[U-Boot] [RFC] [PATCH 0/3] MPC8349EMDS: Using mpc83xx generic pci infrastructure for PCI Agent mode
Hello u-boot-users,
This is my attempt at adding CONFIG_PCISLAVE support to the MPC8349EMDS board. I noticed that there was some shared infrastructure for the PCI controller in the 83xx-series CPU's, so I removed all of the old code, and used the infrastructure instead.
I have boot tested the board in host mode (using the 83XX_GENERIC_PCI infrastructure) but I do not have the IO Expander board, so I cannot test that PCI cards still work. Linux happily initializes the PCI interface, and lspci -vvv is identical before and after my patch.
I copied the configuration bit unlocking routine from other boards support for CONFIG_PCISLAVE. I added it to the shared infrastructure so it would have access to the static pci_controller that is set up and used by the other infrastructure code.
I then went ahead and added support for CONFIG_PCISLAVE to the MPC8349EMDS board. I have boot tested the board in a desktop pc. I have booted Linux on the board in this mode (with CONFIG_PCI=n so it does not try to re-initialize other PCI devices on the bus. Linux is only set up for Host-mode PCI), and have successfully developed both U-Boot and Linux drivers that implement a virtual serial port and virtual ethernet device (between the host pc and the MPC8349EMDS board) using only the PCI bus and the MPC8349EMDS message registers. I'm happy to post them if there is any interest.
I'm looking for suggestions and improvements so that these can be accepted into the U-Boot source.
Thanks, Ira
Change the MPC8349EMDS board to use the generic PCI initialization code for the mpc83xx cpu.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- board/freescale/mpc8349emds/pci.c | 377 ++++++------------------------------- include/configs/MPC8349EMDS.h | 4 +- 2 files changed, 63 insertions(+), 318 deletions(-)
diff --git a/board/freescale/mpc8349emds/pci.c b/board/freescale/mpc8349emds/pci.c index ecc67b6..a783beb 100644 --- a/board/freescale/mpc8349emds/pci.c +++ b/board/freescale/mpc8349emds/pci.c @@ -20,58 +20,62 @@ */
#include <asm/mmu.h> +#include <asm/io.h> #include <common.h> -#include <asm/global_data.h> +#include <mpc83xx.h> #include <pci.h> -#include <asm/mpc8349_pci.h> #include <i2c.h> -#if defined(CONFIG_OF_LIBFDT) -#include <libfdt.h> -#include <fdt_support.h> -#endif - +#include <asm/fsl_i2c.h>
DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_PCI
-/* System RAM mapped to PCI space */ -#define CONFIG_PCI_SYS_MEM_BUS CFG_SDRAM_BASE -#define CONFIG_PCI_SYS_MEM_PHYS CFG_SDRAM_BASE - -#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_mpc8349emds_config_table[] = { - {PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_IDSEL_NUMBER, PCI_ANY_ID, - pci_cfgfunc_config_device, {PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER - } +static struct pci_region pci1_regions[] = { + { + bus_start: CFG_PCI1_MEM_BASE, + phys_start: CFG_PCI1_MEM_PHYS, + size: CFG_PCI1_MEM_SIZE, + flags: PCI_REGION_MEM | PCI_REGION_PREFETCH + }, + { + bus_start: CFG_PCI1_IO_BASE, + phys_start: CFG_PCI1_IO_PHYS, + size: CFG_PCI1_IO_SIZE, + flags: PCI_REGION_IO + }, + { + bus_start: CFG_PCI1_MMIO_BASE, + phys_start: CFG_PCI1_MMIO_PHYS, + size: CFG_PCI1_MMIO_SIZE, + flags: PCI_REGION_MEM }, - {} }; -#endif
