[U-Boot] should all include/configs/*.h headers be included via SYS_CONFIG_NAME?
pretty sure i know the answer to this, but i'm going to ask it anyway ... should all header files under include/configs/ be included in a build either directly or indirectly via the value in CONFIG_SYS_CONFIG_NAME?
i'm aware of that Kbuild setting and what it's used for:
config SYS_CONFIG_NAME string "Board configuration name" default "zynq-common" help This option contains information about board configuration name. Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header will be used for board configuration.
at which point that header file might well include further header files under include/configs/ and so on. so the question is, are include/configs/ header files meant to be included *exclusively* via CONFIG_SYS_CONFIG_NAME?
i ask since, out of curiosity, i did a quick grep to see if any of them were included from anywhere else, and i found all of one hit in the entire code base:
$ git grep '#include <configs' | grep -v ^include board/renesas/ecovec/lowlevel_init.S:#include <configs/ecovec.h> $
i thought it was odd that there would be a single example of that in the whole code base, even more so since the board file Kconfig board/renesas/ecovec/Kconfig includes:
config SYS_CONFIG_NAME default "ecovec"
which suggests that header file would have been included anyway.
thoughts?
rday
Robert P. J. Day
