[U-Boot] Subject: [PATCH 2/3] mmc: use sdhci.c instead of s5p_mmc.c
In driver mmc, generic sdhci code is implemented. s5p_mmc file is dupulicated. we are good that use the generic sdhci. This patch supported the sdhci for Samsung-SoC.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/include/asm/arch-exynos/mmc.h | 93 +++++++++++++++-------------- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 93 +++++++++++++++-------------- drivers/mmc/Makefile | 2 +- drivers/mmc/s5p_sdhci.c | 98 +++++++++++++++++++++++++++++++ drivers/mmc/sdhci.c | 12 ++++ include/sdhci.h | 6 ++ 6 files changed, 211 insertions(+), 93 deletions(-) create mode 100644 drivers/mmc/s5p_sdhci.c
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 30f82b8..0f701c9 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -21,53 +21,54 @@ #ifndef __ASM_ARCH_MMC_H_ #define __ASM_ARCH_MMC_H_
-#ifndef __ASSEMBLY__ -struct s5p_mmc { - unsigned int sysad; - unsigned short blksize; - unsigned short blkcnt; - unsigned int argument; - unsigned short trnmod; - unsigned short cmdreg; - unsigned int rspreg0; - unsigned int rspreg1; - unsigned int rspreg2; - unsigned int rspreg3; - unsigned int bdata; - unsigned int prnsts; - unsigned char hostctl; - unsigned char pwrcon; - unsigned char blkgap; - unsigned char wakcon; - unsigned short clkcon; - unsigned char timeoutcon; - unsigned char swrst; - unsigned int norintsts; /* errintsts */ - unsigned int norintstsen; /* errintstsen */ - unsigned int norintsigen; /* errintsigen */ - unsigned short acmd12errsts; - unsigned char res1[2]; - unsigned int capareg; - unsigned char res2[4]; - unsigned int maxcurr; - unsigned char res3[0x34]; - unsigned int control2; - unsigned int control3; - unsigned char res4[4]; - unsigned int control4; - unsigned char res5[0x6e]; - unsigned short hcver; - unsigned char res6[0xFF00]; -}; +#define SDHCI_CONTROL2 0x80 +#define SDHCI_CONTROL3 0x84 +#define SDHCI_CONTROL4 0x8C
-struct mmc_host { - struct s5p_mmc *reg; - unsigned int version; /* SDHCI spec. version */ - unsigned int clock; /* Current clock (MHz) */ - int dev_index; -}; +#define SDHCI_CTRL2_ENSTAASYNCCLR (1 << 31) +#define SDHCI_CTRL2_ENCMDCNFMSK (1 << 30) +#define SDHCI_CTRL2_CDINVRXD3 (1 << 29) +#define SDHCI_CTRL2_SLCARDOUT (1 << 28)
-int s5p_mmc_init(int dev_index, int bus_width); +#define SDHCI_CTRL2_FLTCLKSEL_MASK (0xf << 24) +#define SDHCI_CTRL2_FLTCLKSEL_SHIFT (24) +#define SDHCI_CTRL2_FLTCLKSEL(_x) ((_x) << 24)
-#endif /* __ASSEMBLY__ */ +#define SDHCI_CTRL2_LVLDAT_MASK (0xff << 16) +#define SDHCI_CTRL2_LVLDAT_SHIFT (16) +#define SDHCI_CTRL2_LVLDAT(_x) ((_x) << 16) + +#define SDHCI_CTRL2_ENFBCLKTX (1 << 15) +#define SDHCI_CTRL2_ENFBCLKRX (1 << 14) +#define SDHCI_CTRL2_SDCDSEL (1 << 13) +#define SDHCI_CTRL2_SDSIGPC (1 << 12) +#define SDHCI_CTRL2_ENBUSYCHKTXSTART (1 << 11) + +#define SDHCI_CTRL2_DFCNT_MASK(_x) ((_x) << 9) +#define SDHCI_CTRL2_DFCNT_SHIFT (9) + +#define SDHCI_CTRL2_ENCLKOUTHOLD (1 << 8) +#define SDHCI_CTRL2_RWAITMODE (1 << 7) +#define SDHCI_CTRL2_DISBUFRD (1 << 6) +#define SDHCI_CTRL2_SELBASECLK_MASK(_x) ((_x) << 4) +#define SDHCI_CTRL2_SELBASECLK_SHIFT (4) +#define SDHCI_CTRL2_PWRSYNC (1 << 3) +#define SDHCI_CTRL2_ENCLKOUTMSKCON (1 << 1) +#define SDHCI_CTRL2_HWINITFIN (1 << 0) + +#define SDHCI_CTRL3_FCSEL3 (1 << 31) +#define SDHCI_CTRL3_FCSEL2 (1 << 23) +#define SDHCI_CTRL3_FCSEL1 (1 << 15) +#define SDHCI_CTRL3_FCSEL0 (1 << 7) + +#define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) +#define SDHCI_CTRL4_DRIVE_SHIFT (16) + +int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks); + +static inline unsigned int s5p_mmc_init(int index, int bus_width) +{ + unsigned int base = samsung_get_base_mmc() + (0x10000 * index); + return s5p_sdhci_init(base, 52000000, 400000, index); +} #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/mmc.h b/arch/arm/include/asm/arch-s5pc1xx/mmc.h index adef4ee..0f701c9 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/mmc.h +++ b/arch/arm/include/asm/arch-s5pc1xx/mmc.h @@ -21,53 +21,54 @@ #ifndef __ASM_ARCH_MMC_H_ #define __ASM_ARCH_MMC_H_