-static struct pci_controller pci_hose[] = { - { -#ifndef CONFIG_PCI_PNP - config_table:pci_mpc8349emds_config_table, -#endif - }, - { -#ifndef CONFIG_PCI_PNP - config_table:pci_mpc8349emds_config_table, -#endif - } +#ifdef CONFIG_MPC83XX_PCI2 +static struct pci_region pci2_regions[] = { + { + bus_start: CFG_PCI2_MEM_BASE, + phys_start: CFG_PCI2_MEM_PHYS, + size: CFG_PCI2_MEM_SIZE, + flags: PCI_REGION_MEM | PCI_REGION_PREFETCH + }, + { + bus_start: CFG_PCI2_IO_BASE, + phys_start: CFG_PCI2_IO_PHYS, + size: CFG_PCI2_IO_SIZE, + flags: PCI_REGION_IO + }, + { + bus_start: CFG_PCI2_MMIO_BASE, + phys_start: CFG_PCI2_MMIO_PHYS, + size: CFG_PCI2_MMIO_SIZE, + flags: PCI_REGION_MEM + }, }; +#endif
-/************************************************************************** - * - * pib_init() -- initialize the PCA9555PW IO expander on the PIB board - * - */ -void -pib_init(void) +void pib_init(void) { u8 val8, orig_i2c_bus; /* @@ -128,299 +132,38 @@ pib_init(void) i2c_set_bus_num(orig_i2c_bus); }
-/************************************************************************** - * pci_init_board() - * - * NOTICE: PCI2 is not currently supported - * - */ -void -pci_init_board(void) +void pci_init_board(void) { - volatile immap_t * immr; - volatile clk83xx_t * clk; - volatile law83xx_t * pci_law; - volatile pot83xx_t * pci_pot; - volatile pcictrl83xx_t * pci_ctrl; - volatile pciconf83xx_t * pci_conf; - u16 reg16; - u32 reg32; - u32 dev; - struct pci_controller * hose; - - immr = (immap_t *)CFG_IMMR; - clk = (clk83xx_t *)&immr->clk; - pci_law = immr->sysconf.pcilaw; - pci_pot = immr->ios.pot; - pci_ctrl = immr->pci_ctrl; - pci_conf = immr->pci_conf; - - hose = &pci_hose[0]; + volatile immap_t *immr = (volatile immap_t *)CFG_IMMR; + volatile clk83xx_t *clk = (volatile clk83xx_t *)&immr->clk; + volatile law83xx_t *pci_law = immr->sysconf.pcilaw; +#ifndef CONFIG_MPC83XX_PCI2 + struct pci_region *reg[] = { pci1_regions }; +#else + struct pci_region *reg[] = { pci1_regions, pci2_regions }; +#endif
+ /* initialize the PCA9555PW IO expander on the PIB board */ pib_init();
- /* - * Configure PCI controller and PCI_CLK_OUTPUT both in 66M mode - */ - - reg32 = clk->occr; - udelay(2000); + /* Enable all 8 PCI_CLK_OUTPUTS */ clk->occr = 0xff000000; udelay(2000);
- /* - * Release PCI RST Output signal - */ - pci_ctrl[0].gcr = 0; - udelay(2000); - pci_ctrl[0].gcr = 1; - -#ifdef CONFIG_MPC83XX_PCI2 - pci_ctrl[1].gcr = 0; - udelay(2000); - pci_ctrl[1].gcr = 1; -#endif - - /* We need to wait at least a 1sec based on PCI specs */ - { - int i; - - for (i = 0; i < 1000; ++i) - udelay (1000); - } - - /* - * Configure PCI Local Access Windows - */ + /* Configure PCI Local Access Windows */ pci_law[0].bar = CFG_PCI1_MEM_PHYS & LAWBAR_BAR; pci_law[0].ar = LAWAR_EN | LAWAR_SIZE_1G;
pci_law[1].bar = CFG_PCI1_IO_PHYS & LAWBAR_BAR; pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_4M;
