[REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Hello Gaurav,
In the new v2022.07, I've stumbled upon the issue with calculating the SHA256 of memory blocks with CAAM hashing. This causes the FIT image not to pass the hash validation, and also `sha256` command not operable.
I'm also wondering if any i.MX8M-based board maintainers have seen the same issues at their end?
I've made a small test executing the following command sequence (with corresponding serial output):
U-Boot 2022.07 (Jul 15 2022 - 14:36:00 +0200)
CPU: Freescale i.MX8MMQ rev1.0 at 1200 MHz Reset cause: POR Model: FSL i.MX8MM EVK board DRAM: 2 GiB Core: 153 devices, 19 uclasses, devicetree: separate WDT: Started watchdog@30280000 with servicing (60s timeout) MMC: FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@30890000 Out: serial@30890000 Err: serial@30890000 SEC0: RNG instantiated Net: eth0: ethernet@30be0000 Hit any key to stop autoboot: 0 u-boot=> mw.b ${kernel_addr_r} DE 100 u-boot=> md.b ${kernel_addr_r} 100 40480000: dededede dededede dededede dededede ................ 40480010: dededede dededede dededede dededede ................ 40480020: dededede dededede dededede dededede ................ 40480030: dededede dededede dededede dededede ................ 40480040: dededede dededede dededede dededede ................ 40480050: dededede dededede dededede dededede ................ 40480060: dededede dededede dededede dededede ................ 40480070: dededede dededede dededede dededede ................ 40480080: dededede dededede dededede dededede ................ 40480090: dededede dededede dededede dededede ................ 404800a0: dededede dededede dededede dededede ................ 404800b0: dededede dededede dededede dededede ................ 404800c0: dededede dededede dededede dededede ................ 404800d0: dededede dededede dededede dededede ................ 404800e0: dededede dededede dededede dededede ................ 404800f0: dededede dededede dededede dededede ................
u-boot=> hash sha256 ${kernel_addr_r} 100 CAAM was not setup properly or it is faulty sha256 for 40480000 ... 404800ff ==> 736372697074616464727d0a626f6f745f6566695f62696e6172793d6c6f6164
Running `sha256` commands several times in a row also produces different Results, sometimes it comes out as all 0's.
For comparison purposes, I've did similar on the desktop: $ while true ; do printf "\xDE"; done | dd of=./test_data bs=1 count=256 256+0 records in 256+0 records out 256 bytes copied, 0.000484 s, 529 kB/s
$ hexdump -C -v ./test_data 00000000 de de de de de de de de de de de de de de de de |................| 00000010 de de de de de de de de de de de de de de de de |................| 00000020 de de de de de de de de de de de de de de de de |................| 00000030 de de de de de de de de de de de de de de de de |................| 00000040 de de de de de de de de de de de de de de de de |................| 00000050 de de de de de de de de de de de de de de de de |................| 00000060 de de de de de de de de de de de de de de de de |................| 00000070 de de de de de de de de de de de de de de de de |................| 00000080 de de de de de de de de de de de de de de de de |................| 00000090 de de de de de de de de de de de de de de de de |................| 000000a0 de de de de de de de de de de de de de de de de |................| 000000b0 de de de de de de de de de de de de de de de de |................| 000000c0 de de de de de de de de de de de de de de de de |................| 000000d0 de de de de de de de de de de de de de de de de |................| 000000e0 de de de de de de de de de de de de de de de de |................| 000000f0 de de de de de de de de de de de de de de de de |................| 00000100
$ sha256sum ./test_data 8b11bcdc65d5f1af0fa1edfa7b5db089dba40d4e8d29b455295d58ab2b314e76 ./test_data
As one can see, the SHA256 has a totally different value, with desktop produces a rather correct one.
Since the CAAM is enabled per default for all i.MX8M derivatives, there is no way to target SHA hash calculations back to SW implementation, therefore it blocks a lot of people to boot FIT images that has `hash` nodes in them.
Looking a bit deeper into why it fails, I saw that the JR used for hash calculations is hard-coded to `0` in run_descriptor_jr() call, which is now reserved in S-World for HAB operations. But changing it to `1` did not change the behavior, the SHA256 is still not calculated proper.
Can you please advise how this can be solved?
And more conceptually: why is SHA hashing now hardwired to HW CAAM module, while it was perfectly executed in SW via `lib/sha.c`?
Thanks a lot!
Regards, Andrey
Hello Andrey
There is a patch in review related caam hash. Please check if it fixes your problem. http://patchwork.ozlabs.org/project/uboot/patch/20220616101009.809953-1-gaur...
