[PATCHv5 00/26] Re-base / re-post of TI-K3 HSM rearch series
As requested, this is just a rebase to the latest u-boot tip.
Boot tested on j721e to make sure nothing got broken.
-Tero
Copy the best rational approximation calculation routines from Linux. Typical usecase for these routines is to calculate the M/N divider values for PLLs to reach a specific clock rate.
This is based on linux kernel commit: "lib/math/rational.c: fix possible incorrect result from rational fractions helper" (sha1: 323dd2c3ed0641f49e89b4e420f9eef5d3d5a881)
Signed-off-by: Tero Kristo t-kristo@ti.com Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Tero Kristo kristo@kernel.org --- include/linux/rational.h | 20 ++++++++ lib/Kconfig | 7 +++ lib/Makefile | 2 + lib/rational.c | 99 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 128 insertions(+) create mode 100644 include/linux/rational.h create mode 100644 lib/rational.c
diff --git a/include/linux/rational.h b/include/linux/rational.h new file mode 100644 index 0000000000..33f5f5fc3e --- /dev/null +++ b/include/linux/rational.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * rational fractions + * + * Copyright (C) 2009 emlix GmbH, Oskar Schirmer oskar@scara.com + * + * helper functions when coping with rational numbers, + * e.g. when calculating optimum numerator/denominator pairs for + * pll configuration taking into account restricted register size + */ + +#ifndef _LINUX_RATIONAL_H +#define _LINUX_RATIONAL_H + +void rational_best_approximation( + unsigned long given_numerator, unsigned long given_denominator, + unsigned long max_numerator, unsigned long max_denominator, + unsigned long *best_numerator, unsigned long *best_denominator); + +#endif /* _LINUX_RATIONAL_H */ diff --git a/lib/Kconfig b/lib/Kconfig index 15019d2c65..ad0cd52edd 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -674,6 +674,13 @@ config GENERATE_SMBIOS_TABLE See also SMBIOS_SYSINFO which allows SMBIOS values to be provided in the devicetree.
+config LIB_RATIONAL + bool "enable continued fraction calculation routines" + +config SPL_LIB_RATIONAL + bool "enable continued fraction calculation routines for SPL" + depends on SPL + endmenu
config ASN1_COMPILER diff --git a/lib/Makefile b/lib/Makefile index b4795a62a0..881034f4ae 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -73,6 +73,8 @@ obj-$(CONFIG_$(SPL_)LZO) += lzo/ obj-$(CONFIG_$(SPL_)LZMA) += lzma/ obj-$(CONFIG_$(SPL_)LZ4) += lz4_wrapper.o
+obj-$(CONFIG_$(SPL_)LIB_RATIONAL) += rational.o + obj-$(CONFIG_LIBAVB) += libavb/
obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/ diff --git a/lib/rational.c b/lib/rational.c new file mode 100644 index 0000000000..316db3b590 --- /dev/null +++ b/lib/rational.c @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * rational fractions + * + * Copyright (C) 2009 emlix GmbH, Oskar Schirmer oskar@scara.com + * Copyright (C) 2019 Trent Piepho tpiepho@gmail.com + * + * helper functions when coping with rational numbers + */ + +#include <linux/rational.h> +#include <linux/compiler.h> +#include <linux/kernel.h> + +/* + * calculate best rational approximation for a given fraction + * taking into account restricted register size, e.g. to find + * appropriate values for a pll with 5 bit denominator and + * 8 bit numerator register fields, trying to set up with a + * frequency ratio of 3.1415, one would say: + * + * rational_best_approximation(31415, 10000, + * (1 << 8) - 1, (1 << 5) - 1, &n, &d); + * + * you may look at given_numerator as a fixed point number, + * with the fractional part size described in given_denominator. + * + * for theoretical background, see: + * http://en.wikipedia.org/wiki/Continued_fraction + */ + +void rational_best_approximation( + unsigned long given_numerator, unsigned long given_denominator, + unsigned long max_numerator, unsigned long max_denominator, + unsigned long *best_numerator, unsigned long *best_denominator) +{ + /* n/d is the starting rational, which is continually + * decreased each iteration using the Euclidean algorithm. + * + * dp is the value of d from the prior iteration. + * + * n2/d2, n1/d1, and n0/d0 are our successively more accurate + * approximations of the rational. They are, respectively, + * the current, previous, and two prior iterations of it. + * + * a is current term of the continued fraction. + */ + unsigned long n, d, n0, d0, n1, d1, n2, d2; + n = given_numerator; + d = given_denominator; + n0 = d1 = 0; + n1 = d0 = 1; + + for (;;) { + unsigned long dp, a; + + if (d == 0) + break; + /* Find next term in continued fraction, 'a', via + * Euclidean algorithm. + */ + dp = d; + a = n / d; + d = n % d; + n = dp; + + /* Calculate the current rational approximation (aka + * convergent), n2/d2, using the term just found and + * the two prior approximations. + */ + n2 = n0 + a * n1; + d2 = d0 + a * d1; + + /* If the current convergent exceeds the maxes, then + * return either the previous convergent or the + * largest semi-convergent, the final term of which is + * found below as 't'. + */ + if ((n2 > max_numerator) || (d2 > max_denominator)) { + unsigned long t = min((max_numerator - n0) / n1, + (max_denominator - d0) / d1); + + /* This tests if the semi-convergent is closer + * than the previous convergent. + */ + if (2u * t > a || (2u * t == a && d0 * dp > d1 * d)) { + n1 = n0 + t * n1; + d1 = d0 + t * d1; + } + break; + } + n0 = n1; + n1 = n2; + d0 = d1; + d1 = d2; + } + *best_numerator = n1; + *best_denominator = d1; +}
On J7 family of SoCs (J721E and J7200), sysfw is being split to be run under two cores, TIFS portion on DMSC core, and DM firmware under MCU R5. As MCU R5 is also used to run one phase of the bootloader, we must prevent access from here towards sysfw services. To support this, add new config option which can be used to detect presence of RM/PM sysfw services.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/Kconfig | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bfbce44bfa..069786ed0e 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -147,6 +147,17 @@ config SYS_K3_SPL_ATF Enabling this will try to start Cortex-A (typically with ATF) after SPL from R5.
+config K3_DM_FW + bool "Separate DM firmware image" + depends on SPL && CPU_V7R && SOC_K3_J721E && !CLK_TI_SCI && !TI_SCI_POWER_DOMAIN + default y + help + Enabling this will indicate that the system has separate DM + and TIFS firmware images in place, instead of a single SYSFW + firmware. Due to DM being executed on the same core as R5 SPL + bootloader, it makes RM and PM services not being available + during R5 SPL execution time. + source "board/ti/am65x/Kconfig" source "board/ti/am64x/Kconfig" source "board/ti/j721e/Kconfig"
With the sysfw rearch, sysfw PM calls are no longer available from SPL level. To properly support this, remove the is_on checks and the reset assertion from the R5 remoteproc driver as these are not supported. Attempting to access unavailable services will cause the device to hang.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/remoteproc/ti_k3_r5f_rproc.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/remoteproc/ti_k3_r5f_rproc.c b/drivers/remoteproc/ti_k3_r5f_rproc.c index 3c569a3b7b..c8c30b9020 100644 --- a/drivers/remoteproc/ti_k3_r5f_rproc.c +++ b/drivers/remoteproc/ti_k3_r5f_rproc.c @@ -781,7 +781,9 @@ static int k3_r5f_probe(struct udevice *dev) { struct k3_r5f_cluster *cluster = dev_get_priv(dev->parent); struct k3_r5f_core *core = dev_get_priv(dev); +#ifndef CONFIG_K3_DM_FW bool r_state; +#endif int ret;
dev_dbg(dev, "%s\n", __func__); @@ -804,6 +806,12 @@ static int k3_r5f_probe(struct udevice *dev) return ret; }
+ /* + * The PM functionality is not supported by the firmware during + * SPL execution with the separated DM firmware image. The following + * piece of code is not compiled in that case. + */ +#ifndef CONFIG_K3_DM_FW ret = core->tsp.sci->ops.dev_ops.is_on(core->tsp.sci, core->tsp.dev_id, &r_state, &core->in_use); if (ret) @@ -817,6 +825,7 @@ static int k3_r5f_probe(struct udevice *dev)
/* Make sure Local reset is asserted. Redundant? */ reset_assert(&core->reset); +#endif
ret = k3_r5f_rproc_configure(core); if (ret) {
board_fit_image_post_process() passes only start and size of the image, but type of the image is not passed. So pass fit and node_offset, to derive information about image to be processed.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/security.c | 3 ++- arch/arm/mach-keystone/mon.c | 3 ++- board/ti/am335x/board.c | 3 ++- board/ti/am43xx/board.c | 3 ++- board/ti/am57xx/board.c | 3 ++- board/ti/dra7xx/evm.c | 3 ++- common/image-fit.c | 2 +- common/spl/spl_fit.c | 2 +- include/image.h | 5 ++++- 9 files changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-k3/security.c b/arch/arm/mach-k3/security.c index 66f90a5a34..5b5ff9ba7b 100644 --- a/arch/arm/mach-k3/security.c +++ b/arch/arm/mach-k3/security.c @@ -18,7 +18,8 @@ #include <spl.h> #include <asm/arch/sys_proto.h>
-void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { struct ti_sci_handle *ti_sci = get_ti_sci_handle(); struct ti_sci_proc_ops *proc_ops = &ti_sci->ops.proc_ops; diff --git a/arch/arm/mach-keystone/mon.c b/arch/arm/mach-keystone/mon.c index 58995d73ac..b863bab196 100644 --- a/arch/arm/mach-keystone/mon.c +++ b/arch/arm/mach-keystone/mon.c @@ -103,7 +103,8 @@ static int k2_hs_bm_auth(int cmd, void *arg1) return result; }
-void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { int result = 0; void *image = *p_image; diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 5959ff73dc..5c156a5d1d 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -960,7 +960,8 @@ int board_fit_config_name_match(const char *name) #endif
#ifdef CONFIG_TI_SECURE_DEVICE -void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { secure_boot_verify_image(p_image, p_size); } diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index e9febb9592..a71b588efc 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -896,7 +896,8 @@ int embedded_dtb_select(void) #endif
#ifdef CONFIG_TI_SECURE_DEVICE -void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { secure_boot_verify_image(p_image, p_size); } diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 05c26c74d9..399a2e5d91 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -1199,7 +1199,8 @@ static int board_bootmode_has_emmc(void) #endif
#ifdef CONFIG_TI_SECURE_DEVICE -void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { secure_boot_verify_image(p_image, p_size); } diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 05f251f778..23e8005991 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -1065,7 +1065,8 @@ int fastboot_set_reboot_flag(enum fastboot_reboot_reason reason) #endif
#ifdef CONFIG_TI_SECURE_DEVICE -void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { secure_boot_verify_image(p_image, p_size); } diff --git a/common/image-fit.c b/common/image-fit.c index e614643fe3..0c5a05948d 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -2143,7 +2143,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr,
/* perform any post-processing on the image data */ if (!host_build() && IS_ENABLED(CONFIG_FIT_IMAGE_POST_PROCESS)) - board_fit_image_post_process(&buf, &size); + board_fit_image_post_process(fit, noffset, &buf, &size);
len = (ulong)size;
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index caddf51196..57d621d5b3 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -320,7 +320,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, }
if (CONFIG_IS_ENABLED(FIT_IMAGE_POST_PROCESS)) - board_fit_image_post_process(&src, &length); + board_fit_image_post_process(fit, node, &src, &length);
load_ptr = map_sysmem(load_addr, length); if (IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP) { diff --git a/include/image.h b/include/image.h index 459685d4d4..0c24bf6f35 100644 --- a/include/image.h +++ b/include/image.h @@ -1581,11 +1581,14 @@ int board_fit_config_name_match(const char *name); * into the FIT creation (i.e. the binary blobs would have been pre-processed * before being added to the FIT image). * + * @fit: pointer to fit image + * @node: offset of image node * @image: pointer to the image start pointer * @size: pointer to the image size * @return no return value (failure should be handled internally) */ -void board_fit_image_post_process(void **p_image, size_t *p_size); +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size);
#define FDT_ERROR ((ulong)(-1))
There is apparently a build failure with ARM socfpga board, the change below fixes it and should be squashed to the original patch:
diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 650122fcd4..36eecdc057 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -103,7 +103,8 @@ __weak int board_fit_config_name_match(const char *name) #endif
#if IS_ENABLED(CONFIG_FIT_IMAGE_POST_PROCESS) -void board_fit_image_post_process(void **p_image, size_t *p_size) +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) { if (IS_ENABLED(CONFIG_SOCFPGA_SECURE_VAB_AUTH)) { if (socfpga_vendor_authentication(p_image, p_size))
Current driver only supports registering fixed rate clocks from DT. Add new API which makes it possible to register fixed rate clocks directly from e.g. platform specific clock drivers.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/clk_fixed_rate.c | 43 ++++++++++++++++++++++++++++++++++++ include/linux/clk-provider.h | 3 +++ 2 files changed, 46 insertions(+)
diff --git a/drivers/clk/clk_fixed_rate.c b/drivers/clk/clk_fixed_rate.c index 09f9ef26a4..c591abf685 100644 --- a/drivers/clk/clk_fixed_rate.c +++ b/drivers/clk/clk_fixed_rate.c @@ -9,6 +9,9 @@ #include <dm/device-internal.h> #include <linux/clk-provider.h>
+#define UBOOT_DM_CLK_FIXED_RATE "fixed_rate_clock" +#define UBOOT_DM_CLK_FIXED_RATE_RAW "fixed_rate_raw_clock" + static ulong clk_fixed_rate_get_rate(struct clk *clk) { return to_clk_fixed_rate(clk->dev)->fixed_rate; @@ -40,6 +43,15 @@ void clk_fixed_rate_ofdata_to_plat_(struct udevice *dev, clk->enable_count = 0; }
+static ulong clk_fixed_rate_raw_get_rate(struct clk *clk) +{ + return container_of(clk, struct clk_fixed_rate, clk)->fixed_rate; +} + +const struct clk_ops clk_fixed_rate_raw_ops = { + .get_rate = clk_fixed_rate_raw_get_rate, +}; + static int clk_fixed_rate_of_to_plat(struct udevice *dev) { clk_fixed_rate_ofdata_to_plat_(dev, to_clk_fixed_rate(dev)); @@ -47,6 +59,30 @@ static int clk_fixed_rate_of_to_plat(struct udevice *dev) return 0; }
+struct clk *clk_register_fixed_rate(struct device *dev, const char *name, + ulong rate) +{ + struct clk *clk; + struct clk_fixed_rate *fixed; + int ret; + + fixed = kzalloc(sizeof(*fixed), GFP_KERNEL); + if (!fixed) + return ERR_PTR(-ENOMEM); + + fixed->fixed_rate = rate; + + clk = &fixed->clk; + + ret = clk_register(clk, UBOOT_DM_CLK_FIXED_RATE_RAW, name, NULL); + if (ret) { + kfree(fixed); + return ERR_PTR(ret); + } + + return clk; +} + static const struct udevice_id clk_fixed_rate_match[] = { { .compatible = "fixed-clock", @@ -63,3 +99,10 @@ U_BOOT_DRIVER(fixed_clock) = { .ops = &clk_fixed_rate_ops, .flags = DM_FLAG_PRE_RELOC, }; + +U_BOOT_DRIVER(clk_fixed_rate_raw) = { + .name = UBOOT_DM_CLK_FIXED_RATE_RAW, + .id = UCLASS_CLK, + .ops = &clk_fixed_rate_raw_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index 6fda14f5fe..9d296f240a 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -247,6 +247,9 @@ struct clk *clk_register_mux(struct device *dev, const char *name, void __iomem *reg, u8 shift, u8 width, u8 clk_mux_flags);
+struct clk *clk_register_fixed_rate(struct device *dev, const char *name, + ulong rate); + const char *clk_hw_get_name(const struct clk *hw); ulong clk_generic_get_rate(struct clk *clk);
Some clocks are not associated to a DM node, so just parsing the DM is not enough. This is especially true for root clocks, which typically don't have any parents. Instead, fetch every registered UCLASS_CLK instance, and dump these out.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- cmd/clk.c | 27 +++++++++++++++++++-------- 1 file changed, 19 insertions(+), 8 deletions(-)
diff --git a/cmd/clk.c b/cmd/clk.c index e3c3d2f9bb..0245b97136 100644 --- a/cmd/clk.c +++ b/cmd/clk.c @@ -18,11 +18,14 @@ static void show_clks(struct udevice *dev, int depth, int last_flag) { int i, is_last; struct udevice *child; - struct clk *clkp; + struct clk *clkp, *parent; u32 rate;
clkp = dev_get_clk_ptr(dev); if (device_get_uclass_id(dev) == UCLASS_CLK && clkp) { + parent = clk_get_parent(clkp); + if (!IS_ERR(parent) && depth == -1) + return; depth++; rate = clk_get_rate(clkp);
@@ -47,6 +50,9 @@ static void show_clks(struct udevice *dev, int depth, int last_flag) }
list_for_each_entry(child, &dev->child_head, sibling_node) { + if (child == dev) + continue; + is_last = list_is_last(&child->sibling_node, &dev->child_head); show_clks(child, depth, (last_flag << 1) | is_last); } @@ -54,14 +60,19 @@ static void show_clks(struct udevice *dev, int depth, int last_flag)
int __weak soc_clk_dump(void) { - struct udevice *root; + struct udevice *dev; + struct uclass *uc; + int ret;
- root = dm_root(); - if (root) { - printf(" Rate Usecnt Name\n"); - printf("------------------------------------------\n"); - show_clks(root, -1, 0); - } + ret = uclass_get(UCLASS_CLK, &uc); + if (ret) + return ret; + + printf(" Rate Usecnt Name\n"); + printf("------------------------------------------\n"); + + uclass_foreach_dev(dev, uc) + show_clks(dev, -1, 0);
return 0; }
Bail out early if device returned for the parent clock is null. This avoids warning prints like this when doing clk dump:
dev_get_uclass_priv: null device
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/clk-uclass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 53e7be764d..451d7da001 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -502,6 +502,8 @@ struct clk *clk_get_parent(struct clk *clk) return NULL;
pdev = dev_get_parent(clk->dev); + if (!pdev) + return ERR_PTR(-ENODEV); pclk = dev_get_clk_ptr(pdev); if (!pclk) return ERR_PTR(-ENODEV);
Add new clk subcommand "clk setfreq", for setting up a clock rate directly from u-boot cmdline. This is handy for any debugging purposes towards clocks.
