[PATCH v2 0/1] Agilex5 enablement
V1: https://patchwork.ozlabs.org/project/uboot/patch/20240220143603.22091-1-jit.... V2: Fixed Git auto-merge causing misalignment of code and insert/delete
Jit Loon Lim (1): arch:arm: Agilex5 enablement
arch/arm/Kconfig | 13 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 458 ++++++++++++ arch/arm/dts/socfpga_agilex5.dtsi | 654 ++++++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 144 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 +++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 69 +- arch/arm/mach-socfpga/Makefile | 4 +- arch/arm/mach-socfpga/board.c | 56 +- .../include/mach/base_addr_soc64.h | 44 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + board/intel/agilex5-socdk/Makefile | 7 + configs/socfpga_agilex5_defconfig | 113 +++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 209 +++++- 16 files changed, 1957 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 board/intel/agilex5-socdk/Makefile create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 include/configs/socfpga_agilex5_socdk.h
This patch is to enable Agilex5 platform for Intel product. Changes, modification and new files are created for board, dts, configs and makefile to create the base for Agilex5.
Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- Changes v1 -> v2: - fixed git auto merge issue --- arch/arm/Kconfig | 13 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 458 ++++++++++++ arch/arm/dts/socfpga_agilex5.dtsi | 654 ++++++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 144 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 +++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 69 +- arch/arm/mach-socfpga/Makefile | 4 +- arch/arm/mach-socfpga/board.c | 56 +- .../include/mach/base_addr_soc64.h | 44 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + board/intel/agilex5-socdk/Makefile | 7 + configs/socfpga_agilex5_defconfig | 113 +++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 209 +++++- 16 files changed, 1957 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 board/intel/agilex5-socdk/Makefile create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 include/configs/socfpga_agilex5_socdk.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fde85dc0d5..baecb0463d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -28,6 +28,7 @@ config COUNTER_FREQUENCY ROCKCHIP_RK3288 || ROCKCHIP_RK322X || ROCKCHIP_RK3036 default 25000000 if ARCH_LX2160A || ARCH_LX2162A || ARCH_LS1088A default 100000000 if ARCH_ZYNQMP + default 200000000 if ARCH_SOCFPGA && ARM64 && TARGET_SOCFPGA_AGILEX5 default 0 help For platforms with ARMv8-A and ARMv7-A which features a system @@ -1116,6 +1117,8 @@ config ARCH_SOCFPGA select SPL_LIBGENERIC_SUPPORT select SPL_OF_CONTROL select SPL_SEPARATE_BSS if TARGET_SOCFPGA_SOC64 + select SPL_DRIVERS_MISC if TARGET_SOCFPGA_SOC64 + select SPL_SOCFPGA_SEC_REG if TARGET_SOCFPGA_SOC64 select SPL_SERIAL select SPL_SYSRESET select SPL_WATCHDOG @@ -1124,7 +1127,8 @@ config ARCH_SOCFPGA select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select SYSRESET select SYSRESET_SOCFPGA if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 - select SYSRESET_SOCFPGA_SOC64 if TARGET_SOCFPGA_SOC64 + select SYSRESET_SOCFPGA_SOC64 if !TARGET_SOCFPGA_AGILEX5 && TARGET_SOCFPGA_SOC64 + imply SYSRESET_SOCFPGA_AGILEX5 if TARGET_SOCFPGA_AGILEX5 imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFY @@ -1158,7 +1162,9 @@ config ARCH_SUNXI select DM_SPI_FLASH if SPI && MTD select DM_KEYBOARD select DM_MMC if MMC + select DM_SCSI if SCSI select DM_SERIAL + select GPIO_EXTRA_HEADER select OF_BOARD_SETUP select OF_CONTROL select OF_SEPARATE @@ -1865,7 +1871,7 @@ config TARGET_SL28 select PCI select DM_RNG select DM_RTC - select SCSI + select DM_SCSI select DM_SERIAL select DM_SPI select GPIO_EXTRA_HEADER @@ -2082,6 +2088,7 @@ config TARGET_POMELO select PCI select DM_PCI select SCSI + select DM_SCSI select DM_SERIAL imply CMD_PCI help @@ -2375,4 +2382,4 @@ source "board/xen/xenguest_arm64/Kconfig"
source "arch/arm/Kconfig.debug"
-endmenu +endmenu \ No newline at end of file diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9725030d5..2b4f896ad2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_TARGET_THUNDERX_88XX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_agilex_socdk.dtb \ + socfpga_agilex5_socdk.dtb \ socfpga_arria5_secu1.dtb \ socfpga_arria5_socdk.dtb \ socfpga_arria10_chameleonv3_270_2.dtb \ diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi new file mode 100644 index 0000000000..daa8c982da --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -0,0 +1,458 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include "socfpga_soc64_fit-u-boot.dtsi" + +/{ + memory { + #address-cells = <2>; + #size-cells = <2>; + bootph-all; + }; + + soc { + bootph-all; + + /* socfpga_secreg: socfpga-secreg { */ + /* compatible = "intel,socfpga-secreg"; */ + /* #address-cells = <1>; */ + /* #size-cells = <1>; */ + /* bootph-all; */ + + /* DSU */ + i_ccu_caiu0@1c000000 { + reg = <0x1c000000 0x00001000>; + intel,offset-settings = + /* CAIUAMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* CAIUMIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* DII2_GICREGS */ + <0x00000424 0x0001d000 0xffffffff>, + <0x00000428 0x00000000 0x000000ff>, + <0x00000420 0xc0800400 0xc1f03e1f>, + /* NCAIU0_LWSOC2FPGA */ + <0x00000444 0x00020000 0xffffffff>, + <0x00000448 0x00000000 0x000000ff>, + <0x00000440 0xc1100006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_1G */ + <0x00000454 0x00040000 0xffffffff>, + <0x00000458 0x00000000 0x000000ff>, + <0x00000450 0xc1200006 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_16G */ + <0x00000474 0x00400000 0xffffffff>, + <0x00000478 0x00000000 0x000000ff>, + <0x00000470 0xc1600006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_256G */ + <0x00000494 0x04000000 0xffffffff>, + <0x00000498 0x00000000 0x000000ff>, + <0x00000490 0xc1a00006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* FPGA2SOC */ + i_ccu_ncaiu0@1c001000 { + reg = <0x1c001000 0x00001000>; + intel,offset-settings = + /* NCAIU0AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* NCAIU0MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* PSS */ + <0x00000404 0x00010000 0xffffffff>, + <0x00000408 0x00000000 0x000000ff>, + <0x00000400 0xC0F00000 0xc1f03e1f>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* NCAIU0_LWSOC2FPGA */ + <0x00000444 0x00020000 0xffffffff>, + <0x00000448 0x00000000 0x000000ff>, + <0x00000440 0xc1100006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_1G */ + <0x00000454 0x00040000 0xffffffff>, + <0x00000458 0x00000000 0x000000ff>, + <0x00000450 0xc1200006 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_16G */ + <0x00000474 0x00400000 0xffffffff>, + <0x00000478 0x00000000 0x000000ff>, + <0x00000470 0xc1600006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_256G */ + <0x00000494 0x04000000 0xffffffff>, + <0x00000498 0x00000000 0x000000ff>, + <0x00000490 0xc1a00006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* GIC_M */ + i_ccu_ncaiu1@1c002000 { + reg = <0x1c002000 0x00001000>; + intel,offset-settings = + /* NCAIU1AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* NCAIU1MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* PSS NOC */ + i_ccu_ncaiu3@1c004000 { + reg = <0x1c004000 0x00001000>; + intel,offset-settings = + /* NCAIU3AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* NCAIU3MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE0 */ + i_ccu_dce0@1c005000 { + reg = <0x1c005000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR0 */ + <0x000003c0 0x00000003 0x0000001f>, + /* DCEUMIFSR0 */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE1 */ + i_ccu_dce1@1c006000 { + reg = <0x1c006000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR1 */ + <0x000003c0 0x00000003 0x0000001f>, + /* DCEUMIFSR1 */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>, + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* DMI0 */ + i_ccu_dmi0@1c007000 { + reg = <0x1c007000 0x00001000>; + intel,offset-settings = + /* DMIUSMCTCR */ + <0x00000300 0x00000003 0x00000003>; + bootph-all; + }; + + /* DMI1 */ + i_ccu_dmi0@1c008000 { + reg = <0x1c008000 0x00001000>; + intel,offset-settings = + /* DMIUSMCTCR */ + <0x00000300 0x00000003 0x00000003>; + bootph-all; + }; + + /* L4 peripherals firewall */ + noc_fw_l4_per@10d21000 { + reg = <0x10d21000 0x0000008c>; + intel,offset-settings = + /* NAND */ + <0x00000000 0x01010001 0x01010001>, + /* USB0 */ + <0x0000000c 0x01010001 0x01010001>, + /* USB1 */ + <0x00000010 0x01010001 0x01010001>, + /* SPI_MAIN0 */ + <0x0000001c 0x01010301 0x01010301>, + /* SPI_MAIN1 */ + <0x00000020 0x01010301 0x01010301>, + /* SPI_SECONDARY0 */ + <0x00000024 0x01010301 0x01010301>, + /* SPI_SECONDARY1 */ + <0x00000028 0x01010301 0x01010301>, + /* EMAC0 */ + <0x0000002c 0x01010001 0x01010001>, + /* EMAC1 */ + <0x00000030 0x01010001 0x01010001>, + /* EMAC2 */ + <0x00000034 0x01010001 0x01010001>, + /* SDMMC */ + <0x00000040 0x01010001 0x01010001>, + /* GPIO0 */ + <0x00000044 0x01010301 0x01010301>, + /* GPIO1 */ + <0x00000048 0x01010301 0x01010301>, + /* I2C0 */ + <0x00000050 0x01010301 0x01010301>, + /* I2C1 */ + <0x00000054 0x01010301 0x01010301>, + /* I2C2 */ + <0x00000058 0x01010301 0x01010301>, + /* I2C3 */ + <0x0000005c 0x01010301 0x01010301>, + /* I2C4 */ + <0x00000060 0x01010301 0x01010301>, + /* SP_TIMER0 */ + <0x00000064 0x01010301 0x01010301>, + /* SP_TIMER1 */ + <0x00000068 0x01010301 0x01010301>, + /* UART0 */ + <0x0000006c 0x01010301 0x01010301>, + /* UART1 */ + <0x00000070 0x01010301 0x01010301>, + /* I3C0 */ + <0x00000074 0x01010301 0x01010301>, + /* I3C1 */ + <0x00000078 0x01010301 0x01010301>, + /* DMA0 */ + <0x0000007c 0x01010001 0x01010001>, + /* DMA1 */ + <0x00000080 0x01010001 0x01010001>, + /* COMBO_PHY */ + <0x00000084 0x01010001 0x01010001>, + /* NAND_SDMA */ + <0x00000088 0x01010301 0x01010301>; + bootph-all; + }; + + /* L4 system firewall */ + noc_fw_l4_sys@10d21100 { + reg = <0x10d21100 0x00000098>; + intel,offset-settings = + /* DMA_ECC */ + <0x00000008 0x01010001 0x01010001>, + /* EMAC0RX_ECC */ + <0x0000000c 0x01010001 0x01010001>, + /* EMAC0TX_ECC */ + <0x00000010 0x01010001 0x01010001>, + /* EMAC1RX_ECC */ + <0x00000014 0x01010001 0x01010001>, + /* EMAC1TX_ECC */ + <0x00000018 0x01010001 0x01010001>, + /* EMAC2RX_ECC */ + <0x0000001c 0x01010001 0x01010001>, + /* EMAC2TX_ECC */ + <0x00000020 0x01010001 0x01010001>, + /* NAND_ECC */ + <0x0000002c 0x01010001 0x01010001>, + /* NAND_READ_ECC */ + <0x00000030 0x01010001 0x01010001>, + /* NAND_WRITE_ECC */ + <0x00000034 0x01010001 0x01010001>, + /* OCRAM_ECC */ + <0x00000038 0x01010001 0x01010001>, + /* SDMMC_ECC */ + <0x00000040 0x01010001 0x01010001>, + /* USB0_ECC */ + <0x00000044 0x01010001 0x01010001>, + /* USB1_CACHEECC */ + <0x00000048 0x01010001 0x01010001>, + /* CLOCK_MANAGER */ + <0x0000004c 0x01010001 0x01010001>, + /* IO_MANAGER */ + <0x00000054 0x01010001 0x01010001>, + /* RESET_MANAGER */ + <0x00000058 0x01010001 0x01010001>, + /* SYSTEM_MANAGER */ + <0x0000005c 0x01010001 0x01010001>, + /* OSC0_TIMER */ + <0x00000060 0x01010301 0x01010301>, + /* OSC1_TIMER0*/ + <0x00000064 0x01010301 0x01010301>, + /* WATCHDOG0 */ + <0x00000068 0x01010301 0x01010301>, + /* WATCHDOG1 */ + <0x0000006c 0x01010301 0x01010301>, + /* WATCHDOG2 */ + <0x00000070 0x01010301 0x01010301>, + /* WATCHDOG3 */ + <0x00000074 0x01010301 0x01010301>, + /* DAP */ + <0x00000078 0x03010001 0x03010001>, + /* WATCHDOG4 */ + <0x0000007c 0x01010301 0x01010301>, + /* POWER_MANAGER */ + <0x00000080 0x01010001 0x01010001>, + /* USB1_RXECC */ + <0x00000084 0x01010001 0x01010001>, + /* USB1_TXECC */ + <0x00000088 0x01010001 0x01010001>, + /* L4_NOC_PROBES */ + <0x00000090 0x01010001 0x01010001>, + /* L4_NOC_QOS */ + <0x00000094 0x01010001 0x01010001>; + bootph-all; + }; + + /* Light weight SoC2FPGA */ + noc_fw_lwsoc2fpga@10d21300 { + reg = <0x10d21300 0x0000004>; + intel,offset-settings = + /* LWSOC2FPGA_CSR */ + <0x00000000 0x0ffe0301>; + bootph-all; + }; + + /* SoC2FPGA */ + noc_fw_soc2fpga@10d21200 { + reg = <0x10d21200 0x0000004>; + intel,offset-settings = + /* SOC2FPGA_CSR */ + <0x00000000 0x0ffe0301 0x0ffe0301>; + bootph-all; + }; + + /* TCU */ + noc_fw_tcu@10d21400 { + reg = <0x10d21400 0x0000004>; + intel,offset-settings = + /* TCU_CSR */ + <0x00000000 0x01010001 0x01010001>; + bootph-all; + }; + }; + }; +}; + +&clkmgr { + bootph-all; +}; + +&i2c0 { + reset-names = "i2c"; +}; + +&i2c1 { + reset-names = "i2c"; +}; + +&i2c2 { + reset-names = "i2c"; +}; + +&i2c3 { + reset-names = "i2c"; +}; + +&mmc { + resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>; +}; + +&porta { + bank-name = "porta"; +}; + +&portb { + bank-name = "portb"; +}; + +&qspi { + bootph-all; +}; + +&rst { + compatible = "altr,rst-mgr"; + altr,modrst-offset = <0x24>; + bootph-all; +}; + +&sdr { + compatible = "intel,sdr-ctl-agilex5"; + reg = <0x18000000 0x400000>, + <0x18400000 0x400000>, + <0x18800000 0x400000>; + resets = <&rst DDRSCH_RESET>; + bootph-all; +}; + +&sysmgr { + compatible = "altr,sys-mgr", "syscon"; + bootph-all; +}; + +&uart0 { + bootph-all; +}; + +&watchdog0 { + bootph-all; +}; diff --git a/arch/arm/dts/socfpga_agilex5.dtsi b/arch/arm/dts/socfpga_agilex5.dtsi new file mode 100644 index 0000000000..0be51d8e72 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5.dtsi @@ -0,0 +1,654 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +/dts-v1/; +#include <dt-bindings/reset/altr,rst-mgr-agx5.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/agilex5-clock.h> + +/ { + compatible = "intel,socfpga-agilex"; + #address-cells = <2>; + #size-cells = <2>; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + service_reserved: svcbuffer@0 { + compatible = "shared-dma-pool"; + reg = <0x0 0x0 0x0 0x1000000>; + alignment = <0x1000>; + no-map; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a55"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a55"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x1>; + }; + + cpu2: cpu@2 { + compatible = "arm,cortex-a76"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x2>; + }; + + cpu3: cpu@3 { + compatible = "arm,cortex-a76"; + device_type = "cpu"; + enable-method = "psci"; + reg = <0x3>; + }; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <0 170 4>, + <0 171 4>, + <0 172 4>, + <0 173 4>; + interrupt-affinity = <&cpu0>, + <&cpu1>, + <&cpu2>, + <&cpu3>; + interrupt-parent = <&intc>; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + intc: intc@fffc1000 { + compatible = "arm,gic-400", "arm,cortex-a15-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1d000000 0x0 0x10000>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges = <0 0 0 0xffffffff>; + + base_fpga_region { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "fpga-region"; + fpga-mgr = <&fpga_mgr>; + }; + + clkmgr: clock-controller@10d10000 { + compatible = "intel,agilex5-clkmgr"; + reg = <0x10d10000 0x1000>; + #clock-cells = <1>; + }; + + clocks { + cb_intosc_hs_div2_clk: cb-intosc-hs-div2-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb-intosc-ls-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s-free-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + qspi_clk: qspi-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <200000000>; + }; + }; + gmac0: ethernet@10810000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10810000 0x3500>; + interrupts = <0 190 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 1>; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + clocks = <&clkmgr AGILEX5_EMAC0_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@10820000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10820000 0x3500>; + interrupts = <0 207 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC1_RESET>, <&rst EMAC1_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 2>; + altr,sysmgr-syscon = <&sysmgr 0x48 0>; + clocks = <&clkmgr AGILEX5_EMAC1_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@10830000 { + compatible = "intel,socfpga-dwxgmac", "snps,dwxgmac-2.10", "snps,dwxgmac"; + reg = <0x10830000 0x3500>; + interrupts = <0 224 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC2_RESET>, <&rst EMAC2_OCP_RESET>; + reset-names = "stmmaceth", "stmmaceth-ocp"; + tx-fifo-depth = <32768>; + rx-fifo-depth = <16384>; + iommus = <&smmu 3>; + altr,sysmgr-syscon = <&sysmgr 0x4c 0>; + clocks = <&clkmgr AGILEX5_EMAC2_CLK>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@10c03200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0x10c03200 0x80>; + resets = <&rst GPIO0_RESET>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 110 4>; + }; + }; + + gpio1: gpio@10c03300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0x10c03300 0x80>; + resets = <&rst GPIO1_RESET>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <24>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 111 4>; + }; + }; + + i2c0: i2c@10c02800 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02800 0x100>; + interrupts = <0 103 4>; + resets = <&rst I2C0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c1: i2c@10c02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02900 0x100>; + interrupts = <0 104 4>; + resets = <&rst I2C1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c2: i2c@10c02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02a00 0x100>; + interrupts = <0 105 4>; + resets = <&rst I2C2_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c3: i2c@10c02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02b00 0x100>; + interrupts = <0 106 4>; + resets = <&rst I2C3_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i2c4: i2c@10c02c00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x10c02c00 0x100>; + interrupts = <0 107 4>; + resets = <&rst I2C4_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + i3c0: i3c@10da0000 { + compatible = "snps,dw-i3c-master-1.00a"; + reg = <0x10da0000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 164 4>; + resets = <&rst I3C0_RESET>; + max_devices = <11>; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>; + status = "disabled"; + }; + + i3c1: i3c@10da1000 { + compatible = "snps,dw-i3c-master-1.00a"; + reg = <0x10da1000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 165 4>; + resets = <&rst I3C1_RESET>; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>; + max_devices = <11>; + status = "disabled"; + }; + + combophy0: combophy@0 { + #phy-cells = <0>; + phy-type = <1>; + compatible = "cdns,combophy"; + reg = <0x10808000 0x1000>; + resets = <&rst COMBOPHY_RESET>; + reset-names = "reset"; + status = "disabled"; + }; + + mmc: mmc0@10808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cdns,sd4hc"; + reg = <0x10808000 0x1000>; + interrupts = <0 96 4>; + phys = <&combophy0>; + phy-names = "combo-phy"; + clocks = <&clkmgr AGILEX5_L4_MP_CLK>, + <&clkmgr AGILEX5_SDMMC_CLK>; + clock-names = "biu", "ciu"; + fifo-depth = <0x800>; + resets = <&rst SDMMC_RESET>; + reset-names = "reset"; + iommus = <&smmu 5>; + status = "disabled"; + }; + + nand: nand@10b80000 { + compatible = "cdns,nand"; + reg = <0x10b80000 0x10000>, + <0x10840000 0x1000>; + reg-names = "reg", "sdma"; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 97 4>; + clocks = <&clkmgr AGILEX5_NAND_CLK>; + resets = <&rst NAND_RESET>, <&rst COMBOPHY_RESET>; + cdns,board-delay-ps = <4830>; + status = "disabled"; + }; + + ocram: sram@00000000 { + compatible = "mmio-sram"; + reg = <0x00000000 0x200000>; + }; + + rst: rstmgr@10d11000 { + #reset-cells = <1>; + compatible = "altr,stratix10-rst-mgr"; + reg = <0x10d11000 0x1000>; + }; + + smmu: iommu@16000000 { + compatible = "arm,mmu-500", "arm,smmu-v2"; + reg = <0x16000000 0x40000>; + #global-interrupts = <2>; + #iommu-cells = <1>; + interrupt-parent = <&intc>; + interrupts = <0 128 4>, /* Global Secure Fault */ + <0 129 4>, /* Global Non-secure Fault */ + /* Non-secure Context Interrupts (32) */ + <0 138 4>, <0 139 4>, <0 140 4>, <0 141 4>, + <0 142 4>, <0 143 4>, <0 144 4>, <0 145 4>, + <0 146 4>, <0 147 4>, <0 148 4>, <0 149 4>, + <0 150 4>, <0 151 4>, <0 152 4>, <0 153 4>, + <0 154 4>, <0 155 4>, <0 156 4>, <0 157 4>, + <0 158 4>, <0 159 4>, <0 160 4>, <0 161 4>, + <0 162 4>, <0 163 4>, <0 164 4>, <0 165 4>, + <0 166 4>, <0 167 4>, <0 168 4>, <0 169 4>; + stream-match-mask = <0x7ff0>; + status = "disabled"; + }; + + spi0: spi@10da4000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x10da4000 0x1000>; + interrupts = <0 99 4>; + resets = <&rst SPIM0_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; + status = "disabled"; + }; + + spi1: spi@10da5000 { + compatible = "intel,agilex-spi", + "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x10da5000 0x1000>; + interrupts = <0 100 4>; + resets = <&rst SPIM1_RESET>; + reg-io-width = <4>; + num-cs = <4>; + clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; + status = "disabled"; + }; + + sysmgr: sysmgr@10d12000 { + compatible = "altr,sys-mgr-s10","altr,sys-mgr"; + reg = <0x10d12000 0x500>; + }; + + /* Local timer */ + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 0xf08>, + <1 14 0xf08>, + <1 11 0xf08>, + <1 10 0xf08>; + }; + + timer0: timer0@10c03000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 113 4>; + reg = <0x10c03000 0x100>; + resets = <&rst SPTIMER0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer1: