[U-Boot] [PATCH 0/7] km82xx and mgcogeXxx reworking
Hello,
this patch series does a bit of housekeeping on our mgcogeXxx boards. First we do some due code cleanups which just move code around, then we introduce dynamic SDRAM detection so the same u-boot binary can be used on different boards.
Gerlando Falauto (6): powerpc/82xx: move mgcoge, mgcoge3ne defines to ease subsequent merge powerpc/82xx: merge mgcoge.h and mgcoge3ne.h into km82xx.h powerpc/82xx: move km/km82xx-common.h within km82xx.h powerpc/82xx: add SDRAM detection for km82xx powerpc/82xx: use SDRAM detection for mgcoge2ne powerpc/82xx: adapt SDRAM settings for mgcoge3ne
Holger Brunck (1): powerpc/82xx: remove unused define for mgcoge3ne
board/keymile/km82xx/km82xx.c | 51 ++++- boards.cfg | 4 +- include/configs/km/km82xx-common.h | 317 ------------------------- include/configs/km82xx.h | 448 ++++++++++++++++++++++++++++++++++++ include/configs/mgcoge.h | 93 -------- include/configs/mgcoge3ne.h | 96 -------- 6 files changed, 499 insertions(+), 510 deletions(-) delete mode 100644 include/configs/km/km82xx-common.h create mode 100644 include/configs/km82xx.h delete mode 100644 include/configs/mgcoge.h delete mode 100644 include/configs/mgcoge3ne.h
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- include/configs/mgcoge3ne.h | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/include/configs/mgcoge3ne.h b/include/configs/mgcoge3ne.h index 6fa1584..43d14ba 100644 --- a/include/configs/mgcoge3ne.h +++ b/include/configs/mgcoge3ne.h @@ -90,7 +90,4 @@ /* include further common stuff for all keymile 82xx boards */ #include "km/km82xx-common.h"
-/* bfticu address */ -#define CONFIG_SYS_BFTICU_BASE 0x40000000 - #endif /* __MGCOGE3NE */
Dear Gerlando Falauto,
In message 1343402200-32020-2-git-send-email-gerlando.falauto@keymile.com you wrote:
Applied, thanks.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- include/configs/mgcoge.h | 34 +++++++++++++++++----------------- include/configs/mgcoge3ne.h | 34 +++++++++++++++++----------------- 2 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index b736c56..ad3b58e 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -33,6 +33,7 @@ #define CONFIG_MGCOGE #define CONFIG_HOSTNAME mgcoge #define CONFIG_KM_82XX +#define CONFIG_KM_BOARD_EXTRA_ENV ""
#define CONFIG_SYS_TEXT_BASE 0xFE000000
@@ -68,25 +69,24 @@ /* SDRAM initialization values */
-#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ - ORxS_SDAM_MSK) |\ - ORxS_BPD_8 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR (PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_5_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_8 |\ + ORxS_ROWST_PBI0_A7 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_SDAM_A14_IS_A5 |\ + PSDMR_BSMA_A14_A16 |\ + PSDMR_SDA10_PBI0_A9 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_1C |\ + PSDMR_CL_2)
-#define CONFIG_KM_BOARD_EXTRA_ENV "" - /* include further common stuff for all keymile 82xx boards */ #include "km/km82xx-common.h"
diff --git a/include/configs/mgcoge3ne.h b/include/configs/mgcoge3ne.h index 43d14ba..7ab03a0 100644 --- a/include/configs/mgcoge3ne.h +++ b/include/configs/mgcoge3ne.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2011 + * (C) Copyright 2007-2011 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -21,8 +21,8 @@ * MA 02111-1307 USA */
-#ifndef __MGCOGE3NE -#define __MGCOGE3NE +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Configuration Options @@ -33,6 +33,7 @@ #define CONFIG_MGCOGE3NE #define CONFIG_HOSTNAME mgcoge3ne #define CONFIG_KM_82XX +#define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0"
@@ -68,26 +69,25 @@ #define SDRAM_MAX_SIZE 0x10000000 /* max. 256 MB */ #define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (512 << 20) /* less than 512 MB */
-#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ - ORxS_SDAM_MSK) |\ +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ ORxS_BPD_4 |\ ORxS_ROWST_PBI1_A4 |\ ORxS_NUMR_13)
-#define CONFIG_SYS_PSDMR (PSDMR_PBI |\ - PSDMR_SDAM_A17_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI1_A6 |\ - PSDMR_RFRC_5_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_2C |\ +#define CONFIG_SYS_PSDMR ( \ + PSDMR_PBI |\ + PSDMR_SDAM_A17_IS_A5 |\ + PSDMR_BSMA_A13_A15 |\ + PSDMR_SDA10_PBI1_A6 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_2C |\ PSDMR_CL_2)
-#define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0" - /* include further common stuff for all keymile 82xx boards */ #include "km/km82xx-common.h"
-#endif /* __MGCOGE3NE */ +#endif /* __CONFIG_H */
In message 1343402200-32020-3-git-send-email-gerlando.falauto@keymile.com you wrote:
Applied, thanks.
The only file including km82xx-common.h is km82xx.h. So there is no need to have it as a separate file.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- Changes from v1: switched to git v1.7.10.4, used git format-patch -M -C -B --- include/configs/{km/km82xx-common.h => km82xx.h} | 128 +++++++++++++++++++++- 1 file changed, 124 insertions(+), 4 deletions(-) rename include/configs/{km/km82xx-common.h => km82xx.h} (75%)
diff --git a/include/configs/km/km82xx-common.h b/include/configs/km82xx.h similarity index 75% rename from include/configs/km/km82xx-common.h rename to include/configs/km82xx.h index 2c763bb..9bfb8df 100644 --- a/include/configs/km/km82xx-common.h +++ b/include/configs/km82xx.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007-2010 + * (C) Copyright 2007-2011 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -21,10 +21,130 @@ * MA 02111-1307 USA */
-#ifndef __KM82XX_COMMON -#define __KM82XX_COMMON +#ifndef __CONFIG_H +#define __CONFIG_H
/* + * High Level Configuration Options + * (easy to change) + */ + +#define CONFIG_MPC8247 +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_HOSTNAME mgcoge +#define CONFIG_KM_BOARD_EXTRA_ENV "" + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) +#define CONFIG_HOSTNAME mgcoge3ne +#define CONFIG_KM_82XX +#define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0" + +#else +#error ("Board unsupported") +#endif + +#define CONFIG_SYS_TEXT_BASE 0xFE000000 + +/* include common defines/options for all Keymile boards */ +#include "km/keymile-common.h" +#include "km/km-powerpc.h" + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_FLASH_BASE 0xFE000000 +#define CONFIG_SYS_FLASH_SIZE 32 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER + +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_SYS_MAX_FLASH_BANKS 3 +/* max num of sects on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +#define CONFIG_SYS_FLASH_BASE_1 0x50000000 +#define CONFIG_SYS_FLASH_SIZE_1 32 +#define CONFIG_SYS_FLASH_BASE_2 0x52000000 +#define CONFIG_SYS_FLASH_SIZE_2 32 + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE_1, \ + CONFIG_SYS_FLASH_BASE_2 } +#define MTDIDS_DEFAULT "nor3=app" + +/* + * Bank 1 - 60x bus SDRAM + */ +#define SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ +#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ + +/* SDRAM initialization values +*/ + +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_8 |\ + ORxS_ROWST_PBI0_A7 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_SDAM_A14_IS_A5 |\ + PSDMR_BSMA_A14_A16 |\ + PSDMR_SDA10_PBI0_A9 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_1C |\ + PSDMR_CL_2) + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* + * max num of sects on one + * chip + */ + +#define CONFIG_SYS_FLASH_BASE_1 0x50000000 +#define CONFIG_SYS_FLASH_SIZE_1 128 + +#define CONFIG_SYS_FLASH_SIZE_2 0 /* dummy value to calc SYS_OR5 */ + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE_1 } + +#define MTDIDS_DEFAULT "nor2=app" + +/* + * Bank 1 - 60x bus SDRAM + * mgcoge3ne has 256M. + */ +#define SDRAM_MAX_SIZE 0x10000000 /* max. 256 MB */ +#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (512 << 20) /* less than 512 MB */ + +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_4 |\ + ORxS_ROWST_PBI1_A4 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_PBI |\ + PSDMR_SDAM_A17_IS_A5 |\ + PSDMR_BSMA_A13_A15 |\ + PSDMR_SDA10_PBI1_A6 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_2C |\ + PSDMR_CL_2) +#endif /* defined(CONFIG_MGCOGE3NE) */ + +/* include further common stuff for all keymile 82xx boards */ +/* * Select serial console configuration * * If either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then @@ -314,4 +434,4 @@ int get_scl(void); #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc/cpm/serial@11a90"
