[U-Boot] [PATCH v3] usb: gadget: Fix data aborts during USB ethernet boot
As seen on GCC 4.6 Linaro compiler, control_req buffer is not aligned on 4 byte boundaray causing data aborts in eth_setup -> conf_buf during dhcp boot over usb_ether. Fix the issue my aligning control_req buffer using DEFINE_CACHE_ALIGN_BUFFER.
Tested on am335x_evm platform (beaglebone). Applies on 2013.10-rc1 branch.
Cc: Tom Rini trini@ti.com Cc: Marek Vasut marex@denx.de Signed-off-by: Joel Fernandes joelf@ti.com --- v2 changes: - Using DEFINE_CACHE_ALIGN_BUFFER macro for the alignment. - Also fixed alignment for status_req.
v3 changes: - Adjusted commit message for v2 change.
drivers/usb/gadget/ether.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 579893c..700d5fb 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -849,9 +849,10 @@ static struct usb_gadget_strings stringtab = { };
/*============================================================================*/ -static u8 control_req[USB_BUFSIZ]; +DEFINE_CACHE_ALIGN_BUFFER(u8, control_req, USB_BUFSIZ); + #if defined(CONFIG_USB_ETH_CDC) || defined(CONFIG_USB_ETH_RNDIS) -static u8 status_req[STATUS_BYTECOUNT] __attribute__ ((aligned(4))); +DEFINE_CACHE_ALIGN_BUFFER(u8, status_req, STATUS_BYTECOUNT); #endif
Hi Joel Fernandes,
v2 changes:
v3 changes:
Test on sama5d3xek board with RNDIS gadget, it still has the unaligned access issue.
However, I test with this patch "usb: gadget: config: fix unaligned access issues" from: Troy Kisky troy.kisky@boundarydevices.com really fix the unaligned access issue.
more information at: http://patchwork.ozlabs.org/patch/264151/
- #if defined(CONFIG_USB_ETH_CDC) || defined(CONFIG_USB_ETH_RNDIS)
Best Regards, Bo Shen
Dear Bo Shen,
Hi Joel Fernandes,
v2 changes:
v3 changes:
Troy, care to fix up the patch's commit log so I can try and understand it?
Best regards, Marek Vasut
Dear Joel Fernandes,
v2 changes:
v3 changes:
/*======================================================================== ====*/ -static u8 control_req[USB_BUFSIZ]; +DEFINE_CACHE_ALIGN_BUFFER(u8, control_req, USB_BUFSIZ);
Applied, thanks
Bo Shen
Joel Fernandes
