[U-Boot] [PATCH v2 0/5] ARM: Allwinner sun7i (A20) USB Host EHCI support
This patch series adds USB Host EHCI support to the sun7i SoC. It was tested on Cubietruck. Now you could boot from a USB stick or use a compatible Ethernet dongle to add a second Ethernet port in U-Boot.
ehci-sunxi.c contains some code for poking GPIOs. This code will go away once [1] is applied against upstream. For now this patch series is self-contained and has no dependencies.
Best, Roman Byshko
Changes since v1: - fixed erroneous copyright author - used SPDX tag instead of the full license - used setbits_le32/clrbits_le32 instead of direct bit poking - usage of setbits_le32/clrbits_le32 automatically fixed bug where usbc_bit was clobbered unintentionally - added more info about commented out gpio_direction_output, it will be used once [1] is applied against upstream
[1] http://patchwork.ozlabs.org/patch/356566/
Roman Byshko (5): sunxi: add defines to control USB Host clocks/resets sunxi: add USB EHCI driver sunxi: add USB options to configs sun7i: add USB EHCI configuration sun7i: cubietruck: enable USB EHCI
arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 4 + boards.cfg | 2 +- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-sunxi.c | 212 ++++++++++++++++++++++++++ include/configs/sun7i.h | 8 + include/configs/sunxi-common.h | 6 + 6 files changed, 232 insertions(+), 1 deletion(-) create mode 100644 drivers/usb/host/ehci-sunxi.c
Signed-off-by: Roman Byshko rbyshko@gmail.com --- arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun4i.h b/arch/arm/include/asm/arch-sunxi/clock_sun4i.h index 928f3f2..fe7348a 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun4i.h @@ -253,4 +253,8 @@ struct sunxi_ccm_reg { #define CCM_GMAC_CTRL_GPIT_MII (0x0 << 2) #define CCM_GMAC_CTRL_GPIT_RGMII (0x1 << 2)
+#define CCM_USB_CTRL_PHY1_RST (0x1 << 1) +#define CCM_USB_CTRL_PHY2_RST (0x1 << 2) +#define CCM_USB_CTRL_PHYGATE (0x1 << 8) + #endif /* _SUNXI_CLOCK_SUN4I_H */
Acked-by: Ian Campbell ijc@hellion.org.uk
Signed-off-by: Roman Byshko rbyshko@gmail.com --- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-sunxi.c | 212 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 213 insertions(+) create mode 100644 drivers/usb/host/ehci-sunxi.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 04c1a64..c4f5157 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o obj-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o obj-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o +obj-$(CONFIG_USB_EHCI_SUNXI) += ehci-sunxi.o obj-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o obj-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o obj-$(CONFIG_USB_EHCI_RMOBILE) += ehci-rmobile.o diff --git a/drivers/usb/host/ehci-sunxi.c b/drivers/usb/host/ehci-sunxi.c new file mode 100644 index 0000000..8e2baa9 --- /dev/null +++ b/drivers/usb/host/ehci-sunxi.c @@ -0,0 +1,212 @@ +/* + * Copyright (C) 2014 Roman Byshko + * + * Roman Byshko rbyshko@gmail.com + * + * Based on code from + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/io.h> +#include <common.h> +#include "ehci.h" + +#define BIT(x) (1 << (x)) + +#define SUNXI_USB1_IO_BASE 0x01c14000 +#define SUNXI_USB2_IO_BASE 0x01c1c000 + +#define SUNXI_USB_PMU_IRQ_ENABLE 0x800 +#define SUNXI_USB_CSR 0x01c13404 +#define SUNXI_USB_PASSBY_EN 1 + +#define SUNXI_EHCI_AHB_ICHR8_EN BIT(10) +#define SUNXI_EHCI_AHB_INCR4_BURST_EN BIT(9) +#define SUNXI_EHCI_AHB_INCRX_ALIGN_EN BIT(8) +#define SUNXI_EHCI_ULPI_BYPASS_EN BIT(0) + +static struct sunxi_ehci_hcd { + void *ehci_base; + struct usb_hcd *hcd; + int usb_rst_mask; + int ahb_clk_mask; + int gpio_vbus; + void *csr; + int irq; + int id; +} sunxi_echi_hcd[CONFIG_USB_MAX_CONTROLLER_COUNT] = { + [0] = { + .ehci_base = (void *) SUNXI_USB1_IO_BASE, + .usb_rst_mask = CCM_USB_CTRL_PHY1_RST, + .ahb_clk_mask = BIT(AHB_GATE_OFFSET_USB_EHCI0), + .gpio_vbus = CONFIG_SUNXI_USB_VBUS0_GPIO, + .csr = (void*) SUNXI_USB_CSR, + .irq = 39, + .id = 1, + }, +#if (CONFIG_USB_MAX_CONTROLLER_COUNT > 1) + [1] = { + .ehci_base = (void *) SUNXI_USB2_IO_BASE, + .usb_rst_mask = CCM_USB_CTRL_PHY2_RST, + .ahb_clk_mask = BIT(AHB_GATE_OFFSET_USB_EHCI1), + .gpio_vbus = CONFIG_SUNXI_USB_VBUS1_GPIO, + .csr = (void*) SUNXI_USB_CSR, + .irq = 40, + .id = 2, + } +#endif +}; + +static int sunxi_gpio_output(u32 pin, u32 val) +{ + u32 bank = GPIO_BANK(pin); + u32 num = GPIO_NUM(pin); + struct sunxi_gpio *pio = + &((struct sunxi_gpio_reg *)SUNXI_PIO_BASE)->gpio_bank[bank]; + + if (val) + setbits_le32(&pio->dat, 0x1 << num); + else + clrbits_le32(&pio->dat, 0x1 << num); + + return 0; +} + +static void usb_phy_write(struct sunxi_ehci_hcd *sunxi_ehci, int addr, + int data, int len) +{ + int temp = 0, j = 0, usbc_bit = 0; + void *dest = sunxi_ehci->csr; + + usbc_bit = BIT(sunxi_ehci->id * 2); + for (j = 0; j < len; j++) { + /* set the bit address to be written */ + clrbits_le32(dest, 0xff << 8); + setbits_le32(dest, (addr + j) << 8); + + clrbits_le32(dest, usbc_bit); + /* set data bit */ + if (data & 0x1) + setbits_le32(dest, BIT(7)); + else + clrbits_le32(dest, BIT(7)); + + setbits_le32(dest, usbc_bit); + + clrbits_le32(dest, usbc_bit); + + data >>= 1; + } +} + +static void sunxi_usb_phy_init(struct sunxi_ehci_hcd *sunxi_ehci) +{ + /* The following comments are machine + * translated from Chinese, you have been warned! + */ + + /* adjust PHY's magnitude and rate */ + usb_phy_write(sunxi_ehci, 0x20, 0x14, 5); + + /* threshold adjustment disconnect */ + usb_phy_write(sunxi_ehci, 0x2a, 3, 2); + + return; +} + +static void sunxi_usb_passby(struct sunxi_ehci_hcd *sunxi_ehci, int enable) +{ + unsigned long reg_value = 0; + unsigned long bits = 0; + void *addr = sunxi_ehci->ehci_base + SUNXI_USB_PMU_IRQ_ENABLE; + + bits = SUNXI_EHCI_AHB_ICHR8_EN | + SUNXI_EHCI_AHB_INCR4_BURST_EN | + SUNXI_EHCI_AHB_INCRX_ALIGN_EN | + SUNXI_EHCI_ULPI_BYPASS_EN; + + if (enable) + setbits_le32(addr, bits); + else + clrbits_le32(addr, bits); + + return; +} + +static void sunxi_ehci_enable(struct sunxi_ehci_hcd *sunxi_ehci) +{ + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + setbits_le32(&ccm->usb_clk_cfg, sunxi_ehci->usb_rst_mask); + setbits_le32(&ccm->ahb_gate0, sunxi_ehci->ahb_clk_mask); + + sunxi_usb_phy_init(sunxi_ehci); + + sunxi_usb_passby(sunxi_ehci, SUNXI_USB_PASSBY_EN); + + /* this should be used instead of next two lines if + * sunxi_gpio.c is merged upstream + * gpio_direction_output(sunxi_ehci->gpio_vbus, 