-#endif /* __KM82XX_COMMON */ +#endif /* __CONFIG_H */
Since mgcoge and mgcoge3ne are the only km82xx boards, there is no need to keep them as separate .h config files. Therefore, make mgcoge3ne.h and mgcoge.h converge into a single km82xx.h file.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- boards.cfg | 4 +- include/configs/km82xx.h | 149 +++++++++++++++++++++++++++++++++++++++++++ include/configs/mgcoge.h | 93 --------------------------- include/configs/mgcoge3ne.h | 93 --------------------------- 4 files changed, 151 insertions(+), 188 deletions(-) create mode 100644 include/configs/km82xx.h delete mode 100644 include/configs/mgcoge.h delete mode 100644 include/configs/mgcoge3ne.h
diff --git a/boards.cfg b/boards.cfg index 2d36d83..1af87c0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -577,8 +577,8 @@ PQ2FADS-ZU_66MHz powerpc mpc8260 mpc8260ads freesca PQ2FADS-ZU_66MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 PQ2FADS-ZU_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 VoVPN-GW_66MHz powerpc mpc8260 vovpn-gw funkwerk - VoVPN-GW:CLKIN_66MHz -mgcoge powerpc mpc8260 km82xx keymile -mgcoge3ne powerpc mpc8260 km82xx keymile +mgcoge powerpc mpc8260 km82xx keymile - km82xx:MGCOGE +mgcoge3ne powerpc mpc8260 km82xx keymile - km82xx:MGCOGE3NE SCM powerpc mpc8260 - siemens TQM8255_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8255,300MHz TQM8260_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz diff --git a/include/configs/km82xx.h b/include/configs/km82xx.h new file mode 100644 index 0000000..5d62f4b --- /dev/null +++ b/include/configs/km82xx.h @@ -0,0 +1,149 @@ +/* + * (C) Copyright 2007-2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ + +#define CONFIG_MPC8247 +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_HOSTNAME mgcoge +#define CONFIG_KM_BOARD_EXTRA_ENV "" + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) +#define CONFIG_HOSTNAME mgcoge3ne +#define CONFIG_KM_82XX +#define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0" + +#else +#error ("Board unsupported") +#endif + +#define CONFIG_SYS_TEXT_BASE 0xFE000000 + +/* include common defines/options for all Keymile boards */ +#include "km/keymile-common.h" +#include "km/km-powerpc.h" + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_FLASH_BASE 0xFE000000 +#define CONFIG_SYS_FLASH_SIZE 32 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER + +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_SYS_MAX_FLASH_BANKS 3 +/* max num of sects on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +#define CONFIG_SYS_FLASH_BASE_1 0x50000000 +#define CONFIG_SYS_FLASH_SIZE_1 32 +#define CONFIG_SYS_FLASH_BASE_2 0x52000000 +#define CONFIG_SYS_FLASH_SIZE_2 32 + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE_1, \ + CONFIG_SYS_FLASH_BASE_2 } +#define MTDIDS_DEFAULT "nor3=app" + +/* + * Bank 1 - 60x bus SDRAM + */ +#define SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ +#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ + +/* SDRAM initialization values +*/ + +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_8 |\ + ORxS_ROWST_PBI0_A7 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_SDAM_A14_IS_A5 |\ + PSDMR_BSMA_A14_A16 |\ + PSDMR_SDA10_PBI0_A9 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_1C |\ + PSDMR_CL_2) + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* + * max num of sects on one + * chip + */ + +#define CONFIG_SYS_FLASH_BASE_1 0x50000000 +#define CONFIG_SYS_FLASH_SIZE_1 128 + +#define CONFIG_SYS_FLASH_SIZE_2 0 /* dummy value to calc SYS_OR5 */ + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE_1 } + +#define MTDIDS_DEFAULT "nor2=app" + +/* + * Bank 1 - 60x bus SDRAM + * mgcoge3ne has 256M. + */ +#define SDRAM_MAX_SIZE 0x10000000 /* max. 256 MB */ +#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (512 << 20) /* less than 512 MB */ + +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_4 |\ + ORxS_ROWST_PBI1_A4 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_PBI |\ + PSDMR_SDAM_A17_IS_A5 |\ + PSDMR_BSMA_A13_A15 |\ + PSDMR_SDA10_PBI1_A6 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_2C |\ + PSDMR_CL_2) +#endif /* defined(CONFIG_MGCOGE3NE) */ + +/* include further common stuff for all keymile 82xx boards */ +#include "km/km82xx-common.h" + +#endif /* __CONFIG_H */ diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h deleted file mode 100644 index ad3b58e..0000000 --- a/include/configs/mgcoge.h +++ /dev/null @@ -1,93 +0,0 @@ -/* - * (C) Copyright 2007-2011 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC8247 -#define CONFIG_MGCOGE -#define CONFIG_HOSTNAME mgcoge -#define CONFIG_KM_82XX -#define CONFIG_KM_BOARD_EXTRA_ENV "" - -#define CONFIG_SYS_TEXT_BASE 0xFE000000 - -/* include common defines/options for all Keymile boards */ -#include "km/keymile-common.h" -#include "km/km-powerpc.h" - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#define CONFIG_SYS_FLASH_SIZE 32 -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_BANKS 3 -/* max num of sects on one chip */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 - -#define CONFIG_SYS_FLASH_BASE_1 0x50000000 -#define CONFIG_SYS_FLASH_SIZE_1 32 -#define CONFIG_SYS_FLASH_BASE_2 0x52000000 -#define CONFIG_SYS_FLASH_SIZE_2 32 - -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ - CONFIG_SYS_FLASH_BASE_1, \ - CONFIG_SYS_FLASH_BASE_2 } -#define MTDIDS_DEFAULT "nor3=app" - -/* - * Bank 1 - 60x bus SDRAM - */ -#define SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ -#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ - -/* SDRAM initialization values -*/ - -#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ - ORxS_SDAM_MSK) |\ - ORxS_BPD_8 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR ( \ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_5_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - -/* include further common stuff for all keymile 82xx boards */ -#include "km/km82xx-common.h" - -#endif /* __CONFIG_H */ diff --git a/include/configs/mgcoge3ne.h b/include/configs/mgcoge3ne.h deleted file mode 100644 index 7ab03a0..0000000 --- a/include/configs/mgcoge3ne.h +++ /dev/null @@ -1,93 +0,0 @@ -/* - * (C) Copyright 2007-2011 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC8247 -#define CONFIG_MGCOGE3NE -#define CONFIG_HOSTNAME mgcoge3ne -#define CONFIG_KM_82XX -#define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0" - -#define CONFIG_SYS_TEXT_BASE 0xFE000000 - -/* include common defines/options for all Keymile boards */ -#include "km/keymile-common.h" -#include "km/km-powerpc.h" - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#define CONFIG_SYS_FLASH_SIZE 32 -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* - * max num of sects on one - * chip - */ - -#define CONFIG_SYS_FLASH_BASE_1 0x50000000 -#define CONFIG_SYS_FLASH_SIZE_1 128 - -#define CONFIG_SYS_FLASH_SIZE_2 0 /* dummy value to calc SYS_OR5 */ - -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ - CONFIG_SYS_FLASH_BASE_1 } - -#define MTDIDS_DEFAULT "nor2=app" - -/* - * Bank 1 - 60x bus SDRAM - * mgcoge3ne has 256M. - */ -#define SDRAM_MAX_SIZE 0x10000000 /* max. 256 MB */ -#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (512 << 20) /* less than 512 MB */ - -#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ - ORxS_SDAM_MSK) |\ - ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A4 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR ( \ - PSDMR_PBI |\ - PSDMR_SDAM_A17_IS_A5 |\ - PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI1_A6 |\ - PSDMR_RFRC_5_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_2C |\ - PSDMR_CL_2) - -/* include further common stuff for all keymile 82xx boards */ -#include "km/km82xx-common.h" - -#endif /* __CONFIG_H */
In message 1343402200-32020-4-git-send-email-gerlando.falauto@keymile.com you wrote:
Can you please try creating this patch with git format-patch with options "-M" and "-C", please? I think git should do better to recognize this rename / merge of two files.
