[U-Boot-Users] [PATCH] sh: Add support SH7710/SH7712
SH7710/SH7712 of SH3 CPU are supported. SH771X is called SH-Ether, and has the Ether controller in CPU. The driver of Ether is not included in this patch.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/serial/serial_sh.c | 31 ++++++++++----------- include/asm-sh/cpu_sh3.h | 4 ++- include/asm-sh/cpu_sh7710.h | 64 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 82 insertions(+), 17 deletions(-) create mode 100644 include/asm-sh/cpu_sh7710.h
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index afba2d2..00a9b39 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -30,25 +30,20 @@ #error "Default SCIF doesn't set....." #endif
-#if defined(CONFIG_SH3) -/* There are SH7720's register */ -#define SCSMR (volatile unsigned short *)(SCIF_BASE + 0x0) -#define SCBRR (volatile unsigned char *)(SCIF_BASE + 0x4) -#define SCSCR (volatile unsigned short *)(SCIF_BASE + 0x8) -#define SCFSR (volatile unsigned short *)(SCIF_BASE + 0x14) /* SCSSR */ -#define SCFCR (volatile unsigned short *)(SCIF_BASE + 0x18) -#define SCFDR (volatile unsigned short *)(SCIF_BASE + 0x1C) -#define SCFTDR (volatile unsigned char *)(SCIF_BASE + 0x20) -#define SCFRDR (volatile unsigned char *)(SCIF_BASE + 0x24) +/* Base register */ +#define SCSMR (vu_short *)(SCIF_BASE + 0x0) +#define SCBRR (vu_char *)(SCIF_BASE + 0x4) +#define SCSCR (vu_short *)(SCIF_BASE + 0x8) +#define SCFCR (vu_short *)(SCIF_BASE + 0x18) +#define SCFDR (vu_short *)(SCIF_BASE + 0x1C) +#ifdef CONFIG_SH7720 /* SH7720 specific */ +#define SCFSR (vu_short *)(SCIF_BASE + 0x14) /* SCSSR */ +#define SCFTDR (vu_char *)(SCIF_BASE + 0x20) +#define SCFRDR (vu_char *)(SCIF_BASE + 0x24) #else -#define SCSMR (vu_short *)(SCIF_BASE + 0x0) -#define SCBRR (vu_char *)(SCIF_BASE + 0x4) -#define SCSCR (vu_short *)(SCIF_BASE + 0x8) #define SCFTDR (vu_char *)(SCIF_BASE + 0xC) #define SCFSR (vu_short *)(SCIF_BASE + 0x10) #define SCFRDR (vu_char *)(SCIF_BASE + 0x14) -#define SCFCR (vu_short *)(SCIF_BASE + 0x18) -#define SCFDR (vu_short *)(SCIF_BASE + 0x1C) #endif
#if defined(CONFIG_SH4A) @@ -62,7 +57,11 @@ #define SCLSR (vu_short *)(SCIF_BASE + 0x24) #define LSR_ORER 1 #elif defined (CONFIG_SH3) -#define SCLSR SCFSR /* SCSSR */ +#ifdef CONFIG_SH7720 /* SH7720 specific */ +# define SCLSR SCFSR /* SCSSR */ +#else +# define SCLSR (vu_short *)(SCIF_BASE + 0x24) +#endif #define LSR_ORER 0x0200 #endif
diff --git a/include/asm-sh/cpu_sh3.h b/include/asm-sh/cpu_sh3.h index 68679c0..6db38a2 100644 --- a/include/asm-sh/cpu_sh3.h +++ b/include/asm-sh/cpu_sh3.h @@ -31,7 +31,9 @@ #define CACHE_OC_NUM_ENTRIES 256 #define CACHE_OC_ENTRY_SHIFT 4
-#if defined(CONFIG_CPU_SH7720) +#if defined(CONFIG_CPU_SH7710) +#include <asm/cpu_sh7710.h> +#elif defined(CONFIG_CPU_SH7720) #include <asm/cpu_sh7720.h> #else #error "Unknown SH3 variant" diff --git a/include/asm-sh/cpu_sh7710.h b/include/asm-sh/cpu_sh7710.h new file mode 100644 index 0000000..e223f1c --- /dev/null +++ b/include/asm-sh/cpu_sh7710.h @@ -0,0 +1,64 @@ +#ifndef _ASM_CPU_SH7710_H_ +#define _ASM_CPU_SH7710_H_ + +#define CACHE_OC_NUM_WAYS 4 +#define CCR_CACHE_INIT 0x0000000D + +/* MMU and Cache control */ +#define MMUCR 0xFFFFFFE0 +#define CCR 0xFFFFFFEC + +/* PFC */ +#define PACR 0xA4050100 +#define PBCR 0xA4050102 +#define PCCR 0xA4050104 +#define PETCR 0xA4050106 + +/* Port Data Registers */ +#define PADR 0xA4050120 +#define PBDR 0xA4050122 +#define PCDR 0xA4050124 + +/* BSC */ +#define CMNCR 0xA4FD0000 +#define CS0BCR 0xA4FD0004 +#define CS2BCR 0xA4FD0008 +#define CS3BCR 0xA4FD000C +#define CS4BCR 0xA4FD0010 +#define CS5ABCR 0xA4FD0014 +#define CS5BBCR 0xA4FD0018 +#define CS6ABCR 0xA4FD001C +#define CS6BBCR 0xA4FD0020 +#define CS0WCR 0xA4FD0024 +#define CS2WCR 0xA4FD0028 +#define CS3WCR 0xA4FD002C +#define CS4WCR 0xA4FD0030 +#define CS5AWCR 0xA4FD0034 +#define CS5BWCR 0xA4FD0038 +#define CS6AWCR 0xA4FD003C +#define CS6BWCR 0xA4FD0040 + +/* SDRAM controller */ +#define SDCR 0xA4FD0044 +#define RTCSR 0xA4FD0048 +#define RTCNT 0xA4FD004C +#define RTCOR 0xA4FD0050 + +/* SCIF */ +#define SCSMR_0 0xA4400000 +#define SCIF0_BASE SCSMR_0 +#define SCSMR_0 0xA4410000 +#define SCIF1_BASE SCSMR_1 + +/* Timer */ +#define TSTR0 0xA412FE92 +#define TSTR TSTR0 +#define TCNT0 0xa412FE98 +#define TCR0 0xa412FE9C + +/* On chip oscillator circuits */ +#define FRQCR 0xA415FF80 +#define WTCNT 0xA415FF84 +#define WTCSR 0xA415FF86 + +#endif /* _ASM_CPU_SH7710_H_ */
Nobuhiro Iwamatsu
