[PATCH] mmc: xenon_sdhci: Add missing common host capabilities
Use mmc_of_parse() to set the common host properties. That includes "bus-width", so parsing it can be removed from the driver.
But more importantly, "non-removable" is now respected, which fixes the usage of eMMC.
Signed-off-by: Andre Heider a.heider@gmail.com ---
Tested myself on v5 without emmc, `mmc info` is unchanged for my sd card
Tested by Gérald on v7 emmc, which started working with this patch: => mmc info Device: sdhci@d8000 Manufacturer ID: 45 OEM: 100 Name: SEM04 Bus Speed: 52000000 Mode: MMC High Speed (52MHz) Rd Block Len: 512 MMC version 4.5 High Capacity: Yes Capacity: 3.7 GiB Bus Width: 8-bit Erase Group Size: 256 KiB HC WP Group Size: 8 MiB User Capacity: 3.7 GiB WRREL Boot Capacity: 2 MiB RPMB Capacity: 2 MiB Boot area 0 is not write protected Boot area 1 is not write protected
drivers/mmc/xenon_sdhci.c | 18 ++++-------------- 1 file changed, 4 insertions(+), 14 deletions(-)
diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 7f9a579c83..6ce9d00d0a 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -485,20 +485,10 @@ static int xenon_sdhci_probe(struct udevice *dev) armada_3700_soc_pad_voltage_set(host);
host->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_DDR_52MHz; - switch (fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "bus-width", - 1)) { - case 8: - host->host_caps |= MMC_MODE_8BIT; - break; - case 4: - host->host_caps |= MMC_MODE_4BIT; - break; - case 1: - break; - default: - printf("Invalid "bus-width" value\n"); - return -EINVAL; - } + + ret = mmc_of_parse(dev, &plat->cfg); + if (ret) + return ret;
host->ops = &xenon_sdhci_ops;
-----Original Message----- From: Andre Heider a.heider@gmail.com Sent: Thursday, September 10, 2020 20:54 To: Stefan Roese sr@denx.de; Kostya Porotchkin kostap@marvell.com Cc: Pali Rohár pali@kernel.org; Gérald Kerma gandalf@gk2.net; u- boot@lists.denx.de Subject: [EXT] [PATCH] mmc: xenon_sdhci: Add missing common host capabilities
External Email
Use mmc_of_parse() to set the common host properties. That includes "bus- width", so parsing it can be removed from the driver.
Reviewed-by: Konstantin Porotchkin kostap@marvell.com
width",
1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
printf("Invalid \"bus-width\" value\n");
return -EINVAL;
if (ret)
return ret;
-- 2.28.0
Adding Marek to loop, can you test this patch on MOX A to verify that it does not break MOX uSD and SDIO support?
(PS: Andre, for one week I would not be available, therefore in this time I would not be able to test or review Armada 3720 patches...)
1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
return -EINVAL;
if (ret)
return ret;
-- 2.28.0
Hi Pali, Andre and others,
I'll also be on vacation next week. Sorry, I was not able to follow all discussions on these Armada related patches lately. Could someone please summarize, which patches (fixes) are "okay" for merging in this rc stage (rc4)? That would really be helpful.
Thanks, Stefan
1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
return -EINVAL;
if (ret)
return ret;
-- 2.28.0
Viele Grüße, Stefan
Going by patchwork we have:
All superseded: https://patchwork.ozlabs.org/project/uboot/list/?series=198544 https://patchwork.ozlabs.org/project/uboot/list/?series=198545 https://patchwork.ozlabs.org/project/uboot/list/?series=198756 https://patchwork.ozlabs.org/project/uboot/list/?series=199690
From my point of view these can go in:
This one, fix emmc: https://patchwork.ozlabs.org/project/uboot/list/?series=200919 dts: fix vendor, add -emmc variant: https://patchwork.ozlabs.org/project/uboot/list/?series=199579
These two for uDPU from its maintainer, taken from the OpenWRT uboot-mvebu package: CONFIG_SYS_BOOTM_LEN to 64MB: https://patchwork.ozlabs.org/project/uboot/list/?series=199858 add support for Macronix mx25u12835f flash: https://patchwork.ozlabs.org/project/uboot/list/?series=199857
And I'd take these two too, Pali has different opinion though: enable NET_RANDOM_ETHADDR: https://patchwork.ozlabs.org/project/uboot/list/?series=200115 set fdtfile: https://patchwork.ozlabs.org/project/uboot/list/?series=201051
Thanks, Andre
I shall check this if it does not break our boards.
I have replied to the NET_RANDOM_ETHADDR patch, please comment on my reply.
As for the fdtfile I think it is good to go.
Thanks, Andre
Thanks. Unfortunately this is taking a bit too long for me, as I have to leave in about an hour. I will take care of these patches in a bit over a week.
Thanks, Stefan
Thanks, Stefan
Happy vacation, Stefan :)
Sounds good, thanks!
Have a nice vacation, Andre
"bus-width",
1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
return -EINVAL;
if (ret)
return ret;
Tested-by: Marek Behún marek.behun@nic.cz
"bus-width",
1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
return -EINVAL;
if (ret)
return ret;
|Tested-by: Gérald Kerma gandalf@gk2.net| ||
participants (6)
Andre Heider
Gérald Kerma
Kostya Porotchkin
Marek Behún
Pali Rohár
Stefan Roese