Dear Wolgfang Denk,
In message1343402200-32020-4-git-send-email-gerlando.falauto@keymile.com you wrote:
Signed-off-by: Gerlando Falautogerlando.falauto@keymile.com
I tried this but to no avail, the resulting patch is still the same. Same for patch number 4.
I guess git gets confused by the fact that we are merging two files into one. What I could do is to split this commit so that, for instance, first we rename one of the files and then (on a separate commit) we move the content of one into the other. In any case, I believe git has no notion of operations like "a file being embedded into another". I think the best we could do is to put such changes into a separate commit and mark it explicitly (perhaps including a sed script in the commit message) so that they can be automated in case of a rebase.
Question is, is this really worth the effort? Is there a common practice for such reworks?
Thank you, Gerlando
No, git can handle this pretty well if you tell it what you are doing. I just retested this; the result is:
--- file.1 | 64 --------------------------------------------------- file.2 => file.common | 64 +++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 64 insertions(+), 64 deletions(-) delete mode 100644 file.1 rename file.2 => file.common (63%)
No, this can and should be done in a single commit, for example like this:
1. run: git mv include/configs/mgcoge.h include/configs/km82xx.h 2. merge include/configs/mgcoge3ne.h into include/configs/km82xx.h 3. run: git rm include/configs/mgcoge3ne.h
git format-patch -M -C will then recognize what you did.
Yes, if possible we want that git tracks such renames / merges. And here it seems easily possible.
- run: git mv include/configs/mgcoge.h include/configs/km82xx.h
- merge include/configs/mgcoge3ne.h into include/configs/km82xx.h
- run: git rm include/configs/mgcoge3ne.h
The way I understand it, such renaming information is built on the fly while building the patch (like you're suggesting, it's a parameter to git format-patch, not to the commit itself).
In other words, a renaming is just a remove and an add (see [1]): -- Git has a rename command git mv, but that is just for convenience. The effect is indistinguishable from removing the file and adding another with different name and the same content. --
As a matter of fact, I am able to get the renaming recognized when committing:
--- [detached HEAD 85129b8] powerpc/82xx: 1of2 move km/km82xx-common.h within km82xx.h 1 files changed, 148 insertions(+), 0 deletions(-) rename include/configs/{km/km82xx-common.h => km82xx.h} (71%) ---
However, I've been struggling to get this same kind of message through git-format-patch. No way, I don't know why. I tried with -M, -M -C, -M10%, adding "[diff]\n renames = copies" to ~/.gitconfig, with both versions below, nothing. Detected as a rename at commit time, it's a plain delete/create commit at patch creation time.
$ git --version git version 1.7.1
$ ~/git/bin-wrappers/git --version git version 1.7.11.3
Could you please share what GIT version you're running?
Could you please try applying the patch to your tree (namely 3 and 4), and then build it again by running: git-format-patch -M30% -C
It should get detected as a rename anyway (I mean, even if applied as a whole delete/add).
In any case, I have no clue whether git would be able to correctly (i.e. intelligently) apply such patch to a slightly different tree (e.g. through cherry-pick or rebase). So for instance, in your example above, what if file.1 (whose contents is anyway moved into file.common, regardless of rename detection) is slightly different? Would the patch fail? Or worse, would it silently apply by just deleting the "new" file and applying the "old" contents (verbatim from the patch)?
I'm strongly convinced that if we want to track such changes for what they are (code moving) so that they can be "easily" re-applied, we should mark this explicitly. Even at the cost of creating multiple patches if necessary. Since git isn't able to figure it out by itself, the only way I can think of doing this is splitting the commit into 3 parts: 1) preparation work, adding #include statements to the old files 2) automated code moving through a script like the following (and including it in the commit message itself) 3) cleanup changes
================================================================ powerpc/82xx: 2of3 merge mgcoge.h and mgcoge3ne.h into km82xx.h
Since mgcoge and mgcoge3ne are the only km82xx boards, there is no need to keep them as separate .h config files. Therefore, make mgcoge3ne.h and mgcoge.h converge into a single km82xx.h file. Step 2 of 3: substitute include files through the following script:
INCLUDE_STMT='#include "mgcoge.h"' INCLUDED=include/configs/mgcoge.h INCLUDING=include/configs/km82xx.h
[[ -e $INCLUDING ]] && [[ -e $INCLUDED ]] && grep -F "$INCLUDE_STMT" $INCLUDING && ( LINE=`grep -nF "$INCLUDE_STMT" $INCLUDING | cut -d: -f1` head -n$((LINE-1)) $INCLUDING cat $INCLUDED tail -n+$((LINE+1)) $INCLUDING) > /tmp/includemerge.txt && mv /tmp/includemerge.txt $INCLUDING && git rm $INCLUDED && git add $INCLUDING
INCLUDE_STMT='#include "mgcoge3ne.h"' INCLUDED=include/configs/mgcoge3ne.h INCLUDING=include/configs/km82xx.h
[[ -e $INCLUDING ]] && [[ -e $INCLUDED ]] && grep -F "$INCLUDE_STMT" $INCLUDING && ( LINE=`grep -nF "$INCLUDE_STMT" $INCLUDING | cut -d: -f1` head -n$((LINE-1)) $INCLUDING cat $INCLUDED tail -n+$((LINE+1)) $INCLUDING) > /tmp/includemerge.txt && mv /tmp/includemerge.txt $INCLUDING && git rm $INCLUDED && git add $INCLUDING ================================================================
Then the patch content itself can be safely ignored. I know it's not nice, but I think it should work.
