[U-Boot] [PATCH 1/9 v3] 82xx, mgcoge: updates for 2009.03
- activate CS4 for accessing the FPGA - activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flashes in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/mgcoge/mgcoge.c | 7 +++++-- include/configs/mgcoge.h | 32 ++++++++++++++++++++++++++++++-- 2 files changed, 35 insertions(+), 4 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 5c50739..0e3aa49 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -325,6 +325,7 @@ void ft_blob_update (void *blob, bd_t *bd) { ulong memory_data[2] = {0}; ulong flash_data[8] = {0}; + flash_info_t *info;
memory_data[0] = cpu_to_be32 (bd->bi_memstart); memory_data[1] = cpu_to_be32 (bd->bi_memsize); @@ -332,12 +333,14 @@ void ft_blob_update (void *blob, bd_t *bd) sizeof (memory_data));
/* update Flash addr, size */ + info = flash_get_info(CONFIG_SYS_FLASH_BASE); flash_data[2] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE); - flash_data[3] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE); + flash_data[3] = cpu_to_be32 (info->size); flash_data[4] = cpu_to_be32 (5); flash_data[5] = cpu_to_be32 (0); + info = flash_get_info(CONFIG_SYS_FLASH_BASE_1); flash_data[6] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE_1); - flash_data[7] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE_1); + flash_data[7] = cpu_to_be32 (info->size); fdt_set_node_and_value (blob, "/localbus", "ranges", flash_data, sizeof (flash_data)); /* MAC addr */ diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index b5d12c6..79c7050 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -32,6 +32,7 @@ #define CONFIG_MPC8247 1 #define CONFIG_MPC8272_FAMILY 1 #define CONFIG_MGCOGE 1 +#define CONFIG_HOSTNAME mgcoge
#define CONFIG_CPM2 1 /* Has a CPM2 */
@@ -49,6 +50,8 @@ #undef CONFIG_CONS_ON_SCC /* It's not on SCC */ #undef CONFIG_CONS_NONE /* It's not on external UART */ #define CONFIG_CONS_INDEX 2 /* SMC2 is used for console */ +#define CONFIG_SYS_SMC_RXBUFLEN 128 +#define CONFIG_SYS_MAXIDLE 10
/* * Select ethernet configuration @@ -75,6 +78,14 @@ #define CONFIG_8260_CLKIN 66000000 /* in Hz */ #endif
+#define BOOTFLASH_START FE000000 +#define CONFIG_PRAM 512 /* protected RAM [KBytes] */ + +#define MTDIDS_DEFAULT "nor0=boot,nor1=app" +#define MTDPARTS_DEFAULT \ + "mtdparts=boot:384k(u-boot),128k(env),128k(envred),3456k(free);" \ + "app:3m(esw0),10m(rootfs0),3m(esw1),10m(rootfs1),1m(var),5m(cfg)" + /* * Default environment settings */ @@ -107,6 +118,8 @@ "tftp ${ramdisk_addr} ${ramdisk_file}; " \ "run ramargs addip; " \ "bootm ${kernel_addr} ${ramdisk_addr} ${fdt_addr}\0" \ + "EEprom_ivm=pca9544a:70:4 \0" \ + "mtdparts=" MK_STR(MTDPARTS_DEFAULT) "\0" \ ""
#define CONFIG_SYS_SDRAM_BASE 0x00000000 @@ -127,12 +140,12 @@ #define CONFIG_SYS_RAMBOOT #endif
-#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256KB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* Reserve 384KB for Monitor */
#define CONFIG_ENV_IS_IN_FLASH
#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SECT_SIZE 0x4000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN
@@ -140,6 +153,7 @@ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) #endif /* CONFIG_ENV_IS_IN_FLASH */ +#define CONFIG_ENV_BUFFER_PRINT 1
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ @@ -187,6 +201,8 @@ #define CONFIG_SYS_DTT_HYSTERESIS 3 #define CONFIG_SYS_DTT_BUS_NUM (CONFIG_SYS_MAX_I2C_BUS)
+#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + #define CONFIG_SYS_IMMR 0xF0000000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR @@ -333,6 +349,18 @@ ORxG_CSNT | ORxG_ACS_DIV2 |\ ORxG_SCY_3_CLK | ORxG_TRLX )
+/* Board FPGA on CS4 initialization values +*/ +#define CONFIG_SYS_FPGA_BASE 0x40000000 +#define CONFIG_SYS_FPGA_SIZE 1 /*1KB*/ + +#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_FPGA_BASE & BRx_BA_MSK) |\ + BRx_PS_8 | BRx_MS_GPCM_P | BRx_V) + +#define CONFIG_SYS_OR4_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FPGA_SIZE << 10) |\ + ORxG_CSNT | ORxG_ACS_DIV2 |\ + ORxG_SCY_3_CLK | ORxG_TRLX ) + /* CFG-Flash on CS5 initialization values */ #define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_FLASH_BASE_1 & BRx_BA_MSK) |\
Dear Heiko Schocher,
- pram activated
Applied, thanks.
Heiko Schocher
