + output_highlight($args{'sections'}{$section}); + } + print "\n\n"; +} + +# output enum in text +sub output_enum_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Enum:\n\n"; + + print "enum " . $args{'enum'} . " - " . $args{'purpose'} . "\n\n"; + print "enum " . $args{'enum'} . " {\n"; + $count = 0; + foreach $parameter (@{$args{'parameterlist'}}) { + print "\t$parameter"; + if ($count != $#{$args{'parameterlist'}}) { + $count++; + print ","; + } + print "\n"; + } + print "};\n\n"; + + print "Constants:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter} . "\n"; + } + + output_section_text(@_); +} + +# output typedef in text +sub output_typedef_text(%) { + my %args = %{$_[0]}; + my ($parameter); + my $count; + print "Typedef:\n\n"; + + print "typedef " . $args{'typedef'} . " - " . $args{'purpose'} . "\n"; + output_section_text(@_); +} + +# output struct as text +sub output_struct_text(%) { + my %args = %{$_[0]}; + my ($parameter); + + print $args{'type'} . " " . $args{'struct'} . " - " . $args{'purpose'} . "\n\n"; + print $args{'type'} . " " . $args{'struct'} . " {\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + if ($parameter =~ /^#/) { + print "$parameter\n"; + next; + } + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + $type = $args{'parametertypes'}{$parameter}; + if ($type =~ m/([^(]*(*)\s*)\s*(([^)]*))/) { + # pointer-to-function + print "\t$1 $parameter) ($2);\n"; + } elsif ($type =~ m/^(.*?)\s*(:.*)/) { + # bitfield + print "\t$1 $parameter$2;\n"; + } else { + print "\t" . $type . " " . $parameter . ";\n"; + } + } + print "};\n\n"; + + print "Members:\n\n"; + foreach $parameter (@{$args{'parameterlist'}}) { + ($parameter =~ /^#/) && next; + + my $parameter_name = $parameter; + $parameter_name =~ s/[.*//; + + ($args{'parameterdescs'}{$parameter_name} ne $undescribed) || next; + print "$parameter\n\t"; + print $args{'parameterdescs'}{$parameter_name} . "\n"; + } + print "\n"; + output_section_text(@_); +} + +sub output_blockhead_text(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print " $section:\n"; + print " -> "; + output_highlight($args{'sections'}{$section}); + } +} + +## list mode output functions + +sub output_function_list(%) { + my %args = %{$_[0]}; + + print $args{'function'} . "\n"; +} + +# output enum in list +sub output_enum_list(%) { + my %args = %{$_[0]}; + print $args{'enum'} . "\n"; +} + +# output typedef in list +sub output_typedef_list(%) { + my %args = %{$_[0]}; + print $args{'typedef'} . "\n"; +} + +# output struct as list +sub output_struct_list(%) { + my %args = %{$_[0]}; + + print $args{'struct'} . "\n"; +} + +sub output_blockhead_list(%) { + my %args = %{$_[0]}; + my ($parameter, $section); + + foreach $section (@{$args{'sectionlist'}}) { + print "DOC: $section\n"; + } +} + +## +# generic output function for all types (function, struct/union, typedef, enum); +# calls the generated, variable output_ function name based on +# functype and output_mode +sub output_declaration { + no strict 'refs'; + my $name = shift; + my $functype = shift; + my $func = "output_${functype}_$output_mode"; + if (($function_only==0) || + ( $function_only == 1 && defined($function_table{$name})) || + ( $function_only == 2 && !defined($function_table{$name}))) + { + &$func(@_); + $section_counter++; + } +} + +## +# generic output function - calls the right one based on current output mode. +sub output_blockhead { + no strict 'refs'; + my $func = "output_blockhead_" . $output_mode; + &$func(@_); + $section_counter++; +} + +## +# takes a declaration (struct, union, enum, typedef) and +# invokes the right handler. NOT called for functions. +sub dump_declaration($$) { + no strict 'refs'; + my ($prototype, $file) = @_; + my $func = "dump_" . $decl_type; + &$func(@_); +} + +sub dump_union($$) { + dump_struct(@_); +} + +sub dump_struct($$) { + my $x = shift; + my $file = shift; + my $nested; + + if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}/) { + #my $decl_type = $1; + $declaration_name = $2; + my $members = $3; + + # ignore embedded structs or unions + $members =~ s/({.