-#ifndef __ASSEMBLY__ -struct s5p_mmc { - unsigned int sysad; - unsigned short blksize; - unsigned short blkcnt; - unsigned int argument; - unsigned short trnmod; - unsigned short cmdreg; - unsigned int rspreg0; - unsigned int rspreg1; - unsigned int rspreg2; - unsigned int rspreg3; - unsigned int bdata; - unsigned int prnsts; - unsigned char hostctl; - unsigned char pwrcon; - unsigned char blkgap; - unsigned char wakcon; - unsigned short clkcon; - unsigned char timeoutcon; - unsigned char swrst; - unsigned int norintsts; /* errintsts */ - unsigned int norintstsen; /* errintstsen */ - unsigned int norintsigen; /* errintsigen */ - unsigned short acmd12errsts; - unsigned char res1[2]; - unsigned int capareg; - unsigned char res2[4]; - unsigned int maxcurr; - unsigned char res3[0x34]; - unsigned int control2; - unsigned int control3; - unsigned char res4[4]; - unsigned int control4; - unsigned char res5[0x6e]; - unsigned short hcver; - unsigned char res6[0xFFF00]; -}; +#define SDHCI_CONTROL2 0x80 +#define SDHCI_CONTROL3 0x84 +#define SDHCI_CONTROL4 0x8C
-#endif /* __ASSEMBLY__ */ +#define SDHCI_CTRL2_LVLDAT_MASK (0xff << 16) +#define SDHCI_CTRL2_LVLDAT_SHIFT (16) +#define SDHCI_CTRL2_LVLDAT(_x) ((_x) << 16) + +#define SDHCI_CTRL2_ENFBCLKTX (1 << 15) +#define SDHCI_CTRL2_ENFBCLKRX (1 << 14) +#define SDHCI_CTRL2_SDCDSEL (1 << 13) +#define SDHCI_CTRL2_SDSIGPC (1 << 12) +#define SDHCI_CTRL2_ENBUSYCHKTXSTART (1 << 11) + +#define SDHCI_CTRL2_DFCNT_MASK(_x) ((_x) << 9) +#define SDHCI_CTRL2_DFCNT_SHIFT (9) + +#define SDHCI_CTRL2_ENCLKOUTHOLD (1 << 8) +#define SDHCI_CTRL2_RWAITMODE (1 << 7) +#define SDHCI_CTRL2_DISBUFRD (1 << 6) +#define SDHCI_CTRL2_SELBASECLK_MASK(_x) ((_x) << 4) +#define SDHCI_CTRL2_SELBASECLK_SHIFT (4) +#define SDHCI_CTRL2_PWRSYNC (1 << 3) +#define SDHCI_CTRL2_ENCLKOUTMSKCON (1 << 1) +#define SDHCI_CTRL2_HWINITFIN (1 << 0) + +#define SDHCI_CTRL3_FCSEL3 (1 << 31) +#define SDHCI_CTRL3_FCSEL2 (1 << 23) +#define SDHCI_CTRL3_FCSEL1 (1 << 15) +#define SDHCI_CTRL3_FCSEL0 (1 << 7) + +#define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) +#define SDHCI_CTRL4_DRIVE_SHIFT (16) + +int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks); + +static inline unsigned int s5p_mmc_init(int index, int bus_width) +{ + unsigned int base = samsung_get_base_mmc() + (0x10000 * index); + return s5p_sdhci_init(base, 52000000, 400000, index); +} #endif diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index c245352..a8e681c 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -39,8 +39,8 @@ COBJS-$(CONFIG_MXS_MMC) += mxsmmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o -COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o +COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o COBJS-$(CONFIG_TEGRA2_MMC) += tegra2_mmc.o
