[U-Boot] [PATCH 0/2] igep00x0: standardize boot commmands
Please consider adding these two patches. I saw that I missed some emails because my MAINTAINERS address was obsolete, so the first patch only updates my email. The second one switches igep00x0 to use generic distro configuration and environment instead of custom boot commands to be more generic.
Enric Balletbo i Serra (2): igep00xx: MAINTAINERS: update eballetbo's email address. igep00x0: Switch to use the generic distro configuration and environment.
board/isee/igep0033/MAINTAINERS | 2 +- board/isee/igep00x0/MAINTAINERS | 2 +- board/isee/igep00x0/igep00x0.c | 4 +- include/configs/omap3_igep00x0.h | 95 ++++++++++++---------------------------- 4 files changed, 32 insertions(+), 71 deletions(-)
Signed-off-by: Enric Balletbo i Serra enric.balletbo@collabora.com --- board/isee/igep0033/MAINTAINERS | 2 +- board/isee/igep00x0/MAINTAINERS | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/isee/igep0033/MAINTAINERS b/board/isee/igep0033/MAINTAINERS index d162d77..bd8a1f2 100644 --- a/board/isee/igep0033/MAINTAINERS +++ b/board/isee/igep0033/MAINTAINERS @@ -1,5 +1,5 @@ IGEP0033 BOARD -M: Enric Balletbo i Serra eballetbo@iseebcn.com +M: Enric Balletbo i Serra eballetbo@gmail.com S: Maintained F: board/isee/igep0033/ F: include/configs/am335x_igep0033.h diff --git a/board/isee/igep00x0/MAINTAINERS b/board/isee/igep00x0/MAINTAINERS index 3fc2c6c..d355c46 100644 --- a/board/isee/igep00x0/MAINTAINERS +++ b/board/isee/igep00x0/MAINTAINERS @@ -1,5 +1,5 @@ IGEP00X0 BOARD -M: Enric Balletbo i Serra eballetbo@iseebcn.com +M: Enric Balletbo i Serra eballetbo@gmail.com S: Maintained F: board/isee/igep00x0/ F: include/configs/omap3_igep00x0.h
This patch changes a little bit the environment, current environment was broken for a long time, and board don't as expected sometimes, on production systems this is fixed adding boot script. I think it's time to change this to make a system conformant environment and use generic distro configurations and environment instead. We can use a boot script for the old way boot mode.
Signed-off-by: Enric Balletbo i Serra enric.balletbo@collabora.com --- board/isee/igep00x0/igep00x0.c | 4 +- include/configs/omap3_igep00x0.h | 95 ++++++++++++---------------------------- 2 files changed, 30 insertions(+), 69 deletions(-)
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index 693fce7..6eb191c 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -153,10 +153,10 @@ void set_fdt(void) { switch (gd->bd->bi_arch_number) { case MACH_TYPE_IGEP0020: - setenv("dtbfile", "omap3-igep0020.dtb"); + setenv("fdtfile", "omap3-igep0020.dtb"); break; case MACH_TYPE_IGEP0030: - setenv("dtbfile", "omap3-igep0030.dtb"); + setenv("fdtfile", "omap3-igep0030.dtb"); break; } } diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 04433ed..4409103 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -19,6 +19,8 @@ #include <configs/ti_omap3_common.h> #include <asm/mach-types.h>
+#undef CONFIG_BOOTDELAY + /* * Display CPU and Board information */ @@ -81,74 +83,33 @@
/*#undef CONFIG_ENV_IS_NOWHERE*/
+#ifndef CONFIG_SPL_BUILD + +#include <config_distro_defaults.h> + +/* Environment */ +#define ENV_DEVICE_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +#define MEM_LAYOUT_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV \ + "scriptaddr=0x87E00000\0" \ + "pxefile_addr_r=0x87F00000\0" + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#include <config_distro_bootcmd.h> + + #define CONFIG_EXTRA_ENV_SETTINGS \ - "usbtty=cdc_acm\0" \ - "loadaddr=0x82000000\0" \ - "dtbaddr=0x81600000\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ - "usbtty=cdc_acm\0" \ - "console=ttyO2,115200n8\0" \ - "mpurate=auto\0" \ - "vram=12M\0" \ - "dvimode=1024x768MR-16@60\0" \ - "defaultdisplay=dvi\0" \ - "mmcdev=0\0" \ - "mmcroot=/dev/mmcblk0p2 rw\0" \ - "mmcrootfstype=ext4 rootwait\0" \ - "nandroot=/dev/mtdblock4 rw\0" \ - "nandrootfstype=jffs2\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "mpurate=${mpurate} " \ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapfb.debug=y " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ - "nandargs=setenv bootargs console=${console} " \ - "mpurate=${mpurate} " \ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapfb.debug=y " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${nandroot} " \ - "rootfstype=${nandrootfstype}\0" \ - "loadbootenv=load mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ - "env import -t $loadaddr $filesize\0" \ - "loadzimage=load mmc ${mmcdev}:2 ${loadaddr} ${bootdir}/${bootfile}\0" \ - "loadfdt=load mmc ${mmcdev}:2 ${dtbaddr} ${bootdir}/${dtbfile}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootz ${loadaddr}\0" \ - "mmcbootfdt=echo Booting with DT from mmc ...; " \ - "bootz ${loadaddr} - ${dtbaddr}\0" \ - "nandboot=echo Booting from onenand ...; " \ - "run nandargs; " \ - "onenand read ${loadaddr} 280000 400000; " \ - "bootz ${loadaddr}\0" \ - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "echo SD/MMC found on device ${mmcdev};" \ - "if run loadbootenv; then " \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run loadzimage; then " \ - "if test -n $dtbfile; then " \ - "if run loadfdt; then " \ - "run mmcbootfdt;" \ - "fi;" \ - "fi;" \ - "run mmcboot;" \ - "fi;" \ - "fi;" \ - "run nandboot;" \ + ENV_DEVICE_SETTINGS \ + MEM_LAYOUT_SETTINGS \ + BOOTENV + +#endif
/* * FLASH and environment organization