*})//g; + $nested = $1; + + # ignore members marked private: + $members =~ s//*\s*private:.*?/*\s*public:.*?*///gos; + $members =~ s//*\s*private:.*//gos; + # strip comments: + $members =~ s//*.*?*///gos; + $nested =~ s//*.*?*///gos; + # strip kmemcheck_bitfield_{begin,end}.*; + $members =~ s/kmemcheck_bitfield_.*?;//gos; + # strip attributes + $members =~ s/__aligned\s*(\d+)//gos; + + create_parameterlist($members, ';', $file); + check_sections($file, $declaration_name, "struct", $sectcheck, $struct_actual, $nested); + + output_declaration($declaration_name, + 'struct', + {'struct' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose, + 'type' => $decl_type + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse struct or union!\n"; + ++$errors; + } +} + +sub dump_enum($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + $x =~ s/^#\s*define\s+.*$//; # strip #define macros inside enums + + if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { + $declaration_name = $1; + my $members = $2; + + foreach my $arg (split ',', $members) { + $arg =~ s/^\s*(\w+).*/$1/; + push @parameterlist, $arg; + if (!$parameterdescs{$arg}) { + $parameterdescs{$arg} = $undescribed; + print STDERR "Warning(${file}:$.): Enum value '$arg' ". + "not described in enum '$declaration_name'\n"; + } + + } + + output_declaration($declaration_name, + 'enum', + {'enum' => $declaration_name, + 'module' => $modulename, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse enum!\n"; + ++$errors; + } +} + +sub dump_typedef($$) { + my $x = shift; + my $file = shift; + + $x =~ s@/*.*?*/@@gos; # strip comments. + while (($x =~ /(*.)\s*;$/) || ($x =~ /[*.]\s*;$/)) { + $x =~ s/(*.)\s*;$/;/; + $x =~ s/[*.]\s*;$/;/; + } + + if ($x =~ /typedef.*\s+(\w+)\s*;/) { + $declaration_name = $1; + + output_declaration($declaration_name, + 'typedef', + {'typedef' => $declaration_name, + 'module' => $modulename, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); + } + else { + print STDERR "Error(${file}:$.): Cannot parse typedef!\n"; + ++$errors; + } +} + +sub save_struct_actual($) { + my $actual = shift; + + # strip all spaces from the actual param so that it looks like one string item + $actual =~ s/\s*//g; + $struct_actual = $struct_actual . $actual . " "; +} + +sub create_parameterlist($$$) { + my $args = shift; + my $splitter = shift; + my $file = shift; + my $type; + my $param; + + # temporarily replace commas inside function pointer definition + while ($args =~ /(([^),]+),/) { + $args =~ s/(([^),]+),/$1#/g; + } + + foreach my $arg (split($splitter, $args)) { + # strip comments + $arg =~ s//*.**///; + # strip leading/trailing spaces + $arg =~ s/^\s*//; + $arg =~ s/\s*$//; + $arg =~ s/\s+/ /; + + if ($arg =~ /^#/) { + # Treat preprocessor directive as a typeless variable just to fill + # corresponding data structures "correctly". Catch it later in + # output_* subs. + push_parameter($arg, "", $file); + } elsif ($arg =~ m/(.+)\s*(/) { + # pointer-to-function + $arg =~ tr/#/,/; + $arg =~ m/[^(]+(*?