[U-Boot] Ethernet i210 (e1000 driver) on tegra K1
I'm using a ethernet controller intel i210 (http://www.commell.com.tw/product/Surveillance/MPX-210.htm) on my nvidia tegra k1 jetson.
I not an expert with pci, but the only way to make it working in u-boot (upstream) is with the workaround below.
E1000 is very common, so finding a critical bug in this driver seems weird... Do you think there is a bug in e1000.c or in tegra pci layer?
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 2ba03ed..206884d 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5186,7 +5186,7 @@ static int _e1000_transmit(struct e1000_hw *hw, void *txpacket, int length) txp = tx_base + tx_tail; tx_tail = (tx_tail + 1) % 8;
- txp->buffer_addr = cpu_to_le64(virt_to_bus(hw->pdev, nv_packet)); + txp->buffer_addr = cpu_to_le64((unsigned long) nv_packet); txp->lower.data = cpu_to_le32(hw->txd_cmd | length); txp->upper.data = 0;
thank you
(You didn't actually CC anyone involved with Tegra, so I only accidentally noticed this while I was looking at my mailing list folder)
- txp->buffer_addr = cpu_to_le64((unsigned long) nv_packet); txp->lower.data = cpu_to_le32(hw->txd_cmd | length); txp->upper.data = 0;
In order to work out what's going on, perhaps you could print out the values of nv_packet and virt_to_bus(hw->pdev, nv_packet).
It's not terribly surprising that removing the call to virt_to_bus works, since IIRC U-Boot on Tegra uses the same address setup for the PCIe bus as for CPU physical addresses as for CPU virtual addresses.
So, the question is: what is virt_to_bus() doing, and is it the right API to call?
I see that virt_to_bus() is defined as:
e1000.c:
#define virt_to_bus(devno, v) pci_virt_to_mem(devno, (void *) (v))
pci.h:
#define pci_virt_to_mem(dev, addr) \ pci_virt_to_bus((dev), (addr), PCI_REGION_MEM)
#define pci_virt_to_bus(dev, addr, flags) \ pci_hose_phys_to_bus(pci_bus_to_hose(PCI_BUS(dev)), \ (virt_to_phys(addr)), (flags))
I know that the RTL8169 driver works on the same board (it's soldered down and attached to the other PCIe root port on the SoC). For what looks like the same "use case", it seems to call pci_mem_to_phys() which is:
pci.h:
#define pci_mem_to_phys(dev, addr) \ pci_bus_to_phys((dev), (addr), PCI_REGION_MEM)
#define pci_bus_to_phys(dev, addr, flags) \ pci_hose_bus_to_phys(pci_bus_to_hose(PCI_BUS(dev)), (addr), \ (flags))
That's odd, since one of those does a phys -> bus translation and the other does a bus -> phys translation. That's the opposite direction, so both can't possibly be right. I wonder if those mapping functions are no-ops on whatever architectures the e1000 driver has been used on (and hence have caused no issues), but fail for some reason on ARM?
(The other difference is the call to virt_to_phys(), but that's a no-op on ARM as far as I can tell).
virt_to_bus() is to translate cpu virtual address to pci bus physical address. Basically two levels of translation.
e1000.c:
pci.h:
pci.h:
Indeed these address translation macros in pci.h are confusing. But most SoC defines 1:1:1 mapping so these are not needed. The reason why it fails on Tegra is probably due to the addresses are not 1:1:1 mapped?
Regards, Bin
e1000.c:
pci.h:
pci.h:
I'm pretty sure everything is 1:1. That's why removing the call to any translation macro made the e1000 driver work for Ivan.
Hi Stephen
By accident I stumbled over this post and by incident now that we at Toradex are working on an Apalis TK1 module design using the same i210/i211 gigabit Ethernet chip as already widely deployed on Apalis T30 we are facing this as well.
On Thu, Nov 5, 2015 at 2:54 AM, Stephen Warren <swarren@wwwdotorg.o rg> wrote:
Exactly. Looking through the e1000 git log one should also have seen that me and others actually worked on it and that we are indeed successfully using it on Tegra albeit T30 only so far.
I did exactly that which gives:
Loading: nv_packet = 0xfffecb00 pci_hose_phys_to_bus: invalid physical address virt_to_bus(hw->pdev, nv_packet) = 0x00000000
So that looks OK but does not yet give us much further clues.
Looking at where the actual translation happens in drivers/pci/pci_common.c:
int __pci_hose_phys_to_bus(struct pci_controller *hose, ...
if (bus_addr >= res->bus_start && bus_addr < res->bus_start + res->size) { *ba = bus_addr; ...
So I added some more prints there giving:
bus_addr = 0xfffecb00 phys_addr = 0xfffecb00 res->phys_start = 0x80000000 res->bus_start = 0x80000000 res->size = 0x80000000
Ah, OK. That makes sense now. Just a classical overflow happening in the address range check (e.g. 0x80000000 + 0x80000000 giving 0x0 in 32- bits).
Strange that this works for others but e.g. the Realtek driver seems to do the inverse conversion:
int __pci_hose_bus_to_phys(struct pci_controller *hose, ...
if (bus_addr >= res->bus_start && (bus_addr - res->bus_start) < res->size) { *pa = (bus_addr - res->bus_start + res-
phys_start);
Ah, they worked around it by changing the order of the addition vs. subtraction in the range check. That will work.
I will be sending out a proper patch to fix this shortly.
But why does it work on T30?
bus_addr = 0xffee92e0 phys_addr = 0xffee92e0 res->phys_start = 0x80000000 res->bus_start = 0x80000000 res->size = 0x7ff00000
Ah funny, ooks like we got lucky due to the size being slightly below 0x80000000 (;-p).
e1000.c:
pci.h:
pci.h:
Yes, it's just 1:1:1 mapped.
@Ivan: Thank you very much for having reported this. Saves me some nightmare on bringing up our Apalis TK1 when time will be short next year couple weeks before the Embedded World show (;-p).
Cheers
Marcel
Bin Meng
Ivan Mercier
Marcel Ziswiler
Stephen Warren