Acked-by: Lukasz Majewski lukma@denx.de Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- cmd/clk.c | 49 +++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 47 insertions(+), 2 deletions(-)
diff --git a/cmd/clk.c b/cmd/clk.c index 0245b97136..fd7944c02e 100644 --- a/cmd/clk.c +++ b/cmd/clk.c @@ -98,8 +98,52 @@ static int do_clk_dump(struct cmd_tbl *cmdtp, int flag, int argc, return ret; }
+struct udevice *clk_lookup(const char *name) +{ + int i = 0; + struct udevice *dev; + + do { + uclass_get_device(UCLASS_CLK, i++, &dev); + if (!strcmp(name, dev->name)) + return dev; + } while (dev); + + return NULL; +} + +static int do_clk_setfreq(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct clk *clk = NULL; + s32 freq; + struct udevice *dev; + + freq = simple_strtoul(argv[2], NULL, 10); + + dev = clk_lookup(argv[1]); + + if (dev) + clk = dev_get_clk_ptr(dev); + + if (!clk) { + printf("clock '%s' not found.\n", argv[1]); + return -EINVAL; + } + + freq = clk_set_rate(clk, freq); + if (freq < 0) { + printf("set_rate failed: %d\n", freq); + return CMD_RET_FAILURE; + } + + printf("set_rate returns %u\n", freq); + return 0; +} + static struct cmd_tbl cmd_clk_sub[] = { U_BOOT_CMD_MKENT(dump, 1, 1, do_clk_dump, "", ""), + U_BOOT_CMD_MKENT(setfreq, 3, 1, do_clk_setfreq, "", ""), };
static int do_clk(struct cmd_tbl *cmdtp, int flag, int argc, @@ -124,7 +168,8 @@ static int do_clk(struct cmd_tbl *cmdtp, int flag, int argc,
#ifdef CONFIG_SYS_LONGHELP static char clk_help_text[] = - "dump - Print clock frequencies"; + "dump - Print clock frequencies\n" + "setfreq [clk] [freq] - Set clock frequency"; #endif
-U_BOOT_CMD(clk, 2, 1, do_clk, "CLK sub-system", clk_help_text); +U_BOOT_CMD(clk, 4, 1, do_clk, "CLK sub-system", clk_help_text);
Set rate should return the new clock rate on success, and negative error value on failure. Fix this, as currently set_rate returns 0 on success.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/ti/clk-sci.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/ti/clk-sci.c b/drivers/clk/ti/clk-sci.c index 6f0fdaa111..acb9eadf03 100644 --- a/drivers/clk/ti/clk-sci.c +++ b/drivers/clk/ti/clk-sci.c @@ -111,10 +111,12 @@ static ulong ti_sci_clk_set_rate(struct clk *clk, ulong rate) #endif
ret = cops->set_freq(sci, clk->id, clk->data, 0, rate, ULONG_MAX); - if (ret) + if (ret) { dev_err(clk->dev, "%s: set_freq failed (%d)\n", __func__, ret); + return ret; + }
- return ret; + return rate; }
static int ti_sci_clk_set_parent(struct clk *clk, struct clk *parent)
If a clock provider is not ready for assigning default rates/parents during its probe, it may return -EPROBE_DEFER directly from xlate. Handle this special case properly by skipping the entry and adjusting the return value to pass. The defaults will be handled properly in post probe phase then.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/clk-uclass.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 451d7da001..815f7bfe98 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -241,6 +241,15 @@ static int clk_set_default_parents(struct udevice *dev, int stage)
ret = clk_get_by_indexed_prop(dev, "assigned-clocks", index, &clk); + /* + * If the clock provider is not ready yet, let it handle + * the re-programming later. + */ + if (ret == -EPROBE_DEFER) { + ret = 0; + continue; + } + if (ret) { debug("%s: could not get assigned clock %d for %s\n", __func__, index, dev_read_name(dev)); @@ -309,6 +318,15 @@ static int clk_set_default_rates(struct udevice *dev, int stage)
ret = clk_get_by_indexed_prop(dev, "assigned-clocks", index, &clk); + /* + * If the clock provider is not ready yet, let it handle + * the re-programming later. + */ + if (ret == -EPROBE_DEFER) { + ret = 0; + continue; + } + if (ret) { dev_dbg(dev, "could not get assigned clock %d (err = %d)\n",
Clock rates are cached within the individual clock nodes, and right now if one changes a clock rate somewhere in the middle of the tree, none of its child clocks notice the change. To fix this, clear up all the cached rates for us and our child clocks.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/clk-uclass.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 815f7bfe98..3d2344f009 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -568,6 +568,22 @@ ulong clk_round_rate(struct clk *clk, ulong rate) return ops->round_rate(clk, rate); }
+static void clk_clean_rate_cache(struct clk *clk) +{ + struct udevice *child_dev; + struct clk *clkp; + + if (!clk) + return; + + clk->rate = 0; + + list_for_each_entry(child_dev, &clk->dev->child_head, sibling_node) { + clkp = dev_get_clk_ptr(child_dev); + clk_clean_rate_cache(clkp); + } +} + ulong clk_set_rate(struct clk *clk, ulong rate) { const struct clk_ops *ops; @@ -580,6 +596,9 @@ ulong clk_set_rate(struct clk *clk, ulong rate) if (!ops->set_rate) return -ENOSYS;
+ /* Clean up cached rates for us and all child clocks */ + clk_clean_rate_cache(clk); + return ops->set_rate(clk, rate); }
Add support for TI K3 SoC PLLs. This clock type supports enabling/disabling/setting and querying the clock rate for the PLL. The euclidean library routine is used to calculate divider/multiplier rates for the PLLs.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/ti/Kconfig | 12 ++ drivers/clk/ti/Makefile | 1 + drivers/clk/ti/clk-k3-pll.c | 283 ++++++++++++++++++++++++++++++++++++ include/k3-clk.h | 15 ++ 4 files changed, 311 insertions(+) create mode 100644 drivers/clk/ti/clk-k3-pll.c create mode 100644 include/k3-clk.h
diff --git a/drivers/clk/ti/Kconfig b/drivers/clk/ti/Kconfig index 2dc86d44a9..a8ec4f541a 100644 --- a/drivers/clk/ti/Kconfig +++ b/drivers/clk/ti/Kconfig @@ -41,3 +41,15 @@ config CLK_TI_SCI This enables the clock driver support over TI System Control Interface available on some new TI's SoCs. If you wish to use clock resources managed by the TI System Controller, say Y here. Otherwise, say N. + +config CLK_K3_PLL + bool "PLL clock support for K3 SoC family of devices" + depends on CLK && LIB_RATIONAL + help + Enables PLL clock support for K3 SoC family of devices. + +config SPL_CLK_K3_PLL + bool "PLL clock support for K3 SoC family of devices" + depends on CLK && LIB_RATIONAL && SPL + help + Enables PLL clock support for K3 SoC family of devices. diff --git a/drivers/clk/ti/Makefile b/drivers/clk/ti/Makefile index 9f56b47736..47839213e5 100644 --- a/drivers/clk/ti/Makefile +++ b/drivers/clk/ti/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_CLK_TI_DIVIDER) += clk-divider.o obj-$(CONFIG_CLK_TI_GATE) += clk-gate.o obj-$(CONFIG_CLK_TI_MUX) += clk-mux.o obj-$(CONFIG_CLK_TI_SCI) += clk-sci.o +obj-$(CONFIG_$(SPL_TPL_)CLK_K3_PLL) += clk-k3-pll.o diff --git a/drivers/clk/ti/clk-k3-pll.c b/drivers/clk/ti/clk-k3-pll.c new file mode 100644 index 0000000000..bf2407a020 --- /dev/null +++ b/drivers/clk/ti/clk-k3-pll.c @@ -0,0 +1,283 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments K3 SoC PLL clock driver + * + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + */ + +#include <common.h> +#include <asm/io.h> +#include <dm.h> +#include <div64.h> +#include <errno.h> +#include <clk-uclass.h> +#include <linux/clk-provider.h> +#include "k3-clk.h" +#include <linux/rational.h> + +/* 16FFT register offsets */ +#define PLL_16FFT_CFG 0x08 +#define PLL_KICK0 0x10 +#define PLL_KICK1 0x14 +#define PLL_16FFT_CTRL 0x20 +#define PLL_16FFT_STAT 0x24 +#define PLL_16FFT_FREQ_CTRL0 0x30 +#define PLL_16FFT_FREQ_CTRL1 0x34 +#define PLL_16FFT_DIV_CTRL 0x38 + +/* CTRL register bits */ +#define PLL_16FFT_CTRL_BYPASS_EN BIT(31) +#define PLL_16FFT_CTRL_PLL_EN BIT(15) +#define PLL_16FFT_CTRL_DSM_EN BIT(1) + +/* STAT register bits */ +#define PLL_16FFT_STAT_LOCK BIT(0) + +/* FREQ_CTRL0 bits */ +#define PLL_16FFT_FREQ_CTRL0_FB_DIV_INT_MASK 0xfff + +/* DIV CTRL register bits */ +#define PLL_16FFT_DIV_CTRL_REF_DIV_MASK 0x3f + +#define PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS 24 +#define PLL_16FFT_HSDIV_CTRL_CLKOUT_EN BIT(15) + +/* KICK register magic values */ +#define PLL_KICK0_VALUE 0x68ef3490 +#define PLL_KICK1_VALUE 0xd172bc5a + +/** + * struct ti_pll_clk - TI PLL clock data info structure + * @clk: core clock structure + * @reg: memory address of the PLL controller + */ +struct ti_pll_clk { + struct clk clk; + void __iomem *reg; +}; + +#define to_clk_pll(_clk) container_of(_clk, struct ti_pll_clk, clk) + +static int ti_pll_wait_for_lock(struct clk *clk) +{ + struct ti_pll_clk *pll = to_clk_pll(clk); + u32 stat; + int i; + + for (i = 0; i < 100000; i++) { + stat = readl(pll->reg + PLL_16FFT_STAT); + if (stat & PLL_16FFT_STAT_LOCK) + return 0; + } + + printf("%s: pll (%s) failed to lock\n", __func__, + clk->dev->name); + + return -EBUSY; +} + +static ulong ti_pll_clk_get_rate(struct clk *clk) +{ + struct ti_pll_clk *pll = to_clk_pll(clk); + u64 current_freq; + u64 parent_freq = clk_get_parent_rate(clk); + u32 pllm; + u32 plld; + u32 pllfm; + u32 ctrl; + + /* Check if we are in bypass */ + ctrl = readl(pll->reg + PLL_16FFT_CTRL); + if (ctrl & PLL_16FFT_CTRL_BYPASS_EN) + return parent_freq; + + pllm = readl(pll->reg + PLL_16FFT_FREQ_CTRL0); + pllfm = readl(pll->reg + PLL_16FFT_FREQ_CTRL1); + + plld = readl(pll->reg + PLL_16FFT_DIV_CTRL) & + PLL_16FFT_DIV_CTRL_REF_DIV_MASK; + + current_freq = parent_freq * pllm / plld; + + if (pllfm) { + u64 tmp; + + tmp = parent_freq * pllfm; + do_div(tmp, plld); + tmp >>= PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS; + current_freq += tmp; + } + + return current_freq; +} + +static ulong ti_pll_clk_set_rate(struct clk *clk, ulong rate) +{ + struct ti_pll_clk *pll = to_clk_pll(clk); + u64 current_freq; + u64 parent_freq = clk_get_parent_rate(clk); + int ret; + u32 ctrl; + unsigned long pllm; + u32 pllfm = 0; + unsigned long plld; + u32 rem; + int shift; + + debug("%s(clk=%p, rate=%u)\n", __func__, clk, (u32)rate); + + if (ti_pll_clk_get_rate(clk) == rate) + return rate; + + if (rate != parent_freq) + /* + * Attempt with higher max multiplier value first to give + * some space for fractional divider to kick in. + */ + for (shift = 8; shift >= 0; shift -= 8) { + rational_best_approximation(rate, parent_freq, + ((PLL_16FFT_FREQ_CTRL0_FB_DIV_INT_MASK + 1) << shift) - 1, + PLL_16FFT_DIV_CTRL_REF_DIV_MASK, &pllm, &plld); + if (pllm / plld <= PLL_16FFT_FREQ_CTRL0_FB_DIV_INT_MASK) + break; + } + + /* Put PLL to bypass mode */ + ctrl = readl(pll->reg + PLL_16FFT_CTRL); + ctrl |= PLL_16FFT_CTRL_BYPASS_EN; + writel(ctrl, pll->reg + PLL_16FFT_CTRL); + + if (rate == parent_freq) { + debug("%s: put %s to bypass\n", __func__, clk->dev->name); + return rate; + } + + debug("%s: pre-frac-calc: rate=%u, parent_freq=%u, plld=%u, pllm=%u\n", + __func__, (u32)rate, (u32)parent_freq, (u32)plld, (u32)pllm); + + /* Check if we need fractional config */ + if (plld > 1) { + pllfm = pllm % plld; + pllfm <<= PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS; + rem = pllfm % plld; + pllfm /= plld; + if (rem) + pllfm++; + pllm /= plld; + plld = 1; + } + + if (pllfm) + ctrl |= PLL_16FFT_CTRL_DSM_EN; + else + ctrl &= ~PLL_16FFT_CTRL_DSM_EN; + + writel(pllm, pll->reg + PLL_16FFT_FREQ_CTRL0); + writel(pllfm, pll->reg + PLL_16FFT_FREQ_CTRL1); + writel(plld, pll->reg + PLL_16FFT_DIV_CTRL); + + ctrl &= ~PLL_16FFT_CTRL_BYPASS_EN; + ctrl |= PLL_16FFT_CTRL_PLL_EN; + writel(ctrl, pll->reg + PLL_16FFT_CTRL); + + ret = ti_pll_wait_for_lock(clk); + if (ret) + return ret; + + debug("%s: pllm=%u, plld=%u, pllfm=%u, parent_freq=%u\n", + __func__, (u32)pllm, (u32)plld, (u32)pllfm, (u32)parent_freq); + + current_freq = parent_freq * pllm / plld; + + if (pllfm) { + u64 tmp; + + tmp = parent_freq * pllfm; + do_div(tmp, plld); + tmp >>= PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS; + current_freq += tmp; + } + + return current_freq; +} + +static int ti_pll_clk_enable(struct clk *clk) +{ + struct ti_pll_clk *pll = to_clk_pll(clk); + u32 ctrl; + + ctrl = readl(pll->reg + PLL_16FFT_CTRL); + ctrl &= ~PLL_16FFT_CTRL_BYPASS_EN; + ctrl |= PLL_16FFT_CTRL_PLL_EN; + writel(ctrl, pll->reg + PLL_16FFT_CTRL); + + return ti_pll_wait_for_lock(clk); +} + +static int ti_pll_clk_disable(struct clk *clk) +{ + struct ti_pll_clk *pll = to_clk_pll(clk); + u32 ctrl; + + ctrl = readl(pll->reg + PLL_16FFT_CTRL); + ctrl |= PLL_16FFT_CTRL_BYPASS_EN; + writel(ctrl, pll->reg + PLL_16FFT_CTRL); + + return 0; +} + +static const struct clk_ops ti_pll_clk_ops = { + .get_rate = ti_pll_clk_get_rate, + .set_rate = ti_pll_clk_set_rate, + .enable = ti_pll_clk_enable, + .disable = ti_pll_clk_disable, +}; + +struct clk *clk_register_ti_pll(const char *name, const char *parent_name, + void __iomem *reg) +{ + struct ti_pll_clk *pll; + int ret; + int i; + u32 cfg, ctrl, hsdiv_presence_bit, hsdiv_ctrl_offs; + + pll = kzalloc(sizeof(*pll), GFP_KERNEL); + if (!pll) + return ERR_PTR(-ENOMEM); + + pll->reg = reg; + + ret = clk_register(&pll->clk, "ti-pll-clk", name, parent_name); + if (ret) { + printf("%s: failed to register: %d\n", __func__, ret); + kfree(pll); + return ERR_PTR(ret); + } + + /* Unlock the PLL registers */ + writel(PLL_KICK0_VALUE, pll->reg + PLL_KICK0); + writel(PLL_KICK1_VALUE, pll->reg + PLL_KICK1); + + /* Enable all HSDIV outputs */ + cfg = readl(pll->reg + PLL_16FFT_CFG); + for (i = 0; i < 16; i++) { + hsdiv_presence_bit = BIT(16 + i); + hsdiv_ctrl_offs = 0x80 + (i * 4); + /* Enable HSDIV output if present */ + if ((hsdiv_presence_bit & cfg) != 0UL) { + ctrl = readl(pll->reg + hsdiv_ctrl_offs); + ctrl |= PLL_16FFT_HSDIV_CTRL_CLKOUT_EN; + writel(ctrl, pll->reg + hsdiv_ctrl_offs); + } + } + + return &pll->clk; +} + +U_BOOT_DRIVER(ti_pll_clk) = { + .name = "ti-pll-clk", + .id = UCLASS_CLK, + .ops = &ti_pll_clk_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/k3-clk.h b/include/k3-clk.h new file mode 100644 index 0000000000..fc84378d03 --- /dev/null +++ b/include/k3-clk.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2020 - Texas Instruments Incorporated - http://www.ti.com + * Tero Kristo t-kristo@ti.com + */ + +#ifndef __K3_CLK_H__ +#define __K3_CLK_H__ + +#include <linux/clk-provider.h> + +struct clk *clk_register_ti_pll(const char *name, const char *parent_name, + void __iomem *reg); + +#endif /* __K3_CLK_H__ */
Add driver to support TI K3 generation SoC clocks. This driver registers the clocks provided via platform data, and adds support for controlling the clocks via DT handles.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- drivers/clk/ti/Kconfig | 12 ++ drivers/clk/ti/Makefile | 1 + drivers/clk/ti/clk-k3.c | 374 ++++++++++++++++++++++++++++++++++++++++ include/k3-clk.h | 162 +++++++++++++++++ 4 files changed, 549 insertions(+) create mode 100644 drivers/clk/ti/clk-k3.c
