[PATCH 2/2] board/km: add support for seli8 design based on nxp ls102x
The SELI8 design is a new tdm service unit card for Hitachi-Powergrids XMC and FOX product lines.
It is based on NXP LS1021 SoC and it provides following interfaces: - IFC interface for NOR, NAND and external FPGA's - 1 x RGMII ETH for debug purposes - 2 x SGMII ETH for management communication via back-plane - 1 x uQE HDLC for management communication via back-plane - 1 x I2C for peripheral devices - 1 x SPI for peripheral devices - 1 x UART for debug logging
It is foreseen that the design will be later re-used for another XMC and FOX service cards with similar SoC requirements.
Signed-off-by: Rainer Boschung rainer.boschung@hitachi-powergrids.com Signed-off-by: Matteo Ghidoni matteo.ghidoni@hitachi-powergrids.com Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com --- arch/arm/Kconfig | 19 ++ arch/arm/dts/Makefile | 2 + arch/arm/dts/ls1021a-pg-wcom-seli8.dts | 111 +++++++++ board/keymile/Kconfig | 23 +- board/keymile/common/ivm.c | 19 +- board/keymile/pg-wcom-ls102xa/Kconfig | 19 ++ board/keymile/pg-wcom-ls102xa/MAINTAINERS | 10 + board/keymile/pg-wcom-ls102xa/Makefile | 11 + board/keymile/pg-wcom-ls102xa/ddr.c | 91 ++++++++ board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c | 160 +++++++++++++ configs/pg_wcom_seli8_defconfig | 70 ++++++ include/configs/km/pg-wcom-ls102xa.h | 292 ++++++++++++++++++++++++ include/configs/pg-wcom-seli8.h | 45 ++++ 13 files changed, 861 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/ls1021a-pg-wcom-seli8.dts create mode 100644 board/keymile/pg-wcom-ls102xa/Kconfig create mode 100644 board/keymile/pg-wcom-ls102xa/MAINTAINERS create mode 100644 board/keymile/pg-wcom-ls102xa/Makefile create mode 100644 board/keymile/pg-wcom-ls102xa/ddr.c create mode 100644 board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c create mode 100644 configs/pg_wcom_seli8_defconfig create mode 100644 include/configs/km/pg-wcom-ls102xa.h create mode 100644 include/configs/pg-wcom-seli8.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d51abbe..cff8520 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1500,6 +1500,24 @@ config TARGET_LS1021ATWR select DM_SPI_FLASH if FSL_DSPI || FSL_QSPI imply SCSI
+config TARGET_PG_WCOM_SELI8 + bool "Support Hitachi-Powergrids SELI8 service unit card" + select ARCH_LS1021A + select ARCH_SUPPORT_PSCI + select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT + select CPU_V7A + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select SYS_FSL_DDR + select FSL_DDR_INTERACTIVE + select VENDOR_KM + imply SCSI + help + Support for Hitachi-Powergrids SELI8 service unit card. + SELI8 is a QorIQ LS1021a based service unit card used + in XMC20 and FOX615 product families. + config TARGET_LS1021ATSN bool "Support ls1021atsn" select ARCH_LS1021A @@ -2017,6 +2035,7 @@ source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" source "board/phytium/durian/Kconfig" source "board/xen/xenguest_arm64/Kconfig" +source "board/keymile/Kconfig"
source "arch/arm/Kconfig.debug"
