[U-Boot-Users] [Attn: Joe Loelinger] Re: [PATCH] Fix up flash_read_uchar() to read uchar more safely in cfi_flash.c.
I have to send this to Joe Loelinger through the list due to an blacklisting issue. Direct mail bounced with the following error:
----- The following addresses had permanent fatal errors ----- jdl@jdl.com (reason: 550-sender IP address 207.115.20.70 is locally blacklisted here. If you think)
I have to send via my ISP mail server "smtp.sbcglobal.net" even though I am using orkun.us as my email. The IP is assigned by PPPoE.
Regards, Tolunay
Tolunay Orkun wrote:
Jon Loeliger wrote:
Signed-off-by: Zhang Wei wei.zhang@freescale.com Signed-off-by: Jon Loeliger jdl@freescale.com
Tolunay,
What do you think of this proposed solution to the problem of handling the flash read width issue that we were having with the 8641 HPCN board?
If you think this is an acceptable approach, I can resubmit this patch to the U-Boot list if you'd like.
Thanks, jdl
I think the approach is sound except I have a few comments below.
Meanwhile, the debugging lead me to conclude the flash_read_uchar() is not really the root cause of your problem.
Please refer to email exchange I had with Haiying yesterday. We probably need to add "asm("sync;"); to flash_write_cmd() and/or udelay(); after reset.
drivers/cfi_flash.c | 30 ++++++++++++++++++++++++++---- 1 files changed, 26 insertions(+), 4 deletions(-)
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index 696f9a4..d109c5e 100644
- --- a/drivers/cfi_flash.c
+++ b/drivers/cfi_flash.c @@ -255,13 +255,35 @@ #endif */ inline uchar flash_read_uchar (flash_info_t * info, uint offset) {
- uchar *cp;
- union {
u8 c;
u16 s;
u32 l;
u64 ll;
u8 b[FLASH_CFI_64BIT];
- } cp;
Instead of a anonymous union use cfiword_t and cfiptr_t just like flash_write_cmd() does. Remember to use "volatile" for pointer of type cfiptr_t.
You will need to augment cfiword_t union for byte access to individual bytes (i.e. u8 b[FLASH_CFI_64BIT]);
In addition to this, we need to rework, flash_read_ushort() and flash_read_long() similarly for portwidth based accesses. Currently, like flash_read_uchar() these are reading single bytes;
Best regards, Tolunay
Bah. Sorry about that.
I'll whitelist that address for you at home too. Sorry.
Yeah, I'm just catching up on that thread now. I agree with folks that the sync (or delay) approach might be the real issue at work here. I'm waiting on that new version of the patch as well. I'll give that a try and see how Chris Fester fares with it as well! :-)
Thanks, jdl
Jon Loeliger
Tolunay Orkun