timer1@10c03100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 114 4>; + reg = <0x10c03100 0x100>; + resets = <&rst SPTIMER1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer2: timer2@10d00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 4>; + reg = <0x10d00000 0x100>; + resets = <&rst L4SYSTIMER0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + timer3: timer3@10d00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 4>; + reg = <0x10d00100 0x100>; + resets = <&rst L4SYSTIMER1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + clock-names = "timer"; + status = "disabled"; + }; + + uart0: serial0@10c02000 { + compatible = "snps,dw-apb-uart"; + reg = <0x10c02000 0x100>; + interrupts = <0 108 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART0_RESET>; + status = "disabled"; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + clock-frequency = <100000000>; + }; + + uart1: serial1@10c02100 { + compatible = "snps,dw-apb-uart"; + reg = <0x10c02100 0x100>; + interrupts = <0 109 4>; + reg-shift = <2>; + reg-io-width = <4>; + resets = <&rst UART1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SP_CLK>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + clocks = <&clkmgr AGILEX5_USB_CLK>; + status = "disabled"; + }; + + usb0: usb@10b00000 { + compatible = "snps,dwc2"; + reg = <0x10b00000 0x40000>; + interrupts = <0 93 4>; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + resets = <&rst USB0_RESET>, <&rst USB0_OCP_RESET>; + reset-names = "dwc2", "dwc2-ecc"; + clocks = <&clkmgr AGILEX5_USB_CLK>; + iommus = <&smmu 6>; + status = "disabled"; + }; + + usb31: usb31@11000000 { + compatible = "snps,dwc3"; + reg = <0x11000000 0x100000>; + resets = <&rst USB1_RESET>; + phys = <&usbphy0>, <&usbphy0>; + phy-names = "usb2-phy", "usb3-phy"; + dr_mode = "host"; + maximum-speed = "super-speed"; + snps,dis_u2_susphy_quirk; + status = "disabled"; + }; + + watchdog0: watchdog@10d00200 { + compatible = "snps,dw-wdt"; + reg = <0x10d00200 0x100>; + interrupts = <0 117 4>; + resets = <&rst WATCHDOG0_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog1: watchdog@10d00300 { + compatible = "snps,dw-wdt"; + reg = <0x10d00300 0x100>; + interrupts = <0 118 4>; + resets = <&rst WATCHDOG1_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog2: watchdog@10d00400 { + compatible = "snps,dw-wdt"; + reg = <0x10d00400 0x100>; + interrupts = <0 125 4>; + resets = <&rst WATCHDOG2_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog3: watchdog@10d00500 { + compatible = "snps,dw-wdt"; + reg = <0x10d00500 0x100>; + interrupts = <0 126 4>; + resets = <&rst WATCHDOG3_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + watchdog4: watchdog@10d00600 { + compatible = "snps,dw-wdt"; + reg = <0x10d00600 0x100>; + interrupts = <0 175 4>; + resets = <&rst WATCHDOG4_RESET>; + clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; + status = "disabled"; + }; + + sdr: sdr@10d21000 { + compatible = "altr,sdr-ctl", "syscon"; + reg = <0x10d21000 0xc0>; + }; + + /* TODO: Update the ECC registers */ + eccmgr { + compatible = "altr,socfpga-s10-ecc-manager", + "altr,socfpga-a10-ecc-manager"; + altr,sysmgr-syscon = <&sysmgr>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <0 15 4>; + interrupt-controller; + #interrupt-cells = <2>; + ranges; + + sdramedac { + compatible = "altr,sdram-edac-s10"; + altr,sdr-syscon = <&sdr>; + interrupts = <16 4>; + }; + + ocram-ecc@ff8cc000 { + compatible = "altr,socfpga-s10-ocram-ecc", + "altr,socfpga-a10-ocram-ecc"; + reg = <0xff8cc000 0x100>; + altr,ecc-parent = <&ocram>; + interrupts = <1 4>; + }; + + usb0-ecc@ff8c4000 { + compatible = "altr,socfpga-s10-usb-ecc", + "altr,socfpga-usb-ecc"; + reg = <0xff8c4000 0x100>; + altr,ecc-parent = <&usb0>; + interrupts = <2 4>; + }; + + emac0-rx-ecc@ff8c0000 { + compatible = "altr,socfpga-s10-eth-mac-ecc", + "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0000 0x100>; + altr,ecc-parent = <&gmac0>; + interrupts = <4 4>; + }; + + emac0-tx-ecc@ff8c0400 { + compatible = "altr,socfpga-s10-eth-mac-ecc", + "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0400 0x100>; + altr,ecc-parent = <&gmac0>; + interrupts = <5 4>; + }; + + sdmmca-ecc@ff8c8c00 { + compatible = "altr,socfpga-s10-sdmmc-ecc", + "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c8c00 0x100>; + altr,ecc-parent = <&mmc>; + interrupts = <14 4>, + <15 4>; + }; + }; + + /* QSPI address not available yet */ + qspi: spi@108d2000 { + compatible = "cdns,qspi-nor"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x108d2000 0x100>, + <0x10900000 0x100000>; + interrupts = <0 3 4>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; + clocks = <&qspi_clk>; + + status = "disabled"; + }; + + firmware { + svc { + compatible = "intel,stratix10-svc"; + method = "smc"; + memory-region = <&service_reserved>; + + fpga_mgr: fpga-mgr { + compatible = "intel,stratix10-soc-fpga-mgr"; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi new file mode 100644 index 0000000000..28e1c140c2 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include "socfpga_agilex5-u-boot.dtsi" + +/{ + aliases { + spi0 = &qspi; + freeze_br0 = &freeze_controller; + }; + + soc { + freeze_controller: freeze_controller@0x20000450 { + compatible = "altr,freeze-bridge-controller"; + reg = <0x20000450 0x00000010>; + status = "disabled"; + }; + }; + + memory { + /* 8GB */ + reg = <0 0x80000000 0 0x80000000>, + <8 0x80000000 1 0x80000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + u-boot,spl-boot-order = &mmc,&flash0,&nand,"/memory"; + }; +}; + +&flash0 { + compatible = "jedec,spi-nor"; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + bootph-all; + /delete-property/ cdns,read-delay; +}; + +&flash1 { + bootph-all; +}; + +&i3c0 { + bootph-all; +}; + +&i3c1 { + bootph-all; +}; + +&mmc { + status = "okay"; + bus-width = <4>; + sd-uhs-sdr50; + cap-mmc-highspeed; + bootph-all; +}; + +&combophy0 { + status = "okay"; + bootph-all; + cdns,phy-use-ext-lpbk-dqs = <1>; + cdns,phy-use-lpbk-dqs = <1>; + cdns,phy-use-phony-dqs = <1>; + cdns,phy-use-phony-dqs-cmd = <1>; + cdns,phy-io-mask-always-on = <0>; + cdns,phy-io-mask-end = <5>; + cdns,phy-io-mask-start = <0>; + cdns,phy-data-select-oe-end = <1>; + cdns,phy-sync-method = <1>; + cdns,phy-sw-half-cycle-shift = <0>; + cdns,phy-rd-del-sel = <52>; + cdns,phy-underrun-suppress = <1>; + cdns,phy-gate-cfg-always-on = <1>; + cdns,phy-param-dll-bypass-mode = <1>; + cdns,phy-param-phase-detect-sel = <2>; + cdns,phy-param-dll-start-point = <254>; + cdns,phy-read-dqs-cmd-delay = <0>; + cdns,phy-clk-wrdqs-delay = <0>; + cdns,phy-clk-wr-delay = <0>; + cdns,phy-read-dqs-delay = <0>; + cdns,phy-phony-dqs-timing = <0>; + cdns,hrs09-rddata-en = <1>; + cdns,hrs09-rdcmd-en = <1>; + cdns,hrs09-extended-wr-mode = <1>; + cdns,hrs09-extended-rd-mode = <1>; + cdns,hrs10-hcsdclkadj = <3>; + cdns,hrs16-wrdata1-sdclk-dly = <0>; + cdns,hrs16-wrdata0-sdclk-dly = <0>; + cdns,hrs16-wrcmd1-sdclk-dly = <0>; + cdns,hrs16-wrcmd0-sdclk-dly = <0>; + cdns,hrs16-wrdata1-dly = <0>; + cdns,hrs16-wrdata0-dly = <0>; + cdns,hrs16-wrcmd1-dly = <0>; + cdns,hrs16-wrcmd0-dly = <0>; + cdns,hrs07-rw-compensate = <10>; + cdns,hrs07-idelay-val = <0>; +}; + +&qspi { + status = "okay"; +}; + +&nand { + bootph-all; +}; + +&timer0 { + bootph-all; +}; + +&timer1 { + bootph-all; +}; + +&timer2 { + bootph-all; +}; + +&timer3 { + bootph-all; +}; + +&watchdog0 { + bootph-all; +}; + +#if !defined(CONFIG_SOCFPGA_SECURE_VAB_AUTH) +&fdt_0_blob { + filename = "arch/arm/dts/socfpga_agilex5_socdk.dtb"; +}; + +/* To add NAND dtb when ready in future */ + +&binman { + /delete-node/ kernel; +}; +#endif + diff --git a/arch/arm/dts/socfpga_agilex5_socdk.dts b/arch/arm/dts/socfpga_agilex5_socdk.dts new file mode 100644 index 0000000000..852e1e5ae3 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5_socdk.dts @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ +#include "socfpga_agilex5.dtsi" + +/ { + model = "SoCFPGA Agilex5 SoCDK"; + + aliases { + serial0 = &uart0; + ethernet0 = &gmac0; + ethernet2 = &gmac2; + }; + + leds { + compatible = "gpio-leds"; + hps0 { + label = "hps_led0"; + gpios = <&portb 20 GPIO_ACTIVE_HIGH>; + }; + + hps1 { + label = "hps_led1"; + gpios = <&portb 19 GPIO_ACTIVE_HIGH>; + }; + + hps2 { + label = "hps_led2"; + gpios = <&portb 21 GPIO_ACTIVE_HIGH>; + }; + }; + + memory { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0 0 0 0>; + }; + + soc { + clocks { + osc1 { + clock-frequency = <25000000>; + }; + }; + }; +}; + +&gpio0 { + status = "okay"; +}; + +&gpio1 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&i3c0 { + status = "okay"; +}; + +&i3c1 { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&usbphy0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; + disable-over-current; +}; + +&watchdog0 { + status = "okay"; +}; + +&watchdog1 { + status = "okay"; +}; + +&watchdog2 { + status = "okay"; +}; + +&watchdog3 { + status = "okay"; +}; + +&watchdog4 { + status = "okay"; +}; + +&timer0 { + status = "okay"; +}; + +&timer1 { + status = "okay"; +}; + +&timer2 { + status = "okay"; +}; + +&timer3 { + status = "okay"; +}; + +&spi0 { + status = "okay"; +}; + +&spi1 { + status = "okay"; +}; + +&qspi { + flash0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mt25qu02g"; + reg = <0>; + spi-max-frequency = <100000000>; + + m25p,fast-read; + cdns,page-size = <256>; + cdns,block-size = <16>; + cdns,read-delay = <1>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + qspi_boot: partition@0 { + label = "u-boot"; + reg = <0x0 0x04200000>; + }; + + root: partition@4200000 { + label = "root"; + reg = <0x04200000 0x0BE00000>; + }; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi index 84b91e8df0..7a5af489c5 100644 --- a/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi +++ b/arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi @@ -2,7 +2,7 @@ /* * U-Boot additions * - * Copyright (C) 2020 Intel Corporation <www.intel.com> + * Copyright (C) 2024 Intel Corporation <www.intel.com> */
#if defined(CONFIG_FIT) @@ -21,14 +21,18 @@ description = "FIT with firmware and bootloader"; #address-cells = <1>;
- images { + images: images { uboot { description = "U-Boot SoC64"; type = "standalone"; os = "U-Boot"; arch = "arm64"; compression = "none"; + #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + load = <0x80200000>; + #else load = <0x00200000>; + #endif uboot_blob: blob-ext { filename = "u-boot-nodtb.bin"; }; @@ -43,8 +47,13 @@ os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; + #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + load = <0x80000000>; + entry = <0x80000000>; + #else load = <0x00001000>; entry = <0x00001000>; + #endif atf_blob: blob-ext { filename = "bl31.bin"; }; @@ -53,11 +62,11 @@ }; };
