[RFC] riscv: (visionfive2:) device tree binding for riscv_timer
following the existing device tree binding[1], here is a draft to use it in drivers/timer/riscv_timer.c. This would also fix the regression we see with commit 55171aedda8 ("dm: Emit the arch_cpu_init_dm() even only before relocation"), at least on the VisionFive2, as sketched out below. The device tree addition suits the Linux kernel dirver
| riscv-timer: riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [3]
The of_match, along with the "timebase-frequency" property, provides a working timer (again) on the VF2.
If this is the way to go, I'll turn this into a nicer patch series. Comments welcome!
Torsten
[1] linux/Documentation/devicetree/bindings/timer/riscv,timer.yaml --- arch/riscv/dts/jh7110.dtsi | 10 ++++++++++ configs/starfive_visionfive2_defconfig | 1 - drivers/timer/riscv_timer.c | 21 ++++++++++++++++++--- 3 files changed, 28 insertions(+), 4 deletions(-)
diff --git a/drivers/timer/riscv_timer.c b/drivers/timer/riscv_timer.c index 3627ed79b8..03dda12f73 100644 --- a/drivers/timer/riscv_timer.c +++ b/drivers/timer/riscv_timer.c @@ -13,6 +13,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <fdt_support.h> #include <timer.h> #include <asm/csr.h>
@@ -53,9 +54,18 @@ u64 notrace timer_early_get_count(void) static int riscv_timer_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); - /* clock frequency was passed from the cpu driver as driver data */ - uc_priv->clock_rate = dev->driver_data; + u32 rate = dev->driver_data; + + if (!rate && gd->fdt_blob) { /* not called from CPU driver? */ + rate = fdt_getprop_u32_default(gd->fdt_blob, + "/cpus", "timebase-frequency", 0); + } + uc_priv->clock_rate = rate; + + /* timer uclass post_probe will later fail with -EINVAL. Hint at the cause! */ + if (!rate) + log_err("riscv_timer_probe with clock rate 0\n");
return 0; } @@ -64,10 +74,15 @@ static const struct timer_ops riscv_timer_ops = { .get_count = riscv_timer_get_count, };
+static const struct udevice_id riscv_timer_ids[] = { + { .compatible = "riscv,timer", }, + { } +}; + U_BOOT_DRIVER(riscv_timer) = { .name = "riscv_timer", .id = UCLASS_TIMER, + .of_match = of_match_ptr(riscv_timer_ids), .probe = riscv_timer_probe, .ops = &riscv_timer_ops, - .flags = DM_FLAG_PRE_RELOC, }; diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi index c61730e8d1..9944f261b3 100644 --- a/arch/riscv/dts/jh7110.dtsi +++ b/arch/riscv/dts/jh7110.dtsi @@ -6,6 +6,7 @@ /dts-v1/; #include <dt-bindings/clock/starfive,jh7110-crg.h> #include <dt-bindings/reset/starfive,jh7110-crg.h> +#include <dt-bindings/interrupt-controller/riscv-hart.h>
/ { compatible = "starfive,jh7110"; @@ -204,6 +205,15 @@ }; };
+ timer { + compatible = "riscv,timer"; + interrupts-extended = <&cpu0_intc HART_INT_S_TIMER>, + <&cpu1_intc HART_INT_S_TIMER>, + <&cpu2_intc HART_INT_S_TIMER>, + <&cpu3_intc HART_INT_S_TIMER>, + <&cpu4_intc HART_INT_S_TIMER>; + }; + osc: oscillator { compatible = "fixed-clock"; clock-output-names = "osc"; diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index 570a1f53a1..3a213b2601 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -102,4 +102,3 @@ CONFIG_PINCTRL_STARFIVE=y # CONFIG_RAM_SIFIVE is not set CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y -CONFIG_TIMER_EARLY=y
Torsten Duwe