diff --git a/drivers/clk/ti/Kconfig b/drivers/clk/ti/Kconfig index a8ec4f541a..fbcdefd889 100644 --- a/drivers/clk/ti/Kconfig +++ b/drivers/clk/ti/Kconfig @@ -53,3 +53,15 @@ config SPL_CLK_K3_PLL depends on CLK && LIB_RATIONAL && SPL help Enables PLL clock support for K3 SoC family of devices. + +config CLK_K3 + bool "Clock support for K3 SoC family of devices" + depends on CLK + help + Enables the clock translation layer from DT to device clocks. + +config SPL_CLK_K3 + bool "Clock support for K3 SoC family of devices" + depends on CLK && SPL + help + Enables the clock translation layer from DT to device clocks. diff --git a/drivers/clk/ti/Makefile b/drivers/clk/ti/Makefile index 47839213e5..07aa9a53e0 100644 --- a/drivers/clk/ti/Makefile +++ b/drivers/clk/ti/Makefile @@ -12,3 +12,4 @@ obj-$(CONFIG_CLK_TI_GATE) += clk-gate.o obj-$(CONFIG_CLK_TI_MUX) += clk-mux.o obj-$(CONFIG_CLK_TI_SCI) += clk-sci.o obj-$(CONFIG_$(SPL_TPL_)CLK_K3_PLL) += clk-k3-pll.o +obj-$(CONFIG_$(SPL_TPL_)CLK_K3) += clk-k3.o diff --git a/drivers/clk/ti/clk-k3.c b/drivers/clk/ti/clk-k3.c new file mode 100644 index 0000000000..ec262d5c21 --- /dev/null +++ b/drivers/clk/ti/clk-k3.c @@ -0,0 +1,374 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments K3 clock driver + * + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <soc.h> +#include <clk-uclass.h> +#include "k3-clk.h" + +#define PLL_MIN_FREQ 800000000 +#define PLL_MAX_FREQ 3200000000UL +#define PLL_MAX_DIV 127 + +/** + * struct clk_map - mapping from dev/clk id tuples towards physical clocks + * @dev_id: device ID for the clock + * @clk_id: clock ID for the clock + * @clk: pointer to the registered clock entry for the mapping + */ +struct clk_map { + u16 dev_id; + u32 clk_id; + struct clk *clk; +}; + +/** + * struct ti_clk_data - clock controller information structure + * @map: mapping from dev/clk id tuples to physical clock entries + * @size: number of entries in the map + */ +struct ti_clk_data { + struct clk_map *map; + int size; +}; + +static ulong osc_freq; + +static void clk_add_map(struct ti_clk_data *data, struct clk *clk, + u32 dev_id, u32 clk_id) +{ + struct clk_map *map; + + debug("%s: added clk=%p, data=%p, dev=%d, clk=%d\n", __func__, + clk, data, dev_id, clk_id); + if (!clk) + return; + + map = data->map + data->size++; + + map->dev_id = dev_id; + map->clk_id = clk_id; + map->clk = clk; +} + +static const struct soc_attr ti_k3_soc_clk_data[] = { +#ifdef CONFIG_SOC_K3_J721E + { + .family = "J721E", + .data = &j721e_clk_platdata, + }, + { + .family = "J7200", + .data = &j7200_clk_platdata, + }, +#endif + { /* sentinel */ } +}; + +static int ti_clk_probe(struct udevice *dev) +{ + struct ti_clk_data *data = dev_get_priv(dev); + struct clk *clk; + const char *name; + const struct clk_data *ti_clk_data; + int i, j; + const struct soc_attr *soc_match_data; + const struct ti_k3_clk_platdata *pdata; + + debug("%s(dev=%p)\n", __func__, dev); + + soc_match_data = soc_device_match(ti_k3_soc_clk_data); + if (!soc_match_data) + return -ENODEV; + + pdata = (const struct ti_k3_clk_platdata *)soc_match_data->data; + + data->map = kcalloc(pdata->soc_dev_clk_data_cnt, sizeof(*data->map), + GFP_KERNEL); + data->size = 0; + + for (i = 0; i < pdata->clk_list_cnt; i++) { + ti_clk_data = &pdata->clk_list[i]; + + switch (ti_clk_data->type) { + case CLK_TYPE_FIXED_RATE: + name = ti_clk_data->clk.fixed_rate.name; + clk = clk_register_fixed_rate(NULL, + name, + ti_clk_data->clk.fixed_rate.rate); + break; + case CLK_TYPE_DIV: + name = ti_clk_data->clk.div.name; + clk = clk_register_divider(NULL, name, + ti_clk_data->clk.div.parent, + ti_clk_data->clk.div.flags, + map_physmem(ti_clk_data->clk.div.reg, 0, MAP_NOCACHE), + ti_clk_data->clk.div.shift, + ti_clk_data->clk.div.width, + 0); + break; + case CLK_TYPE_MUX: + name = ti_clk_data->clk.mux.name; + clk = clk_register_mux(NULL, name, + ti_clk_data->clk.mux.parents, + ti_clk_data->clk.mux.num_parents, + ti_clk_data->clk.mux.flags, + map_physmem(ti_clk_data->clk.mux.reg, 0, MAP_NOCACHE), + ti_clk_data->clk.mux.shift, + ti_clk_data->clk.mux.width, + 0); + break; + case CLK_TYPE_PLL: + name = ti_clk_data->clk.pll.name; + clk = clk_register_ti_pll(name, + ti_clk_data->clk.pll.parent, + map_physmem(ti_clk_data->clk.pll.reg, 0, MAP_NOCACHE)); + + if (!osc_freq) + osc_freq = clk_get_rate(clk_get_parent(clk)); + break; + default: + name = NULL; + clk = NULL; + printf("WARNING: %s has encountered unknown clk type %d\n", + __func__, ti_clk_data->type); + } + + if (clk && ti_clk_data->default_freq) + clk_set_rate(clk, ti_clk_data->default_freq); + + if (clk && name) { + for (j = 0; j < pdata->soc_dev_clk_data_cnt; j++) { + if (!strcmp(name, pdata->soc_dev_clk_data[j].clk_name)) { + clk_add_map(data, clk, pdata->soc_dev_clk_data[j].dev_id, + pdata->soc_dev_clk_data[j].clk_id); + } + } + } + } + + return 0; +} + +static int _clk_cmp(u32 dev_id, u32 clk_id, const struct clk_map *map) +{ + if (map->dev_id == dev_id && map->clk_id == clk_id) + return 0; + if (map->dev_id > dev_id || + (map->dev_id == dev_id && map->clk_id > clk_id)) + return -1; + return 1; +} + +static int bsearch(u32 dev_id, u32 clk_id, struct clk_map *map, int num) +{ + int result; + int idx; + + for (idx = 0; idx < num; idx++) { + result = _clk_cmp(dev_id, clk_id, &map[idx]); + + if (result == 0) + return idx; + } + + return -ENOENT; +} + +static int ti_clk_of_xlate(struct clk *clk, + struct ofnode_phandle_args *args) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + int idx; + + debug("%s(clk=%p, args_count=%d [0]=%d [1]=%d)\n", __func__, clk, + args->args_count, args->args[0], args->args[1]); + + if (args->args_count != 2) { + debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (!data->size) + return -EPROBE_DEFER; + + idx = bsearch(args->args[0], args->args[1], data->map, data->size); + if (idx < 0) + return idx; + + clk->id = idx; + + return 0; +} + +static ulong ti_clk_get_rate(struct clk *clk) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + struct clk *clkp = data->map[clk->id].clk; + + return clk_get_rate(clkp); +} + +static ulong ti_clk_set_rate(struct clk *clk, ulong rate) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + struct clk *clkp = data->map[clk->id].clk; + int div = 1; + ulong child_rate; + const struct clk_ops *ops; + ulong new_rate, rem; + ulong diff, new_diff; + + /* + * We must propagate rate change to parent if current clock type + * does not allow setting it. + */ + while (clkp) { + ops = clkp->dev->driver->ops; + if (ops->set_rate) + break; + + /* + * Store child rate so we can calculate the clock rate + * that must be passed to parent + */ + child_rate = clk_get_rate(clkp); + clkp = clk_get_parent(clkp); + if (clkp) { + debug("%s: propagating rate change to parent %s, rate=%u.\n", + __func__, clkp->dev->name, (u32)rate / div); + div *= clk_get_rate(clkp) / child_rate; + } + } + + if (!clkp) + return -ENOSYS; + + child_rate = clk_get_rate(clkp); + + new_rate = clk_set_rate(clkp, rate / div); + + diff = abs(new_rate - rate / div); + + debug("%s: clk=%s, div=%d, rate=%u, new_rate=%u, diff=%u\n", __func__, + clkp->dev->name, div, (u32)rate, (u32)new_rate, (u32)diff); + + /* + * If the new rate differs by 50% of the target, + * modify parent. This handles typical cases where we have a hsdiv + * following directly a PLL + */ + + if (diff > rate / div / 2) { + ulong pll_tgt; + int pll_div = 0; + + clk = clkp; + + debug("%s: propagating rate change to parent, rate=%u.\n", + __func__, (u32)rate / div); + + clkp = clk_get_parent(clkp); + + if (rate > osc_freq) { + if (rate > PLL_MAX_FREQ / 2 && rate < PLL_MAX_FREQ) { + pll_tgt = rate; + pll_div = 1; + } else { + for (pll_div = 2; pll_div < PLL_MAX_DIV; pll_div++) { + pll_tgt = rate / div * pll_div; + if (pll_tgt >= PLL_MIN_FREQ && pll_tgt <= PLL_MAX_FREQ) + break; + } + } + } else { + pll_tgt = osc_freq; + pll_div = rate / div / osc_freq; + } + + debug("%s: pll_tgt=%u, rate=%u, div=%u\n", __func__, + (u32)pll_tgt, (u32)rate, pll_div); + + clk_set_rate(clkp, pll_tgt); + + return clk_set_rate(clk, rate / div) * div; + } + + /* + * If the new rate differs by at least 5% of the target, + * we must check for rounding error in a divider, so try + * set rate with rate + (parent_freq % rate). + */ + + if (diff > rate / div / 20) { + u64 parent_freq = clk_get_parent_rate(clkp); + + rem = parent_freq % rate; + new_rate = clk_set_rate(clkp, (rate / div) + rem); + new_diff = abs(new_rate - rate / div); + + if (new_diff > diff) { + new_rate = clk_set_rate(clkp, rate / div); + } else { + debug("%s: Using better rate %lu that gives diff %lu\n", + __func__, new_rate, new_diff); + } + } + + return new_rate; +} + +static int ti_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + struct clk *clkp = data->map[clk->id].clk; + struct clk *parentp = data->map[parent->id].clk; + + return clk_set_parent(clkp, parentp); +} + +static int ti_clk_enable(struct clk *clk) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + struct clk *clkp = data->map[clk->id].clk; + + return clk_enable(clkp); +} + +static int ti_clk_disable(struct clk *clk) +{ + struct ti_clk_data *data = dev_get_priv(clk->dev); + struct clk *clkp = data->map[clk->id].clk; + + return clk_disable(clkp); +} + +static const struct udevice_id ti_clk_of_match[] = { + { .compatible = "ti,k2g-sci-clk" }, + { /* sentinel */ }, +}; + +static const struct clk_ops ti_clk_ops = { + .of_xlate = ti_clk_of_xlate, + .set_rate = ti_clk_set_rate, + .get_rate = ti_clk_get_rate, + .enable = ti_clk_enable, + .disable = ti_clk_disable, + .set_parent = ti_clk_set_parent, +}; + +U_BOOT_DRIVER(ti_clk) = { + .name = "ti-clk", + .id = UCLASS_CLK, + .of_match = ti_clk_of_match, + .probe = ti_clk_probe, + .priv_auto = sizeof(struct ti_clk_data), + .ops = &ti_clk_ops, +}; diff --git a/include/k3-clk.h b/include/k3-clk.h index fc84378d03..36f0ddf7cc 100644 --- a/include/k3-clk.h +++ b/include/k3-clk.h @@ -7,7 +7,169 @@ #ifndef __K3_CLK_H__ #define __K3_CLK_H__
+#include <common.h> +#include <asm/io.h> +#include <linux/bitops.h> #include <linux/clk-provider.h> +#include <linux/types.h> +#include <stdint.h> + +struct dev_clk { + int dev_id; + int clk_id; + const char *clk_name; +}; + +#define DEV_CLK(_dev_id, _clk_id, _clk_name) { .dev_id = _dev_id, \ + .clk_id = _clk_id, .clk_name = _clk_name, } + +#define CLK_TYPE_MUX 0x01 +#define CLK_TYPE_DIV 0x02 +#define CLK_TYPE_PLL 0x03 +#define CLK_TYPE_HFOSC 0x04 +#define CLK_TYPE_POSTDIV 0x05 +#define CLK_TYPE_MUX_PLLCTRL 0x06 +#define CLK_TYPE_FIXED_RATE 0x07 + +struct pll_data { + u32 reg; + const char *name; + const char *parent; + u32 flags; +}; + +struct mux_data { + u32 reg; + const char *name; + const char * const *parents; + int num_parents; + u32 flags; + int shift; + int width; +}; + +struct div_data { + u32 reg; + const char *name; + const char *parent; + u32 flags; + int shift; + int width; +}; + +struct hfosc_data { + const char *name; + u32 flags; +}; + +struct fixed_rate_data { + const char *name; + u64 rate; + u32 flags; +}; + +struct postdiv_data { + const char *name; + const char *parent; + int width; + u32 flags; +}; + +struct mux_pllctrl_data { + u32 reg; + const char *name; + const char * const *parents; + int num_parents; + u32 flags; +}; + +struct clk_data { + int type; + u32 default_freq; + union { + struct pll_data pll; + struct mux_data mux; + struct div_data div; + struct hfosc_data hfosc; + struct postdiv_data postdiv; + struct mux_pllctrl_data mux_pllctrl; + struct fixed_rate_data fixed_rate; + } clk; +}; + +#define CLK_MUX(_name, _parents, _num_parents, _reg, _shift, _width, _flags) \ + { \ + .type = CLK_TYPE_MUX, \ + .clk.mux = { .name = _name, .parents = _parents, \ + .reg = _reg, \ + .num_parents = _num_parents, .shift = _shift, \ + .width = _width, .flags = _flags } \ + } + +#define CLK_DIV(_name, _parent, _reg, _shift, _width, _flags) \ + { \ + .type = CLK_TYPE_DIV, \ + .clk.div = {.name = _name, .parent = _parent, .reg = _reg, .shift = _shift, .width = _width, .flags = _flags } \ + } + +#define CLK_DIV_DEFFREQ(_name, _parent, _reg, _shift, _width, _flags, _freq) \ + { \ + .type = CLK_TYPE_DIV, \ + .default_freq = _freq, \ + .clk.div = { \ + .name = _name, .parent = _parent, \ + .reg = _reg, .shift = _shift, \ + .width = _width, .flags = _flags } \ + } + +#define CLK_PLL(_name, _parent, _reg, _flags) \ + { \ + .type = CLK_TYPE_PLL, \ + .clk.pll = {.name = _name, .parent = _parent, .reg = _reg, .flags = _flags } \ + } + +#define CLK_PLL_DEFFREQ(_name, _parent, _reg, _flags, _freq) \ + { \ + .type = CLK_TYPE_PLL, \ + .default_freq = _freq, \ + .clk.pll = { .name = _name, .parent = _parent, \ + .reg = _reg, .flags = _flags } \ + } + +#define CLK_HFOSC(_name, _flags) \ + { \ + .type = CLK_TYPE_HFOSC, \ + .clk.hfosc = { .name = _name, .flags = _flags } \ + } + +#define CLK_FIXED_RATE(_name, _rate, _flags) \ + { \ + .type = CLK_TYPE_FIXED_RATE, \ + .clk.fixed_rate = { .name = _name, .rate = _rate, .flags = _flags } \ + } + +#define CLK_POSTDIV(_name, _parent, _width, _flags) \ + { \ + .type = CLK_TYPE_POSTDIV, \ + .clk.postdiv = {.name = _name, .parent = _parent, .width = _width, .flags = _flags } \ + } + +#define CLK_MUX_PLLCTRL(_name, _parents, _num_parents, _reg, _flags) \ + { \ + .type = CLK_TYPE_MUX, \ + .clk.mux_pllctrl = { .name = _name, .parents = _parents,\ + .num_parents = _num_parents, .flags = _flags } \ + } + +struct ti_k3_clk_platdata { + const struct clk_data *clk_list; + int clk_list_cnt; + const struct dev_clk *soc_dev_clk_data; + int soc_dev_clk_data_cnt; +}; + +extern const struct ti_k3_clk_platdata j721e_clk_platdata; +extern const struct ti_k3_clk_platdata j7200_clk_platdata;
struct clk *clk_register_ti_pll(const char *name, const char *parent_name, void __iomem *reg);
Normally, power domains are handled via TI-SCI in K3 SoCs. However, SPL is not going to have access to sysfw resources, so it must control them directly. Add driver for supporting this.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/power/domain/Kconfig | 7 + drivers/power/domain/Makefile | 1 + drivers/power/domain/ti-power-domain.c | 368 +++++++++++++++++++++++++ include/k3-dev.h | 76 +++++ 4 files changed, 452 insertions(+) create mode 100644 drivers/power/domain/ti-power-domain.c create mode 100644 include/k3-dev.h
diff --git a/drivers/power/domain/Kconfig b/drivers/power/domain/Kconfig index a0fd980752..99b3f9ae71 100644 --- a/drivers/power/domain/Kconfig +++ b/drivers/power/domain/Kconfig @@ -72,4 +72,11 @@ config TI_SCI_POWER_DOMAIN help Generic power domain implementation for TI devices implementing the TI SCI protocol. + +config TI_POWER_DOMAIN + bool "Enable the TI K3 Power domain driver" + depends on POWER_DOMAIN && ARCH_K3 + help + Generic power domain implementation for TI K3 devices. + endmenu diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index 45bf9f6383..3d1e5f073c 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_SANDBOX_POWER_DOMAIN) += sandbox-power-domain.o obj-$(CONFIG_SANDBOX_POWER_DOMAIN) += sandbox-power-domain-test.o obj-$(CONFIG_TEGRA186_POWER_DOMAIN) += tegra186-power-domain.o obj-$(CONFIG_TI_SCI_POWER_DOMAIN) += ti-sci-power-domain.o +obj-$(CONFIG_TI_POWER_DOMAIN) += ti-power-domain.o diff --git a/drivers/power/domain/ti-power-domain.c b/drivers/power/domain/ti-power-domain.c new file mode 100644 index 0000000000..5d089f8e19 --- /dev/null +++ b/drivers/power/domain/ti-power-domain.c @@ -0,0 +1,368 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments power domain driver + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + */ + +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <power-domain-uclass.h> +#include <soc.h> +#include <k3-dev.h> +#include <linux/iopoll.h> + +#define PSC_PTCMD 0x120 +#define PSC_PTSTAT 0x128 +#define PSC_PDSTAT 0x200 +#define PSC_PDCTL 0x300 +#define PSC_MDSTAT 0x800 +#define PSC_MDCTL 0xa00 + +#define PDCTL_STATE_MASK 0x1 +#define PDCTL_STATE_OFF 0x0 +#define PDCTL_STATE_ON 0x1 + +#define MDSTAT_STATE_MASK 0x3f +#define MDSTAT_BUSY_MASK 0x30 +#define MDSTAT_STATE_SWRSTDISABLE 0x0 +#define MDSTAT_STATE_ENABLE 0x3 + +#define LPSC_TIMEOUT 1000 +#define PD_TIMEOUT 1000 + +static u32 psc_read(struct ti_psc *psc, u32 reg) +{ + u32 val; + + val = readl(psc->base + reg); + debug("%s: 0x%x from %p\n", __func__, val, psc->base + reg); + return val; +} + +static void psc_write(u32 val, struct ti_psc *psc, u32 reg) +{ + debug("%s: 0x%x to %p\n", __func__, val, psc->base + reg); + writel(val, psc->base + reg); +} + +static u32 pd_read(struct ti_pd *pd, u32 reg) +{ + return psc_read(pd->psc, reg + 4 * pd->id); +} + +static void pd_write(u32 val, struct ti_pd *pd, u32 reg) +{ + psc_write(val, pd->psc, reg + 4 * pd->id); +} + +static u32 lpsc_read(struct ti_lpsc *lpsc, u32 reg) +{ + return psc_read(lpsc->psc, reg + 4 * lpsc->id); +} + +static void lpsc_write(u32 val, struct ti_lpsc *lpsc, u32 reg) +{ + psc_write(val, lpsc->psc, reg + 4 * lpsc->id); +} + +static const struct soc_attr ti_k3_soc_pd_data[] = { +#ifdef CONFIG_SOC_K3_J721E + { + .family = "J721E", + .data = &j721e_pd_platdata, + }, + { + .family = "J7200", + .data = &j7200_pd_platdata, + }, +#endif + { /* sentinel */ } +}; + +static int ti_power_domain_probe(struct udevice *dev) +{ + struct ti_k3_pd_platdata *data = dev_get_priv(dev); + const struct soc_attr *soc_match_data; + const struct ti_k3_pd_platdata *pdata; + + printf("%s(dev=%p)\n", __func__, dev); + + if (!data) + return -ENOMEM; + + soc_match_data = soc_device_match(ti_k3_soc_pd_data); + if (!soc_match_data) + return -ENODEV; + + pdata = (const struct ti_k3_pd_platdata *)soc_match_data->data; + + data->psc = pdata->psc; + data->pd = pdata->pd; + data->lpsc = pdata->lpsc; + data->devs = pdata->devs; + data->num_psc = pdata->num_psc; + data->num_pd = pdata->num_pd; + data->num_lpsc = pdata->num_lpsc; + data->num_devs = pdata->num_devs; + + return 0; +} + +static int ti_pd_wait(struct ti_pd *pd) +{ + u32 ptstat; + int ret; + + ret = readl_poll_timeout(pd->psc->base + PSC_PTSTAT, ptstat, + !