- fdt { - description = "U-Boot SoC64 flat device-tree"; + fdt-0 { + description = "socfpga_socdk"; type = "flat_dt"; compression = "none"; - uboot_fdt_blob: blob-ext { + fdt_0_blob: blob-ext { filename = "u-boot.dtb"; }; hash { @@ -66,17 +75,18 @@ }; };
- configurations { - default = "conf"; - conf { - description = "Intel SoC64 FPGA"; + board_config: configurations { + default = "board-0"; + + board-0 { + description = "board_0"; firmware = "atf"; loadables = "uboot"; - fdt = "fdt"; + fdt = "fdt-0"; signature { algo = "crc32"; key-name-hint = "dev"; - sign-images = "atf", "fdt", "uboot"; + sign-images = "atf", "uboot", "fdt-0"; }; }; }; @@ -96,8 +106,8 @@ arch = "arm64"; os = "linux"; compression = "none"; - load = <0x4080000>; - entry = <0x4080000>; + load = <0x6000000>; + entry = <0x6000000>; kernel_blob: blob-ext { filename = "Image"; }; @@ -146,7 +156,7 @@ filename = "signed-bl31.bin"; };
-&uboot_fdt_blob { +&fdt_0_blob { filename = "signed-u-boot.dtb"; };
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 114d243812..bb61e91ac3 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -8,7 +8,7 @@ config NR_DRAM_BANKS
config SOCFPGA_SECURE_VAB_AUTH bool "Enable boot image authentication with Secure Device Manager" - depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X + depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X || TARGET_SOCFPGA_AGILEX5 select FIT_IMAGE_POST_PROCESS select SHA384 select SHA512 @@ -54,10 +54,51 @@ config TARGET_SOCFPGA_AGILEX select BINMAN if SPL_ATF select CLK select FPGA_INTEL_SDM_MAILBOX + select GICV2 select NCORE_CACHE select SPL_CLK if SPL select TARGET_SOCFPGA_SOC64
+config TARGET_SOCFPGA_AGILEX5 + bool + select BINMAN if SPL_ATF + select CLK + select FPGA_INTEL_SDM_MAILBOX + select GICV3 + select NCORE_CACHE + select SPL_CLK if SPL + select TARGET_SOCFPGA_SOC64 + +config TARGET_SOCFPGA_AGILEX5_OOBE2 + bool "Enable build that bootable only on Agilex5 OOBE2 DevKit" + help + This is for Agilex5 platform. + It enable build that bootable only on Agilex5 OOBE2 DevKit. + +config TARGET_SOCFPGA_AGILEX5_NAND2 + bool "Enable build that bootable only on Agilex5 NAND2 DevKit" + help + This is for Agilex5 platform. + Enable build that bootable only on Agilex5 NAND2 DevKit. + +config TARGET_SOCFPGA_AGILEX5_TSN_AIC0 + bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC0 MuDV" + help + This is for Agilex5 platform. + Enable build that bootable only on Agilex5 TSN_PHY_AIC0 MuDV. + +config TARGET_SOCFPGA_AGILEX5_TSN_AIC1 + bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC1 MuDV" + help + This is for Agilex5 platform. + Enable build that bootable only on Agilex5 TSN_PHY_AIC1 MuDV. + +config TARGET_SOCFPGA_AGILEX5_TSN_AIC2 + bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC2 MuDV" + help + This is for Agilex5 platform. + Enable build that bootable only on Agilex5 TSN_PHY_AIC2 MuDV. + config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5 @@ -121,6 +162,25 @@ config TARGET_SOCFPGA_STRATIX10 select FPGA_INTEL_SDM_MAILBOX select TARGET_SOCFPGA_SOC64
+config ARMV8_PSCI_NR_CPUS + default 4 if TARGET_SOCFPGA_SOC64 + +config ARMV8_SECURE_BASE + default 0x00001000 if TARGET_SOCFPGA_SOC64 && ARMV8_PSCI + +config SYS_HAS_ARMV8_SECURE_BASE + default y if TARGET_SOCFPGA_SOC64 && ARMV8_PSCI + +config TARGET_SOCFPGA_AGILEX5 + bool + select BINMAN if SPL_ATF + select CLK + select FPGA_INTEL_SDM_MAILBOX + select GICV3 + select NCORE_CACHE + select SPL_CLK if SPL + select TARGET_SOCFPGA_SOC64 + choice prompt "Altera SOCFPGA board select" optional @@ -129,6 +189,10 @@ config TARGET_SOCFPGA_AGILEX_SOCDK bool "Intel SOCFPGA SoCDK (Agilex)" select TARGET_SOCFPGA_AGILEX
+config TARGET_SOCFPGA_AGILEX5_SOCDK + bool "Intel SOCFPGA SoCDK (Agilex5)" + select TARGET_SOCFPGA_AGILEX5 + config TARGET_SOCFPGA_ARIES_MCVEVK bool "Aries MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -202,6 +266,7 @@ config TARGET_SOCFPGA_TERASIC_SOCKIT endchoice
config SYS_BOARD + default "agilex5-socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "agilex-socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK @@ -223,6 +288,7 @@ config SYS_BOARD default "vining_fpga" if TARGET_SOCFPGA_SOFTING_VINING_FPGA
config SYS_VENDOR + default "intel" if TARGET_SOCFPGA_AGILEX5_SOCDK default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK @@ -245,6 +311,7 @@ config SYS_SOC default "socfpga"
config SYS_CONFIG_NAME + default "socfpga_agilex5_socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "socfpga_agilex_socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "socfpga_arria5_secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index ec38b64dd4..181bb01fdd 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2021 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -94,6 +94,8 @@ obj-y += spl_agilex.o endif ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += spl_n5x.o +ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += spl_soc64.o endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 09e09192fb..616e1afe5d 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -7,9 +7,11 @@
#include <common.h> #include <asm/arch/clock_manager.h> +#include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/secure_vab.h> +#include <asm/arch/smc_api.h> #include <asm/global_data.h> #include <asm/io.h> #include <errno.h> @@ -23,6 +25,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#define DEFAULT_JTAG_USERCODE 0xFFFFFFFF + void s_init(void) { #ifndef CONFIG_ARM64 /* @@ -92,13 +96,50 @@ int g_dnl_board_usb_cable_connected(void) } #endif
-#ifdef CONFIG_SPL_BUILD -__weak int board_fit_config_name_match(const char *name) +u8 socfpga_get_board_id(void) { - /* Just empty function now - can't decide what to choose */ - debug("%s: %s\n", __func__, name); + u8 board_id = 0; + u32 jtag_usercode; + int err;
- return 0; +#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF) + err = smc_get_usercode(&jtag_usercode); +#else + u32 resp_len = 1; + + err = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_GET_USERCODE, MBOX_CMD_DIRECT, 0, + NULL, 0, &resp_len, &jtag_usercode); +#endif + + if (err) { + puts("Fail to read JTAG Usercode. Default Board ID to 0\n"); + return board_id; + } + + debug("Valid JTAG Usercode: %u\n", jtag_usercode); + + if (jtag_usercode == DEFAULT_JTAG_USERCODE) { + debug("JTAG Usercode is not set. Default Board ID to 0\n"); + } else if (jtag_usercode >= 0 && jtag_usercode <= 255) { + board_id = jtag_usercode; + debug("Valid JTAG Usercode. Set Board ID to %u\n", board_id); + } else { + puts("Board ID is not in range 0 to 255\n"); + } + + return board_id; +} + +#if IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_TARGET_SOCFPGA_SOC64) +int board_fit_config_name_match(const char *name) +{ + char board_name[10]; + + sprintf(board_name, "board_%u", socfpga_get_board_id()); + + debug("Board name: %s\n", board_name); + + return strcmp(name, board_name); } #endif
@@ -116,6 +157,8 @@ void board_fit_image_post_process(const void *fit, int node, void **p_image, #if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_FIT) void board_prep_linux(struct bootm_headers *images) { + bool use_fit = false; + if (!images->fit_uname_cfg) { if (IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH) && !IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH_ALLOW_NON_FIT_IMAGE)) { @@ -127,12 +170,13 @@ void board_prep_linux(struct bootm_headers *images) hang(); } } else { + use_fit = true; /* Update fdt_addr in enviroment variable */ env_set_hex("fdt_addr", (ulong)images->ft_addr); debug("images->ft_addr = 0x%08lx\n", (ulong)images->ft_addr); }
- if (IS_ENABLED(CONFIG_CADENCE_QSPI)) { + if (use_fit && IS_ENABLED(CONFIG_CADENCE_QSPI)) { if (env_get("linux_qspi_enable")) run_command(env_get("linux_qspi_enable"), 0); } diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index 3f899fcfa3..8215238ac7 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -1,21 +1,59 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> */
#ifndef _SOCFPGA_SOC64_BASE_HARDWARE_H_ #define _SOCFPGA_SOC64_BASE_HARDWARE_H_
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SOCFPGA_CCU_ADDRESS 0x1c000000 +#define SOCFPGA_F2SDRAM_MGR_ADDRESS 0x18001000 +#define SOCFPGA_SMMU_ADDRESS 0x16000000 +#define SOCFPGA_OCRAM_FIREWALL_ADDRESS 0x108cc400 +#define SOCFPGA_MAILBOX_ADDRESS 0x10a30000 +#define SOCFPGA_UART0_ADDRESS 0x10c02000 +#define SOCFPGA_UART1_ADDRESS 0x10c02100 +#define SOCFPGA_SPTIMER0_ADDRESS 0x10c03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0x10c03100 +#define SOCFPGA_SYSTIMER0_ADDRESS 0x10d00000 +#define SOCFPGA_SYSTIMER1_ADDRESS 0x10d00100 +#define SOCFPGA_L4WD0_ADDRESS 0x10d00200 +#define SOCFPGA_L4WD1_ADDRESS 0x10d00300 +#define SOCFPGA_L4WD2_ADDRESS 0x10d00400 +#define SOCFPGA_L4WD3_ADDRESS 0x10d00500 +#define SOCFPGA_L4WD4_ADDRESS 0x10d00600 +#define SOCFPGA_GTIMER_SEC_ADDRESS 0x10d01000 +#define SOCFPGA_GTIMER_NSEC_ADDRESS 0x10d02000 +#define SOCFPGA_CLKMGR_ADDRESS 0x10d10000 +#define SOCFPGA_RSTMGR_ADDRESS 0x10d11000 +#define SOCFPGA_SYSMGR_ADDRESS 0x10d12000 +#define SOCFPGA_OCRAM_ADDRESS 0x00000000 +#define SOCFPGA_FW_DDR_CCU_DMI0_ADDRESS 0x18000800 +#define SOCFPGA_FW_DDR_CCU_DMI1_ADDRESS 0x18000A00 +#define SOCFPGA_FW_TBU2NOC_ADDRESS 0x18000C00 +#define SOCFPGA_FIREWALL_L4_PER 0x10d21000 +#define SOCFPGA_FIREWALL_L4_SYS 0x10d21100 +#define SOCFPGA_FIREWALL_SOC2FPGA 0x10d21200 +#define SOCFPGA_FIREWALL_LWSOC2FPGA 0x10d21300 +#define SOCFPGA_FIREWALL_TCU 0x10d21400 +#define SOCFPGA_FIREWALL_PRIV_MEMORYMAP_PRIV 0x10d24800 +#define GICD_BASE 0x1d000000 +#define GICR_BASE 0x1d060000 +#else #define SOCFPGA_CCU_ADDRESS 0xf7000000 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 #define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 #define SOCFPGA_SDR_ADDRESS 0xf8011000 +#define SOCFPGA_FW_MPFE_SCR_ADDRESS 0xf8020000 #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ - IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) + IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX7) #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020200 #else #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020100 #endif +#define SOCFPGA_F2SDRAM_MGR_ADDRESS 0xf8024000 #define SOCFPGA_SMMU_ADDRESS 0xfa000000 #define SOCFPGA_MAILBOX_ADDRESS 0xffa30000 #define SOCFPGA_UART0_ADDRESS 0xffc02000 @@ -39,10 +77,12 @@ #define SOCFPGA_FIREWALL_SOC2FPGA 0xffd21200 #define SOCFPGA_FIREWALL_LWSOC2FPGA 0xffd21300 #define SOCFPGA_FIREWALL_TCU 0xffd21400 +#define SOCFPGA_FIREWALL_PRIV_MEMORYMAP_PRIV 0xffd24800 #define SOCFPGA_DMANONSECURE_ADDRESS 0xffda0000 #define SOCFPGA_DMASECURE_ADDRESS 0xffda1000 #define SOCFPGA_OCRAM_ADDRESS 0xffe00000 #define GICD_BASE 0xfffc1000 #define GICC_BASE 0xfffc2000 +#endif /* IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) */