Thank you for reading up to this point. :-) Gerlando
Yes, and I fail to understand where your problems could be.
I see this (doing it all manually for testing):
-> patch -p1 </tmp/patch -> git rm include/configs/mgcoge.h include/configs/mgcoge3ne.h -> git add include/configs/km82xx.h -> git commit -s -m 'test 1' -> git format-patch -M -C --stdout HEAD^ >/tmp/patch -> less /tmp/patch
From 1d9ce92a542d139b78291fb4e437e538d647d55b Mon Sep 17 00:00:00 2001
From: Wolfgang Denk wd@denx.de Date: Mon, 30 Jul 2012 17:57:53 +0200 Subject: [PATCH] test 1
Signed-off-by: Wolfgang Denk wd@denx.de --- include/configs/{mgcoge3ne.h => km82xx.h} | 95 ++++++++++++++++++++++------- include/configs/mgcoge.h | 93 ---------------------------- 2 files changed, 74 insertions(+), 114 deletions(-) rename include/configs/{mgcoge3ne.h => km82xx.h} (55%) delete mode 100644 include/configs/mgcoge.h
Oops, I forgot to "git add boards.cfg" here, but for this test it makes no difference.
-> git --version git version 1.7.10.4
That's what I get from the normal Fedora 17 installation.
See above...
It doesn't matter. If there are conflicts, and these can be resolved, it works just the same.
No, on contrary. This is basicly an atomic change, and we should not artificially split it. git should have no problems with such actions, they are really not special in any way.
No, please don't.
Argh.... No, this is not what we're going to do.
-> patch -p1</tmp/patch -> git rm include/configs/mgcoge.h include/configs/mgcoge3ne.h -> git add include/configs/km82xx.h -> git commit -s -m 'test 1' -> git format-patch -M -C --stdout HEAD^>/tmp/patch -> less /tmp/patch From 1d9ce92a542d139b78291fb4e437e538d647d55b Mon Sep 17 00:00:00 2001 From: Wolfgang Denkwd@denx.de Date: Mon, 30 Jul 2012 17:57:53 +0200 Subject: [PATCH] test 1
Signed-off-by: Wolfgang Denkwd@denx.de
It turns out it's a bug/limitation of git 1.7.1. I upgraded to 1.7.10.4 and 1.7.11.3 and now I get the same results as you do (rename detected). See new patch as a follow-up.
Renaming, I understand. But merging/splitting files, I guess they should be treated differently (i.e., as such!) IMHO, if we want repeatability and resilience to small changes. But git doesn't (yet?) do that, and I think it should be worked around some other way.
No, please don't.
Alright, your call.
Thanks for your patience. Gerlando
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- Changes from v1: switched to git v1.7.11.3, used git format-patch -M -C --- boards.cfg | 4 +- include/configs/{mgcoge3ne.h => km82xx.h} | 58 ++++++++++++++++++- include/configs/mgcoge.h | 93 ------------------------------- 3 files changed, 59 insertions(+), 96 deletions(-) rename include/configs/{mgcoge3ne.h => km82xx.h} (66%) delete mode 100644 include/configs/mgcoge.h
diff --git a/boards.cfg b/boards.cfg index 2d36d83..1af87c0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -577,8 +577,8 @@ PQ2FADS-ZU_66MHz powerpc mpc8260 mpc8260ads freesca PQ2FADS-ZU_66MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 PQ2FADS-ZU_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 VoVPN-GW_66MHz powerpc mpc8260 vovpn-gw funkwerk - VoVPN-GW:CLKIN_66MHz -mgcoge powerpc mpc8260 km82xx keymile -mgcoge3ne powerpc mpc8260 km82xx keymile +mgcoge powerpc mpc8260 km82xx keymile - km82xx:MGCOGE +mgcoge3ne powerpc mpc8260 km82xx keymile - km82xx:MGCOGE3NE SCM powerpc mpc8260 - siemens TQM8255_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8255,300MHz TQM8260_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz diff --git a/include/configs/mgcoge3ne.h b/include/configs/km82xx.h similarity index 66% rename from include/configs/mgcoge3ne.h rename to include/configs/km82xx.h index 7ab03a0..5d62f4b 100644 --- a/include/configs/mgcoge3ne.h +++ b/include/configs/km82xx.h @@ -30,11 +30,21 @@ */
#define CONFIG_MPC8247 -#define CONFIG_MGCOGE3NE +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_HOSTNAME mgcoge +#define CONFIG_KM_BOARD_EXTRA_ENV "" + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) #define CONFIG_HOSTNAME mgcoge3ne #define CONFIG_KM_82XX #define CONFIG_KM_BOARD_EXTRA_ENV "bobcatreset=true\0"
+#else +#error ("Board unsupported") +#endif + #define CONFIG_SYS_TEXT_BASE 0xFE000000
/* include common defines/options for all Keymile boards */ @@ -46,6 +56,51 @@ #define CONFIG_SYS_FLASH_SIZE 32 #define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER + +/* MGCOGE */ +#if defined(CONFIG_MGCOGE) +#define CONFIG_SYS_MAX_FLASH_BANKS 3 +/* max num of sects on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +#define CONFIG_SYS_FLASH_BASE_1 0x50000000 +#define CONFIG_SYS_FLASH_SIZE_1 32 +#define CONFIG_SYS_FLASH_BASE_2 0x52000000 +#define CONFIG_SYS_FLASH_SIZE_2 32 + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE_1, \ + CONFIG_SYS_FLASH_BASE_2 } +#define MTDIDS_DEFAULT "nor3=app" + +/* + * Bank 1 - 60x bus SDRAM + */ +#define SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ +#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ + +/* SDRAM initialization values +*/ + +#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ + ORxS_SDAM_MSK) |\ + ORxS_BPD_8 |\ + ORxS_ROWST_PBI0_A7 |\ + ORxS_NUMR_13) + +#define CONFIG_SYS_PSDMR ( \ + PSDMR_SDAM_A14_IS_A5 |\ + PSDMR_BSMA_A14_A16 |\ + PSDMR_SDA10_PBI0_A9 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_LDOTOPRE_1C |\ + PSDMR_WRC_1C |\ + PSDMR_CL_2) + +/* MGCOGE3NE */ +#elif defined(CONFIG_MGCOGE3NE) #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* * max num of sects on one @@ -86,6 +141,7 @@ PSDMR_LDOTOPRE_1C |\ PSDMR_WRC_2C |\ PSDMR_CL_2) +#endif /* defined(CONFIG_MGCOGE3NE) */
