[U-Boot] [PATCH] sh: sh_eth: Add support SH7724
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 42 +++++++++++++++++++++++------------------- drivers/net/sh_eth.h | 41 +++++++++++++++++++++++++++++++++++++---- 2 files changed, 60 insertions(+), 23 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 27d0401..995e249 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -1,8 +1,8 @@ /* * sh_eth.c - Driver for Renesas SH7763's ethernet controler. * - * Copyright (C) 2008 Renesas Solutions Corp. - * Copyright (c) 2008 Nobuhiro Iwamatsu + * Copyright (C) 2008, 2011 Renesas Solutions Corp. + * Copyright (c) 2008, 2011 Nobuhiro Iwamatsu * Copyright (c) 2007 Carlos Munoz carlos@kenati.com * * This program is free software; you can redistribute it and/or modify @@ -371,7 +371,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl(0, TFTR(port)); outl((FIFO_SIZE_T | FIFO_SIZE_R), FDR(port)); outl(RMCR_RST, RMCR(port)); -#ifndef CONFIG_CPU_SH7757 +#if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) outl(0, RPADIR(port)); #endif outl((FIFO_F_D_RFF | FIFO_F_D_RFD), FCFTR(port)); @@ -393,16 +393,19 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl(val, MALR(port));
outl(RFLR_RFL_MIN, RFLR(port)); -#ifndef CONFIG_CPU_SH7757 +#if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) outl(0, PIPR(port)); #endif +#if !defined(CONFIG_CPU_SH7724) outl(APR_AP, APR(port)); outl(MPR_MP, MPR(port)); -#ifdef CONFIG_CPU_SH7757 - outl(TPAUSER_UNLIMITED, TPAUSER(port)); -#else +#endif +#if defined(CONFIG_CPU_SH7763) outl(TPAUSER_TPAUSE, TPAUSER(port)); +#elif defined(CONFIG_CPU_SH7757) + outl(TPAUSER_UNLIMITED, TPAUSER(port)); #endif + /* Configure phy */ ret = sh_eth_phy_config(eth); if (ret) { @@ -412,33 +415,34 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) phy = port_info->phydev; phy_startup(phy);
+ val = 0; + /* Set the transfer speed */ -#ifdef CONFIG_CPU_SH7763 if (phy->speed == 100) { printf(SHETHER_NAME ": 100Base/"); +#ifdef CONFIG_CPU_SH7763 outl(GECMR_100B, GECMR(port)); +#elif defined(CONFIG_CPU_SH7757) + outl(1, RTRATE(port)); +#elif defined(CONFIG_CPU_SH7724) + val = ECMR_RTM; +#endif } else if (phy->speed == 10) { printf(SHETHER_NAME ": 10Base/"); +#ifdef CONFIG_CPU_SH7763 outl(GECMR_10B, GECMR(port)); - } -#endif -#if defined(CONFIG_CPU_SH7757) - if (phy->speed == 100) { - printf("100Base/"); - outl(1, RTRATE(port)); - } else if (phy->speed == 10) { - printf("10Base/"); +#elif defined(CONFIG_CPU_SH7757) outl(0, RTRATE(port)); - } #endif + }
/* Check if full duplex mode is supported by the phy */ if (phy->duplex) { printf("Full\n"); - outl((ECMR_CHG_DM|ECMR_RE|ECMR_TE|ECMR_DM), ECMR(port)); + outl(val | (ECMR_CHG_DM|ECMR_RE|ECMR_TE|ECMR_DM), ECMR(port)); } else { printf("Half\n"); - outl((ECMR_CHG_DM|ECMR_RE|ECMR_TE), ECMR(port)); + outl(val | (ECMR_CHG_DM|ECMR_RE|ECMR_TE), ECMR(port)); }
return ret; diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index dd6a422..589cc11 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -1,8 +1,8 @@ /* * sh_eth.h - Driver for Renesas SuperH ethernet controler. * - * Copyright (C) 2008 Renesas Solutions Corp. - * Copyright (c) 2008 Nobuhiro Iwamatsu + * Copyright (C) 2008, 2011 Renesas Solutions Corp. + * Copyright (c) 2008, 2011 Nobuhiro Iwamatsu * Copyright (c) 2007 Carlos Munoz carlos@kenati.com * * This program is free software; you can redistribute it and/or modify @@ -162,6 +162,32 @@ struct sh_eth_dev { #define MAHR(port) (BASE_IO_ADDR + 0x800 * (port) + 0x01c0) #define MALR(port) (BASE_IO_ADDR + 0x800 * (port) + 0x01c8) #define RTRATE(port) (BASE_IO_ADDR + 0x800 * (port) + 0x01fc) + +#elif defined(CONFIG_CPU_SH7724) +#define BASE_IO_ADDR 0xA4600000 + +#define TDLAR(port) (BASE_IO_ADDR + 0x0018) +#define RDLAR(port) (BASE_IO_ADDR + 0x0020) + +#define EDMR(port) (BASE_IO_ADDR + 0x0000) +#define EDTRR(port) (BASE_IO_ADDR + 0x0008) +#define EDRRR(port) (BASE_IO_ADDR + 0x0010) +#define