#endif /* _SOCFPGA_SOC64_BASE_HARDWARE_H_ */ diff --git a/board/intel/agilex5-socdk/MAINTAINERS b/board/intel/agilex5-socdk/MAINTAINERS new file mode 100644 index 0000000000..b696f788c8 --- /dev/null +++ b/board/intel/agilex5-socdk/MAINTAINERS @@ -0,0 +1,8 @@ +SOCFPGA BOARD +M: Tien Fong Chee tien.fong.chee@intel.com +M: Teik Heng Chong teik.heng.chong@intel.com +M: Jit Loon Lim jit.loon.lim@intel.com +S: Maintained +F: board/intel/agilex5-socdk/ +F: include/configs/socfpga_agilex5_socdk.h +F: configs/socfpga_agilex5_defconfig diff --git a/board/intel/agilex5-socdk/Makefile b/board/intel/agilex5-socdk/Makefile new file mode 100644 index 0000000000..d598d249e5 --- /dev/null +++ b/board/intel/agilex5-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2024 Intel Corporation <www.intel.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig new file mode 100644 index 0000000000..415c8e4a2b --- /dev/null +++ b/configs/socfpga_agilex5_defconfig @@ -0,0 +1,113 @@ +CONFIG_ARM=y +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x04100000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex5_socdk" +CONFIG_TARGET_SOCFPGA_AGILEX5_SOCDK=y +CONFIG_IDENT_STRING="socfpga_agilex5" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 initrd=0x90000000 root=/dev/ram0 rw init=/sbin/init ramdisk_size=10000000 earlycon panic=-1 nosmp kvm-arm.mode=nvhe" +CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_DOS_PARTITION=y +CONFIG_SPL_DOS_PARTITION=y +CONFIG_SPL_SYS_DISABLE_DCACHE_OPS=y +CONFIG_CMD_MTD=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_DW=y +CONFIG_MISC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_DM_ETH=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=y +CONFIG_USB_XHCI_HCD=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_WDT=y +CONFIG_CMD_WDT=y +CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_SPL_WDT=y +CONFIG_WATCHDOG_AUTOSTART=n +CONFIG_TIMER=y +CONFIG_DESIGNWARE_APB_TIMER=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x7f000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +# CONFIG_EFI_LOADER is not set +CONFIG_I3C=y +CONFIG_DW_I3C_MASTER=y +CONFIG_CMD_I3C=y +CONFIG_SYS_MAXARGS=32 +CONFIG_CMD_TIMER=y diff --git a/include/configs/socfpga_agilex5_socdk.h b/include/configs/socfpga_agilex5_socdk.h new file mode 100644 index 0000000000..b5b5bd767f --- /dev/null +++ b/include/configs/socfpga_agilex5_socdk.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ + +#ifndef __CONFIG_SOCFGPA_AGILEX5_H__ +#define __CONFIG_SOCFGPA_AGILEX5_H__ + +#include <configs/socfpga_soc64_common.h> + +#endif /* __CONFIG_SOCFGPA_AGILEX5_H__ */ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 820372c28b..26a7ad1a5c 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 * - * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> + * Copyright (C) 2017-2024 Intel Corporation <www.intel.com> * */
@@ -14,29 +14,193 @@ /* * U-Boot general configurations */ -/* sysmgr.boot_scratch_cold4 & 5 (64bit) will be used for PSCI_CPU_ON call */ -#define CPU_RELEASE_ADDR 0xFFD12210
/* * U-Boot console configurations */
-/* Extend size of kernel image for uncompression */ - /* * U-Boot run time memory configurations */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define CFG_SYS_INIT_RAM_ADDR 0x0 +#define CFG_SYS_INIT_RAM_SIZE 0x80000 +#else #define CFG_SYS_INIT_RAM_ADDR 0xFFE00000 #define CFG_SYS_INIT_RAM_SIZE 0x40000 +#endif
/* * U-Boot environment configurations */ +/* + * NAND support + */ +#ifdef CONFIG_NAND_DENALI +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define CFG_SYS_NAND_U_BOOT_SIZE (1 * 1024 * 1024) +#define CFG_SYS_NAND_U_BOOT_DST CONFIG_TEXT_BASE +#endif /* CONFIG_NAND_DENALI */
/* * Environment variable */ +#if IS_ENABLED(CONFIG_SPL_ATF) +#define CONFIG_BOOTFILE "kernel.itb" +#else +#define CONFIG_BOOTFILE "Image" +#endif + +#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS) +#if IS_ENABLED(CONFIG_CMD_MMC) +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if IS_ENABLED(CONFIG_CMD_SF) +#define BOOT_TARGET_DEVICES_QSPI(func) func(QSPI, qspi, na) +#else +#define BOOT_TARGET_DEVICES_QSPI(func) +#endif + +#define BOOTENV_DEV_QSPI(devtypeu, devtypel, instance) \ + "bootcmd_qspi=ubi detach; sf probe && " \ + "setenv mtdids 'nor0=nor0,nand0=nand.0' && " \ + "setenv mtdparts 'mtdparts=nor0:66m(u-boot),190m(root);" \ + "nand.0:2m(u-boot),500m(nand_root)' && env select UBI; saveenv && " \ + "ubi part root && " \ + "if ubi part root && ubi readvol ${scriptaddr} script; " \ + "then echo QSPI: Running script from UBIFS; " \ + "elif sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize}; " \ + "then echo QSPI: Running script from JFFS2; fi; " \ + "echo QSPI: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo QSPI: SCRIPT FAILED: continuing...; ubi detach;\0" + +#define BOOTENV_DEV_NAME_QSPI(devtypeu, devtypel, instance) \ + "qspi " + +#if IS_ENABLED(CONFIG_CMD_NAND) +# define BOOT_TARGET_DEVICES_NAND(func) func(NAND, nand, na) +#else +# define BOOT_TARGET_DEVICES_NAND(func) +#endif + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_nand=ubi detach && " \ + "setenv mtdids 'nor0=nor0,nand0=nand.0' && " \ + "setenv mtdparts 'mtdparts=nor0:66m(u-boot),190m(qspi_root);" \ + "nand.0:2m(u-boot),500m(root)' && env select UBI; saveenv && " \ + "ubi part root && " \ + "ubi readvol ${scriptaddr} script && " \ + "echo NAND: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo NAND: SCRIPT FAILED: continuing...; ubi detach;\0" + +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + "nand " + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_QSPI(func) \ + BOOT_TARGET_DEVICES_NAND(func) + +#include <config_distro_bootcmd.h> + +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + #define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x82000000\0" \ + "fdt_addr_r=0x86000000\0" \ + "qspiscriptaddr=0x02110000\0" \ + "scriptsize=0x00010000\0" \ + "qspibootimageaddr=0x02120000\0" \ + "bootimagesize=0x03200000\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@108d2000 status okay;" \ + "if fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ + "scriptaddr=0x81000000\0" \ + "scriptfile=boot.scr\0" \ + "nandroot=ubi0:rootfs\0" \ + "nandfitboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1; " \ + "bootm ${loadaddr}\0" \ + "nandfitload=ubi part root; ubi readvol ${loadaddr} kernel\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "rsu_status=rsu dtb; rsu display_dcmf_version; "\ + "rsu display_dcmf_status; rsu display_max_retry\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " \ + BOOTENV + +#else + +#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x2000000\0" \ + "fdt_addr_r=0x6000000\0" \ + "qspiscriptaddr=0x02110000\0" \ + "scriptsize=0x00010000\0" \ + "qspibootimageaddr=0x02120000\0" \ + "bootimagesize=0x03200000\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@ff8d2000 status okay;" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ + "scriptaddr=0x05FF0000\0" \ + "scriptfile=boot.scr\0" \ + "nandroot=ubi0:rootfs\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "rsu_status=rsu dtb; rsu display_dcmf_version; "\ + "rsu display_dcmf_status; rsu display_max_retry\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " \ + BOOTENV +#endif /*#IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)*/ + +#else + +#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_comp_addr_r=0x9000000\0" \ + "kernel_comp_size=0x01000000\0" \ + "qspibootimageaddr=0x020E0000\0" \ + "qspifdtaddr=0x020D0000\0" \ + "bootimagesize=0x01F00000\0" \ + "fdtimagesize=0x00010000\0" \ + "qspiload=sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize};" \ + "sf read ${fdt_addr} ${qspifdtaddr} ${fdtimagesize}\0" \ + "qspiboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \ + "rootfstype=jffs2 rootwait;booti ${loadaddr} - ${fdt_addr}\0" \ + "qspifitload=sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize}\0" \ + "qspifitboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \ + "rootfstype=jffs2 rootwait;bootm ${loadaddr}\0" \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "bootfile=" CONFIG_BOOTFILE "\0" \ "fdt_addr=8000000\0" \ @@ -53,24 +217,51 @@ "bootm ${loadaddr}\0" \ "mmcfitload=mmc rescan;" \ "load mmc 0:1 ${loadaddr} ${bootfile}\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "linux_qspi_enable=if sf probe; then " \ "echo Enabling QSPI at Linux DTB...;" \ "fdt addr ${fdt_addr}; fdt resize;" \ "fdt set /soc/spi@ff8d2000 status okay;" \ - "fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency " \ - " ${qspi_clock}; fi; \0" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " elif fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; then echo QSPI clock frequency updated;" \ + " else fdt set /clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \ "scriptaddr=0x02100000\0" \ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ - "then source ${scriptaddr}; fi\0" \ - "socfpga_legacy_reset_compat=1\0" + "then source ${scriptaddr}:script; fi\0" \ + "nandroot=ubi0:rootfs\0" \ + "nandload=ubi part root; ubi readvol ${loadaddr} kernel; ubi readvol ${fdt_addr} dtb\0" \ + "nandboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1; " \ + "booti ${loadaddr} - ${fdt_addr}\0" \ + "nandfitboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1; " \ + "bootm ${loadaddr}\0" \ + "nandfitload=ubi part root; ubi readvol ${loadaddr} kernel\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "rsu_status=rsu dtb; rsu display_dcmf_version; "\ + "rsu display_dcmf_status; rsu display_max_retry\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " +#endif /*#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS)*/
/* * External memory configurations */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) +#define CFG_SYS_SDRAM_BASE 0x80000000 +#else #define PHYS_SDRAM_1 0x0 #define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) #define CFG_SYS_SDRAM_BASE 0 +#endif
/* * Serial / UART configurations
-----Original Message----- From: Lim, Jit Loon jit.loon.lim@intel.com Sent: Monday, February 26, 2024 3:07 PM To: u-boot@lists.denx.de Cc: Jagan Teki jagan@amarulasolutions.com; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Maniyam, Dinesh dinesh.maniyam@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Chong, Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com; Bin Meng bmeng.cn@gmail.com Subject: [PATCH v2 1/1] arch:arm: Agilex5 enablement
This patch is to enable Agilex5 platform for Intel product. Changes, modification and new files are created for board, dts, configs and makefile to create the base for Agilex5.
Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com
Changes v1 -> v2:
- fixed git auto merge issue
arch/arm/Kconfig | 13 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 458 ++++++++++++ arch/arm/dts/socfpga_agilex5.dtsi | 654 ++++++++++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 144 ++++ arch/arm/dts/socfpga_agilex5_socdk.dts | 163 +++++ arch/arm/dts/socfpga_soc64_fit-u-boot.dtsi | 38 +- arch/arm/mach-socfpga/Kconfig | 69 +- arch/arm/mach-socfpga/Makefile | 4 +- arch/arm/mach-socfpga/board.c | 56 +- .../include/mach/base_addr_soc64.h | 44 +- board/intel/agilex5-socdk/MAINTAINERS | 8 + board/intel/agilex5-socdk/Makefile | 7 + configs/socfpga_agilex5_defconfig | 113 +++ include/configs/socfpga_agilex5_socdk.h | 12 + include/configs/socfpga_soc64_common.h | 209 +++++- 16 files changed, 1957 insertions(+), 36 deletions(-) create mode 100644 arch/arm/dts/socfpga_agilex5-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_agilex5_socdk.dts create mode 100644 board/intel/agilex5-socdk/MAINTAINERS create mode 100644 board/intel/agilex5-socdk/Makefile create mode 100644 configs/socfpga_agilex5_defconfig create mode 100644 include/configs/socfpga_agilex5_socdk.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fde85dc0d5..baecb0463d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -28,6 +28,7 @@ config COUNTER_FREQUENCY ROCKCHIP_RK3288 || ROCKCHIP_RK322X || ROCKCHIP_RK3036 default 25000000 if ARCH_LX2160A || ARCH_LX2162A || ARCH_LS1088A default 100000000 if ARCH_ZYNQMP
- default 200000000 if ARCH_SOCFPGA && ARM64 &&
TARGET_SOCFPGA_AGILEX5 default 0 help For platforms with ARMv8-A and ARMv7-A which features a system @@ -1116,6 +1117,8 @@ config ARCH_SOCFPGA select SPL_LIBGENERIC_SUPPORT select SPL_OF_CONTROL select SPL_SEPARATE_BSS if TARGET_SOCFPGA_SOC64
- select SPL_DRIVERS_MISC if TARGET_SOCFPGA_SOC64
- select SPL_SOCFPGA_SEC_REG if TARGET_SOCFPGA_SOC64 select SPL_SERIAL select SPL_SYSRESET select SPL_WATCHDOG
@@ -1124,7 +1127,8 @@ config ARCH_SOCFPGA select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select SYSRESET select SYSRESET_SOCFPGA if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10
- select SYSRESET_SOCFPGA_SOC64 if TARGET_SOCFPGA_SOC64
- select SYSRESET_SOCFPGA_SOC64 if !TARGET_SOCFPGA_AGILEX5 &&
- imply SYSRESET_SOCFPGA_AGILEX5 if TARGET_SOCFPGA_AGILEX5 imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFY
@@ -1158,7 +1162,9 @@ config ARCH_SUNXI select DM_SPI_FLASH if SPI && MTD select DM_KEYBOARD select DM_MMC if MMC
- select DM_SCSI if SCSI select DM_SERIAL
- select GPIO_EXTRA_HEADER select OF_BOARD_SETUP select OF_CONTROL select OF_SEPARATE
@@ -1865,7 +1871,7 @@ config TARGET_SL28 select PCI select DM_RNG select DM_RTC
- select SCSI
- select DM_SCSI select DM_SERIAL select DM_SPI select GPIO_EXTRA_HEADER
@@ -2082,6 +2088,7 @@ config TARGET_POMELO select PCI select DM_PCI select SCSI
- select DM_SCSI select DM_SERIAL imply CMD_PCI help
@@ -2375,4 +2382,4 @@ source "board/xen/xenguest_arm64/Kconfig"
source "arch/arm/Kconfig.debug"
-endmenu +endmenu \ No newline at end of file diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9725030d5..2b4f896ad2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_TARGET_THUNDERX_88XX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_agilex_socdk.dtb \
- socfpga_agilex5_socdk.dtb \ socfpga_arria5_secu1.dtb \ socfpga_arria5_socdk.dtb \ socfpga_arria10_chameleonv3_270_2.dtb \
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi new file mode 100644 index 0000000000..daa8c982da --- /dev/null +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -0,0 +1,458 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- U-Boot additions
- Copyright (C) 2024 Intel Corporation <www.intel.com>
+#include "socfpga_soc64_fit-u-boot.dtsi"
- memory {
#size-cells = <2>;
bootph-all;
- soc {
bootph-all;
/* socfpga_secreg: socfpga-secreg { */
/* compatible = "intel,socfpga-secreg"; */
/* #address-cells = <1>; */
/* #size-cells = <1>; */
/* bootph-all; */
/* DSU */
i_ccu_caiu0@1c000000 {
reg = <0x1c000000 0x00001000>;
/* CAIUAMIGR */
0x0000001f>,
/* CAIUMIFSR */
0x07070777>,
/* DII1_MPFEREGS */
0x000000ff>,
0xc1f03e1f>,
/* DII2_GICREGS */
<0x00000424 0x0001d000 0xffffffff>,
<0x00000428 0x00000000
0x000000ff>,
<0x00000420 0xc0800400
0xc1f03e1f>,
/* NCAIU0_LWSOC2FPGA */
<0x00000444 0x00020000 0xffffffff>,
<0x00000448 0x00000000
0x000000ff>,
<0x00000440 0xc1100006
0xc1f03e1f>,
/* NCAIU0_SOC2FPGA_1G */
<0x00000454 0x00040000 0xffffffff>,
<0x00000458 0x00000000
0x000000ff>,
<0x00000450 0xc1200006
0xc1f03e1f>,
/* DMI_SDRAM_2G */
0x000000ff>,
0xc1f03e1f>,
/* NCAIU0_SOC2FPGA_16G */
<0x00000474 0x00400000 0xffffffff>,
<0x00000478 0x00000000
0x000000ff>,
<0x00000470 0xc1600006
0xc1f03e1f>,
/* DMI_SDRAM_30G */
0x000000ff>,
0xc1f03e1f>,
/* NCAIU0_SOC2FPGA_256G */
<0x00000494 0x04000000 0xffffffff>,
<0x00000498 0x00000000
0x000000ff>,
<0x00000490 0xc1a00006
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>;
bootph-all;
/* FPGA2SOC */
i_ccu_ncaiu0@1c001000 {
reg = <0x1c001000 0x00001000>;
/* NCAIU0AMIGR */
0x0000001f>,
/* NCAIU0MIFSR */
0x07070777>,
/* PSS */
<0x00000404 0x00010000 0xffffffff>,
<0x00000408 0x00000000
0x000000ff>,
<0x00000400 0xC0F00000
0xc1f03e1f>,
/* DII1_MPFEREGS */
<0x00000414 0x00018000 0xffffffff>,
<0x00000418 0x00000000
0x000000ff>,
<0x00000410 0xc0e00200
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_2G */
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_30G */
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>;
bootph-all;
/* GIC_M */
i_ccu_ncaiu1@1c002000 {
reg = <0x1c002000 0x00001000>;
/* NCAIU1AMIGR */
<0x000003c0 0x00000003
0x0000001f>,
/* NCAIU1MIFSR */
<0x000003c4 0x00000000
0x07070777>,
/* DMI_SDRAM_2G */
<0x00000464 0x00080000 0xffffffff>,
<0x00000468 0x00000000
0x000000ff>,
<0x00000460 0x81300006
0xc1f03e1f>,
/* DMI_SDRAM_30G */
<0x00000484 0x00800000 0xffffffff>,
<0x00000488 0x00000000
0x000000ff>,
<0x00000480 0x81700006
0xc1f03e1f>,
/* DMI_SDRAM_480G */
<0x000004a4 0x08000000 0xffffffff>,
<0x000004a8 0x00000000
0x000000ff>,
<0x000004a0 0x81b00006
0xc1f03e1f>;
bootph-all;
/* PSS NOC */
i_ccu_ncaiu3@1c004000 {
reg = <0x1c004000 0x00001000>;
/* NCAIU3AMIGR */
0x0000001f>,
/* NCAIU3MIFSR */
0x07070777>,
/* DII1_MPFEREGS */
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_2G */
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_30G */
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>;
bootph-all;
/* DCE0 */
i_ccu_dce0@1c005000 {
reg = <0x1c005000 0x00001000>;
/* DCEUAMIGR0 */
0x0000001f>,
/* DCEUMIFSR0 */
0x07070777>,
/* DMI_SDRAM_2G */
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_30G */
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>;
bootph-all;
/* DCE1 */
i_ccu_dce1@1c006000 {
reg = <0x1c006000 0x00001000>;
/* DCEUAMIGR1 */
0x0000001f>,
/* DCEUMIFSR1 */
0x07070777>,
/* DMI_SDRAM_2G */
0x000000ff>,
0xc1f03e1f>,
/* DMI_SDRAM_30G */
0x000000ff>,
0xc1f03e1f>,
0x000000ff>,
0xc1f03e1f>;
bootph-all;
/* DMI0 */
i_ccu_dmi0@1c007000 {
reg = <0x1c007000 0x00001000>;
/* DMIUSMCTCR */
<0x00000300 0x00000003
0x00000003>;
bootph-all;
/* DMI1 */
i_ccu_dmi0@1c008000 {
reg = <0x1c008000 0x00001000>;
/* DMIUSMCTCR */
0x00000003>;
bootph-all;
/* L4 peripherals firewall */
noc_fw_l4_per@10d21000 {
reg = <0x10d21000 0x0000008c>;
/* NAND */
0x01010001>,
/* USB0 */
0x01010001>,
/* USB1 */
0x01010001>,
/* SPI_MAIN0 */
<0x0000001c 0x01010301
0x01010301>,
/* SPI_MAIN1 */
<0x00000020 0x01010301
0x01010301>,
/* SPI_SECONDARY0 */
<0x00000024 0x01010301
0x01010301>,
/* SPI_SECONDARY1 */
<0x00000028 0x01010301
0x01010301>,
/* EMAC0 */
0x01010001>,
/* EMAC1 */
0x01010001>,
/* EMAC2 */
0x01010001>,
/* SDMMC */
0x01010001>,
/* GPIO0 */
<0x00000044 0x01010301
0x01010301>,
/* GPIO1 */
<0x00000048 0x01010301
0x01010301>,
/* I2C0 */
<0x00000050 0x01010301
0x01010301>,
/* I2C1 */
<0x00000054 0x01010301
0x01010301>,
/* I2C2 */
<0x00000058 0x01010301
0x01010301>,