(ptstat & BIT(pd->id)), PD_TIMEOUT); + + if (ret) + printf("%s: psc%d, pd%d failed to transition.\n", __func__, + pd->psc->id, pd->id); + + return ret; +} + +static void ti_pd_transition(struct ti_pd *pd) +{ + psc_write(BIT(pd->id), pd->psc, PSC_PTCMD); +} + +static u8 ti_pd_state(struct ti_pd *pd) +{ + return pd_read(pd, PSC_PDCTL) & PDCTL_STATE_MASK; +} + +static int ti_pd_get(struct ti_pd *pd) +{ + u32 pdctl; + int ret; + + pd->usecount++; + + if (pd->usecount > 1) + return 0; + + if (pd->depend) { + ret = ti_pd_get(pd->depend); + if (ret) + return ret; + ti_pd_transition(pd->depend); + ret = ti_pd_wait(pd->depend); + if (ret) + return ret; + } + + pdctl = pd_read(pd, PSC_PDCTL); + + if ((pdctl & PDCTL_STATE_MASK) == PDCTL_STATE_ON) + return 0; + + debug("%s: enabling psc:%d, pd:%d\n", __func__, pd->psc->id, pd->id); + + pdctl &= ~PDCTL_STATE_MASK; + pdctl |= PDCTL_STATE_ON; + + pd_write(pdctl, pd, PSC_PDCTL); + + return 0; +} + +static int ti_pd_put(struct ti_pd *pd) +{ + u32 pdctl; + int ret; + + pd->usecount--; + + if (pd->usecount > 0) + return 0; + + pdctl = pd_read(pd, PSC_PDCTL); + if ((pdctl & PDCTL_STATE_MASK) == PDCTL_STATE_OFF) + return 0; + + pdctl &= ~PDCTL_STATE_MASK; + pdctl |= PDCTL_STATE_OFF; + + debug("%s: disabling psc:%d, pd:%d\n", __func__, pd->psc->id, pd->id); + + pd_write(pdctl, pd, PSC_PDCTL); + + if (pd->depend) { + ti_pd_transition(pd); + ret = ti_pd_wait(pd); + if (ret) + return ret; + + ret = ti_pd_put(pd->depend); + if (ret) + return ret; + ti_pd_transition(pd->depend); + ret = ti_pd_wait(pd->depend); + if (ret) + return ret; + } + + return 0; +} + +static int ti_lpsc_wait(struct ti_lpsc *lpsc) +{ + u32 mdstat; + int ret; + + ret = readl_poll_timeout(lpsc->psc->base + PSC_MDSTAT + lpsc->id * 4, + mdstat, + !(mdstat & MDSTAT_BUSY_MASK), LPSC_TIMEOUT); + + if (ret) + printf("%s: module %d failed to transition.\n", __func__, + lpsc->id); + + return ret; +} + +static u8 lpsc_get_state(struct ti_lpsc *lpsc) +{ + return lpsc_read(lpsc, PSC_MDCTL) & MDSTAT_STATE_MASK; +} + +static int ti_lpsc_transition(struct ti_lpsc *lpsc, u8 state) +{ + struct ti_pd *psc_pd; + int ret; + u32 mdctl; + + psc_pd = lpsc->pd; + + if (state == MDSTAT_STATE_ENABLE) { + lpsc->usecount++; + if (lpsc->usecount > 1) + return 0; + } else { + lpsc->usecount--; + if (lpsc->usecount >= 1) + return 0; + } + + debug("%s: transitioning psc:%d, lpsc:%d to %x\n", __func__, + lpsc->psc->id, lpsc->id, state); + + if (lpsc->depend) + ti_lpsc_transition(lpsc->depend, state); + + mdctl = lpsc_read(lpsc, PSC_MDCTL); + if ((mdctl & MDSTAT_STATE_MASK) == state) + return 0; + + if (state == MDSTAT_STATE_ENABLE) + ti_pd_get(psc_pd); + else + ti_pd_put(psc_pd); + + mdctl &= ~MDSTAT_STATE_MASK; + mdctl |= state; + + lpsc_write(mdctl, lpsc, PSC_MDCTL); + + ti_pd_transition(psc_pd); + ret = ti_pd_wait(psc_pd); + if (ret) + return ret; + + return ti_lpsc_wait(lpsc); +} + +static int ti_power_domain_transition(struct power_domain *pd, u8 state) +{ + struct ti_lpsc *lpsc = pd->priv; + + return ti_lpsc_transition(lpsc, state); +} + +static int ti_power_domain_on(struct power_domain *pd) +{ + debug("%s(pd=%p, id=%lu)\n", __func__, pd, pd->id); + + return ti_power_domain_transition(pd, MDSTAT_STATE_ENABLE); +} + +static int ti_power_domain_off(struct power_domain *pd) +{ + debug("%s(pd=%p, id=%lu)\n", __func__, pd, pd->id); + + return ti_power_domain_transition(pd, MDSTAT_STATE_SWRSTDISABLE); +} + +static struct ti_lpsc *lpsc_lookup(struct ti_k3_pd_platdata *data, int id) +{ + int idx; + + for (idx = 0; idx < data->num_devs; idx++) + if (data->devs[idx].id == id) + return data->devs[idx].lpsc; + + return NULL; +} + +static int ti_power_domain_of_xlate(struct power_domain *pd, + struct ofnode_phandle_args *args) +{ + struct ti_k3_pd_platdata *data = dev_get_priv(pd->dev); + struct ti_lpsc *lpsc; + + debug("%s(power_domain=%p, id=%d)\n", __func__, pd, args->args[0]); + + if (args->args_count < 1) { + printf("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + lpsc = lpsc_lookup(data, args->args[0]); + if (!lpsc) { + printf("%s: invalid dev-id: %d\n", __func__, args->args[0]); + return -ENOENT; + } + + pd->id = lpsc->id; + pd->priv = lpsc; + + return 0; +} + +static int ti_power_domain_request(struct power_domain *pd) +{ + return 0; +} + +static int ti_power_domain_free(struct power_domain *pd) +{ + return 0; +} + +static const struct udevice_id ti_power_domain_of_match[] = { + { .compatible = "ti,sci-pm-domain" }, + { /* sentinel */ } +}; + +static struct power_domain_ops ti_power_domain_ops = { + .on = ti_power_domain_on, + .off = ti_power_domain_off, + .of_xlate = ti_power_domain_of_xlate, + .request = ti_power_domain_request, + .rfree = ti_power_domain_free, +}; + +U_BOOT_DRIVER(ti_pm_domains) = { + .name = "ti-pm-domains", + .id = UCLASS_POWER_DOMAIN, + .of_match = ti_power_domain_of_match, + .probe = ti_power_domain_probe, + .priv_auto = sizeof(struct ti_k3_pd_platdata), + .ops = &ti_power_domain_ops, +}; diff --git a/include/k3-dev.h b/include/k3-dev.h new file mode 100644 index 0000000000..de3a8bdf9e --- /dev/null +++ b/include/k3-dev.h @@ -0,0 +1,76 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Texas Instruments K3 Device Platform Data + * + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + */ +#ifndef __K3_DEV_H__ +#define __K3_DEV_H__ + +#include <asm/io.h> +#include <linux/types.h> +#include <stdint.h> + +#define LPSC_MODULE_EXISTS BIT(0) +#define LPSC_NO_CLOCK_GATING BIT(1) +#define LPSC_DEPENDS BIT(2) +#define LPSC_HAS_RESET_ISO BIT(3) +#define LPSC_HAS_LOCAL_RESET BIT(4) +#define LPSC_NO_MODULE_RESET BIT(5) + +#define PSC_PD_EXISTS BIT(0) +#define PSC_PD_ALWAYSON BIT(1) +#define PSC_PD_DEPENDS BIT(2) + +struct ti_psc { + int id; + void __iomem *base; +}; + +struct ti_pd; + +struct ti_pd { + int id; + int usecount; + struct ti_psc *psc; + struct ti_pd *depend; +}; + +struct ti_lpsc; + +struct ti_lpsc { + int id; + int usecount; + struct ti_psc *psc; + struct ti_pd *pd; + struct ti_lpsc *depend; +}; + +struct ti_dev { + struct ti_lpsc *lpsc; + int id; +}; + +/** + * struct ti_k3_pd_platdata - pm domain controller information structure + */ +struct ti_k3_pd_platdata { + struct ti_psc *psc; + struct ti_pd *pd; + struct ti_lpsc *lpsc; + struct ti_dev *devs; + int num_psc; + int num_pd; + int num_lpsc; + int num_devs; +}; + +#define PSC(_id, _base) { .id = _id, .base = (void *)_base, } +#define PSC_PD(_id, _psc, _depend) { .id = _id, .psc = _psc, .depend = _depend } +#define PSC_LPSC(_id, _psc, _pd, _depend) { .id = _id, .psc = _psc, .pd = _pd, .depend = _depend } +#define PSC_DEV(_id, _lpsc) { .id = _id, .lpsc = _lpsc } + +extern const struct ti_k3_pd_platdata j721e_pd_platdata; +extern const struct ti_k3_pd_platdata j7200_pd_platdata; + +#endif
Add support command for debugging K3 power domains. This is useful with the HSM rearch setup, where power domains are directly controlled by SPL instead of going through the TI SCI layer. The debugging support is only available in the u-boot codebase though, so the raw register access power domain layer must be enabled on u-boot side for this to work. By default, u-boot side uses the TI SCI layer, and R5 SPL only uses the direct access methods.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com --- cmd/ti/Kconfig | 8 ++ cmd/ti/Makefile | 1 + cmd/ti/pd.c | 185 +++++++++++++++++++++++++ drivers/power/domain/ti-power-domain.c | 6 +- include/k3-dev.h | 9 ++ 5 files changed, 206 insertions(+), 3 deletions(-) create mode 100644 cmd/ti/pd.c
diff --git a/cmd/ti/Kconfig b/cmd/ti/Kconfig index efeff0d482..db557445a8 100644 --- a/cmd/ti/Kconfig +++ b/cmd/ti/Kconfig @@ -7,4 +7,12 @@ config CMD_DDR3 supports memory verification, memory comapre and ecc verification if supported.
+config CMD_PD + bool "command for verifying power domains" + depends on TI_POWER_DOMAIN + help + Debug command for K3 power domains. For this to work, the + K3 power domain driver must be enabled for the u-boot; by + default it is only enabled for SPL. + endmenu diff --git a/cmd/ti/Makefile b/cmd/ti/Makefile index 16fbade9ed..045593396b 100644 --- a/cmd/ti/Makefile +++ b/cmd/ti/Makefile @@ -5,4 +5,5 @@ obj- += dummy.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_DDR3) += ddr3.o +obj-$(CONFIG_CMD_PD) += pd.o endif diff --git a/cmd/ti/pd.c b/cmd/ti/pd.c new file mode 100644 index 0000000000..a53ccdcc40 --- /dev/null +++ b/cmd/ti/pd.c @@ -0,0 +1,185 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Power Domain test commands + * + * Copyright (C) 2020 Texas Instruments Incorporated, <www.ti.com> + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <k3-dev.h> + +static const struct udevice_id ti_pd_of_match[] = { + { .compatible = "ti,sci-pm-domain" }, + { /* sentinel */ } +}; + +static struct ti_k3_pd_platdata *ti_pd_find_data(void) +{ + struct udevice *dev; + int i = 0; + + while (1) { + uclass_get_device(UCLASS_POWER_DOMAIN, i++, &dev); + if (!dev) + return NULL; + + if (device_is_compatible(dev, + ti_pd_of_match[0].compatible)) + return dev_get_priv(dev); + } + + return NULL; +} + +static void dump_lpsc(struct ti_k3_pd_platdata *data, struct ti_pd *pd) +{ + int i; + struct ti_lpsc *lpsc; + u8 state; + static const char * const lpsc_states[] = { + "swrstdis", "syncrst", "disable", "enable", "autosleep", + "autowake", "unknown", + }; + + for (i = 0; i < data->num_lpsc; i++) { + lpsc = &data->lpsc[i]; + if (lpsc->pd != pd) + continue; + state = lpsc_get_state(lpsc); + if (state > ARRAY_SIZE(lpsc_states)) + state = ARRAY_SIZE(lpsc_states) - 1; + printf(" LPSC%d: state=%s, usecount=%d\n", + lpsc->id, lpsc_states[state], lpsc->usecount); + } +} + +static void dump_pd(struct ti_k3_pd_platdata *data, struct ti_psc *psc) +{ + int i; + struct ti_pd *pd; + u8 state; + static const char * const pd_states[] = { + "off", "on", "unknown" + }; + + for (i = 0; i < data->num_pd; i++) { + pd = &data->pd[i]; + if (pd->psc != psc) + continue; + state = ti_pd_state(pd); + if (state > ARRAY_SIZE(pd_states)) + state = ARRAY_SIZE(pd_states) - 1; + printf(" PD%d: state=%s, usecount=%d:\n", + pd->id, pd_states[state], pd->usecount); + dump_lpsc(data, pd); + } +} + +static void dump_psc(struct ti_k3_pd_platdata *data) +{ + int i; + struct ti_psc *psc; + + for (i = 0; i < data->num_psc; i++) { + psc = &data->psc[i]; + printf("PSC%d [%p]:\n", psc->id, psc->base); + dump_pd(data, psc); + } +} + +static int do_pd_dump(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ti_k3_pd_platdata *data; + + data = ti_pd_find_data(); + if (!data) + return CMD_RET_FAILURE; + + dump_psc(data); + + return 0; +} + +static int do_pd_endis(int argc, char *const argv[], u8 state) +{ + u32 psc_id; + u32 lpsc_id; + int i; + struct ti_k3_pd_platdata *data; + struct ti_lpsc *lpsc; + int ret; + + if (argc < 3) + return CMD_RET_FAILURE; + + data = ti_pd_find_data(); + if (!data) + return CMD_RET_FAILURE; + + psc_id = simple_strtoul(argv[1], NULL, 10); + lpsc_id = simple_strtoul(argv[2], NULL, 10); + + for (i = 0; i < data->num_lpsc; i++) { + lpsc = &data->lpsc[i]; + if (lpsc->pd->psc->id != psc_id) + continue; + if (lpsc->id != lpsc_id) + continue; + printf("%s pd [PSC:%d,LPSC:%d]...\n", + state == MDSTAT_STATE_ENABLE ? "Enabling" : "Disabling", + psc_id, lpsc_id); + ret = ti_lpsc_transition(lpsc, state); + if (ret) + return CMD_RET_FAILURE; + else + return 0; + } + + printf("No matching psc/lpsc found.\n"); + + return CMD_RET_FAILURE; +} + +static int do_pd_enable(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + return do_pd_endis(argc, argv, MDSTAT_STATE_ENABLE); +} + +static int do_pd_disable(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + return do_pd_endis(argc, argv, MDSTAT_STATE_SWRSTDISABLE); +} + +static struct cmd_tbl cmd_pd[] = { + U_BOOT_CMD_MKENT(dump, 1, 0, do_pd_dump, "", ""), + U_BOOT_CMD_MKENT(enable, 3, 0, do_pd_enable, "", ""), + U_BOOT_CMD_MKENT(disable, 3, 0, do_pd_disable, "", ""), +}; + +static int ti_do_pd(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) +{ + struct cmd_tbl *c; + + argc--; + argv++; + + c = find_cmd_tbl(argv[0], cmd_pd, ARRAY_SIZE(cmd_pd)); + if (c) + return c->cmd(cmdtp, flag, argc, argv); + else + return CMD_RET_USAGE; +} + +U_BOOT_CMD(pd, 4, 1, ti_do_pd, + "TI power domain control", +#ifdef CONFIG_SYS_LONGHELP + "dump - show power domain status\n" + "enable [psc] [lpsc] - enable power domain\n" + "disable [psc] [lpsc] - disable power domain\n" +#endif +); diff --git a/drivers/power/domain/ti-power-domain.c b/drivers/power/domain/ti-power-domain.c index 5d089f8e19..d15f922ee6 100644 --- a/drivers/power/domain/ti-power-domain.c +++ b/drivers/power/domain/ti-power-domain.c @@ -132,7 +132,7 @@ static void ti_pd_transition(struct ti_pd *pd) psc_write(BIT(pd->id), pd->psc, PSC_PTCMD); }
-static u8 ti_pd_state(struct ti_pd *pd) +u8 ti_pd_state(struct ti_pd *pd) { return pd_read(pd, PSC_PDCTL) & PDCTL_STATE_MASK; } @@ -227,12 +227,12 @@ static int ti_lpsc_wait(struct ti_lpsc *lpsc) return ret; }
-static u8 lpsc_get_state(struct ti_lpsc *lpsc) +u8 lpsc_get_state(struct ti_lpsc *lpsc) { return lpsc_read(lpsc, PSC_MDCTL) & MDSTAT_STATE_MASK; }
-static int ti_lpsc_transition(struct ti_lpsc *lpsc, u8 state) +int ti_lpsc_transition(struct ti_lpsc *lpsc, u8 state) { struct ti_pd *psc_pd; int ret; diff --git a/include/k3-dev.h b/include/k3-dev.h index de3a8bdf9e..55c5057db3 100644 --- a/include/k3-dev.h +++ b/include/k3-dev.h @@ -22,6 +22,11 @@ #define PSC_PD_ALWAYSON BIT(1) #define PSC_PD_DEPENDS BIT(2)
+#define MDSTAT_STATE_MASK 0x3f +#define MDSTAT_BUSY_MASK 0x30 +#define MDSTAT_STATE_SWRSTDISABLE 0x0 +#define MDSTAT_STATE_ENABLE 0x3 + struct ti_psc { int id; void __iomem *base; @@ -73,4 +78,8 @@ struct ti_k3_pd_platdata { extern const struct ti_k3_pd_platdata j721e_pd_platdata; extern const struct ti_k3_pd_platdata j7200_pd_platdata;
+u8 ti_pd_state(struct ti_pd *pd); +u8 lpsc_get_state(struct ti_lpsc *lpsc); +int ti_lpsc_transition(struct ti_lpsc *lpsc, u8 state); + #endif
Add DM (device manager) firmware image to the fit image that is loaded by R5 SPL. This is needed with the HSM rearch where the firmware allocation has been changed slightly.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/config.mk | 4 ++++ tools/k3_fit_atf.sh | 19 ++++++++++++++++++- 2 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index 41fee2b5a1..503ece4520 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -49,6 +49,10 @@ endif
ifdef CONFIG_ARM64
+ifeq ($(CONFIG_SOC_K3_J721E),) +export DM := /dev/null +endif + ifeq ($(CONFIG_TI_SECURE_DEVICE),y) SPL_ITS := u-boot-spl-k3_HS.its $(SPL_ITS): export IS_HS=1 diff --git a/tools/k3_fit_atf.sh b/tools/k3_fit_atf.sh index 4e9f69c087..c0940a2fcc 100755 --- a/tools/k3_fit_atf.sh +++ b/tools/k3_fit_atf.sh @@ -21,6 +21,13 @@ if [ ! -f $TEE ]; then TEE=/dev/null fi
+[ -z "$DM" ] && DM="dm.bin" + +if [ ! -e $DM ]; then + echo "WARNING DM file $DM NOT found, resulting might be non-functional" >&2 + DM=/dev/null +fi + if [ ! -z "$IS_HS" ]; then HS_APPEND=_HS fi @@ -53,6 +60,16 @@ cat << __HEADER_EOF load = <0x9e800000>; entry = <0x9e800000>; }; + dm { + description = "DM binary"; + data = /incbin/("$DM"); + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0xa0000000>; + entry = <0xa0000000>; + }; spl { description = "SPL (64-bit)"; data = /incbin/("spl/u-boot-spl-nodtb.bin$HS_APPEND"); @@ -91,7 +108,7 @@ do $(basename $dtname) { description = "$(basename $dtname .dtb)"; firmware = "atf"; - loadables = "tee", "spl"; + loadables = "tee", "dm", "spl"; fdt = "$(basename $dtname)"; }; __CONF_SECTION_EOF
Add platform clock and powerdomain data for J721e and J7200. This data is used by the corresponding drivers to register all the required device clocks and powerdomains.
