[U-Boot] [PATCH v3] arm, arm-kirkwood: disable l2c before linux boot
The decompressor expects the L2 cache to be disabled. This fixes booting some kernels, which have CONFIG_ARM_PATCH_PHYS_VIRT enabled.
Signed-off-by: Michael Walle michael@walle.cc Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Wolfgang Denk wd@denx.de --- v3: remove unused enable function
v2: replace magic number with macro
arch/arm/cpu/arm926ejs/cache.c | 9 ++++++++ arch/arm/cpu/arm926ejs/cpu.c | 2 + arch/arm/cpu/arm926ejs/kirkwood/Makefile | 1 + arch/arm/cpu/arm926ejs/kirkwood/cache.c | 34 ++++++++++++++++++++++++++++++ 4 files changed, 46 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/kirkwood/cache.c
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index ee90ab7..504f604 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -68,3 +68,12 @@ void flush_cache(unsigned long start, unsigned long size) { } #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */ + +/* + * Stub implementations for l2 cache operations + */ +void __l2_cache_disable(void) +{ +} +void l2_cache_disable(void) + __attribute__((weak, alias("__l2_cache_disable"))); diff --git a/arch/arm/cpu/arm926ejs/cpu.c b/arch/arm/cpu/arm926ejs/cpu.c index 5c902df..626384c 100644 --- a/arch/arm/cpu/arm926ejs/cpu.c +++ b/arch/arm/cpu/arm926ejs/cpu.c @@ -50,6 +50,8 @@ int cleanup_before_linux (void) /* turn off I/D-cache */ icache_disable(); dcache_disable(); + l2_cache_disable(); + /* flush I/D-cache */ cache_flush();
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/Makefile b/arch/arm/cpu/arm926ejs/kirkwood/Makefile index 0754297..777006c 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/Makefile +++ b/arch/arm/cpu/arm926ejs/kirkwood/Makefile @@ -30,6 +30,7 @@ COBJS-y = cpu.o COBJS-y += dram.o COBJS-y += mpp.o COBJS-y += timer.o +COBJS-y += cache.o
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cache.c b/arch/arm/cpu/arm926ejs/kirkwood/cache.c new file mode 100644 index 0000000..3e73565 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/kirkwood/cache.c @@ -0,0 +1,34 @@ +/* + * Copyright (c) 2011 Michael Walle + * Michael Walle michael@walle.cc + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +#include <common.h> +#include <asm/arch/cpu.h> + +#define FEROCEON_EXTRA_FEATURE_L2C_EN (1<<22) + +void l2_cache_disable() +{ + u32 ctrl; + + ctrl = readfr_extra_feature_reg(); + ctrl &= ~FEROCEON_EXTRA_FEATURE_L2C_EN; + writefr_extra_feature_reg(ctrl); +}
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: 01 February 2012 04:53 To: u-boot@lists.denx.de Cc: Michael Walle; Albert ARIBAUD; Prafulla Wadaskar; Wolfgang Denk Subject: [PATCH v3] arm, arm-kirkwood: disable l2c before linux boot
- Stub implementations for l2 cache operations
- l2_cache_disable();
- /* flush I/D-cache */ cache_flush();
- Copyright (c) 2011 Michael Walle
Please change this to 2012, otherwise ack for rest of the patch.
Regards.. Prafulla . . .
Michael Walle
Prafulla Wadaskar