/* I2C3 */
<0x0000005c 0x01010301
0x01010301>,
/* I2C4 */
0x01010301>,
/* SP_TIMER0 */
0x01010301>,
/* SP_TIMER1 */
0x01010301>,
/* UART0 */
0x01010301>,
/* UART1 */
0x01010301>,
/* I3C0 */
0x01010301>,
/* I3C1 */
<0x00000078 0x01010301
0x01010301>,
/* DMA0 */
<0x0000007c 0x01010001
0x01010001>,
/* DMA1 */
0x01010001>,
/* COMBO_PHY */
0x01010001>,
/* NAND_SDMA */
<0x00000088 0x01010301
0x01010301>;
bootph-all;
/* L4 system firewall */
noc_fw_l4_sys@10d21100 {
reg = <0x10d21100 0x00000098>;
/* DMA_ECC */
<0x00000008 0x01010001
0x01010001>,
/* EMAC0RX_ECC */
<0x0000000c 0x01010001
0x01010001>,
/* EMAC0TX_ECC */
<0x00000010 0x01010001
0x01010001>,
/* EMAC1RX_ECC */
<0x00000014 0x01010001
0x01010001>,
/* EMAC1TX_ECC */
<0x00000018 0x01010001
0x01010001>,
/* EMAC2RX_ECC */
<0x0000001c 0x01010001
0x01010001>,
/* EMAC2TX_ECC */
<0x00000020 0x01010001
0x01010001>,
/* NAND_ECC */
<0x0000002c 0x01010001
0x01010001>,
/* NAND_READ_ECC */
<0x00000030 0x01010001
0x01010001>,
/* NAND_WRITE_ECC */
<0x00000034 0x01010001
0x01010001>,
/* OCRAM_ECC */
<0x00000038 0x01010001
0x01010001>,
/* SDMMC_ECC */
<0x00000040 0x01010001
0x01010001>,
/* USB0_ECC */
<0x00000044 0x01010001
0x01010001>,
/* USB1_CACHEECC */
<0x00000048 0x01010001
0x01010001>,
/* CLOCK_MANAGER */
<0x0000004c 0x01010001
0x01010001>,
/* IO_MANAGER */
<0x00000054 0x01010001
0x01010001>,
/* RESET_MANAGER */
<0x00000058 0x01010001
0x01010001>,
/* SYSTEM_MANAGER */
<0x0000005c 0x01010001
0x01010001>,
/* OSC0_TIMER */
<0x00000060 0x01010301
0x01010301>,
/* OSC1_TIMER0*/
<0x00000064 0x01010301
0x01010301>,
/* WATCHDOG0 */
<0x00000068 0x01010301
0x01010301>,
/* WATCHDOG1 */
<0x0000006c 0x01010301
0x01010301>,
/* WATCHDOG2 */
<0x00000070 0x01010301
0x01010301>,
/* WATCHDOG3 */
<0x00000074 0x01010301
0x01010301>,
/* DAP */
<0x00000078 0x03010001
0x03010001>,
/* WATCHDOG4 */
<0x0000007c 0x01010301
0x01010301>,
/* POWER_MANAGER */
<0x00000080 0x01010001
0x01010001>,
/* USB1_RXECC */
<0x00000084 0x01010001
0x01010001>,
/* USB1_TXECC */
<0x00000088 0x01010001
0x01010001>,
/* L4_NOC_PROBES */
<0x00000090 0x01010001
0x01010001>,
/* L4_NOC_QOS */
<0x00000094 0x01010001
0x01010001>;
bootph-all;
/* Light weight SoC2FPGA */
noc_fw_lwsoc2fpga@10d21300 {
reg = <0x10d21300 0x0000004>;
/* LWSOC2FPGA_CSR */
<0x00000000 0x0ffe0301>;
bootph-all;
/* SoC2FPGA */
/* SOC2FPGA_CSR */
0x0ffe0301>;
bootph-all;
/* TCU */
/* TCU_CSR */
0x01010001>;
bootph-all;
+&clkmgr {
- bootph-all;
+&i2c0 {
- reset-names = "i2c";
+&i2c1 {
+&i2c2 {
+&i2c3 {
+&mmc {
- resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>;
+&porta {
- bank-name = "porta";
+&portb {
- bank-name = "portb";
+&qspi {
- bootph-all;
+&rst {
- compatible = "altr,rst-mgr";
- altr,modrst-offset = <0x24>;
- bootph-all;
+&sdr {
- compatible = "intel,sdr-ctl-agilex5";
- reg = <0x18000000 0x400000>,
- resets = <&rst DDRSCH_RESET>;
- bootph-all;
+&sysmgr {
- compatible = "altr,sys-mgr", "syscon";
- bootph-all;
+&uart0 {
- bootph-all;
+&watchdog0 {
- bootph-all;
- compatible = "intel,socfpga-agilex";
- #address-cells = <2>;
- #size-cells = <2>;
- reserved-memory {
#size-cells = <2>;
ranges;
no-map;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
cpu1: cpu@1 {
reg = <0x1>;
cpu2: cpu@2 {
reg = <0x2>;
cpu3: cpu@3 {
reg = <0x3>;
- pmu {
<0 171 4>,
<0 172 4>,
<0 173 4>;
<&cpu1>,
<&cpu2>,
<&cpu3>;
- psci {
method = "smc";
- intc: intc@fffc1000 {
- soc {
#size-cells = <1>;
base_fpga_region {
#clock-cells = <1>;
clocks {
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
osc1: osc1 {
#clock-cells = <0>;
#clock-cells = <0>;
EMAC0_OCP_RESET>;
iommus = <&smmu 1>;
EMAC1_OCP_RESET>;
iommus = <&smmu 2>;
EMAC2_OCP_RESET>;
iommus = <&smmu 3>;
#size-cells = <0>;
gpio-controller;
#gpio-cells = <2>;
reg = <0>;
#size-cells = <0>;
gpio-controller;
#gpio-cells = <2>;
reg = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
max_devices = <11>;
#size-cells = <0>;
max_devices = <11>;
#phy-cells = <0>;
phy-type = <1>;
#size-cells = <0>;
iommus = <&smmu 5>;
#size-cells = <0>;
COMBOPHY_RESET>;
#reset-cells = <1>;
#iommu-cells = <1>;
ssi";
#size-cells = <0>;
reg-io-width = <4>;
num-cs = <4>;
ssi";
#size-cells = <0>;
reg-io-width = <4>;
num-cs = <4>;
/* Local timer */
timer {
<1 14 0xf08>,
<1 11 0xf08>,
<1 10 0xf08>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
usbphy0: usbphy@0 {
#phy-cells = <0>;
phys = <&usbphy0>;
USB0_OCP_RESET>;
iommus = <&smmu 6>;
dr_mode = "host";
sdr: sdr@10d21000 {
eccmgr {
#size-cells = <1>;
ranges;
sdramedac {
interrupts = <1 4>;
usb0-ecc@ff8c4000 {
interrupts = <2 4>;
interrupts = <4 4>;
interrupts = <5 4>;
<15 4>;
#size-cells = <0>;
firmware {
svc {
method = "smc";
fpga-mgr";
- U-Boot additions
- aliases {
spi0 = &qspi;
- soc {
- memory {
/* 8GB */
- chosen {
+&flash0 {
- compatible = "jedec,spi-nor";
- spi-tx-bus-width = <4>;
- spi-rx-bus-width = <4>;
- bootph-all;
- /delete-property/ cdns,read-delay;
+&flash1 {
- bootph-all;
+&i3c0 {
- bootph-all;
+&i3c1 {
- bootph-all;
+&mmc {
- status = "okay";
- bus-width = <4>;
- sd-uhs-sdr50;
- cap-mmc-highspeed;
- bootph-all;
+&combophy0 {
- status = "okay";
- bootph-all;
- cdns,phy-use-ext-lpbk-dqs = <1>;
- cdns,phy-use-lpbk-dqs = <1>;
- cdns,phy-use-phony-dqs = <1>;
- cdns,phy-use-phony-dqs-cmd = <1>;
- cdns,phy-io-mask-always-on = <0>;
- cdns,phy-io-mask-end = <5>;
- cdns,phy-io-mask-start = <0>;
- cdns,phy-data-select-oe-end = <1>;
- cdns,phy-sync-method = <1>;
- cdns,phy-sw-half-cycle-shift = <0>;
- cdns,phy-rd-del-sel = <52>;
- cdns,phy-underrun-suppress = <1>;
- cdns,phy-gate-cfg-always-on = <1>;
- cdns,phy-param-dll-bypass-mode = <1>;
- cdns,phy-param-phase-detect-sel = <2>;
- cdns,phy-param-dll-start-point = <254>;
- cdns,phy-read-dqs-cmd-delay = <0>;
- cdns,phy-clk-wrdqs-delay = <0>;
- cdns,phy-clk-wr-delay = <0>;
- cdns,phy-read-dqs-delay = <0>;
- cdns,phy-phony-dqs-timing = <0>;
- cdns,hrs09-rddata-en = <1>;
- cdns,hrs09-rdcmd-en = <1>;
- cdns,hrs09-extended-wr-mode = <1>;
- cdns,hrs09-extended-rd-mode = <1>;
- cdns,hrs10-hcsdclkadj = <3>;
- cdns,hrs16-wrdata1-sdclk-dly = <0>;
- cdns,hrs16-wrdata0-sdclk-dly = <0>;
- cdns,hrs16-wrcmd1-sdclk-dly = <0>;
- cdns,hrs16-wrcmd0-sdclk-dly = <0>;
- cdns,hrs16-wrdata1-dly = <0>;
- cdns,hrs16-wrdata0-dly = <0>;
- cdns,hrs16-wrcmd1-dly = <0>;
- cdns,hrs16-wrcmd0-dly = <0>;
- cdns,hrs07-rw-compensate = <10>;
- cdns,hrs07-idelay-val = <0>;
+&qspi {
- status = "okay";
+&nand {
- bootph-all;
+&timer0 {
- bootph-all;
+&timer1 {
- bootph-all;
+&timer2 {
- bootph-all;
+&timer3 {
- bootph-all;
+&watchdog0 {
- bootph-all;
- filename = "arch/arm/dts/socfpga_agilex5_socdk.dtb";
+&binman {
- /delete-node/ kernel;
+}; +#endif
- model = "SoCFPGA Agilex5 SoCDK";
- aliases {
serial0 = &uart0;
ethernet0 = &gmac0;
ethernet2 = &gmac2;
- leds {
hps0 {
label = "hps_led0";
hps1 {
label = "hps_led1";
hps2 {
label = "hps_led2";
- memory {
reg = <0 0 0 0>;
- soc {
clocks {
osc1 {
+&gpio0 {
- status = "okay";
+&gpio1 {
- status = "okay";
+&i2c0 {
- status = "okay";
+&i2c1 {
- status = "okay";
+&i3c0 {
- status = "okay";
+&i3c1 {
- status = "okay";
+&uart0 {
- status = "okay";
+&usbphy0 {
- status = "okay";
+&usb0 {
- status = "okay";
- disable-over-current;
+&watchdog0 {
- status = "okay";
+&watchdog1 {
- status = "okay";
+&watchdog2 {
- status = "okay";
+&watchdog3 {
- status = "okay";
+&watchdog4 {
- status = "okay";
+&timer0 {
- status = "okay";
+&timer1 {
- status = "okay";
+&timer2 {
- status = "okay";
+&timer3 {
- status = "okay";
+&spi0 {
- status = "okay";
+&spi1 {
- status = "okay";
+&qspi {
- flash0: flash@0 {
#size-cells = <1>;
reg = <0>;
m25p,fast-read;
partitions {
#size-cells = <1>;
label = "u-boot";
label = "root";
- U-Boot additions
- Copyright (C) 2020 Intel Corporation <www.intel.com>
images {
#if
#if
fdt {
device-tree";
fdt-0 {
configurations {
default = "conf";
conf {
board-0 {
fdt = "fdt";
"uboot";
load = <0x4080000>;
load = <0x6000000>;