- /* - * Configure PCI Outbound Translation Windows - */ - - /* PCI1 mem space - prefetch */ - pci_pot[0].potar = (CFG_PCI1_MEM_BASE >> 12) & POTAR_TA_MASK; - pci_pot[0].pobar = (CFG_PCI1_MEM_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[0].pocmr = POCMR_EN | POCMR_PREFETCH_EN | (POCMR_CM_256M & POCMR_CM_MASK); - - /* PCI1 IO space */ - pci_pot[1].potar = (CFG_PCI1_IO_BASE >> 12) & POTAR_TA_MASK; - pci_pot[1].pobar = (CFG_PCI1_IO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[1].pocmr = POCMR_EN | POCMR_IO | (POCMR_CM_1M & POCMR_CM_MASK); - - /* PCI1 mmio - non-prefetch mem space */ - pci_pot[2].potar = (CFG_PCI1_MMIO_BASE >> 12) & POTAR_TA_MASK; - pci_pot[2].pobar = (CFG_PCI1_MMIO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[2].pocmr = POCMR_EN | (POCMR_CM_256M & POCMR_CM_MASK); - - /* - * Configure PCI Inbound Translation Windows - */ - - /* we need RAM mapped to PCI space for the devices to - * access main memory */ - pci_ctrl[0].pitar1 = 0x0; - pci_ctrl[0].pibar1 = 0x0; - pci_ctrl[0].piebar1 = 0x0; - pci_ctrl[0].piwar1 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | PIWAR_WTT_SNOOP | (__ilog2(gd->ram_size) - 1); - - hose->first_busno = 0; - hose->last_busno = 0xff; - - /* PCI memory prefetch space */ - pci_set_region(hose->regions + 0, - CFG_PCI1_MEM_BASE, - CFG_PCI1_MEM_PHYS, - CFG_PCI1_MEM_SIZE, - PCI_REGION_MEM|PCI_REGION_PREFETCH); - - /* PCI memory space */ - pci_set_region(hose->regions + 1, - CFG_PCI1_MMIO_BASE, - CFG_PCI1_MMIO_PHYS, - CFG_PCI1_MMIO_SIZE, - PCI_REGION_MEM); - - /* PCI IO space */ - pci_set_region(hose->regions + 2, - CFG_PCI1_IO_BASE, - CFG_PCI1_IO_PHYS, - CFG_PCI1_IO_SIZE, - PCI_REGION_IO); - - /* System memory space */ - pci_set_region(hose->regions + 3, - CONFIG_PCI_SYS_MEM_BUS, - CONFIG_PCI_SYS_MEM_PHYS, - gd->ram_size, - PCI_REGION_MEM | PCI_REGION_MEMORY); - - hose->region_count = 4; - - pci_setup_indirect(hose, - (CFG_IMMR+0x8300), - (CFG_IMMR+0x8304)); - - pci_register_hose(hose); - - /* - * Write to Command register - */ - reg16 = 0xff; - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word (hose, dev, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_SERR | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY; - pci_hose_write_config_word(hose, dev, PCI_COMMAND, reg16); - - /* - * Clear non-reserved bits in status register. - */ - pci_hose_write_config_word(hose, dev, PCI_STATUS, 0xffff); - pci_hose_write_config_byte(hose, dev, PCI_LATENCY_TIMER, 0x80); - pci_hose_write_config_byte(hose, dev, PCI_CACHE_LINE_SIZE, 0x08); - -#ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Bus Dev VenId DevId Class Int\n"); -#endif - /* - * Hose scan. - */ - hose->last_busno = pci_hose_scan(hose); - -#ifdef CONFIG_MPC83XX_PCI2 - hose = &pci_hose[1]; - - /* - * Configure PCI Outbound Translation Windows - */ - - /* PCI2 mem space - prefetch */ - pci_pot[3].potar = (CFG_PCI2_MEM_BASE >> 12) & POTAR_TA_MASK; - pci_pot[3].pobar = (CFG_PCI2_MEM_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[3].