[U-Boot-Users] u-boot on the BDAu1500
I am having a difficult time getting u-boot to run on the BDAu1500 board from AMD. It appears that there is something missing in the board initialization, but I have not been able to track down what it is. If I start the board with yamon in flash, I can successfully load a u-boot image built to run from ram and run it. If I load u-boot into the flash, built with TEXT_BASE set to 0xbfc00000, which is where the board is supposed to start from in flash, it will not init and run from a power on. I tried following the directions at:
http://www.denx.de/twiki/bin/view/DULG/DebuggingUBoot
to debug the problem, but it appears that the function cpu_init_f does not exist for mips targets. Are there any C functions before relocation for mips targets? Are there any instructions similar to those in the above web page for mips target debugging?
Ed Okerson
In message Pine.LNX.4.44.0311231903000.23580-100000@dallas.texasconnect.net you wrote:
Yes, of course there are. See the init_sequence[] table in "lib_mips/board.c".
Why do you think you need cpu_init_f()?
There is no difference for MIPS. The procedure is the same.
I was simply following the directions. The web page says:
<quote> (gdb) target remote bdi:2001 Remote debugging using bdi:2001 0xfffffffc in ?? () (gdb) b cpu_init_f Breakpoint 1 at 0xfffd3310: file cpu_init.c, line 136. (gdb) c Continuing.
Breakpoint 1, cpu_init_f () at cpu_init.c:136 136 asm volatile(" bl 0f" ::: "lr"); (gdb) s 137 asm volatile("0: mflr 3" ::: "r3"); (gdb) 138 asm volatile(" addi 4, 0, 14" ::: "r4"); (gdb)
cpu_init_f is the first C function called from the code in start.C.
</quote>
Except that the function that the web page says to set breakpoints on do not exist for the mips platform.
Ed Okerson
In message Pine.LNX.4.44.0311240920150.23580-100000@dallas.texasconnect.net you wrote:
Please don't use an example as directions that must be strictly followed.
You can set breakpoints anywhere you think it is useful for debugging. That was just an EXAMPLE.
Ed Okerson