1); */ + sunxi_gpio_set_cfgpin(sunxi_ehci->gpio_vbus, SUNXI_GPIO_OUTPUT); + sunxi_gpio_output(sunxi_ehci->gpio_vbus, 1); +} + +static void sunxi_ehci_disable(struct sunxi_ehci_hcd *sunxi_ehci) +{ + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + /* this should be used instead of next two lines if + * sunxi_gpio.c is merged upstream + * gpio_direction_output(sunxi_ehci->gpio_vbus, 0); */ + sunxi_gpio_set_cfgpin(sunxi_ehci->gpio_vbus, SUNXI_GPIO_OUTPUT); + sunxi_gpio_output(sunxi_ehci->gpio_vbus, 0); + + sunxi_usb_passby(sunxi_ehci, !SUNXI_USB_PASSBY_EN); + + clrbits_le32(&ccm->ahb_gate0, sunxi_ehci->ahb_clk_mask); + clrbits_le32(&ccm->usb_clk_cfg, sunxi_ehci->usb_rst_mask); +} + +int ehci_hcd_init(int index, enum usb_init_type init, struct ehci_hccr **hccr, + struct ehci_hcor **hcor) +{ + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_ehci_hcd *sunxi_ehci = &sunxi_echi_hcd[index]; + + /* enable common PHY only once */ + if (index == 0) + setbits_le32(&ccm->usb_clk_cfg, CCM_USB_CTRL_PHYGATE); + + sunxi_ehci_enable(sunxi_ehci); + + *hccr = sunxi_ehci->ehci_base; + + *hcor = (struct ehci_hcor *)((uint32_t) *hccr + + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + + debug("sunxi-ehci: init hccr %x and hcor %x hc_length %d\n", + (uint32_t)*hccr, (uint32_t)*hcor, + (uint32_t)HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + + return 0; +} + +int ehci_hcd_stop(int index) +{ + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_ehci_hcd *sunxi_ehci = &sunxi_echi_hcd[index]; + + sunxi_ehci_disable(sunxi_ehci); + + /* disable common PHY only once, for the last hcd */ + if (index == CONFIG_USB_MAX_CONTROLLER_COUNT - 1) + clrbits_le32(&ccm->usb_clk_cfg, CCM_USB_CTRL_PHYGATE); + + return 0; +}
- Copyright (C) 2014 Roman Byshko
- Roman Byshko rbyshko@gmail.com
Are Roman Byshko and "arokux arokux@gmail.com" the same person then? If not then who wrote this code?
Ian.
Yes Arokux is Roman Byshko's alias (*), he prefers to operate under an alias usually, but he knows he needs to use his real name for code submissions to u-boot / the upstream kernel.
Regards,
Hans
*) To the best of my knowledge I've a mail from arokux@gmail.com stating this (from when I was working on upstreaming the usb support for the kernel).
Ühel kenal päeval, T, 15.07.2014 kell 23:56, kirjutas Roman Byshko:
- Based on code from
- Allwinner Technology Co., Ltd. <www.allwinnertech.com>
Dupe ^^
On Tuesday, July 15, 2014 at 11:56:49 PM, Roman Byshko wrote:
Please start writing commit messages for the patches. [...]
Please remove this code obfuscation, just use (1 << n) in the definitions below.
Please implement an get_io_base() or such function, since these addresses are likely to change eventually.
- void *ehci_base;
- struct usb_hcd *hcd;
- int usb_rst_mask;
- int ahb_clk_mask;
- int gpio_vbus;
- void *csr;
- int irq;
- int id;
No need to use this [CONFIG...] , just use [] and the compiler will calculate the size.
- [0] = {
No need for such explicit enumeration.
.irq = 39,
.id = 1,
- [1] = {
.irq = 40,
.id = 2,
+#endif +};
- u32 bank = GPIO_BANK(pin);
- u32 num = GPIO_NUM(pin);
- struct sunxi_gpio *pio =
Is this still an USB driver or is this now a GPIO driver ?