Regards Gaurav Jain
-----Original Message----- From: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Sent: Friday, July 15, 2022 6:11 PM To: Gaurav Jain gaurav.jain@nxp.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl-uboot-imx <uboot- imx@nxp.com> Subject: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Caution: EXT Email
Hello Gaurav,
Thanks a lot!
Regards, Andrey
Hello Gaurav,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, July 15, 2022 2:56 PM To: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl- uboot-imx uboot-imx@nxp.com Subject: RE: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Hello Andrey
There is a patch in review related caam hash. Please check if it fixes your problem. http://patchwork.ozlabs.org/project/uboot/patch/20220616101009.809953-1- gaurav.jain@nxp.com/
No, unfortunately this patch did not solve the issue, behavior is still the same.
Regards Gaurav Jain
Caution: EXT Email
Hello Gaurav,
Thanks a lot!
Regards, Andrey
-- andrey
Hello Andrey
Right now I am not sure what could cause the issue. As per our previous discussions, JR0 can not be used in uboot, so you need to mark it as disabled until kernel device tree is not sync. To debug more, can you run hash command with HASH_VERIFY.
Regards Gaurav Jain
-----Original Message----- From: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Sent: Friday, July 15, 2022 7:04 PM To: Gaurav Jain gaurav.jain@nxp.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl-uboot-imx <uboot- imx@nxp.com> Subject: RE: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Caution: EXT Email
Hello Gaurav,
Hello Andrey
There is a patch in review related caam hash. Please check if it fixes your problem. https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatch
work.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20220616101009.809953- 1-&a
mp;data=05%7C01%7Cgaurav.jain%40nxp.com%7C4e78116cfe2b4487fdc208 da6666
aa79%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637934888408 633266%7
CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJB TiI6Ik1
haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Dwe%2FOgeLeH mWD7tKcmmJbV
%2F0D5cOZvH3kpCx%2FO%2FvMRg%3D&reserved=0 gaurav.jain@nxp.com/
Regards Gaurav Jain
Simon
Caution: EXT Email
Hello Gaurav,
./test_data
proper.
Thanks a lot!
Regards, Andrey
-- andrey
Hello Gaurav,
Cc: Tom here for integration points.
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, July 15, 2022 4:01 PM To: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl- uboot-imx uboot-imx@nxp.com Subject: RE: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Hello Andrey
Actually, I've given this a try by setting `status = "disabled"` in sec_jr0 node, and then the hash calculation was working again!
This has puzzled me a lot, since JR ID used to enqueue the SHA hashing descriptor is hard-coded to `0`, see the [1] for code reference. I was expecting that the call would fail but it somehow worked, perhaps by picking up the JR which is not disabled (JR1?)...
This is a bit that needs more explanation, perhaps you can shed some light here on how this JR assignments are working in case when nodes are enabled/disabled?
Stefano/Tom,
From what I can see, since patch from Fabio [2] is planned for inclusion to linux-5.20.y (see [3] for PR) - it might be that the SHA computation will stay broken on i.MX8M derivatives until v2022.10 at least, or the HW hash computations are replaced with SW alternative until the JR configuration is not synced into U-Boot.
Any advice on how to proceed here? I guess this would affect some people who are relying on FIT boot via `bootm`...
This did not solve the problem when JR0 node was still enabled, and had no effect when I disabled the node.
Regards Gaurav Jain
Caution: EXT Email
Hello Gaurav,
Hello Andrey
same.
Regards Gaurav Jain
Simon
Caution: EXT Email
Hello Gaurav,
./test_data
proper.
Thanks a lot!
Regards, Andrey
-- andrey
Thanks a lot!
-- andrey
Link: [1]: https://source.denx.de/u-boot/u-boot/-/blob/master/drivers/crypto/fsl/jr.c#L... Link: [2]: https://lore.kernel.org/all/20220608170223.1536594-1-festevam@denx.de/ Link: [3]: https://lore.kernel.org/all/20220709082951.15123-5-shawnguo@kernel.org/
Hi Andrey,
On Fri, Jul 15, 2022 at 12:06 PM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
I will send a patch syncing imx8mm.dtsi from linux-next.
Hello Andrey
-----Original Message----- From: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Sent: Friday, July 15, 2022 8:36 PM To: Gaurav Jain gaurav.jain@nxp.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl-uboot-imx <uboot- imx@nxp.com>; trini trini@konsulko.com Subject: RE: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Caution: EXT Email
Hello Gaurav,
Hello Andrey
This is expected as caam driver will pick up the first jobring enabled in device tree.