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_PREFETCH_EN | (POCMR_CM_256M & POCMR_CM_MASK); - - /* PCI2 IO space */ - pci_pot[4].potar = (CFG_PCI2_IO_BASE >> 12) & POTAR_TA_MASK; - pci_pot[4].pobar = (CFG_PCI2_IO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[4].pocmr = POCMR_EN | POCMR_PCI2 | POCMR_IO | (POCMR_CM_1M & POCMR_CM_MASK); - - /* PCI2 mmio - non-prefetch mem space */ - pci_pot[5].potar = (CFG_PCI2_MMIO_BASE >> 12) & POTAR_TA_MASK; - pci_pot[5].pobar = (CFG_PCI2_MMIO_PHYS >> 12) & POBAR_BA_MASK; - pci_pot[5].pocmr = POCMR_EN | POCMR_PCI2 | (POCMR_CM_256M & POCMR_CM_MASK); - - /* - * Configure PCI Inbound Translation Windows - */ - - /* we need RAM mapped to PCI space for the devices to - * access main memory */ - pci_ctrl[1].pitar1 = 0x0; - pci_ctrl[1].pibar1 = 0x0; - pci_ctrl[1].piebar1 = 0x0; - pci_ctrl[1].piwar1 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | PIWAR_WTT_SNOOP | (__ilog2(gd->ram_size) - 1); - - hose->first_busno = pci_hose[0].last_busno + 1; - hose->last_busno = 0xff; - - /* PCI memory prefetch space */ - pci_set_region(hose->regions + 0, - CFG_PCI2_MEM_BASE, - CFG_PCI2_MEM_PHYS, - CFG_PCI2_MEM_SIZE, - PCI_REGION_MEM|PCI_REGION_PREFETCH); - - /* PCI memory space */ - pci_set_region(hose->regions + 1, - CFG_PCI2_MMIO_BASE, - CFG_PCI2_MMIO_PHYS, - CFG_PCI2_MMIO_SIZE, - PCI_REGION_MEM); - - /* PCI IO space */ - pci_set_region(hose->regions + 2, - CFG_PCI2_IO_BASE, - CFG_PCI2_IO_PHYS, - CFG_PCI2_IO_SIZE, - PCI_REGION_IO); - - /* System memory space */ - pci_set_region(hose->regions + 3, - CONFIG_PCI_SYS_MEM_BUS, - CONFIG_PCI_SYS_MEM_PHYS, - gd->ram_size, - PCI_REGION_MEM | PCI_REGION_MEMORY); - - hose->region_count = 4; - - pci_setup_indirect(hose, - (CFG_IMMR+0x8380), - (CFG_IMMR+0x8384)); - - pci_register_hose(hose); - - /* - * Write to Command register - */ - reg16 = 0xff; - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word (hose, dev, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_SERR | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY; - pci_hose_write_config_word(hose, dev, PCI_COMMAND, reg16); - - /* - * Clear non-reserved bits in status register. - */ - pci_hose_write_config_word(hose, dev, PCI_STATUS, 0xffff); - pci_hose_write_config_byte(hose, dev, PCI_LATENCY_TIMER, 0x80); - pci_hose_write_config_byte(hose, dev, PCI_CACHE_LINE_SIZE, 0x08); + udelay(2000);
- /* - * Hose scan. - */ - hose->last_busno = pci_hose_scan(hose); +#ifndef CONFIG_MPC83XX_PCI2 + mpc83xx_pci_init(1, reg, 0); +#else + mpc83xx_pci_init(2, reg, 0); #endif - }
-#if defined(CONFIG_OF_LIBFDT) -void ft_pci_setup(void *blob, bd_t *bd) -{ - int nodeoffset; - int tmp[2]; - const char *path; - - nodeoffset = fdt_path_offset(blob, "/aliases"); - if (nodeoffset >= 0) { - path = fdt_getprop(blob, nodeoffset, "pci0", NULL); - if (path) { - tmp[0] = cpu_to_be32(pci_hose[0].first_busno); - tmp[1] = cpu_to_be32(pci_hose[0].last_busno); - do_fixup_by_path(blob, path, "bus-range", - &tmp, sizeof(tmp), 1); - - tmp[0] = cpu_to_be32(gd->pci_clk); - do_fixup_by_path(blob, path, "clock-frequency", - &tmp, sizeof(tmp[0]), 1); - } -#ifdef CONFIG_MPC83XX_PCI2 - path = fdt_getprop(blob, nodeoffset, "pci1", NULL); - if (path) { - tmp[0] = cpu_to_be32(pci_hose[0].first_busno); - tmp[1] = cpu_to_be32(pci_hose[0].last_busno); - do_fixup_by_path(blob, path, "bus-range", - &tmp, sizeof(tmp), 1); - - tmp[0] = cpu_to_be32(gd->pci_clk); - do_fixup_by_path(blob, path, "clock-frequency", - &tmp, sizeof(tmp[0]), 1); - } -#endif - } -} -#endif /* CONFIG_OF_LIBFDT */ #endif /* CONFIG_PCI */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index a53f5cd..d659a15 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -406,6 +406,8 @@