\s*(\w*)\s*)/; + $param = $1; + $type = $arg; + $type =~ s/([^(]+(*?)\s*$param/$1/; + save_struct_actual($param); + push_parameter($param, $type, $file); + } elsif ($arg) { + $arg =~ s/\s*:\s*/:/g; + $arg =~ s/\s*[/[/g; + + my @args = split('\s*,\s*', $arg); + if ($args[0] =~ m/*/) { + $args[0] =~ s/(*+)\s*/ $1/; + } + + my @first_arg; + if ($args[0] =~ /^(.*\s+)(.*?[.*].*)$/) { + shift @args; + push(@first_arg, split('\s+', $1)); + push(@first_arg, $2); + } else { + @first_arg = split('\s+', shift @args); + } + + unshift(@args, pop @first_arg); + $type = join " ", @first_arg; + + foreach $param (@args) { + if ($param =~ m/^(*+)\s*(.*)/) { + save_struct_actual($2); + push_parameter($2, "$type $1", $file); + } + elsif ($param =~ m/(.*?):(\d+)/) { + if ($type ne "") { # skip unnamed bit-fields + save_struct_actual($1); + push_parameter($1, "$type:$2", $file) + } + } + else { + save_struct_actual($param); + push_parameter($param, $type, $file); + } + } + } + } +} + +sub push_parameter($$$) { + my $param = shift; + my $type = shift; + my $file = shift; + + if (($anon_struct_union == 1) && ($type eq "") && + ($param eq "}")) { + return; # ignore the ending }; from anon. struct/union + } + + $anon_struct_union = 0; + my $param_name = $param; + $param_name =~ s/[.*//; + + if ($type eq "" && $param =~ /...$/) + { + if (!defined $parameterdescs{$param} || $parameterdescs{$param} eq "") { + $parameterdescs{$param} = "variable arguments"; + } + } + elsif ($type eq "" && ($param eq "" or $param eq "void")) + { + $param="void"; + $parameterdescs{void} = "no arguments"; + } + elsif ($type eq "" && ($param eq "struct" or $param eq "union")) + # handle unnamed (anonymous) union or struct: + { + $type = $param; + $param = "{unnamed_" . $param . "}"; + $parameterdescs{$param} = "anonymous\n"; + $anon_struct_union = 1; + } + + # warn if parameter has no description + # (but ignore ones starting with # as these are not parameters + # but inline preprocessor statements); + # also ignore unnamed structs/unions; + if (!$anon_struct_union) { + if (!defined $parameterdescs{$param_name} && $param_name !~ /^#/) { + + $parameterdescs{$param_name} = $undescribed; + + if (($type eq 'function') || ($type eq 'enum')) { + print STDERR "Warning(${file}:$.): Function parameter ". + "or member '$param' not " . + "described in '$declaration_name'\n"; + } + print STDERR "Warning(${file}:$.):" . + " No description found for parameter '$param'\n"; + ++$warnings; + } + } + + $param = xml_escape($param); + + # strip spaces from $param so that it is one continuous string + # on @parameterlist; + # this fixes a problem where check_sections() cannot find + # a parameter like "addr[6 + 2]" because it actually appears + # as "addr[6", "+", "2]" on the parameter list; + # but it's better to maintain the param string unchanged for output, + # so just weaken the string compare in check_sections() to ignore + # "[blah" in a parameter string; + ###$param =~ s/\s*//g; + push @parameterlist, $param; + $parametertypes{$param} = $type; +} + +sub check_sections($$$$$$) { + my ($file, $decl_name, $decl_type, $sectcheck, $prmscheck, $nested) = @_; + my @sects = split ' ', $sectcheck; + my @prms = split ' ', $prmscheck; + my $err; + my ($px, $sx); + my $prm_clean; # strip trailing "[array size]" and/or beginning "*" + + foreach $sx (0 .. $#sects) { + $err = 1; + foreach $px (0 .. $#prms) { + $prm_clean = $prms[$px]; + $prm_clean =~ s/[.