/* include further common stuff for all keymile 82xx boards */ #include "km/km82xx-common.h" diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h deleted file mode 100644 index ad3b58e..0000000 --- a/include/configs/mgcoge.h +++ /dev/null @@ -1,93 +0,0 @@ -/* - * (C) Copyright 2007-2011 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC8247 -#define CONFIG_MGCOGE -#define CONFIG_HOSTNAME mgcoge -#define CONFIG_KM_82XX -#define CONFIG_KM_BOARD_EXTRA_ENV "" - -#define CONFIG_SYS_TEXT_BASE 0xFE000000 - -/* include common defines/options for all Keymile boards */ -#include "km/keymile-common.h" -#include "km/km-powerpc.h" - -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#define CONFIG_SYS_FLASH_SIZE 32 -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_BANKS 3 -/* max num of sects on one chip */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 - -#define CONFIG_SYS_FLASH_BASE_1 0x50000000 -#define CONFIG_SYS_FLASH_SIZE_1 32 -#define CONFIG_SYS_FLASH_BASE_2 0x52000000 -#define CONFIG_SYS_FLASH_SIZE_2 32 - -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, \ - CONFIG_SYS_FLASH_BASE_1, \ - CONFIG_SYS_FLASH_BASE_2 } -#define MTDIDS_DEFAULT "nor3=app" - -/* - * Bank 1 - 60x bus SDRAM - */ -#define SDRAM_MAX_SIZE 0x08000000 /* max. 128 MB */ -#define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (256 << 20) /* less than 256 MB */ - -/* SDRAM initialization values -*/ - -#define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ - ORxS_SDAM_MSK) |\ - ORxS_BPD_8 |\ - ORxS_ROWST_PBI0_A7 |\ - ORxS_NUMR_13) - -#define CONFIG_SYS_PSDMR ( \ - PSDMR_SDAM_A14_IS_A5 |\ - PSDMR_BSMA_A14_A16 |\ - PSDMR_SDA10_PBI0_A9 |\ - PSDMR_RFRC_5_CLK |\ - PSDMR_PRETOACT_2W |\ - PSDMR_ACTTORW_2W |\ - PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_1C |\ - PSDMR_CL_2) - - -/* include further common stuff for all keymile 82xx boards */ -#include "km/km82xx-common.h" - -#endif /* __CONFIG_H */
Applied, thanks.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- include/configs/km/km82xx-common.h | 317 ------------------------------------ include/configs/km82xx.h | 290 ++++++++++++++++++++++++++++++++- 2 files changed, 289 insertions(+), 318 deletions(-) delete mode 100644 include/configs/km/km82xx-common.h
diff --git a/include/configs/km/km82xx-common.h b/include/configs/km/km82xx-common.h deleted file mode 100644 index 2c763bb..0000000 --- a/include/configs/km/km82xx-common.h +++ /dev/null @@ -1,317 +0,0 @@ -/* - * (C) Copyright 2007-2010 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __KM82XX_COMMON -#define __KM82XX_COMMON - -/* - * Select serial console configuration - * - * If either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then - * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 - * for SCC). - */ -#define CONFIG_CONS_ON_SMC /* Console is on SMC */ -#undef CONFIG_CONS_ON_SCC /* It's not on SCC */ -#undef CONFIG_CONS_NONE /* It's not on external UART */ -#define CONFIG_CONS_INDEX 2 /* SMC2 is used for console */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 - -/* - * Select ethernet configuration - * - * If either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, - * then CONFIG_ETHER_INDEX must be set to the channel number (1-4 for - * SCC, 1-3 for FCC) - * - * If CONFIG_ETHER_NONE is defined, then either the ethernet routines - * must be defined elsewhere (as for the console), or CONFIG_CMD_NET - * must be unset. - */ -#define CONFIG_ETHER_ON_SCC /* Ethernet is on SCC */ -#undef CONFIG_ETHER_ON_FCC /* Ethernet is not on FCC */ -#undef CONFIG_ETHER_NONE /* No external Ethernet */ - -#define CONFIG_ETHER_INDEX 4 -#define CONFIG_HAS_ETH0 -#define CONFIG_SYS_SCC_TOUT_LOOP 10000000 - -#define CONFIG_SYS_CMXSCR_VALUE (CMXSCR_RS4CS_CLK7 | CMXSCR_TS4CS_CLK8) - -#ifndef CONFIG_8260_CLKIN -#define CONFIG_8260_CLKIN 66000000 /* in Hz */ -#endif - -#define BOOTFLASH_START 0xFE000000 - -#define CONFIG_KM_CONSOLE_TTY "ttyCPM0" - -#define MTDPARTS_DEFAULT "mtdparts=" \ - "app:" \ - "768k(u-boot)," \ - "128k(env)," \ - "128k(envred)," \ - "3072k(free)," \ - "-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ")" - -/* - * Default environment settings - */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - CONFIG_KM_BOARD_EXTRA_ENV \ - CONFIG_KM_DEF_ENV \ - "EEprom_ivm=pca9544a:70:4 \0" \ - "unlock=yes\0" \ - "newenv=" \ - "prot off 0xFE0C0000 +0x40000 && " \ - "era 0xFE0C0000 +0x40000\0" \ - "arch=ppc_82xx\0" \ - "" - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_LEN (768 << 10) - -#define CONFIG_ENV_IS_IN_FLASH - -#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ - CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) -#endif /* CONFIG_ENV_IS_IN_FLASH */ - -/* enable I2C and select the hardware/software driver */ -#undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 50000 /* I2C speed */ -#define CONFIG_SYS_I2C_SLAVE 0x7F /* I2C slave address */ - -/* - * Software (bit-bang) I2C driver configuration - */ - -#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ -#define I2C_ACTIVE (iop->pdir |= 0x00010000) -#define I2C_TRISTATE (iop->pdir &= ~0x00010000) -#define I2C_READ ((iop->pdat & 0x00010000) != 0) -#define I2C_SDA(bit) do { \ - if (bit) \ - iop->pdat |= 0x00010000; \ - else \ - iop->pdat &= ~0x00010000; \ - } while (0) -#define I2C_SCL(bit) do { \ - if (bit) \ - iop->pdat |= 0x00020000; \ - else \ - iop->pdat &= ~0x00020000; \ - } while (0) -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -#ifndef __ASSEMBLY__ -void set_sda(int state); -void set_scl(int state); -int get_sda(void); -int get_scl(void); -#endif - -/* I2C SYSMON (LM75, AD7414 is almost compatible) */ -#define CONFIG_DTT_LM75 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ -#define CONFIG_SYS_DTT_MAX_TEMP 70 -#define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3 -#define CONFIG_SYS_DTT_BUS_NUM (CONFIG_SYS_MAX_I2C_BUS) - -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - -#define CONFIG_SYS_IMMR 0xF0000000 - -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* used size in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/* Hard reset configuration word */ -#define CONFIG_SYS_HRCW_MASTER 0x0604b211 - -/* No slaves */ -#define CONFIG_SYS_HRCW_SLAVE1 0 -#define CONFIG_SYS_HRCW_SLAVE2 0 -#define CONFIG_SYS_HRCW_SLAVE3 0 -#define CONFIG_SYS_HRCW_SLAVE4 0 -#define CONFIG_SYS_HRCW_SLAVE5 0 -#define CONFIG_SYS_HRCW_SLAVE6 0 -#define CONFIG_SYS_HRCW_SLAVE7 0 - -/* Initial Memory map for Linux */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -#define CONFIG_SYS_HID0_INIT 0 -#define CONFIG_SYS_HID0_FINAL (HID0_ICE | HID0_IFEM | HID0_ABE) - -#define CONFIG_SYS_HID2 0 - -#define CONFIG_SYS_SIUMCR 0x4020c200 -#define CONFIG_SYS_SYPCR 0xFFFFFF83 -#define CONFIG_SYS_BCR 0x10000000 -#define CONFIG_SYS_SCCR (SCCR_PCI_MODE | SCCR_PCI_MODCK) - -/* - *----------------------------------------------------------------------- - * RMR - Reset Mode Register 5-5 - *----------------------------------------------------------------------- - * turn on Checkstop Reset Enable - */ -#define CONFIG_SYS_RMR 0 - -/* - *----------------------------------------------------------------------- - * TMCNTSC - Time Counter