#define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_83XX_GENERIC_PCI +#define CONFIG_83XX_PCI_STREAMING
#undef CONFIG_EEPRO100 #undef CONFIG_TULIP @@ -417,7 +419,7 @@ #endif
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CFG_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */ +#define CFG_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */
This adds a helper function to unlock the PCI configuration bit, so that any extra PCI setup (such as outbound windows, etc.) can be done after using the 83XX_GENERIC_PCI code to set up the PCI bus.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- cpu/mpc83xx/pci.c | 26 ++++++++++++++++++++++++++ 1 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc83xx/pci.c b/cpu/mpc83xx/pci.c index adabf7a..c3ec5f8 100644 --- a/cpu/mpc83xx/pci.c +++ b/cpu/mpc83xx/pci.c @@ -167,6 +167,32 @@ void mpc83xx_pci_init(int num_buses, struct pci_region **reg, int warmboot) pci_init_bus(i, reg[i]); }
+#ifdef CONFIG_PCISLAVE + +#define PCI_FUNCTION_CONFIG 0x44 +#define PCI_FUNCTION_CFG_LOCK 0x20 + +/* + * Unlock the configuration bit so that the host system can begin booting + * + * This should be used after you have: + * 1) Called mpc83xx_pci_init() + * 2) Set up your inbound translation windows to the appropriate size + */ +void mpc83xx_pcislave_unlock(int bus) +{ + struct pci_controller *hose = &pci_hose[bus]; + u32 dev; + u16 reg16; + + /* Unlock configuration lock in PCI function configuration register */ + dev = PCI_BDF(hose->first_busno, 0, 0); + pci_hose_read_config_word (hose, dev, PCI_FUNCTION_CONFIG, ®16); + reg16 &= ~(PCI_FUNCTION_CFG_LOCK); + pci_hose_write_config_word (hose, dev, PCI_FUNCTION_CONFIG, reg16); +} +#endif + #if defined(CONFIG_OF_LIBFDT) void ft_pci_setup(void *blob, bd_t *bd) {
Add the ability for the MPC8349EMDS to run in PCI Agent mode, acting as a PCI card rather than a host computer.
Signed-off-by: Ira W. Snyder iws@ovro.caltech.edu --- board/freescale/mpc8349emds/mpc8349emds.c | 9 +++++ board/freescale/mpc8349emds/pci.c | 49 +++++++++++++++++++++++++++++ include/configs/MPC8349EMDS.h | 22 ++++++++++++- 3 files changed, 79 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 9a312c3..4c04f2c 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -165,6 +165,15 @@ int fixed_sdram(void)
int checkboard (void) { + /* + * Warning: do not read the BCSR registers here + * + * There is a timing bug in the 8349E and 8349EA BCSR code + * version 1.2 (read from BCSR 11) that will cause the CFI + * flash initialization code to overwrite BCSR 0, disabling + * the serial ports and gigabit ethernet + */ + puts("Board: Freescale MPC8349EMDS\n"); return 0; } diff --git a/board/freescale/mpc8349emds/pci.c b/board/freescale/mpc8349emds/pci.c index a783beb..9c19e30 100644 --- a/board/freescale/mpc8349emds/pci.c +++ b/board/freescale/mpc8349emds/pci.c @@ -75,6 +75,7 @@ static struct pci_region pci2_regions[] = { }; #endif
