[U-Boot] [PATCH 1/6] x86/pcat_timer: fix implicit declaration of function ‘unmask_irq’
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- lib_i386/pcat_timer.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/lib_i386/pcat_timer.c b/lib_i386/pcat_timer.c index e282f64..97ed8b6 100644 --- a/lib_i386/pcat_timer.c +++ b/lib_i386/pcat_timer.c @@ -22,6 +22,7 @@ */
#include <common.h> +#include <asm/interrupt.h> #include <asm/io.h> #include <asm/i8254.h> #include <asm/ibmpc.h>
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/i386/sc520/sc520_pci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/i386/sc520/sc520_pci.c b/cpu/i386/sc520/sc520_pci.c index 38b837e..871ad0a 100644 --- a/cpu/i386/sc520/sc520_pci.c +++ b/cpu/i386/sc520/sc520_pci.c @@ -124,7 +124,7 @@ void pci_sc520_init(struct pci_controller *hose) SC520_PCI_MEMORY_BUS, SC520_PCI_MEMORY_PHYS, SC520_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY);
/* PCI memory space */ pci_set_region(hose->regions + 1,
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- board/sc520_spunk/sc520_spunk.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/sc520_spunk/sc520_spunk.c b/board/sc520_spunk/sc520_spunk.c index d3bd869..e439b0b 100644 --- a/board/sc520_spunk/sc520_spunk.c +++ b/board/sc520_spunk/sc520_spunk.c @@ -24,11 +24,11 @@
#include <common.h> #include <pci.h> -#include <ssi.h> #include <netdev.h> #include <asm/io.h> #include <asm/pci.h> #include <asm/ic/sc520.h> +#include <asm/ic/ssi.h>
DECLARE_GLOBAL_DATA_PTR;
when allowing for PCI addresses to be 64-bit in commint 30e76d5e3bc4
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- lib_i386/pci.c | 2 +- lib_i386/video_bios.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib_i386/pci.c b/lib_i386/pci.c index 4331b04..f366bdc 100644 --- a/lib_i386/pci.c +++ b/lib_i386/pci.c @@ -60,7 +60,7 @@ int pci_shadow_rom(pci_dev_t dev, unsigned char *dest) vendor, device, class_code); #endif /* Enable the rom addess decoder */ - pci_write_config_dword(dev, PCI_ROM_ADDRESS, PCI_ROM_ADDRESS_MASK); + pci_write_config_dword(dev, PCI_ROM_ADDRESS, (u32)PCI_ROM_ADDRESS_MASK); pci_read_config_dword(dev, PCI_ROM_ADDRESS, &addr_reg);
if (!addr_reg) { diff --git a/lib_i386/video_bios.c b/lib_i386/video_bios.c index ce96a3e..d9116d4 100644 --- a/lib_i386/video_bios.c +++ b/lib_i386/video_bios.c @@ -103,7 +103,7 @@ static u32 probe_pci_video(void)
/* Test the ROM decoder, do the device support a rom? */ pci_read_config_dword(devbusfn, PCI_ROM_ADDRESS, &old); - pci_write_config_dword(devbusfn, PCI_ROM_ADDRESS, PCI_ROM_ADDRESS_MASK); + pci_write_config_dword(devbusfn, PCI_ROM_ADDRESS, (u32)PCI_ROM_ADDRESS_MASK); pci_read_config_dword(devbusfn, PCI_ROM_ADDRESS, &addr); pci_write_config_dword(devbusfn, PCI_ROM_ADDRESS, old);
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- lib_i386/video_bios.c | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/lib_i386/video_bios.c b/lib_i386/video_bios.c index d9116d4..3935d05 100644 --- a/lib_i386/video_bios.c +++ b/lib_i386/video_bios.c @@ -76,11 +76,12 @@ void print_bios_bios_stat(void) } #endif
+#ifdef CONFIG_VIDEO + #define PCI_CLASS_VIDEO 3 #define PCI_CLASS_VIDEO_STD 0 #define PCI_CLASS_VIDEO_PROG_IF_VGA 0
- static u32 probe_pci_video(void) { pci_dev_t devbusfn; @@ -132,7 +133,7 @@ static u32 probe_pci_video(void)
return 0; } - +#endif /* CONFIG_VIDEO */
#endif
@@ -176,7 +177,9 @@ int video_bios_init(void)
if (probe_isa_video()) { /* No ISA board found, try the PCI bus */ +#ifdef CONFIG_PCI regs.eax = probe_pci_video(); +#endif }
/* Did we succeed in mapping any video bios */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- MAKEALL | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 46a96c0..62697c4 100755 --- a/MAKEALL +++ b/MAKEALL @@ -697,8 +697,8 @@ LIST_mips_el=" \ #########################################################################
LIST_I486=" \ + eNET \ sc520_cdp \ - sc520_eNET \ sc520_spunk \ sc520_spunk_rel \ "
Dear Jean-Christophe PLAGNIOL-VILLARD,
Please provice a description what sort of problem you are fixing.
Please provide a proper commit message explaining what you are doing, and get rid of the special character(s) in the Subject: line.
- pci_write_config_dword(dev, PCI_ROM_ADDRESS, (u32)PCI_ROM_ADDRESS_MASK);
Ummm... but when we have 64 bit PIC addresses, then truncating these to 32 bit (either implicitly or explicitly) is wrong. Instead of fixing the problem, you just hush up the compiler warning. NAK.
Please get rid of the special characters in the Subject: line.
Since most patches of these series had some issues, I suggest you repost the whole serias after cleaning up.
Thanks.