Signed-off-by: Dave Gerlach d-gerlach@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/Makefile | 2 +- arch/arm/mach-k3/j7200/Makefile | 5 + arch/arm/mach-k3/j7200/clk-data.c | 547 +++++++++++++++++++++ arch/arm/mach-k3/j7200/dev-data.c | 77 +++ arch/arm/mach-k3/j721e/Makefile | 5 + arch/arm/mach-k3/j721e/clk-data.c | 781 ++++++++++++++++++++++++++++++ arch/arm/mach-k3/j721e/dev-data.c | 75 +++ 7 files changed, 1491 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-k3/j7200/Makefile create mode 100644 arch/arm/mach-k3/j7200/clk-data.c create mode 100644 arch/arm/mach-k3/j7200/dev-data.c create mode 100644 arch/arm/mach-k3/j721e/Makefile create mode 100644 arch/arm/mach-k3/j721e/clk-data.c create mode 100644 arch/arm/mach-k3/j721e/dev-data.c
diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 890d1498d0..47cf7b6d17 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -4,7 +4,7 @@ # Lokesh Vutla lokeshvutla@ti.com
obj-$(CONFIG_SOC_K3_AM6) += am6_init.o -obj-$(CONFIG_SOC_K3_J721E) += j721e_init.o +obj-$(CONFIG_SOC_K3_J721E) += j721e_init.o j721e/ j7200/ obj-$(CONFIG_SOC_K3_AM642) += am642_init.o obj-$(CONFIG_ARM64) += arm64-mmu.o obj-$(CONFIG_CPU_V7R) += r5_mpu.o lowlevel_init.o diff --git a/arch/arm/mach-k3/j7200/Makefile b/arch/arm/mach-k3/j7200/Makefile new file mode 100644 index 0000000000..ff9abd78ea --- /dev/null +++ b/arch/arm/mach-k3/j7200/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ +obj-y += clk-data.o +obj-y += dev-data.o diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/j7200/clk-data.c new file mode 100644 index 0000000000..93c067079a --- /dev/null +++ b/arch/arm/mach-k3/j7200/clk-data.c @@ -0,0 +1,547 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * J7200 specific clock platform data + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "k3-clk.h" + +static const char * const gluelogic_hfosc0_clkout_parents[] = { + "osc_19_2_mhz", + "osc_20_mhz", + "osc_24_mhz", + "osc_25_mhz", + "osc_26_mhz", + "osc_27_mhz", +}; + +static const char * const mcu_ospi0_iclk_sel_out0_parents[] = { + "board_0_mcu_ospi0_dqs_out", + "fss_mcu_0_ospi_0_ospi_oclk_clk", +}; + +static const char * const wkup_fref_clksel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", +}; + +static const char * const main_pll_hfosc_sel_out1_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents[] = { + "wkup_fref_clksel_out0", + "hsdiv1_16fft_mcu_0_hsdivout0_clk", +}; + +static const char * const mcu_ospi_ref_clk_sel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout4_clk", + "hsdiv4_16fft_mcu_2_hsdivout4_clk", +}; + +static const char * const mcuusart_clk_sel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "postdiv2_16fft_main_1_hsdivout5_clk", +}; + +static const char * const wkup_gpio0_clksel_out0_parents[] = { + "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", + "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", +}; + +static const char * const wkup_i2c0_mcupll_bypass_clksel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "gluelogic_hfosc0_clkout", +}; + +static const char * const main_pll_hfosc_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out12_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out14_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out2_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out3_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out4_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out7_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out8_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const usb0_refclk_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const wkup_obsclk_mux_out0_parents[] = { + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", + NULL, + "hsdiv1_16fft_mcu_0_hsdivout0_clk", + "hsdiv1_16fft_mcu_0_hsdivout0_clk", + "hsdiv4_16fft_mcu_1_hsdivout1_clk", + "hsdiv4_16fft_mcu_1_hsdivout2_clk", + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "hsdiv4_16fft_mcu_1_hsdivout4_clk", + "hsdiv4_16fft_mcu_2_hsdivout0_clk", + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", + "hsdiv4_16fft_mcu_2_hsdivout1_clk", + "hsdiv4_16fft_mcu_2_hsdivout2_clk", + "hsdiv4_16fft_mcu_2_hsdivout3_clk", + "hsdiv4_16fft_mcu_2_hsdivout4_clk", + "gluelogic_hfosc0_clkout", + "board_0_wkup_lf_clkin_out", +}; + +static const char * const main_pll4_xref_sel_out0_parents[] = { + "main_pll_hfosc_sel_out4", + "board_0_ext_refclk1_out", +}; + +static const char * const mcu_clkout_mux_out0_parents[] = { + "hsdiv4_16fft_mcu_2_hsdivout0_clk", + "hsdiv4_16fft_mcu_2_hsdivout0_clk", +}; + +static const char * const k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents[] = { + "main_pll_hfosc_sel_out0", + "hsdiv4_16fft_main_0_hsdivout0_clk", +}; + +static const char * const mcu_obsclk_outmux_out0_parents[] = { + "mcu_obsclk_div_out0", + "gluelogic_hfosc0_clkout", +}; + +static const char * const clkout_mux_out0_parents[] = { + "hsdiv4_16fft_main_3_hsdivout0_clk", + "hsdiv4_16fft_main_3_hsdivout0_clk", +}; + +static const char * const emmcsd_refclk_sel_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout2_clk", + "hsdiv4_16fft_main_1_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", +}; + +static const char * const emmcsd_refclk_sel_out1_parents[] = { + "hsdiv4_16fft_main_0_hsdivout2_clk", + "hsdiv4_16fft_main_1_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", +}; + +static const char * const gtc_clk_mux_out0_parents[] = { + "hsdiv4_16fft_main_3_hsdivout1_clk", + "postdiv2_16fft_main_0_hsdivout6_clk", + "board_0_mcu_cpts0_rft_clk_out", + "board_0_cpts0_rft_clk_out", + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv4_16fft_mcu_2_hsdivout1_clk", + "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const obsclk1_mux_out0_parents[] = { + NULL, + "hsdiv0_16fft_main_8_hsdivout0_clk", + NULL, + NULL, +}; + +static const char * const gpmc_fclk_sel_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout3_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk", + "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const audio_refclko_mux_out0_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv2_16fft_main_4_hsdivout2_clk", + NULL, + NULL, + NULL, +}; + +static const char * const audio_refclko_mux_out1_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv2_16fft_main_4_hsdivout2_clk", + NULL, + NULL, + NULL, +}; + +static const char * const obsclk0_mux_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout0_clk", + "hsdiv4_16fft_main_1_hsdivout0_clk", + "hsdiv4_16fft_main_2_hsdivout0_clk", + "hsdiv4_16fft_main_3_hsdivout0_clk", + "hsdiv2_16fft_main_4_hsdivout0_clk", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv0_16fft_main_12_hsdivout0_clk", + "obsclk1_mux_out0", + "hsdiv1_16fft_main_14_hsdivout0_clk", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", + "board_0_wkup_lf_clkin_out", + "hsdiv4_16fft_main_0_hsdivout0_clk", + "board_0_hfosc1_clk_out", + "gluelogic_hfosc0_clkout", +}; + +static const struct clk_data clk_list[] = { + CLK_FIXED_RATE("osc_27_mhz", 27000000, 0), + CLK_FIXED_RATE("osc_26_mhz", 26000000, 0), + CLK_FIXED_RATE("osc_25_mhz", 25000000, 0), + CLK_FIXED_RATE("osc_24_mhz", 24000000, 0), + CLK_FIXED_RATE("osc_20_mhz", 20000000, 0), + CLK_FIXED_RATE("osc_19_2_mhz", 19200000, 0), + CLK_MUX("gluelogic_hfosc0_clkout", gluelogic_hfosc0_clkout_parents, 6, 0x43000030, 0, 3, 0), + CLK_FIXED_RATE("board_0_hfosc1_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ospi0_dqs_out", 0, 0), + CLK_FIXED_RATE("board_0_wkup_i2c0_scl_out", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_ospi_0_ospi_oclk_clk", 0, 0), + CLK_FIXED_RATE("j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", 12500000, 0), + CLK_FIXED_RATE("j7vc_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", 32550, 0), + CLK_MUX("mcu_ospi0_iclk_sel_out0", mcu_ospi0_iclk_sel_out0_parents, 2, 0x40f08030, 4, 1, 0), + CLK_FIXED_RATE("mshsi2c_wkup_0_porscl", 0, 0), + CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), + CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_PLL("pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), + CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), + CLK_PLL_DEFFREQ("pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), + CLK_DIV("postdiv2_16fft_main_1_hsdivout5_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 166666666), + CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents, 2, 0x42010000, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0), + CLK_MUX("mcu_ospi_ref_clk_sel_out0", mcu_ospi_ref_clk_sel_out0_parents, 2, 0x40f08030, 0, 1, 0), + CLK_MUX("mcuusart_clk_sel_out0", mcuusart_clk_sel_out0_parents, 2, 0x40f081c0, 0, 1, 0), + CLK_MUX("wkup_gpio0_clksel_out0", wkup_gpio0_clksel_out0_parents, 4, 0x43008070, 0, 2, 0), + CLK_MUX("wkup_i2c0_mcupll_bypass_clksel_out0", wkup_i2c0_mcupll_bypass_clksel_out0_parents, 2, 0x43008060, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out0", main_pll_hfosc_sel_out0_parents, 2, 0x43008080, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out12", main_pll_hfosc_sel_out12_parents, 2, 0x430080b0, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out14", main_pll_hfosc_sel_out14_parents, 2, 0x430080b8, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out2", main_pll_hfosc_sel_out2_parents, 2, 0x43008088, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out3", main_pll_hfosc_sel_out3_parents, 2, 0x4300808c, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out4", main_pll_hfosc_sel_out4_parents, 2, 0x43008090, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out7", main_pll_hfosc_sel_out7_parents, 2, 0x4300809c, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out8", main_pll_hfosc_sel_out8_parents, 2, 0x430080a0, 0, 1, 0), + CLK_MUX("usb0_refclk_sel_out0", usb0_refclk_sel_out0_parents, 2, 0x1080e0, 0, 1, 0), + CLK_FIXED_RATE("board_0_cpts0_rft_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_ext_refclk1_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_cpts0_rft_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ext_refclk0_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_i2c0_scl_out", 0, 0), + CLK_FIXED_RATE("board_0_wkup_lf_clkin_out", 0, 0), + CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 192000000), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfracf_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_2_foutvcop_clk", "main_pll_hfosc_sel_out2", 0x682000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_3_foutvcop_clk", "main_pll_hfosc_sel_out3", 0x683000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_7_foutvcop_clk", "main_pll_hfosc_sel_out7", 0x687000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_8_foutvcop_clk", "main_pll_hfosc_sel_out8", 0x688000, 0), + CLK_DIV("postdiv2_16fft_main_0_hsdivout6_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0), + CLK_DIV("postdiv2_16fft_main_1_hsdivout7_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0), + CLK_MUX("wkup_obsclk_mux_out0", wkup_obsclk_mux_out0_parents, 16, 0x43008000, 0, 4, 0), + CLK_MUX("main_pll4_xref_sel_out0", main_pll4_xref_sel_out0_parents, 2, 0x43008090, 4, 1, 0), + CLK_MUX("mcu_clkout_mux_out0", mcu_clkout_mux_out0_parents, 2, 0x40f08010, 0, 1, 0), + CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 48000000), + CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfracf_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfracf_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfracf_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfracf_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0), + CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_main_0_sysclkout_clk", k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0), + CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0), + CLK_MUX("mcu_obsclk_outmux_out0", mcu_obsclk_outmux_out0_parents, 2, 0x43008000, 24, 1, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_4_foutvcop_clk", "main_pll4_xref_sel_out0", 0x684000, 0), + CLK_MUX("clkout_mux_out0", clkout_mux_out0_parents, 2, 0x108010, 0, 1, 0), + CLK_MUX("emmcsd_refclk_sel_out0", emmcsd_refclk_sel_out0_parents, 4, 0x1080b0, 0, 2, 0), + CLK_MUX("emmcsd_refclk_sel_out1", emmcsd_refclk_sel_out1_parents, 4, 0x1080b4, 0, 2, 0), + CLK_MUX("gtc_clk_mux_out0", gtc_clk_mux_out0_parents, 16, 0x108030, 0, 4, 0), + CLK_MUX("obsclk1_mux_out0", obsclk1_mux_out0_parents, 4, 0x108004, 0, 2, 0), + CLK_MUX("gpmc_fclk_sel_out0", gpmc_fclk_sel_out0_parents, 4, 0x1080d0, 0, 2, 0), + CLK_DIV("hsdiv2_16fft_main_4_hsdivout0_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0), + CLK_DIV("hsdiv2_16fft_main_4_hsdivout2_clk", "pllfracf_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0), + CLK_MUX("audio_refclko_mux_out0", audio_refclko_mux_out0_parents, 32, 0x1082e0, 0, 5, 0), + CLK_MUX("audio_refclko_mux_out1", audio_refclko_mux_out1_parents, 32, 0x1082e4, 0, 5, 0), + CLK_MUX("obsclk0_mux_out0", obsclk0_mux_out0_parents, 32, 0x108000, 0, 5, 0), + CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0), +}; + +static const struct dev_clk soc_dev_clk_data[] = { + DEV_CLK(4, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(4, 1, "hsdiv0_16fft_main_7_hsdivout0_clk"), + DEV_CLK(4, 2, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(8, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(8, 5, "hsdiv0_16fft_main_12_hsdivout0_clk"), + DEV_CLK(30, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 1, "board_0_hfosc1_clk_out"), + DEV_CLK(30, 2, "hsdiv4_16fft_main_0_hsdivout3_clk"), + DEV_CLK(30, 4, "hsdiv4_16fft_main_0_hsdivout1_clk"), + DEV_CLK(30, 5, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 6, "gluelogic_hfosc0_clkout"), + DEV_CLK(30, 7, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(30, 8, "hsdiv4_16fft_main_0_hsdivout4_clk"), + DEV_CLK(30, 9, "gluelogic_hfosc0_clkout"), + DEV_CLK(30, 10, "board_0_hfosc1_clk_out"), + DEV_CLK(30, 11, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 12, "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(61, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(61, 1, "gtc_clk_mux_out0"), + DEV_CLK(61, 2, "hsdiv4_16fft_main_3_hsdivout1_clk"), + DEV_CLK(61, 3, "postdiv2_16fft_main_0_hsdivout6_clk"), + DEV_CLK(61, 4, "board_0_mcu_cpts0_rft_clk_out"), + DEV_CLK(61, 5, "board_0_cpts0_rft_clk_out"), + DEV_CLK(61, 6, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(61, 7, "board_0_ext_refclk1_out"), + DEV_CLK(61, 16, "hsdiv4_16fft_mcu_2_hsdivout1_clk"), + DEV_CLK(61, 17, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(91, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(91, 3, "emmcsd_refclk_sel_out0"), + DEV_CLK(91, 4, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(91, 5, "hsdiv4_16fft_main_1_hsdivout2_clk"), + DEV_CLK(91, 6, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(91, 7, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(92, 0, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(92, 1, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(92, 2, "emmcsd_refclk_sel_out1"), + DEV_CLK(92, 3, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(92, 4, "hsdiv4_16fft_main_1_hsdivout2_clk"), + DEV_CLK(92, 5, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(92, 6, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(102, 1, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 2, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 4, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(102, 5, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 7, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(103, 0, "mcu_ospi_ref_clk_sel_out0"), + DEV_CLK(103, 1, "hsdiv4_16fft_mcu_1_hsdivout4_clk"), + DEV_CLK(103, 2, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(103, 3, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(103, 4, "board_0_mcu_ospi0_dqs_out"), + DEV_CLK(103, 5, "mcu_ospi0_iclk_sel_out0"), + DEV_CLK(103, 6, "board_0_mcu_ospi0_dqs_out"), + DEV_CLK(103, 7, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(103, 8, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(104, 0, "hsdiv4_16fft_mcu_1_hsdivout4_clk"), + DEV_CLK(104, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(104, 7, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(113, 0, "wkup_gpio0_clksel_out0"), + DEV_CLK(113, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(113, 2, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(113, 3, "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk"), + DEV_CLK(113, 4, "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(133, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(133, 1, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(138, 0, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(138, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(146, 2, "usart_programmable_clock_divider_out0"), + DEV_CLK(146, 3, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(149, 2, "mcuusart_clk_sel_out0"), + DEV_CLK(149, 3, "hsdiv4_16fft_mcu_1_hsdivout3_clk"), + DEV_CLK(149, 4, "postdiv2_16fft_main_1_hsdivout5_clk"), + DEV_CLK(149, 5, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(154, 0, "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(154, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(154, 2, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 5, "osbclk0_div_out0"), + DEV_CLK(157, 7, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n"), + DEV_CLK(157, 14, "mcu_obsclk_outmux_out0"), + DEV_CLK(157, 15, "mcu_obsclk_div_out0"), + DEV_CLK(157, 16, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 35, "clkout_mux_out0"), + DEV_CLK(157, 36, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 37, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 38, "osbclk0_div_out0"), + DEV_CLK(157, 57, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p"), + DEV_CLK(157, 65, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(157, 69, "mcu_clkout_mux_out0"), + DEV_CLK(157, 70, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(157, 71, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(157, 77, "audio_refclko_mux_out1"), + DEV_CLK(157, 106, "hsdiv2_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 110, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(157, 114, "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk"), + DEV_CLK(157, 123, "mshsi2c_wkup_0_porscl"), + DEV_CLK(157, 131, "audio_refclko_mux_out0"), + DEV_CLK(157, 