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 33e483f..a15e2d3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -397,6 +397,8 @@ dtb-$(CONFIG_ARCH_LS1021A) += ls1021a-qds-duart.dtb \ ls1021a-qds-lpuart.dtb \ ls1021a-twr-duart.dtb ls1021a-twr-lpuart.dtb \ ls1021a-iot-duart.dtb ls1021a-tsn.dtb +dtb-$(CONFIG_TARGET_PG_WCOM_SELI8) += ls1021a-pg-wcom-seli8.dtb + dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-qds-42-x.dtb \ fsl-ls2080a-rdb.dtb \ diff --git a/arch/arm/dts/ls1021a-pg-wcom-seli8.dts b/arch/arm/dts/ls1021a-pg-wcom-seli8.dts new file mode 100644 index 0000000..e335188 --- /dev/null +++ b/arch/arm/dts/ls1021a-pg-wcom-seli8.dts @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * Copyright 2020 Hitachi Power Grids. All rights reserved. + */ + +/dts-v1/; +#include "ls1021a.dtsi" + +/ { + model = "Hitachi-Powergrids SELI8 Service Unit for XMC and FOX"; + + chosen { + stdout-path = &uart0; + }; +}; + +&enet0 { + status = "okay"; + tbi-handle = <&tbi0>; + phy-connection-type = "sgmii"; + fixed-link { + speed = <1000>; + full-duplex; + }; +}; + +&enet1 { + status = "okay"; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + fixed-link { + speed = <1000>; + full-duplex; + }; +}; + +&enet2 { + phy-handle = <&debug_phy>; + phy-connection-type = "rgmii-id"; + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; + +&ifc { + #address-cells = <2>; + #size-cells = <1>; + /* NOR Flash on board */ + ranges = <0x0 0x0 0x60000000 0x04000000>; + status = "okay"; + + nor@0,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "cfi-flash"; + reg = <0x0 0x0 0x4000000>; + bank-width = <2>; + device-width = <1>; + + partition@0 { + label = "rcw"; + reg = <0x0 0x20000>; + read-only; + }; + partition@20000 { + label = "qe"; + reg = <0x20000 0x20000>; + }; + partition@40000 { + label = "envred"; + reg = <0x40000 0x20000>; + }; + partition@60000 { + label = "env"; + reg = <0x60000 0x20000>; + }; + partition@100000 { + label = "u-boot"; + reg = <0x100000 0x100000>; + }; + partition@200000 { + label = "ubi0"; + reg = <0x200000 0x3E00000>; + }; + }; +}; + +&mdio0 { + debug_phy: ethernet-phy@11 { + reg = <0x11>; + }; + + tbi0: tbi-phy@0xb { + reg = <0xb>; + device_type = "tbi-phy"; + }; +}; + +&mdio1 { + tbi1: tbi-phy@0xd { + reg = <0xd>; + device_type = "tbi-phy"; + }; +}; + +&uart0 { + status = "okay"; +}; diff --git a/board/keymile/Kconfig b/board/keymile/Kconfig index 6b7377c..86a6670 100644 --- a/board/keymile/Kconfig +++ b/board/keymile/Kconfig @@ -20,8 +20,8 @@ config KM_PNVRAM
config KM_PHRAM hex "Physical RAM" - default 0x17F000 if ARM - default 0x100000 if PPC + default 0x17F000 if ARM && !ARCH_LS1021A + default 0x100000 if PPC || ARCH_LS1021A depends on !ARCH_SOCFPGA help Start address of the physical RAM, which is the mounted /var folder. @@ -30,13 +30,14 @@ config KM_RESERVED_PRAM hex "Reserved RAM" default 0x801000 if ARCH_KIRKWOOD default 0x0 if MPC83xx - default 0x1000 if MPC85xx + default 0x1000 if MPC85xx || ARCH_LS1021A depends on !ARCH_SOCFPGA help Reserved physical RAM area at the end of memory for special purposes.
config KM_CRAMFS_ADDR hex "CRAMFS Address" + default 0x83000000 if ARCH_LS1021A default 0x3000000 depends on !ARCH_SOCFPGA help @@ -44,16 +45,25 @@ config KM_CRAMFS_ADDR
config KM_KERNEL_ADDR hex "Kernel Load Address" + default 0x82000000 if ARCH_LS1021A default 0x2000000 help Address where to load Linux kernel in RAM.
config KM_FDT_ADDR hex "FDT Load Address" + default 0x82FC0000 if ARCH_LS1021A default 0x2FC0000 help Address where to load flattened device tree in RAM.