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c new file mode 100644 index 0000000..1d4481b --- /dev/null +++ b/drivers/mmc/s5p_sdhci.c @@ -0,0 +1,98 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Jaehoon Chung jh80.chung@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/mmc.h> + +static char *S5P_NAME = "SAMSUNG SDHCI"; +static void s5p_sdhci_set_control_reg(struct sdhci_host *host) +{ + unsigned long val, ctrl; + /* + * SELCLKPADDS[17:16] + * 00 = 2mA + * 01 = 4mA + * 10 = 7mA + * 11 = 9mA + */ + sdhci_writel(host, SDHCI_CTRL4_DRIVE_MASK(0x3), SDHCI_CONTROL4); + + val = sdhci_readl(host, SDHCI_CONTROL2); + val &= SDHCI_CTRL2_SELBASECLK_SHIFT; + + val |= SDHCI_CTRL2_ENSTAASYNCCLR | + SDHCI_CTRL2_ENCMDCNFMSK | + SDHCI_CTRL2_ENFBCLKRX | + SDHCI_CTRL2_ENCLKOUTHOLD; + + sdhci_writel(host, val, SDHCI_CONTROL2); + + /* + * FCSEL3[31] FCSEL2[23] FCSEL1[15] FCSEL0[7] + * FCSel[1:0] : Rx Feedback Clock Delay Control + * Inverter delay means10ns delay if SDCLK 50MHz setting + * 01 = Delay1 (basic delay) + * 11 = Delay2 (basic delay + 2ns) + * 00 = Delay3 (inverter delay) + * 10 = Delay4 (inverter delay + 2ns) + */ + val = SDHCI_CTRL3_FCSEL3 | SDHCI_CTRL3_FCSEL1; + sdhci_writel(host, val, SDHCI_CONTROL3); + + /* + * SELBASECLK[5:4] + * 00/01 = HCLK + * 10 = EPLL + * 11 = XTI or XEXTCLK + */ + ctrl = sdhci_readl(host, SDHCI_CONTROL2); + ctrl &= ~SDHCI_CTRL2_SELBASECLK_MASK(0x3); + ctrl |= SDHCI_CTRL2_SELBASECLK_MASK(0x2); + sdhci_writel(host, ctrl, SDHCI_CONTROL2); +} + +int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) +{ + struct sdhci_host *host = NULL; + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdhci__host malloc fail!\n"); + return 1; + } + + host->name = S5P_NAME; + host->ioaddr = (void *)regbase; + host->quirks = quirks; + + host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + if (quirks & SDHCI_QUIRK_REG32_RW) + host->version = sdhci_readl(host, SDHCI_HOST_VERSION - 2) >> 16; + else + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + + host->host_caps = MMC_MODE_HC; + + add_sdhci(host, max_clk, min_clk); + return 0; +} diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 0dd08b9..962633b 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -338,6 +338,9 @@ void sdhci_set_ios(struct mmc *mmc) u32 ctrl; struct sdhci_host *host = (struct sdhci_host *)mmc->priv;
+ if (host->set_control_reg) + host->set_control_reg(host); + if (mmc->clock != host->clock) sdhci_set_clock(mmc, mmc->clock);
@@ -361,6 +364,9 @@ void sdhci_set_ios(struct mmc *mmc) else ctrl &= ~SDHCI_CTRL_HISPD;
+ if (host->quirks & SDHCI_QUIRK_NO_HISPD_BIT) + ctrl &= ~SDHCI_CTRL_HISPD; + sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL); }
@@ -444,9 +450,15 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) mmc->voltages |= MMC_VDD_29_30 | MMC_VDD_30_31; if (caps & SDHCI_CAN_VDD_180) mmc->voltages |= MMC_VDD_165_195; + + if (host->quirks & SDHCI_QUIRK_BROKEN_VOLTAGE) + mmc->voltages |= host->voltages; + mmc->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; if (caps & SDHCI_CAN_DO_8BIT) mmc->host_caps |= MMC_MODE_8BIT; + if (host->host_caps) + mmc->host_caps |= host->host_caps;
sdhci_reset(host, SDHCI_RESET_ALL); mmc_register(mmc); diff --git a/include/sdhci.h b/include/sdhci.h index 800f9d9..435f945 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -216,6 +216,8 @@ */ #define SDHCI_QUIRK_32BIT_DMA_ADDR (1 << 0) #define SDHCI_QUIRK_REG32_RW (1 << 1) +#define SDHCI_QUIRK_NO_HISPD_BIT (1 << 2) +#define SDHCI_QUIRK_BROKEN_VOLTAGE (1 << 3)
/* to make gcc happy */ struct sdhci_host; @@ -240,10 +242,14 @@ struct sdhci_host { char *name; void *ioaddr; unsigned int quirks; + unsigned int host_caps; unsigned int version; unsigned int clock; struct mmc *mmc; const struct sdhci_ops *ops; + + void (*set_control_reg)(struct sdhci_host *host); + uint voltages; };
#ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS
Jaehoon Chung
