[PATCH v3 1/3] configs: rockchip: reduce diff for rk3308, rk3328, rk3399, rk3568, and rk3588
this is cosmetic change. no functional change is intended.
- remove redundant white spaces - replace white spaces with tab - align position of last letter/word - sort lines in CFG_EXTRA_ENV_SETTINGS - add comment after #endif
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v3: - add missing separator in commit message - collect R-b tag Changes in v2: - rewrite whole commit message --- include/configs/rk3308_common.h | 26 ++++++++++----------- include/configs/rk3328_common.h | 28 +++++++++++------------ include/configs/rk3399_common.h | 40 ++++++++++++++++----------------- include/configs/rk3568_common.h | 14 ++++++------ include/configs/rk3588_common.h | 12 +++++----- 5 files changed, 60 insertions(+), 60 deletions(-)
diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 861154fbeb..80113220e4 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -8,24 +8,24 @@
#include "rockchip-common.h"
-#define CFG_IRAM_BASE 0xfff80000 +#define CFG_IRAM_BASE 0xfff80000
#define CFG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000
-#define ENV_MEM_LAYOUT_SETTINGS \ - "scriptaddr=0x00500000\0" \ - "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x03e00000\0" \ - "fdtoverlay_addr_r=0x03f00000\0" \ - "kernel_addr_r=0x00680000\0" \ +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00500000\0" \ + "pxefile_addr_r=0x00600000\0" \ + "fdt_addr_r=0x03e00000\0" \ + "fdtoverlay_addr_r=0x03f00000\0" \ + "kernel_addr_r=0x00680000\0" \ "ramdisk_addr_r=0x04000000\0"
-#define CFG_EXTRA_ENV_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - ENV_MEM_LAYOUT_SETTINGS \ - "partitions=" PARTS_DEFAULT \ - ROCKCHIP_DEVICE_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
-#endif +#endif /* __CONFIG_RK3308_COMMON_H */ diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 2c40674b22..f9e6634c5f 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -8,25 +8,25 @@
-#define CFG_IRAM_BASE 0xff090000 +#define CFG_IRAM_BASE 0xff090000
-#define ENV_MEM_LAYOUT_SETTINGS \ - "scriptaddr=0x00500000\0" \ - "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01f00000\0" \ - "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x06000000\0" \ - "kernel_comp_addr_r=0x08000000\0" \ +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00500000\0" \ + "pxefile_addr_r=0x00600000\0" \ + "fdt_addr_r=0x01f00000\0" \ + "kernel_addr_r=0x02080000\0" \ + "ramdisk_addr_r=0x06000000\0" \ + "kernel_comp_addr_r=0x08000000\0" \ "kernel_comp_size=0x2000000\0"
-#define CFG_EXTRA_ENV_SETTINGS \ - ENV_MEM_LAYOUT_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "partitions=" PARTS_DEFAULT \ - ROCKCHIP_DEVICE_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
-#endif +#endif /* __CONFIG_RK3328_COMMON_H */ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 4e75771055..62007c8b27 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -8,36 +8,36 @@
-#define CFG_IRAM_BASE 0xff8c0000 +#define CFG_IRAM_BASE 0xff8c0000
#define CFG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf8000000
#ifndef CONFIG_SPL_BUILD
-#define ENV_MEM_LAYOUT_SETTINGS \ - "scriptaddr=0x00500000\0" \ - "script_offset_f=0xffe000\0" \ - "script_size_f=0x2000\0" \ - "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01f00000\0" \ - "fdtoverlay_addr_r=0x02000000\0" \ - "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x06000000\0" \ - "kernel_comp_addr_r=0x08000000\0" \ - "kernel_comp_size=0x2000000\0" - #ifndef ROCKCHIP_DEVICE_SETTINGS #define ROCKCHIP_DEVICE_SETTINGS #endif
-#define CFG_EXTRA_ENV_SETTINGS \ - ENV_MEM_LAYOUT_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "partitions=" PARTS_DEFAULT \ - ROCKCHIP_DEVICE_SETTINGS \ +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00500000\0" \ + "script_offset_f=0xffe000\0" \ + "script_size_f=0x2000\0" \ + "pxefile_addr_r=0x00600000\0" \ + "fdt_addr_r=0x01f00000\0" \ + "fdtoverlay_addr_r=0x02000000\0" \ + "kernel_addr_r=0x02080000\0" \ + "ramdisk_addr_r=0x06000000\0" \ + "kernel_comp_addr_r=0x08000000\0" \ + "kernel_comp_size=0x2000000\0" + +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
-#endif +#endif /* CONFIG_SPL_BUILD */
-#endif +#endif /* __CONFIG_RK3399_COMMON_H */ diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index 48f93083de..09b7b71c6a 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0+ */ /* * (C) Copyright 2021 Rockchip Electronics Co., Ltd */ @@ -10,7 +10,7 @@
-#define CFG_IRAM_BASE 0xfdcc0000 +#define CFG_IRAM_BASE 0xfdcc0000
#define CFG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf0000000 @@ -28,10 +28,10 @@ "kernel_comp_size=0x8000000\0"
#define CFG_EXTRA_ENV_SETTINGS \ - ENV_MEM_LAYOUT_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "partitions=" PARTS_DEFAULT \ - ROCKCHIP_DEVICE_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
-#endif +#endif /* __CONFIG_RK3568_COMMON_H */ diff --git a/include/configs/rk3588_common.h b/include/configs/rk3588_common.h index 70430612ef..e6654c275a 100644 --- a/include/configs/rk3588_common.h +++ b/include/configs/rk3588_common.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0+ */ /* * (C) Copyright 2021 Rockchip Electronics Co., Ltd * Copyright (c) 2023 Edgeble AI Technologies Pvt. Ltd. @@ -26,11 +26,11 @@ "ramdisk_addr_r=0x12180000\0" \ "kernel_comp_size=0x8000000\0"