160, "hsdiv2_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 169, "board_0_mcu_i2c0_scl_out"), + DEV_CLK(157, 177, "k3_pll_ctrl_wrap_main_0_sysclkout_clk"), + DEV_CLK(157, 184, "gpmc_fclk_sel_out0"), + DEV_CLK(157, 187, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(157, 192, "osbclk0_div_out0"), + DEV_CLK(157, 193, "hsdiv4_16fft_main_0_hsdivout0_clk"), + DEV_CLK(157, 194, "hsdiv4_16fft_main_1_hsdivout0_clk"), + DEV_CLK(157, 195, "hsdiv4_16fft_main_2_hsdivout0_clk"), + DEV_CLK(157, 196, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 197, "hsdiv2_16fft_main_4_hsdivout0_clk"), + DEV_CLK(157, 205, "hsdiv0_16fft_main_12_hsdivout0_clk"), + DEV_CLK(157, 206, "obsclk1_mux_out0"), + DEV_CLK(157, 207, "hsdiv1_16fft_main_14_hsdivout0_clk"), + DEV_CLK(157, 220, "j7vc_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(157, 221, "board_0_wkup_lf_clkin_out"), + DEV_CLK(157, 222, "hsdiv4_16fft_main_0_hsdivout0_clk"), + DEV_CLK(157, 223, "board_0_hfosc1_clk_out"), + DEV_CLK(157, 224, "gluelogic_hfosc0_clkout"), + DEV_CLK(197, 0, "board_0_wkup_i2c0_scl_out"), + DEV_CLK(197, 1, "wkup_i2c0_mcupll_bypass_clksel_out0"), + DEV_CLK(197, 2, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(202, 2, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(203, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(288, 3, "postdiv2_16fft_main_1_hsdivout7_clk"), + DEV_CLK(288, 4, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 6, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 12, "usb0_refclk_sel_out0"), + DEV_CLK(288, 13, "gluelogic_hfosc0_clkout"), + DEV_CLK(288, 14, "board_0_hfosc1_clk_out"), + DEV_CLK(288, 15, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 17, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), +}; + +const struct ti_k3_clk_platdata j7200_clk_platdata = { + .clk_list = clk_list, + .clk_list_cnt = 108, + .soc_dev_clk_data = soc_dev_clk_data, + .soc_dev_clk_data_cnt = 127, +}; diff --git a/arch/arm/mach-k3/j7200/dev-data.c b/arch/arm/mach-k3/j7200/dev-data.c new file mode 100644 index 0000000000..c68bcc58e9 --- /dev/null +++ b/arch/arm/mach-k3/j7200/dev-data.c @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * J7200 specific device platform data + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "k3-dev.h" + +static struct ti_psc soc_psc_list[] = { + [0] = PSC(0, 0x00400000), + [1] = PSC(1, 0x42000000), +}; + +static struct ti_pd soc_pd_list[] = { + [0] = PSC_PD(0, &soc_psc_list[0], NULL), + [1] = PSC_PD(2, &soc_psc_list[0], &soc_pd_list[5]), + [2] = PSC_PD(14, &soc_psc_list[0], NULL), + [3] = PSC_PD(15, &soc_psc_list[0], &soc_pd_list[2]), + [4] = PSC_PD(16, &soc_psc_list[0], &soc_pd_list[2]), + [5] = PSC_PD(0, &soc_psc_list[1], NULL), +}; + +static struct ti_lpsc soc_lpsc_list[] = { + [0] = PSC_LPSC(0, &soc_psc_list[0], &soc_pd_list[0], NULL), + [1] = PSC_LPSC(9, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[14]), + [2] = PSC_LPSC(14, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[3]), + [3] = PSC_LPSC(15, &soc_psc_list[0], &soc_pd_list[0], NULL), + [4] = PSC_LPSC(20, &soc_psc_list[0], &soc_pd_list[0], NULL), + [5] = PSC_LPSC(23, &soc_psc_list[0], &soc_pd_list[0], NULL), + [6] = PSC_LPSC(25, &soc_psc_list[0], &soc_pd_list[0], NULL), + [7] = PSC_LPSC(54, &soc_psc_list[0], &soc_pd_list[1], NULL), + [8] = PSC_LPSC(78, &soc_psc_list[0], &soc_pd_list[2], NULL), + [9] = PSC_LPSC(79, &soc_psc_list[0], &soc_pd_list[2], &soc_lpsc_list[8]), + [10] = PSC_LPSC(80, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[8]), + [11] = PSC_LPSC(81, &soc_psc_list[0], &soc_pd_list[4], &soc_lpsc_list[8]), + [12] = PSC_LPSC(0, &soc_psc_list[1], &soc_pd_list[5], NULL), + [13] = PSC_LPSC(3, &soc_psc_list[1], &soc_pd_list[5], NULL), + [14] = PSC_LPSC(10, &soc_psc_list[1], &soc_pd_list[5], NULL), + [15] = PSC_LPSC(11, &soc_psc_list[1], &soc_pd_list[5], NULL), + [16] = PSC_LPSC(12, &soc_psc_list[1], &soc_pd_list[5], NULL), +}; + +static struct ti_dev soc_dev_list[] = { + PSC_DEV(30, &soc_lpsc_list[0]), + PSC_DEV(61, &soc_lpsc_list[1]), + PSC_DEV(90, &soc_lpsc_list[2]), + PSC_DEV(8, &soc_lpsc_list[3]), + PSC_DEV(288, &soc_lpsc_list[4]), + PSC_DEV(92, &soc_lpsc_list[5]), + PSC_DEV(91, &soc_lpsc_list[6]), + PSC_DEV(146, &soc_lpsc_list[7]), + PSC_DEV(4, &soc_lpsc_list[8]), + PSC_DEV(4, &soc_lpsc_list[9]), + PSC_DEV(202, &soc_lpsc_list[10]), + PSC_DEV(203, &soc_lpsc_list[11]), + PSC_DEV(102, &soc_lpsc_list[12]), + PSC_DEV(103, &soc_lpsc_list[12]), + PSC_DEV(104, &soc_lpsc_list[12]), + PSC_DEV(154, &soc_lpsc_list[12]), + PSC_DEV(149, &soc_lpsc_list[12]), + PSC_DEV(113, &soc_lpsc_list[13]), + PSC_DEV(197, &soc_lpsc_list[13]), + PSC_DEV(103, &soc_lpsc_list[14]), + PSC_DEV(104, &soc_lpsc_list[15]), + PSC_DEV(102, &soc_lpsc_list[16]), +}; + +const struct ti_k3_pd_platdata j7200_pd_platdata = { + .psc = soc_psc_list, + .pd = soc_pd_list, + .lpsc = soc_lpsc_list, + .devs = soc_dev_list, + .num_psc = 2, + .num_pd = 6, + .num_lpsc = 17, + .num_devs = 22, +}; diff --git a/arch/arm/mach-k3/j721e/Makefile b/arch/arm/mach-k3/j721e/Makefile new file mode 100644 index 0000000000..ff9abd78ea --- /dev/null +++ b/arch/arm/mach-k3/j721e/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ +obj-y += clk-data.o +obj-y += dev-data.o diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/j721e/clk-data.c new file mode 100644 index 0000000000..953ac45713 --- /dev/null +++ b/arch/arm/mach-k3/j721e/clk-data.c @@ -0,0 +1,781 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * J721E specific clock platform data + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "k3-clk.h" + +static const char * const gluelogic_hfosc0_clkout_parents[] = { + "osc_19_2_mhz", + "osc_20_mhz", + "osc_24_mhz", + "osc_25_mhz", + "osc_26_mhz", + "osc_27_mhz", +}; + +static const char * const mcu_ospi0_iclk_sel_out0_parents[] = { + "board_0_mcu_ospi0_dqs_out", + "fss_mcu_0_ospi_0_ospi_oclk_clk", +}; + +static const char * const mcu_ospi1_iclk_sel_out0_parents[] = { + "board_0_mcu_ospi1_dqs_out", + "fss_mcu_0_ospi_1_ospi_oclk_clk", +}; + +static const char * const wkup_fref_clksel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", +}; + +static const char * const main_pll_hfosc_sel_out1_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents[] = { + "wkup_fref_clksel_out0", + "hsdiv1_16fft_mcu_0_hsdivout0_clk", +}; + +static const char * const mcu_ospi_ref_clk_sel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout4_clk", + "hsdiv4_16fft_mcu_2_hsdivout4_clk", +}; + +static const char * const mcu_ospi_ref_clk_sel_out1_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout4_clk", + "hsdiv4_16fft_mcu_2_hsdivout4_clk", +}; + +static const char * const mcuusart_clk_sel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "postdiv3_16fft_main_1_hsdivout5_clk", +}; + +static const char * const wkup_i2c0_mcupll_bypass_clksel_out0_parents[] = { + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "gluelogic_hfosc0_clkout", +}; + +static const char * const main_pll25_hfosc_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out12_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out13_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out14_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out15_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out16_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out17_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out18_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out19_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out2_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out23_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out3_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out4_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out5_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out6_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out7_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const main_pll_hfosc_sel_out8_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const usb0_refclk_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const usb1_refclk_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_hfosc1_clk_out", +}; + +static const char * const wkup_obsclk_mux_out0_parents[] = { + "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", + NULL, + "hsdiv1_16fft_mcu_0_hsdivout0_clk", + "hsdiv1_16fft_mcu_0_hsdivout0_clk", + "hsdiv4_16fft_mcu_1_hsdivout1_clk", + "hsdiv4_16fft_mcu_1_hsdivout2_clk", + "hsdiv4_16fft_mcu_1_hsdivout3_clk", + "hsdiv4_16fft_mcu_1_hsdivout4_clk", + "hsdiv4_16fft_mcu_2_hsdivout0_clk", + "j7_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", + "hsdiv4_16fft_mcu_2_hsdivout1_clk", + "hsdiv4_16fft_mcu_2_hsdivout2_clk", + "hsdiv4_16fft_mcu_2_hsdivout3_clk", + "hsdiv4_16fft_mcu_2_hsdivout4_clk", + "gluelogic_hfosc0_clkout", + "gluelogic_lpxosc_clkout", +}; + +static const char * const main_pll15_xref_sel_out0_parents[] = { + "main_pll_hfosc_sel_out15", + "board_0_ext_refclk1_out", +}; + +static const char * const main_pll24_hfosc_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "board_0_mlb0_mlbcp_out", +}; + +static const char * const main_pll4_xref_sel_out0_parents[] = { + "main_pll_hfosc_sel_out4", + "board_0_ext_refclk1_out", +}; + +static const char * const mcu_clkout_mux_out0_parents[] = { + "hsdiv4_16fft_mcu_2_hsdivout0_clk", + "hsdiv4_16fft_mcu_2_hsdivout0_clk", +}; + +static const char * const k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents[] = { + "main_pll_hfosc_sel_out0", + "hsdiv4_16fft_main_0_hsdivout0_clk", +}; + +static const char * const mcu_obsclk_outmux_out0_parents[] = { + "mcu_obsclk_div_out0", + "gluelogic_hfosc0_clkout", +}; + +static const char * const obsclk1_mux_out0_parents[] = { + "hsdiv0_16fft_main_7_hsdivout0_clk", + "hsdiv0_16fft_main_8_hsdivout0_clk", + "hsdiv3_16fft_main_13_hsdivout0_clk", + NULL, +}; + +static const char * const clkout_mux_out0_parents[] = { + "hsdiv4_16fft_main_3_hsdivout0_clk", + "hsdiv4_16fft_main_3_hsdivout0_clk", +}; + +static const char * const emmcsd_refclk_sel_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout2_clk", + "hsdiv4_16fft_main_1_hsdivout2_clk", + "hsdiv4_16fft_main_2_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", +}; + +static const char * const emmcsd_refclk_sel_out1_parents[] = { + "hsdiv4_16fft_main_0_hsdivout2_clk", + "hsdiv4_16fft_main_1_hsdivout2_clk", + "hsdiv4_16fft_main_2_hsdivout2_clk", + "hsdiv4_16fft_main_3_hsdivout2_clk", +}; + +static const char * const gtc_clk_mux_out0_parents[] = { + "hsdiv4_16fft_main_3_hsdivout1_clk", + "postdiv3_16fft_main_0_hsdivout6_clk", + "board_0_mcu_cpts0_rft_clk_out", + "board_0_cpts0_rft_clk_out", + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv4_16fft_mcu_2_hsdivout1_clk", + "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const gpmc_fclk_sel_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout3_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk", + "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const mcasp_ahclko_mux_out0_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv3_16fft_main_4_hsdivout2_clk", + "hsdiv3_16fft_main_15_hsdivout2_clk", + NULL, + NULL, + "board_0_audio_ext_refclk0_out", +}; + +static const char * const mcasp_ahclko_mux_out1_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv3_16fft_main_4_hsdivout2_clk", + "hsdiv3_16fft_main_15_hsdivout2_clk", + NULL, + NULL, + "board_0_audio_ext_refclk1_out", +}; + +static const char * const mcasp_ahclko_mux_out2_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv3_16fft_main_4_hsdivout2_clk", + "hsdiv3_16fft_main_15_hsdivout2_clk", + NULL, + NULL, + "board_0_audio_ext_refclk2_out", +}; + +static const char * const mcasp_ahclko_mux_out3_parents[] = { + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv3_16fft_main_4_hsdivout2_clk", + "hsdiv3_16fft_main_15_hsdivout2_clk", + NULL, + NULL, + "board_0_audio_ext_refclk3_out", +}; + +static const char * const obsclk0_mux_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout0_clk", + "hsdiv4_16fft_main_1_hsdivout0_clk", + "hsdiv4_16fft_main_2_hsdivout0_clk", + "hsdiv4_16fft_main_3_hsdivout0_clk", + "hsdiv3_16fft_main_4_hsdivout0_clk", + "hsdiv3_16fft_main_5_hsdivout0_clk", + "hsdiv0_16fft_main_6_hsdivout0_clk", + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv0_16fft_main_12_hsdivout0_clk", + "obsclk1_mux_out0", + "hsdiv1_16fft_main_14_hsdivout0_clk", + "hsdiv3_16fft_main_15_hsdivout0_clk", + "hsdiv1_16fft_main_16_hsdivout0_clk", + "hsdiv1_16fft_main_17_hsdivout0_clk", + "hsdiv1_16fft_main_18_hsdivout0_clk", + "hsdiv1_16fft_main_19_hsdivout0_clk", + NULL, + NULL, + NULL, + "hsdiv1_16fft_main_23_hsdivout0_clk", + "hsdiv0_16fft_main_24_hsdivout0_clk", + "hsdiv1_16fft_main_25_hsdivout0_clk", + NULL, + "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", + "gluelogic_lpxosc_clkout", + "hsdiv4_16fft_main_0_hsdivout0_clk", + "board_0_hfosc1_clk_out", + "gluelogic_hfosc0_clkout", +}; + +static const struct clk_data clk_list[] = { + CLK_FIXED_RATE("osc_27_mhz", 27000000, 0), + CLK_FIXED_RATE("osc_26_mhz", 26000000, 0), + CLK_FIXED_RATE("osc_25_mhz", 25000000, 0), + CLK_FIXED_RATE("osc_24_mhz", 24000000, 0), + CLK_FIXED_RATE("osc_20_mhz", 20000000, 0), + CLK_FIXED_RATE("osc_19_2_mhz", 19200000, 0), + CLK_MUX("gluelogic_hfosc0_clkout", gluelogic_hfosc0_clkout_parents, 6, 0x43000030, 0, 3, 0), + CLK_FIXED_RATE("board_0_hfosc1_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ospi0_dqs_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ospi1_dqs_out", 0, 0), + CLK_FIXED_RATE("board_0_wkup_i2c0_scl_out", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_ospi_0_ospi_oclk_clk", 0, 0), + CLK_FIXED_RATE("fss_mcu_0_ospi_1_ospi_oclk_clk", 0, 0), + CLK_FIXED_RATE("j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", 12500000, 0), + CLK_MUX("mcu_ospi0_iclk_sel_out0", mcu_ospi0_iclk_sel_out0_parents, 2, 0x40f08030, 4, 1, 0), + CLK_MUX("mcu_ospi1_iclk_sel_out0", mcu_ospi1_iclk_sel_out0_parents, 2, 0x40f08034, 4, 1, 0), + CLK_FIXED_RATE("mshsi2c_wkup_0_porscl", 0, 0), + CLK_MUX("wkup_fref_clksel_out0", wkup_fref_clksel_out0_parents, 2, 0x43008050, 8, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out1", main_pll_hfosc_sel_out1_parents, 2, 0x43008084, 0, 1, 0), + CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_main_1_foutvcop_clk", "main_pll_hfosc_sel_out1", 0x681000, 0, 1920000000), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x680038, 24, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_PLL("pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d00000, 0), + CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d01000, 0, 2400000000), + CLK_PLL_DEFFREQ("pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", "wkup_fref_clksel_out0", 0x40d02000, 0, 2000000000), + CLK_DIV("postdiv3_16fft_main_1_hsdivout5_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_mcu_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_0_foutvcop_clk", 0x40d00080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d0108c, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01090, 0, 7, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_mcu_2_hsdivout4_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02090, 0, 7, 0, 166666666), + CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", k3_pll_ctrl_wrap_wkup_0_sysclkout_clk_parents, 2, 0x42010000, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0), + CLK_MUX("mcu_ospi_ref_clk_sel_out0", mcu_ospi_ref_clk_sel_out0_parents, 2, 0x40f08030, 0, 1, 0), + CLK_MUX("mcu_ospi_ref_clk_sel_out1", mcu_ospi_ref_clk_sel_out1_parents, 2, 0x40f08034, 0, 1, 0), + CLK_MUX("mcuusart_clk_sel_out0", mcuusart_clk_sel_out0_parents, 2, 0x40f081c0, 0, 1, 0), + CLK_MUX("wkup_i2c0_mcupll_bypass_clksel_out0", wkup_i2c0_mcupll_bypass_clksel_out0_parents, 2, 0x43008060, 0, 1, 0), + CLK_FIXED_RATE("gluelogic_lpxosc_clkout", 32768, 0), + CLK_MUX("main_pll25_hfosc_sel_out0", main_pll25_hfosc_sel_out0_parents, 2, 0x430080e4, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out0", main_pll_hfosc_sel_out0_parents, 2, 0x43008080, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out12", main_pll_hfosc_sel_out12_parents, 2, 0x430080b0, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out13", main_pll_hfosc_sel_out13_parents, 2, 0x430080b4, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out14", main_pll_hfosc_sel_out14_parents, 2, 0x430080b8, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out15", main_pll_hfosc_sel_out15_parents, 2, 0x430080bc, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out16", main_pll_hfosc_sel_out16_parents, 2, 0x430080c0, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out17", main_pll_hfosc_sel_out17_parents, 2, 0x430080c4, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out18", main_pll_hfosc_sel_out18_parents, 2, 0x430080c8, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out19", main_pll_hfosc_sel_out19_parents, 2, 0x430080cc, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out2", main_pll_hfosc_sel_out2_parents, 2, 0x43008088, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out23", main_pll_hfosc_sel_out23_parents, 2, 0x430080dc, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out3", main_pll_hfosc_sel_out3_parents, 2, 0x4300808c, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out4", main_pll_hfosc_sel_out4_parents, 2, 0x43008090, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out5", main_pll_hfosc_sel_out5_parents, 2, 0x43008094, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out6", main_pll_hfosc_sel_out6_parents, 2, 0x43008098, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out7", main_pll_hfosc_sel_out7_parents, 2, 0x4300809c, 0, 1, 0), + CLK_MUX("main_pll_hfosc_sel_out8", main_pll_hfosc_sel_out8_parents, 2, 0x430080a0, 0, 1, 0), + CLK_MUX("usb0_refclk_sel_out0", usb0_refclk_sel_out0_parents, 2, 0x1080e0, 0, 1, 0), + CLK_MUX("usb1_refclk_sel_out0", usb1_refclk_sel_out0_parents, 2, 0x1080e4, 0, 1, 0), + CLK_FIXED_RATE("board_0_audio_ext_refclk0_out", 0, 0), + CLK_FIXED_RATE("board_0_audio_ext_refclk1_out", 0, 0), + CLK_FIXED_RATE("board_0_audio_ext_refclk2_out", 0, 0), + CLK_FIXED_RATE("board_0_audio_ext_refclk3_out", 0, 0), + CLK_FIXED_RATE("board_0_cpts0_rft_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_ext_refclk1_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_cpts0_rft_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ext_refclk0_out", 