*]//; + $prm_clean =~ s/__attribute__\s*(([a-z,_*\s()]*))//i; + # ignore array size in a parameter string; + # however, the original param string may contain + # spaces, e.g.: addr[6 + 2] + # and this appears in @prms as "addr[6" since the + # parameter list is split at spaces; + # hence just ignore "[..." for the sections check; + $prm_clean =~ s/[.*//; + + ##$prm_clean =~ s/^**//; + if ($prm_clean eq $sects[$sx]) { + $err = 0; + last; + } + } + if ($err) { + if ($decl_type eq "function") { + print STDERR "Warning(${file}:$.): " . + "Excess function parameter " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } else { + if ($nested !~ m/\Q$sects[$sx]\E/) { + print STDERR "Warning(${file}:$.): " . + "Excess struct/union/enum/typedef member " . + "'$sects[$sx]' " . + "description in '$decl_name'\n"; + ++$warnings; + } + } + } + } +} + +## +# takes a function prototype and the name of the current file being +# processed and spits out all the details stored in the global +# arrays/hashes. +sub dump_function($$) { + my $prototype = shift; + my $file = shift; + + $prototype =~ s/^static +//; + $prototype =~ s/^extern +//; + $prototype =~ s/^asmlinkage +//; + $prototype =~ s/^inline +//; + $prototype =~ s/^__inline__ +//; + $prototype =~ s/^__inline +//; + $prototype =~ s/^__always_inline +//; + $prototype =~ s/^noinline +//; + $prototype =~ s/__devinit +//; + $prototype =~ s/__init +//; + $prototype =~ s/__init_or_module +//; + $prototype =~ s/__must_check +//; + $prototype =~ s/__weak +//; + $prototype =~ s/^#\s*define\s+//; #ak added + $prototype =~ s/__attribute__\s*(([a-z,]*))//; + + # Yes, this truly is vile. We are looking for: + # 1. Return type (may be nothing if we're looking at a macro) + # 2. Function name + # 3. Function parameters. + # + # All the while we have to watch out for function pointer parameters + # (which IIRC is what the two sections are for), C types (these + # regexps don't even start to express all the possibilities), and + # so on. + # + # If you mess with these regexps, it's a good idea to check that + # the following functions' documentation still comes out right: + # - parport_register_device (function pointer parameters) + # - atomic_set (macro) + # - pci_match_device, __copy_to_user (long return type) + + if ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**+)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + $prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s+\w+\s+\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/ || + $prototype =~ m/^(\w+\s+\w+\s**\s*\w+\s**\s*)\s*([a-zA-Z0-9_~:]+)\s*(([^{]*))/) { + $return_type = $1; + $declaration_name = $2; + my $args = $3; + + create_parameterlist($args, ',', $file); + } else { + print STDERR "Error(${file}:$.): cannot understand prototype: '$prototype'\n"; + ++$errors; + return; + } + + my $prms = join " ", @parameterlist; + check_sections($file, $declaration_name, "function", $sectcheck, $prms, ""); + + output_declaration($declaration_name, + 'function', + {'function' => $declaration_name, + 'module' => $modulename, + 'functiontype' => $return_type, + 'parameterlist' => @parameterlist, + 'parameterdescs' => %parameterdescs, + 'parametertypes' => %parametertypes, + 'sectionlist' => @sectionlist, + 'sections' => %sections, + 'purpose' => $declaration_purpose + }); +} + +sub reset_state { + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $sectcheck = ""; + $struct_actual = ""; + $prototype = ""; + + $state = 0; +} + +sub tracepoint_munge($) { + my $file = shift; + my $tracepointname = 0; + my $tracepointargs = 0; + + if ($prototype =~ m/TRACE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_SINGLE_EVENT((.