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach- socfpga/Kconfig index 114d243812..bb61e91ac3 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -8,7 +8,7 @@ config NR_DRAM_BANKS
- depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X ||
- select GICV2 select NCORE_CACHE select SPL_CLK if SPL select TARGET_SOCFPGA_SOC64
- bool
- select BINMAN if SPL_ATF
- select CLK
- select FPGA_INTEL_SDM_MAILBOX
- select GICV3
- select NCORE_CACHE
- select SPL_CLK if SPL
- select TARGET_SOCFPGA_SOC64
- bool "Enable build that bootable only on Agilex5 OOBE2 DevKit"
- help
- bool "Enable build that bootable only on Agilex5 NAND2 DevKit"
- help
- bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC0
MuDV"
- help
- bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC1
MuDV"
- help
- bool "Enable build that bootable only on Agilex5 TSN_PHY_AIC2
MuDV"
- help
- default 4 if TARGET_SOCFPGA_SOC64
- default 0x00001000 if TARGET_SOCFPGA_SOC64 && ARMV8_PSCI
- default y if TARGET_SOCFPGA_SOC64 && ARMV8_PSCI
- bool
- select CLK
- select GICV3
- bool "Intel SOCFPGA SoCDK (Agilex5)"
- select TARGET_SOCFPGA_AGILEX5
config SYS_BOARD
- default "agilex5-socdk" if TARGET_SOCFPGA_AGILEX5_SOCDK default "agilex-socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK
config SYS_VENDOR
- default "intel" if TARGET_SOCFPGA_AGILEX5_SOCDK default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK
- default "socfpga_agilex5_socdk" if
TARGET_SOCFPGA_AGILEX5_SOCDK default "socfpga_agilex_socdk" if TARGET_SOCFPGA_AGILEX_SOCDK default "socfpga_arria5_secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index ec38b64dd4..181bb01fdd 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2021 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -94,6 +94,8 @@ obj-y += spl_agilex.o endif ifdef CONFIG_TARGET_SOCFPGA_N5X obj-y += spl_n5x.o +ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 +obj-y += spl_soc64.o endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach- socfpga/board.c index 09e09192fb..616e1afe5d 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -7,9 +7,11 @@
- u8 board_id = 0;
- u32 jtag_usercode;
- int err;
- err = smc_get_usercode(&jtag_usercode);
+#else
- u32 resp_len = 1;
- err = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_GET_USERCODE,
MBOX_CMD_DIRECT, 0,
- if (err) {
return board_id;
- debug("Valid JTAG Usercode: %u\n", jtag_usercode);
- if (jtag_usercode == DEFAULT_JTAG_USERCODE) {
- } else if (jtag_usercode >= 0 && jtag_usercode <= 255) {
board_id);
- } else {
- return board_id;
- char board_name[10];
- sprintf(board_name, "board_%u", socfpga_get_board_id());
- debug("Board name: %s\n", board_name);
- return strcmp(name, board_name);
} #endif
- bool use_fit = false;
- if (!images->fit_uname_cfg) { if (IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH) &&
!IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH_ALLOW_NON_FIT_IMA GE)) { @@ -127,12 +170,13 @@ void board_prep_linux(struct bootm_headers *images) hang(); } } else {
/* Update fdt_addr in enviroment variable */ env_set_hex("fdt_addr", (ulong)images->ft_addr); debug("images->ft_addr = 0x%08lx\n", (ulong)images-use_fit = true;
ft_addr);
- if (use_fit && IS_ENABLED(CONFIG_CADENCE_QSPI)) { if (env_get("linux_qspi_enable")) run_command(env_get("linux_qspi_enable"), 0); }
- Copyright (C) 2016-2021 Intel Corporation <www.intel.com>
- Copyright (C) 2016-2024 Intel Corporation <www.intel.com>
- IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) || \
- IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX7)
#endif /* _SOCFPGA_SOC64_BASE_HARDWARE_H_ */ diff --git a/board/intel/agilex5-socdk/MAINTAINERS b/board/intel/agilex5- socdk/MAINTAINERS new file mode 100644 index 0000000000..b696f788c8 --- /dev/null +++ b/board/intel/agilex5-socdk/MAINTAINERS @@ -0,0 +1,8 @@ +SOCFPGA BOARD +M: Tien Fong Chee tien.fong.chee@intel.com +M: Teik Heng Chong teik.heng.chong@intel.com +M: Jit Loon Lim jit.loon.lim@intel.com +S: Maintained +F: board/intel/agilex5-socdk/ +F: include/configs/socfpga_agilex5_socdk.h +F: configs/socfpga_agilex5_defconfig diff --git a/board/intel/agilex5-socdk/Makefile b/board/intel/agilex5- socdk/Makefile new file mode 100644 index 0000000000..d598d249e5 --- /dev/null +++ b/board/intel/agilex5-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2024 Intel Corporation <www.intel.com> +# +# SPDX-License-Identifier: GPL-2.0 +#
- Copyright (C) 2017-2019 Intel Corporation <www.intel.com>
- Copyright (C) 2017-2024 Intel Corporation <www.intel.com>
- U-Boot general configurations
- U-Boot console configurations
- U-Boot run time memory configurations
- U-Boot environment configurations
- NAND support
- Environment variable
- "bootcmd_qspi=ubi detach; sf probe && " \
- "setenv mtdids 'nor0=nor0,nand0=nand.0' && " \
- "setenv mtdparts 'mtdparts=nor0:66m(u-boot),190m(root);" \
- "nand.0:2m(u-boot),500m(nand_root)' && env select UBI; saveenv
- "ubi part root && " \
- "if ubi part root && ubi readvol ${scriptaddr} script; " \
- "then echo QSPI: Running script from UBIFS; " \
- "elif sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize}; " \
- "then echo QSPI: Running script from JFFS2; fi; " \
- "echo QSPI: Trying to boot script at ${scriptaddr} && " \
- "source ${scriptaddr}; " \
- "echo QSPI: SCRIPT FAILED: continuing...; ubi detach;\0"
- "qspi "
- "bootcmd_nand=ubi detach && " \
- "setenv mtdparts 'mtdparts=nor0:66m(u-boot),190m(qspi_root);" \
- "nand.0:2m(u-boot),500m(root)' && env select UBI; saveenv && " \
- "ubi readvol ${scriptaddr} script && " \
- "echo NAND: Trying to boot script at ${scriptaddr} && " \
- "echo NAND: SCRIPT FAILED: continuing...; ubi detach;\0"
- "nand "
- BOOT_TARGET_DEVICES_MMC(func) \
- BOOT_TARGET_DEVICES_QSPI(func) \
- BOOT_TARGET_DEVICES_NAND(func)
- "kernel_addr_r=0x82000000\0" \
- "fdt_addr_r=0x86000000\0" \
- "qspiscriptaddr=0x02110000\0" \
- "scriptsize=0x00010000\0" \
- "qspibootimageaddr=0x02120000\0" \
- "bootimagesize=0x03200000\0" \
- "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
- "bootfile=" CONFIG_BOOTFILE "\0" \
- "mmcroot=/dev/mmcblk0p2\0" \
- "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \
- "linux_qspi_enable=if sf probe; then " \
- "scriptaddr=0x81000000\0" \
- "scriptfile=boot.scr\0" \
- "nandroot=ubi0:rootfs\0" \
- "nandfitboot=setenv bootargs " CONFIG_BOOTARGS \
ubi.mtd=1; " \
- "nandfitload=ubi part root; ubi readvol ${loadaddr} kernel\0" \
- "socfpga_legacy_reset_compat=1\0" \
- "rsu_status=rsu dtb; rsu display_dcmf_version; "\
- "smc_fid_rd=0xC2000007\0" \
- "smc_fid_wr=0xC2000008\0" \
- "smc_fid_upd=0xC2000009\0 " \
- BOOTENV
+#else
- "kernel_addr_r=0x2000000\0" \
- "fdt_addr_r=0x6000000\0" \
- "scriptaddr=0x05FF0000\0" \
- BOOTENV
+#else
- "kernel_comp_addr_r=0x9000000\0" \
- "kernel_comp_size=0x01000000\0" \
- "qspibootimageaddr=0x020E0000\0" \
- "qspifdtaddr=0x020D0000\0" \
- "bootimagesize=0x01F00000\0" \
- "fdtimagesize=0x00010000\0" \
- "qspiload=sf read ${loadaddr} ${qspibootimageaddr}
- "qspiboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \
- "qspifitload=sf read ${loadaddr} ${qspibootimageaddr}
- "qspifitboot=setenv bootargs earlycon root=/dev/mtdblock1 rw " \
"loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "bootfile=" CONFIG_BOOTFILE "\0" \ "fdt_addr=8000000\0" \"rootfstype=jffs2 rootwait;bootm ${loadaddr}\0" \
- "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ "linux_qspi_enable=if sf probe; then " \ "echo Enabling QSPI at Linux DTB...;" \ "fdt addr ${fdt_addr}; fdt resize;" \ "fdt set /soc/spi@ff8d2000 status okay;" \
"scriptaddr=0x02100000\0" \ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \" ${qspi_clock}; echo QSPI clock frequency updated; fi; fi\0" \
- "nandload=ubi part root; ubi readvol ${loadaddr} kernel; ubi readvol
- "nandboot=setenv bootargs " CONFIG_BOOTARGS \
ubi.mtd=1; " \
ubi.mtd=1; " \
- External memory configurations
- Serial / UART configurations
-- 2.26.2
Shall RESEND additional changes in V2.
Jit Loon Lim
Lim, Jit Loon
