Hi Tom,
https://source.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/17224 https://dev.azure.com/simon0972/u-boot/_build/results?buildId=45&view=re...
The following changes since commit 9787da0d32c2d58bae790a16ded0fe0c150c3280:
Merge branch '2023-08-04-toradex-platform-updates' (2023-08-04 16:04:11 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-5aug23
for you to fetch changes up to 48d4c0a85d6f7fdb46dddcaa8a5f5b5c4290819f:
buildman: Drop warning about orphaned defconfigs (2023-08-05 11:39:23 -0600)
---------------------------------------------------------------- binman support for Xilinx signing buildman minor fixes
---------------------------------------------------------------- Jaehoon Chung (1): event: Fix a wrong type_name from dm_post_init to dm_post_init_f
Lukas Funke (3): binman: btool: Add Xilinx Bootgen btool binman: etype: Add xilinx-bootgen etype binman: ftest: Add test for xilinx-bootgen etype
Simon Glass (3): binman: Renumber 291 and 292 test files buildman: Exit after reading toolchain buildman: Drop warning about orphaned defconfigs
common/event.c | 2 +- tools/binman/bintools.rst | 2 +- tools/binman/btool/bootgen.py | 137 ++++++++++++++++ tools/binman/entries.rst | 75 +++++++++ tools/binman/etype/xilinx_bootgen.py | 225 +++++++++++++++++++++++++++ tools/binman/ftest.py | 81 +++++++++- tools/binman/test/307_xilinx_bootgen_sign.dts | 22 +++ tools/binman/test/308_xilinx_bootgen_sign_enc.dts | 24 +++ .../{291_template_phandle.dts => 309_template_phandle.dts} | 0 ...2_template_phandle_dup.dts => 310_template_phandle_dup.dts} | 0 tools/buildman/boards.py | 7 - tools/buildman/control.py | 3 + tools/buildman/func_test.py | 9 +- 13 files changed, 569 insertions(+), 18 deletions(-) create mode 100644 tools/binman/btool/bootgen.py create mode 100644 tools/binman/etype/xilinx_bootgen.py create mode 100644 tools/binman/test/307_xilinx_bootgen_sign.dts create mode 100644 tools/binman/test/308_xilinx_bootgen_sign_enc.dts rename tools/binman/test/{291_template_phandle.dts => 309_template_phandle.dts} (100%) rename tools/binman/test/{292_template_phandle_dup.dts => 310_template_phandle_dup.dts} (100%)
On Sat, Aug 05, 2023 at 08:00:20PM -0600, Simon Glass wrote:
Hi Tom,