- if (val)
- else
- struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
- setbits_le32(&ccm->usb_clk_cfg, sunxi_ehci->usb_rst_mask);
- setbits_le32(&ccm->ahb_gate0, sunxi_ehci->ahb_clk_mask);
- sunxi_usb_phy_init(sunxi_ehci);
- sunxi_usb_passby(sunxi_ehci, SUNXI_USB_PASSBY_EN);
- /* this should be used instead of next two lines if
Please fix the comment ( http://www.denx.de/wiki/U-Boot/CodingStyle )
- sunxi_gpio_set_cfgpin(sunxi_ehci->gpio_vbus, SUNXI_GPIO_OUTPUT);
- sunxi_gpio_output(sunxi_ehci->gpio_vbus, 1);
DTTO.
- sunxi_gpio_output(sunxi_ehci->gpio_vbus, 0);
- sunxi_usb_passby(sunxi_ehci, !SUNXI_USB_PASSBY_EN);
- clrbits_le32(&ccm->ahb_gate0, sunxi_ehci->ahb_clk_mask);
- clrbits_le32(&ccm->usb_clk_cfg, sunxi_ehci->usb_rst_mask);
- struct sunxi_ehci_hcd *sunxi_ehci = &sunxi_echi_hcd[index];
- /* enable common PHY only once */
- if (index == 0)
This would fail if I enabled only controller #1 , which is perfectly legal operation. Just add a counter here and disable the clock upon last call of ehci_hcd_stop() .
- sunxi_ehci_enable(sunxi_ehci);
- *hccr = sunxi_ehci->ehci_base;
- *hcor = (struct ehci_hcor *)((uint32_t) *hccr
- debug("sunxi-ehci: init hccr %x and hcor %x hc_length %d\n",
- sunxi_ehci_disable(sunxi_ehci);
- /* disable common PHY only once, for the last hcd */
- if (index == CONFIG_USB_MAX_CONTROLLER_COUNT - 1)
On Tue, 2014-07-15 at 23:56 +0200, Roman Byshko wrote: [...]
Please can you base v3 on: git://git.denx.de/u-boot-sunxi.git master
This includes the gpio stuff which you need here.
Cheers, Ian.
Signed-off-by: Roman Byshko rbyshko@gmail.com --- include/configs/sunxi-common.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5d72d62..c7746bb 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -181,6 +181,12 @@ #define CONFIG_BOOTP_SEND_HOSTNAME #endif
+#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1 +#define CONFIG_USB_STORAGE +#endif + #if !defined CONFIG_ENV_IS_IN_MMC && \ !defined CONFIG_ENV_IS_IN_NAND && \ !defined CONFIG_ENV_IS_IN_FAT && \
On Tuesday, July 15, 2014 at 11:56:50 PM, Roman Byshko wrote:
I will stop reviewing here until all these patches have proper commit message.
Best regards, Marek Vasut
Signed-off-by: Roman Byshko rbyshko@gmail.com --- include/configs/sun7i.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/sun7i.h b/include/configs/sun7i.h index 9b693f7..0a1d83e 100644 --- a/include/configs/sun7i.h +++ b/include/configs/sun7i.h @@ -16,6 +16,14 @@
#define CONFIG_SYS_PROMPT "sun7i# "
+#ifdef CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_SUNXI + +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_SUNXI_USB_VBUS0_GPIO 230 +#define CONFIG_SUNXI_USB_VBUS1_GPIO 227 +#endif + /* * Include common sunxi configuration where most the settings are */
Signed-off-by: Roman Byshko rbyshko@gmail.com --- boards.cfg | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boards.cfg b/boards.cfg index 1ba2081..fda3a08 100644 --- a/boards.cfg +++ b/boards.cfg @@ -377,7 +377,7 @@ Active arm armv7 rmobile renesas lager Active arm armv7 s5pc1xx samsung goni s5p_goni - Robert Baldyga r.baldyga@samsung.com Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - -Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,SUNXI_GMAC,RGMII - +Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,SUNXI_GMAC,RGMII,USB_EHCI - Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,SUNXI_GMAC,RGMII - Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org Active arm armv7 u8500 st-ericsson u8500 u8500_href - -
Hi Marex,
I'm sorry I forgot to CC you on my submission. It would be great, if you can take a look at it.
Best, Roman
On Wednesday, July 16, 2014 at 12:05:34 AM, Roman B. wrote:
Hi Marex,
Thanks for the ping.
participants (6)
Hans de Goede
Ian Campbell
Priit Laes
Roman B.
Roman Byshko