*?),/) { + $tracepointname = $1; + } + if ($prototype =~ m/DEFINE_EVENT((.*?),(.*?),/) { + $tracepointname = $2; + } + $tracepointname =~ s/^\s+//; #strip leading whitespace + if ($prototype =~ m/TP_PROTO((.*?))/) { + $tracepointargs = $1; + } + if (($tracepointname eq 0) || ($tracepointargs eq 0)) { + print STDERR "Warning(${file}:$.): Unrecognized tracepoint format: \n". + "$prototype\n"; + } else { + $prototype = "static inline void trace_$tracepointname($tracepointargs)"; + } +} + +sub syscall_munge() { + my $void = 0; + + $prototype =~ s@[\r\n\t]+@ @gos; # strip newlines/CR's/tabs +## if ($prototype =~ m/SYSCALL_DEFINE0\s*(\s*(a-zA-Z0-9_)*\s*)/) { + if ($prototype =~ m/SYSCALL_DEFINE0/) { + $void = 1; +## $prototype = "long sys_$1(void)"; + } + + $prototype =~ s/SYSCALL_DEFINE.*(/long sys_/; # fix return type & func name + if ($prototype =~ m/long (sys_.*?),/) { + $prototype =~ s/,/(/; + } elsif ($void) { + $prototype =~ s/)/(void)/; + } + + # now delete all of the odd-number commas in $prototype + # so that arg types & arg names don't have a comma between them + my $count = 0; + my $len = length($prototype); + if ($void) { + $len = 0; # skip the for-loop + } + for (my $ix = 0; $ix < $len; $ix++) { + if (substr($prototype, $ix, 1) eq ',') { + $count++; + if ($count % 2 == 1) { + substr($prototype, $ix, 1) = ' '; + } + } + } +} + +sub process_state3_function($$) { + my $x = shift; + my $file = shift; + + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ m#\s*/*\s+MACDOC\s*#io || ($x =~ /^#/ && $x !~ /^#\s*define/)) { + # do nothing + } + elsif ($x =~ /([^{]*)/) { + $prototype .= $1; + } + + if (($x =~ /{/) || ($x =~ /#\s*define/) || ($x =~ /;/)) { + $prototype =~ s@/*.*?*/@@gos; # strip comments. + $prototype =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $prototype =~ s@^\s+@@gos; # strip leading spaces + if ($prototype =~ /SYSCALL_DEFINE/) { + syscall_munge(); + } + if ($prototype =~ /TRACE_EVENT/ || $prototype =~ /DEFINE_EVENT/ || + $prototype =~ /DEFINE_SINGLE_EVENT/) + { + tracepoint_munge($file); + } + dump_function($prototype, $file); + reset_state(); + } +} + +sub process_state3_type($$) { + my $x = shift; + my $file = shift; + + $x =~ s@[\r\n]+@ @gos; # strip newlines/cr's. + $x =~ s@^\s+@@gos; # strip leading spaces + $x =~ s@\s+$@@gos; # strip trailing spaces + $x =~ s@//.*$@@gos; # strip C99-style comments to end of line + + if ($x =~ /^#/) { + # To distinguish preprocessor directive from regular declaration later. + $x .= ";"; + } + + while (1) { + if ( $x =~ /([^{};]*)([{};])(.*)/ ) { + $prototype .= $1 . $2; + ($2 eq '{') && $brcount++; + ($2 eq '}') && $brcount--; + if (($2 eq ';') && ($brcount == 0)) { + dump_declaration($prototype, $file); + reset_state(); + last; + } + $x = $3; + } else { + $prototype .= $x; + last; + } + } +} + +# xml_escape: replace <, >, and & in the text stream; +# +# however, formatting controls that are generated internally/locally in the +# kernel-doc script are not escaped here; instead, they begin life like +# $blankline_html (4 of '' followed by a mnemonic + ':'), then these strings +# are converted to their mnemonic-expected output, without the 4 * '' & ':', +# just before actual output; (this is done by local_unescape()) +sub xml_escape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/&/\\\amp;/g; + $text =~ s/</\\\lt;/g; + $text =~ s/>/\\\gt;/g; + return $text; +} + +# convert local escape strings to html +# local escape strings look like: '\\menmonic:' (that's 4 backslashes) +sub local_unescape($) { + my $text = shift; + if (($output_mode eq "text") || ($output_mode