Status and Control 4-40 - *----------------------------------------------------------------------- - * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, - * and enable Time Counter - */ -#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) - -/* - *----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 4-42 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable - * Periodic timer - */ -#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) - -/* - *----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration 13-7 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RCCR 0 - -/* - * Init Memory Controller: - * - * Bank Bus Machine PortSz Device - * ---- --- ------- ------ ------ - * 0 60x GPCM 8 bit FLASH - * 1 60x SDRAM 32 bit SDRAM - * 3 60x GPCM 8 bit GPIO/PIGGY - * 5 60x GPCM 16 bit CFG-Flash - * - */ -/* Bank 0 - FLASH - */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ - BRx_PS_8 |\ - BRx_MS_GPCM_P |\ - BRx_V) - -#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ - ORxG_CSNT |\ - ORxG_ACS_DIV2 |\ - ORxG_SCY_5_CLK |\ - ORxG_TRLX) - -#define CONFIG_SYS_MPTPR 0x1800 - -/* - *----------------------------------------------------------------------------- - * Address for Mode Register Set (MRS) command - *----------------------------------------------------------------------------- - */ -#define CONFIG_SYS_MRS_OFFS 0x00000110 -#define CONFIG_SYS_PSRT 0x0e - -#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ - BRx_PS_64 |\ - BRx_MS_SDRAM_P |\ - BRx_V) - -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR1 - -/* - * UPIO FPGA (GPIO/PIGGY) on CS3 initialization values - */ -#define CONFIG_SYS_KMBEC_FPGA_BASE 0x30000000 -#define CONFIG_SYS_KMBEC_FPGA_SIZE 128 - -#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_KMBEC_FPGA_BASE & BRx_BA_MSK) |\ - BRx_PS_8 | BRx_MS_GPCM_P | BRx_V) - -#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_KMBEC_FPGA_SIZE) |\ - ORxG_CSNT | ORxG_ACS_DIV2 |\ - ORxG_SCY_3_CLK | ORxG_TRLX) - -/* - * BFTICU board FPGA on CS4 initialization values - */ -#define CONFIG_SYS_FPGA_BASE 0x40000000 -#define CONFIG_SYS_FPGA_SIZE 1 /*1KB*/ - -#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_FPGA_BASE & BRx_BA_MSK) |\ - BRx_PS_8 | BRx_MS_GPCM_P | BRx_V) - -#define CONFIG_SYS_OR4_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FPGA_SIZE << 10) |\ - ORxG_CSNT | ORxG_ACS_DIV2 |\ - ORxG_SCY_3_CLK | ORxG_TRLX) - -/* - * CFG-Flash on CS5 initialization values - */ -#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_FLASH_BASE_1 & BRx_BA_MSK) |\ - BRx_PS_16 | BRx_MS_GPCM_P | BRx_V) - -#define CONFIG_SYS_OR5_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE_1 + \ - CONFIG_SYS_FLASH_SIZE_2) |\ - ORxG_CSNT | ORxG_ACS_DIV2 |\ - ORxG_SCY_5_CLK | ORxG_TRLX) - -#define CONFIG_SYS_RESET_ADDRESS 0xFDFFFFFC /* "bad" address */ - -/* pass open firmware flat tree */ -#define CONFIG_FIT 1 -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 - -#define OF_TBCLK (bd->bi_busfreq / 4) -#define OF_STDOUT_PATH "/soc/cpm/serial@11a90" - -#endif /* __KM82XX_COMMON */ diff --git a/include/configs/km82xx.h b/include/configs/km82xx.h index 5d62f4b..9bfb8df 100644 --- a/include/configs/km82xx.h +++ b/include/configs/km82xx.h @@ -144,6 +144,294 @@ #endif /* defined(CONFIG_MGCOGE3NE) */
/* include further common stuff for all keymile 82xx boards */ -#include "km/km82xx-common.h" +/* + * Select serial console configuration + * + * If either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then + * CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4 + * for SCC). + */ +#define CONFIG_CONS_ON_SMC /* Console is on SMC */ +#undef CONFIG_CONS_ON_SCC /* It's not on SCC */ +#undef CONFIG_CONS_NONE /* It's not on external UART */ +#define CONFIG_CONS_INDEX 2 /* SMC2 is used for console */ +#define CONFIG_SYS_SMC_RXBUFLEN 128 +#define CONFIG_SYS_MAXIDLE 10 + +/* + * Select ethernet configuration + * + * If either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, + * then CONFIG_ETHER_INDEX must be set to the channel number (1-4 for + * SCC, 1-3 for FCC) + * + * If CONFIG_ETHER_NONE is defined, then either the ethernet routines + * must be defined elsewhere (as for the console), or CONFIG_CMD_NET + * must be unset. + */ +#define CONFIG_ETHER_ON_SCC /* Ethernet is on SCC */ +#undef CONFIG_ETHER_ON_FCC /* Ethernet is not on FCC */ +#undef CONFIG_ETHER_NONE /* No external Ethernet */ + +#define CONFIG_ETHER_INDEX 4 +#define CONFIG_HAS_ETH0 +#define CONFIG_SYS_SCC_TOUT_LOOP 10000000 + +#define CONFIG_SYS_CMXSCR_VALUE (CMXSCR_RS4CS_CLK7 | CMXSCR_TS4CS_CLK8) + +#ifndef CONFIG_8260_CLKIN +#define CONFIG_8260_CLKIN 66000000 /* in Hz */ +#endif + +#define BOOTFLASH_START 0xFE000000 + +#define CONFIG_KM_CONSOLE_TTY "ttyCPM0" + +#define MTDPARTS_DEFAULT "mtdparts=" \ + "app:" \ + "768k(u-boot)," \ + "128k(env)," \ + "128k(envred)," \ + "3072k(free)," \ + "-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ")" + +/* + * Default environment settings + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_KM_BOARD_EXTRA_ENV \ + CONFIG_KM_DEF_ENV \ + "EEprom_ivm=pca9544a:70:4 \0" \ + "unlock=yes\0" \ + "newenv=" \ + "prot off 0xFE0C0000 +0x40000 && " \ + "era 0xFE0C0000 +0x40000\0" \ + "arch=ppc_82xx\0" \ + "" + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_SYS_MONITOR_LEN (768 << 10) + +#define CONFIG_ENV_IS_IN_FLASH + +#ifdef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#endif /* CONFIG_ENV_IS_IN_FLASH */ + +/* enable I2C and select the hardware/software driver */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 50000 /* I2C speed */ +#define CONFIG_SYS_I2C_SLAVE 0x7F /* I2C slave address */ + +/* + * Software (bit-bang) I2C driver configuration + */ + +#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ +#define I2C_ACTIVE (iop->pdir |= 0x00010000) +#define I2C_TRISTATE (iop->pdir &= ~0x00010000) +#define I2C_READ ((iop->pdat & 0x00010000) != 0) +#define I2C_SDA(bit) do { \ + if (bit) \ + iop->pdat |= 0x00010000; \ + else \ + iop->pdat &= ~0x00010000; \ + } while (0) +#define I2C_SCL(bit) do { \ + if (bit) \ + iop->pdat |= 0x00020000; \ + else \ + iop->pdat &= ~0x00020000; \ + } while (0) +#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ + +#ifndef __ASSEMBLY__ +void set_sda(int state); +void set_scl(int state); +int get_sda(void); +int get_scl(void); +#endif + +/* I2C SYSMON (LM75, AD7414 is almost compatible) */ +#define