+config SYS_PAX_BASE + hex "PAX IFC Base Address" + default 0x78000000 + depends on ARCH_LS1021A + help + IFC Base Address for PAXx FPGA. + config KM_CONSOLE_TTY string "KM Console" default "ttyS0" @@ -69,9 +79,9 @@ config KM_DEF_NETDEV config KM_COMMON_ETH_INIT bool "Common Ethernet Initialization" default y if ARCH_KIRKWOOD || MPC83xx - default n if MPC85xx || ARCH_SOCFPGA + default n if MPC85xx || ARCH_SOCFPGA || ARCH_LS1021A help - Use the Ethernet initialization implemented in common code, which + Use the Ethernet initialization implemented in common code that detects if a Piggy board is present.
config PIGGY_MAC_ADDRESS_OFFSET @@ -90,7 +100,7 @@ config KM_MVEXTSW_ADDR config KM_IVM_BUS int "IVM I2C Bus" default 0 if ARCH_SOCFPGA - default 1 if ARCH_KIRKWOOD || MPC85xx + default 1 if ARCH_KIRKWOOD || MPC85xx || ARCH_LS1021A default 2 if MPC83xx help Identifier number of I2C bus, where the inventory EEPROM is connected to. @@ -117,6 +127,7 @@ source "board/keymile/km83xx/Kconfig" source "board/keymile/kmcent2/Kconfig" source "board/keymile/kmp204x/Kconfig" source "board/keymile/km_arm/Kconfig" +source "board/keymile/pg-wcom-ls102xa/Kconfig"
endmenu
diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index 9a3a856..14c70b9 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -306,11 +306,7 @@ static int ivm_populate_env(unsigned char *buf, int len, int mac_address_offset) return 0; page2 = &buf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN * 2];
- if (!IS_ENABLED(CONFIG_KMTEGR1)) { - /* if an offset is defined, add it */ - process_mac(valbuf, page2, mac_address_offset, true); - env_set((char *)"ethaddr", (char *)valbuf); - } else { + if (IS_ENABLED(CONFIG_KMTEGR1)) { /* KMTEGR1 has a special setup. eth0 has no connection to the * outside and gets an locally administred MAC address, eth1 is * the debug interface and gets the official MAC address from @@ -320,6 +316,19 @@ static int ivm_populate_env(unsigned char *buf, int len, int mac_address_offset) env_set((char *)"ethaddr", (char *)valbuf); process_mac(valbuf, page2, mac_address_offset, true); env_set((char *)"eth1addr", (char *)valbuf); + } else if (IS_ENABLED(CONFIG_ARCH_LS1021A)) { + /* LS102xA has 1xRGMII for debug connection and + * 2xSGMII for back-plane mgmt connection + */ + process_mac(valbuf, page2, 1, true); + env_set((char *)"ethaddr", (char *)valbuf); + process_mac(valbuf, page2, 2, true); + env_set((char *)"eth1addr", (char *)valbuf); + process_mac(valbuf, page2, mac_address_offset, true); + env_set((char *)"eth2addr", (char *)valbuf); + } else { + process_mac(valbuf, page2, mac_address_offset, true); + env_set((char *)"ethaddr", (char *)valbuf); } if (IS_ENABLED(CONFIG_TARGET_KMCENT2)) { /* 3rd ethernet interface */ diff --git a/board/keymile/pg-wcom-ls102xa/Kconfig b/board/keymile/pg-wcom-ls102xa/Kconfig new file mode 100644 index 0000000..15c009d --- /dev/null +++ b/board/keymile/pg-wcom-ls102xa/Kconfig @@ -0,0 +1,19 @@ +if TARGET_PG_WCOM_SELI8 + +config SYS_BOARD + default "pg-wcom-ls102xa" + +config SYS_VENDOR + default "keymile" + +config SYS_SOC + default "ls102xa" + +config SYS_CONFIG_NAME + default "pg-wcom-seli8" + +config BOARD_SPECIFIC_OPTIONS + def_bool y + imply FS_CRAMFS + +endif diff --git a/board/keymile/pg-wcom-ls102xa/MAINTAINERS b/board/keymile/pg-wcom-ls102xa/MAINTAINERS new file mode 100644 index 0000000..e1bc90a --- /dev/null +++ b/board/keymile/pg-wcom-ls102xa/MAINTAINERS @@ -0,0 +1,10 @@ +Hitachi Power Grids LS102XA BOARD +M: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com +M: Rainer Boschung rainer.boschung@hitachi-powergrids.com +M: Matteo Ghidoni matteo.ghidoni@hitachi-powergrids.com +S: Maintained +F: board/keymile/pg-wcom-ls102xa/ +F: include/configs/km/pg-wcom-ls102xa.h +F: include/configs/pg-wcom-seli8.h +F: configs/pg_wcom_seli8_defconfig +F: arch/arm/dts/ls1021a-pg-wcom-seli8.dts diff --git a/board/keymile/pg-wcom-ls102xa/Makefile b/board/keymile/pg-wcom-ls102xa/Makefile new file mode 100644 index 0000000..229b0c2 --- /dev/null +++ b/board/keymile/pg-wcom-ls102xa/Makefile @@ -0,0 +1,11 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2021 Hitachi Power Grids. All rights reserved. +# + +obj-y += pg-wcom-ls102xa.o ddr.o +obj-y += ../common/common.o ../common/ivm.o ../common/qrio.o +obj-$(CONFIG_LAYERSCAPE_NS_ACCESS) += ../../freescale/common/ns_access.o +obj-$(CONFIG_LS102XA_STREAM_ID) += ../../freescale/common/ls102xa_stream_id.o +obj-$(CONFIG_ID_EEPROM) += ../../freescale/common/sys_eeprom.o diff --git a/board/keymile/pg-wcom-ls102xa/ddr.c b/board/keymile/pg-wcom-ls102xa/ddr.c new file mode 100644 index 0000000..4ec60f1 --- /dev/null +++ b/board/keymile/pg-wcom-ls102xa/ddr.c @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2020 Hitachi Power Grids. All rights reserved. + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/global_data.h> +#include <asm/arch/ls102xa_soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + + // 1/2 DRAM cycle (should be increased in case of ADDR/CMD heavily loaded than the clock) + popts->clk_adjust = 0x4; + popts->write_data_delay = 0x4; + // wr leveling start value for lane 0 + popts->wrlvl_start = 0x5; + // wr leveling start values for lanes 1-3 (lane 4 not there) + popts->wrlvl_ctl_2 = 0x05050500; + // 32-bit DRAM, no need to set start values for lanes we do not have (5-8) + popts->wrlvl_ctl_3 = 0x0; + popts->cpo_override = 0x1f; + + /* force DDR bus width to 32 bits */ + popts->data_bus_width = 1; + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 1; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + popts->cswl_override = DDR_CSWL_CS0; + + /* optimize cpo for erratum A-009942 */ + popts->cpo_sample = 0x58; + + /* DHC_EN =1, ODT = 75 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +} + +int fsl_initdram(void) +{ + phys_size_t dram_size; + + puts("Initializing DDR....using SPD\n"); + dram_size = fsl_ddr_sdram(); + + erratum_a008850_post(); + + gd->ram_size = dram_size; + + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} diff --git a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c new file mode 100644 index 0000000..6b0e963 --- /dev/null +++ b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c @@ -0,0 +1,160 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Hitachi Power Grids. All rights reserved. + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/immap_ls102xa.