eq "man")) { + return $text; + } + $text =~ s/\\\\lt:/</g; + $text =~ s/\\\\gt:/>/g; + return $text; +} + +sub process_file($) { + my $file; + my $identifier; + my $func; + my $descr; + my $in_purpose = 0; + my $initial_section_counter = $section_counter; + + if (defined($ENV{'SRCTREE'})) { + $file = "$ENV{'SRCTREE'}" . "/" . "@_"; + } + else { + $file = "@_"; + } + if (defined($source_map{$file})) { + $file = $source_map{$file}; + } + + if (!open(IN,"<$file")) { + print STDERR "Error: Cannot open file $file\n"; + ++$errors; + return; + } + + $. = 1; + + $section_counter = 0; + while (<IN>) { + if ($state == 0) { + if (/$doc_start/o) { + $state = 1; # next line is always the function name + $in_doc_sect = 0; + } + } elsif ($state == 1) { # this line is the function name (always) + if (/$doc_block/o) { + $state = 4; + $contents = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_decl/o) { + $identifier = $1; + if (/\s*([\w\s]+?)\s*-/) { + $identifier = $1; + } + + $state = 2; + if (/-(.*)/) { + # strip leading/trailing/multiple spaces + $descr= $1; + $descr =~ s/^\s*//; + $descr =~ s/\s*$//; + $descr =~ s/\s+/ /; + $declaration_purpose = xml_escape($descr); + $in_purpose = 1; + } else { + $declaration_purpose = ""; + } + + if (($declaration_purpose eq "") && $verbose) { + print STDERR "Warning(${file}:$.): missing initial short description on line:\n"; + print STDERR $_; + ++$warnings; + } + + if ($identifier =~ m/^struct/) { + $decl_type = 'struct'; + } elsif ($identifier =~ m/^union/) { + $decl_type = 'union'; + } elsif ($identifier =~ m/^enum/) { + $decl_type = 'enum'; + } elsif ($identifier =~ m/^typedef/) { + $decl_type = 'typedef'; + } else { + $decl_type = 'function'; + } + + if ($verbose) { + print STDERR "Info(${file}:$.): Scanning doc for $identifier\n"; + } + } else { + print STDERR "Warning(${file}:$.): Cannot understand $_ on line $.", + " - I thought it was a doc line\n"; + ++$warnings; + $state = 0; + } + } elsif ($state == 2) { # look for head: lines, and include content + if (/$doc_sect/o) { + $newsection = $1; + $newcontents = $2; + + if (($contents ne "") && ($contents ne "\n")) { + if (!$in_doc_sect && $verbose) { + print STDERR "Warning(${file}:$.): contents before sections\n"; + ++$warnings; + } + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + } + + $in_doc_sect = 1; + $in_purpose = 0; + $contents = $newcontents; + if ($contents ne "") { + while ((substr($contents, 0, 1) eq " ") || + substr($contents, 0, 1) eq "\t") { + $contents = substr($contents, 1); + } + $contents .= "\n"; + } + $section = $newsection; + } elsif (/$doc_end/) { + + if (($contents ne "") && ($contents ne "\n")) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } + # look for doc_com + <text> + doc_end: + if ($_ =~ m'\s**\s*[a-zA-Z_0-9:.]+*/') { + print STDERR "Warning(${file}:$.): suspicious ending line: $_"; + ++$warnings; + } + + $prototype = ""; + $state = 3; + $brcount = 0; +# print STDERR "end of doc comment, looking for prototype\n"; + } elsif (/$doc_content/) { + # miguel-style comment kludge, look for blank lines after + # @parameter line to signify start of description + if ($1 eq "") { + if ($section =~ m/^@/ || $section eq $section_context) { + dump_section($file, $section, xml_escape($contents)); + $section = $section_default; + $contents = ""; + } else { + $contents .= "\n"; + } + $in_purpose = 0; + } elsif ($in_purpose == 1) { + # Continued declaration purpose + chomp($declaration_purpose); + $declaration_purpose .= " " . xml_escape($1); + } else { + $contents .