[U-Boot] [PATCH 06/15 v2] drivers/qe: Change QE RISC ALLOCATION to support 4 RISCs
Also define the QE_RISC_ALLOCATION_RISCs to MACROs instead of using enum, and define MAX_QE_RISC for QE based silicons.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com Acked-by: Timur Tabi timur@freescale.com --- v2 change: rename riscRx and riscTx to risc_rx and risc_tx
drivers/qe/qe.c | 3 --- drivers/qe/qe.h | 17 +++++++++++------ drivers/qe/uec.c | 32 +++++++++++++++++++++++++++++++- drivers/qe/uec.h | 4 ++-- include/asm-ppc/immap_qe.h | 8 ++++++++ 5 files changed, 52 insertions(+), 12 deletions(-)
diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index f114fe0..30fe726 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -258,9 +258,6 @@ int qe_set_mii_clk_src(int ucc_num) return 0; }
-/* The maximum number of RISCs we support */ -#define MAX_QE_RISC 2 - /* Firmware information stored here for qe_get_firmware_info() */ static struct qe_firmware_info qe_firmware_info;
diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index d78edba..2128f56 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2006 Freescale Semiconductor, Inc. + * Copyright (C) 2006-2009 Freescale Semiconductor, Inc. * * Dave Liu daveliu@freescale.com * based on source code of Shlomi Gridish @@ -46,11 +46,16 @@ typedef struct qe_snum {
/* QE RISC allocation */ -typedef enum qe_risc_allocation { - QE_RISC_ALLOCATION_RISC1 = 1, /* RISC 1 */ - QE_RISC_ALLOCATION_RISC2 = 2, /* RISC 2 */ - QE_RISC_ALLOCATION_RISC1_AND_RISC2 = 3 /* RISC 1 or RISC 2 */ -} qe_risc_allocation_e; +#define QE_RISC_ALLOCATION_RISC1 0x1 /* RISC 1 */ +#define QE_RISC_ALLOCATION_RISC2 0x2 /* RISC 2 */ +#define QE_RISC_ALLOCATION_RISC3 0x4 /* RISC 3 */ +#define QE_RISC_ALLOCATION_RISC4 0x8 /* RISC 4 */ +#define QE_RISC_ALLOCATION_RISC1_AND_RISC2 (QE_RISC_ALLOCATION_RISC1 | \ + QE_RISC_ALLOCATION_RISC2) +#define QE_RISC_ALLOCATION_FOUR_RISCS (QE_RISC_ALLOCATION_RISC1 | \ + QE_RISC_ALLOCATION_RISC2 | \ + QE_RISC_ALLOCATION_RISC3 | \ + QE_RISC_ALLOCATION_RISC4)
/* QE CECR commands for UCC fast. */ diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index bba3ef2..eadcc2c 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2006 Freescale Semiconductor, Inc. + * Copyright (C) 2006-2009 Freescale Semiconductor, Inc. * * Dave Liu daveliu@freescale.com * @@ -46,8 +46,13 @@ static uec_info_t eth1_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC1_PHY_ADDR, @@ -69,8 +74,13 @@ static uec_info_t eth2_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC2_PHY_ADDR, @@ -92,8 +102,13 @@ static uec_info_t eth3_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC3_PHY_ADDR, @@ -115,8 +130,13 @@ static uec_info_t eth4_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC4_PHY_ADDR, @@ -138,8 +158,13 @@ static uec_info_t eth5_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC5_PHY_ADDR, @@ -161,8 +186,13 @@ static uec_info_t eth6_uec_info = { .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, #endif +#if (MAX_QE_RISC == 4) + .risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS, + .risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS, +#else .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, +#endif .tx_bd_ring_len = 16, .rx_bd_ring_len = 16, .phy_address = CONFIG_SYS_UEC6_PHY_ADDR, diff --git a/drivers/qe/uec.h b/drivers/qe/uec.h index 0b64499..411f0d2 100644 --- a/drivers/qe/uec.h +++ b/drivers/qe/uec.h @@ -654,8 +654,8 @@ typedef struct uec_info { ucc_fast_info_t uf_info; uec_num_of_threads_e num_threads_tx; uec_num_of_threads_e num_threads_rx; - qe_risc_allocation_e risc_tx; - qe_risc_allocation_e risc_rx; + unsigned int risc_tx; + unsigned int risc_rx; u16 rx_bd_ring_len; u16 tx_bd_ring_len; u8 phy_address; diff --git a/include/asm-ppc/immap_qe.h b/include/asm-ppc/immap_qe.h index 55667ca..7613b5c 100644 --- a/include/asm-ppc/immap_qe.h +++ b/include/asm-ppc/immap_qe.h @@ -607,4 +607,12 @@ extern qe_map_t *qe_immr; #define QE_MURAM_SIZE 0x4000UL #endif
+#if defined(CONFIG_MPC8323) +#define MAX_QE_RISC 1 +#elif defined(CONFIG_MPC8569) +#define MAX_QE_RISC 4 +#else +#define MAX_QE_RISC 2 +#endif + #endif /* __IMMAP_QE_H__ */
Haiying Wang