CONFIG_DTT_LM75 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CONFIG_SYS_DTT_MAX_TEMP 70 +#define CONFIG_SYS_DTT_LOW_TEMP -30 +#define CONFIG_SYS_DTT_HYSTERESIS 3 +#define CONFIG_SYS_DTT_BUS_NUM (CONFIG_SYS_MAX_I2C_BUS) + +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +#define CONFIG_SYS_IMMR 0xF0000000 + +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* used size in DPRAM */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* Hard reset configuration word */ +#define CONFIG_SYS_HRCW_MASTER 0x0604b211 + +/* No slaves */ +#define CONFIG_SYS_HRCW_SLAVE1 0 +#define CONFIG_SYS_HRCW_SLAVE2 0 +#define CONFIG_SYS_HRCW_SLAVE3 0 +#define CONFIG_SYS_HRCW_SLAVE4 0 +#define CONFIG_SYS_HRCW_SLAVE5 0 +#define CONFIG_SYS_HRCW_SLAVE6 0 +#define CONFIG_SYS_HRCW_SLAVE7 0 + +/* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) + +#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + +#define CONFIG_SYS_HID0_INIT 0 +#define CONFIG_SYS_HID0_FINAL (HID0_ICE | HID0_IFEM | HID0_ABE) + +#define CONFIG_SYS_HID2 0 + +#define CONFIG_SYS_SIUMCR 0x4020c200 +#define CONFIG_SYS_SYPCR 0xFFFFFF83 +#define CONFIG_SYS_BCR 0x10000000 +#define CONFIG_SYS_SCCR (SCCR_PCI_MODE | SCCR_PCI_MODCK) + +/* + *----------------------------------------------------------------------- + * RMR - Reset Mode Register 5-5 + *----------------------------------------------------------------------- + * turn on Checkstop Reset Enable + */ +#define CONFIG_SYS_RMR 0 + +/* + *----------------------------------------------------------------------- + * TMCNTSC - Time Counter Status and Control 4-40 + *----------------------------------------------------------------------- + * Clear once per Second and Alarm Interrupt Status, Set 32KHz timersclk, + * and enable Time Counter + */ +#define CONFIG_SYS_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE) + +/* + *----------------------------------------------------------------------- + * PISCR - Periodic Interrupt Status and Control 4-42 + *----------------------------------------------------------------------- + * Clear Periodic Interrupt Status, Set 32KHz timersclk, and enable + * Periodic timer + */ +#define CONFIG_SYS_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE) + +/* + *----------------------------------------------------------------------- + * RCCR - RISC Controller Configuration 13-7 + *----------------------------------------------------------------------- + */ +#define CONFIG_SYS_RCCR 0 + +/* + * Init Memory Controller: + * + * Bank Bus Machine PortSz Device + * ---- --- ------- ------ ------ + * 0 60x GPCM 8 bit FLASH + * 1 60x SDRAM 32 bit SDRAM + * 3 60x GPCM 8 bit GPIO/PIGGY + * 5 60x GPCM 16 bit CFG-Flash + * + */ +/* Bank 0 - FLASH + */ +#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BRx_BA_MSK) |\ + BRx_PS_8 |\ + BRx_MS_GPCM_P |\ + BRx_V) + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) |\ + ORxG_CSNT |\ + ORxG_ACS_DIV2 |\ + ORxG_SCY_5_CLK |\ + ORxG_TRLX) + +#define CONFIG_SYS_MPTPR 0x1800 + +/* + *----------------------------------------------------------------------------- + * Address for Mode Register Set (MRS) command + *----------------------------------------------------------------------------- + */ +#define CONFIG_SYS_MRS_OFFS 0x00000110 +#define CONFIG_SYS_PSRT 0x0e + +#define CONFIG_SYS_BR1_PRELIM ((CONFIG_SYS_SDRAM_BASE & BRx_BA_MSK) |\ + BRx_PS_64 |\ + BRx_MS_SDRAM_P |\ + BRx_V) + +#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR1 + +/* + * UPIO FPGA (GPIO/PIGGY) on CS3 initialization values + */ +#define CONFIG_SYS_KMBEC_FPGA_BASE 0x30000000 +#define CONFIG_SYS_KMBEC_FPGA_SIZE 128 + +#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_KMBEC_FPGA_BASE & BRx_BA_MSK) |\ + BRx_PS_8 | BRx_MS_GPCM_P | BRx_V) + +#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_KMBEC_FPGA_SIZE) |\ + ORxG_CSNT | ORxG_ACS_DIV2 |\ + ORxG_SCY_3_CLK | ORxG_TRLX) + +/* + * BFTICU board FPGA on CS4 initialization values + */ +#define CONFIG_SYS_FPGA_BASE 0x40000000 +#define CONFIG_SYS_FPGA_SIZE 1 /*1KB*/ + +#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_FPGA_BASE & BRx_BA_MSK) |\ + BRx_PS_8 | BRx_MS_GPCM_P | BRx_V) + +#define CONFIG_SYS_OR4_PRELIM (P2SZ_TO_AM(CONFIG_SYS_FPGA_SIZE << 10) |\ + ORxG_CSNT | ORxG_ACS_DIV2 |\ + ORxG_SCY_3_CLK | ORxG_TRLX) + +/* + * CFG-Flash on CS5 initialization values + */ +#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_FLASH_BASE_1 & BRx_BA_MSK) |\ + BRx_PS_16 | BRx_MS_GPCM_P | BRx_V) + +#define CONFIG_SYS_OR5_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE_1 + \ + CONFIG_SYS_FLASH_SIZE_2) |\ + ORxG_CSNT | ORxG_ACS_DIV2 |\ + ORxG_SCY_5_CLK | ORxG_TRLX) + +#define CONFIG_SYS_RESET_ADDRESS 0xFDFFFFFC /* "bad" address */ + +/* pass open firmware flat tree */ +#define CONFIG_FIT 1 +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc/cpm/serial@11a90"
In message 1343402200-32020-5-git-send-email-gerlando.falauto@keymile.com you wrote:
Please also try with -M -C and see if this changes anything.
In message1343402200-32020-5-git-send-email-gerlando.falauto@keymile.com you wrote:
For this one patch I can't get git to detect renames. I tried with git 1.7.1, 1.7.10.4, 1.7.11.3:
-> git commit --amend [xxx f9981ff] powerpc/82xx: move km/km82xx-common.h within km82xx.h 1 files changed, 124 insertions(+), 4 deletions(-) rename include/configs/{km/km82xx-common.h => km82xx.h} (75%)
Notice how git commit DOES detect the rename, but the following format-patch does NOT:
-> git format-patch -M -C --stdout -1 From f9981ff849562c9d466d9429e0ec9a510a0d4b3c Mon Sep 17 00:00:00 2001 From: Gerlando Falauto gerlando.falauto@keymile.com Date: Tue, 10 Jul 2012 18:13:27 +0200 Subject: [PATCH] ... ... --- include/configs/km/km82xx-common.h | 317 ------------------------------------ include/configs/km82xx.h | 290 ++++++++++++++++++++++++++++++++- 2 files changed, 289 insertions(+), 318 deletions(-) delete mode 100644 include/configs/km/km82xx-common.h ... #endif /* __CONFIG_H */
Dear Gerlando,
Neither can I. Thanks for trying, though.
On 07/30/2012 09:12 PM, Wolfgang Denk wrote:
Dear Gerlando,
It turns out you also need to use "-B", see an excellent thorough explanation at http://article.gmane.org/gmane.comp.version-control.git/202723
Even though this patch was already applied, I'm posting a "v2" version for whoever is curious to see a smaller patch. It won't make any difference on the repository, anyway.