= $1 . "\n"; + } + } else { + # i dont know - bad line? ignore. + print STDERR "Warning(${file}:$.): bad line: $_"; + ++$warnings; + } + } elsif ($state == 3) { # scanning for function '{' (end of prototype) + if ($decl_type eq 'function') { + process_state3_function($_, $file); + } else { + process_state3_type($_, $file); + } + } elsif ($state == 4) { + # Documentation block + if (/$doc_block/) { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + if ( $1 eq "" ) { + $section = $section_intro; + } else { + $section = $1; + } + } + elsif (/$doc_end/) + { + dump_doc_section($file, $section, xml_escape($contents)); + $contents = ""; + $function = ""; + %constants = (); + %parameterdescs = (); + %parametertypes = (); + @parameterlist = (); + %sections = (); + @sectionlist = (); + $prototype = ""; + $state = 0; + } + elsif (/$doc_content/) + { + if ( $1 eq "" ) + { + $contents .= $blankline; + } + else + { + $contents .= $1 . "\n"; + } + } + } + } + if ($initial_section_counter == $section_counter) { + print STDERR "Warning(${file}): no structured comments found\n"; + if ($output_mode eq "xml") { + # The template wants at least one RefEntry here; make one. + print "<refentry>\n"; + print " <refnamediv>\n"; + print " <refname>\n"; + print " ${file}\n"; + print " </refname>\n"; + print " <refpurpose>\n"; + print " Document generation inconsistency\n"; + print " </refpurpose>\n"; + print " </refnamediv>\n"; + print " <refsect1>\n"; + print " <title>\n"; + print " Oops\n"; + print " </title>\n"; + print " <warning>\n"; + print " <para>\n"; + print " The template for this document tried to insert\n"; + print " the structured comment from the file\n"; + print " <filename>${file}</filename> at this point,\n"; + print " but none was found.\n"; + print " This dummy section is inserted to allow\n"; + print " generation to continue.\n"; + print " </para>\n"; + print " </warning>\n"; + print " </refsect1>\n"; + print "</refentry>\n"; + } + } +} + + +$kernelversion = get_kernel_version(); + +# generate a sequence of code that will splice in highlighting information +# using the s// operator. +foreach my $pattern (keys %highlights) { +# print STDERR "scanning pattern:$pattern, highlight:($highlights{$pattern})\n"; + $dohighlight .= "$contents =~ s:$pattern:$highlights{$pattern}:gs;\n"; +} + +# Read the file that maps relative names to absolute names for +# separate source and object directories and for shadow trees. +if (open(SOURCE_MAP, "<.tmp_filelist.txt")) { + my ($relname, $absname); + while(<SOURCE_MAP>) { + chop(); + ($relname, $absname) = (split())[0..1]; + $relname =~ s:^/+::; + $source_map{$relname} = $absname; + } + close(SOURCE_MAP); +} + +foreach (@ARGV) { + chomp; + process_file($_); +} +if ($verbose && $errors) { + print STDERR "$errors errors\n"; +} +if ($verbose && $warnings) { + print STDERR "$warnings warnings\n"; +} + +exit($errors);
Import basic CSS stylesheet for the HTML documentation. The base for the stylesheet is taken from:
http://ds9a.nl/docbook/minimal-page.html
I customized the CSS a bit further, for example to add curvy corners to example section and change the tint of gray. The HTML documentation does not look that crude anymore.
Signed-off-by: Marek Vasut marex@denx.de --- doc/DocBook/docbook.css | 16 ++++++++++++++++ doc/DocBook/stylesheet.xsl | 1 + 2 files changed, 17 insertions(+) create mode 100644 doc/DocBook/docbook.css
V3: - Make use of patman tags in commit description - Push the patches to testing: http://git.denx.de/?p=u-boot/u-boot-testing.git;a=shortlog;h=refs/heads/dm-k...
