Re: [U-Boot] [PATCH 2/2] WIP2: Add support for pi
Please, ignore this patch. Pushed by mistake.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com
arch/arm/cpu/armv7/exynos/clock.c | 20 +++++++++++--------- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 2 +- arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/include/asm/arch-exynos/cpu.h | 11 ++++++++++- arch/arm/include/asm/arch-exynos/gpio.h | 4 ++-- drivers/gpio/s5p_gpio.c | 2 +- 6 files changed, 26 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 7558eff..9c0d507 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -118,7 +118,9 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) div = PLL_DIV_1024; else if (proid_is_exynos4412()) div = PLL_DIV_65535;
else if (proid_is_exynos5250() || proid_is_exynos5420())
else return 0;|| proid_is_exynos5800()) div = PLL_DIV_65536;
@@ -1581,7 +1583,7 @@ static unsigned long exynos4_get_i2c_clk(void) unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) {
if (proid_is_exynos5420())
return exynos5_get_pll_clk(pllreg); } else {if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_pll_clk(pllreg);
@@ -1617,7 +1619,7 @@ unsigned long get_i2c_clk(void) unsigned long get_pwm_clk(void) { if (cpu_is_exynos5()) {
return clock_get_periph_rate(PERIPH_ID_PWM0); } else {if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_pwm_clk();
@@ -1630,7 +1632,7 @@ unsigned long get_pwm_clk(void) unsigned long get_uart_clk(int dev_index) { if (cpu_is_exynos5()) {
return exynos5_get_uart_clk(dev_index); } else {if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_uart_clk(dev_index);
@@ -1643,7 +1645,7 @@ unsigned long get_uart_clk(int dev_index) unsigned long get_mmc_clk(int dev_index) { if (cpu_is_exynos5()) {
return exynos5_get_mmc_clk(dev_index); } else {if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_mmc_clk(dev_index);
@@ -1654,7 +1656,7 @@ unsigned long get_mmc_clk(int dev_index) void set_mmc_clk(int dev_index, unsigned int div) { if (cpu_is_exynos5()) {
else exynos5_set_mmc_clk(dev_index, div);if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_set_mmc_clk(dev_index, div);
@@ -1668,7 +1670,7 @@ unsigned long get_lcd_clk(void) if (cpu_is_exynos4()) return exynos4_get_lcd_clk(); else {
else return exynos5_get_lcd_clk();if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_get_lcd_clk();
@@ -1682,7 +1684,7 @@ void set_lcd_clk(void) else { if (proid_is_exynos5250()) exynos5_set_lcd_clk();
else if (proid_is_exynos5420())
}else if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_set_lcd_clk();
} @@ -1696,7 +1698,7 @@ void set_mipi_clk(void) int set_spi_clk(int periph_id, unsigned int rate) { if (cpu_is_exynos5()) {
return exynos5_set_spi_clk(periph_id, rate); } else {if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_set_spi_clk(periph_id, rate);
diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index b6a9bc1..0aff3d0 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -971,7 +971,7 @@ static void exynos5420_system_clock_init(void)
void system_clock_init(void) {
- if (proid_is_exynos5420())
- if (proid_is_exynos5420() || proid_is_exynos5800()) exynos5420_system_clock_init(); else exynos5250_system_clock_init();
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index b929486..17ae2e6 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -834,7 +834,7 @@ static int exynos4x12_pinmux_config(int peripheral, int flags) int exynos_pinmux_config(int peripheral, int flags) { if (cpu_is_exynos5()) {
else if (proid_is_exynos5250()) return exynos5_pinmux_config(peripheral, flags);if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_pinmux_config(peripheral, flags);
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index ba71714..9f3672b 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -218,6 +218,13 @@ static inline void s5p_set_cpu_id(void) /* Exynos5420 */ s5p_cpu_id = 0x5420; break;
- case 0x422:
* Exynos5800 is a variant of Exynos5422
* and has the same product id
s5p_cpu_id = 0x5800;
}break;
@@ -246,6 +253,7 @@ IS_EXYNOS_TYPE(exynos4210, 0x4210) IS_EXYNOS_TYPE(exynos4412, 0x4412) IS_EXYNOS_TYPE(exynos5250, 0x5250) IS_EXYNOS_TYPE(exynos5420, 0x5420) +IS_EXYNOS_TYPE(exynos5800, 0x5800)
#define SAMSUNG_BASE(device, base) \ static inline unsigned int __attribute__((no_instrument_function)) \ @@ -256,7 +264,8 @@ static inline unsigned int __attribute__((no_instrument_function)) \ return EXYNOS4X12_##base; \ return EXYNOS4_##base; \ } else if (cpu_is_exynos5()) { \
if (proid_is_exynos5420()) \
if (proid_is_exynos5420() \
return EXYNOS5_##base; \ } \|| proid_is_exynos5800()) \ return EXYNOS5420_##base; \
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 8fb5c23..32e045a 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -1379,7 +1379,7 @@ static struct gpio_info exynos5420_gpio_data[EXYNOS5420_GPIO_NUM_PARTS] = { static inline struct gpio_info *get_gpio_data(void) { if (cpu_is_exynos5()) {
else return exynos5_gpio_data;if (proid_is_exynos5420() || proid_is_exynos5800()) return exynos5420_gpio_data;
@@ -1396,7 +1396,7 @@ static inline struct gpio_info *get_gpio_data(void) static inline unsigned int get_bank_num(void) { if (cpu_is_exynos5()) {
else return EXYNOS5_GPIO_NUM_PARTS;if (proid_is_exynos5420() || proid_is_exynos5800()) return EXYNOS5420_GPIO_NUM_PARTS;
diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index db7b673..bcf44eb 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -57,7 +57,7 @@ static inline int s5p_name_to_gpio(const char *name) */ #if defined(CONFIG_EXYNOS4) || defined(CONFIG_EXYNOS5) if (cpu_is_exynos5()) {
if (proid_is_exynos5420()) {
if (proid_is_exynos5420() || proid_is_exynos5800()) { tabp = exynos5420_gpio_table; irregular_bank_name = 'y'; irregular_set_number = '7';
-- 1.9.1
Regards, Akshay Saraswat
Akshay Saraswat