Caam driver model approach was developed to initialize the caam based on jobring enabled in device tree. If driver model is not enabled then hardcoded JR0 will be used.
See the code drivers/crypto/fsl/jr.c , function caam_jr_probe(). This function checks for enabled job ring and initialize caam.
Regards Gaurav
Stefano/Tom,
Regards Gaurav Jain
Simon
Caution: EXT Email
Hello Gaurav,
Delaunay
Hello Andrey
There is a patch in review related caam hash. Please check if it fixes your problem. https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fp atch
1-&a
da6666
633266%7
TiI6Ik1
mWD7tKcmmJbV
same.
Regards Gaurav Jain
Simon
Caution: EXT Email
Hello Gaurav,
not operable.
./test_data
proper.
Thanks a lot!
Regards, Andrey
-- andrey
Thanks a lot!
-- andrey
Link: [1]: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsourc e.denx.de%2Fu-boot%2Fu-boot%2F- %2Fblob%2Fmaster%2Fdrivers%2Fcrypto%2Ffsl%2Fjr.c%23L372&data=0 5%7C01%7Cgaurav.jain%40nxp.com%7C351b3fc4ae864c5e579a08da6673901 2%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637934943776754 909%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luM zIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=G% 2FBsNqPCACQ5F8DoYgy7IOwgu1QZeUVei85gwKzhpaw%3D&reserved=0 Link: [2]: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flore.k ernel.org%2Fall%2F20220608170223.1536594-1- festevam%40denx.de%2F&data=05%7C01%7Cgaurav.jain%40nxp.com% 7C351b3fc4ae864c5e579a08da66739012%7C686ea1d3bc2b4c6fa92cd99c5c3 01635%7C0%7C0%7C637934943776754909%7CUnknown%7CTWFpbGZsb3d8 eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3 D%7C3000%7C%7C%7C&sdata=zQm7kQHuOyLfkfI2WFPJtl0YKtPhVFtUM s7BoCedGsY%3D&reserved=0 Link: [3]: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flore.k ernel.org%2Fall%2F20220709082951.15123-5- shawnguo%40kernel.org%2F&data=05%7C01%7Cgaurav.jain%40nxp.co m%7C351b3fc4ae864c5e579a08da66739012%7C686ea1d3bc2b4c6fa92cd99c 5c301635%7C0%7C0%7C637934943776754909%7CUnknown%7CTWFpbGZsb 3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0 %3D%7C3000%7C%7C%7C&sdata=geHpB6tnctt4dG5N8lhzlUJM31rj3T5b 9J8hkDgKVcc%3D&reserved=0
On 7/15/2022 11:06 PM, ZHIZHIKIN Andrey wrote:
Hello Gaurav,
Hello Andrey
Did you enable optee? If disabling sec_jr0 to make it work, i think there is issue somewhere.
With optee enabled, optee will take JR0. If optee not enabled, JR0 could be used by U-Boot.
Regards, Peng.
Stefano/Tom,
Regards Gaurav Jain
Caution: EXT Email
Hello Gaurav,
Hello Andrey
same.
Regards Gaurav Jain
Simon
Caution: EXT Email
Hello Gaurav,
./test_data
proper.
Thanks a lot!
Regards, Andrey
-- andrey
Thanks a lot!
-- andrey
I can't speak for Andrey, but no, I don't enable/use optee on my imx8mp.
Rasmus
Hello all,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Rasmus Villemoes Sent: Friday, October 14, 2022 7:50 PM To: Peng Fan peng.fan@oss.nxp.com; ZHIZHIKIN Andrey <andrey.zhizhikin@leica- geosystems.com>; Gaurav Jain gaurav.jain@nxp.com Cc: u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl- uboot-imx uboot-imx@nxp.com; trini trini@konsulko.com Subject: Re: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
I also do not have an OP-TEE in my setup, but since upstream TF-A commit 77850c96f23b ("feat(plat/imx8m): do not release JR0 to NS if HAB is using it") [1] this makes no difference, as JR0 would be permanently held in S-World.
Downstream fork has the same implementation done in commit 961f90418874 ("TEE-639 plat: imx8m: Do not release JR0 to NS if HAB is using it"), so it is now consistent behavior across upstream and downstream.
This means that JR0 has to be permanently disabled in the DTB, with Kernel being the first followed by the U-Boot sync.
This work has been already accomplished by Fabio in Kernel via commit dc9c1ceb555f ("arm64: dts: imx8m: Disable job ring 0 nodes") [3], and sync'd in for `imx8mm.dtsi` in commit 05996f350d48 ("imx8mm: Sync device tree with linux-next 20220711") [4].