Thanks, Gerlando
Applied, thanks.
This patch adds SDRAM detection feature to km82xx boards. To enable this feature, define CONFIG_SYS_SDRAM_LIST as the initializer for an array of struct sdram_conf_s. These structs will expose the bitfields within registers PSDMR and OR1 which have to be different between configurations; common bitfields will be defined, as usual, within CONFIG_SYS_PSDMR and CONFIG_SYS_OR1. If CONFIG_SYS_SDRAM_LIST is not defined, then the usual behavior is retained.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- board/keymile/km82xx/km82xx.c | 51 +++++++++++++++++++++++++++++++++++++++- 1 files changed, 49 insertions(+), 2 deletions(-)
diff --git a/board/keymile/km82xx/km82xx.c b/board/keymile/km82xx/km82xx.c index 0e50b0b..67b69f6 100644 --- a/board/keymile/km82xx/km82xx.c +++ b/board/keymile/km82xx/km82xx.c @@ -261,6 +261,54 @@ static long int try_init(memctl8260_t *memctl, ulong sdmr, return size; }
+#ifdef CONFIG_SYS_SDRAM_LIST + +/* + * If CONFIG_SYS_SDRAM_LIST is defined, we cycle through all SDRAM + * configurations therein (should be from high to lower) to find the + * one actually matching the current configuration. + * CONFIG_SYS_PSDMR and CONFIG_SYS_OR1 will contain the base values which are + * common among all possible configurations; values in CONFIG_SYS_SDRAM_LIST + * (defined as the initialization value for the array of struct sdram_conf_s) + * will then be ORed with such base values. + */ + +struct sdram_conf_s { + ulong size; + int or1; + int psdmr; +}; + +static struct sdram_conf_s sdram_conf[] = CONFIG_SYS_SDRAM_LIST; + +static long probe_sdram(memctl8260_t *memctl) +{ + int n = 0; + long psize = 0; + + for (n = 0; n < ARRAY_SIZE(sdram_conf); psize = 0, n++) { + psize = try_init(memctl, + CONFIG_SYS_PSDMR | sdram_conf[n].psdmr, + CONFIG_SYS_OR1 | sdram_conf[n].or1, + (uchar *) CONFIG_SYS_SDRAM_BASE); + debug("Probing %ld bytes returned %ld\n", + sdram_conf[n].size, psize); + if (psize == sdram_conf[n].size) + break; + } + return psize; +} + +#else /* CONFIG_SYS_SDRAM_LIST */ + +static long probe_sdram(memctl8260_t *memctl) +{ + return try_init(memctl, CONFIG_SYS_PSDMR, CONFIG_SYS_OR1, + (uchar *) CONFIG_SYS_SDRAM_BASE); +} +#endif /* CONFIG_SYS_SDRAM_LIST */ + + phys_size_t initdram(int board_type) { immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; @@ -274,8 +322,7 @@ phys_size_t initdram(int board_type) #ifndef CONFIG_SYS_RAMBOOT /* 60x SDRAM setup: */ - psize = try_init(memctl, CONFIG_SYS_PSDMR, CONFIG_SYS_OR1, - (uchar *) CONFIG_SYS_SDRAM_BASE); + psize = probe_sdram(memctl); #endif /* CONFIG_SYS_RAMBOOT */
icache_enable();
In message 1343402200-32020-6-git-send-email-gerlando.falauto@keymile.com you wrote:
Applied, thanks.
mgcoge2ne was an intermediate step towards mgcoge3ne. One difference is the smaller SDRAM on mgcoge2ne (128MB). To support both boards with the same u-boot we use here the SDRAM detection.
This patch enables SDRAM detection between 256MB and 128MB. So in addition to the existing 256MB geometry: 4 chips x 8M (13 rows, 10 cols) x 16 bit x 4 banks we can now also have 128MB geometry: 4 chips x 4M (13 rows, 9 cols) x 16 bit x 4 banks
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- include/configs/km82xx.h | 17 +++++++++++++---- 1 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/include/configs/km82xx.h b/include/configs/km82xx.h index 9bfb8df..f046337 100644 --- a/include/configs/km82xx.h +++ b/include/configs/km82xx.h @@ -119,7 +119,8 @@
/* * Bank 1 - 60x bus SDRAM - * mgcoge3ne has 256M. + * mgcoge3ne has 256MB + * mgcoge2ne has 128MB */ #define SDRAM_MAX_SIZE 0x10000000 /* max. 256 MB */ #define CONFIG_SYS_GLOBAL_SDRAM_LIMIT (512 << 20) /* less than 512 MB */ @@ -127,20 +128,28 @@ #define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ ORxS_SDAM_MSK) |\ ORxS_BPD_4 |\ - ORxS_ROWST_PBI1_A4 |\ ORxS_NUMR_13)
#define CONFIG_SYS_PSDMR ( \ PSDMR_PBI |\ - PSDMR_SDAM_A17_IS_A5 |\ PSDMR_BSMA_A13_A15 |\ - PSDMR_SDA10_PBI1_A6 |\ PSDMR_RFRC_5_CLK |\ PSDMR_PRETOACT_2W |\ PSDMR_ACTTORW_2W |\ PSDMR_LDOTOPRE_1C |\ PSDMR_WRC_2C |\ PSDMR_CL_2) + +#define CONFIG_SYS_SDRAM_LIST { \ + { .size = 256 << 20, \ + .or1 = ORxS_ROWST_PBI1_A4, \ + .psdmr = PSDMR_SDAM_A17_IS_A5 | PSDMR_SDA10_PBI1_A6, \ + }, \ + { .size = 128 << 20, \ + .or1 = ORxS_ROWST_PBI1_A5, \ + .psdmr = PSDMR_SDAM_A16_IS_A5 | PSDMR_SDA10_PBI1_A7, \ + }, \ +} #endif /* defined(CONFIG_MGCOGE3NE) */
In message 1343402200-32020-7-git-send-email-gerlando.falauto@keymile.com you wrote:
Applied, thanks.
The HW guys suggested to change these two values. And these values are now identical to the values we use on mgcoge.
PSDMR_WRC was set to 1C as it should lead to better performance.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com --- include/configs/km82xx.h | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/configs/km82xx.h b/include/configs/km82xx.h index f046337..3c2117f 100644 --- a/include/configs/km82xx.h +++ b/include/configs/km82xx.h @@ -128,16 +128,18 @@ #define CONFIG_SYS_OR1 ((~(CONFIG_SYS_GLOBAL_SDRAM_LIMIT-1) & \ ORxS_SDAM_MSK) |\ ORxS_BPD_4 |\ - ORxS_NUMR_13) + ORxS_NUMR_13 |\ + ORxS_IBID)
#define CONFIG_SYS_PSDMR ( \ PSDMR_PBI |\ + PSDMR_RFEN |\ PSDMR_BSMA_A13_A15 |\ PSDMR_RFRC_5_CLK |\ PSDMR_PRETOACT_2W |\ PSDMR_ACTTORW_2W |\ PSDMR_LDOTOPRE_1C |\ - PSDMR_WRC_2C |\ + PSDMR_WRC_1C |\ PSDMR_CL_2)
Dear Gerlando Falauto,
In message 1343402200-32020-8-git-send-email-gerlando.falauto@keymile.com you wrote:
Applied, thanks.
Gerlando Falauto