0, 0), + CLK_FIXED_RATE("board_0_mlb0_mlbcp_out", 0, 0), + CLK_FIXED_RATE("ddr32ss_16ffc_ew_dv_wrap_main_0_ddrss_io_ck", 0, 0), + CLK_FIXED_RATE("ddr32ss_16ffc_ew_dv_wrap_main_0_ddrss_io_ck_n", 0, 0), + CLK_FIXED_RATE("emmc8ss_16ffc_main_0_emmcss_io_clk", 0, 0), + CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 192000000), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_1_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_1_foutvcop_clk", 0x40d01088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d02088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_mcu_2_hsdivout3_clk", "pllfrac2_ssmod_16fft_mcu_2_foutvcop_clk", 0x40d0208c, 0, 7, 0), + CLK_FIXED_RATE("j7_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", 32000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_0_foutvcop_clk", "main_pll_hfosc_sel_out0", 0x680000, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 24, 3, 0), + CLK_DIV("pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 16, 3, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_13_foutvcop_clk", "main_pll_hfosc_sel_out13", 0x68d000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_14_foutvcop_clk", "main_pll_hfosc_sel_out14", 0x68e000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_16_foutvcop_clk", "main_pll_hfosc_sel_out16", 0x690000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_17_foutvcop_clk", "main_pll_hfosc_sel_out17", 0x691000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_18_foutvcop_clk", "main_pll_hfosc_sel_out18", 0x692000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_19_foutvcop_clk", "main_pll_hfosc_sel_out19", 0x693000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_2_foutvcop_clk", "main_pll_hfosc_sel_out2", 0x682000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_23_foutvcop_clk", "main_pll_hfosc_sel_out23", 0x697000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_25_foutvcop_clk", "main_pll25_hfosc_sel_out0", 0x699000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_3_foutvcop_clk", "main_pll_hfosc_sel_out3", 0x683000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_5_foutvcop_clk", "main_pll_hfosc_sel_out5", 0x685000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_6_foutvcop_clk", "main_pll_hfosc_sel_out6", 0x686000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_7_foutvcop_clk", "main_pll_hfosc_sel_out7", 0x687000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_8_foutvcop_clk", "main_pll_hfosc_sel_out8", 0x688000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "main_pll_hfosc_sel_out12", 0x68c000, 0), + CLK_DIV("postdiv3_16fft_main_0_hsdivout6_clk", "pllfrac2_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0), + CLK_DIV("postdiv3_16fft_main_1_hsdivout7_clk", "pllfrac2_ssmod_16fft_main_1_foutpostdiv_clk", 0x68109c, 0, 7, 0), + CLK_MUX("wkup_obsclk_mux_out0", wkup_obsclk_mux_out0_parents, 16, 0x43008000, 0, 4, 0), + CLK_MUX("main_pll15_xref_sel_out0", main_pll15_xref_sel_out0_parents, 2, 0x430080bc, 4, 1, 0), + CLK_MUX("main_pll24_hfosc_sel_out0", main_pll24_hfosc_sel_out0_parents, 2, 0x430080e0, 0, 1, 0), + CLK_MUX("main_pll4_xref_sel_out0", main_pll4_xref_sel_out0_parents, 2, 0x43008090, 4, 1, 0), + CLK_MUX("mcu_clkout_mux_out0", mcu_clkout_mux_out0_parents, 2, 0x40f08010, 0, 1, 0), + CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x1081c0, 0, 2, 0, 48000000), + CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_6_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_6_foutvcop_clk", 0x686080, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_7_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_7_foutvcop_clk", 0x687080, 0, 7, 0), + CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_14_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_14_foutvcop_clk", 0x68e080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_16_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_16_foutvcop_clk", 0x690080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_17_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_17_foutvcop_clk", 0x691080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_18_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_18_foutvcop_clk", 0x692080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_19_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_19_foutvcop_clk", 0x693080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_23_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_23_foutvcop_clk", 0x697080, 0, 7, 0), + CLK_DIV("hsdiv1_16fft_main_25_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_25_foutvcop_clk", 0x699080, 0, 7, 0), + CLK_DIV("hsdiv3_16fft_main_13_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_13_foutvcop_clk", 0x68d080, 0, 7, 0), + CLK_DIV("hsdiv3_16fft_main_5_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_5_foutvcop_clk", 0x685080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfrac2_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_2_foutvcop_clk", 0x682088, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683080, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout1_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683084, 0, 7, 0), + CLK_DIV("hsdiv4_16fft_main_3_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_3_foutvcop_clk", 0x683088, 0, 7, 0), + CLK_MUX_PLLCTRL("k3_pll_ctrl_wrap_main_0_sysclkout_clk", k3_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0), + CLK_DIV("mcu_obsclk_div_out0", "wkup_obsclk_mux_out0", 0x43008000, 8, 4, 0), + CLK_MUX("mcu_obsclk_outmux_out0", mcu_obsclk_outmux_out0_parents, 2, 0x43008000, 24, 1, 0), + CLK_MUX("obsclk1_mux_out0", obsclk1_mux_out0_parents, 4, 0x108004, 0, 2, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_15_foutvcop_clk", "main_pll15_xref_sel_out0", 0x68f000, 0), + CLK_PLL("pllfrac2_ssmod_16fft_main_4_foutvcop_clk", "main_pll4_xref_sel_out0", 0x684000, 0), + CLK_MUX("clkout_mux_out0", clkout_mux_out0_parents, 2, 0x108010, 0, 1, 0), + CLK_MUX("emmcsd_refclk_sel_out0", emmcsd_refclk_sel_out0_parents, 4, 0x1080b0, 0, 2, 0), + CLK_MUX("emmcsd_refclk_sel_out1", emmcsd_refclk_sel_out1_parents, 4, 0x1080b4, 0, 2, 0), + CLK_MUX("gtc_clk_mux_out0", gtc_clk_mux_out0_parents, 16, 0x108030, 0, 4, 0), + CLK_MUX("gpmc_fclk_sel_out0", gpmc_fclk_sel_out0_parents, 4, 0x1080d0, 0, 2, 0), + CLK_DIV("hsdiv0_16fft_main_24_hsdivout0_clk", "plldeskew_16fft_main_24_foutp_clk", 0x698080, 0, 0, 0), + CLK_DIV("hsdiv3_16fft_main_15_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f080, 0, 7, 0), + CLK_DIV("hsdiv3_16fft_main_15_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_15_foutvcop_clk", 0x68f088, 0, 7, 0), + CLK_DIV("hsdiv3_16fft_main_4_hsdivout0_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684080, 0, 7, 0), + CLK_DIV("hsdiv3_16fft_main_4_hsdivout2_clk", "pllfrac2_ssmod_16fft_main_4_foutvcop_clk", 0x684088, 0, 7, 0), + CLK_MUX("mcasp_ahclko_mux_out0", mcasp_ahclko_mux_out0_parents, 33, 0x1082e0, 0, 5, 0), + CLK_MUX("mcasp_ahclko_mux_out1", mcasp_ahclko_mux_out1_parents, 33, 0x1082e4, 0, 5, 0), + CLK_MUX("mcasp_ahclko_mux_out2", mcasp_ahclko_mux_out2_parents, 33, 0x1082e8, 0, 5, 0), + CLK_MUX("mcasp_ahclko_mux_out3", mcasp_ahclko_mux_out3_parents, 33, 0x1082ec, 0, 5, 0), + CLK_MUX("obsclk0_mux_out0", obsclk0_mux_out0_parents, 32, 0x108000, 0, 5, 0), + CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0), + CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0), + CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0), +}; + +static const struct dev_clk soc_dev_clk_data[] = { + DEV_CLK(4, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(4, 1, "hsdiv0_16fft_main_7_hsdivout0_clk"), + DEV_CLK(4, 2, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(30, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 1, "board_0_hfosc1_clk_out"), + DEV_CLK(30, 2, "hsdiv4_16fft_main_0_hsdivout3_clk"), + DEV_CLK(30, 4, "hsdiv4_16fft_main_0_hsdivout1_clk"), + DEV_CLK(30, 5, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 6, "gluelogic_hfosc0_clkout"), + DEV_CLK(30, 7, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(30, 8, "hsdiv4_16fft_main_0_hsdivout4_clk"), + DEV_CLK(30, 9, "gluelogic_hfosc0_clkout"), + DEV_CLK(30, 10, "board_0_hfosc1_clk_out"), + DEV_CLK(30, 11, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(30, 12, "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(47, 0, "hsdiv0_16fft_main_7_hsdivout0_clk"), + DEV_CLK(47, 1, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(47, 2, "hsdiv0_16fft_main_12_hsdivout0_clk"), + DEV_CLK(47, 3, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(61, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(61, 1, "gtc_clk_mux_out0"), + DEV_CLK(61, 2, "hsdiv4_16fft_main_3_hsdivout1_clk"), + DEV_CLK(61, 3, "postdiv3_16fft_main_0_hsdivout6_clk"), + DEV_CLK(61, 4, "board_0_mcu_cpts0_rft_clk_out"), + DEV_CLK(61, 5, "board_0_cpts0_rft_clk_out"), + DEV_CLK(61, 6, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(61, 7, "board_0_ext_refclk1_out"), + DEV_CLK(61, 16, "hsdiv4_16fft_mcu_2_hsdivout1_clk"), + DEV_CLK(61, 17, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(91, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(91, 1, "emmcsd_refclk_sel_out0"), + DEV_CLK(91, 2, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(91, 3, "hsdiv4_16fft_main_1_hsdivout2_clk"), + DEV_CLK(91, 4, "hsdiv4_16fft_main_2_hsdivout2_clk"), + DEV_CLK(91, 5, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(92, 0, "emmcsd_refclk_sel_out1"), + DEV_CLK(92, 1, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(92, 2, "hsdiv4_16fft_main_1_hsdivout2_clk"), + DEV_CLK(92, 3, "hsdiv4_16fft_main_2_hsdivout2_clk"), + DEV_CLK(92, 4, "hsdiv4_16fft_main_3_hsdivout2_clk"), + DEV_CLK(92, 5, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(92, 6, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(102, 0, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 1, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 2, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(102, 3, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(102, 4, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(103, 0, "mcu_ospi_ref_clk_sel_out0"), + DEV_CLK(103, 1, "hsdiv4_16fft_mcu_1_hsdivout4_clk"), + DEV_CLK(103, 2, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(103, 3, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(103, 4, "mcu_ospi0_iclk_sel_out0"), + DEV_CLK(103, 5, "board_0_mcu_ospi0_dqs_out"), + DEV_CLK(103, 6, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(103, 7, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(103, 8, "board_0_mcu_ospi0_dqs_out"), + DEV_CLK(104, 0, "mcu_ospi_ref_clk_sel_out1"), + DEV_CLK(104, 1, "hsdiv4_16fft_mcu_1_hsdivout4_clk"), + DEV_CLK(104, 2, "hsdiv4_16fft_mcu_2_hsdivout4_clk"), + DEV_CLK(104, 3, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(104, 4, "mcu_ospi1_iclk_sel_out0"), + DEV_CLK(104, 5, "board_0_mcu_ospi1_dqs_out"), + DEV_CLK(104, 6, "fss_mcu_0_ospi_1_ospi_oclk_clk"), + DEV_CLK(104, 7, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(104, 8, "board_0_mcu_ospi1_dqs_out"), + DEV_CLK(113, 0, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(133, 0, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(133, 1, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(138, 0, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(138, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(146, 0, "usart_programmable_clock_divider_out0"), + DEV_CLK(146, 1, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(149, 0, "mcuusart_clk_sel_out0"), + DEV_CLK(149, 1, "hsdiv4_16fft_mcu_1_hsdivout3_clk"), + DEV_CLK(149, 2, "postdiv3_16fft_main_1_hsdivout5_clk"), + DEV_CLK(149, 3, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(154, 0, "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(154, 1, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(154, 2, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 18, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(157, 19, "fss_mcu_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(157, 21, "fss_mcu_0_ospi_1_ospi_oclk_clk"), + DEV_CLK(157, 22, "fss_mcu_0_ospi_1_ospi_oclk_clk"), + DEV_CLK(157, 42, "mshsi2c_wkup_0_porscl"), + DEV_CLK(157, 50, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p"), + DEV_CLK(157, 51, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n"), + DEV_CLK(157, 91, "ddr32ss_16ffc_ew_dv_wrap_main_0_ddrss_io_ck"), + DEV_CLK(157, 92, "ddr32ss_16ffc_ew_dv_wrap_main_0_ddrss_io_ck_n"), + DEV_CLK(157, 99, "emmc8ss_16ffc_main_0_emmcss_io_clk"), + DEV_CLK(157, 100, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(157, 104, "gpmc_fclk_sel_out0"), + DEV_CLK(157, 109, "hsdiv1_16fft_main_19_hsdivout0_clk"), + DEV_CLK(157, 111, "hsdiv1_16fft_main_23_hsdivout0_clk"), + DEV_CLK(157, 113, "osbclk0_div_out0"), + DEV_CLK(157, 114, "hsdiv4_16fft_main_0_hsdivout0_clk"), + DEV_CLK(157, 115, "hsdiv4_16fft_main_1_hsdivout0_clk"), + DEV_CLK(157, 116, "hsdiv4_16fft_main_2_hsdivout0_clk"), + DEV_CLK(157, 117, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 118, "hsdiv3_16fft_main_4_hsdivout0_clk"), + DEV_CLK(157, 119, "hsdiv3_16fft_main_5_hsdivout0_clk"), + DEV_CLK(157, 120, "hsdiv0_16fft_main_6_hsdivout0_clk"), + DEV_CLK(157, 126, "hsdiv0_16fft_main_12_hsdivout0_clk"), + DEV_CLK(157, 127, "obsclk1_mux_out0"), + DEV_CLK(157, 128, "hsdiv1_16fft_main_14_hsdivout0_clk"), + DEV_CLK(157, 129, "hsdiv3_16fft_main_15_hsdivout0_clk"), + DEV_CLK(157, 130, "hsdiv1_16fft_main_16_hsdivout0_clk"), + DEV_CLK(157, 131, "hsdiv1_16fft_main_17_hsdivout0_clk"), + DEV_CLK(157, 132, "hsdiv1_16fft_main_18_hsdivout0_clk"), + DEV_CLK(157, 133, "hsdiv1_16fft_main_19_hsdivout0_clk"), + DEV_CLK(157, 137, "hsdiv1_16fft_main_23_hsdivout0_clk"), + DEV_CLK(157, 138, "hsdiv0_16fft_main_24_hsdivout0_clk"), + DEV_CLK(157, 139, "hsdiv1_16fft_main_25_hsdivout0_clk"), + DEV_CLK(157, 141, "j7_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk"), + DEV_CLK(157, 142, "gluelogic_lpxosc_clkout"), + DEV_CLK(157, 143, "hsdiv4_16fft_main_0_hsdivout0_clk"), + DEV_CLK(157, 144, "board_0_hfosc1_clk_out"), + DEV_CLK(157, 145, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 146, "obsclk1_mux_out0"), + DEV_CLK(157, 147, "hsdiv0_16fft_main_7_hsdivout0_clk"), + DEV_CLK(157, 148, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(157, 149, "hsdiv3_16fft_main_13_hsdivout0_clk"), + DEV_CLK(157, 152, "mcu_obsclk_outmux_out0"), + DEV_CLK(157, 153, "mcu_obsclk_div_out0"), + DEV_CLK(157, 154, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 169, "k3_pll_ctrl_wrap_main_0_sysclkout_clk"), + DEV_CLK(157, 170, "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk"), + DEV_CLK(157, 172, "clkout_mux_out0"), + DEV_CLK(157, 173, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 174, "hsdiv4_16fft_main_3_hsdivout0_clk"), + DEV_CLK(157, 175, "mcu_clkout_mux_out0"), + DEV_CLK(157, 176, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(157, 177, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(157, 301, "mcasp_ahclko_mux_out0"), + DEV_CLK(157, 330, "hsdiv3_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 331, "hsdiv3_16fft_main_15_hsdivout2_clk"), + DEV_CLK(157, 334, "board_0_audio_ext_refclk0_out"), + DEV_CLK(157, 336, "mcasp_ahclko_mux_out1"), + DEV_CLK(157, 365, "hsdiv3_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 366, "hsdiv3_16fft_main_15_hsdivout2_clk"), + DEV_CLK(157, 369, "board_0_audio_ext_refclk1_out"), + DEV_CLK(157, 371, "mcasp_ahclko_mux_out2"), + DEV_CLK(157, 400, "hsdiv3_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 401, "hsdiv3_16fft_main_15_hsdivout2_clk"), + DEV_CLK(157, 404, "board_0_audio_ext_refclk2_out"), + DEV_CLK(157, 406, "mcasp_ahclko_mux_out3"), + DEV_CLK(157, 435, "hsdiv3_16fft_main_4_hsdivout2_clk"), + DEV_CLK(157, 436, "hsdiv3_16fft_main_15_hsdivout2_clk"), + DEV_CLK(157, 439, "board_0_audio_ext_refclk3_out"), + DEV_CLK(197, 0, "wkup_i2c0_mcupll_bypass_clksel_out0"), + DEV_CLK(197, 1, "hsdiv4_16fft_mcu_1_hsdivout3_clk"), + DEV_CLK(197, 2, "gluelogic_hfosc0_clkout"), + DEV_CLK(197, 3, "board_0_wkup_i2c0_scl_out"), + DEV_CLK(197, 4, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(202, 2, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(203, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(288, 3, "postdiv3_16fft_main_1_hsdivout7_clk"), + DEV_CLK(288, 4, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 5, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 15, "usb0_refclk_sel_out0"), + DEV_CLK(288, 16, "gluelogic_hfosc0_clkout"), + DEV_CLK(288, 17, "board_0_hfosc1_clk_out"), + DEV_CLK(288, 18, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(288, 19, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(289, 3, "postdiv3_16fft_main_1_hsdivout7_clk"), + DEV_CLK(289, 4, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(289, 5, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(289, 15, "usb1_refclk_sel_out0"), + DEV_CLK(289, 16, "gluelogic_hfosc0_clkout"), + DEV_CLK(289, 17, "board_0_hfosc1_clk_out"), + DEV_CLK(289, 18, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(289, 19, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), +}; + +const struct ti_k3_clk_platdata j721e_clk_platdata = { + .clk_list = clk_list, + .clk_list_cnt = 156, + .soc_dev_clk_data = soc_dev_clk_data, + .soc_dev_clk_data_cnt = 171, +}; diff --git a/arch/arm/mach-k3/j721e/dev-data.c b/arch/arm/mach-k3/j721e/dev-data.c new file mode 100644 index 0000000000..96393c7132 --- /dev/null +++ b/arch/arm/mach-k3/j721e/dev-data.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * J721E specific device platform data + * + * Copyright (C) 2020-2021 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "k3-dev.h" + +static struct ti_psc soc_psc_list[] = { + [0] = PSC(0, 0x00400000), + [1] = PSC(1, 0x42000000), +}; + +static struct ti_pd soc_pd_list[] = { + [0] = PSC_PD(0, &soc_psc_list[0], NULL), + [1] = PSC_PD(14, &soc_psc_list[0], NULL), + [2] = PSC_PD(15, &soc_psc_list[0], &soc_pd_list[1]), + [3] = PSC_PD(16, &soc_psc_list[0], &soc_pd_list[1]), + [4] = PSC_PD(0, &soc_psc_list[1], NULL), +}; + +static struct ti_lpsc soc_lpsc_list[] = { + [0] = PSC_LPSC(0, &soc_psc_list[0], &soc_pd_list[0], NULL), + [1] = PSC_LPSC(7, &soc_psc_list[0], &soc_pd_list[0], NULL), + [2] = PSC_LPSC(14, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[3]), + [3] = PSC_LPSC(15, &soc_psc_list[0], &soc_pd_list[0], NULL), + [4] = PSC_LPSC(20, &soc_psc_list[0], &soc_pd_list[0], NULL), + [5] = PSC_LPSC(21, &soc_psc_list[0], &soc_pd_list[0], NULL), + [6] = PSC_LPSC(23, &soc_psc_list[0], &soc_pd_list[0], NULL), + [7] = PSC_LPSC(25, &soc_psc_list[0], &soc_pd_list[0], NULL), + [8] = PSC_LPSC(78, &soc_psc_list[0], &soc_pd_list[1], NULL), + [9] = PSC_LPSC(80, &soc_psc_list[0], &soc_pd_list[2], &soc_lpsc_list[8]), + [10] = PSC_LPSC(81, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[8]), + [11] = PSC_LPSC(0, &soc_psc_list[1], &soc_pd_list[4], NULL), + [12] = PSC_LPSC(3, &soc_psc_list[1], &soc_pd_list[4], NULL), + [13] = PSC_LPSC(10, &soc_psc_list[1], &soc_pd_list[4], NULL), + [14] = PSC_LPSC(11, &soc_psc_list[1], &soc_pd_list[4], NULL), + [15] = PSC_LPSC(12, &soc_psc_list[1], &soc_pd_list[4], NULL), +}; + +static struct ti_dev soc_dev_list[] = { + PSC_DEV(30, &soc_lpsc_list[0]), + PSC_DEV(61, &soc_lpsc_list[0]), + PSC_DEV(146, &soc_lpsc_list[1]), + PSC_DEV(90, &soc_lpsc_list[2]), + PSC_DEV(47, &soc_lpsc_list[3]), + PSC_DEV(288, &soc_lpsc_list[4]), + PSC_DEV(289, &soc_lpsc_list[5]), + PSC_DEV(92, &soc_lpsc_list[6]), + PSC_DEV(91, &soc_lpsc_list[7]), + PSC_DEV(4, &soc_lpsc_list[8]), + PSC_DEV(202, &soc_lpsc_list[9]), + PSC_DEV(203, &soc_lpsc_list[10]), + PSC_DEV(102, &soc_lpsc_list[11]), + PSC_DEV(103, &soc_lpsc_list[11]), + PSC_DEV(104, &soc_lpsc_list[11]), + PSC_DEV(154, &soc_lpsc_list[11]), + PSC_DEV(149, &soc_lpsc_list[11]), + PSC_DEV(113, &soc_lpsc_list[12]), + PSC_DEV(197, &soc_lpsc_list[12]), + PSC_DEV(103, &soc_lpsc_list[13]), + PSC_DEV(104, &soc_lpsc_list[14]), + PSC_DEV(102, &soc_lpsc_list[15]), +}; + +const struct ti_k3_pd_platdata j721e_pd_platdata = { + .psc = soc_psc_list, + .pd = soc_pd_list, + .lpsc = soc_lpsc_list, + .devs = soc_dev_list, + .num_psc = 2, + .num_pd = 5, + .num_lpsc = 16, + .num_devs = 22, +};
