[U-Boot] [PATCH 0/4 V6] EXYNOS5250: FDT: Add device tree support for console
Enabled fdt support for default console on EXYNOS5250.
Changes in V2: - Changed the compatible string to "samsung,exynos4210-uart" Changes in V3: - Rebased the patchset on latest u-boot-samsung branch. - Added a alias console as we will support one at any point of time. - Moved driver config structure to data section. - Changed silent_console to silent-console. - Did put a check for base address before doing fdt decoding. Changes in V4: - Rebased the patchset on latest u-boot-samsung branch. - Changed to COMPAT_SAMSUNG_EXYNOS5_SERIAL to COMPAT_SAMSUNG_EXYNOS_SERIAL Changes in V5: - Added serial device node for Snow board. Changes in V6: - Rebased the patchset on latest u-boot-samsung branch. - Changed the if..else condition to a switch statement. - Moved compatible strings up with all other samsung strings.
Rajeshwari Shinde (4): EXYNOS5: FDT: Add compatible strings for Serial EXYNOS5: FDT: Add serial device node values S5P: Serial: Add fdt support to driver CONFIG: EXYNOS5: Enable silent console
arch/arm/dts/exynos5250.dtsi | 28 ++++++++++ board/samsung/dts/exynos5250-smdk5250.dts | 2 + board/samsung/dts/exynos5250-snow.dts | 2 + drivers/serial/serial_s5p.c | 78 +++++++++++++++++++++++++++++ include/configs/exynos5250-dt.h | 2 +- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 7 files changed, 113 insertions(+), 1 deletions(-)
Add required compatible information for s5p serial driver
Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Changed the compatible string to "samsung,exynos4210-uart" Changes in V3: - Rebased on latest u-boot-samsung Changes in V4: - Rebased on latest u-boot-samsung - Changed to COMPAT_SAMSUNG_EXYNOS5_SERIAL to COMPAT_SAMSUNG_EXYNOS_SERIAL Changes in V5: - None Changes in V6: - Moved compatible strings up with all other samsung strings. include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index bc3b89b..bea326e 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -90,6 +90,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index e3142cb..d1acc35 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -63,6 +63,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"),
- COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */
- COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
Is it exynos4210 specific? If not, how about exynos-uart?
Thanks, Minkyu Kang.
Hi Minkyu,
Please do find the answer to your commnet.
We use "samsung,exynos4210-uart" to keep it same as it is in kernel. This was changed after a commnet from Simon http://lists.denx.de/pipermail/u-boot/2013-March/148095.html
This patch adds the device node required for serial driver
Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Changed the compatible string to "samsung,exynos4210-uart" Changes in V3: - Added a alias console as we will support one at any point of time. Changes in V4: - Rebased on latest u-boot-samsung tree. Changes in V5: - Added device node for Snow board. Changes in V6: - Rebased on latest u-boot-samsung branch. arch/arm/dts/exynos5250.dtsi | 28 ++++++++++++++++++++++++++++ board/samsung/dts/exynos5250-smdk5250.dts | 2 ++ board/samsung/dts/exynos5250-snow.dts | 2 ++ 3 files changed, 32 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index cee4fe8..1e14154 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -202,4 +202,32 @@ interrupts = <0 78 0>; };
+ + serial@12C00000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C00000 0x100>; + interrupts = <0 51 0>; + id = <0>; + }; + + serial@12C10000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C10000 0x100>; + interrupts = <0 52 0>; + id = <1>; + }; + + serial@12C20000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C20000 0x100>; + interrupts = <0 53 0>; + id = <2>; + }; + + serial@12C30000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C30000 0x100>; + interrupts = <0 54 0>; + id = <3>; + }; }; diff --git a/board/samsung/dts/exynos5250-smdk5250.dts b/board/samsung/dts/exynos5250-smdk5250.dts index 93375a6..80ffe30 100644 --- a/board/samsung/dts/exynos5250-smdk5250.dts +++ b/board/samsung/dts/exynos5250-smdk5250.dts @@ -34,6 +34,8 @@ mmc1 = "/mmc@12210000"; mmc2 = "/mmc@12220000"; mmc3 = "/mmc@12230000"; + serial0 = "/serial@12C30000"; + console = "/serial@12C30000"; };
sromc@12250000 { diff --git a/board/samsung/dts/exynos5250-snow.dts b/board/samsung/dts/exynos5250-snow.dts index d167df9..fdc047a 100644 --- a/board/samsung/dts/exynos5250-snow.dts +++ b/board/samsung/dts/exynos5250-snow.dts @@ -34,6 +34,8 @@ mmc1 = "/mmc@12210000"; mmc2 = "/mmc@12220000"; mmc3 = "/mmc@12230000"; + serial0 = "/serial@12C30000"; + console = "/serial@12C30000"; };
sound@12d60000 {
please remove this extra line.
- serial@12C00000 {
id = <0>;
- serial@12C10000 {
id = <1>;
- serial@12C20000 {
id = <2>;
- serial@12C30000 {
id = <3>;
sromc@12250000 {
sound@12d60000 {
Hi Minkyu Kang,
Thank you for comment
Will correct this and send a new patchset.
serial@12C00000 {
id = <0>;
serial@12C10000 {
id = <1>;
serial@12C20000 {
id = <2>;
serial@12C30000 {
id = <3>;
console = "/serial@12C30000"; }; sromc@12250000 {
console = "/serial@12C30000"; }; sound@12d60000 {
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
This patch adds FDT support to the serial s5p driver. At present disabling the serial console (from the device tree) crashes U-Boot. Add checks for this case, so that execution can continue without a serial console. It also enables the serial_s5p driver recognize the silent_console option.
Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Gabe Black gabeblack@google.com Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None Changes in V3: - Moved driver config structure to data section. - Changed silent_console to silent-console. - Did put a check for base address before doing fdt decoding. Changes in V4: - None Changes in V5: - None Changes in V6: - Changed the if..else condition to a switch statement. drivers/serial/serial_s5p.c | 78 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 78 insertions(+), 0 deletions(-)
diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index e65125c..6836c7a 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -22,6 +22,7 @@ */
#include <common.h> +#include <fdtdec.h> #include <linux/compiler.h> #include <asm/io.h> #include <asm/arch/uart.h> @@ -34,10 +35,21 @@ DECLARE_GLOBAL_DATA_PTR; #define RX_FIFO_FULL_MASK (1 << 8) #define TX_FIFO_FULL_MASK (1 << 24)
+/* Information about a serial port */ +struct fdt_serial { + u32 base_addr; /* address of registers in physical memory */ + u8 port_id; /* uart port number */ + u8 enabled; /* 1 if enabled, 0 if disabled */ +} config __attribute__ ((section(".data"))); + static inline struct s5p_uart *s5p_get_base_uart(int dev_index) { +#ifdef CONFIG_OF_CONTROL + return (struct s5p_uart *)(config.base_addr); +#else u32 offset = dev_index * sizeof(struct s5p_uart); return (struct s5p_uart *)(samsung_get_base_uart() + offset); +#endif }
/* @@ -73,6 +85,16 @@ void serial_setbrg_dev(const int dev_index) u32 baudrate = gd->baudrate; u32 val;
+#if defined(CONFIG_SILENT_CONSOLE) && \ + defined(CONFIG_OF_CONTROL) && \ + !defined(CONFIG_SPL_BUILD) + if (fdtdec_get_config_int(gd->fdt_blob, "silent_console", 0)) + gd->flags |= GD_FLG_SILENT; +#endif + + if (!config.enabled) + return; + val = uclk / baudrate;
writel(val / 16 - 1, &uart->ubrdiv); @@ -133,6 +155,9 @@ int serial_getc_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
+ if (!config.enabled) + return 0; + /* wait for character to arrive */ while (!(readl(&uart->ufstat) & (RX_FIFO_COUNT_MASK | RX_FIFO_FULL_MASK))) { @@ -150,6 +175,9 @@ void serial_putc_dev(const char c, const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
+ if (!config.enabled) + return; + /* wait for room in the tx FIFO */ while ((readl(&uart->ufstat) & TX_FIFO_FULL_MASK)) { if (serial_err_check(dev_index, 1)) @@ -170,6 +198,9 @@ int serial_tstc_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
+ if (!config.enabled) + return 0; + return (int)(readl(&uart->utrstat) & 0x1); }
@@ -212,8 +243,54 @@ DECLARE_S5P_SERIAL_FUNCTIONS(3); struct serial_device s5p_serial3_device = INIT_S5P_SERIAL_STRUCTURE(3, "s5pser3");
+#ifdef CONFIG_OF_CONTROL +int fdtdec_decode_console(int *index, struct fdt_serial *uart) +{ + const void *blob = gd->fdt_blob; + int node; + + node = fdt_path_offset(blob, "console"); + if (node < 0) + return node; + + uart->base_addr = fdtdec_get_addr(blob, node, "reg"); + if (uart->base_addr == FDT_ADDR_T_NONE) + return -FDT_ERR_NOTFOUND; + + uart->port_id = fdtdec_get_int(blob, node, "id", -1); + uart->enabled = fdtdec_get_is_enabled(blob, node); + + return 0; +} +#endif + __weak struct serial_device *default_serial_console(void) { +#ifdef CONFIG_OF_CONTROL + int index = 0; + + if ((!config.base_addr) && (fdtdec_decode_console(&index, &config))) { + debug("Cannot decode default console node\n"); + return NULL; + } + + switch (config.port_id) { + case 0: + return &s5p_serial0_device; + case 1: + return &s5p_serial1_device; + case 2: + return &s5p_serial2_device; + case 3: + return &s5p_serial3_device; + default: + debug("Unknown config.port_id: %d", config.port_id); + break; + } + + return NULL; +#else + config.enabled = 1; #if defined(CONFIG_SERIAL0) return &s5p_serial0_device; #elif defined(CONFIG_SERIAL1) @@ -225,6 +302,7 @@ __weak struct serial_device *default_serial_console(void) #else #error "CONFIG_SERIAL? missing." #endif +#endif }
void s5p_serial_initialize(void)
This patch enables CONFIG_SILENT_CONSOLE for EXYNOS5. This patch also removes the hardcoding of UART port from exynos5250 config.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None Changes in V3: - None Changes in V4: - None Changes in V5: - None Chnages in V6: - Removed CONFIG_SERIAL3 as it is decoded from device tree include/configs/exynos5250-dt.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 9b97d4f..1c9eca2 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -78,9 +78,9 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20))
/* select serial console configuration */ -#define CONFIG_SERIAL3 /* use SERIAL 3 */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 +#define CONFIG_SILENT_CONSOLE
/* Console configuration */ #define CONFIG_CONSOLE_MUX
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
