[U-Boot] [PATCH v2] rockchip: video: mipi: Modify variable type for arm32 compatibility
Some address relevant varibable is defined originally as u64. To compatible with arm32, this patch change them to "void __iomem *" type.
Signed-off-by: Eric Gao eric.gao@rock-chips.com
Changes in v1: -Change the address base variable to uintptr_t type.
drivers/video/rockchip/rk_mipi.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index ad00397..a9522ce 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -40,7 +40,7 @@ DECLARE_GLOBAL_DATA_PTR; * @txesc_clk: clock for tx esc mode */ struct rk_mipi_priv { - void __iomem *regs; + uintptr_t *regs; struct rk3399_grf_regs *grf; struct udevice *panel; struct mipi_dsi *dsi; @@ -76,13 +76,13 @@ static int rk_mipi_read_timing(struct udevice *dev, * use define in rk_mipi.h directly for this parameter * @val: value that will be write to specified bits of register */ -static void rk_mipi_dsi_write(u32 regs, u32 reg, u32 val) +static void rk_mipi_dsi_write(uintptr_t *regs, u32 reg, u32 val) { u32 dat; u32 mask; u32 offset = (reg >> OFFSET_SHIFT) & 0xff; u32 bits = (reg >> BITS_SHIFT) & 0xff; - u64 addr = (reg >> ADDR_SHIFT) + regs; + uintptr_t *addr = (reg >> ADDR_SHIFT) + regs;
/* Mask for specifiled bits,the corresponding bits will be clear */ mask = ~((0xffffffff << offset) & (0xffffffff >> (32 - offset - bits))); @@ -108,7 +108,7 @@ static int rk_mipi_dsi_enable(struct udevice *dev, int node, timing_node; int val; struct rk_mipi_priv *priv = dev_get_priv(dev); - u64 regs = (u64)priv->regs; + uintptr_t *regs = priv->regs; struct display_plat *disp_uc_plat = dev_get_uclass_platdata(dev); u32 txbyte_clk = priv->txbyte_clk; u32 txesc_clk = priv->txesc_clk; @@ -224,7 +224,7 @@ static int rk_mipi_dsi_enable(struct udevice *dev, }
/* rk mipi dphy write function. It is used to write test data to dphy */ -static void rk_mipi_phy_write(u32 regs, unsigned char test_code, +static void rk_mipi_phy_write(uintptr_t *regs, unsigned char test_code, unsigned char *test_data, unsigned char size) { int i = 0; @@ -253,7 +253,7 @@ static int rk_mipi_phy_enable(struct udevice *dev) { int i; struct rk_mipi_priv *priv = dev_get_priv(dev); - u64 regs = (u64)priv->regs; + uintptr_t *regs = priv->regs; u64 fbdiv; u64 prediv = 1; u32 max_fbdiv = 512;
Eric Gao
