[U-Boot] [PATCH 1/3 v3] Add LZO decompressor support
This patch adds LZO decompression support to U-Boot. It is needed for the upcoming UBIFS support, since UBIFS uses LZO as default compressor/ decompressor. Since we only support read-only in UBIFS only the decompressor is needed.
All this is copied with minor changes from the current Linux kernel version (2.6.28-rc8).
This patch only implements this LZO decompressor support for PPC. Other platforms using UBIFS will have to add the required "include/asm/unaligned.h" as well. It should be fairly easy to copy this from the Linux source tree as I have done it for PPC in this patch.
Signed-off-by: Stefan Roese sr@denx.de --- Makefile | 1 + include/asm-ppc/unaligned.h | 16 +++ include/linux/lzo.h | 44 ++++++ include/linux/unaligned/access_ok.h | 66 ++++++++++ include/linux/unaligned/generic.h | 71 ++++++++++ lib_generic/lzo/Makefile | 46 +++++++ lib_generic/lzo/lzo1x_decompress.c | 245 +++++++++++++++++++++++++++++++++++ lib_generic/lzo/lzodefs.h | 43 ++++++ 8 files changed, 532 insertions(+), 0 deletions(-) create mode 100644 include/asm-ppc/unaligned.h create mode 100644 include/linux/lzo.h create mode 100644 include/linux/unaligned/access_ok.h create mode 100644 include/linux/unaligned/generic.h create mode 100644 lib_generic/lzo/Makefile create mode 100644 lib_generic/lzo/lzo1x_decompress.c create mode 100644 lib_generic/lzo/lzodefs.h
diff --git a/Makefile b/Makefile index a67cf15..a88f337 100644 --- a/Makefile +++ b/Makefile @@ -210,6 +210,7 @@ OBJS := $(addprefix $(obj),$(OBJS))
LIBS = lib_generic/libgeneric.a LIBS += lib_generic/lzma/liblzma.a +LIBS += lib_generic/lzo/liblzo.a LIBS += $(shell if [ -f board/$(VENDOR)/common/Makefile ]; then echo \ "board/$(VENDOR)/common/lib$(VENDOR).a"; fi) LIBS += cpu/$(CPU)/lib$(CPU).a diff --git a/include/asm-ppc/unaligned.h b/include/asm-ppc/unaligned.h new file mode 100644 index 0000000..5f1b1e3 --- /dev/null +++ b/include/asm-ppc/unaligned.h @@ -0,0 +1,16 @@ +#ifndef _ASM_POWERPC_UNALIGNED_H +#define _ASM_POWERPC_UNALIGNED_H + +#ifdef __KERNEL__ + +/* + * The PowerPC can do unaligned accesses itself in big endian mode. + */ +#include <linux/unaligned/access_ok.h> +#include <linux/unaligned/generic.h> + +#define get_unaligned __get_unaligned_be +#define put_unaligned __put_unaligned_be + +#endif /* __KERNEL__ */ +#endif /* _ASM_POWERPC_UNALIGNED_H */ diff --git a/include/linux/lzo.h b/include/linux/lzo.h new file mode 100644 index 0000000..d793497 --- /dev/null +++ b/include/linux/lzo.h @@ -0,0 +1,44 @@ +#ifndef __LZO_H__ +#define __LZO_H__ +/* + * LZO Public Kernel Interface + * A mini subset of the LZO real-time data compression library + * + * Copyright (C) 1996-2005 Markus F.X.J. Oberhumer markus@oberhumer.com + * + * The full LZO package can be found at: + * http://www.oberhumer.com/opensource/lzo/ + * + * Changed for kernel use by: + * Nitin Gupta nitingupta910@gmail.com + * Richard Purdie rpurdie@openedhand.com + */ + +#define LZO1X_MEM_COMPRESS (16384 * sizeof(unsigned char *)) +#define LZO1X_1_MEM_COMPRESS LZO1X_MEM_COMPRESS + +#define lzo1x_worst_compress(x) ((x) + ((x) / 16) + 64 + 3) + +/* This requires 'workmem' of size LZO1X_1_MEM_COMPRESS */ +int lzo1x_1_compress(const unsigned char *src, size_t src_len, + unsigned char *dst, size_t *dst_len, void *wrkmem); + +/* safe decompression with overrun testing */ +int lzo1x_decompress_safe(const unsigned char *src, size_t src_len, + unsigned char *dst, size_t *dst_len); + +/* + * Return values (< 0 = Error) + */ +#define LZO_E_OK 0 +#define