`imx8mp.dtsi` however was not sync'd in, so the JR0 disabling is left out. :( This does explain why the SHA calculation are not operable for that SoC.
Rasmus
-- andrey
Link: [1]: http://git.trustedfirmware.org/TF-A/trusted-firmware-a.git/commit/?id=77850c... Link: [2]: https://source.codeaurora.org/external/imx/imx-atf/commit/plat/imx/imx8m/imx... Link: [3]: https://github.com/torvalds/linux/commit/dc9c1ceb555ff661e6fc1081434600771f2... Link: [4]: https://source.denx.de/u-boot/u-boot/-/commit/05996f350d482d2a450173ce3340ee...
Hi Andrey,
On Fri, Oct 14, 2022 at 3:53 PM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
Marcel has submitted the dts sync patch: https://lists.denx.de/pipermail/u-boot/2022-August/492834.html
Hello Fabio,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Fabio Estevam Sent: Friday, October 14, 2022 9:38 PM To: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk; Peng Fan peng.fan@oss.nxp.com; Gaurav Jain gaurav.jain@nxp.com; u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl- uboot-imx uboot-imx@nxp.com; trini trini@konsulko.com Subject: Re: [EXT] [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Hi Andrey,
Yes, but this was not picked up... At least, I do not see it applied on the master.
From the entire series [1], the patch that shall solve the issue is [2], and it is the one I do not see applied onto master.
Regards, Andrey
Link: [1]: https://lore.kernel.org/u-boot/20220826183141.789236-1-marcel@ziswiler.com/ Link: [2]: https://lore.kernel.org/u-boot/20220826183141.789236-7-marcel@ziswiler.com/
Hi Andrey,
On Sun, Oct 16, 2022 at 7:17 AM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
Correct. Hopefully, Stefano can apply it for 2023.01.
Regards,
Fabio Estevam
On 15/07/2022 14.40, ZHIZHIKIN Andrey wrote:
Hello Gaurav,
This is still broken in v2022.10. Are there any plans to fix this?
Booting FIT images where image nodes are hashed with sha1 or sha256 on imx8m boards is currently impossible.
Rasmus
Hi Rasmus,
On Mon, Oct 10, 2022 at 11:07 AM Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
If I recall correctly the fix for this issue is to sync imx8m dts files with Linux so that the following commit can be in place: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?h...
Marcel submitted some imx8m dtsi sync patches, which should address this failure.
Hi Fabio
Thanks for the patch information. @Rasmus Villemoes I hope this fixed your problem?
Regards Gaurav Jain
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Monday, October 10, 2022 7:45 PM To: Rasmus Villemoes rasmus.villemoes@prevas.dk; Marcel Ziswiler marcel.ziswiler@toradex.com Cc: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com; Gaurav Jain gaurav.jain@nxp.com; u-boot@lists.denx.de; festevam@denx.de; sbabic@denx.de; Michael Walle michael@walle.cc; Tommaso Merciai tommaso.merciai@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Marek Vasut marex@denx.de; Simon Glass sjg@chromium.org; Patrick Delaunay patrick.delaunay@foss.st.com; Stefan Roese sr@denx.de; Horia Geanta horia.geanta@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com; dl-uboot-imx <uboot- imx@nxp.com> Subject: [EXT] Re: [REGRESSION]: v2022.07: SHA256 hash is broken on imx8m series with CAAM enabled
Caution: EXT Email
Hi Rasmus,
If I recall correctly the fix for this issue is to sync imx8m dts files with Linux so that the following commit can be in place: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgit.ker nel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2F commit%2F%3Fh%3Dv6.0%26id%3Ddc9c1ceb555ff661e6fc1081434600771f29 657c&data=05%7C01%7Cgaurav.jain%40nxp.com%7Ce5f346e2f2024b08 83ab08daaac9e5c7%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6 38010081361514213%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwM DAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7 C&sdata=oEYSt8zYXlvu0mfmmop76Eshz0WKySE%2Buk6D3MKgpRM%3 D&reserved=0
On 13/10/2022 08.20, Gaurav Jain wrote:
Hi Fabio
Sort of, kind of. I monkey-patched arch/arm/dts/imx8mp-u-boot.dtsi to include that
+&sec_jr0 { + status = "disabled"; +}; +
because I don't want to do the much more invasive thing of sync'ing imx8mp.dtsi proper with linux master. So yes, the pointers did lead me to a local fix, and one that I can hopefully rip out again with the next U-Boot release.
Rasmus
participants (5)
Fabio Estevam
Gaurav Jain
Peng Fan
Rasmus Villemoes
ZHIZHIKIN Andrey