-#define CFG_EXTRA_ENV_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "partitions=" PARTS_DEFAULT \ - ENV_MEM_LAYOUT_SETTINGS \ - ROCKCHIP_DEVICE_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
#endif /* __CONFIG_RK3588_COMMON_H */
- add support for compressed kernel for rk3308 - prepare support for fdtoverlay for rk3328
tested on ROCK Pi S 256MB, ROCK Pi E 2GB, and ROCK Pi 4A 4GB with linux-next-20240613 defconfig kernel.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v3: - add missing separator in commit message - collect R-b tag Changes in v2: - minor cosmetic change in commit message --- include/configs/rk3308_common.h | 12 ++++++++---- include/configs/rk3328_common.h | 5 ++++- include/configs/rk3399_common.h | 4 ++-- 3 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 80113220e4..2de55538fd 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -15,11 +15,15 @@
#define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ + "script_offset_f=0xffe000\0" \ + "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x03e00000\0" \ - "fdtoverlay_addr_r=0x03f00000\0" \ - "kernel_addr_r=0x00680000\0" \ - "ramdisk_addr_r=0x04000000\0" + "fdt_addr_r=0x01e00000\0" \ + "fdtoverlay_addr_r=0x01f00000\0" \ + "kernel_addr_r=0x02080000\0" \ + "ramdisk_addr_r=0x06000000\0" \ + "kernel_comp_addr_r=0x08000000\0" \ + "kernel_comp_size=0x2000000\0"
#define CFG_EXTRA_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index f9e6634c5f..bd2bfe2910 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -15,8 +15,11 @@
#define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ + "script_offset_f=0xffe000\0" \ + "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01f00000\0" \ + "fdt_addr_r=0x01e00000\0" \ + "fdtoverlay_addr_r=0x01f00000\0" \ "kernel_addr_r=0x02080000\0" \ "ramdisk_addr_r=0x06000000\0" \ "kernel_comp_addr_r=0x08000000\0" \ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 62007c8b27..d652ae4ca3 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -24,8 +24,8 @@ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01f00000\0" \ - "fdtoverlay_addr_r=0x02000000\0" \ + "fdt_addr_r=0x01e00000\0" \ + "fdtoverlay_addr_r=0x01f00000\0" \ "kernel_addr_r=0x02080000\0" \ "ramdisk_addr_r=0x06000000\0" \ "kernel_comp_addr_r=0x08000000\0" \
for rk3308, all defconfigs have CONFIG_OF_LIBFDT_OVERLAY=y, so enable it by default.
for rk3328, any defconfig doesn't have it. but there is no strong reason not to enable it. at least it's required for ROCK Pi E.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- Changes in v3: - add missing separator in commit message Changes in v2: - none --- arch/arm/mach-rockchip/Kconfig | 2 ++ configs/evb-rk3308_defconfig | 1 - configs/roc-cc-rk3308_defconfig | 1 - configs/rock-pi-s-rk3308_defconfig | 1 - 4 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 661e7fd1c9..5f6a4dd24a 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -166,6 +166,7 @@ config ROCKCHIP_RK3308 imply LEGACY_IMAGE_FORMAT imply MISC imply MISC_INIT_R + imply OF_LIBFDT_OVERLAY imply OF_UPSTREAM imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD @@ -196,6 +197,7 @@ config ROCKCHIP_RK3328 imply ARMV8_SET_SMPEN imply MISC imply MISC_INIT_R + imply OF_LIBFDT_OVERLAY imply OF_LIVE imply OF_UPSTREAM imply PRE_CONSOLE_BUFFER diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index f4c2ea12ad..6d090dba30 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -3,7 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-evb" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_EVB_RK3308=y diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index 862ea4301f..b1b59d9cb5 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -4,7 +4,6 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-roc-cc" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_ROC_RK3308_CC=y diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index c15ba3d8a4..e450a06180 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -3,7 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-rock-pi-s" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_EVB_RK3308=y
I wonder if it makes sense to eventually move it up to ARCH_ROCKCHIP?
ChenYu
Changes in v3:
Changes in v2:
- none
diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index f4c2ea12ad..6d090dba30 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -3,7 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-evb" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_EVB_RK3308=y diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index 862ea4301f..b1b59d9cb5 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -4,7 +4,6 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-roc-cc" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_ROC_RK3308_CC=y diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index c15ba3d8a4..e450a06180 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -3,7 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-rock-pi-s" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_TARGET_EVB_RK3308=y -- 2.43.0
Thanks, - Kever
Changes in v3:
Changes in v2:
- none
- imply OF_LIBFDT_OVERLAY imply OF_UPSTREAM imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD
- imply OF_LIBFDT_OVERLAY imply OF_LIVE imply OF_UPSTREAM imply PRE_CONSOLE_BUFFER
Chen-Yu Tsai
FUKAUMI Naoki
Kever Yang