LZO_E_ERROR (-1) +#define LZO_E_OUT_OF_MEMORY (-2) +#define LZO_E_NOT_COMPRESSIBLE (-3) +#define LZO_E_INPUT_OVERRUN (-4) +#define LZO_E_OUTPUT_OVERRUN (-5) +#define LZO_E_LOOKBEHIND_OVERRUN (-6) +#define LZO_E_EOF_NOT_FOUND (-7) +#define LZO_E_INPUT_NOT_CONSUMED (-8) +#define LZO_E_NOT_YET_IMPLEMENTED (-9) + +#endif diff --git a/include/linux/unaligned/access_ok.h b/include/linux/unaligned/access_ok.h new file mode 100644 index 0000000..5f46eee --- /dev/null +++ b/include/linux/unaligned/access_ok.h @@ -0,0 +1,66 @@ +#ifndef _LINUX_UNALIGNED_ACCESS_OK_H +#define _LINUX_UNALIGNED_ACCESS_OK_H + +#include <asm/byteorder.h> + +static inline u16 get_unaligned_le16(const void *p) +{ + return le16_to_cpup((__le16 *)p); +} + +static inline u32 get_unaligned_le32(const void *p) +{ + return le32_to_cpup((__le32 *)p); +} + +static inline u64 get_unaligned_le64(const void *p) +{ + return le64_to_cpup((__le64 *)p); +} + +static inline u16 get_unaligned_be16(const void *p) +{ + return be16_to_cpup((__be16 *)p); +} + +static inline u32 get_unaligned_be32(const void *p) +{ + return be32_to_cpup((__be32 *)p); +} + +static inline u64 get_unaligned_be64(const void *p) +{ + return be64_to_cpup((__be64 *)p); +} + +static inline void put_unaligned_le16(u16 val, void *p) +{ + *((__le16 *)p) = cpu_to_le16(val); +} + +static inline void put_unaligned_le32(u32 val, void *p) +{ + *((__le32 *)p) = cpu_to_le32(val); +} + +static inline void put_unaligned_le64(u64 val, void *p) +{ + *((__le64 *)p) = cpu_to_le64(val); +} + +static inline void put_unaligned_be16(u16 val, void *p) +{ + *((__be16 *)p) = cpu_to_be16(val); +} + +static inline void put_unaligned_be32(u32 val, void *p) +{ + *((__be32 *)p) = cpu_to_be32(val); +} + +static inline void put_unaligned_be64(u64 val, void *p) +{ + *((__be64 *)p) = cpu_to_be64(val); +} + +#endif /* _LINUX_UNALIGNED_ACCESS_OK_H */ diff --git a/include/linux/unaligned/generic.h b/include/linux/unaligned/generic.h new file mode 100644 index 0000000..cc688e1 --- /dev/null +++ b/include/linux/unaligned/generic.h @@ -0,0 +1,71 @@ +#ifndef _LINUX_UNALIGNED_GENERIC_H +#define _LINUX_UNALIGNED_GENERIC_H + +/* define __force to nothing in U-Boot */ +#define __force + +/* + * Cause a link-time error if we try an unaligned access other than + * 1,2,4 or 8 bytes long + */ +extern void __bad_unaligned_access_size(void); + +#define __get_unaligned_le(ptr) ((__force typeof(*(ptr)))({ \ + __builtin_choose_expr(sizeof(*(ptr)) == 1, *(ptr), \ + __builtin_choose_expr(sizeof(*(ptr)) == 2, get_unaligned_le16((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 4, get_unaligned_le32((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 8, get_unaligned_le64((ptr)), \ + __bad_unaligned_access_size())))); \ + })) + +#define __get_unaligned_be(ptr) ((__force typeof(*(ptr)))({ \ + __builtin_choose_expr(sizeof(*(ptr)) == 1, *(ptr), \ + __builtin_choose_expr(sizeof(*(ptr)) == 2, get_unaligned_be16((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 4, get_unaligned_be32((ptr)), \ + __builtin_choose_expr(sizeof(*(ptr)) == 8, get_unaligned_be64((ptr)), \ + __bad_unaligned_access_size())))); \ + })) + +#define __put_unaligned_le(val, ptr) ({ \ + void *__gu_p = (ptr); \ + switch (sizeof(*(ptr))) { \ + case 1: \ + *(u8 *)__gu_p = (__force u8)(val); \ + break; \ + case 2: \ + put_unaligned_le16((__force u16)(val), __gu_p); \ + break; \ + case 4: \ + put_unaligned_le32((__force u32)(val), __gu_p); \ + break; \ + case 8: \ + put_unaligned_le64((__force u64)(val), __gu_p); \ + break; \ + default: \ + __bad_unaligned_access_size(); \ + break; \ + } \ + (void)0; }) + +#define __put_unaligned_be(val, ptr) ({ \ + void *__gu_p = (ptr); \ + switch (sizeof(*(ptr))) { \ + case 1: \ + *(u8 *)__gu_p = (__force u8)(val); \ + break; \ + case 2: \ + put_unaligned_be16((__force u16)(val), __gu_p); \ + break; \ + case 4: \ + put_unaligned_be32((__force u32)(val), __gu_p); \ + break; \ + case 8: \ + put_unaligned_be64((__force u64)(val), __gu_p); \ + break; \ + default: \ + __bad_unaligned_access_size(); \ + break; \ + } \ + (void)0; }) + +#endif /* _LINUX_UNALIGNED_GENERIC_H */ diff --git a/lib_generic/lzo/Makefile b/lib_generic/lzo/Makefile new file mode 100644 index 0000000..5dd1bf5 --- /dev/null +++ b/lib_generic/lzo/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2008 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)liblzo.a + +SOBJS = + +COBJS-$(CONFIG_LZO) += lzo1x_decompress.o + +COBJS = $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/lib_generic/lzo/lzo1x_decompress.c b/lib_generic/lzo/lzo1x_decompress.c new file mode 100644 index 0000000..2780e11 --- /dev/null +++ b/lib_generic/lzo/lzo1x_decompress.c @@ -0,0 +1,245 @@ +/* + * LZO1X Decompressor from MiniLZO + * + * Copyright (C) 1996-2005 Markus F.X.J. Oberhumer markus@oberhumer.com + * + * The full LZO package can be found at: + * http://www.oberhumer.com/opensource/lzo/ + * + * Changed for kernel use by: + * Nitin Gupta nitingupta910@gmail.com + * Richard Purdie rpurdie@openedhand.com + */ + +#include <common.h> +#include <linux/lzo.h> +#include <asm/byteorder.h> +#include <asm/unaligned.h> +#include "lzodefs.h" + +#define HAVE_IP(x, ip_end, ip) ((size_t)(ip_end - ip) < (x)) +#define HAVE_OP(x, op_end, op) ((size_t)(op_end - op) < (x)) +#define HAVE_LB(m_pos, out, op) (m_pos < out || m_pos >= op) + +#define COPY4(dst, src) \ + put_unaligned(get_unaligned((const u32 *)(src)), (u32 *)(dst)) + +int lzo1x_decompress_safe(const unsigned char *in, size_t in_len, + unsigned char *out, size_t *out_len) +{ + const unsigned char * const ip_end = in + in_len; + unsigned char * const op_end = out + *out_len; + const unsigned char *ip = in, *m_pos; + unsigned char *op = out; + size_t t; + + *out_len = 0; + + if (*ip > 17) { + t = *ip++ - 17; + if (t < 4) + goto match_next; + if (HAVE_OP(t, op_end, op)) + goto output_overrun; + if (HAVE_IP(t + 1, ip_end, ip)) + goto input_overrun; + do { + *op++ = *ip++; + } while (--t > 0); + goto first_literal_run; + } + + while ((ip < ip_end)) { + t = *ip++; + if (t >= 16) + goto match; + if (t == 0) { + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + while (*ip == 0) { + t += 255; + ip++; + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + } + t += 15 + *ip++; + } + if (HAVE_OP(t + 3, op_end, op)) + goto output_overrun; + if (HAVE_IP(t + 4, ip_end, ip)) + goto input_overrun; + + COPY4(op, ip); + op += 4; + ip += 4; + if (--t > 0) { + if (t >= 4) { + do { + COPY4(op, ip); + op += 4; + ip += 4; + t -= 4; + } while (t >= 4); + if (t > 0) { + do { + *op++ = *ip++; + } while (--t > 0); + } + } else { + do { + *op++ = *ip++; + } while (--t > 0); + } + } + +first_literal_run: + t = *ip++; + if (t >= 16) + goto match; + m_pos = op - (1 + M2_MAX_OFFSET); + m_pos -= t >> 2; + m_pos -= *ip++ << 2; + + if (HAVE_LB(m_pos, out, op)) + goto lookbehind_overrun; + + if (HAVE_OP(3, op_end, op)) + goto output_overrun; + *op++ = *m_pos++; + *op++ = *m_pos++; + *op++ = *m_pos; + + goto match_done; + + do { +match: + if (t >= 64) { + m_pos = op - 1; + m_pos -= (t >> 2) & 7; + m_pos -= *ip++ << 3; + t = (t >> 5) - 1; + if (HAVE_LB(m_pos, out, op)) + goto lookbehind_overrun; + if (HAVE_OP(t + 3 - 1, op_end, op)) + goto output_overrun; + goto copy_match; + } else if (t >= 32) { + t &= 31; + if (t == 0) { + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + while (*ip == 0) { + t += 255; + ip++; + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + } + t += 31 + *ip++; + } + m_pos = op - 1; + m_pos -= get_unaligned_le16(ip) >> 2; + ip += 2; + } else if (t >= 16) { + m_pos = op; + m_pos -= (t & 8) << 11; + + t &= 7; + if (t == 0) { + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + while (*ip == 0) { + t += 255; + ip++; + if (HAVE_IP(1, ip_end, ip)) + goto input_overrun; + } + t += 7 + *ip++; + } + m_pos -= get_unaligned_le16(ip) >> 2; + ip += 2; + if (m_pos == op) + goto eof_found; + m_pos -= 0x4000; + } else { + m_pos = op - 1; + m_pos -= t >> 2; + m_pos -= *ip++ << 2; + + if (HAVE_LB(m_pos, out, op)) + goto lookbehind_overrun; + if (HAVE_OP(2, op_end, op)) + goto output_overrun; + + *op++ = *m_pos++; + *op++ = *m_pos; + goto match_done; + } + + if (HAVE_LB(m_pos, out, op)) + goto lookbehind_overrun; + if (HAVE_OP(t + 3 - 1, op_end, op)) + goto output_overrun; + + if (t >= 2 * 4 - (3 - 1) && (op - m_pos) >= 4) { + COPY4(op, m_pos); + op += 4; + m_pos += 4; + t -= 4 - (3 - 1); + do { + COPY4(op, m_pos); + op += 4; + m_pos += 4; + t -= 4; + } while (t >= 4); + if (t > 0) + do { + *op++ = *m_pos++; + } while (--t > 0); + } else { +copy_match: + *op++ = *m_pos++; + *op++ = *m_pos++; + do { + *op++ = *m_pos++; + } while (--t > 0); + } +match_done: + t = ip[-2] & 3; + if (t == 0) + break; +match_next: + if (HAVE_OP(t, op_end, op)) + goto output_overrun; + if (HAVE_IP(t + 1, ip_end, ip)) + goto input_overrun; + + *op++ = *ip++; + if (t > 1) { + *op++ = *ip++; + if (t > 2) + *op++ = *ip++; + } + + t = *ip++; + } while (ip < ip_end); + } + + *out_len = op - out; + return LZO_E_EOF_NOT_FOUND; + +eof_found: + *out_len = op - out; + return (ip == ip_end ? LZO_E_OK : + (ip < ip_end ? LZO_E_INPUT_NOT_CONSUMED : LZO_E_INPUT_OVERRUN)); +input_overrun: + *out_len = op - out; + return LZO_E_INPUT_OVERRUN; + +output_overrun: + *out_len = op - out; + return LZO_E_OUTPUT_OVERRUN; + +lookbehind_overrun: + *out_len = op - out; + return LZO_E_LOOKBEHIND_OVERRUN; +} diff --git a/lib_generic/lzo/lzodefs.h b/lib_generic/lzo/lzodefs.h new file mode 100644 index 0000000..b6d482c --- /dev/null +++ b/lib_generic/lzo/lzodefs.h @@ -0,0 +1,43 @@ +/* + * lzodefs.h -- architecture, OS and compiler specific defines + * + * Copyright (C) 1996-2005 Markus F.X.J. Oberhumer markus@oberhumer.com + * + * The full LZO package can be found at: + * http://www.oberhumer.com/opensource/lzo/ + * + * Changed for kernel use by: + * Nitin Gupta nitingupta910@gmail.com + * Richard Purdie rpurdie@openedhand.com + */ + +#define LZO_VERSION 0x2020 +#define LZO_VERSION_STRING "2.02" +#define LZO_VERSION_DATE "Oct 17 2005" + +#define M1_MAX_OFFSET 0x0400 +#define M2_MAX_OFFSET 0x0800 +#define M3_MAX_OFFSET 0x4000 +#define M4_MAX_OFFSET 0xbfff + +#define M1_MIN_LEN 2 +#define M1_MAX_LEN 2 +#define M2_MIN_LEN 3 +#define M2_MAX_LEN 8 +#define M3_MIN_LEN 3 +#define M3_MAX_LEN 33 +#define M4_MIN_LEN 3 +#define M4_MAX_LEN 9 + +#define M1_MARKER 0 +#define M2_MARKER 64 +#define M3_MARKER 32 +#define M4_MARKER 16 + +#define D_BITS 14 +#define D_MASK ((1u << D_BITS) - 1) +#define D_HIGH ((D_MASK >> 1) + 1) + +#define DX2(p, s1, s2) (((((size_t)((p)[2]) << (s2)) ^ (p)[1]) \ + << (s1)) ^ (p)[0]) +#define DX3(p, s1, s2, s3) ((DX2((p)+1, s2, s3) << (s1)) ^ (p)[0])
Stefan Roese