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/ls102xa_devdis.h> +#include <asm/arch/ls102xa_soc.h> +#include <hwconfig.h> +#include <mmc.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include <fsl_immap.h> +#include <netdev.h> +#include <fsl_mdio.h> +#include <tsec.h> +#include <fsl_sec.h> +#include <fsl_devdis.h> +#include <fsl_ddr.h> +#include <spl.h> +#include <fdt_support.h> +#include <fsl_qe.h> +#include <fsl_validate.h> + +#include "../common/common.h" +#include "../common/qrio.h" + +DECLARE_GLOBAL_DATA_PTR; + +static uchar ivm_content[CONFIG_SYS_IVM_EEPROM_MAX_LEN]; + +int checkboard(void) +{ + show_qrio(); + + return 0; +} + +int dram_init(void) +{ + return fsl_initdram(); +} + +int board_early_init_f(void) +{ + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + struct fsl_ifc ifc = {(void *)CONFIG_SYS_IFC_ADDR, (void *)NULL}; + + /* Disable unused MCK1 */ + setbits_be32(&gur->ddrclkdr, 2); + + /* IFC Global Configuration */ + setbits_be32(&ifc.gregs->ifc_gcr, 12 << IFC_GCR_TBCTL_TRN_TIME_SHIFT); + setbits_be32(&ifc.gregs->ifc_ccr, IFC_CCR_CLK_DIV(3) | + IFC_CCR_INV_CLK_EN); + + /* clear BD & FR bits for BE BD's and frame data */ + clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); + out_be32(&scfg->etsecmcr, SCFG_ETSECCMCR_GE2_CLK125); + + init_early_memctl_regs(); + + /* QRIO Configuration */ + qrio_uprstreq(UPREQ_CORE_RST); + + if (IS_ENABLED(CONFIG_TARGET_PG_WCOM_SELI8)) { + qrio_prstcfg(KM_LIU_RST, PRSTCFG_POWUP_UNIT_RST); + qrio_wdmask(KM_LIU_RST, true); + + qrio_prstcfg(KM_PAXK_RST, PRSTCFG_POWUP_UNIT_RST); + qrio_wdmask(KM_PAXK_RST, true); + + qrio_prstcfg(KM_DBG_ETH_RST, PRSTCFG_POWUP_UNIT_CORE_RST); + qrio_prst(KM_DBG_ETH_RST, false, false); + } + + i2c_deblock_gpio_cfg(); + + arch_soc_init(); + + return 0; +} + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_A010315)) + erratum_a010315(); + + fsl_serdes_init(); + + ls102xa_smmu_stream_id_init(); + + u_qe_init(); + + return 0; +} + +int board_late_init(void) +{ + return 0; +} + +int misc_init_r(void) +{ + if (IS_ENABLED(CONFIG_FSL_DEVICE_DISABLE)) + device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); + + ivm_read_eeprom(ivm_content, CONFIG_SYS_IVM_EEPROM_MAX_LEN, + CONFIG_PIGGY_MAC_ADDRESS_OFFSET); + + return 0; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + ft_cpu_setup(blob, bd); + + if (IS_ENABLED(CONFIG_PCI)) + ft_pci_setup(blob, bd); + + return 0; +} + +u8 flash_read8(void *addr) +{ + return __raw_readb(addr + 1); +} + +void flash_write16(u16 val, void *addr) +{ + u16 shftval = (((val >> 8) & 0xff) | ((val << 8) & 0xff00)); + + __raw_writew(shftval, addr); +} + +u16 flash_read16(void *addr) +{ + u16 val = __raw_readw(addr); + + return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); +} + +int hush_init_var(void) +{ + ivm_analyze_eeprom(ivm_content, CONFIG_SYS_IVM_EEPROM_MAX_LEN); + return 0; +} + +int last_stage_init(void) +{ + set_km_env(); + return 0; +} diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig new file mode 100644 index 0000000..7d1a28a --- /dev/null +++ b/configs/pg_wcom_seli8_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_TARGET_PG_WCOM_SELI8=y +CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_KM_DEF_NETDEV="eth2" +CONFIG_KM_COMMON_ETH_INIT=y +CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x9fffffff +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +CONFIG_SYS_BOOTCOUNT_ADDR=0x70000020 +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-pg-wcom-seli8" +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0" +CONFIG_SILENT_CONSOLE=y +CONFIG_MISC_INIT_R=y +CONFIG_LAST_STAGE_INIT=y +CONFIG_CMD_IMLS=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y +CONFIG_CMD_CRAMFS=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=60000000.nor,nand0=68000000.flash" +CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:128k(rcw),128k(qe),128k(envred),128k(env),512k(res),1m(u-boot),-(ubi0);68000000.flash:-(ubi1)" +CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_ADDR=0x60060000 +CONFIG_ENV_ADDR_REDUND=0x60040000 +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_SYS_FSL_DDR3=y +# CONFIG_MMC is not set +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_FLASH_CFI_MTD=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_MTD_RAW_NAND=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_PHY_GIGE=y +CONFIG_MII=y +CONFIG_TSEC_ENET=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h new file mode 100644 index 0000000..3d7519c --- /dev/null +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -0,0 +1,292 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Hitachi Power Grids. All rights reserved. + */ + +#ifndef __CONFIG_PG_WCOM_LS102XA_H +#define __CONFIG_PG_WCOM_LS102XA_H + +#define CONFIG_SYS_FSL_CLK + +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* include common defines/options for all Keymile boards */ +#include "keymile-common.h" + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 16 * 1024 * 1024) + +#define CONFIG_SYS_INIT_RAM_ADDR OCRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE + +#define CONFIG_SYS_CLK_FREQ 66666666 +/* + * Take into account default implementation where DDR_FDBK_MULTI is consider as + * configured for DDR_PLL = 2*MEM_PLL_RAT. + * In our case DDR_FDBK_MULTI is 2, means DDR_PLL = MEM_PLL_RAT. + */ +#define CONFIG_DDR_CLK_FREQ (100000000 >> 1) + +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) + +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#define CONFIG_DDR_SPD + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x54 + +/* + * IFC Definitions + */ +/* NOR Flash Definitions */ +#define CONFIG_FSL_IFC +#define CONFIG_SYS_FLASH_BASE 0x60000000 +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE + +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_TE | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(64 * 1024 * 1024) + +#define CONFIG_SYS_NOR_CSOR (CSOR_NOR_AVD_TGL_PGM_EN | \ + CSOR_NOR_ADM_SHIFT(0x4) | \ + CSOR_NOR_NOR_MODE_ASYNC_NOR | \ + CSOR_NOR_TRHZ_20 | \ + CSOR_NOR_BCTLD) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x7) | \ + FTIM0_NOR_TAVDS(0x0) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x21) | \ + FTIM1_NOR_TSEQRAD_NOR(0x21)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x1) | \ + FTIM2_NOR_TCH(0x1) | \ + FTIM2_NOR_TWPH(0x6) | \ + FTIM2_NOR_TWP(0xb)) +#define CONFIG_SYS_NOR_FTIM3 0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS } + +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_SYS_WRITE_SWAPPED_DATA + +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 + +/* NAND Flash Definitions */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0x68000000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_TE | \ + CSPR_MSEL_NAND | \ + CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN \ + | CSOR_NAND_ECC_DEC_EN \ + | CSOR_NAND_ECC_MODE_4 \ + | CSOR_NAND_RAL_3 \ + | CSOR_NAND_PGS_2K \ + | CSOR_NAND_SPRZ_64 \ + | CSOR_NAND_PB(64) \ + | CSOR_NAND_TRHZ_40 \ + | CSOR_NAND_BCTLD) + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x3) | \ + FTIM0_NAND_TWP(0x8) | \ + FTIM0_NAND_TWCHT(0x3) | \ + FTIM0_NAND_TWH(0x5)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x1e) | \ + FTIM1_NAND_TWBE(0x1e) | \ + FTIM1_NAND_TRR(0x6) | \ + FTIM1_NAND_TRP(0x8)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x9) | \ + FTIM2_NAND_TREH(0x5) | \ + FTIM2_NAND_TWHRE(0x3c)) +#define CONFIG_SYS_NAND_FTIM3 (FTIM3_NAND_TWW(0x1e)) + +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* QRIO FPGA Definitions */ +#define CONFIG_SYS_QRIO_BASE 0x70000000 +#define CONFIG_SYS_QRIO_BASE_PHYS CONFIG_SYS_QRIO_BASE + +#define CONFIG_SYS_CSPR2_EXT (0x00) +#define CONFIG_SYS_CSPR2 (CSPR_PHYS_ADDR(CONFIG_SYS_QRIO_BASE) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_TE | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_AMASK2 IFC_AMASK(64 * 1024) +#define CONFIG_SYS_CSOR2 (CSOR_GPCM_ADM_SHIFT(0x4) | \ + CSOR_GPCM_TRHZ_20 | \ + CSOR_GPCM_BCTLD) +#define CONFIG_SYS_CS2_FTIM0 (FTIM0_GPCM_TACSE(0x2) | \ + FTIM0_GPCM_TEADC(0x8) | \ + FTIM0_GPCM_TEAHC(0x2)) +#define CONFIG_SYS_CS2_FTIM1 (FTIM1_GPCM_TACO(0x2) | \ + FTIM1_GPCM_TRAD(0x6)) +#define CONFIG_SYS_CS2_FTIM2 (FTIM2_GPCM_TCS(0x1) | \ + FTIM2_GPCM_TCH(0x1) | \ + FTIM2_GPCM_TWP(0x7)) +#define CONFIG_SYS_CS2_FTIM3 0x04000000 + +/* + * Serial Port + */ +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_CLK get_serial_clock() + +/* + * I2C + */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_MAX_HOPS 1 +#define CONFIG_SYS_NUM_I2C_BUSES 3 +#define I2C_MUX_PCA_ADDR 0x70 +#define I2C_MUX_CH_DEFAULT 0x0 +#define CONFIG_SYS_I2C_BUSES { {0, {I2C_NULL_HOP} }, \ + {0, {{I2C_MUX_PCA9547, 0x70, 1 } } }, \ + {1, {I2C_NULL_HOP} }, \ + } + +/* + * eTSEC + */ +#ifdef CONFIG_TSEC_ENET +#define CONFIG_ETHPRIME "ethernet@2d90000" +#endif + +#define CONFIG_LAYERSCAPE_NS_ACCESS +#define CONFIG_SMP_PEN_ADDR 0x01ee0200 +#define COUNTER_FREQUENCY 12500000 + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 256 +#define CONFIG_FSL_DEVICE_DISABLE + +/* + * Miscellaneous configurable options + */ + +#define CONFIG_SYS_LOAD_ADDR 0x82000000 + +#define CONFIG_LS102XA_STREAM_ID + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_MONITOR_LEN 0x100000 /* 1Mbyte */ +#define CONFIG_SYS_QE_FW_ADDR 0x60020000 + +#define CONFIG_SYS_BOOTCOUNT_BE + +/* + * Environment + */ + +#define CONFIG_ENV_TOTAL_SIZE 0x40000 +#define