Add callback routines for parsing the firmware info from FIT image, and use the data to boot up ATF and the MCU R5 firmware.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/common.c | 80 +++++++++++++++++++++++++++++++++---- arch/arm/mach-k3/common.h | 1 + arch/arm/mach-k3/security.c | 3 +- 3 files changed, 75 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 9191f686f0..a5d6a10dc7 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -28,6 +28,27 @@ #include <elf.h> #include <soc.h>
+#ifdef CONFIG_SYS_K3_SPL_ATF +enum { + IMAGE_ID_ATF, + IMAGE_ID_OPTEE, + IMAGE_ID_SPL, + IMAGE_ID_DM_FW, + IMAGE_AMT, +}; + +#ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS +static const char *image_os_match[IMAGE_AMT] = { + "arm-trusted-firmware", + "tee", + "U-Boot", + "DM", +}; +#endif + +static struct image_info fit_image_info[IMAGE_AMT]; +#endif + struct ti_sci_handle *get_ti_sci_handle(void) { struct udevice *dev; @@ -181,7 +202,7 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) typedef void __noreturn (*image_entry_noargs_t)(void); struct ti_sci_handle *ti_sci = get_ti_sci_handle(); u32 loadaddr = 0; - int ret, size; + int ret, size = 0;
/* Release all the exclusive devices held by SPL before starting ATF */ ti_sci->ops.dev_ops.release_exclusive_devices(ti_sci); @@ -192,15 +213,20 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image)
init_env(); start_non_linux_remote_cores(); - size = load_firmware("name_mcur5f0_0fw", "addr_mcur5f0_0load", - &loadaddr); + if (!fit_image_info[IMAGE_ID_DM_FW].image_start) + size = load_firmware("name_mcur5f0_0fw", "addr_mcur5f0_0load", + &loadaddr);
/* * It is assumed that remoteproc device 1 is the corresponding * Cortex-A core which runs ATF. Make sure DT reflects the same. */ - ret = rproc_load(1, spl_image->entry_point, 0x200); + if (!fit_image_info[IMAGE_ID_ATF].image_start) + fit_image_info[IMAGE_ID_ATF].image_start = + spl_image->entry_point; + + ret = rproc_load(1, fit_image_info[IMAGE_ID_ATF].image_start, 0x200); if (ret) panic("%s: ATF failed to load on rproc (%d)\n", __func__, ret);
@@ -210,7 +236,8 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) ret = rproc_start(1); if (ret) panic("%s: ATF failed to start on rproc (%d)\n", __func__, ret); - if (!(size > 0 && valid_elf_image(loadaddr))) { + if (!fit_image_info[IMAGE_ID_DM_FW].image_len && + !(size > 0 && valid_elf_image(loadaddr))) { debug("Shutting down...\n"); release_resources_for_core_shutdown();
@@ -218,13 +245,52 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) asm volatile("wfe"); }
- image_entry_noargs_t image_entry = - (image_entry_noargs_t)load_elf_image_phdr(loadaddr); + if (!fit_image_info[IMAGE_ID_DM_FW].image_start) { + loadaddr = load_elf_image_phdr(loadaddr); + } else { + loadaddr = fit_image_info[IMAGE_ID_DM_FW].image_start; + if (valid_elf_image(loadaddr)) + loadaddr = load_elf_image_phdr(loadaddr); + } + + debug("%s: jumping to address %x\n", __func__, loadaddr); + + image_entry_noargs_t image_entry = (image_entry_noargs_t)loadaddr;
image_entry(); } #endif
+#ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS +void board_fit_image_post_process(const void *fit, int node, void **p_image, + size_t *p_size) +{ + int len; + int i; + const char *os; + u32 addr; + + os = fdt_getprop(fit, node, "os", &len); + addr = fdt_getprop_u32_default_node(fit, node, 0, "entry", -1); + + debug("%s: processing image: addr=%x, size=%d, os=%s\n", __func__, + addr, *p_size, os); + + for (i = 0; i < IMAGE_AMT; i++) { + if (!strcmp(os, image_os_match[i])) { + fit_image_info[i].image_start = addr; + fit_image_info[i].image_len = *p_size; + debug("%s: matched image for ID %d\n", __func__, i); + break; + } + } + +#ifdef CONFIG_TI_SECURE_DEVICE + ti_secure_image_post_process(p_image, p_size); +#endif +} +#endif + #if defined(CONFIG_OF_LIBFDT) int fdt_fixup_msmc_ram(void *blob, char *parent_path, char *node_name) { diff --git a/arch/arm/mach-k3/common.h b/arch/arm/mach-k3/common.h index a6dbc7808b..f421ed1bb1 100644 --- a/arch/arm/mach-k3/common.h +++ b/arch/arm/mach-k3/common.h @@ -28,3 +28,4 @@ void k3_sysfw_print_ver(void); void spl_enable_dcache(void); void mmr_unlock(phys_addr_t base, u32 partition); bool is_rom_loaded_sysfw(struct rom_extended_boot_data *data); +void ti_secure_image_post_process(void **p_image, size_t *p_size); diff --git a/arch/arm/mach-k3/security.c b/arch/arm/mach-k3/security.c index 5b5ff9ba7b..8de9739a40 100644 --- a/arch/arm/mach-k3/security.c +++ b/arch/arm/mach-k3/security.c @@ -18,8 +18,7 @@ #include <spl.h> #include <asm/arch/sys_proto.h>
-void board_fit_image_post_process(const void *fit, int node, void **p_image, - size_t *p_size) +void ti_secure_image_post_process(void **p_image, size_t *p_size) { struct ti_sci_handle *ti_sci = get_ti_sci_handle(); struct ti_sci_proc_ops *proc_ops = &ti_sci->ops.proc_ops;
If the raw PM support is built in, we are operating in the split firmware approach mode where PM support is not available. In this case, skip the board config for this.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/sysfw-loader.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c index 0bacfc4d07..c6af205163 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -159,11 +159,13 @@ static void k3_sysfw_configure_using_fit(void *fit, ret);
/* Apply power/clock (PM) specific configuration to SYSFW */ +#ifndef CONFIG_K3_DM_FW ret = board_ops->board_config_pm(ti_sci, (u64)(u32)cfg_fragment_addr, (u32)cfg_fragment_size); if (ret) panic("Failed to set board PM configuration (%d)\n", ret); +#endif
/* Extract resource management (RM) specific configuration from FIT */ ret = fit_get_data_by_name(fit, images, SYSFW_CFG_RM,
Only start-up the non-linux remote cores if we are running in legacy boot mode. HSM rearch is not yet supporting this.
Signed-off-by: Dave Gerlach d-gerlach@ti.com Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/common.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index a5d6a10dc7..2b8c09a650 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -212,11 +212,12 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) panic("rproc failed to be initialized (%d)\n", ret);
init_env(); - start_non_linux_remote_cores(); - if (!fit_image_info[IMAGE_ID_DM_FW].image_start) + + if (!fit_image_info[IMAGE_ID_DM_FW].image_start) { + start_non_linux_remote_cores(); size = load_firmware("name_mcur5f0_0fw", "addr_mcur5f0_0load", &loadaddr); - + }
Copy the contents of the board config loaded from sysfw.itb into an EXTBOOT shared memory buffer that gets passed to sciserver. This only needs to be done if EXTBOOT area has not been populated by ROM code yet.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/sysfw-loader.c | 103 ++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c index c6af205163..ac719cd46f 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -40,6 +40,46 @@ DECLARE_GLOBAL_DATA_PTR; */ #define K3_SYSTEM_CONTROLLER_RPROC_ID 0
+#define COMMON_HEADER_ADDRESS 0x41cffb00 +#define BOARDCFG_ADDRESS 0x41c80000 + +#define COMP_TYPE_SBL_DATA 0x11 +#define DESC_TYPE_BOARDCFG_PM_INDEX 0x2 +#define DESC_TYPE_BOARDCFG_RM_INDEX 0x3 + +#define BOARD_CONFIG_RM_DESC_TYPE 0x000c +#define BOARD_CONFIG_PM_DESC_TYPE 0x000e + +struct extboot_comp { + u32 comp_type; + u32 boot_core; + u32 comp_opts; + u64 dest_addr; + u32 comp_size; +}; + +struct extboot_header { + u8 magic[8]; + u32 num_comps; + struct extboot_comp comps[5]; + u32 reserved; +}; + +struct bcfg_desc { + u16 type; + u16 offset; + u16 size; + u8 devgrp; + u8 reserved; +} __packed; + +struct bcfg_header { + u8 num_elems; + u8 sw_rev; + struct bcfg_desc descs[4]; + u16 reserved; +} __packed; + static bool sysfw_loaded; static void *sysfw_load_address;
@@ -131,6 +171,15 @@ static void k3_sysfw_configure_using_fit(void *fit, const void *cfg_fragment_addr; size_t cfg_fragment_size; int ret; +#ifdef CONFIG_K3_DM_FW + u8 *buf; + struct extboot_header *common_header; + struct bcfg_header *bcfg_header; + struct extboot_comp *comp; + struct bcfg_desc *desc; + u32 addr; + bool copy_bcfg = false; +#endif
/* Find the node holding the images information */ images = fdt_path_offset(fit, FIT_IMAGES_PATH); @@ -165,6 +214,46 @@ static void k3_sysfw_configure_using_fit(void *fit, (u32)cfg_fragment_size); if (ret) panic("Failed to set board PM configuration (%d)\n", ret); +#else + /* Initialize shared memory boardconfig buffer */ + buf = (u8 *)COMMON_HEADER_ADDRESS; + common_header = (struct extboot_header *)buf; + + /* Check if we have a struct populated by ROM in memory already */ + if (strcmp((char *)common_header->magic, "EXTBOOT")) + copy_bcfg = true; + + if (copy_bcfg) { + strcpy((char *)common_header->magic, "EXTBOOT"); + common_header->num_comps = 1; + + comp = &common_header->comps[0]; + + comp->comp_type = COMP_TYPE_SBL_DATA; + comp->boot_core = 0x10; + comp->comp_opts = 0; + addr = (u32)BOARDCFG_ADDRESS; + comp->dest_addr = addr; + comp->comp_size = sizeof(*bcfg_header); + + bcfg_header = (struct bcfg_header *)addr; + + bcfg_header->num_elems = 2; + bcfg_header->sw_rev = 0; + + desc = &bcfg_header->descs[0]; + + desc->type = BOARD_CONFIG_PM_DESC_TYPE; + desc->offset = sizeof(*bcfg_header); + desc->size = cfg_fragment_size; + comp->comp_size += desc->size; + desc->devgrp = 0; + desc->reserved = 0; + memcpy((u8 *)bcfg_header + desc->offset, cfg_fragment_addr, + cfg_fragment_size); + + bcfg_header->descs[1].offset = desc->offset + desc->size; + } #endif
/* Extract resource management (RM) specific configuration from FIT */ @@ -174,6 +263,20 @@ static void k3_sysfw_configure_using_fit(void *fit, panic("Error accessing %s node in FIT (%d)\n", SYSFW_CFG_RM, ret);
+#ifdef CONFIG_K3_DM_FW + if (copy_bcfg) { + desc = &bcfg_header->descs[1]; + + desc->type = BOARD_CONFIG_RM_DESC_TYPE; + desc->size = cfg_fragment_size; + comp->comp_size += desc->size; + desc->devgrp = 0; + desc->reserved = 0; + memcpy((u8 *)bcfg_header + desc->offset, cfg_fragment_addr, + cfg_fragment_size); + } +#endif + /* Apply resource management (RM) configuration to SYSFW */ ret = board_ops->board_config_rm(ti_sci, (u64)(u32)cfg_fragment_addr,
Force the clk-k3 driver to probe early during R5 SPL boot to ensure the default system clock configuration is completed. Many other drivers assume a default state of the clock tree and it is currently possible for them to probe before clk-k3 depending on the exact system configuration.
Signed-off-by: Dave Gerlach d-gerlach@ti.com Reported-by: Keerthy j-keerthy@ti.com Tested-by: Keerthy j-keerthy@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/mach-k3/j721e_init.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 76a04a9035..833568d4b8 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -180,6 +180,18 @@ void board_init_f(ulong dummy) k3_sysfw_loader(is_rom_loaded_sysfw(&bootdata), k3_mmc_stop_clock, k3_mmc_restart_clock);
+#ifdef CONFIG_SPL_CLK_K3 + /* + * Force probe of clk_k3 driver here to ensure basic default clock + * configuration is always done. + */ + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(ti_clk), + &dev); + if (ret) + panic("Failed to initialize clk-k3!\n"); +#endif + /* Prepare console output */ preloader_console_init();
Sysfw is not going to provide access to power management features in the new architecture, so SPL must implement these itself. Enable all the raw register access based clock + power domain drivers.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- configs/j721e_evm_r5_defconfig | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 8ebbe7348f..8a9b20141b 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -72,7 +72,7 @@ CONFIG_SPL_REGMAP=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_CLK_TI_SCI=y +# CONFIG_CLK_TI_SCI is not set CONFIG_DMA_CHANNELS=y CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y @@ -102,7 +102,7 @@ CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_GENERIC is not set CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y +# CONFIG_TI_SCI_POWER_DOMAIN is not set CONFIG_DM_PMIC=y CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y @@ -140,3 +140,11 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x6163 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_TI_POWER_DOMAIN=y +CONFIG_SPL_CLK_CCF=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_K3_DM_FW=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y
Signed-off-by: Dave Gerlach d-gerlach@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- configs/j7200_evm_r5_defconfig | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 08fad3e04b..5c51bd5ae7 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -75,7 +75,7 @@ CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_CLK_TI_SCI=y +# CONFIG_CLK_TI_SCI is not set CONFIG_DMA_CHANNELS=y CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y @@ -110,7 +110,7 @@ CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_GENERIC is not set CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y +# CONFIG_TI_SCI_POWER_DOMAIN is not set CONFIG_K3_SYSTEM_CONTROLLER=y CONFIG_REMOTEPROC_TI_K3_ARM64=y CONFIG_DM_RESET=y @@ -142,3 +142,13 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_SPL_CLK_CCF=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_K3_DM_FW=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y
Update build instructions and image formats based on HSM rearch. A new DM image is added into the build, which gets executed right after R5 SPL finishes its job.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Tero Kristo kristo@kernel.org --- board/ti/j721e/README | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/board/ti/j721e/README b/board/ti/j721e/README index c33afa496e..b1c9145c92 100644 --- a/board/ti/j721e/README +++ b/board/ti/j721e/README @@ -73,12 +73,12 @@ support. Below is the pictorial representation of boot flow: | | | | +-------------+ | | | | | |<--------|---| Start A72 | | | | | | | | | and jump to | | | | -| | | | | next image | | | | +| | | | | DM fw image | | | | | | | | +-------------+ | | | | | | | | +-----------+ | | | | |---------|-----------------------|---->| Reset rls | | | | | | | | +-----------+ | | -| | DMSC | | | : | | +| | TIFS | | | : | | | |Services | | | +-----------+ | | | | |<--------|-----------------------|---->|*ATF/OPTEE*| | | | | | | | +-----------+ | | @@ -154,7 +154,7 @@ $ make CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5
4.2. A72: $ make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=/tmp/a72 -$ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a72 +$ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<path to DM firmware image> O=/tmp/a72
Target Images -------------- @@ -197,6 +197,9 @@ Image formats: | | A72 OPTEE | | | +-------------------+ | | | | | + | | R5 DM FW | | + | +-------------------+ | + | | | | | | A72 SPL | | | +-------------------+ | | | | |
MCU timer1 is used as the tick timer for MCU R5 SPL, and the clock-frequency defined in DT appears to be incorrect at the moment. Actual clock source for the timer is MCU_SYSCLK0 / 4 which is 250MHz.
Earlier setup of 25MHz went unnoticed, as there was a separate issue with omap-timer, which caused an error to the clock by a factor of 8 with j7 devices. This problem surfaced once the omap-timer was fixed.
Signed-off-by: Tero Kristo kristo@kernel.org --- arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 2 +- arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index bd037be350..c3aae65b39 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -33,7 +33,7 @@ compatible = "ti,omap5430-timer"; reg = <0x0 0x40400000 0x0 0x80>; ti,timer-alwon; - clock-frequency = <25000000>; + clock-frequency = <250000000>; u-boot,dm-spl; };
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index fe095a6153..951331831e 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -46,7 +46,7 @@ compatible = "ti,omap5430-timer"; reg = <0x0 0x40400000 0x0 0x80>; ti,timer-alwon; - clock-frequency = <25000000>; + clock-frequency = <250000000>; u-boot,dm-spl; };
On 03/06/21 12:02 pm, Tero Kristo wrote:
As requested, this is just a rebase to the latest u-boot tip.
Boot tested on j721e to make sure nothing got broken.
There are some build errors. Can you take a look? https://source.denx.de/u-boot/custodians/u-boot-ti/-/jobs/275511
Thanks and regards, Lokesh
-Tero
Hmm yeah, HS boards fail building. Attached fix, do you want me to re-post or do you want to squash this in?
-Tero
Can you point me to the patch no to squash this patch?
-Tero
Goes on top of patch #18. Rest apply cleanly.
-Tero
Lokesh Vutla
Tero Kristo