EESR(port) (BASE_IO_ADDR + 0x0028) +#define EESIPR(port) (BASE_IO_ADDR + 0x0030) +#define TRSCER(port) (BASE_IO_ADDR + 0x0038) +#define TFTR(port) (BASE_IO_ADDR + 0x0048) +#define FDR(port) (BASE_IO_ADDR + 0x0050) +#define RMCR(port) (BASE_IO_ADDR + 0x0058) +#define FCFTR(port) (BASE_IO_ADDR + 0x0070) +#define ECMR(port) (BASE_IO_ADDR + 0x0100) +#define RFLR(port) (BASE_IO_ADDR + 0x0108) +#define ECSIPR(port) (BASE_IO_ADDR + 0x0118) +#define PIR(port) (BASE_IO_ADDR + 0x0120) +#define APR(port) (BASE_IO_ADDR + 0x0154) +#define MPR(port) (BASE_IO_ADDR + 0x0158) +#define TPAUSER(port) (BASE_IO_ADDR + 0x0164) +#define MAHR(port) (BASE_IO_ADDR + 0x01c0) +#define MALR(port) (BASE_IO_ADDR + 0x01c8) #endif
/* @@ -183,7 +209,7 @@ enum DMAC_M_BIT { EDMR_SRST = 0x03, EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ -#elif defined CONFIG_CPU_SH7757 +#elif defined (CONFIG_CPU_SH7757) || defined (CONFIG_CPU_SH7724) EDMR_SRST = 0x01, EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ @@ -325,7 +351,8 @@ enum FCFTR_BIT {
/* Transfer descriptor bit */ enum TD_STS_BIT { -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7757) +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7757) \ + || defined(CONFIG_CPU_SH7724) TD_TACT = 0x80000000, #else TD_TACT = 0x7fffffff, @@ -350,6 +377,10 @@ enum FELIC_MODE_BIT { ECMR_PMDE = 0x00000200, ECMR_RE = 0x00000040, ECMR_TE = 0x00000020, ECMR_ILB = 0x00000008, ECMR_ELB = 0x00000004, ECMR_DM = 0x00000002, ECMR_PRM = 0x00000001, +#ifdef CONFIG_CPU_SH7724 + ECMR_RTM = 0x00000010, +#endif + };
#ifdef CONFIG_CPU_SH7763 @@ -357,6 +388,8 @@ enum FELIC_MODE_BIT { ECMR_TXF | ECMR_MCT) #elif CONFIG_CPU_SH7757 #define ECMR_CHG_DM (ECMR_ZPF) +#elif CONFIG_CPU_SH7724 +#define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF) #else #define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF | ECMR_MCT) #endif
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 18 +++++++++--------- 1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 995e249..903ce23 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -44,7 +44,7 @@ #define flush_cache_wback(...) #endif
-#define SH_ETH_PHY_DELAY 50000 +#define TIMEOUT_CNT 1000
int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) { @@ -59,8 +59,8 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) }
/* packet must be a 4 byte boundary */ - if ((int)packet & (4 - 1)) { - printf(SHETHER_NAME ": %s: packet not 4 byte alligned\n", __func__); + if ((int)packet & 3) { + printf(SHETHER_NAME ": packet not 4 byte alligned\n"); ret = -EFAULT; goto err; } @@ -80,7 +80,7 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) outl(EDTRR_TRNS, EDTRR(port));
/* Wait until packet is transmitted */ - timeout = 1000; + timeout = TIMEOUT_CNT; while (port_info->tx_desc_cur->td0 & TD_TACT && timeout--) udelay(100);
@@ -94,7 +94,6 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) if (port_info->tx_desc_cur >= port_info->tx_desc_base + NUM_TX_DESC) port_info->tx_desc_cur = port_info->tx_desc_base;
- return ret; err: return ret; } @@ -136,11 +135,10 @@ int sh_eth_recv(struct eth_device *dev) return len; }
-#define EDMR_INIT_CNT 1000 static int sh_eth_reset(struct sh_eth_dev *eth) { - int port = eth->port; #if defined(CONFIG_CPU_SH7763) + int port = eth->port; int ret = 0, i;
/* Start e-dmac transmitter and receiver */ @@ -148,19 +146,21 @@ static int sh_eth_reset(struct sh_eth_dev *eth)
/* Perform a software reset and wait for it to complete */ outl(EDMR_SRST, EDMR(port)); - for (i = 0; i < EDMR_INIT_CNT; i++) { + for (i = 0; i < TIMEOUT_CNT; i++) { if (!(inl(EDMR(port)) & EDMR_SRST)) break; udelay(1000); }
- if (i == EDMR_INIT_CNT) { + if (i == TIMEOUT_CNT) { printf(SHETHER_NAME ": Software reset timeout\n"); ret = -EIO; }
return ret; #else + int port = eth->port; + outl(inl(EDMR(port)) | EDMR_SRST, EDMR(port)); udelay(3000); outl(inl(EDMR(port)) & ~EDMR_SRST, EDMR(port));
Nobuhiro Iwamatsu