V2: - Resend
diff --git a/doc/DocBook/docbook.css b/doc/DocBook/docbook.css new file mode 100644 index 0000000..7a79ec5 --- /dev/null +++ b/doc/DocBook/docbook.css @@ -0,0 +1,16 @@ +body { + font-family: sans-serif; +} + +.programlisting { + font-family: monospace; + font-size: 1em; + display: block; + padding: 10px; + border: 1px solid #aaa; + color: #000; + background-color: #eee; + overflow: auto; + margin: 1em 0em; + border-radius: 6px; +} diff --git a/doc/DocBook/stylesheet.xsl b/doc/DocBook/stylesheet.xsl index 85b2527..8adce56 100644 --- a/doc/DocBook/stylesheet.xsl +++ b/doc/DocBook/stylesheet.xsl @@ -7,4 +7,5 @@ <!-- <param name="paper.type">A4</param> --> <param name="generate.section.toc.level">2</param> <param name="use.id.as.filename">1</param> +<param name="html.stylesheet">../docbook.css</param> </stylesheet>
The default kernel-doc strips starting spaces from every single line in the Example section. This makes the code look bad. Thus, implement special handling for this section.
Signed-off-by: Marek Vasut marex@denx.de --- tools/kernel-doc/kernel-doc | 3 +++ 1 file changed, 3 insertions(+)
V2: - Resend
diff --git a/tools/kernel-doc/kernel-doc b/tools/kernel-doc/kernel-doc index 8848efd..6347418 100755 --- a/tools/kernel-doc/kernel-doc +++ b/tools/kernel-doc/kernel-doc @@ -2424,6 +2424,9 @@ sub process_file($) { # Continued declaration purpose chomp($declaration_purpose); $declaration_purpose .= " " . xml_escape($1); + } elsif ($section =~ m/^Example/) { + $_ =~ s/^\s**//; + $contents .= $_; } else { $contents .= $1 . "\n"; }
Add entry for kerneldoc into the git-mailrc pointing to the U-Boot ML and myself.
Signed-off-by: Marek Vasut marex@denx.de --- doc/git-mailrc | 1 + 1 file changed, 1 insertion(+)
V3: - New patch - Make use of patman tags in commit description - Push the patches to testing: http://git.denx.de/?p=u-boot/u-boot-testing.git;a=shortlog;h=refs/heads/dm-k...
diff --git a/doc/git-mailrc b/doc/git-mailrc index d7fc3c8..d6e01c3 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -95,6 +95,7 @@ alias x86 uboot, gruss
# Subsystem aliases alias cfi uboot, stroese +alias kerneldoc uboot, marex alias fdt uboot, Jerry Van Baren vanbaren@cideas.com alias i2c uboot, hs alias mmc uboot, afleming
On Sat, Oct 6, 2012 at 7:04 PM, Marek Vasut marex@denx.de wrote:
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build.
Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400
This patch makes it so that MAKEALL doesn't build silently anymore:
make[1]: Entering directory `/local/afleming/u-boot/doc/DocBook' make[1]: Leaving directory `/local/afleming/u-boot/doc/DocBook'
Any ideas how we can fix that?
Dear Andy Fleming,
I thought this was fixed, where do you see it?
$ BUILD_DIR=/tmp/test ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- ./MAKEALL m28evk Configuring for m28evk board... text data bss dec hex filename 424579 7784 288876 721239 b0157 /tmp/test/u-boot 6984 760 0 7744 1e40 /tmp/test/spl/u-boot-spl
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ----------------------------------------------------------
Best regards, Marek Vasut
On Tue, Oct 23, 2012 at 2:30 AM, Marek Vasut marex@denx.de wrote:
Dear Andy Fleming,
Hmm, with the latest tree I get:
[afleming@right u-boot (master)]$ ./MAKEALL P2020RDB_NAND Configuring for P2020RDB_NAND - Board: P1_P2_RDB, Options: P2020RDB,NAND make[1]: Entering directory `/local/afleming/u-boot/doc/DocBook' make[1]: Leaving directory `/local/afleming/u-boot/doc/DocBook' text data bss dec hex filename 399394 16752 267792 683938 a6fa2 ./build/P2020RDB_NAND/u-boot
Dear Andy Fleming,
make --version ?
Dear Andy Fleming,
make --version ?
GNU Make 3.81
This program built for x86_64-redhat-linux-gnu
Dear Andy Fleming,
make --version ?
GNU Make 3.81
OK, found it, posting a patch now.
participants (5)
Albert ARIBAUD
Andy Fleming
Graeme Russ