+#ifndef CONFIG_PCISLAVE void pib_init(void) { u8 val8, orig_i2c_bus; @@ -166,4 +167,52 @@ void pci_init_board(void) #endif }
+#else +void pci_init_board(void) +{ + volatile immap_t *immr = (volatile immap_t *)CFG_IMMR; + volatile clk83xx_t *clk = (volatile clk83xx_t *)&immr->clk; + volatile law83xx_t *pci_law = immr->sysconf.pcilaw; + volatile pcictrl83xx_t *pci_ctrl = &immr->pci_ctrl[0]; + struct pci_region *reg[] = { pci1_regions }; + + /* Enable all 8 PCI_CLK_OUTPUTS */ + clk->occr = 0xff000000; + udelay(2000); + + /* Configure PCI Local Access Windows */ + pci_law[0].bar = CFG_PCI1_MEM_PHYS & LAWBAR_BAR; + pci_law[0].ar = LAWAR_EN | LAWAR_SIZE_1G; + + pci_law[1].bar = CFG_PCI1_IO_PHYS & LAWBAR_BAR; + pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_4M; + + udelay(2000); + + mpc83xx_pci_init(1, reg, 0); + + /* Configure PCI Inbound Translation Windows (3 1MB windows) */ + pci_ctrl->pitar0 = 0x0; + pci_ctrl->pibar0 = 0x0; + pci_ctrl->piwar0 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | + PIWAR_WTT_SNOOP | PIWAR_IWS_1M; + + pci_ctrl->pitar1 = 0x0; + pci_ctrl->pibar1 = 0x0; + pci_ctrl->piebar1 = 0x0; + pci_ctrl->piwar1 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | + PIWAR_WTT_SNOOP | PIWAR_IWS_1M; + + pci_ctrl->pitar2 = 0x0; + pci_ctrl->pibar2 = 0x0; + pci_ctrl->piebar2 = 0x0; + pci_ctrl->piwar2 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | + PIWAR_WTT_SNOOP | PIWAR_IWS_1M; + + /* Unlock the configuration bit */ + mpc83xx_pcislave_unlock(0); + printf("PCI: Agent mode enabled\n"); +} +#endif /* CONFIG_PCISLAVE */ + #endif /* CONFIG_PCI */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index d659a15..c8870b5 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -48,6 +48,11 @@ #define CONFIG_83XX_CLKIN 33000000 /* in Hz */ #endif
+#ifdef CONFIG_PCISLAVE +#define CONFIG_PCI +#define CONFIG_83XX_PCICLK 66666666 /* in Hz */ +#endif /* CONFIG_PCISLAVE */ + #ifndef CONFIG_SYS_CLK_FREQ #ifdef PCI_66M #define CONFIG_SYS_CLK_FREQ 66000000 @@ -575,6 +580,20 @@ HRCWL_CORE_TO_CSB_1X1) #endif
+#ifdef CONFIG_PCISLAVE +#define CFG_HRCW_HIGH (\ + HRCWH_PCI_AGENT |\ + HRCWH_64_BIT_PCI |\ + HRCWH_PCI1_ARBITER_DISABLE |\ + HRCWH_PCI2_ARBITER_DISABLE |\ + HRCWH_CORE_ENABLE |\ + HRCWH_FROM_0X00000100 |\ + HRCWH_BOOTSEQ_DISABLE |\ + HRCWH_SW_WATCHDOG_DISABLE |\ + HRCWH_ROM_LOC_LOCAL_16BIT |\ + HRCWH_TSEC1M_IN_GMII |\ + HRCWH_TSEC2M_IN_GMII ) +#else #if defined(PCI_64BIT) #define CFG_HRCW_HIGH (\ HRCWH_PCI_HOST |\ @@ -601,7 +620,8 @@ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ HRCWH_TSEC2M_IN_GMII ) -#endif +#endif /* PCI_64BIT */ +#endif /* CONFIG_PCISLAVE */
/* * System performance
On Fri, 22 Aug 2008 11:00:12 -0700 "Ira W. Snyder" iws@ovro.caltech.edu wrote:
Hello u-boot-users,
great!
none that I noticed; applied 1-3 out of 3.
Thanks,
Kim
Ira W. Snyder
Kim Phillips