ENV_DEL_ADDR CONFIG_ENV_ADDR_REDUND /* direct for newenv */ + +#ifndef CONFIG_KM_DEF_ENV /* if not set by keymile-common.h */ +#define CONFIG_KM_DEF_ENV +#endif + +#ifndef CONFIG_KM_DEF_BOOT_ARGS_CPU +#define CONFIG_KM_DEF_BOOT_ARGS_CPU "" +#endif + +#define CONFIG_KM_DEF_ENV_CPU \ + "boot=bootm ${load_addr_r} - ${fdt_addr_r}\0" \ + "cramfsloadfdt=" \ + "cramfsload ${fdt_addr_r} " \ + "fdt_0x${IVM_BoardId}_0x${IVM_HWKey}.dtb\0" \ + "u-boot=" CONFIG_HOSTNAME "/u-boot.bin\0" \ + "update=protect off " __stringify(CONFIG_SYS_MONITOR_BASE) \ + " +${filesize} && " \ + "erase " __stringify(CONFIG_SYS_MONITOR_BASE) \ + " +${filesize} && " \ + "cp.b ${load_addr_r} " \ + __stringify(CONFIG_SYS_MONITOR_BASE) " ${filesize} && " \ + "protect on " __stringify(CONFIG_SYS_MONITOR_BASE) \ + " +${filesize}\0" \ + "update-nor=protect off " __stringify(CONFIG_SYS_FLASH_BASE) \ + " +${filesize} && " \ + "erase " __stringify(CONFIG_SYS_FLASH_BASE) \ + " +${filesize} && " \ + "cp.b ${load_addr_r} " \ + __stringify(CONFIG_SYS_FLASH_BASE) " ${filesize} && " \ + "protect on " __stringify(CONFIG_SYS_MONITOR_BASE) \ + " +" __stringify(CONFIG_SYS_MONITOR_LEN)"\0" \ + "set_fdthigh=true\0" \ + "checkfdt=true\0" \ + "" + +#define CONFIG_KM_NEW_ENV \ + "newenv=protect off " __stringify(ENV_DEL_ADDR) \ + " +" __stringify(CONFIG_ENV_TOTAL_SIZE) " && " \ + "erase " __stringify(ENV_DEL_ADDR) \ + " +" __stringify(CONFIG_ENV_TOTAL_SIZE) " && " \ + "protect on " __stringify(ENV_DEL_ADDR) \ + " +" __stringify(CONFIG_ENV_TOTAL_SIZE) "\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_KM_NEW_ENV \ + CONFIG_KM_DEF_ENV \ + "EEprom_ivm=pca9547:70:9\0" \ + "" + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Increase map for Linux */ + +#endif diff --git a/include/configs/pg-wcom-seli8.h b/include/configs/pg-wcom-seli8.h new file mode 100644 index 0000000..9a7669c --- /dev/null +++ b/include/configs/pg-wcom-seli8.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Hitachi Power Grids. All rights reserved. + */ + +#ifndef __CONFIG_PG_WCOM_SELI8_H +#define __CONFIG_PG_WCOM_SELI8_H + +#define CONFIG_HOSTNAME "SELI8" + +#define CONFIG_KM_UBI_PARTITION_NAME_BOOT "ubi0" +#define CONFIG_KM_UBI_PARTITION_NAME_APP "ubi1" + +/* PAXK FPGA Definitions */ +#define CONFIG_SYS_CSPR3_EXT (0x00) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(CONFIG_SYS_PAX_BASE) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(64 * 1024) +#define CONFIG_SYS_CSOR3 (CSOR_GPCM_ADM_SHIFT(0x4) | \ + CSOR_GPCM_TRHZ_40) +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x6) | \ + FTIM0_GPCM_TEADC(0x7) | \ + FTIM0_GPCM_TEAHC(0x2)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0x2) | \ + FTIM1_GPCM_TRAD(0x12)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x3) | \ + FTIM2_GPCM_TCH(0x1) | \ + FTIM2_GPCM_TWP(0x12)) +#define CONFIG_SYS_CS3_FTIM3 0x04000000 + +/* PRST */ +#define KM_LIU_RST 0 +#define KM_PAXK_RST 1 +#define KM_DBG_ETH_RST 15 + +/* QRIO GPIOs used for deblocking */ +#define KM_I2C_DEBLOCK_PORT QRIO_GPIO_A +#define KM_I2C_DEBLOCK_SCL 20 +#define KM_I2C_DEBLOCK_SDA 21 + +#include "km/pg-wcom-ls102xa.h" + +#endif /* __CONFIG_PG_WCOM_SELI8_H */
